path: root/block
2008-12-12Merge branch 'sched/core' into cpus4096Ingo Molnar
Conflicts: include/linux/ftrace.h kernel/sched.c
2008-12-05Enforce a minimum SG_IO timeoutLinus Torvalds
There's no point in having too short SG_IO timeouts, since if the command does end up timing out, we'll end up through the reset sequence that is several seconds long in order to abort the command that timed out. As a result, shorter timeouts than a few seconds simply do not make sense, as the recovery would be longer than the timeout itself. Add a BLK_MIN_SG_TIMEOUT to match the existign BLK_DEFAULT_SG_TIMEOUT. Suggested-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-05Merge branches 'tracing/ftrace', 'tracing/function-graph-tracer' and ↵Ingo Molnar
'tracing/urgent' into tracing/core
2008-12-04[PATCH 1/2] kill FMODE_NDELAY_NOWChristoph Hellwig
Update FMODE_NDELAY before each ioctl call so that we can kill the magic FMODE_NDELAY_NOW. It would be even better to do this directly in setfl(), but for that we'd need to have FMODE_NDELAY for all files, not just block special files. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-04[PATCH] Fix block dev compat ioctl handlingAndreas Schwab
Commit 33c2dca4957bd0da3e1af7b96d0758d97e708ef6 (trim file propagation in block/compat_ioctl.c) removed the handling of some ioctls from compat_blkdev_driver_ioctl. That caused them to be rejected as unknown by the compat layer. Signed-off-by: Andreas Schwab <schwab@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-03block: fix setting of max_segment_size and seg_boundary maskMilan Broz
Fix setting of max_segment_size and seg_boundary mask for stacked md/dm devices. When stacking devices (LVM over MD over SCSI) some of the request queue parameters are not set up correctly in some cases by default, namely max_segment_size and and seg_boundary mask. If you create MD device over SCSI, these attributes are zeroed. Problem become when there is over this mapping next device-mapper mapping - queue attributes are set in DM this way: request_queue max_segment_size seg_boundary_mask SCSI 65536 0xffffffff MD RAID1 0 0 LVM 65536 -1 (64bit) Unfortunately bio_add_page (resp. bio_phys_segments) calculates number of physical segments according to these parameters. During the generic_make_request() is segment cout recalculated and can increase bio->bi_phys_segments count over the allowed limit. (After bio_clone() in stack operation.) Thi is specially problem in CCISS driver, where it produce OOPS here BUG_ON(creq->nr_phys_segments > MAXSGENTRIES); (MAXSEGENTRIES is 31 by default.) Sometimes even this command is enough to cause oops: dd iflag=direct if=/dev/<vg>/<lv> of=/dev/null bs=128000 count=10 This command generates bios with 250 sectors, allocated in 32 4k-pages (last page uses only 1024 bytes). For LVM layer, it allocates bio with 31 segments (still OK for CCISS), unfortunatelly on lower layer it is recalculated to 32 segments and this violates CCISS restriction and triggers BUG_ON(). The patch tries to fix it by: * initializing attributes above in queue request constructor blk_queue_make_request() * make sure that blk_queue_stack_limits() inherits setting (DM uses its own function to set the limits because it blk_queue_stack_limits() was introduced later. It should probably switch to use generic stack limit function too.) * sets the default seg_boundary value in one place (blkdev.h) * use this mask as default in DM (instead of -1, which differs in 64bit) Bugs related to this: https://bugzilla.redhat.com/show_bug.cgi?id=471639 http://bugzilla.kernel.org/show_bug.cgi?id=8672 Signed-off-by: Milan Broz <mbroz@redhat.com> Reviewed-by: Alasdair G Kergon <agk@redhat.com> Cc: Neil Brown <neilb@suse.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Tejun Heo <htejun@gmail.com> Cc: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-03block: internal dequeue shouldn't start timerTejun Heo
blkdev_dequeue_request() and elv_dequeue_request() are equivalent and both start the timeout timer. Barrier code dequeues the original barrier request but doesn't passes the request itself to lower level driver, only broken down proxy requests; however, as the original barrier code goes through the same dequeue path and timeout timer is started on it. If barrier sequence takes long enough, this timer expires but the low level driver has no idea about this request and oops follows. Timeout timer shouldn't have been started on the original barrier request as it never goes through actual IO. This patch unexports elv_dequeue_request(), which has no external user anyway, and makes it operate on elevator proper w/o adding the timer and make blkdev_dequeue_request() call elv_dequeue_request() and add timer. Internal users which don't pass the request to driver - barrier code and end_that_request_last() - are converted to use elv_dequeue_request(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Mike Anderson <andmike@linux.vnet.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-03block: set disk->node_id before it's being usedCheng Renquan
disk->node_id will be refered in allocating in disk_expand_part_tbl, so we should set it before disk->node_id is refered. Signed-off-by: Cheng Renquan <crquan@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-03When block layer fails to map iov, it calls bio_unmap_user to undoPetr Vandrovec
mapping. Which is good if pages were mapped - but if they were provided by someone else and just copied then bad things happen - pages are released once here, and once by caller, leading to user triggerable BUG at include/linux/mm.h:246. Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-26blktrace: port to tracepoints, updateIngo Molnar
Port to the new tracepoints API: split DEFINE_TRACE() and DECLARE_TRACE() sites. Spread them out to the usage sites, as suggested by Mathieu Desnoyers. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
2008-11-26blktrace: port to tracepointsArnaldo Carvalho de Melo
This was a forward port of work done by Mathieu Desnoyers, I changed it to encode the 'what' parameter on the tracepoint name, so that one can register interest in specific events and not on classes of events to then check the 'what' parameter. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-18block: hold extra reference to bio in blk_rq_map_user_iov()Jens Axboe
If the size passed in is OK but we end up mapping too many segments, we call the unmap path directly like from IO completion. But from IO completion we have an extra reference to the bio, so this error case goes OOPS when it attempts to free and already free bio. Fix it by getting an extra reference to the bio before calling the unmap failure case. Reported-by: Petr Vandrovec <vandrove@vc.cvut.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-18block: fix boot failure with CONFIG_DEBUG_BLOCK_EXT_DEVT=y and nashZhang, Yanmin
We run into system boot failure with kernel 2.6.28-rc. We found it on a couple of machines, including T61 notebook, nehalem machine, and another HPC NX6325 notebook. All the machines use FedoraCore 8 or FedoraCore 9. With kernel prior to 2.6.28-rc, system boot doesn't fail. I debug it and locate the root cause. Pls. see http://bugzilla.kernel.org/show_bug.cgi?id=11899 https://bugzilla.redhat.com/show_bug.cgi?id=471517 As a matter of fact, there are 2 bugs. 1)root=/dev/sda1, system boot randomly fails. Mostly, boot for 5 times and fails once. nash has a bug. Some of its functions misuse return value 0. Sometimes, 0 means timeout and no uevent available. Sometimes, 0 means nash gets an uevent, but the uevent isn't block-related (for exmaple, usb). If by coincidence, kernel tells nash that uevents are available, but kernel also set timeout, nash might stops collecting other uevents in queue if current uevent isn't block-related. I work out a patch for nash to fix it. http://bugzilla.kernel.org/attachment.cgi?id=18858 2) root=LABEL=/, system always can't boot. initrd init reports switchroot fails. Here is an executation branch of nash when booting: (1) nash read /sys/block/sda/dev; Assume major is 8 (on my desktop) (2) nash query /proc/devices with the major number; It found line "8 sd"; (3) nash use 'sd' to search its own probe table to find device (DISK) type for the device and add it to its own list; (4) Later on, it probes all devices in its list to get filesystem labels; scsi register "8 sd" always. When major is 259, nash fails to find the device(DISK) type. I enables CONFIG_DEBUG_BLOCK_EXT_DEVT=y when compiling kernel, so 259 is picked up for device /dev/sda1, which causes nash to fail to find device (DISK) type. To fixing issue 2), I create a patch for nash and another patch for kernel. http://bugzilla.kernel.org/attachment.cgi?id=18859 http://bugzilla.kernel.org/attachment.cgi?id=18837 Below is the patch for kernel 2.6.28-rc4. It registers blkext, a new block device in proc/devices. With 2 patches on nash and 1 patch on kernel, I boot my machines for dozens of times without failure. Signed-off-by Zhang Yanmin <yanmin.zhang@linux.intel.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-18block: make add_partition() return pointer to hd_structTejun Heo
Make add_partition() return pointer to the new hd_struct on success and ERR_PTR() value on failure. This change will be used to fix md autodetection bug. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-06Block: use round_jiffies_up()Alan Stern
This patch (as1159b) changes the timeout routines in the block core to use round_jiffies_up(). There's no point in rounding the timer deadline down, since if it expires too early we will have to restart it. The patch also removes some unnecessary tests when a request is removed from the queue's timer list. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-06blk: move blk_delete_timer call in end_that_request_lastMike Anderson
Move the calling blk_delete_timer to later in end_that_request_last to address an issue where blkdev_dequeue_request may have add a timer for the request. Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-06block: add timer on blkdev_dequeue_request() not elv_next_request()Tejun Heo
Block queue supports two usage models - one where block driver peeks at the front of queue using elv_next_request(), processes it and finishes it and the other where block driver peeks at the front of queue, dequeue the request using blkdev_dequeue_request() and finishes it. The latter is more flexible as it allows the driver to process multiple commands concurrently. These two inconsistent usage models affect the block layer implementation confusing. For some, elv_next_request() is considered the issue point while others consider blkdev_dequeue_request() the issue point. Till now the inconsistency mostly affect only accounting, so it didn't really break anything seriously; however, with block layer timeout, this inconsistency hits hard. Block layer considers elv_next_request() the issue point and adds timer but SCSI layer thinks it was just peeking and when the request can't process the command right away, it's just left there without further processing. This makes the request dangling on the timer list and, when the timer goes off, the request which the SCSI layer and below think is still on the block queue ends up in the EH queue, causing various problems - EH hang (failed count goes over busy count and EH never wakes up), WARN_ON() and oopses as low level driver trying to handle the unknown command, etc. depending on the timing. As SCSI midlayer is the only user of block layer timer at the moment, moving blk_add_timer() to elv_dequeue_request() fixes the problem; however, this two usage models definitely need to be cleaned up in the future. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-06block: remove unused ll_new_mergeable()FUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23Merge branch 'proc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: (35 commits) proc: remove fs/proc/proc_misc.c proc: move /proc/vmcore creation to fs/proc/vmcore.c proc: move pagecount stuff to fs/proc/page.c proc: move all /proc/kcore stuff to fs/proc/kcore.c proc: move /proc/schedstat boilerplate to kernel/sched_stats.h proc: move /proc/modules boilerplate to kernel/module.c proc: move /proc/diskstats boilerplate to block/genhd.c proc: move /proc/zoneinfo boilerplate to mm/vmstat.c proc: move /proc/vmstat boilerplate to mm/vmstat.c proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.c proc: move /proc/buddyinfo boilerplate to mm/vmstat.c proc: move /proc/vmallocinfo to mm/vmalloc.c proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.c proc: move /proc/slab_allocators boilerplate to mm/slab.c proc: move /proc/interrupts boilerplate code to fs/proc/interrupts.c proc: move /proc/stat to fs/proc/stat.c proc: move rest of /proc/partitions code to block/genhd.c proc: move /proc/cpuinfo code to fs/proc/cpuinfo.c proc: move /proc/devices code to fs/proc/devices.c proc: move rest of /proc/locks to fs/locks.c ...
2008-10-23compat_blkdev_driver_ioctl: Remove unused variable warningLinus Torvalds
Variable 'ret' is no longer used. Don't declare it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23proc: move /proc/diskstats boilerplate to block/genhd.cAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-23proc: move rest of /proc/partitions code to block/genhd.cAlexey Dobriyan
2008-10-21[PATCH] kill the rest of struct file propagation in block ioctlsAl Viro
Now we can switch blkdev_ioctl() block_device/mode Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] get rid of struct file use in blkdev_ioctl() BLKBSZSETAl Viro
We need to do bd_claim() only if file hadn't been opened with O_EXCL and then we have no need to use file itself as owner. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] get rid of blkdev_locked_ioctl()Al Viro
Most of that stuff doesn't need BKL at all; expand in the (only) caller, merge the switch into one there and leave BKL only around the stuff that might actually need it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] get rid of blkdev_driver_ioctl()Al Viro
convert remaining callers to __blkdev_driver_ioctl() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] trim file propagation in block/compat_ioctl.cAl Viro
... and remove the handling of cases when it falls back to native without changing arguments. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] end of methods switch: remove the old onesAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] introduce __blkdev_driver_ioctl()Al Viro
Analog of blkdev_driver_ioctl() with sane arguments. For now uses fake struct file, by the end of the series it won't and blkdev_driver_ioctl() will become a wrapper around it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-21[PATCH] switch scsi_cmd_ioctl() to passing fmode_tAl Viro
2008-10-21[PATCH] switch sg_scsi_ioctl() to passing fmode_tAl Viro
2008-10-21[PATCH] pass mode instead of file to sg_io()Al Viro
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-10-17Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: remove __generic_unplug_device() from exports block: move q->unplug_work initialization blktrace: pass zfcp driver data blktrace: add support for driver data block: fix current kernel-doc warnings block: only call ->request_fn when the queue is not stopped block: simplify string handling in elv_iosched_store() block: fix kernel-doc for blk_alloc_devt() block: fix nr_phys_segments miscalculation bug block: add partition attribute for partition number block: add BIG FAT WARNING to CONFIG_DEBUG_BLOCK_EXT_DEVT softirq: Add support for triggering softirq work on softirqs.
2008-10-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (39 commits) [SCSI] sd: fix compile failure with CONFIG_BLK_DEV_INTEGRITY=n libiscsi: fix locking in iscsi_eh_device_reset libiscsi: check reason why we are stopping iscsi session to determine error value [SCSI] iscsi_tcp: return a descriptive error value during connection errors [SCSI] libiscsi: rename host reset to target reset [SCSI] iscsi class: fix endpoint id handling [SCSI] libiscsi: Support drivers initiating session removal [SCSI] libiscsi: fix data corruption when target has to resend data-in packets [SCSI] sd: Switch kernel printing level for DIF messages [SCSI] sd: Correctly handle all combinations of DIF and DIX [SCSI] sd: Always print actual protection_type [SCSI] sd: Issue correct protection operation [SCSI] scsi_error: fix target reset handling [SCSI] lpfc 8.2.8 v2 : Add statistical reporting control and additional fc vendor events [SCSI] lpfc 8.2.8 v2 : Add sysfs control of target queue depth handling [SCSI] lpfc 8.2.8 v2 : Revert target busy in favor of transport disrupted [SCSI] scsi_dh_alua: remove REQ_NOMERGE [SCSI] lpfc 8.2.8 : update driver version to 8.2.8 [SCSI] lpfc 8.2.8 : Add MSI-X support [SCSI] lpfc 8.2.8 : Update driver to use new Host byte error code DID_TRANSPORT_DISRUPTED ...
2008-10-17block: remove __generic_unplug_device() from exportsJens Axboe
The only out-of-core user is IDE, and that should be using blk_start_queueing() instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: move q->unplug_work initializationPeter Zijlstra
modprobe loop; rmmod loop effectively creates a blk_queue and destroys it which results in q->unplug_work being canceled without it ever being initialized. Therefore, move the initialization of q->unplug_work from blk_queue_make_request() to blk_alloc_queue*(). Reported-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: fix current kernel-doc warningsRandy Dunlap
Fix block kernel-doc warnings: Warning(linux-2.6.27-git4//fs/block_dev.c:1272): No description found for parameter 'path' Warning(linux-2.6.27-git4//block/blk-core.c:1021): No description found for parameter 'cpu' Warning(linux-2.6.27-git4//block/blk-core.c:1021): No description found for parameter 'part' Warning(/var/linsrc/linux-2.6.27-git4//block/genhd.c:544): No description found for parameter 'partno' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: only call ->request_fn when the queue is not stoppedJens Axboe
Callers should use either blk_run_queue/__blk_run_queue, or blk_start_queueing() to invoke request handling instead of calling ->request_fn() directly as that does not take the queue stopped flag into account. Also add appropriate comments on the above functions to detail their usage. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: simplify string handling in elv_iosched_store()Li Zefan
strlcpy() guarantees the dest buffer is NULL teminated. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: fix kernel-doc for blk_alloc_devt()Li Zefan
No argument 'gfp_mask' for blk_alloc_devt(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-17block: fix nr_phys_segments miscalculation bugFUJITA Tomonori
This fixes the bug reported by Nikanth Karthikesan <knikanth@suse.de>: http://lkml.org/lkml/2008/10/2/203 The root cause of the bug is that blk_phys_contig_segment miscalculates q->max_segment_size. blk_phys_contig_segment checks: req->biotail->bi_size + next_req->bio->bi_size > q->max_segment_size But blk_recalc_rq_segments might expect that req->biotail and the previous bio in the req are supposed be merged into one segment. blk_recalc_rq_segments might also expect that next_req->bio and the next bio in the next_req are supposed be merged into one segment. In such case, we merge two requests that can't be merged here. Later, blk_rq_map_sg gives more segments than it should. We need to keep track of segment size in blk_recalc_rq_segments and use it to see if two requests can be merged. This patch implements it in the similar way that we used to do for hw merging (virtual merging). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-16device create: block: convert device_create_drvdata to device_createGreg Kroah-Hartman
Now that device_create() has been audited, rename things back to the original call to be sane. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-13[SCSI] block: separate failfast into multiple bits.Mike Christie
Multipath is best at handling transport errors. If it gets a device error then there is not much the multipath layer can do. It will just access the same device but from a different path. This patch breaks up failfast into device, transport and driver errors. The multipath layers (md and dm mutlipath) only ask the lower levels to fast fail transport errors. The user of failfast, read ahead, will ask to fast fail on all errors. Note that blk_noretry_request will return true if any failfast bit is set. This allows drivers that do not support the multipath failfast bits to continue to fail on any failfast error like before. Drivers like scsi that are able to fail fast specific errors can check for the specific fail fast type. In the next patch I will convert scsi. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-10-09block: Switch blk_integrity_compare from bdev to gendiskMartin K. Petersen
The DM and MD integrity support now depends on being able to use gendisks instead of block_devices when comparing integrity profiles. Change function parameters accordingly. Also update comparison logic so that two NULL profiles are a valid configuration. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Fix double put in blk_integrity_unregisterMartin K. Petersen
- kobject_del already puts the parent. - Set integrity profile to NULL to prevent stale data. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: remove end_{queued|dequeued}_request()Kiyoshi Ueda
This patch removes end_queued_request() and end_dequeued_request(), which are no longer used. As a results, users of __end_request() became only end_request(). So the actual code in __end_request() is moved to end_request() and __end_request() is removed. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: change elevator to use __blk_end_request()Kiyoshi Ueda
This patch converts elevator to use __blk_end_request() directly so that end_{queued|dequeued}_request() can be removed. Related 'uptodate' arguments is converted to 'error'. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09blktrace: use BLKTRACE_BDEV_SIZE as the name size for setup structureJens Axboe
Define as 32, which is is what BDEVNAME_SIZE is/was as well. This keeps the user interface the same and gets rid of the difference between kernel and user api here. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
