path: root/block
2010-11-11block: remove unused copy_io_context()Jens Axboe
Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: remove REQ_HARDBARRIERChristoph Hellwig
REQ_HARDBARRIER is dead now, so remove the leftovers. What's left at this point is: - various checks inside the block layer. - sanity checks in bio based drivers. - now unused bio_empty_barrier helper. - Xen blockfront use of BLKIF_OP_WRITE_BARRIER - it's dead for a while, but Xen really needs to sort out it's barrier situaton. - setting of ordered tags in uas - dead code copied from old scsi drivers. - scsi different retry for barriers - it's dead and should have been removed when flushes were converted to FS requests. - blktrace handling of barriers - removed. Someone who knows blktrace better should add support for REQ_FLUSH and REQ_FUA, though. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: ioctl: fix information leak to userlandVasiliy Kulikov
Structure hd_geometry is copied to userland with 4 padding bytes between cylinders and start fields uninitialized on 64-bit platforms. It leads to leaking of contents of kernel stack memory. Currently there is no memset() in real implementations of getgeo() in drivers/block/, so it makes sense to have memset() in blkdev_ioctl(). Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: read i_size with i_size_read()Mike Snitzer
Convert direct reads of an inode's i_size to using i_size_read(). i_size_{read,write} use a seqcount to protect reads from accessing incomple writes. Concurrent i_size_write()s require mutual exclussion to protect the seqcount that is used by i_size_{read,write}. But i_size_read() callers do not need to use additional locking. Signed-off-by: Mike Snitzer <snitzer@redhat.com> Acked-by: NeilBrown <neilb@suse.de> Acked-by: Lars Ellenberg <lars.ellenberg@linbit.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: take care not to overflow when calculating total iov lengthJens Axboe
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: check for proper length of iov entries in blk_rq_map_user_iov()Jens Axboe
Ensure that we pass down properly validated iov segments before calling into the mapping or copy functions. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-25Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: Revert "block: fix accounting bug on cross partition merges"
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-24Revert "block: fix accounting bug on cross partition merges"Jens Axboe
This reverts commit 7681bfeeccff5efa9eb29bf09249a3c400b15327. Conflicts: include/linux/genhd.h It has numerous issues with the cleanup path and non-elevator devices. Revert it for now so we can come up with a clean version without rushing things. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-23block: fix use-after-free bug in blk throttle codeJens Axboe
blk_throtl_exit() frees the throttle data hanging off the queue in blk_cleanup_queue(), but blk_put_queue() will indirectly dereference this data when calling blk_sync_queue() which in turns calls throtl_shutdown_timer_wq(). Fix this by moving the freeing of the throttle data to when the queue is truly being released, and post the call to blk_sync_queue(). Reported-by: Ingo Molnar <mingo@elte.hu> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-22Merge branch 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/core' of git://git.kernel.dk/linux-2.6-block: (39 commits) cfq-iosched: Fix a gcc 4.5 warning and put some comments block: Turn bvec_k{un,}map_irq() into static inline functions block: fix accounting bug on cross partition merges block: Make the integrity mapped property a bio flag block: Fix double free in blk_integrity_unregister block: Ensure physical block size is unsigned int blkio-throttle: Fix possible multiplication overflow in iops calculations blkio-throttle: limit max iops value to UINT_MAX blkio-throttle: There is no need to convert jiffies to milli seconds blkio-throttle: Fix link failure failure on i386 blkio: Recalculate the throttled bio dispatch time upon throttle limit change blkio: Add root group to td->tg_list blkio: deletion of a cgroup was causes oops blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=n block: set the bounce_pfn to the actual DMA limit rather than to max memory block: revert bad fix for memory hotplug causing bounces Fix compile error in blk-exec.c for !CONFIG_DETECT_HUNG_TASK block: set the bounce_pfn to the actual DMA limit rather than to max memory block: Prevent hang_check firing during long I/O cfq: improve fsync performance for small files ... Fix up trivial conflicts due to __rcu sparse annotation in include/linux/genhd.h
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-22Merge branch 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: block: autoconvert trivial BKL users to private mutex drivers: autoconvert trivial BKL users to private mutex ipmi: autoconvert trivial BKL users to private mutex mac: autoconvert trivial BKL users to private mutex mtd: autoconvert trivial BKL users to private mutex scsi: autoconvert trivial BKL users to private mutex Fix up trivial conflicts (due to addition of private mutex right next to deletion of a version string) in drivers/char/pcmcia/cm40[04]0_cs.c
2010-10-22SYSFS: Allow boot time switching between deprecated and modern sysfs layoutAndi Kleen
I have some systems which need legacy sysfs due to old tools that are making assumptions that a directory can never be a symlink to another directory, and it's a big hazzle to compile separate kernels for them. This patch turns CONFIG_SYSFS_DEPRECATED into a run time option that can be switched on/off the kernel command line. This way the same binary can be used in both cases with just a option on the command line. The old CONFIG_SYSFS_DEPRECATED_V2 option is still there to set the default. I kept the weird name to not break existing config files. Also the compat code can be still completely disabled by undefining CONFIG_SYSFS_DEPRECATED_SWITCH -- just the optimizer takes care of this now instead of lots of ifdefs. This makes the code look nicer. v2: This is an updated version on top of Kay's patch to only handle the block devices. I tested it on my old systems and that seems to work. Cc: axboe@kernel.dk Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22cfq-iosched: Fix a gcc 4.5 warning and put some commentsVivek Goyal
- Andi encountedred following warning with gcc 4.5 linux/block/cfq-iosched.c: In function ‘cfq_dispatch_requests’: linux/block/cfq-iosched.c:2156:3: warning: array subscript is above array bounds - Warning happens due to following code. slice = group_slice * count / max_t(unsigned, cfqg->busy_queues_avg[cfqd->serving_prio], cfq_group_busy_queues_wl(cfqd->serving_prio, cfqd, cfqg)); gcc is complaining about cfqg->busy_queues_avg[] being indexed by CFQ prio classes (RT, BE and IDLE) while the array size is only 2. - At run time, we never access cfqg->busy_queues_avg[IDLE] and return from function before this code hits. - To fix warning increase the array size though it will remain unused. This patch also puts some comments to clarify some of the confusions. - I have taken Jens's patch and modified it a bit. - Compile tested with gcc 4.4 and boot tested. I don't have gcc 4.5 running, Andi can you please test it with gcc 4.5 to make sure it worked. Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] bsg: fix incorrect device_status value [SCSI] Fix VPD inquiry page wrapper
2010-10-19Merge branch 'v2.6.36-rc8' into for-2.6.37/barrierJens Axboe
Conflicts: block/blk-core.c drivers/block/loop.c mm/swapfile.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-19block: fix accounting bug on cross partition mergesYasuaki Ishimatsu
/proc/diskstats would display a strange output as follows. $ cat /proc/diskstats |grep sda 8 0 sda 90524 7579 102154 20464 0 0 0 0 0 14096 20089 8 1 sda1 19085 1352 21841 4209 0 0 0 0 4294967064 15689 4293424691 ~~~~~~~~~~ 8 2 sda2 71252 3624 74891 15950 0 0 0 0 232 23995 1562390 8 3 sda3 54 487 2188 92 0 0 0 0 0 88 92 8 4 sda4 4 0 8 0 0 0 0 0 0 0 0 8 5 sda5 81 2027 2130 138 0 0 0 0 0 87 137 Its reason is the wrong way of accounting hd_struct->in_flight. When a bio is merged into a request belongs to different partition by ELEVATOR_FRONT_MERGE. The detailed root cause is as follows. Assuming that there are two partition, sda1 and sda2. 1. A request for sda2 is in request_queue. Hence sda1's hd_struct->in_flight is 0 and sda2's one is 1. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 2. A bio belongs to sda1 is issued and is merged into the request mentioned on step1 by ELEVATOR_BACK_MERGE. The first sector of the request is changed from sda2 region to sda1 region. However the two partition's hd_struct->in_flight are not changed. | hd_struct->in_flight --------------------------- sda1 | 0 sda2 | 1 --------------------------- 3. The request is finished and blk_account_io_done() is called. In this case, sda2's hd_struct->in_flight, not a sda1's one, is decremented. | hd_struct->in_flight --------------------------- sda1 | -1 sda2 | 1 --------------------------- The patch fixes the problem by caching the partition lookup inside the request structure, hence making sure that the increment and decrement will always happen on the same partition struct. This also speeds up IO with accounting enabled, since it cuts down on the number of lookups we have to do. When reloading partition tables, quiesce IO to ensure that no request references to the partition struct exists. When it is safe to free the partition table, the IO for that device is restarted again. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-15[SCSI] bsg: fix incorrect device_status valueFUJITA Tomonori
bsg incorrectly returns sg's masked_status value for device_status. [jejb: fix up expression logic] Reported-by: Douglas Gilbert <dgilbert@interlog.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-15block: Fix double free in blk_integrity_unregisterMartin K. Petersen
Commit 3839e4b introduced a kobject_put but failed to remove the kmem_cache_free beneath it, leading to a double free. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-13block: Ensure physical block size is unsigned intMartin K. Petersen
Physical block size was declared unsigned int to accomodate the maximum size reported by READ CAPACITY(16). Make sure we use the right type in the related functions. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-07elevator: fix oops on early call to elevator_change()Jens Axboe
2.6.36 introduces an API for drivers to switch the IO scheduler instead of manually calling the elevator exit and init functions. This API was added since q->elevator must be cleared in between those two calls. And since we already have this functionality directly from use by the sysfs interface to switch schedulers online, it was prudent to reuse it internally too. But this API needs the queue to be in a fully initialized state before it is called, or it will attempt to unregister elevator kobjects before they have been added. This results in an oops like this: BUG: unable to handle kernel NULL pointer dereference at 0000000000000051 IP: [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 PGD 47ddfc067 PUD 47c6a1067 PMD 0 Oops: 0000 [#1] PREEMPT SMP last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/0000:04:00.1/irq CPU 2 Modules linked in: t(+) loop hid_apple usbhid ahci ehci_hcd uhci_hcd libahci usbcore nls_base igb Pid: 7319, comm: modprobe Not tainted 2.6.36-rc6+ #132 QSSC-S4R/QSSC-S4R RIP: 0010:[<ffffffff8116f15e>] [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 RSP: 0018:ffff88027da25d08 EFLAGS: 00010246 RAX: ffff88047c68c528 RBX: 00000000fffffffe RCX: 0000000000000000 RDX: 000000000000002f RSI: 000000000000002f RDI: ffff88047e196c88 RBP: ffff88027da25d38 R08: 0000000000000000 R09: d84156c5635688c0 R10: d84156c5635688c0 R11: 0000000000000000 R12: ffff88047e196c88 R13: 0000000000000000 R14: 0000000000000000 R15: ffff88047c68c528 FS: 00007fcb0b26f6e0(0000) GS:ffff880287400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000051 CR3: 000000047e76e000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process modprobe (pid: 7319, threadinfo ffff88027da24000, task ffff88027d377090) Stack: ffff88027da25d58 ffff88047c68c528 00000000fffffffe ffff88047e196c88 <0> ffff88047c68c528 ffff88047e05bd90 ffff88027da25d78 ffffffff8123fb77 <0> ffff88047e05bd90 0000000000000000 ffff88047e196c88 ffff88047c68c528 Call Trace: [<ffffffff8123fb77>] kobject_add_internal+0xe7/0x1f0 [<ffffffff8123fd98>] kobject_add_varg+0x38/0x60 [<ffffffff8123feb9>] kobject_add+0x69/0x90 [<ffffffff8116efe0>] ? sysfs_remove_dir+0x20/0xa0 [<ffffffff8103d48d>] ? sub_preempt_count+0x9d/0xe0 [<ffffffff8143de20>] ? _raw_spin_unlock+0x30/0x50 [<ffffffff8116efe0>] ? sysfs_remove_dir+0x20/0xa0 [<ffffffff8116eff4>] ? sysfs_remove_dir+0x34/0xa0 [<ffffffff81224204>] elv_register_queue+0x34/0xa0 [<ffffffff81224aad>] elevator_change+0xfd/0x250 [<ffffffffa007e000>] ? t_init+0x0/0x361 [t] [<ffffffffa007e000>] ? t_init+0x0/0x361 [t] [<ffffffffa007e0a8>] t_init+0xa8/0x361 [t] [<ffffffff810001de>] do_one_initcall+0x3e/0x170 [<ffffffff8108c3fd>] sys_init_module+0xbd/0x220 [<ffffffff81002f2b>] system_call_fastpath+0x16/0x1b Code: e5 41 56 41 55 41 54 49 89 fc 53 48 83 ec 10 48 85 ff 74 52 48 8b 47 18 49 c7 c5 00 46 61 81 48 85 c0 74 04 4c 8b 68 30 45 31 f6 <41> 80 7d 51 00 74 0e 49 8b 44 24 28 4c 89 e7 ff 50 20 49 89 c6 RIP [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 RSP <ffff88027da25d08> CR2: 0000000000000051 ---[ end trace a6541d3bf07945df ]--- Fix this by adding a registered bit to the elevator queue, which is set when the sysfs kobjects have been registered. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-05block: autoconvert trivial BKL users to private mutexArnd Bergmann
The block device drivers have all gained new lock_kernel calls from a recent pushdown, and some of the drivers were already using the BKL before. This turns the BKL into a set of per-driver mutexes. Still need to check whether this is safe to do. file=$1 name=$2 if grep -q lock_kernel ${file} ; then if grep -q 'include.*linux.mutex.h' ${file} ; then sed -i '/include.*<linux\/smp_lock.h>/d' ${file} else sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file} fi sed -i ${file} \ -e "/^#include.*linux.mutex.h/,$ { 1,/^\(static\|int\|long\)/ { /^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex); } }" \ -e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \ -e '/[ ]*cycle_kernel_lock();/d' else sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \ -e '/cycle_kernel_lock()/d' fi Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-01blkio-throttle: Fix possible multiplication overflow in iops calculationsVivek Goyal
o User can specify max iops value of 32bit (UINT_MAX), through cgroup interface. If a user has specified say 4294967294 (UNIT_MAX - 2), then on 32bit platform, following multiplication can overflow. io_allowed = (tg->iops[rw] * jiffy_elapsed_rnd) o Explicitly cast the multiplication to 64bit and then perform division and then check whether result is still great then UNINT_MAX. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio-throttle: limit max iops value to UINT_MAXVivek Goyal
- Limit max iops value to UINT_MAX and return error to user if value is more than that instead of accepting bigger values and truncating implicitly. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio-throttle: There is no need to convert jiffies to milli secondsVivek Goyal
o Do not convert jiffies to mili seconds as it is not required. Just work with jiffies and HZ. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio-throttle: Fix link failure failure on i386Vivek Goyal
o Randy Dunlap reported following linux-next failure. This patch fixes it. on i386: blk-throttle.c:(.text+0x1abb8): undefined reference to `__udivdi3' blk-throttle.c:(.text+0x1b1dc): undefined reference to `__udivdi3' o bytes_per_second interface is 64bit and I was continuing to do 64 bit division even on 32bit platform without help of special macros/functions hence the failure. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio: Recalculate the throttled bio dispatch time upon throttle limit changeVivek Goyal
o Currently any cgroup throttle limit changes are processed asynchronousy and the change does not take affect till a new bio is dispatched from same group. o It might happen that a user sets a redicuously low limit on throttling. Say 1 bytes per second on reads. In such cases simple operations like mount a disk can wait for a very long time. o Once bio is throttled, there is no easy way to come out of that wait even if user increases the read limit later. o This patch fixes it. Now if a user changes the cgroup limits, we recalculate the bio dispatch time according to new limits. o Can't take queueu lock under blkcg_lock, hence after the change I wake up the dispatch thread again which recalculates the time. So there are some variables being synchronized across two threads without lock and I had to make use of barriers. Hoping I have used barriers correctly. Any review of memory barrier code especially will help. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio: Add root group to td->tg_listVivek Goyal
o Currently all the dynamically allocated groups, except root grp is added to td->tg_list. This was not a problem so far but in next patch I will travel through td->tg_list to process any updates of limits on the group. If root group is not in tg_list, then root group's updates are not processed. o It is better to root group also to tg_list instead of doing special processing for it during limit updates. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio: deletion of a cgroup was causes oopsVivek Goyal
o Now a cgroup list of blkg elements can contain blkg from multiple policies. Before sending an unlink event, make sure blkg belongs to they policy. If policy does not own the blkg, do not send update for this blkg. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01blkio: Do not export throttle files if CONFIG_BLK_DEV_THROTTLING=nVivek Goyal
Currently throttling related files were visible even if user had disabled throttling using config options. It was switching off background throttling of bio but not the cgroup files. This patch fixes it. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01block: set the bounce_pfn to the actual DMA limit rather than to max memoryMalahal Naineni
The bounce_pfn of the request queue in 64 bit systems is set to the current max_low_pfn. Adding more memory later makes this incorrect. Memory allocated beyond this boot time max_low_pfn appear to require bounce buffers (bounce buffers are actually not allocated but used in calculating segments that may result in "over max segments limit" errors). Signed-off-by: Malahal Naineni <malahal@us.ibm.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-01block: revert bad fix for memory hotplug causing bouncesJens Axboe
Revert "block: set the bounce_pfn to the actual DMA limit rather than to max memory" This reverts commit c49825facfd4969585224a896a5e717f88450cad. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-25block: prevent merges of discard and write requestsAdrian Hunter
Add logic to prevent two I/O requests being merged if only one of them is a discard. Ditto secure discard. Without this fix, it is possible for write requests to transform into discard requests. For example: Submit bio 1 to discard 8 sectors from sector n Submit bio 2 to write 8 sectors from sector n + 16 Submit bio 3 to write 8 sectors from sector n + 8 Bio 1 becomes request 1. Bio 2 becomes request 2. Bio 3 is merged with request 2, and then subsequently request 2 is merged with request 1 resulting in just one I/O request which discards all 24 sectors. Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com> (Moved the checks above the position checks /Jens) Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-24block: set the bounce_pfn to the actual DMA limit rather than to max memoryMalahal Naineni
2010-09-24block: Prevent hang_check firing during long I/OMark Lord
During long I/O operations, the hang_check timer may fire, trigger stack dumps that unnecessarily alarm the user. Eg. hdparm --security-erase NULL /dev/sdb ## can take *hours* to complete So, if hang_check is armed, we should wake up periodically to prevent it from triggering. This patch uses a wake-up interval equal to half the hang_check timer period, which keeps overhead low enough. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-21cfq-iosched: fix a kernel OOPs when usb key is insertedVivek Goyal
Mike reported a kernel crash when a usb key hotplug is performed while all kernel thrads are not in a root cgroup and are running in one of the child cgroups of blkio controller. BUG: unable to handle kernel NULL pointer dereference at 0000002c IP: [<c11c7b08>] cfq_get_queue+0x232/0x412 *pde = 00000000 Oops: 0000 [#1] PREEMPT last sysfs file: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/host3/scsi_host/host3/uevent [..] Pid: 30039, comm: scsi_scan_3 Not tainted 2.6.35.2-fg.roam #1 Volvi2 /Aspire 4315 EIP: 0060:[<c11c7b08>] EFLAGS: 00010086 CPU: 0 EIP is at cfq_get_queue+0x232/0x412 EAX: f705f9c0 EBX: e977abac ECX: 00000000 EDX: 00000000 ESI: f00da400 EDI: f00da4ec EBP: e977a800 ESP: dff8fd00 DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068 Process scsi_scan_3 (pid: 30039, ti=dff8e000 task=f6b6c9a0 task.ti=dff8e000) Stack: 00000000 00000000 00000001 01ff0000 f00da508 00000000 f00da524 f00da540 <0> e7994940 dd631750 f705f9c0 e977a820 e977ac44 f00da4d0 00000001 f6b6c9a0 <0> 00000010 00008010 0000000b 00000000 00000001 e977a800 dd76fac0 00000246 Call Trace: [<c11c7f10>] ? cfq_set_request+0x228/0x34c [<c11c7ce8>] ? cfq_set_request+0x0/0x34c [<c11bb3b9>] ? elv_set_request+0xf/0x1c [<c11bdd51>] ? get_request+0x1ad/0x22f [<c11bddf2>] ? get_request_wait+0x1f/0x11a [<c11d013b>] ? kvasprintf+0x33/0x3b [<c127b537>] ? scsi_execute+0x1d/0x103 [<c127b675>] ? scsi_execute_req+0x58/0x83 [<c127c391>] ? scsi_probe_and_add_lun+0x188/0x7c2 [<c12718c6>] ? attribute_container_add_device+0x15/0xfa [<c11c95d1>] ? kobject_get+0xf/0x13 [<c126d1db>] ? get_device+0x10/0x14 [<c127be93>] ? scsi_alloc_target+0x217/0x24d [<c127cbd8>] ? __scsi_scan_target+0x95/0x480 [<c10204eb>] ? dequeue_entity+0x14/0x1fe [<c1020491>] ? update_curr+0x165/0x1ab [<c1020491>] ? update_curr+0x165/0x1ab [<c127d00d>] ? scsi_scan_channel+0x4a/0x76 [<c127d0b0>] ? scsi_scan_host_selected+0x77/0xad [<c127d13c>] ? do_scan_async+0x0/0x11a [<c127d137>] ? do_scsi_scan_host+0x51/0x56 [<c127d13c>] ? do_scan_async+0x0/0x11a [<c127d14a>] ? do_scan_async+0xe/0x11a [<c127d13c>] ? do_scan_async+0x0/0x11a [<c10354c5>] ? kthread+0x5e/0x63 [<c1035467>] ? kthread+0x0/0x63 [<c1002af6>] ? kernel_thread_helper+0x6/0x10 Code: 44 24 1c 54 83 44 24 18 54 83 fa 03 75 94 8b 06 c7 86 64 02 00 00 01 00 00 00 83 e0 03 09 f0 89 06 8b 44 24 28 8b 90 58 01 00 00 <8b> 42 2c 85 c0 75 03 8b 42 08 8d 54 24 48 52 8d 4c 24 50 51 68 EIP: [<c11c7b08>] cfq_get_queue+0x232/0x412 SS:ESP 0068:dff8fd00 CR2: 000000000000002c ---[ end trace 9a88306573f69b12 ]--- The problem here is that we don't have bdi->dev information available when thread does some IO. Hence when dev_name() tries to access bdi->dev, it crashes. This problem does not happen if kernel threads are in root group as root group is statically allocated at device initialization time and we don't hit this piece of code. Fix it by delaying the filling of major and minor number information of device in blk_group. Initially a blk_group is created with 0 as device information and this information is filled later once some more IO comes in from same group. Reported-by: Mike Kazantsev <mk.fraggod@gmail.com> Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-21block: fix blk_rq_map_kern bio direction flagBenny Halevy
This bug was introduced in 7b6d91daee5cac6402186ff224c3af39d79f4a0e "block: unify flags for struct bio and struct request" Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-20cfq: improve fsync performance for small filesCorrado Zoccolo
Fsync performance for small files achieved by cfq on high-end disks is lower than what deadline can achieve, due to idling introduced between the sync write happening in process context and the journal commit. Moreover, when competing with a sequential reader, a process writing small files and fsync-ing them is starved. This patch fixes the two problems by: - marking journal commits as WRITE_SYNC, so that they get the REQ_NOIDLE flag set, - force all queues that have REQ_NOIDLE requests to be put in the noidle tree. Having the queue associated to the fsync-ing process and the one associated to journal commits in the noidle tree allows: - switching between them without idling, - fairness vs. competing idling queues, since they will be serviced only after the noidle tree expires its slice. Acked-by: Vivek Goyal <vgoyal@redhat.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Tested-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Corrado Zoccolo <czoccolo@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16block: Fix race during disk initializationSigned-off-by: Jan Kara
When a new disk is being discovered, add_disk() first ties the bdev to gendisk (via register_disk()->blkdev_get()) and only after that calls bdi_register_bdev(). Because register_disk() also creates disk's kobject, it can happen that userspace manages to open and modify the device's data (or inode) before its BDI is properly initialized leading to a warning in __mark_inode_dirty(). Fix the problem by registering BDI early enough. This patch addresses https://bugzilla.kernel.org/show_bug.cgi?id=16312 Cc: stable@kernel.org Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blkio: Implementation of IOPS limit logicVivek Goyal
o core logic of implementing IOPS throttling. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blk-cgroup: cgroup changes for IOPS limit supportVivek Goyal
o cgroup changes for IOPS throttling rules. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blkio: Core implementation of throttle policyVivek Goyal
o Actual implementation of throttling policy in block layer. Currently it implements READ and WRITE bytes per second throttling logic. IOPS throttling comes in later patches. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blk-cgroup: Introduce cgroup changes for throttling policyVivek Goyal
o cgroup chagnes for throttle policy. o Introduces READ and WRITE bytes per second throttling rules. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blk-cgroup: Prepare the base for supporting more than one IO control policiesVivek Goyal
o This patch prepares the base for introducing new IO control policies. Currently all the code is written knowing there is only one policy and that is proportional bandwidth. Creating infrastructure for newer policies to come in. o Also there were many functions which were generated using macro. It was very confusing. Got rid of those. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-16blk-cgroup: Kill the header printed at the start of blkio.weight_device fileVivek Goyal
o Kill extra "dev weight" header which is printed when somebody reads blkio.weight_device file. This really seems to be out of convention. No other blkio files are printing any header at the start of file. I think it is ok to just print values and how to interpret values should be part of documentation. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
