path: root/drivers/acpi/acpica/dswstate.c
2016-05-05ACPICA: Divergence: remove unwanted spaces for typedefLv Zheng
ACPICA commit b2294cae776f5a66a7697414b21949d307e6856f This patch removes unwanted spaces for typedef. This solution doesn't cover function types. Note that the linuxize result of this commit is very giant and should have many conflicts against the current Linux upstream. Thus it is required to modify the linuxize result of this commit and the commits around it manually in order to have them merged to the Linux upstream. Since this is very costy, we should do this only once, and if we can't ensure to do this only once, we need to revert the Linux code to the wrong indentation result before merging the linuxize result of this commit. Lv Zheng. Link: https://github.com/acpica/acpica/commit/b2294cae Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-01-15ACPICA: Additional 2016 copyright changesBob Moore
All tool/utility signons. Dual-license module header. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-02-05ACPICA: Update Copyright headers to 2015David E. Box
ACPICA commit 8990e73ab2aa15d6a0068b860ab54feff25bee36 Link: https://github.com/acpica/acpica/commit/8990e73a Signed-off-by: David E. Box <david.e.box@linux.intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-02-11ACPICA: Update ACPICA copyrights to 2014.Bob Moore
Update ACPICA copyrights to 2014. Includes all source headers and signons for the various tools. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-01-25ACPICA: Update ACPICA copyrights to 2013Bob Moore
2012-11-15ACPICA: Remove extra spaces after periods within commentsBob Moore
This makes all comments consistent. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Audit/update for ACPICA return macros and debug depth counterBob Moore
1) Ensure that all functions that use the various TRACE macros also use the appropriate ACPICA return macros. 2) Ensure that all normal return statements surround the return expression (value) with parens. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-15ACPICA: Fix indent caused divergences.Lv Zheng
New version of "indent" program will generate different outputs that will lead to the divergences between the Linux and the ACPICA. This patch fixes such divergences caused by the "indent" program. The version of the "indent" used for this patch is "GNU indent 2.2.11". This patch will not affect the generated vmlinux binary. This will decrease 581 lines of 20120913 divergence.diff. Signed-off-by: Robert Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-07-17ACPICA: AcpiSrc: Fix some translation issues for Linux conversionBob Moore
Fixes issues like this: i_aSL -> iASL 00-7_f -> 00-7F local_fADT -> local_FADT execute_oSI -> execute_OSI Also, in function headers, the parameters are now translated to lower case (with underscores if necessary.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-01-17ACPICA: Update all copyrights to 2012Bob Moore
Update all copyrights to 2012. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-01-18ACPICA: Update all ACPICA copyrights and signons to 2011Bob Moore
2010-04-20ACPICA: Standardize integer output for ACPICA warnings/errorsBob Moore
Always use 0x prefix for hex output, use %u for integer output (all integers are unsigned.) Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-01-22ACPICA: Update all ACPICA copyrights and signons to 2010Bob Moore
Add 2010 copyright to all module headers and signons, including the Linux header. This affects virtually every file in the ACPICA core subsystem, iASL compiler, and all utilities. Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-05-27ACPICA: Fix miscellaneous warnings under gcc 4+Bob Moore
Some possible warnings with gcc 4+, especially with extended warnings enabled Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-09ACPICA: hide private headersLen Brown
2009-01-09ACPICA: create acpica/ directoryLen Brown
also, delete sleep/ and delete ACPI_CFLAGS from Makefile Signed-off-by: Len Brown <len.brown@intel.com>
