path: root/crypto/aes.c
2006-09-21[CRYPTO] api: Get rid of flags argument to setkeyHerbert Xu
Now that the tfm is passed directly to setkey instead of the ctx, we no longer need to pass the &tfm->crt_flags pointer. This patch also gets rid of a few unnecessary checks on the key length for ciphers as the cipher layer guarantees that the key length is within the bounds specified by the algorithm. Rather than testing dia_setkey every time, this patch does it only once during crypto_alloc_tfm. The redundant check from crypto_digest_setkey is also removed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-06-26[CRYPTO] all: Pass tfm instead of ctx to algorithmsHerbert Xu
Up until now algorithms have been happy to get a context pointer since they know everything that's in the tfm already (e.g., alignment, block size). However, once we have parameterised algorithms, such information will be specific to each tfm. So the algorithm API needs to be changed to pass the tfm structure instead of the context pointer. This patch is basically a text substitution. The only tricky bit is the assembly routines that need to get the context pointer offset through asm-offsets.h. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-03-21[CRYPTO] aes: Fixed array boundary violationDavid McCullough
The AES setkey routine writes 64 bytes to the E_KEY area even though there are only 60 bytes there. It is in fact safe since E_KEY is immediately follwed by D_KEY which is initialised afterwards. However, doing this may trigger undefined behaviour and makes Coverity unhappy. So by combining E_KEY and D_KEY into one array we sidestep this issue altogether. This problem was reported by Adrian Bunk. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] cipher: Set alignmask for multi-byte loadsHerbert Xu
Many cipher implementations use 4-byte/8-byte loads/stores which require alignment on some architectures. This patch explicitly sets the alignment requirements for them. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Allow AES C/ASM implementations to coexistHerbert Xu
As the Crypto API now allows multiple implementations to be registered for the same algorithm, we no longer have to play tricks with Kconfig to select the right AES implementation. This patch sets the driver name and priority for all the AES implementations and removes the Kconfig conditions on the C implementation for AES. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-01-09[CRYPTO] Use standard byte order macros wherever possibleHerbert Xu
A lot of crypto code needs to read/write a 32-bit/64-bit words in a specific gender. Many of them open code them by reading/writing one byte at a time. This patch converts all the applicable usages over to use the standard byte order macros. This is based on a previous patch by Denis Vlasenko. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
