path: root/block/blk-throttle.c
2021-09-26blk-throttle: fix UAF by deleteing timer in blk_throtl_exit()Li Jinlin
[ Upstream commit 884f0e84f1e3195b801319c8ec3d5774e9bf2710 ] The pending timer has been set up in blk_throtl_init(). However, the timer is not deleted in blk_throtl_exit(). This means that the timer handler may still be running after freeing the timer, which would result in a use-after-free. Fix by calling del_timer_sync() to delete the timer in blk_throtl_exit(). Signed-off-by: Li Jinlin <lijinlin3@huawei.com> Link: https://lore.kernel.org/r/20210907121242.2885564-1-lijinlin3@huawei.com Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-09-15block: make rq sector size accessible for block statsHou Tao
Currently rq->data_len will be decreased by partial completion or zeroed by completion, so when blk_stat_add() is invoked, data_len will be zero and there will never be samples in poll_cb because blk_mq_poll_stats_bkt() will return -1 if data_len is zero. We could move blk_stat_add() back to __blk_mq_complete_request(), but that would make the effort of trying to call ktime_get_ns() once in vain. Instead we can reuse throtl_size field, and use it for both block stats and block throttle, and adjust the logic in blk_mq_poll_stats_bkt() accordingly. Fixes: 4bc6339a583c ("block: move blk_stat_add() to __blk_mq_end_request()") Tested-by: Pavel Begunkov <asml.silence@gmail.com> Signed-off-by: Hou Tao <houtao1@huawei.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2019-08-28blkcg: pass @q and @blkcg into blkcg_pol_alloc_pd_fn()Tejun Heo
Instead of @node, pass in @q and @blkcg so that the alloc function has more context. This doesn't cause any behavior change and will be used by io.weight implementation. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2019-07-10blk-throttle: fix zero wait time for iops throttled groupKonstantin Khlebnikov
After commit 991f61fe7e1d ("Blk-throttle: reduce tail io latency when iops limit is enforced") wait time could be zero even if group is throttled and cannot issue requests right now. As a result throtl_select_dispatch() turns into busy-loop under irq-safe queue spinlock. Fix is simple: always round up target time to the next throttle slice. Fixes: 991f61fe7e1d ("Blk-throttle: reduce tail io latency when iops limit is enforced") Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Cc: stable@vger.kernel.org # v4.19+ Signed-off-by: Jens Axboe <axboe@kernel.dk>
2019-05-31block: Fix throtl_pending_timer_fn() kernel-doc headerBart Van Assche
Commit e99e88a9d2b0 renamed a function argument without updating the corresponding kernel-doc header. Update the kernel-doc header. Reviewed-by: Chaitanya Kulkarni <chiatanya.kulkarni@wdc.com> Reviewed-by: Kees Cook <keescook@chromium.org> Fixes: e99e88a9d2b0 ("treewide: setup_timer() -> timer_setup()") # v4.15. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-12-07blkcg: consolidate bio_issue_init() to be a part of coreDennis Zhou
bio_issue_init among other things initializes the timestamp for an IO. Rather than have this logic handled by policies, this consolidates it to be on the init paths (normal, clone, bounce clone). Signed-off-by: Dennis Zhou <dennis@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Liu Bo <bo.liu@linux.alibaba.com> Reviewed-by: Josef Bacik <josef@toxicpanda.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-12-07blkcg: associate blkg when associating a deviceDennis Zhou
Previously, blkg association was handled by controller specific code in blk-throttle and blk-iolatency. However, because a blkg represents a relationship between a blkcg and a request_queue, it makes sense to keep the blkg->q and bio->bi_disk->queue consistent. This patch moves association into the bio_set_dev macro(). This should cover the majority of cases where the device is set/changed keeping the two pointers consistent. Fallback code is added to blkcg_bio_issue_check() to catch any missing paths. Signed-off-by: Dennis Zhou <dennis@kernel.org> Reviewed-by: Josef Bacik <josef@toxicpanda.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-12-07blkcg: introduce common blkg association logicDennis Zhou
There are 3 ways blkg association can happen: association with the current css, with the page css (swap), or from the wbc css (writeback). This patch handles how association is done for the first case where we are associating bsaed on the current css. If there is already a blkg associated, the css will be reused and association will be redone as the request_queue may have changed. Signed-off-by: Dennis Zhou <dennis@kernel.org> Reviewed-by: Josef Bacik <josef@toxicpanda.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-12-07blkcg: convert blkg_lookup_create() to find closest blkgDennis Zhou
There are several scenarios where blkg_lookup_create() can fail such as the blkcg dying, request_queue is dying, or simply being OOM. Most handle this by simply falling back to the q->root_blkg and calling it a day. This patch implements the notion of closest blkg. During blkg_lookup_create(), if it fails to create, return the closest blkg found or the q->root_blkg. blkg_try_get_closest() is introduced and used during association so a bio is always attached to a blkg. Signed-off-by: Dennis Zhou <dennis@kernel.org> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Josef Bacik <josef@toxicpanda.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-16block: add queue_is_mq() helperJens Axboe
Various spots check for q->mq_ops being non-NULL, but provide a helper to do this instead. Where the ->mq_ops != NULL check is redundant, remove it. Since mq == rq-based now that legacy is gone, get rid of the queue_is_rq_based() and just use queue_is_mq() everywhere. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-15block: remove the queue_lock indirectionChristoph Hellwig
With the legacy request path gone there is no good reason to keep queue_lock as a pointer, we can always use the embedded lock now. Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Fixed floppy and blk-cgroup missing conversions and half done edits. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-15block: remove queue_lockdep_assert_heldChristoph Hellwig
The only remaining user unconditionally drops and reacquires the lock, which means we really don't need any additional (conditional) annotation. Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-15block: remove QUEUE_FLAG_BYPASS and ->bypassChristoph Hellwig
Unused since the removal of the legacy request code. Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-11-01blkcg: revert blkcg cleanups seriesDennis Zhou
This reverts a series committed earlier due to null pointer exception bug report in [1]. It seems there are edge case interactions that I did not consider and will need some time to understand what causes the adverse interactions. The original series can be found in [2] with a follow up series in [3]. [1] https://www.spinics.net/lists/cgroups/msg20719.html [2] https://lore.kernel.org/lkml/20180911184137.35897-1-dennisszhou@gmail.com/ [3] https://lore.kernel.org/lkml/20181020185612.51587-1-dennis@kernel.org/ This reverts the following commits: d459d853c2ed, b2c3fa546705, 101246ec02b5, b3b9f24f5fcc, e2b0989954ae, f0fcb3ec89f3, c839e7a03f92, bdc2491708c4, 74b7c02a9bc1, 5bf9a1f3b4ef, a7b39b4e961c, 07b05bcc3213, 49f4c2dc2b50, 27e6fa996c53 Signed-off-by: Dennis Zhou <dennis@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-09-21blkcg: consolidate bio_issue_init to be a part of coreDennis Zhou (Facebook)
bio_issue_init among other things initializes the timestamp for an IO. Rather than have this logic handled by policies, this consolidates it to be on the init paths (normal, clone, bounce clone). Signed-off-by: Dennis Zhou <dennisszhou@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Reviewed-by: Liu Bo <bo.liu@linux.alibaba.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-09-21blkcg: always associate a bio with a blkgDennis Zhou (Facebook)
Previously, blkg's were only assigned as needed by blk-iolatency and blk-throttle. bio->css was also always being associated while blkg was being looked up and then thrown away in blkcg_bio_issue_check. This patch begins the cleanup of bio->css and bio->bi_blkg by always associating a blkg in blkcg_bio_issue_check. This tries to create the blkg, but if it is not possible, falls back to using the root_blkg of the request_queue. Therefore, a bio will always be associated with a blkg. The duplicate association logic is removed from blk-throttle and blk-iolatency. Signed-off-by: Dennis Zhou <dennisszhou@gmail.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-09-20Blk-throttle: update to use rbtree with leftmost node cachedLiu Bo
As rbtree has native support of caching leftmost node, i.e. rb_root_cached, no need to do the caching by ourselves. Signed-off-by: Liu Bo <bo.liu@linux.alibaba.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-08-31blkcg: use tryget logic when associating a blkg with a bioDennis Zhou (Facebook)
There is a very small change a bio gets caught up in a really unfortunate race between a task migration, cgroup exiting, and itself trying to associate with a blkg. This is due to css offlining being performed after the css->refcnt is killed which triggers removal of blkgs that reach their blkg->refcnt of 0. To avoid this, association with a blkg should use tryget and fallback to using the root_blkg. Fixes: 08e18eab0c579 ("block: add bi_blkg to the bio for cgroups") Reviewed-by: Josef Bacik <josef@toxicpanda.com> Signed-off-by: Dennis Zhou <dennisszhou@gmail.com> Cc: Jiufei Xue <jiufei.xue@linux.alibaba.com> Cc: Joseph Qi <joseph.qi@linux.alibaba.com> Cc: Tejun Heo <tj@kernel.org> Cc: Josef Bacik <josef@toxicpanda.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-08-09Blk-throttle: reduce tail io latency when iops limit is enforcedLiu Bo
When an application's iops has exceeded its cgroup's iops limit, surely it is throttled and kernel will set a timer for dispatching, thus IO latency includes the delay. However, the dispatch delay which is calculated by the limit and the elapsed jiffies is suboptimal. As the dispatch delay is only calculated once the application's iops is (iops limit + 1), it doesn't need to wait any longer than the remaining time of the current slice. The difference can be proved by the following fio job and cgroup iops setting, ----- $ echo 4 > /mnt/config/nullb/disk1/mbps # limit nullb's bandwidth to 4MB/s for testing. $ echo "253:1 riops=100 rbps=max" > /sys/fs/cgroup/unified/cg1/io.max $ cat r2.job [global] name=fio-rand-read filename=/dev/nullb1 rw=randread bs=4k direct=1 numjobs=1 time_based=1 runtime=60 group_reporting=1 [file1] size=4G ioengine=libaio iodepth=1 rate_iops=50000 norandommap=1 thinktime=4ms ----- wo patch: file1: (g=0): rw=randread, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=1 fio-3.7-66-gedfc Starting 1 process read: IOPS=99, BW=400KiB/s (410kB/s)(23.4MiB/60001msec) slat (usec): min=10, max=336, avg=27.71, stdev=17.82 clat (usec): min=2, max=28887, avg=5929.81, stdev=7374.29 lat (usec): min=24, max=28901, avg=5958.73, stdev=7366.22 clat percentiles (usec): | 1.00th=[ 4], 5.00th=[ 4], 10.00th=[ 4], 20.00th=[ 4], | 30.00th=[ 4], 40.00th=[ 4], 50.00th=[ 6], 60.00th=[11731], | 70.00th=[11863], 80.00th=[11994], 90.00th=[12911], 95.00th=[22676], | 99.00th=[23725], 99.50th=[23987], 99.90th=[23987], 99.95th=[25035], | 99.99th=[28967] w/ patch: file1: (g=0): rw=randread, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=libaio, iodepth=1 fio-3.7-66-gedfc Starting 1 process read: IOPS=100, BW=400KiB/s (410kB/s)(23.4MiB/60005msec) slat (usec): min=10, max=155, avg=23.24, stdev=16.79 clat (usec): min=2, max=12393, avg=5961.58, stdev=5959.25 lat (usec): min=23, max=12412, avg=5985.91, stdev=5951.92 clat percentiles (usec): | 1.00th=[ 3], 5.00th=[ 3], 10.00th=[ 4], 20.00th=[ 4], | 30.00th=[ 4], 40.00th=[ 5], 50.00th=[ 47], 60.00th=[11863], | 70.00th=[11994], 80.00th=[11994], 90.00th=[11994], 95.00th=[11994], | 99.00th=[11994], 99.50th=[11994], 99.90th=[12125], 99.95th=[12125], | 99.99th=[12387] Signed-off-by: Liu Bo <bo.liu@linux.alibaba.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-07-09block: add bi_blkg to the bio for cgroupsJosef Bacik
Currently io.low uses a bi_cg_private to stash its private data for the blkg, however other blkcg policies may want to use this as well. Since we can get the private data out of the blkg, move this to bi_blkg in the bio and make it generic, then we can use bio_associate_blkg() to attach the blkg to the bio. Theoretically we could simply replace the bi_css with this since we can get to all the same information from the blkg, however you have to lookup the blkg, so for example wbc_init_bio() would have to lookup and possibly allocate the blkg for the css it was trying to attach to the bio. This could be problematic and result in us either not attaching the css at all to the bio, or falling back to the root blkcg if we are unable to allocate the corresponding blkg. So for now do this, and in the future if possible we could just replace the bi_css with bi_blkg and update the helpers to do the correct translation. Signed-off-by: Josef Bacik <jbacik@fb.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-07-09Block: blk-throttle: set low_valid immediately once one cgroup has io.low ↵Liu Bo
configured Once one cgroup has io.low configured, @low_valid becomes true and other cgroups won't switch it back whatsoever. Signed-off-by: Liu Bo <bo.liu@linux.alibaba.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-05-30blk-throttle: return proper bool type to caller instead of 0/1Chengguang Xu
Change to return true/false only for bool type return code. Signed-off-by: Chengguang Xu <cgxu519@gmx.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-05-30blk-throttle: fix potential NULL pointer dereference in throtl_select_dispatchLiu Bo
tg in throtl_select_dispatch is used first and then do check. Since tg may be NULL, it has potential NULL pointer dereference risk. So fix it. Signed-off-by: Joseph Qi <joseph.qi@linux.alibaba.com> Signed-off-by: Liu Bo <bo.liu@linux.alibaba.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-05-09block: get rid of struct blk_issue_statOmar Sandoval
struct blk_issue_stat squashes three things into one u64: - The time the driver started working on a request - The original size of the request (for the io.low controller) - Flags for writeback throttling It turns out that on x86_64, we have a 4 byte hole in struct request which we can fill with the non-timestamp fields from blk_issue_stat, simplifying things quite a bit. Signed-off-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-05-09block: replace bio->bi_issue_stat with bio-specific typeOmar Sandoval
struct blk_issue_stat is going away, and bio->bi_issue_stat doesn't even use the blk-stats interface, so we can provide a separate implementation specific for bios. The helpers work the same way as the blk-stats helpers. Signed-off-by: Omar Sandoval <osandov@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-29Merge branch 'for-4.16/block' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block updates from Jens Axboe: "This is the main pull request for block IO related changes for the 4.16 kernel. Nothing major in this pull request, but a good amount of improvements and fixes all over the map. This contains: - BFQ improvements, fixes, and cleanups from Angelo, Chiara, and Paolo. - Support for SMR zones for deadline and mq-deadline from Damien and Christoph. - Set of fixes for bcache by way of Michael Lyle, including fixes from himself, Kent, Rui, Tang, and Coly. - Series from Matias for lightnvm with fixes from Hans Holmberg, Javier, and Matias. Mostly centered around pblk, and the removing rrpc 1.2 in preparation for supporting 2.0. - A couple of NVMe pull requests from Christoph. Nothing major in here, just fixes and cleanups, and support for command tracing from Johannes. - Support for blk-throttle for tracking reads and writes separately. From Joseph Qi. A few cleanups/fixes also for blk-throttle from Weiping. - Series from Mike Snitzer that enables dm to register its queue more logically, something that's alwways been problematic on dm since it's a stacked device. - Series from Ming cleaning up some of the bio accessor use, in preparation for supporting multipage bvecs. - Various fixes from Ming closing up holes around queue mapping and quiescing. - BSD partition fix from Richard Narron, fixing a problem where we can't mount newer (10/11) FreeBSD partitions. - Series from Tejun reworking blk-mq timeout handling. The previous scheme relied on atomic bits, but it had races where we would think a request had timed out if it to reused at the wrong time. - null_blk now supports faking timeouts, to enable us to better exercise and test that functionality separately. From me. - Kill the separate atomic poll bit in the request struct. After this, we don't use the atomic bits on blk-mq anymore at all. From me. - sgl_alloc/free helpers from Bart. - Heavily contended tag case scalability improvement from me. - Various little fixes and cleanups from Arnd, Bart, Corentin, Douglas, Eryu, Goldwyn, and myself" * 'for-4.16/block' of git://git.kernel.dk/linux-block: (186 commits) block: remove smart1,2.h nvme: add tracepoint for nvme_complete_rq nvme: add tracepoint for nvme_setup_cmd nvme-pci: introduce RECONNECTING state to mark initializing procedure nvme-rdma: remove redundant boolean for inline_data nvme: don't free uuid pointer before printing it nvme-pci: Suspend queues after deleting them bsg: use pr_debug instead of hand crafted macros blk-mq-debugfs: don't allow write on attributes with seq_operations set nvme-pci: Fix queue double allocations block: Set BIO_TRACE_COMPLETION on new bio during split blk-throttle: use queue_is_rq_based block: Remove kblockd_schedule_delayed_work{,_on}() blk-mq: Avoid that blk_mq_delay_run_hw_queue() introduces unintended delays blk-mq: Rename blk_mq_request_direct_issue() into blk_mq_request_issue_directly() lib/scatterlist: Fix chaining support in sgl_alloc_order() blk-throttle: track read and write request individually block: add bdev_read_only() checks to common helpers block: fail op_is_write() requests to read-only partitions blk-throttle: export io_serviced_recursive, io_service_bytes_recursive ...
2018-01-19blk-throttle: use queue_is_rq_basedweiping zhang
use queue_is_rq_based instead of open code. Signed-off-by: weiping zhang <zhangweiping@didichuxing.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-18blk-throttle: track read and write request individuallyJoseph Qi
In mixed read/write workload on SSD, write latency is much lower than read. But now we only track and record read latency and then use it as threshold base for both read and write io latency accounting. As a result, write io latency will always be considered as good and bad_bio_cnt is much smaller than 20% of bio_cnt. That is to mean, the tg to be checked will be treated as idle most of the time and still let others dispatch more ios, even it is truly running under low limit and wants its low limit to be guaranteed, which is not we expected in fact. So track read and write request individually, which can bring more precise latency control for low limit idle detection. Signed-off-by: Joseph Qi <qijiang.qj@alibaba-inc.com> Reviewed-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-01-18blk-throttle: export io_serviced_recursive, io_service_bytes_recursiveweiping zhang
export these two interface for cgroup-v1. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: weiping zhang <zhangweiping@didichuxing.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-12-20block-throttle: avoid double chargeShaohua Li
If a bio is throttled and split after throttling, the bio could be resubmited and enters the throttling again. This will cause part of the bio to be charged multiple times. If the cgroup has an IO limit, the double charge will significantly harm the performance. The bio split becomes quite common after arbitrary bio size change. To fix this, we always set the BIO_THROTTLED flag if a bio is throttled. If the bio is cloned/split, we copy the flag to new bio too to avoid a double charge. However, cloned bio could be directed to a new disk, keeping the flag be a problem. The observation is we always set new disk for the bio in this case, so we can clear the flag in bio_set_dev(). This issue exists for a long time, arbitrary bio size change just makes it worse, so this should go into stable at least since v4.2. V1-> V2: Not add extra field in bio based on discussion with Tejun Cc: Vivek Goyal <vgoyal@redhat.com> Cc: stable@vger.kernel.org Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-11-21treewide: setup_timer() -> timer_setup()Kees Cook
This converts all remaining cases of the old setup_timer() API into using timer_setup(), where the callback argument is the structure already holding the struct timer_list. These should have no behavioral changes, since they just change which pointer is passed into the callback with the same available pointers after conversion. It handles the following examples, in addition to some other variations. Casting from unsigned long: void my_callback(unsigned long data) { struct something *ptr = (struct something *)data; ... } ... setup_timer(&ptr->my_timer, my_callback, ptr); and forced object casts: void my_callback(struct something *ptr) { ... } ... setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr); become: void my_callback(struct timer_list *t) { struct something *ptr = from_timer(ptr, t, my_timer); ... } ... timer_setup(&ptr->my_timer, my_callback, 0); Direct function assignments: void my_callback(unsigned long data) { struct something *ptr = (struct something *)data; ... } ... ptr->my_timer.function = my_callback; have a temporary cast added, along with converting the args: void my_callback(struct timer_list *t) { struct something *ptr = from_timer(ptr, t, my_timer); ... } ... ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback; And finally, callbacks without a data assignment: void my_callback(unsigned long data) { ... } ... setup_timer(&ptr->my_timer, my_callback, 0); have their argument renamed to verify they're unused during conversion: void my_callback(struct timer_list *unused) { ... } ... timer_setup(&ptr->my_timer, my_callback, 0); The conversion is done with the following Coccinelle script: spatch --very-quiet --all-includes --include-headers \ -I ./arch/x86/include -I ./arch/x86/include/generated \ -I ./include -I ./arch/x86/include/uapi \ -I ./arch/x86/include/generated/uapi -I ./include/uapi \ -I ./include/generated/uapi --include ./include/linux/kconfig.h \ --dir . \ --cocci-file ~/src/data/timer_setup.cocci @fix_address_of@ expression e; @@ setup_timer( -&(e) +&e , ...) // Update any raw setup_timer() usages that have a NULL callback, but // would otherwise match change_timer_function_usage, since the latter // will update all function assignments done in the face of a NULL // function initialization in setup_timer(). @change_timer_function_usage_NULL@ expression _E; identifier _timer; type _cast_data; @@ ( -setup_timer(&_E->_timer, NULL, _E); +timer_setup(&_E->_timer, NULL, 0); | -setup_timer(&_E->_timer, NULL, (_cast_data)_E); +timer_setup(&_E->_timer, NULL, 0); | -setup_timer(&_E._timer, NULL, &_E); +timer_setup(&_E._timer, NULL, 0); | -setup_timer(&_E._timer, NULL, (_cast_data)&_E); +timer_setup(&_E._timer, NULL, 0); ) @change_timer_function_usage@ expression _E; identifier _timer; struct timer_list _stl; identifier _callback; type _cast_func, _cast_data; @@ ( -setup_timer(&_E->_timer, _callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, &_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, &_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)&_callback, _E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E._timer, _callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, &_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, &_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E); +timer_setup(&_E._timer, _callback, 0); | _E->_timer@_stl.function = _callback; | _E->_timer@_stl.function = &_callback; | _E->_timer@_stl.function = (_cast_func)_callback; | _E->_timer@_stl.function = (_cast_func)&_callback; | _E._timer@_stl.function = _callback; | _E._timer@_stl.function = &_callback; | _E._timer@_stl.function = (_cast_func)_callback; | _E._timer@_stl.function = (_cast_func)&_callback; ) // callback(unsigned long arg) @change_callback_handle_cast depends on change_timer_function_usage@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; identifier _handle; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { ( ... when != _origarg _handletype *_handle = -(_handletype *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle = -(void *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(_handletype *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg | ... when != _origarg _handletype *_handle; ... when != _handle _handle = -(void *)_origarg; +from_timer(_handle, t, _timer); ... when != _origarg ) } // callback(unsigned long arg) without existing variable @change_callback_handle_cast_no_arg depends on change_timer_function_usage && !change_callback_handle_cast@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _origtype; identifier _origarg; type _handletype; @@ void _callback( -_origtype _origarg +struct timer_list *t ) { + _handletype *_origarg = from_timer(_origarg, t, _timer); + ... when != _origarg - (_handletype *)_origarg + _origarg ... when != _origarg } // Avoid already converted callbacks. @match_callback_converted depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier t; @@ void _callback(struct timer_list *t) { ... } // callback(struct something *handle) @change_callback_handle_arg depends on change_timer_function_usage && !match_callback_converted && !change_callback_handle_cast && !change_callback_handle_cast_no_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; @@ void _callback( -_handletype *_handle +struct timer_list *t ) { + _handletype *_handle = from_timer(_handle, t, _timer); ... } // If change_callback_handle_arg ran on an empty function, remove // the added handler. @unchange_callback_handle_arg depends on change_timer_function_usage && change_callback_handle_arg@ identifier change_timer_function_usage._callback; identifier change_timer_function_usage._timer; type _handletype; identifier _handle; identifier t; @@ void _callback(struct timer_list *t) { - _handletype *_handle = from_timer(_handle, t, _timer); } // We only want to refactor the setup_timer() data argument if we've found // the matching callback. This undoes changes in change_timer_function_usage. @unchange_timer_function_usage depends on change_timer_function_usage && !change_callback_handle_cast && !change_callback_handle_cast_no_arg && !change_callback_handle_arg@ expression change_timer_function_usage._E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type change_timer_function_usage._cast_data; @@ ( -timer_setup(&_E->_timer, _callback, 0); +setup_timer(&_E->_timer, _callback, (_cast_data)_E); | -timer_setup(&_E._timer, _callback, 0); +setup_timer(&_E._timer, _callback, (_cast_data)&_E); ) // If we fixed a callback from a .function assignment, fix the // assignment cast now. @change_timer_function_assignment depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression change_timer_function_usage._E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_func; typedef TIMER_FUNC_TYPE; @@ ( _E->_timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -&_callback +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -(_cast_func)_callback; +(TIMER_FUNC_TYPE)_callback ; | _E->_timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -&_callback; +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -(_cast_func)_callback +(TIMER_FUNC_TYPE)_callback ; | _E._timer.function = -(_cast_func)&_callback +(TIMER_FUNC_TYPE)_callback ; ) // Sometimes timer functions are called directly. Replace matched args. @change_timer_function_calls depends on change_timer_function_usage && (change_callback_handle_cast || change_callback_handle_cast_no_arg || change_callback_handle_arg)@ expression _E; identifier change_timer_function_usage._timer; identifier change_timer_function_usage._callback; type _cast_data; @@ _callback( ( -(_cast_data)_E +&_E->_timer | -(_cast_data)&_E +&_E._timer | -_E +&_E->_timer ) ) // If a timer has been configured without a data argument, it can be // converted without regard to the callback argument, since it is unused. @match_timer_function_unused_data@ expression _E; identifier _timer; identifier _callback; @@ ( -setup_timer(&_E->_timer, _callback, 0); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, 0L); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E->_timer, _callback, 0UL); +timer_setup(&_E->_timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0L); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_E._timer, _callback, 0UL); +timer_setup(&_E._timer, _callback, 0); | -setup_timer(&_timer, _callback, 0); +timer_setup(&_timer, _callback, 0); | -setup_timer(&_timer, _callback, 0L); +timer_setup(&_timer, _callback, 0); | -setup_timer(&_timer, _callback, 0UL); +timer_setup(&_timer, _callback, 0); | -setup_timer(_timer, _callback, 0); +timer_setup(_timer, _callback, 0); | -setup_timer(_timer, _callback, 0L); +timer_setup(_timer, _callback, 0); | -setup_timer(_timer, _callback, 0UL); +timer_setup(_timer, _callback, 0); ) @change_callback_unused_data depends on match_timer_function_unused_data@ identifier match_timer_function_unused_data._callback; type _origtype; identifier _origarg; @@ void _callback( -_origtype _origarg +struct timer_list *unused ) { ... when != _origarg } Signed-off-by: Kees Cook <keescook@chromium.org>
2017-11-14Merge branch 'for-4.15/block' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block layer updates from Jens Axboe: "This is the main pull request for block storage for 4.15-rc1. Nothing out of the ordinary in here, and no API changes or anything like that. Just various new features for drivers, core changes, etc. In particular, this pull request contains: - A patch series from Bart, closing the whole on blk/scsi-mq queue quescing. - A series from Christoph, building towards hidden gendisks (for multipath) and ability to move bio chains around. - NVMe - Support for native multipath for NVMe (Christoph). - Userspace notifications for AENs (Keith). - Command side-effects support (Keith). - SGL support (Chaitanya Kulkarni) - FC fixes and improvements (James Smart) - Lots of fixes and tweaks (Various) - bcache - New maintainer (Michael Lyle) - Writeback control improvements (Michael) - Various fixes (Coly, Elena, Eric, Liang, et al) - lightnvm updates, mostly centered around the pblk interface (Javier, Hans, and Rakesh). - Removal of unused bio/bvec kmap atomic interfaces (me, Christoph) - Writeback series that fix the much discussed hundreds of millions of sync-all units. This goes all the way, as discussed previously (me). - Fix for missing wakeup on writeback timer adjustments (Yafang Shao). - Fix laptop mode on blk-mq (me). - {mq,name} tupple lookup for IO schedulers, allowing us to have alias names. This means you can use 'deadline' on both !mq and on mq (where it's called mq-deadline). (me). - blktrace race fix, oopsing on sg load (me). - blk-mq optimizations (me). - Obscure waitqueue race fix for kyber (Omar). - NBD fixes (Josef). - Disable writeback throttling by default on bfq, like we do on cfq (Luca Miccio). - Series from Ming that enable us to treat flush requests on blk-mq like any other request. This is a really nice cleanup. - Series from Ming that improves merging on blk-mq with schedulers, getting us closer to flipping the switch on scsi-mq again. - BFQ updates (Paolo). - blk-mq atomic flags memory ordering fixes (Peter Z). - Loop cgroup support (Shaohua). - Lots of minor fixes from lots of different folks, both for core and driver code" * 'for-4.15/block' of git://git.kernel.dk/linux-block: (294 commits) nvme: fix visibility of "uuid" ns attribute blk-mq: fixup some comment typos and lengths ide: ide-atapi: fix compile error with defining macro DEBUG blk-mq: improve tag waiting setup for non-shared tags brd: remove unused brd_mutex blk-mq: only run the hardware queue if IO is pending block: avoid null pointer dereference on null disk fs: guard_bio_eod() needs to consider partitions xtensa/simdisk: fix compile error nvme: expose subsys attribute to sysfs nvme: create 'slaves' and 'holders' entries for hidden controllers block: create 'slaves' and 'holders' entries for hidden gendisks nvme: also expose the namespace identification sysfs files for mpath nodes nvme: implement multipath access to nvme subsystems nvme: track shared namespaces nvme: introduce a nvme_ns_ids structure nvme: track subsystems block, nvme: Introduce blk_mq_req_flags_t block, scsi: Make SCSI quiesce and resume work reliably block: Add the QUEUE_FLAG_PREEMPT_ONLY request queue flag ...
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-10blk-throttle: fix null pointer dereference while throttling writeback IOsJiufei Xue
A null pointer dereference can occur when blkcg is removed manually with writeback IOs inflight. This is caused by the following case: Writeback kworker submit the bio and set bio->bi_cg_private to tg in blk_throtl_assoc_bio. Then we remove the block cgroup manually, the blkg and tg would be freed if there is no request inflight. When the submitted bio come back, blk_throtl_bio_endio() fetch the tg which was already freed. Fix this by increasing the refcount of blkg in funcion blk_throtl_assoc_bio() so that the blkg will not be freed until the bio_endio called. Reviewed-by: Shaohua Li <shli@fb.com> Signed-off-by: Jiufei Xue <jiufei.xjf@alibaba-inc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-10-03blk-throttle: fix possible io stall when upgrade to maxJoseph Qi
There is a case which will lead to io stall. The case is described as follows. /test1 |-subtest1 /test2 |-subtest2 And subtest1 and subtest2 each has 32 queued bios already. Now upgrade to max. In throtl_upgrade_state, it will try to dispatch bios as follows: 1) tg=subtest1, do nothing; 2) tg=test1, transfer 32 queued bios from subtest1 to test1; no pending left, no need to schedule next dispatch; 3) tg=subtest2, do nothing; 4) tg=test2, transfer 32 queued bios from subtest2 to test2; no pending left, no need to schedule next dispatch; 5) tg=/, transfer 8 queued bios from test1 to /, 8 queued bios from test2 to /, 8 queued bios from test1 to /, and 8 queued bios from test2 to /; note that test1 and test2 each still has 16 queued bios left; 6) tg=/, try to schedule next dispatch, but since disptime is now (update in tg_update_disptime, wait=0), pending timer is not scheduled in fact; 7) In throtl_upgrade_state it totally dispatches 32 queued bios and with 32 left. test1 and test2 each has 16 queued bios; 8) throtl_pending_timer_fn sees the left over bios, but could do nothing, because throtl_select_dispatch returns 0, and test1/test2 has no pending tg. The blktrace shows the following: 8,32 0 0 2.539007641 0 m N throtl upgrade to max 8,32 0 0 2.539072267 0 m N throtl /test2 dispatch nr_queued=16 read=0 write=16 8,32 7 0 2.539077142 0 m N throtl /test1 dispatch nr_queued=16 read=0 write=16 So force schedule dispatch if there are pending children. Reviewed-by: Shaohua Li <shli@fb.com> Signed-off-by: Joseph Qi <qijiang.qj@alibaba-inc.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-09-07Merge branch 'for-4.14/block' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer updates from Jens Axboe: "This is the first pull request for 4.14, containing most of the code changes. It's a quiet series this round, which I think we needed after the churn of the last few series. This contains: - Fix for a registration race in loop, from Anton Volkov. - Overflow complaint fix from Arnd for DAC960. - Series of drbd changes from the usual suspects. - Conversion of the stec/skd driver to blk-mq. From Bart. - A few BFQ improvements/fixes from Paolo. - CFQ improvement from Ritesh, allowing idling for group idle. - A few fixes found by Dan's smatch, courtesy of Dan. - A warning fixup for a race between changing the IO scheduler and device remova. From David Jeffery. - A few nbd fixes from Josef. - Support for cgroup info in blktrace, from Shaohua. - Also from Shaohua, new features in the null_blk driver to allow it to actually hold data, among other things. - Various corner cases and error handling fixes from Weiping Zhang. - Improvements to the IO stats tracking for blk-mq from me. Can drastically improve performance for fast devices and/or big machines. - Series from Christoph removing bi_bdev as being needed for IO submission, in preparation for nvme multipathing code. - Series from Bart, including various cleanups and fixes for switch fall through case complaints" * 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits) kernfs: checking for IS_ERR() instead of NULL drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set drbd: Fix allyesconfig build, fix recent commit drbd: switch from kmalloc() to kmalloc_array() drbd: abort drbd_start_resync if there is no connection drbd: move global variables to drbd namespace and make some static drbd: rename "usermode_helper" to "drbd_usermode_helper" drbd: fix race between handshake and admin disconnect/down drbd: fix potential deadlock when trying to detach during handshake drbd: A single dot should be put into a sequence. drbd: fix rmmod cleanup, remove _all_ debugfs entries drbd: Use setup_timer() instead of init_timer() to simplify the code. drbd: fix potential get_ldev/put_ldev refcount imbalance during attach drbd: new disk-option disable-write-same drbd: Fix resource role for newly created resources in events2 drbd: mark symbols static where possible drbd: Send P_NEG_ACK upon write error in protocol != C drbd: add explicit plugging when submitting batches drbd: change list_for_each_safe to while(list_first_entry_or_null) drbd: introduce drbd_recv_header_maybe_unplug ...
2017-08-23blk-throttle: cap discard request sizeShaohua Li
discard request usually is very big and easily use all bandwidth budget of a cgroup. discard request size doesn't really mean the size of data written, so it doesn't make sense to account it into bandwidth budget. Jens pointed out treating the size 0 doesn't make sense too, because discard request does have cost. But it's not easy to find the actual cost. This patch simply makes the size one sector. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-07-29block: use standard blktrace API to output cgroup info for debug notesShaohua Li
Currently cfq/bfq/blk-throttle output cgroup info in trace in their own way. Now we have standard blktrace API for this, so convert them to use it. Note, this changes the behavior a little bit. cgroup info isn't output by default, we only do this with 'blk_cgroup' option enabled. cgroup info isn't output as a string by default too, we only do this with 'blk_cgname' option enabled. Also cgroup info is output in different position of the note string. I think these behavior changes aren't a big issue (actually we make trace data shorter which is good), since the blktrace note is solely for debugging. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-07-29block: always attach cgroup info into bioShaohua Li
blkcg_bio_issue_check() already gets blkcg for a BIO. bio_associate_blkcg() uses a percpu refcounter, so it's a very cheap operation. There is no point we don't attach the cgroup info into bio at blkcg_bio_issue_check. This also makes blktrace outputs correct cgroup info. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-06-07blk-throttle: set default latency baseline for harddiskShaohua Li
hard disk IO latency varies a lot depending on spindle move. The latency range could be from several microseconds to several milliseconds. It's pretty hard to get the baseline latency used by io.low. We will use a different stragety here. The idea is only using IO with spindle move to determine if cgroup IO is in good state. For HD, if io latency is small (< 1ms), we ignore the IO. Such IO is likely from sequential IO, and is helpless to help determine if a cgroup's IO is impacted by other cgroups. With this, we only account IO with big latency. Then we can choose a hardcoded baseline latency for HD (4ms, which is typical IO latency with seek). With all these settings, the io.low latency works for both HD and SSD. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-06-07blk-throttle: fix NULL pointer dereference in throtl_schedule_pending_timerJoseph Qi
I have encountered a NULL pointer dereference in throtl_schedule_pending_timer: [ 413.735396] BUG: unable to handle kernel NULL pointer dereference at 0000000000000038 [ 413.735535] IP: [<ffffffff812ebbbf>] throtl_schedule_pending_timer+0x3f/0x210 [ 413.735643] PGD 22c8cf067 PUD 22cb34067 PMD 0 [ 413.735713] Oops: 0000 [#1] SMP ...... This is caused by the following case: blk_throtl_bio throtl_schedule_next_dispatch <= sq is top level one without parent throtl_schedule_pending_timer sq_to_tg(sq)->td->throtl_slice <= sq_to_tg(sq) returns NULL Fix it by using sq_to_td instead of sq_to_tg(sq)->td, which will always return a valid td. Fixes: 297e3d854784 ("blk-throttle: make throtl_slice tunable") Signed-off-by: Joseph Qi <qijiang.qj@alibaba-inc.com> Reviewed-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-05-22blk-throttle: force user to configure all settings for io.lowShaohua Li
Default value of io.low limit is 0. If user doesn't configure the limit, last patch makes cgroup be throttled to very tiny bps/iops, which could stall the system. A cgroup with default settings of io.low limit really means nothing, so we force user to configure all settings, otherwise io.low limit doesn't take effect. With this stragety, default setting of latency/idle isn't important, so just set them to very conservative and safe value. Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-05-22blk-throttle: respect 0 bps/iops settings for io.lowShaohua Li
If a cgroup with low limit 0 for both bps/iops, the cgroup's low limit is ignored and we throttle the cgroup with its max limit. In this way, other cgroups with a low limit will not get protected. To fix this, we don't do the exception any more. cgroup will be throttled to a limit 0 if it uese default setting. To avoid completed stall, we give such cgroup tiny IO resources. Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-05-22blk-throttle: output some debug info in traceShaohua Li
These info are important to understand what's happening and help debug. Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-05-22blk-throttle: add hierarchy support for latency target and idle timeShaohua Li
For idle time, children's setting should not be bigger than parent's. For latency target, children's setting should not be smaller than parent's. The leaf nodes will adjust their settings according to the hierarchy and compare their IO with the settings and do upgrade/downgrade. parents nodes don't need to track their IO latency/idle time. Signed-off-by: Shaohua Li <shli@fb.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-04-20blk-throttle: fix unused variable warning with BLK_DEV_THROTTLING_LOW=nJens Axboe
We trigger this warning: block/blk-throttle.c: In function ‘blk_throtl_bio’: block/blk-throttle.c:2042:6: warning: variable ‘ret’ set but not used [-Wunused-but-set-variable] int ret; ^~~ since we only assign 'ret' if BLK_DEV_THROTTLING_LOW is off, we never check it. Reported-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-03-28blk-throttle: add latency target supportShaohua Li
One hard problem adding .low limit is to detect idle cgroup. If one cgroup doesn't dispatch enough IO against its low limit, we must have a mechanism to determine if other cgroups dispatch more IO. We added the think time detection mechanism before, but it doesn't work for all workloads. Here we add a latency based approach. We already have mechanism to calculate latency threshold for each IO size. For every IO dispatched from a cgorup, we compare its latency against its threshold and record the info. If most IO latency is below threshold (in the code I use 75%), the cgroup could be treated idle and other cgroups can dispatch more IO. Currently this latency target check is only for SSD as we can't calcualte the latency target for hard disk. And this is only for cgroup leaf node so far. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-03-28blk-throttle: add a mechanism to estimate IO latencyShaohua Li
User configures latency target, but the latency threshold for each request size isn't fixed. For a SSD, the IO latency highly depends on request size. To calculate latency threshold, we sample some data, eg, average latency for request size 4k, 8k, 16k, 32k .. 1M. The latency threshold of each request size will be the sample latency (I'll call it base latency) plus latency target. For example, the base latency for request size 4k is 80us and user configures latency target 60us. The 4k latency threshold will be 80 + 60 = 140us. To sample data, we calculate the order base 2 of rounded up IO sectors. If the IO size is bigger than 1M, it will be accounted as 1M. Since the calculation does round up, the base latency will be slightly smaller than actual value. Also if there isn't any IO dispatched for a specific IO size, we will use the base latency of smaller IO size for this IO size. But we shouldn't sample data at any time. The base latency is supposed to be latency where disk isn't congested, because we use latency threshold to schedule IOs between cgroups. If disk is congested, the latency is higher, using it for scheduling is meaningless. Hence we only do the sampling when block throttling is in the LOW limit, with assumption disk isn't congested in such state. If the assumption isn't true, eg, low limit is too high, calculated latency threshold will be higher. Hard disk is completely different. Latency depends on spindle seek instead of request size. Currently this feature is SSD only, we probably can use a fixed threshold like 4ms for hard disk though. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-03-28blk-throttle: add interface for per-cgroup target latencyShaohua Li
Here we introduce per-cgroup latency target. The target determines how a cgroup can afford latency increasement. We will use the target latency to calculate a threshold and use it to schedule IO for cgroups. If a cgroup's bandwidth is below its low limit but its average latency is below the threshold, other cgroups can safely dispatch more IO even their bandwidth is higher than their low limits. On the other hand, if the first cgroup's latency is higher than the threshold, other cgroups are throttled to their low limits. So the target latency determines how we efficiently utilize free disk resource without sacifice of worload's IO latency. For example, assume 4k IO average latency is 50us when disk isn't congested. A cgroup sets the target latency to 30us. Then the cgroup can accept 50+30=80us IO latency. If the cgroupt's average IO latency is 90us and its bandwidth is below low limit, other cgroups are throttled to their low limit. If the cgroup's average IO latency is 60us, other cgroups are allowed to dispatch more IO. When other cgroups dispatch more IO, the first cgroup's IO latency will increase. If it increases to 81us, we then throttle other cgroups. User will configure the interface in this way: echo "8:16 rbps=2097152 wbps=max latency=100 idle=200" > io.low latency is in microsecond unit By default, latency target is 0, which means to guarantee IO latency. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2017-03-28blk-throttle: ignore idle cgroup limitShaohua Li
Last patch introduces a way to detect idle cgroup. We use it to make upgrade/downgrade decision. And the new algorithm can detect completely idle cgroup too, so we can delete the corresponding code. Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Jens Axboe <axboe@fb.com>
