path: root/block
2008-03-04unexport blk_{get,put}_queueAdrian Bunk
This patch removes the unused exports of blk_{get,put}_queue. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block/genhd.c: cleanupsAdrian Bunk
This patch contains the following cleanups: - make the needlessly global struct disk_type static - #if 0 the unused genhd_media_change_notify() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04proper prototype for blk_dev_init()Adrian Bunk
This patch adds a proper prototye for blk_dev_init() in block/blk.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block/blk-tag.c should #include "blk.h"Adrian Bunk
Every file should include the headers containing the externs for its global functions (in this case for __blk_queue_free_tags()). Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04Fix DMA access of block device in 64-bit kernel on some non-x86 systems with ↵Yang Shi
4GB or upper 4GB memory For some non-x86 systems with 4GB or upper 4GB memory, we need increase the range of addresses that can be used for direct DMA in 64-bit kernel. Signed-off-by: Yang Shi <yang.shi@windriver.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: separate out padding from alignmentTejun Heo
Block layer alignment was used for two different purposes - memory alignment and padding. This causes problems in lower layers because drivers which only require memory alignment ends up with adjusted rq->data_len. Separate out padding such that padding occurs iff driver explicitly requests it. Tomo: restorethe code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa according to padding alignment. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: restore the meaning of rq->data_len to the true data lengthFUJITA Tomonori
The meaning of rq->data_len was changed to the length of an allocated buffer from the true data length. It breaks SG_IO friends and bsg. This patch restores the meaning of rq->data_len to the true data length and adds rq->extra_len to store an extended length (due to drain buffer and padding). This patch also removes the code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa. The commit adjusts bio according to memory alignment (queue_dma_alignment). However, memory alignment is NOT padding alignment. This adjustment also breaks SG_IO friends and bsg. Padding alignment needs to be fixed in a proper way (by a separate patch). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-03-04block: fix kernel-docbook parameters and filesRandy Dunlap
kernel-doc for block/: - add missing parameters - fix one function's parameter list (remove blank line) - add 2 source files to docbook for non-exported kernel-doc functions Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: clear drain buffer if draining for write commandTejun Heo
Clear drain buffer before chaining if the command in question is a write. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: implement request_queue->dma_drain_neededTejun Heo
Draining shouldn't be done for commands where overflow may indicate data integrity issues. Add dma_drain_needed callback to request_queue. Drain buffer is appened iff this function returns non-zero. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: add request->raw_data_lenTejun Heo
With padding and draining moved into it, block layer now may extend requests as directed by queue parameters, so now a request has two sizes - the original request size and the extended size which matches the size of area pointed to by bios and later by sgs. The latter size is what lower layers are primarily interested in when allocating, filling up DMA tables and setting up the controller. Both padding and draining extend the data area to accomodate controller characteristics. As any controller which speaks SCSI can handle underflows, feeding larger data area is safe. So, this patch makes the primary data length field, request->data_len, indicate the size of full data area and add a separate length field, request->raw_data_len, for the unmodified request size. The latter is used to report to higher layer (userland) and where the original request size should be fed to the controller or device. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: update bio according to DMA alignment paddingTejun Heo
DMA start address and transfer size alignment for PC requests are achieved using bio_copy_user() instead of bio_map_user(). This works because bio_copy_user() always uses full pages and block DMA alignment isn't allowed to go over PAGE_SIZE. However, the implementation didn't update the last bio of the request to make this padding visible to lower layers. This patch makes blk_rq_map_user() extend the last bio such that it includes the padding area and the size of area pointed to by the request is properly aligned. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19elevator: make elevator_get() attempt to load the appropriate moduleJens Axboe
Currently we fail if someone requests a valid io scheduler, but it's modular and not currently loaded. That can happen from a driver init asking for a different scheduler, or online switching through sysfs as requested by a user. This patch makes elevator_get() request_module() to attempt to load the appropriate module, instead of requiring that done manually. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19cfq-iosched: add hlist for browsing parallel to the radix treeJens Axboe
It's cumbersome to browse a radix tree from start to finish, especially since we modify keys when a process exits. So add a hlist for the single purpose of browsing over all known cfq_io_contexts, used for exit, io prio change, etc. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=9948 Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19block: make blk_rq_map_user() clear ->bio if it unmaps itJens Axboe
That way the interface is symmetric, and calling blk_rq_unmap_user() on the request wont oops. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-19make blk_settings_init() staticAdrian Bunk
blk_settings_init() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-19make blk_ioc_init() staticAdrian Bunk
blk_ioc_init() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-19make blk-core.c:request_cachep static againAdrian Bunk
request_cachep needlessly became global. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-02-08Enhanced partition statistics: remove old partition statisticsJerome Marchand
Removes the now unused old partition statistic code. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-08Enhanced partition statistics: procfsJerome Marchand
Reports enhanced partition statistics in /proc/diskstats. Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
2008-02-08Enhanced partition statistics: update partition statiticsJerome Marchand
Updates the enhanced partition statistics in generic block layer besides the disk statistics. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-08block: fixup rq_init() a bitJens Axboe
Rearrange fields in cache order and initialize some fields that we didn't previously init. Remove init of ->completion_data, it's part of a union with ->hash. Luckily clearing the rb node is the same as setting it to null! Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01block: kill swap_io_context()Jens Axboe
It blindly copies everything in the io_context, including the lock. That doesn't work so well for either lock ordering or lockdep. There seems zero point in swapping io contexts on a request to request merge, so the best point of action is to just remove it. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01as-iosched: fix inconsistent ioc->lock contextJens Axboe
Since it's acquired from irq context, all locking must be of the irq safe variant. Most are already inside the queue lock (which already disables interrupts), but the io scheduler rmmod path always has irqs enabled and the put_io_context() path may legally be called with irqs enabled (even if it isn't usually). So fixup those two. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-01block: make elevator lib checkpatch compliantJens Axboe
2008-02-01cfq-iosched: make checkpatch compliantJens Axboe
2008-02-01block: make core bits checkpatch compliantJens Axboe
2008-02-01block: new end request handling interface should take unsigned byte countsJens Axboe
No point in passing signed integers as the byte count, they can never be negative. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-30[SCSI] bsg: copy the cmd_type field to the subordinate request for bidiJames Bottomley
This fixes a problem in SCSI where we use the (previously uninitialised) cmd_type via blk_pc_request() to set up the transfer in scsi_init_sgtable(). Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-30as-iosched: fix double locking bug in as_merged_requests()Jens Axboe
If the two requests belong to the same io context, we will attempt to lock the same lock twice. But swapping contexts is pointless in that case, so just check for rioc == nioc before doing the double lock and copy. Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29Expose hardware sector sizeMartin K. Petersen
Expose hardware sector size in sysfs queue directory. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: ll_rw_blk.c split, add blk-merge.cJens Axboe
2008-01-29block: remove dated (and wrong) comment in blk-core.cJens Axboe
2008-01-29block: get rid of unnecessary forward declarations in blk-core.cJens Axboe
2008-01-29block: continue ll_rw_blk.c splitupJens Axboe
Adds files for barrier handling, rq execution, io context handling, mapping data to requests, and queue settings. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: split tag and sysfs handling from blk-core.cJens Axboe
Seperates the tag and sysfs handling from ll_rw_blk. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29block: first step of splitting ll_rw_blk, rename itJens Axboe
Then we retain history in blk-core.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-29Merge branch 'for-2.6.25' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.25' of git://git.kernel.dk/linux-2.6-block: block: implement drain buffers __bio_clone: don't calculate hw/phys segment counts block: allow queue dma_alignment of zero blktrace: Add blktrace ioctls to SCSI generic devices
2008-01-29Merge branch 'blk-end-request' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'blk-end-request' of git://git.kernel.dk/linux-2.6-block: (30 commits) blk_end_request: changing xsysace (take 4) blk_end_request: changing ub (take 4) blk_end_request: cleanup of request completion (take 4) blk_end_request: cleanup 'uptodate' related code (take 4) blk_end_request: remove/unexport end_that_request_* (take 4) blk_end_request: changing scsi (take 4) blk_end_request: add bidi completion interface (take 4) blk_end_request: changing ide-cd (take 4) blk_end_request: add callback feature (take 4) blk_end_request: changing ide normal caller (take 4) blk_end_request: changing cpqarray (take 4) blk_end_request: changing cciss (take 4) blk_end_request: changing ide-scsi (take 4) blk_end_request: changing s390 (take 4) blk_end_request: changing mmc (take 4) blk_end_request: changing i2o_block (take 4) blk_end_request: changing viocd (take 4) blk_end_request: changing xen-blkfront (take 4) blk_end_request: changing viodasd (take 4) blk_end_request: changing sx8 (take 4) ...
2008-01-28cfq-iosched: kill some big inlinesJens Axboe
Use of inlines were a bit over the top, trim them down a bit. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28cfq-iosched: relax IOPRIO_CLASS_IDLE restrictionsJens Axboe
Currently you must be root to set idle io prio class on a process. This is due to the fact that the idle class is implemented as a true idle class, meaning that it will not make progress if someone else is requesting disk access. Unfortunately this means that it opens DOS opportunities by locking down file system resources, hence it is root only at the moment. This patch relaxes the idle class a little, by removing the truly idle part (which entals a grace period with associated timer). The modifications make the idle class as close to zero impact as can be done while still guarenteeing progress. This means we can relax the root only criteria as well. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28block: implement drain buffersJames Bottomley
These DMA drain buffer implementations in drivers are pretty horrible to do in terms of manipulating the scatterlist. Plus they're being done at least in drivers/ide and drivers/ata, so we now have code duplication. The one use case for this, as I understand it is AHCI controllers doing PIO mode to mmc devices but translating this to DMA at the controller level. So, what about adding a callback to the block layer that permits the adding of the drain buffer for the problem devices. The idea is that you'd do this in slave_configure after you find one of these devices. The beauty of doing it in the block layer is that it quietly adds the drain buffer to the end of the sg list, so it automatically gets mapped (and unmapped) without anything unusual having to be done to the scatterlist in driver/scsi or drivers/ata and without any alteration to the transfer length. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io_context sharing - anticipatory changesJens Axboe
changes to anticipatory io scheduler for io_context sharing Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28block: cfq: make the io contect sharing locklessJens Axboe
The io context sharing introduced a per-ioc spinlock, that would protect the cfq io context lookup. That is a regression from the original, since we never needed any locking there because the ioc/cic were process private. The cic lookup is changed from an rbtree construct to a radix tree, which we can then use RCU to make the reader side lockless. That is the performance critical path, modifying the radix tree is only done on process creation (when that process first does IO, actually) and on process exit (if that process has done IO). As it so happens, radix trees are also much faster for this type of lookup where the key is a pointer. It's a very sparse tree. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io_context sharing - cfq changesNikanth Karthikesan
changes in the cfq for io_context sharing Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28io context sharing: preliminary supportJens Axboe
Detach task state from ioc, instead keep track of how many processes are accessing the ioc. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28ioprio: move io priority from task_struct to io_contextJens Axboe
This is where it belongs and then it doesn't take up space for a process that doesn't do IO. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: cleanup of request completion (take 4)Kiyoshi Ueda
This patch merges complete_request() into end_that_request_last() for cleanup. complete_request() was introduced by earlier part of this patch-set, not to break the existing users of end_that_request_last(). Since all users are converted to blk_end_request interfaces and end_that_request_last() is no longer exported, the code can be merged to end_that_request_last(). Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-28blk_end_request: cleanup 'uptodate' related code (take 4)Kiyoshi Ueda
This patch converts 'uptodate' arguments of no longer exported interfaces, end_that_request_first/last, to 'error', and removes internal conversions for it in blk_end_request interfaces. Also, this patch removes no longer needed end_io_error(). Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
