This updated the generic SHA-1 implementation to use the generic
shared SHA-1 glue code.
It also implements a .finup hook crypto_sha1_finup() and exports
it to other modules. The import and export() functions and the
.statesize member are dropped, since the default implementation
is perfectly suitable for this module.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
changed the automatic module loading when requesting crypto algorithms
to prefix all module requests with "crypto-". This requires all crypto
modules to have a crypto specific module alias even if their file name
would otherwise match the requested crypto algorithm.
Even though commit 5d26a105b5a7 added those aliases for a vast amount of
modules, it was missing a few. Add the required MODULE_ALIAS_CRYPTO
annotations to those files to make them get loaded automatically, again.
This fixes, e.g., requesting 'ecb(blowfish-generic)', which used to work
with kernels v3.18 and below.
Also change MODULE_ALIAS() lines to MODULE_ALIAS_CRYPTO(). The former
won't work for crypto modules any more.
Fixes: 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"")
Signed-off-by: Mathias Krause <minipli@googlemail.com>
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
Recently, in commit 13aa93c70e71 ("random: add and use memzero_explicit()
for clearing data"), we have found that GCC may optimize some memset()
cases away when it detects a stack variable is not being used anymore
and going out of scope. This can happen, for example, in cases when we
are clearing out sensitive information such as keying material or any
e.g. intermediate results from crypto computations, etc.
With the help of Coccinelle, we can figure out and fix such occurences
in the crypto subsytem as well. Julia Lawall provided the following
Coccinelle program:
type T;
identifier x;
T x;
... when exists
when any
-memset
+memzero_explicit
(&x,
-0,
... when != x
when strict
type T;
identifier x;
T x[...];
... when exists
when any
-memset
+memzero_explicit
(x,
-0,
... when != x
when strict
Therefore, make use of the drop-in replacement memzero_explicit() for
exactly such cases instead of using memset().
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Export the update function as crypto_sha1_update() to not have the need
to reimplement the same algorithm for each SHA-1 implementation. This
way the generic SHA-1 implementation can be used as fallback for other
implementations that fail to run under certain circumstances, like the
need for an FPU context while executing in IRQ context.
Modify sha1_update to use SHA1_BLOCK_SIZE.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
This patch adds export/import support to sha1_generic. The exported
type is defined by struct sha1_state, which is basically the entire
descriptor state of sha1_generic.
This patch changes sha1 to the new shash interface.
Signed-off-by: Adrian-Ken Rueegsegger <ken@codelabs.ch>
On Thu, Mar 27, 2008 at 03:40:36PM +0100, Bodo Eggert wrote:
> Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> wrote:
> > This patch cleanups the crypto code, replaces the init() and fini()
> > with the <algorithm name>_init/_fini
> This part ist OK.
> > or init/fini_<algorithm name> (if the
> > <algorithm name>_init/_fini exist)
> Having init_foo and foo_init won't be a good thing, will it? I'd start
> confusing them.
> What about foo_modinit instead?
Thanks for the suggestion, the init() is replaced with
<algorithm name>_mod_init ()
and fini () is replaced with <algorithm name>_mod_fini.
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Not architecture specific code should not #include <asm/scatterlist.h>.
This patch therefore either replaces them with
#include <linux/scatterlist.h> or simply removes them if they were
unused.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
There are currently several SHA implementations that all define their own
initialization vectors and size values. Since this values are idential
move them to a header file under include/crypto.
Signed-off-by: Jan Glauber <jang@de.ibm.com>
Loading the crypto algorithm by the alias instead of by module directly
has the advantage that all possible implementations of this algorithm
are loaded automatically and the crypto API can choose the best one
depending on its priority.
Additionally it ensures that the generic implementation as well as the
HW driver (if available) is loaded in case the HW driver needs the
generic version as fallback in corner cases.
Also remove the probe for sha1 in padlock's init code.
Quote from Herbert:
The probe is actually pointless since we can always probe when
the algorithm is actually used which does not lead to dead-locks
like this.
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc>
