path: root/crypto/authencesn.c
2017-08-06crypto: authencesn - Fix digest_null crashHerbert Xu
commit 41cdf7a45389e01991ee31e3301ed83cb3e3f7dc upstream. When authencesn is used together with digest_null a crash will occur on the decrypt path. This is because normally we perform a special setup to preserve the ESN, but this is skipped if there is no authentication. However, on the post-authentication path it always expects the preservation to be in place, thus causing a crash when digest_null is used. This patch fixes this by also skipping the post-processing when there is no authentication. Fixes: 104880a6b470 ("crypto: authencesn - Convert to new AEAD...") Reported-by: Jan Tluka <jtluka@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-07-18crypto: authencesn - Use skcipherHerbert Xu
This patch converts authencesn to use the new skcipher interface as opposed to ablkcipher. It also fixes a little bug where if a sync version of authencesn is requested we may still end up using an async ahash. This should have no effect as none of the authencesn users can request for a sync authencesn. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2016-07-01crypto: authenc - Consider ahash ASYNC bitHerbert Xu
As it is, if you get an async ahash with a sync skcipher you'll end up with a sync authenc, which is wrong. This patch fixes it by considering the ASYNC bit from ahash as well. It also fixes a little bug where if a sync version of authenc is requested we may still end up using an async ahash. Neither of them should have any effect as none of the authenc users can request for a sync authenc. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-17crypto: aead - Remove CRYPTO_ALG_AEAD_NEW flagHerbert Xu
This patch removes the CRYPTO_ALG_AEAD_NEW flag now that everyone has been converted. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-10crypto: authencesn - Convert to new AEAD interfaceHerbert Xu
This patch converts authencesn to the new AEAD interface. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-08-10crypto: authencesn - Fix breakage with new ESP codeHerbert Xu
The ESP code has been updated to generate a completely linear AD SG list. This unfortunately broke authencesn which expects the AD to be divided into at least three parts. This patch fixes it to cope with the new format. Later we will fix it properly to accept arbitrary input and not rely on the input being linear as part of the AEAD conversion. Fixes: 7021b2e1cddd ("esp4: Switch to new AEAD interface") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-13crypto: authencesn - Use crypto_aead_set_reqsize helperHerbert Xu
This patch uses the crypto_aead_set_reqsize helper to avoid directly touching the internals of aead. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-05-13crypto: authencesn - Include internal/aead.hHerbert Xu
All AEAD implementations must include internal/aead.h in order to access required helpers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-11-26crypto: include crypto- module prefix in templateKees Cook
This adds the module loading prefix "crypto-" to the template lookup as well. For example, attempting to load 'vfat(blowfish)' via AF_ALG now correctly includes the "crypto-" prefix at every level, correctly rejecting "vfat": net-pf-38 algif-hash crypto-vfat(blowfish) crypto-vfat(blowfish)-all crypto-vfat Reported-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-10-16crypto: authencesn - Simplify key parsingMathias Krause
Use the common helper function crypto_authenc_extractkeys() for key parsing. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Mathias Krause <mathias.krause@secunet.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-10-07crypto: crypto_memneq - add equality testing of memory regions w/o timing leaksJames Yonan
When comparing MAC hashes, AEAD authentication tags, or other hash values in the context of authentication or integrity checking, it is important not to leak timing information to a potential attacker, i.e. when communication happens over a network. Bytewise memory comparisons (such as memcmp) are usually optimized so that they return a nonzero value as soon as a mismatch is found. E.g, on x86_64/i5 for 512 bytes this can be ~50 cyc for a full mismatch and up to ~850 cyc for a full match (cold). This early-return behavior can leak timing information as a side channel, allowing an attacker to iteratively guess the correct result. This patch adds a new method crypto_memneq ("memory not equal to each other") to the crypto API that compares memory areas of the same length in roughly "constant time" (cache misses could change the timing, but since they don't reveal information about the content of the strings being compared, they are effectively benign). Iow, best and worst case behaviour take the same amount of time to complete (in contrast to memcmp). Note that crypto_memneq (unlike memcmp) can only be used to test for equality or inequality, NOT for lexicographical order. This, however, is not an issue for its use-cases within the crypto API. We tried to locate all of the places in the crypto API where memcmp was being used for authentication or integrity checking, and convert them over to crypto_memneq. crypto_memneq is declared noinline, placed in its own source file, and compiled with optimizations that might increase code size disabled ("Os") because a smart compiler (or LTO) might notice that the return value is always compared against zero/nonzero, and might then reintroduce the same early-return optimization that we are trying to avoid. Using #pragma or __attribute__ optimization annotations of the code for disabling optimization was avoided as it seems to be considered broken or unmaintained for long time in GCC [1]. Therefore, we work around that by specifying the compile flag for memneq.o directly in the Makefile. We found that this seems to be most appropriate. As we use ("Os"), this patch also provides a loop-free "fast-path" for frequently used 16 byte digests. Similarly to kernel library string functions, leave an option for future even further optimized architecture specific assembler implementations. This was a joint work of James Yonan and Daniel Borkmann. Also thanks for feedback from Florian Weimer on this and earlier proposals [2]. [1] http://gcc.gnu.org/ml/gcc/2012-07/msg00211.html [2] https://lkml.org/lkml/2013/2/10/131 Signed-off-by: James Yonan <james@openvpn.net> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Cc: Florian Weimer <fw@deneb.enyo.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-02-04crypto: use ERR_CASTJulia Lawall
Replace PTR_ERR followed by ERR_PTR by ERR_CAST, to be more concise. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression err,x; @@ - err = PTR_ERR(x); if (IS_ERR(x)) - return ERR_PTR(err); + return ERR_CAST(x); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2011-03-13crypto: authencesn - Add algorithm to handle IPsec extended sequence numbersSteffen Klassert
ESP with separate encryption/authentication algorithms needs a special treatment for the associated data. This patch add a new algorithm that handles esp with extended sequence numbers. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
