path: root/drivers/acpi/Makefile
2007-02-16ACPI: hotkey: remove driver, per feature-removal-schedule.txtLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03Pull motherboard into test branchLen Brown
Conflicts: drivers/acpi/motherboard.c Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03Pull sysfs into test branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt include/acpi/acpi_drivers.h Signed-off-by: Len Brown <len.brown@intel.com>
2007-02-03ACPI: bay: new driver adding removable drive bay supportKristen Carlson Accardi
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-01-26ACPI: remove motherboard driver (redundant with PNP system driver)Bjorn Helgaas
The PNP system board driver (drivers/pnp/system.c) contains all the same functionality, so we don't need the ACPI version. Previously, a motherboard device would be claimed by *both* the ACPI and PNP drivers, resulting in stuff like this in /proc/ioports: 1200-121f : motherboard <-- from drivers/acpi/motherboard.c 1200-121f : pnp 00:0d <-- from drivers/pnp/system.c Make sure to enable CONFIG_PNP (and CONFIG_PNPACPI) to include the PNP system board driver. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-12-15ACPI: adjust init orderLi Shaohua
Adjust link order to add ACPI devices to global list before PCI devices. In addition, acpi_bus type must be initialized before any driver loads. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2006-07-09Revert "Revert "ACPI: dock driver""Len Brown
This reverts 953969ddf5b049361ed1e8471cc43dc4134d2a6f commit.
2006-07-09Revert "ACPI: dock driver"Linus Torvalds
This reverts commit a5e1b94008f2a96abf4a0c0371a55a56b320c13e. Adrian Bunk points out that it has build errors, and apparently no maintenance. Throw it out. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01ACPI: add support for Smart BatteryRich Townsend
Most batteries today are ACPI "Control Method" batteries, but some models ship with the older "Smart Battery" that requires this code. Rich Townsend and Bruno Ducrot were the original authors. Vladimir Lebedev updated to run on latest kernel. http://bugzilla.kernel.org/show_bug.cgi?id=3734 Signed-off-by: Len Brown <len.brown@intel.com>
2006-06-28ACPI: dock driverKristen Accardi
Create a driver which lives in the acpi subsystem to handle dock events. This driver is not an "ACPI" driver, because acpi drivers require that the object be present when the driver is loaded. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Len Brown <len.brown@intel.com>
2005-11-30[ACPI] IA64 build: blacklist.c is used only on X86Al Viro
Signed-off-by: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Len Brown <len.brown@intel.com> (cherry picked from ef4611613657dfb8af8d336f2f61f08cfcdc9d8a commit)
2005-08-25[ACPI] delete CONFIG_ACPI_PCILen Brown
Delete the ability to build an ACPI kernel that does not include PCI support. When such a machine is created and it requires a tuned kernel, send a patch. http://bugzilla.kernel.org/show_bug.cgi?id=1364 Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-24[ACPI] delete CONFIG_ACPI_BUSLen Brown
it is a synonym for CONFIG_ACPI Signed-off-by: Len Brown <len.brown@intel.com>
2005-08-24[ACPI] delete CONFIG_ACPI_INTERPRETERLen Brown
2005-08-24[ACPI] delete CONFIG_ACPI_BOOTLen Brown
it has been a synonym for CONFIG_ACPI since 2.6.12 Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] Bind PCI devices with ACPI devicesDavid Shaohua Li
Implement the framework for binding physical devices with ACPI devices. A physical bus like PCI bus should create a 'acpi_bus_type', with: .find_device: For device which has parent such as normal PCI devices. .find_bridge: It's for special devices, such as PCI root bridge or IDE controller. Such devices generally haven't a parent or ->bus. We use the special method to get an ACPI handle. Uses new field in struct device: firmware_data http://bugzilla.kernel.org/show_bug.cgi?id=4277 Signed-off-by: David Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-11[ACPI] generic Hot Key supportLuming Yu
See Documentation/acpi-hotkey.txt Use cmdline "acpi_specific_hotkey" to enable legacy platform specific drivers. http://bugzilla.kernel.org/show_bug.cgi?id=3887 Signed-off-by: Luming Yu <luming.yu@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
