path: root/drivers/acpi/acpica/evxface.c
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-10ACPICA: Cleanup indentation to reduce differences between Linux and ACPICA.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 210 lines of 20121018 divergence.diff. The ACPICA source codes uses a totally different indentation style from the Linux to be compatible with other users (operating systems or BIOS). Indentation differences are critical to the release automation. There are two causes related to the "indentation" that are affecting the release automation: 1. The ACPICA -> Linux release process is: ACPICA source -- acpisrc - hierarchy - indent -> linuxized ACPICA source -- diff -> linuxized ACPICA patch (x) -- human intervention -> linuxized ACPICA patch (o) Where 'x' means "cannot be directly applied to the Linux" 'o' means "can be directly applied to the Linux" Different "indent" version or "indent" options used in the "indent" step will lead to different divergences. The version of "indent" used for the current release process is: GNU indent 2.2.11 The options of "indent" used for the current release process is: -npro -kr -i8 -ts8 -sob -l80 -ss -ncs 2. Manual indentation prettifying work in the Linux side will also harm the automatically generated linuxized ACPICA patches, making them impossible to apply directly. This patch fixes source code differences caused by the two causes so that the "human intervention" can be reduced in the future. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-10ACPICA: Cleanup updated comments.Lv Zheng
This is a cosmetic patch only. Comparison of the resulting binary showed only line number differences. This patch does not affect the generation of the Linux binary. This patch decreases 558 lines of 20121018 divergence.diff. This patch reduces the source code diff between Linux and ACPICA by cleaning the comments that already have been updated in ACPICA. There is no extra indentation done in this patch. Even the empty line deletions and insertions are also splitted into another cleanup patch so that this patch can be easily reviewed, and the binary differences can be held to a lowest level. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix AcpiSrc caused divergences.Lv Zheng
There are definitions that can been converted into new styles by the recent AcpiSrc while they remain the old styles in the Linux. This patch fixes those definitions that will be converted by the AcpiSrc. This patch will not affect the generated vmlinux binary. This will decrease 97 lines of 20120913 divergence.diff. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-07-17ACPICA: AcpiSrc: Fix some translation issues for Linux conversionBob Moore
Fixes issues like this: i_aSL -> iASL 00-7_f -> 00-7F local_fADT -> local_FADT execute_oSI -> execute_OSI Also, in function headers, the parameters are now translated to lower case (with underscores if necessary.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-01ACPICA: Remove argument of acpi_os_wait_events_completeLin Ming
Remove the unused argument of acpi_os_wait_events_complete. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-06-01ACPICA: Add support for multiple notify handlersBob Moore
This change adds support to allow multiple notify handlers on Device, ThermalZone, and Processor objects. Also re-worked and restructured the entire notify support code for handler installation, handler removal, notify event queuing, and notify dispatch to handler. Extends and updates original commit 3f0be67("ACPI / ACPICA: Multiple system notify handlers per device") by Rafael Wysocki. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-22ACPICA: Support for custom ACPICA build for ACPI 5 reduced hardwareBob Moore
Add ACPI_REDUCED_HARDWARE flag that removes all hardware-related code (about 10% code, 5% static data). Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Update all copyrights to 2012Bob Moore
Update all copyrights to 2012. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-10-31acpi: add export.h to files using THIS_MODULE/EXPORT_SYMBOLPaul Gortmaker
These files were relying on module.h to come in via the path in an include/acpi header file, but we don't want to have instances of module.h being included from include/* files if it can be avoided. Have the files include export.h instead. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2011-01-12ACPICA: Global event handlerLin Ming
The global event handler is called whenever a general purpose or fixed ACPI event occurs. Also update Linux OSL to collect events counter with global event handler. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: New GPE handler callback definitionLin Ming
The new GPE handler callback has 2 additional parameters, gpe_device and gpe_number. typedef u32 (*acpi_gpe_handler) (acpi_handle gpe_device, u32 gpe_number, void *context); Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-12ACPICA: Rename some function and variable namesLin Ming
Some function and variable names are renamed to be consistent with ACPICA code base. acpi_raw_enable_gpe -> acpi_ev_add_gpe_reference acpi_raw_disable_gpe -> acpi_ev_remove_gpe_reference acpi_gpe_can_wake -> acpi_setup_gpe_for_wake acpi_gpe_wakeup -> acpi_set_gpe_wake_mask acpi_update_gpes -> acpi_update_all_gpes acpi_all_gpes_initialized -> acpi_gbl_all_gpes_initialized acpi_handler_info -> acpi_gpe_handler_info ... Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-24ACPI / ACPICA: Defer enabling of runtime GPEs (v3)Rafael J. Wysocki
The current ACPI GPEs initialization code has a problem that it enables some GPEs pointed to by device _PRW methods, generally intended for signaling wakeup events (system or device wakeup). These GPEs are then almost immediately disabled by the ACPI namespace scanning code with the help of acpi_gpe_can_wake(), but it would be better not to enable them at all until really necessary. Modify the initialization of GPEs so that the ones that have associated _Lxx or _Exx methods and are not pointed to by any _PRW methods will be enabled after the namespace scan is complete. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-07ACPI / ACPICA: Fix reference counting problems with GPE handlersRafael J. Wysocki
If a handler is installed for a GPE associated with an AML method and such that it cannot wake up the system from sleep states, the GPE remains enabled after the handler has been installed, although it should be disabled in that case to avoid spurious execution of the handler. Fix this issue by making acpi_install_gpe_handler() disable GPEs that were previously associated with AML methods and cannot wake up the system from sleep states. Analogously, make acpi_remove_gpe_handler() enable the GPEs that are associated with AML methods after their handlers have been removed and cannot wake up the system from sleep states. In addition to that, fix a code ordering issue in acpi_remove_gpe_handler() that renders the locking ineffective (ACPI_MTX_EVENTS is released temporarily in the middle of the routine to wait for the completion of events already in progress). For this purpose introduce acpi_raw_disable_gpe() and acpi_raw_enable_gpe() to be called with acpi_gbl_gpe_lock held and rework acpi_disable_gpe() and acpi_enable_gpe(), respectively, to use them. Also rework acpi_gpe_can_wake() to use acpi_raw_disable_gpe() instead of calling acpi_disable_gpe() after releasing the lock to avoid the possible theoretical race with acpi_install_gpe_handler(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: "Moore, Robert" <robert.moore@intel.com> Cc: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-06-11ACPI / ACPICA: Do not attempt to disable GPE when installing handlerRafael J. Wysocki
Commit 0f849d2cc6863c7874889ea60a871fb71399dd3f (ACPICA: Minimize the differences between linux GPE code and ACPICA code base) introduced a change attempting to disable a GPE before installing a handler for it in acpi_install_gpe_handler() which was incorrect. First, the GPE disabled by it is never enabled again (except during resume) which leads to battery insert/remove events not being reported on the Maxim Levitsky's machine. Second, the disabled GPE is still reported as enabled by the sysfs interface that only checks its enable register's enable_for_run mask. Revert this change for now, because it causes more damage to happen than the bug it was supposed to fix. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-20ACPICA: Minimize the differences between linux GPE code and ACPICA code baseLin Ming
We have ported Rafael's major GPE changes (ACPI: Use GPE reference counting to support shared GPEs) into ACPICA code base. But the port and Rafael's original patch have some differences, so we made below patch to make linux GPE code consistent with ACPICA code base. Most changes are about comments and coding styles. Other noticeable changes are based on: Rafael: Reduce code duplication related to GPE lookup https://patchwork.kernel.org/patch/86237/ Rafael: Always use the same lock for GPE locking https://patchwork.kernel.org/patch/90471/ A new field gpe_count in struct acpi_gpe_block_info to record the number of individual GPEs in block. Rename acpi_ev_save_method_info to acpi_ev_match_gpe_method. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-20ACPICA: Standardize integer output for ACPICA warnings/errorsBob Moore
Always use 0x prefix for hex output, use %u for integer output (all integers are unsigned.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-01Merge branch 'acpica' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: replace acpi_integer by u64 ACPICA: Update version to 20100121. ACPICA: Remove unused uint32_struct type ACPICA: Disassembler: Remove obsolete "Integer64" field in parse object ACPICA: Remove obsolete ACPI_INTEGER (acpi_integer) type ACPICA: Predefined name repair: fix NULL package elements ACPICA: AcpiGetDevices: Eliminate unnecessary _STA calls ACPICA: Update all ACPICA copyrights and signons to 2010 ACPICA: Update for new gcc-4 warning options
2010-02-22ACPI / ACPICA: Multiple system notify handlers per deviceRafael J. Wysocki
Currently it only is possible to install one system notify handler per namespace node, but this is not enough for PCI run-time power management, because we need to install power management notifiers for devices that already have hotplug notifiers installed. While in principle this could be handled at the PCI level, that would be suboptimal due to the way in which the ACPI-based PCI hotplug code is designed. For this reason, modify ACPICA so that it is possible to install more than one system notify handler per namespace node. Namely, make acpi_install_notify_handler(), acpi_remove_notify_handler() and acpi_ev_notify_dispatch() use a list of system notify handler objects associated with a namespace node. Make acpi_remove_notify_handler() call acpi_os_wait_events_complete() upfront to avoid a situation in which concurrent instance of acpi_remove_notify_handler() removes the handler from under us while we're waiting for the event queues to flush. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22ACPI: Use GPE reference counting to support shared GPEsRafael J. Wysocki
ACPI GPEs may map to multiple devices. The current GPE interface only provides a mechanism for enabling and disabling GPEs, making it difficult to change the state of GPEs at runtime without extensive cooperation between devices. Add an API to allow devices to indicate whether or not they want their device's GPE to be enabled for both runtime and wakeup events. Remove the old GPE type handling entirely, which gets rid of various quirks, like the implicit disabling with GPE type setting. This requires a small amount of rework in order to ensure that non-wake GPEs are enabled by default to preserve existing behaviour. Based on patches from Matthew Garrett <mjg@redhat.com>. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15ACPICA: Update internal namespace node/handle interfacesBob Moore
This change deletes the unnecessary acpi_ns_convert_entry_to_handle interface and renames the acpi_ns_map_handle_to_node interface to acpi_ns_validate_handle. ACPICA BZ 798. http://www.acpica.org/bugzilla/show_bug.cgi?id=798 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-03-27ACPICA: Formatting update - no functional changesBob Moore
Split long lines, update comments. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09ACPICA: hide private headersLen Brown
2009-01-09ACPICA: create acpica/ directoryLen Brown
also, delete sleep/ and delete ACPI_CFLAGS from Makefile Signed-off-by: Len Brown <len.brown@intel.com>
