path: root/crypto/tcrypt.c
2014-05-22crypto: testmgr - add aead cbc des, des3_ede testsNitesh Lal
Test vectors were taken from existing test for CBC(DES3_EDE). Associated data has been added to test vectors. HMAC computed with Crypto++ has been used. Following algos have been covered. (a) "authenc(hmac(sha1),cbc(des))" (b) "authenc(hmac(sha1),cbc(des3_ede))" (c) "authenc(hmac(sha224),cbc(des))" (d) "authenc(hmac(sha224),cbc(des3_ede))" (e) "authenc(hmac(sha256),cbc(des))" (f) "authenc(hmac(sha256),cbc(des3_ede))" (g) "authenc(hmac(sha384),cbc(des))" (h) "authenc(hmac(sha384),cbc(des3_ede))" (i) "authenc(hmac(sha512),cbc(des))" (j) "authenc(hmac(sha512),cbc(des3_ede))" Signed-off-by: Vakul Garg <vakul@freescale.com> [NiteshNarayanLal@freescale.com: added hooks for the missing algorithms test and tested the patch] Signed-off-by: Nitesh Lal <NiteshNarayanLal@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-04-28crypto: tcrypt - Fix leak of struct aead_request in test_aead_speed()Christian Engelmayer
Fix leakage of memory for struct aead_request that is allocated via aead_request_alloc() but not released via aead_request_free(). Reported by Coverity - CID 1163869. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-04-28crypto: tcrypt - Fix potential leak in test_aead_speed() if ↵Christian Engelmayer
crypto_alloc_aead() fails Fix a potential memory leak in the error handling of test_aead_speed(). In case crypto_alloc_aead() fails, the function returns without going through the centralized cleanup path. Reported by Coverity - CID 1163870. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-04-28crypto: tcrypt - Fix potential leak in test_aead_speed() if aad_size is too bigChristian Engelmayer
Fix a potential memory leak in the error handling of test_aead_speed(). In case the size check on the associate data length parameter fails, the function goes through the wrong exit label. Reported by Coverity - CID 1163870. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Acked-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-03-21crypto: testmgr - add aead null encryption test vectorsHoria Geanta
Add test vectors for aead with null encryption and md5, respectively sha1 authentication. Input data is taken from test vectors listed in RFC2410. Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-12-20crypto: tcrypt - Added speed tests for AEAD crypto alogrithms in tcrypt test ↵Tim Chen
suite Adding simple speed tests for a range of block sizes for AEAD crypto algorithms. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-11-28crypto: caam - fix aead sglen for case 'dst != src'Horia Geanta
For aead case when source and destination buffers are different, there is an incorrect assumption that the source length includes the ICV length. Fix this, since it leads to an oops when using sg_count() to find the number of nents in the scatterlist: Unable to handle kernel paging request for data at address 0x00000004 Faulting instruction address: 0xf91f7634 Oops: Kernel access of bad area, sig: 11 [#1] SMP NR_CPUS=8 P4080 DS Modules linked in: caamalg(+) caam_jr caam CPU: 1 PID: 1053 Comm: cryptomgr_test Not tainted 3.11.0 #16 task: eeb24ab0 ti: eeafa000 task.ti: eeafa000 NIP: f91f7634 LR: f91f7f24 CTR: f91f7ef0 REGS: eeafbbc0 TRAP: 0300 Not tainted (3.11.0) MSR: 00029002 <CE,EE,ME> CR: 44044044 XER: 00000000 DEAR: 00000004, ESR: 00000000 GPR00: f91f7f24 eeafbc70 eeb24ab0 00000002 ee8e0900 ee8e0800 00000024 c45c4462 GPR08: 00000010 00000000 00000014 0c0e4000 24044044 00000000 00000000 c0691590 GPR16: eeab0000 eeb23000 00000000 00000000 00000000 00000001 00000001 eeafbcc8 GPR24: 000000d1 00000010 ee2d5000 ee49ea10 ee49ea10 ee46f640 ee46f640 c0691590 NIP [f91f7634] aead_edesc_alloc.constprop.14+0x144/0x780 [caamalg] LR [f91f7f24] aead_encrypt+0x34/0x288 [caamalg] Call Trace: [eeafbc70] [a1004000] 0xa1004000 (unreliable) [eeafbcc0] [f91f7f24] aead_encrypt+0x34/0x288 [caamalg] [eeafbcf0] [c020d77c] __test_aead+0x3ec/0xe20 [eeafbe20] [c020f35c] test_aead+0x6c/0xe0 [eeafbe40] [c020f420] alg_test_aead+0x50/0xd0 [eeafbe60] [c020e5e4] alg_test+0x114/0x2e0 [eeafbee0] [c020bd1c] cryptomgr_test+0x4c/0x60 [eeafbef0] [c0047058] kthread+0xa8/0xb0 [eeafbf40] [c000eb0c] ret_from_kernel_thread+0x5c/0x64 Instruction dump: 69084321 7d080034 5508d97e 69080001 0f080000 81290024 552807fe 0f080000 3a600001 5529003a 2f8a0000 40dd0028 <80e90004> 3ab50001 8109000c 70e30002 ---[ end trace b3c3e23925c7484e ]--- While here, add a tcrypt mode for making it easy to test authenc (needed for triggering case above). Signed-off-by: Horia Geanta <horia.geanta@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-07Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This patch reinstates commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Now that module softdeps are in the kernel we can use that to resolve the boot issue which cause the revert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-24Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This reverts commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Unfortunately this change broke boot on some systems that used an initrd which does not include the newly created crct10dif modules. As these modules are required by sd_mod under certain configurations this is a serious problem. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-05-24crypto: crct10dif - Simple correctness and speed test for CRCT10DIF hashTim Chen
These are simple tests to do sanity check of CRC T10 DIF hash. The correctness of the transform can be checked with the command modprobe tcrypt mode=47 The speed of the transform can be evaluated with the command modprobe tcrypt mode=320 Set the cpu frequency to constant and turn turbo off when running the speed test so the frequency governor will not tweak the frequency and affects the measurements. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: tcrypt - add async cipher speed tests for blowfishJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: add CMAC support to CryptoAPIJussi Kivilinna
Patch adds support for NIST recommended block cipher mode CMAC to CryptoAPI. This work is based on Tom St Denis' earlier patch, http://marc.info/?l=linux-crypto-vger&m=135877306305466&w=2 Cc: Tom St Denis <tstdenis@elliptictech.com> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-25crypto: testmgr - add AES GMAC test vectorsJussi Kivilinna
2013-01-08crypto: ctr - make rfc3686 asynchronous block cipherJussi Kivilinna
Some hardware crypto drivers register asynchronous ctr(aes), which is left unused in IPSEC because rfc3686 template only supports synchronous block ciphers. Some other drivers register rfc3686(ctr(aes)) to workaround this limitation but not all. This patch changes rfc3686 to use asynchronous block ciphers, to allow async ctr(aes) algorithms to be utilized automatically by IPSEC. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2012-11-09crypto: tcrypt - add async speed test for camellia cipherJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - add new larger DES3_EDE testvectorsJussi Kivilinna
Most DES3_EDE testvectors are short and do not test parallelised codepaths well. Add larger testvectors to test large crypto operations and to test multi-page crypto with DES3_EDE. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-24crypto: testmgr - add new larger DES testvectorsJussi Kivilinna
Most DES testvectors are short and do not test parallelised codepaths well. Add larger testvectors to test large crypto operations and to test multi-page crypto with DES. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-10-15crypto: tcrypt - Added speed test in tcrypt for crc32cTim Chen
This patch adds a test case in tcrypt to perform speed test for crc32c checksum calculation. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto: tcrypt - add missing tests for camellia and ghashJussi Kivilinna
Add missing tests for ctr(camellia), lrw(camellia), xts(camellia) and ghash, as these have test vectors available. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-27crypto, tcrypt: remove local_bh_disable/enable() around ↵Suresh Siddha
local_irq_disable/enable() Ran into this while looking at some new crypto code using FPU hitting a WARN_ON_ONCE(!irq_fpu_usable()) in the kernel_fpu_begin() on a x86 kernel that uses the new eagerfpu model. In short, current eagerfpu changes return 0 for interrupted_kernel_fpu_idle() and the in_interrupt() thinks it is in the interrupt context because of the local_bh_disable(). Thus resulting in the WARN_ON(). Remove the local_bh_disable/enable() calls around the existing local_irq_disable/enable() calls. local_irq_disable/enable() already disables the BH. [ If there are any other legitimate users calling kernel_fpu_begin() from the process context but with BH disabled, then we can look into fixing the irq_fpu_usable() in future. ] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: testmgr - add larger cast6 testvectorsJohannes Goetzfried
New ECB, CBC, CTR, LRW and XTS testvectors for cast6. We need larger testvectors to check parallel code paths in the optimized implementation. Tests have also been added to the tcrypt module. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: testmgr - add larger cast5 testvectorsJohannes Goetzfried
New ECB, CBC and CTR testvectors for cast5. We need larger testvectors to check parallel code paths in the optimized implementation. Tests have also been added to the tcrypt module. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-07-11crypto: atmel - add new tests to tcryptNicolas Royer
- set sg buffers size equals to message size - add cfb & ofb tests for AES, DES & TDES Signed-off-by: Nicolas Royer <nicolas@eukrea.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Eric Bénard <eric@eukrea.com> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-14crypto: testmgr - add ecb(arc4) speed testsJussi Kivilinna
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-12crypto: twofish - add x86_64/avx assembler implementationJohannes Goetzfried
This patch adds a x86_64/avx assembler implementation of the Twofish block cipher. The implementation processes eight blocks in parallel (two 4 block chunk AVX operations). The table-lookups are done in general-purpose registers. For small blocksizes the 3way-parallel functions from the twofish-x86_64-3way module are called. A good performance increase is provided for blocksizes greater or equal to 128B. Patch has been tested with tcrypt and automated filesystem tests. Tcrypt benchmark results: Intel Core i5-2500 CPU (fam:6, model:42, step:7) twofish-avx-x86_64 vs. twofish-x86_64-3way 128bit key: (lrw:256bit) (xts:256bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.96x 0.97x 1.00x 0.95x 0.97x 0.97x 0.96x 0.95x 0.95x 0.98x 64B 0.99x 0.99x 1.00x 0.99x 0.98x 0.98x 0.99x 0.98x 0.99x 0.98x 256B 1.20x 1.21x 1.00x 1.19x 1.15x 1.14x 1.19x 1.20x 1.18x 1.19x 1024B 1.29x 1.30x 1.00x 1.28x 1.23x 1.24x 1.26x 1.28x 1.26x 1.27x 8192B 1.31x 1.32x 1.00x 1.31x 1.25x 1.25x 1.28x 1.29x 1.28x 1.30x 256bit key: (lrw:384bit) (xts:512bit) size ecb-enc ecb-dec cbc-enc cbc-dec ctr-enc ctr-dec lrw-enc lrw-dec xts-enc xts-dec 16B 0.96x 0.96x 1.00x 0.96x 0.97x 0.98x 0.95x 0.95x 0.95x 0.96x 64B 1.00x 0.99x 1.00x 0.98x 0.98x 1.01x 0.98x 0.98x 0.98x 0.98x 256B 1.20x 1.21x 1.00x 1.21x 1.15x 1.15x 1.19x 1.20x 1.18x 1.19x 1024B 1.29x 1.30x 1.00x 1.28x 1.23x 1.23x 1.26x 1.27x 1.26x 1.27x 8192B 1.31x 1.33x 1.00x 1.31x 1.26x 1.26x 1.29x 1.29x 1.28x 1.30x twofish-avx-x86_64 vs aes-asm (8kB block): 128bit 256bit ecb-enc 1.19x 1.63x ecb-dec 1.18x 1.62x cbc-enc 0.75x 1.03x cbc-dec 1.23x 1.67x ctr-enc 1.24x 1.65x ctr-dec 1.24x 1.65x lrw-enc 1.15x 1.53x lrw-dec 1.14x 1.52x xts-enc 1.16x 1.56x xts-dec 1.16x 1.56x Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-06-12crypto: testmgr - Add new test cases for Blackfin CRC crypto driverSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-03-14crypto: tcrypt - add more camellia testsJussi Kivilinna
Add tests for CTR, LRW and XTS modes. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: tcrypt - add xts(twofish) testsJussi Kivilinna
2011-11-09crypto: tcrypt - add xts(serpent) testsJussi Kivilinna
2011-11-09crypto: tcrypt - add lrw(twofish) testsJussi Kivilinna
2011-11-09crypto: tcrypt - add lrw(serpent) testsJussi Kivilinna
2011-11-09crypto: tcrypt - add serpent speed testsJussi Kivilinna
2011-11-09crypto: tcrypt - add test_acipher_speedJussi Kivilinna
Add test_acipher_speed for testing async block ciphers. Also include tests for aes/des/des3/ede as these appear to have ablk_cipher implementations available. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-11-09crypto: testmgr - add new serpent test vectorsJussi Kivilinna
Add new serpent tests for serpent_sse2 x86_64/i586 8-way/4-way code paths. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: testmgr - add twofish testsJussi Kivilinna
Add tests for parallel twofish-x86_64-3way code paths. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: testmgr - add blowfish test-vectorsJussi Kivilinna
Add tests for parallel blowfish-x86_64 code paths. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-10-21crypto: tcrypt - add ctr(twofish) speed testJussi Kivilinna
2011-09-22crypto: tcrypt - add ctr(blowfish) speed testJussi Kivilinna
Add ctr(blowfish) speed test to receive results for blowfish x86_64 assembly patch. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-05-04crypto: tcrypt - CTR mode speed test for AESJan Glauber
Add the CTR mode speed test for AES. Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-03-04crypto: tcrypt - do not attempt to write to readonly variableDavid Sterba
Commit da7f033ddc9fdeb (”crypto: cryptomgr - Add test infrastructure”) added a const to variable which is later used as target buffer of memcpy. crypto/tcrypt.c:217:12: warning: passing 'const char (*)[128]' to parameter of type 'void *' discards qualifiers memset(&iv, 0xff, iv_len); crypto/tcrypt.c:test_cipher_speed() - unsigned char *key, iv[128]; + const char *key, iv[128]; ... memset(&iv, 0xff, iv_len); Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-11-13crypto: rfc4106 - Extending the RC4106 AES-GCM test vectorsAdrian Hoban
Updated RFC4106 AES-GCM testing. Some test vectors were taken from http://csrc.nist.gov/groups/ST/toolkit/BCM/documents/proposedmodes/ gcm/gcm-test-vectors.tar.gz Signed-off-by: Adrian Hoban <adrian.hoban@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Gabriele Paoloni <gabriele.paoloni@intel.com> Signed-off-by: Aidan O'Mahony <aidan.o.mahony@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-19crypto: tcrypt - Add speed tests for async hashingDavid S. Miller
These are invoked in the 'mode' range of 400 to 499. The cost of async vs. sync for the software algorithm implementations varies. It can be as low as 16 cycles but as much as a couple hundred. Here two runs of md5 testing, async then sync: testing speed of async md5 test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): 2448 cycles/operation, 153 cycles/byte test 1 ( 64 byte blocks, 16 bytes per update, 4 updates): 4992 cycles/operation, 78 cycles/byte test 2 ( 64 byte blocks, 64 bytes per update, 1 updates): 3808 cycles/operation, 59 cycles/byte test 3 ( 256 byte blocks, 16 bytes per update, 16 updates): 14000 cycles/operation, 54 cycles/byte test 4 ( 256 byte blocks, 64 bytes per update, 4 updates): 8480 cycles/operation, 33 cycles/byte test 5 ( 256 byte blocks, 256 bytes per update, 1 updates): 7280 cycles/operation, 28 cycles/byte test 6 ( 1024 byte blocks, 16 bytes per update, 64 updates): 50016 cycles/operation, 48 cycles/byte test 7 ( 1024 byte blocks, 256 bytes per update, 4 updates): 22496 cycles/operation, 21 cycles/byte test 8 ( 1024 byte blocks, 1024 bytes per update, 1 updates): 21232 cycles/operation, 20 cycles/byte test 9 ( 2048 byte blocks, 16 bytes per update, 128 updates): 117184 cycles/operation, 57 cycles/byte test 10 ( 2048 byte blocks, 256 bytes per update, 8 updates): 43008 cycles/operation, 21 cycles/byte test 11 ( 2048 byte blocks, 1024 bytes per update, 2 updates): 40176 cycles/operation, 19 cycles/byte test 12 ( 2048 byte blocks, 2048 bytes per update, 1 updates): 39888 cycles/operation, 19 cycles/byte test 13 ( 4096 byte blocks, 16 bytes per update, 256 updates): 194176 cycles/operation, 47 cycles/byte test 14 ( 4096 byte blocks, 256 bytes per update, 16 updates): 84096 cycles/operation, 20 cycles/byte test 15 ( 4096 byte blocks, 1024 bytes per update, 4 updates): 78336 cycles/operation, 19 cycles/byte test 16 ( 4096 byte blocks, 4096 bytes per update, 1 updates): 77120 cycles/operation, 18 cycles/byte test 17 ( 8192 byte blocks, 16 bytes per update, 512 updates): 403056 cycles/operation, 49 cycles/byte test 18 ( 8192 byte blocks, 256 bytes per update, 32 updates): 166112 cycles/operation, 20 cycles/byte test 19 ( 8192 byte blocks, 1024 bytes per update, 8 updates): 154768 cycles/operation, 18 cycles/byte test 20 ( 8192 byte blocks, 4096 bytes per update, 2 updates): 151904 cycles/operation, 18 cycles/byte test 21 ( 8192 byte blocks, 8192 bytes per update, 1 updates): 155456 cycles/operation, 18 cycles/byte testing speed of md5 test 0 ( 16 byte blocks, 16 bytes per update, 1 updates): 2208 cycles/operation, 138 cycles/byte test 1 ( 64 byte blocks, 16 bytes per update, 4 updates): 5008 cycles/operation, 78 cycles/byte test 2 ( 64 byte blocks, 64 bytes per update, 1 updates): 3600 cycles/operation, 56 cycles/byte test 3 ( 256 byte blocks, 16 bytes per update, 16 updates): 14080 cycles/operation, 55 cycles/byte test 4 ( 256 byte blocks, 64 bytes per update, 4 updates): 8560 cycles/operation, 33 cycles/byte test 5 ( 256 byte blocks, 256 bytes per update, 1 updates): 7040 cycles/operation, 27 cycles/byte test 6 ( 1024 byte blocks, 16 bytes per update, 64 updates): 50592 cycles/operation, 49 cycles/byte test 7 ( 1024 byte blocks, 256 bytes per update, 4 updates): 22736 cycles/operation, 22 cycles/byte test 8 ( 1024 byte blocks, 1024 bytes per update, 1 updates): 24960 cycles/operation, 24 cycles/byte test 9 ( 2048 byte blocks, 16 bytes per update, 128 updates): 99312 cycles/operation, 48 cycles/byte test 10 ( 2048 byte blocks, 256 bytes per update, 8 updates): 43520 cycles/operation, 21 cycles/byte test 11 ( 2048 byte blocks, 1024 bytes per update, 2 updates): 40704 cycles/operation, 19 cycles/byte test 12 ( 2048 byte blocks, 2048 bytes per update, 1 updates): 39552 cycles/operation, 19 cycles/byte test 13 ( 4096 byte blocks, 16 bytes per update, 256 updates): 196720 cycles/operation, 48 cycles/byte test 14 ( 4096 byte blocks, 256 bytes per update, 16 updates): 85152 cycles/operation, 20 cycles/byte test 15 ( 4096 byte blocks, 1024 bytes per update, 4 updates): 79408 cycles/operation, 19 cycles/byte test 16 ( 4096 byte blocks, 4096 bytes per update, 1 updates): 76816 cycles/operation, 18 cycles/byte test 17 ( 8192 byte blocks, 16 bytes per update, 512 updates): 391520 cycles/operation, 47 cycles/byte test 18 ( 8192 byte blocks, 256 bytes per update, 32 updates): 168464 cycles/operation, 20 cycles/byte test 19 ( 8192 byte blocks, 1024 bytes per update, 8 updates): 156912 cycles/operation, 19 cycles/byte test 20 ( 8192 byte blocks, 4096 bytes per update, 2 updates): 154016 cycles/operation, 18 cycles/byte test 21 ( 8192 byte blocks, 8192 bytes per update, 1 updates): 153856 cycles/operation, 18 cycles/byte We can ditch the sync hash code at some point if we feel that makes sense. For now I've left it there. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2010-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Herbert Xu
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-10crypto: tcrypt - Speed testing support for ghashHuang Ying
Because ghash needs setkey, the setkey and keysize template support for test_hash_speed is added. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-09-02crypto: vmac - New hash algorithm for intel_txt supportShane Wang
This patch adds VMAC (a fast MAC) support into crypto framework. Signed-off-by: Shane Wang <shane.wang@intel.com> Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-07-14crypto: tcrypt - Add mask parameterHerbert Xu
This patch adds a mask parameter to complement the existing type parameter. This is useful when instantiating algorithms that require a mask other than the default, e.g., ahash algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-19crypto: tcrypt - Fix module return code when testing by nameHerbert Xu
We should return 0/-ENOENT instead of 1/0 when testing by name. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-06-19crypto: tcrypt - Test algorithms by nameSteffen Klassert
This adds the 'alg' module parameter to be able to test an algorithm by name. If the algorithm type is not ad-hoc clear for a algorithm (e.g. pcrypt, cryptd) it is possilbe to set the algorithm type with the 'type' module parameter. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
