for MX platforms. Drivers include: Digital Audio Mux (DAM),
MPEG4, Image Processing Unit (IPU), Power Management, SSI, and
VPU (Video Processing Unit) drivers.
http://www.bitshrine.org/gpp/linux-2.6.22-mx-drivers_mxc.patch
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'juju' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (138 commits)
firewire: Convert OHCI driver to use standard goto unwinding for error handling.
firewire: Always use parens with sizeof.
firewire: Drop single buffer request support.
firewire: Add a comment to describe why we split the sg list.
firewire: Return SCSI_MLQUEUE_HOST_BUSY for out of memory cases in queuecommand.
firewire: Handle the last few DMA mapping error cases.
firewire: Allocate scsi_host up front and allocate the sbp2_device as hostdata.
firewire: Provide module aliase for backwards compatibility.
firewire: Add to fw-core-y instead of assigning fw-core-objs in Makefile.
firewire: Break out shared IEEE1394 constant to separate header file.
firewire: Use linux/*.h instead of asm/*.h header files.
firewire: Uppercase most macro names.
firewire: Coding style cleanup: no spaces after function names.
firewire: Convert card_rwsem to a regular mutex.
firewire: Clean up comment style.
firewire: Use lib/ implementation of CRC ITU-T.
CRC ITU-T V.41
firewire: Rename fw-device-cdev.c to fw-cdev.c and move header to include/linux.
firewire: Future proof the iso ioctls by adding a handle for the iso context.
firewire: Add read/write and size annotations to IOC numbers.
Acked-by: Christoph Hellwig <hch@infradead.org>
This provides partial support for new-style I2C driver binding. It builds
on "struct i2c_board_info" declarations that identify I2C devices on a given
board. This is needed on systems with I2C devices that can't be fully probed
and/or autoconfigured, such as many embedded Linux configurations where the
way a given I2C device is wired may affect how it must be used.
There are two models for declaring such devices:
* LATE -- using a public function i2c_new_device(). This lets modules
declare I2C devices found *AFTER* a given I2C adapter becomes available.
For example, a PCI card could create adapters giving access to utility
chips on that card, and this would be used to associate those chips with
those adapters.
* EARLY -- from arch_initcall() level code, using a non-exported function
i2c_register_board_info(). This copies the declarations *BEFORE* such
an i2c_adapter becomes available, arranging that i2c_new_device() will
be called later when i2c-core registers the relevant i2c_adapter.
For example, arch/.../.../board-*.c files would declare the I2C devices
along with their platform data, and I2C devices would behave much like
PNPACPI devices. (That is, both enumerate from board-specific tables.)
To match the exported i2c_new_device(), the previously-private function
i2c_unregister_device() is now exported.
Pending later patches using these new APIs, this is effectively a NOP.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Since commit b1c1b6a3 ("IB/ipath: merge ipath_core and ib_ipath
drivers"), CONFIG_IPATH_CORE no longer exists, so there's no reason to
have a line for it in drivers/Makefile.
Pointed out by Robert P. J. Day <rpjday@mindspring.com>.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
to avoid confusion with CONFIG_FW_LOADER.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Acked-by: Kristian Høgsberg <krh@redhat.com>
Signed-off-by: Kristian Høgsberg <krh@redhat.com>
Add support for auxiliary displays, the ks0108 LCD controller, the
cfag12864b LCD and adds a framebuffer device: cfag12864bfb.
- Add a "auxdisplay/" folder in "drivers/" for auxiliary display
drivers.
- Add support for the ks0108 LCD Controller as a device driver. (uses
parport interface)
- Add support for the cfag12864b LCD as a device driver. (uses ks0108
LCD Controller driver)
- Add a framebuffer device called cfag12864bfb. (uses cfag12864b LCD
driver)
- Add the usual Documentation, includes, Makefiles, Kconfigs,
MAINTAINERS, CREDITS...
- Miguel Ojeda will maintain all the stuff above.
[rdunlap@xenotime.net: workqueue fixups]
[akpm@osdl.org: kconfig fix]
Signed-off-by: Miguel Ojeda Sandonis <maxextreme@gmail.com>
Cc: Greg KH <greg@kroah.com>
Acked-by: Paulo Marques <pmarques@grupopie.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
As macbook/macbook pro's also have to live with a single mouse button the
following patch just enables the Macintosh device drivers menu in Kconfig +
adds the macintosh dir to the obj-* to make macbook* users happy (who use
exactly that since months....
Signed-off-by: Soeren Sonnenburg <kernel@nn7.de>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: <stable@kernel.org>
web site: http://kvm.sourceforge.net
mailing list: kvm-devel@lists.sourceforge.net
(http://lists.sourceforge.net/lists/listinfo/kvm-devel)
The following patchset adds a driver for Intel's hardware virtualization
extensions to the x86 architecture. The driver adds a character device
(/dev/kvm) that exposes the virtualization capabilities to userspace. Using
this driver, a process can run a virtual machine (a "guest") in a fully
virtualized PC containing its own virtual hard disks, network adapters, and
display.
Using this driver, one can start multiple virtual machines on a host.
Each virtual machine is a process on the host; a virtual cpu is a thread in
that process. kill(1), nice(1), top(1) work as expected. In effect, the
driver adds a third execution mode to the existing two: we now have kernel
mode, user mode, and guest mode. Guest mode has its own address space mapping
guest physical memory (which is accessible to user mode by mmap()ing
/dev/kvm). Guest mode has no access to any I/O devices; any such access is
intercepted and directed to user mode for emulation.
The driver supports i386 and x86_64 hosts and guests. All combinations are
allowed except x86_64 guest on i386 host. For i386 guests and hosts, both pae
and non-pae paging modes are supported.
SMP hosts and UP guests are supported. At the moment only Intel
hardware is supported, but AMD virtualization support is being worked on.
Performance currently is non-stellar due to the naive implementation of the
mmu virtualization, which throws away most of the shadow page table entries
every context switch. We plan to address this in two ways:
- cache shadow page tables across tlb flushes
- wait until AMD and Intel release processors with nested page tables
Currently a virtual desktop is responsive but consumes a lot of CPU. Under
Windows I tried playing pinball and watching a few flash movies; with a recent
CPU one can hardly feel the virtualization. Linux/X is slower, probably due
to X being in a separate process.
In addition to the driver, you need a slightly modified qemu to provide I/O
device emulation and the BIOS.
Caveats (akpm: might no longer be true):
- The Windows install currently bluescreens due to a problem with the
virtual APIC. We are working on a fix. A temporary workaround is to
use an existing image or install through qemu
- Windows 64-bit does not work. That's also true for qemu, so it's
probably a problem with the device model.
[bero@arklinux.org: build fix]
[simon.kagstrom@bth.se: build fix, other fixes]
[uril@qumranet.com: KVM: Expose interrupt bitmap]
[akpm@osdl.org: i386 build fix]
[mingo@elte.hu: i386 fixes]
[rdreier@cisco.com: add log levels to all printks]
[randy.dunlap@oracle.com: Fix sparse NULL and C99 struct init warnings]
[anthony@codemonkey.ws: KVM: AMD SVM: 32-bit host support]
Signed-off-by: Yaniv Kamay <yaniv@qumranet.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
Cc: Simon Kagstrom <simon.kagstrom@bth.se>
Cc: Bernhard Rosenkraenzer <bero@arklinux.org>
Signed-off-by: Uri Lublin <uril@qumranet.com>
Cc: Roland Dreier <rolandd@cisco.com>
Signed-off-by: Anthony Liguori <anthony@codemonkey.ws>
This modifies Makefiles and Kconfigs to properly reflect the creation of
generic HID layer.
It also removes the dependency of BROKEN, which was introduced by the
first patch in series (see the comment). Also updates credits.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
When renaming CONFIG_PS3 to CONFIG_PPC_PS3, a few occurrences have been
missed.
I also fixed up the alignment in arch/powerpc/platforms/Makefile.
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com>
Adds a PS3 system bus driver. This system bus is a virtual bus used to present
the PS3 system devices in the LDM.
Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com>
Implement the time sources for i386 (acpi_pm, cyclone, hpet, pit, and tsc).
With this patch, the conversion of the i386 arch to the generic timekeeping
code should be complete.
The patch should be fairly straight forward, only adding the new clocksources.
[hirofumi@mail.parknet.co.jp: acpi_pm cleanup]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Provides an API for offloading memory copies to DMA devices
Signed-off-by: Chris Leech <christopher.leech@intel.com>
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband:
IB/ipath: kbuild infrastructure
IB/ipath: infiniband verbs support
IB/ipath: misc infiniband code, part 2
IB/ipath: misc infiniband code, part 1
IB/ipath: infiniband RC protocol support
IB/ipath: infiniband UC and UD protocol support
IB/ipath: infiniband header files
IB/ipath: layering interfaces used by higher-level driver code
IB/ipath: support for userspace apps using core driver
IB/ipath: sysfs and ipathfs support for core driver
IB/ipath: misc driver support code
IB/ipath: chip initialisation code, and diag support
IB/ipath: support for PCI Express devices
IB/ipath: support for HyperTransport devices
IB/ipath: core driver header files
IB/ipath: core device driver
arch/powerpc/kernel/setup-common.c
drivers/input/keyboard/hil_kbd.c
drivers/input/mouse/hil_ptr.c
Integrate the ipath core and OpenIB drivers into the kernel build
infrastructure. Add entry to MAINTAINERS.
Signed-off-by: Bryan O'Sullivan <bos@pathscale.com>
Add the foundations of a new LEDs subsystem. This patch adds a class which
presents LED devices within sysfs and allows their brightness to be
controlled.
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
RTC and date/time related functions.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Serio and gameport cores do not depend on other drivers and are
used by code living outside of drivers/input/{gameport|serio}.
Registering them at subsystem level guarantees that they are
fully initialized before anyone tries to use them.
Actually I think this is more appropriate so we don't end up with 17
cases that add drivers/sn to the build lib.
Include drivers/sn when CONFIG_IA64_SGI_SN2 or CONFIG_IA64_GENERIC
is enabled.
Acked-by: Dave Jones <davej@redhat.com>
Signed-off-by: Jes Sorensen <jes@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
This is a subset of the bluesmoke project core code, stripped of the NMI work
which isn't ready to merge and some of the "interesting" proc functionality
that needs reworking or just has no place in kernel. It requires no core
kernel changes except the added scrub functions already posted.
The goal is to merge further functionality only after the core code is
accepted and proven in the base kernel, and only at the point the upstream
extras are really ready to merge.
This converts EDAC to sysfs and is the final chunk neccessary before EDAC
has a stable user space API and can be considered for submission into the
base kernel.
Signed-off-by: Alan Cox <alan@redhat.com>
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Signed-off-by: doug thompson <norsk5@xmission.com>
Signed-off-by: Pavel Machek <pavel@suse.cz>
This is the core of a small SPI framework, implementing the model of a
queue of messages which complete asynchronously (with thin synchronous
wrappers on top).
- It's still less than 2KB of ".text" (ARM). If there's got to be a
mid-layer for something so simple, that's the right size budget. :)
- The guts use board-specific SPI device tables to build the driver
model tree. (Hardware probing is rarely an option.)
- This version of Kconfig includes no drivers. At this writing there
are two known master controller drivers (PXA/SSP, OMAP MicroWire)
and three protocol drivers (CS8415a, ADS7846, DataFlash) with LKML
mentions of other drivers in development.
- No userspace API. There are several implementations to compare.
Implement them like any other driver, and bind them with sysfs.
The changes from last version posted to LKML (on 11-Nov-2005) are minor,
and include:
- One bugfix (removes a FIXME), with the visible effect of making device
names be "spiB.C" where B is the bus number and C is the chipselect.
- The "caller provides DMA mappings" mechanism now has kerneldoc, for
DMA drivers that want to be fancy.
- Hey, the framework init can be subsys_init. Even though board init
logic fires earlier, at arch_init ... since the framework init is
for driver support, and the board init support uses static init.
- Various additional spec/doc clarifications based on discussions
with other folk. It adds a brief "thank you" at the end, for folk
who've helped nudge this framework into existence.
As I've said before, I think that "protocol tweaking" is the main support
that this driver framework will need to evolve.
Update the SPI framework to remove a potential priority inversion case by
reverting to kmalloc if the pre-allocated DMA-safe buffer isn't available.
Make the AMBA bus code visible to other architectures.
We want to link the "regular" SCSI drivers before the USB storage
driver, since historically we've always detected internal SCSI disks
before the external USB storage modules.
The link order matters for initcall ordering, and this got broken by
mistake by commit 7586269c0b52970f60bb69fcb86e765fc1d72309 which moved
the USB host controller PCI quirk handling around.
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect
used in higher-end embedded applications. The curious can look at the specs
over at http://www.rapidio.org
The core code implements enumeration/discovery, management of
devices/resources, and interfaces for RIO drivers.
There's a lot more to do to take advantages of all the hardware features.
However, this should provide a good base for folks with RIO hardware to start
contributing.
Signed-off-by: Matt Porter <mporter@kernel.crashing.org>
drivers/sh/ got dropped from drivers/Makefile, so add it back in..
This moves the PCI quirk handling for USB host controllers from the
PCI directory to the USB directory. Follow-on patches will need to:
(a) merge these copies with the originals in the HCD reset methods.
they don't wholly agree, despite doing the very same thing; and
(b) eventually change it so "usb-handoff" is the default, to help
get more robust USB/BIOS/input/... interactions.
drivers/Makefile | 2
drivers/pci/quirks.c | 253 ---------------------------------------
drivers/usb/Makefile | 1
drivers/usb/host/Makefile | 5
drivers/usb/host/pci-quirks.c | 272 ++++++++++++++++++++++++++++++++++++++++++
5 files changed, 280 insertions(+), 253 deletions(-)
Kernel connector - new userspace <-> kernel space easy to use
communication module which implements easy to use bidirectional
message bus using netlink as it's backend. Connector was created to
eliminate complex skb handling both in send and receive message bus
direction.
Connector driver adds possibility to connect various agents using as
one of it's backends netlink based network. One must register
callback and identifier. When driver receives special netlink message
with appropriate identifier, appropriate callback will be called.
From the userspace point of view it's quite straightforward:
socket();
bind();
send();
recv();
But if kernelspace want to use full power of such connections, driver
writer must create special sockets, must know about struct sk_buff
handling... Connector allows any kernelspace agents to use netlink
based networking for inter-process communication in a significantly
easier way:
int cn_add_callback(struct cb_id *id, char *name, void (*callback) (void *));
void cn_netlink_send(struct cn_msg *msg, u32 __groups, int gfp_mask);
struct cb_id
__u32 idx;
__u32 val;
idx and val are unique identifiers which must be registered in
connector.h for in-kernel usage. void (*callback) (void *) - is a
callback function which will be called when message with above idx.val
will be received by connector core.
Using connector completely hides low-level transport layer from it's
users.
Connector uses new netlink ability to have many groups in one socket.
[ Incorporating many cleanups and fixes by myself and
Andrew Morton -DaveM ]
Signed-off-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
it has been a synonym for CONFIG_ACPI since 2.6.12
Signed-off-by: Len Brown <len.brown@intel.com>
Add support for the core of the multimedia communication port
framework. This is a port used to communicate with devices
with two DMA paths and a control path.
Part 1: Configuration files and Makefiles.
The SGI IOC4 I/O controller chip drivers are currently all configured by
CONFIG_BLK_DEV_SGIIOC4. This is undesirable as not all IOC4 hardware features
are needed by all systems.
This patch adds two configuration variables, CONFIG_SGI_IOC4 for core IOC4
driver support (see patch 1/3 in this series for further explanation) and
CONFIG_SERIAL_SGI_IOC4 to independently enable serial port support.
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
Acked-by: Pat Gefre <pfg@sgi.com>
Acked-by: Jeremy Higdon <jeremy@sgi.com>
infrastructure for it.
Let it rip!
