git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"One performance optimization for page_clear and a couple of bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/mm: fix incorrect ASCE after crst_table_downgrade
s390/ftrace: fix crashes when switching tracers / add notrace to cpu_relax()
s390/pci: unify pci_iomap symbol exports
s390/pci: fix [un]map_resources sequence
s390: let the compiler do page clearing
s390/pci: fix possible information leak in mmio syscall
s390/dcss: array index 'i' is used before limits check.
s390/scm_block: fix off by one during cluster reservation
s390/jump label: improve and fix sanity check
s390/jump label: add missing jump_label_apply_nops() call
Pull networking fixes from David Miller:
1) nft_compat accidently truncates ethernet protocol to 8-bits, from
Arturo Borrero.
2) Memory leak in ip_vs_proc_conn(), from Julian Anastasov.
3) Don't allow the space required for nftables rules to exceed the
maximum value representable in the dlen field. From Patrick
McHardy.
4) bcm63xx_enet can accidently leave interrupts permanently disabled
due to errors in the NAPI polling exit logic. Fix from Nicolas
Schichan.
5) Fix OOPSes triggerable by the ping protocol module, due to missing
address family validations etc. From Lorenzo Colitti.
6) Don't use RCU locking in sleepable context in team driver, from Jiri
Pirko.
7) xen-netback miscalculates statistic offset pointers when reporting
the stats to userspace. From David Vrabel.
8) Fix a leak of up to 256 pages per VIF destroy in xen-netaback, also
from David Vrabel.
9) ip_check_defrag() cannot assume that skb_network_offset(),
particularly when it is used by the AF_PACKET fanout defrag code.
From Alexander Drozdov.
10) gianfar driver doesn't query OF node names properly when trying to
determine the number of hw queues available. Fix it to explicitly
check for OF nodes named queue-group. From Tobias Waldekranz.
11) MID field in macb driver should be 12 bits, not 16. From Punnaiah
Choudary Kalluri.
12) Fix unintentional regression in traceroute due to timestamp socket
option changes. Empty ICMP payloads should be allowed in
non-timestamp cases. From Willem de Bruijn.
13) When devices are unregistered, we have to get rid of AF_PACKET
multicast list entries that point to it via ifindex. Fix from
Francesco Ruggeri.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits)
tipc: fix bug in link failover handling
net: delete stale packet_mclist entries
net: macb: constify macb configuration data
MAINTAINERS: add Marc Kleine-Budde as co maintainer for CAN networking layer
MAINTAINERS: linux-can moved to github
can: kvaser_usb: Read all messages in a bulk-in URB buffer
can: kvaser_usb: Avoid double free on URB submission failures
can: peak_usb: fix missing ctrlmode_ init for every dev
can: add missing initialisations in CAN related skbuffs
ip: fix error queue empty skb handling
bgmac: Clean warning messages
tcp: align tcp_xmit_size_goal() on tcp_tso_autosize()
net: fec: fix unbalanced clk disable on driver unbind
net: macb: Correct the MID field length value
net: gianfar: correctly determine the number of queue groups
ipv4: ip_check_defrag should not assume that skb_network_offset is zero
net: bcmgenet: properly disable password matching
net: eth: xgene: fix booting with devicetree
bnx2x: Force fundamental reset for EEH recovery
xen-netback: refactor xenvif_handle_frag_list()
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
"arm64 and generic kernel/module.c (acked by Rusty) fixes for
CONFIG_DEBUG_SET_MODULE_RONX"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
kernel/module.c: Update debug alignment after symtable generation
arm64: Don't use is_module_addr in setting page attributes
Pull power management and ACPI fixes from Rafael Wysocki:
"These are fixes for recent regressions (ACPI resources management,
suspend-to-idle), stable-candidate fixes (ACPI backlight), fixes
related to the wakeup IRQ management changes made in v3.18, other
fixes (suspend-to-idle, cpufreq ppc driver) and a couple of cleanups
(suspend-to-idle, generic power domains, ACPI backlight).
Specifics:
- Fix ACPI resources management problems introduced by the recent
rework of the code in question (Jiang Liu) and a build issue
introduced by those changes (Joachim Nilsson).
- Fix a recent suspend-to-idle regression on systems where entering
idle states causes local timers to stop, prevent suspend-to-idle
from crashing in restricted configurations (no cpuidle driver,
cpuidle disabled etc.) and clean up the idle loop somewhat while at
it (Rafael J Wysocki).
- Fix build problem in the cpufreq ppc driver (Geert Uytterhoeven).
- Allow the ACPI backlight driver module to be loaded if ACPI is
disabled which helps the i915 driver in those configurations
(stable-candidate) and change the code to help debug unusual use
cases (Chris Wilson).
- Wakeup IRQ management changes in v3.18 caused some drivers on the
at91 platform to trigger a warning from the IRQ core related to an
unexpected combination of interrupt action handler flags. However,
on at91 a timer IRQ is shared with some other devices (including
system wakeup ones) and that leads to the unusual combination of
flags in question.
To make it possible to avoid the warning introduce a new interrupt
action handler flag (which can be used by drivers to indicate the
special case to the core) and rework the problematic at91 drivers
to use it and work as expected during system suspend/resume. From
Boris Brezillon, Rafael J Wysocki and Mark Rutland.
- Clean up the generic power domains subsystem's debugfs interface
(Kevin Hilman)"
* tag 'pm+acpi-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
genirq / PM: describe IRQF_COND_SUSPEND
tty: serial: atmel: rework interrupt and wakeup handling
watchdog: at91sam9: request the irq with IRQF_NO_SUSPEND
cpuidle / sleep: Use broadcast timer for states that stop local timer
clk: at91: implement suspend/resume for the PMC irqchip
rtc: at91rm9200: rework wakeup and interrupt handling
rtc: at91sam9: rework wakeup and interrupt handling
PM / wakeup: export pm_system_wakeup symbol
genirq / PM: Add flag for shared NO_SUSPEND interrupt lines
ACPI / video: Propagate the error code for acpi_video_register
ACPI / video: Load the module even if ACPI is disabled
PM / Domains: cleanup: rename gpd -> genpd in debugfs interface
cpufreq: ppc: Add missing #include <asm/smp.h>
x86/PCI/ACPI: Relax ACPI resource descriptor checks to work around BIOS bugs
x86/PCI/ACPI: Ignore resources consumed by host bridge itself
cpuidle: Clean up fallback handling in cpuidle_idle_call()
cpuidle / sleep: Do sanity checks in cpuidle_enter_freeze() too
idle / sleep: Avoid excessive disabling and enabling interrupts
PCI: versatile: Update for list_for_each_entry() API change
genirq / PM: better describe IRQF_NO_SUSPEND semantics
The set_memory_* functions currently only support module
addresses. The addresses are validated using is_module_addr.
That function is special though and relies on internal state
in the module subsystem to work properly. At the time of
module initialization and calling set_memory_*, it's too early
for is_module_addr to work properly so it always returns
false. Rather than be subject to the whims of the module state,
just bounds check against the module virtual address range.
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
* acpi-resources:
Pull x86 fixes from Ingo Molnar:
"Misc fixes: EFI fixes, an Intel Quark fix, an asm fix and an FPU
handling fix"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/fpu/xsaves: Fix improper uses of __ex_table
x86/intel/quark: Select COMMON_CLK
x86/asm/entry/64: Remove a bogus 'ret_from_fork' optimization
firmware: dmi_scan: Fix dmi_len type
efi/libstub: Fix boundary checking in efi_high_alloc()
firmware: dmi_scan: Fix dmi scan to handle "End of Table" structure
Commit:
f31a9f7c7169 ("x86/xsaves: Use xsaves/xrstors to save and restore xsave area")
introduced alternative instructions for XSAVES/XRSTORS and commit:
adb9d526e982 ("x86/xsaves: Add xsaves and xrstors support for booting time")
added support for the XSAVES/XRSTORS instructions at boot time.
Unfortunately both failed to properly protect them against faulting:
The 'xstate_fault' macro will use the closest label named '1'
backward and that ends up in the .altinstr_replacement section
rather than in .text. This means that the kernel will never find
in the __ex_table the .text address where this instruction might
fault, leading to serious problems if userspace manages to
trigger the fault.
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
[ Improved the changelog, fixed some whitespace noise. ]
Acked-by: Borislav Petkov <bp@alien8.de>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: <stable@vger.kernel.org>
Cc: Allan Xavier <mr.a.xavier@gmail.com>
Fixes: adb9d526e982 ("x86/xsaves: Add xsaves and xrstors support for booting time")
Fixes: f31a9f7c7169 ("x86/xsaves: Use xsaves/xrstors to save and restore xsave area")
The commit 8bbc2a135b63 ("x86/intel/quark: Add Intel Quark
platform support") introduced a minimal support of Intel Quark
SoC. That allows to use core parts of the SoC. However, the SPI,
I2C, and GPIO drivers can't be selected by kernel configuration
because they depend on COMMON_CLK. The patch adds a COMMON_CLK
selection to the platfrom definition to allow user choose the drivers.
Acked-by: Ong, Boon Leong <boon.leong.ong@intel.com>
Cc: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Cc: Darren Hart <dvhart@linux.intel.com>
Fixes: 8bbc2a135b63 ("x86/intel/quark: Add Intel Quark platform support")
Link: http://lkml.kernel.org/r/1425569044-2867-1-git-send-email-andriy.shevchenko@linux.intel.com
I recently did a rework of the smc91x driver and did some build-testing
by compiling hundreds of randconfig kernels. Unfortunately, my script
was wrong and did not actually test the configurations that mattered,
so I introduced stupid typos in almost every file I touched.
I fixed my script now, built all configurations that actually matter
and fixed all the typos, this is the result.
Fixes: b70661c70830d ("net: smc91x: use run-time configuration on all ARM machines")
'ret_from_fork' checks TIF_IA32 to determine whether 'pt_regs' and
the related state make sense for 'ret_from_sys_call'. This is
entirely the wrong check. TS_COMPAT would make a little more
sense, but there's really no point in keeping this optimization
at all.
This fixes a return to the wrong user CS if we came from int
0x80 in a 64-bit task.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/4710be56d76ef994ddf59087aad98c000fbab9a4.1424989793.git.luto@amacapital.net
[ Backported from tip:x86/asm. ]
This patch fixes the backward compatibility of the older driver with the
newer firmware by making the binding unique so that the older driver won't
recognize the non-supported interfaces.
The new bindings are in sync with the newer firmware.
Signed-off-by: Iyappan Subramanian <isubramanian@apm.com>
Signed-off-by: Keyur Chudgar <kchudgar@apm.com>
Tested-by: Mark Langsdorf <mlangsdo@redhat.com>
Pull KVM fixes from Marcelo Tosatti:
"KVM bug fixes, including a SVM interrupt injection regression fix,
MIPS and ARM bug fixes"
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: MIPS: Enable after disabling interrupt
KVM: MIPS: Fix trace event to save PC directly
KVM: SVM: fix interrupt injection (apic->isr_count always 0)
KVM: emulate: fix CMPXCHG8B on 32-bit hosts
KVM: VMX: fix build without CONFIG_SMP
arm/arm64: KVM: Add exit reaons to kvm_exit event tracing
ARM: KVM: Fix size check in __coherent_cache_guest_page
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc
Pull ARC fixes from Vineet Gupta:
- Fix for /proc/<pid>/maps "stack" vma annotation
- sched stats not printing correct sleeping task PC
- perf not reporting page faults
* tag 'arc-4.0-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc:
ARC: Fix thread_saved_pc()
ARC: Fix KSTK_ESP()
ARC: perf: Enable generic software events
ARC: Make arc_unwind_core accessible externally
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull powerpc fixes from Michael Ellerman:
- Fix for dynticks.
- Fix for smpboot bug.
- Fix for IOMMU group refcounting.
* tag 'powerpc-4.0-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux:
powerpc/iommu: Remove IOMMU device references via bus notifier
powerpc/smp: Wait until secondaries are active & online
powerpc: Re-enable dynticks
When parsing resources for PCI host bridge, we should ignore resources
consumed by host bridge itself and only report window resources available
to child PCI busses.
Fixes: 593669c2ac0f (x86/PCI/ACPI: Use common ACPI resource interfaces ...)
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
After d905c5df9aef ("PPC: POWERNV: move iommu_add_device earlier"), the
refcnt on the kobject backing the IOMMU group for a PCI device is
elevated by each call to pci_dma_dev_setup_pSeriesLP() (via
set_iommu_table_base_and_group). When we go to dlpar a multi-function
PCI device out:
iommu_reconfig_notifier ->
iommu_free_table ->
iommu_group_put
BUG_ON(tbl->it_group)
We trip this BUG_ON, because there are still references on the table, so
it is not freed. Fix this by moving the powernv bus notifier to common
code and calling it for both powernv and pseries.
Fixes: d905c5df9aef ("PPC: POWERNV: move iommu_add_device earlier")
Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Tested-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Anton has a busy ppc64le KVM box where guests sometimes hit the infamous
"kernel BUG at kernel/smpboot.c:134!" issue during boot:
BUG_ON(td->cpu != smp_processor_id());
Basically a per CPU hotplug thread scheduled on the wrong CPU. The oops
output confirms it:
CPU: 0
Comm: watchdog/130
The problem is that we aren't ensuring the CPU active bit is set for the
secondary before allowing the master to continue on. The master unparks
the secondary CPU's kthreads and the scheduler looks for a CPU to run
on. It calls select_task_rq() and realises the suggested CPU is not in
the cpus_allowed mask. It then ends up in select_fallback_rq(), and
since the active bit isnt't set we choose some other CPU to run on.
This seems to have been introduced by 6acbfb96976f "sched: Fix hotplug
vs. set_cpus_allowed_ptr()", which changed from setting active before
online to setting active after online. However that was in turn fixing a
bug where other code assumed an active CPU was also online, so we can't
just revert that fix.
The simplest fix is just to spin waiting for both active & online to be
set. We already have a barrier prior to set_cpu_online() (which also
sets active), to ensure all other setup is completed before online &
active are set.
Fixes: 6acbfb96976f ("sched: Fix hotplug vs. set_cpus_allowed_ptr()")
1) If an IPVS tunnel is created with a mixed-family destination
address, it cannot be removed. Fix from Alexey Andriyanov.
2) Fix module refcount underflow in netfilter's nft_compat, from Pablo
Neira Ayuso.
3) Generic statistics infrastructure can reference variables sitting on
a released function stack, therefore use dynamic allocation always.
Fix from Ignacy Gawędzki.
4) skb_copy_bits() return value test is inverted in ip_check_defrag().
5) Fix network namespace exit in openvswitch, we have to release all of
the per-net vports. From Pravin B Shelar.
6) Fix signedness bug in CAIF's cfpkt_iterate(), from Dan Carpenter.
7) Fix rhashtable grow/shrink behavior, only expand during inserts and
shrink during deletes. From Daniel Borkmann.
8) Netdevice names with semicolons should never be allowed, because
they serve as a separator. From Matthew Thode.
9) Use {,__}set_current_state() where appropriate, from Fabian
Frederick.
10) Revert byte queue limits support in r8169 driver, it's causing
regressions we can't figure out.
11) tcp_should_expand_sndbuf() erroneously uses tp->packets_out to
measure packets in flight, properly use tcp_packets_in_flight()
instead. From Neal Cardwell.
12) Fix accidental removal of support for bluetooth in CSR based Intel
wireless cards. From Marcel Holtmann.
13) We accidently added a behavioral change between native and compat
tasks, wrt testing the MSG_CMSG_COMPAT bit. Just ignore it if the
user happened to set it in a native binary as that was always the
behavior we had. From Catalin Marinas.
14) Check genlmsg_unicast() return valud in hwsim netlink tx frame
handling, from Bob Copeland.
15) Fix stale ->radar_required setting in mac80211 that can prevent
starting new scans, from Eliad Peller.
16) Fix memory leak in nl80211 monitor, from Johannes Berg.
17) Fix race in TX index handling in xen-netback, from David Vrabel.
18) Don't enable interrupts in amx-xgbe driver until all software et al.
state is ready for the interrupt handler to run. From Thomas
Lendacky.
19) Add missing netlink_ns_capable() checks to rtnl_newlink(), from Eric
W Biederman.
20) The amount of header space needed in macvtap was not calculated
properly, fix it otherwise we splat past the beginning of the
packet. From Eric Dumazet.
21) Fix bcmgenet TCP TX perf regression, from Jaedon Shin.
22) Don't raw initialize or mod timers, use setup_timer() and
mod_timer() instead. From Vaishali Thakkar.
23) Fix software maintained statistics in bcmgenet and systemport
drivers, from Florian Fainelli.
24) DMA descriptor updates in sh_eth need proper memory barriers, from
Ben Hutchings.
25) Don't do UDP Fragmentation Offload on RAW sockets, from Michal
Kubecek.
26) Openvswitch's non-masked set actions aren't constructed properly
into netlink messages, fix from Joe Stringer.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (116 commits)
openvswitch: Fix serialization of non-masked set actions.
gianfar: Reduce logging noise seen due to phy polling if link is down
ibmveth: Add function to enable live MAC address changes
net: bridge: add compile-time assert for cb struct size
udp: only allow UFO for packets from SOCK_DGRAM sockets
sh_eth: Really fix padding of short frames on TX
Revert "sh_eth: Enable Rx descriptor word 0 shift for r8a7790"
sh_eth: Fix RX recovery on R-Car in case of RX ring underrun
sh_eth: Ensure proper ordering of descriptor active bit write/read
net/mlx4_en: Disbale GRO for incoming loopback/selftest packets
net/mlx4_core: Fix wrong mask and error flow for the update-qp command
net: systemport: fix software maintained statistics
net: bcmgenet: fix software maintained statistics
rxrpc: don't multiply with HZ twice
rxrpc: terminate retrans loop when sending of skb fails
net/hsr: Fix NULL pointer dereference and refcnt bugs when deleting a HSR interface.
net: pasemi: Use setup_timer and mod_timer
net: stmmac: Use setup_timer and mod_timer
net: 8390: axnet_cs: Use setup_timer and mod_timer
net: 8390: pcnet_cs: Use setup_timer and mod_timer
Enable disabled interrupt, on unsuccessful operation.
Found by Coccinelle.
Signed-off-by: Tapasweni Pathak <tapaswenipathak@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Currently the guest exit trace event saves the VCPU pointer to the
structure, and the guest PC is retrieved by dereferencing it when the
event is printed rather than directly from the trace record. This isn't
safe as the printing may occur long afterwards, after the PC has changed
and potentially after the VCPU has been freed. Usually this results in
the same (wrong) PC being printed for multiple trace events. It also
isn't portable as userland has no way to access the VCPU data structure
when interpreting the trace record itself.
Lets save the actual PC in the structure so that the correct value is
accessible later.
Fixes: 669e846e6c4e ("KVM/MIPS32: MIPS arch specific APIs for KVM")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: kvm@vger.kernel.org
Cc: <stable@vger.kernel.org> # v3.10+
Acked-by: Steven Rostedt <rostedt@goodmis.org>
In commit b4eef9b36db4, we started to use hwapic_isr_update() != NULL
instead of kvm_apic_vid_enabled(vcpu->kvm). This didn't work because
SVM had it defined and "apicv" path in apic_{set,clear}_isr() does not
change apic->isr_count, because it should always be 1. The initial
value of apic->isr_count was based on kvm_apic_vid_enabled(vcpu->kvm),
which is always 0 for SVM, so KVM could have injected interrupts when it
shouldn't.
Fix it by implicitly setting SVM's hwapic_isr_update to NULL and make the
initial isr_count depend on hwapic_isr_update() for good measure.
Fixes: b4eef9b36db4 ("kvm: x86: vmx: NULL out hwapic_isr_update() in case of !enable_apicv")
Reported-and-tested-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag
Pull arch/metag fix from James Hogan:
"This is just a single patch to fix the KSTK_EIP() and KSTK_ESP()
macros for metag which have always been erronously returning the PC
and stack pointer of the task's kernel context rather than from its
user context saved at entry from userland into the kernel, which
affects the contents of /proc/<pid>/maps and /proc/<pid>/stat"
* tag 'metag-fixes-v4.0-1' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag:
metag: Fix KSTK_EIP() and KSTK_ESP() macros
The switch_mm function does nothing in case the prev and next mm
are the same. It can happen that a crst_table_downgrade has changed
the top-level pgd in the meantime on a different CPU. Always store
the new ASCE to be picked up in entry.S.
[heiko.carstens@de.ibm.com]: Bug was introduced with git commit
53e857f30867 ("s390/mm,tlb: race of lazy TLB flush vs. recreation
of TLB entries") and causes random crashes due to broken page tables
being used.
Reported-by: Dominik Vogt <vogt@linux.vnet.ibm.com>
With git commit 4d92f50249eb ("s390: reintroduce diag 44 calls for
cpu_relax()") I reintroduced a non-trivial cpu_relax() variant on s390.
The difference to the previous variant however is that the new version is
an out-of-line function, which will be traced if function tracing is enabled.
Switching to different tracers includes instruction patching. Therefore this
is done within stop_machine() "context" to prevent that any function tracing
is going on while instructions are being patched.
With the new out-of-line variant of cpu_relax() this is not true anymore,
since cpu_relax() gets called in a busy loop by all waiting cpus within
stop_machine() until function patching is finished.
Therefore cpu_relax() must be marked notrace.
This fixes kernel crashes when frequently switching between "function" and
"function_graph" tracers.
Moving cpu_relax() to a header file again, doesn't work because of header
include order dependencies.
"A CR4-shadow 32-bit init fix, plus two typo fixes"
x86: Init per-cpu shadow copy of CR4 on 32-bit CPUs too
x86/platform/intel-mid: Fix trivial printk message typo in intel_mid_arch_setup()
x86/cpu/intel: Fix trivial typo in intel_tlb_table[]
Pull timer fixes from Ingo Molnar:
"Three clockevents/clocksource driver fixes"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
clocksource: pxa: Fix section mismatch
clocksource: mtk: Fix race conditions in probe code
clockevents: asm9260: Fix compilation error with sparc/sparc64 allyesconfig
Pull perf fixes from Ingo Molnar:
"Two kprobes fixes and a handful of tooling fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf tools: Make sparc64 arch point to sparc
perf symbols: Define EM_AARCH64 for older OSes
perf top: Fix SIGBUS on sparc64
perf tools: Fix probing for PERF_FLAG_FD_CLOEXEC flag
perf tools: Fix pthread_attr_setaffinity_np build error
perf tools: Define _GNU_SOURCE on pthread_attr_setaffinity_np feature check
perf bench: Fix order of arguments to memcpy_alloc_mem
kprobes/x86: Check for invalid ftrace location in __recover_probed_insn()
kprobes/x86: Use 5-byte NOP when the code might be modified by ftrace
Merge misc fixes from Andrew Morton:
"13 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: add missing __PAGETABLE_{PUD,PMD}_FOLDED defines
mm: page_alloc: revert inadvertent !__GFP_FS retry behavior change
kernel/sys.c: fix UNAME26 for 4.0
mm: memcontrol: use "max" instead of "infinity" in control knobs
zram: use proper type to update max_used_pages
drivers/rtc/rtc-ds1685.c: fix conditional in ds1685_rtc_sysfs_time_regs_{show,store}
nilfs2: fix potential memory overrun on inode
scripts/gdb: add empty package initialization script
rtc: ds1685: remove superfluous checks for out-of-range u8 values
rtc: ds1685: fix ds1685_rtc_alarm_irq_enable build error
memcg: fix low limit calculation
mm/nommu: fix memory leak
ocfs2: update web page + git tree in documentation
Core mm expects __PAGETABLE_{PUD,PMD}_FOLDED to be defined if these page
table levels folded. Usually, these defines are provided by
<asm-generic/pgtable-nopmd.h> and <asm-generic/pgtable-nopud.h>.
But some architectures fold page table levels in a custom way. They
need to define these macros themself. This patch adds missing defines.
The patch fixes mm->nr_pmds underflow and eliminates dead __pmd_alloc()
and __pud_alloc() on architectures without these page table levels.
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
The smc91x driver traditionally gets configured at compile-time
for whichever hardware it runs on. This no longer works on
ARM as we continue to move to building all-in-one kernels.
Most ARM configurations with this driver already use run-time
configuration through DT or through platform_data, but a
few have not been converted yet.
I've checked all ARM boards that use this driver in their
legacy board files, and converted the ones that were using
compile-time configuration in smc91x.h to behave like the
other ones and provide the interrupt polarity along with
the MMIO configuration (width, stride) at platform device
creation time.
In particular, these combinations were previously selectable
in Kconfig but in fact broken:
- sa1100 assabet plus pleb
- msm combined with any other armv6/v7 platform
- pxa-idp combined with any non-DMA pxa variant
- LogicPD PXA270 combined with any other pxa
- nomadik combined with any other armv4/v5 platform,
e.g. versatile.
None of these seem critical enough to warrant a backport
to stable, but it would be nice to clean this up for good.
I would like the patch to get merged through netdev, after
Robert and/or Linus have verified it on at least some hardware.
There are a few other non-ARM platforms using this driver,
I could do the same patch for those if we want to take
it further.
arch/arm/mach-msm/board-halibut.c | 8 ++++-
arch/arm/mach-msm/board-qsd8x50.c | 8 ++++-
arch/arm/mach-pxa/idp.c | 5 +++
arch/arm/mach-pxa/lpd270.c | 8 ++++-
arch/arm/mach-realview/core.c | 7 ++++
arch/arm/mach-realview/realview_eb.c | 2 +-
arch/arm/mach-sa1100/neponset.c | 6 ++++
arch/arm/mach-sa1100/pleb.c | 7 ++++
drivers/net/ethernet/smsc/smc91x.c | 9 +++--
drivers/net/ethernet/smsc/smc91x.h | 114 ++----------------------------------------------------------
10 files changed, 57 insertions(+), 117 deletions(-)
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Commit:
1e02ce4cccdc ("x86: Store a per-cpu shadow copy of CR4")
added a shadow CR4 such that reads and writes that do not
modify the CR4 execute much faster than always reading the
register itself.
The change modified cpu_init() in common.c, so that the
shadow CR4 gets initialized before anything uses it.
Unfortunately, there's two cpu_init()s in common.c. There's
one for 64-bit and one for 32-bit. The commit only added
the shadow init to the 64-bit path, but the 32-bit path
needs the init too.
Link: http://lkml.kernel.org/r/20150227125208.71c36402@gandalf.local.home Fixes: 1e02ce4cccdc "x86: Store a per-cpu shadow copy of CR4"
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20150227145019.2bdd4354@gandalf.local.home
Pull ARM SoC fixes from Arnd Bergmann:
"The arm-soc bug fixes this time around are mostly for the omap
platform, coming from a pull request from Tony Lindgren and are almost
entirely fixing dts files.
The other two changes enable support for the shmobile platform in
generic armv7 kernels and change some properties in the ARM64
reference board dts files"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: multi_v7_defconfig: Enable shmobile platforms
arm64: Add L2 cache topology to ARM Ltd boards/models
ARM: dts: am335x-bone*: usb0 is hardwired for peripheral
ARM: dts: dra7x-evm: beagle-x15: Fix USB Host
ARM: omap2plus_defconfig: Fix SATA boot
ARM: omap2plus_defconfig: Enable OMAP NAND BCH driver
ARM: dts: dra7: Correct the dma controller's property names
ARM: dts: omap5: Correct the dma controller's property names
ARM: dts: omap4: Correct the dma controller's property names
ARM: dts: omap3: Correct the dma controller's property names
ARM: dts: omap2: Correct the dma controller's property names
ARM: dts: am437x-idk: fix sleep pinctrl state
ARM: omap2plus_defconfig: enable TPS62362 regulator
ARM: dts: am437x-idk: fix TPS62362 i2c bus
ARM: dts: n900: Fix offset for smc91x ethernet
ARM: dts: n900: fix i2c bus numbering
ARM: dts: Fix USB dts configuration for dm816x
ARM: dts: OMAP5: Fix SATA PHY node
ARM: dts: DRA7: Fix SATA PHY node
"Various arm64 fixes:
- ftrace branch generation fix
- branch instruction encoding fix
- include files, guards and unused prototypes clean-up
- minor VDSO ABI fix (clock_getres)
- PSCI functions moved to .S to avoid compilation error with gcc 5
- pte_modify fix to not ignore the mapping type
- crypto: AES interleaved increased to 4x (for performance reasons)
- text patching fix for modules
- swiotlb increased back to 64MB
- copy_siginfo_to_user32() fix for big endian"
arm64: cpuidle: add asm/proc-fns.h inclusion
arm64: compat Fix siginfo_t -> compat_siginfo_t conversion on big endian
arm64: Increase the swiotlb buffer size 64MB
arm64: Fix text patching logic when using fixmap
arm64: crypto: increase AES interleave to 4x
arm64: enable PTE type bit in the mask for pte_modify
arm64: mm: remove unused functions and variable protoypes
arm64: psci: move psci firmware calls out of line
arm64: vdso: minor ABI fix for clock_getres
arm64: guard asm/assembler.h against multiple inclusions
arm64: insn: fix compare-and-branch encodings
arm64: ftrace: fix ftrace_modify_graph_caller for branch replace
ARM64 CPUidle driver requires the cpu_do_idle function so that it can
be used to enter the shallowest idle state, and it is declared in
asm/proc-fns.h.
The current ARM64 CPUidle driver does not include asm/proc-fns.h
explicitly and it has so far relied on implicit inclusion from other
header files.
Owing to some header dependencies reshuffling this currently triggers
build failures when CONFIG_ARM64_64K_PAGES=y:
drivers/cpuidle/cpuidle-arm64.c: In function "arm64_enter_idle_state"
drivers/cpuidle/cpuidle-arm64.c:42:3: error: implicit declaration of
function "cpu_do_idle" [-Werror=implicit-function-declaration]
cpu_do_idle();
This patch adds the explicit inclusion of the asm/proc-fns.h header file
in the arm64 asm/cpuidle.h header file, so that the build breakage is fixed
and the required header inclusion is added to the appropriate arch back-end
CPUidle header, already included by the CPUidle arm64 driver, where
CPUidle arch related function declarations belong.
Reported-by: Laura Abbott <lauraa@codeaurora.org>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
The native (64-bit) sigval_t union contains sival_int (32-bit) and
sival_ptr (64-bit). When a compat application invokes a syscall that
takes a sigval_t value (as part of a larger structure, e.g.
compat_sys_mq_notify, compat_sys_timer_create), the compat_sigval_t
union is converted to the native sigval_t with sival_int overlapping
with either the least or the most significant half of sival_ptr,
depending on endianness. When the corresponding signal is delivered to a
compat application, on big endian the current (compat_uptr_t)sival_ptr
cast always returns 0 since sival_int corresponds to the top part of
sival_ptr. This patch fixes copy_siginfo_to_user32() so that sival_int
is copied to the compat_siginfo_t structure.
Reported-by: Bamvor Jian Zhang <bamvor.zhangjian@huawei.com>
Tested-by: Bamvor Jian Zhang <bamvor.zhangjian@huawei.com>
With commit 3690951fc6d4 (arm64: Use swiotlb late initialisation), the
swiotlb buffer size is limited to MAX_ORDER_NR_PAGES. However, there are
platforms with 32-bit only devices that require bounce buffering via
swiotlb. This patch changes the swiotlb initialisation to an early 64MB
memblock allocation. In order to get the swiotlb buffer correctly
allocated (via memblock_virt_alloc_low_nopanic), this patch also defines
ARCH_LOW_ADDRESS_LIMIT to the maximum physical address capable of 32-bit
DMA.
Reported-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Tested-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Since commit 8cfc99b58366 ("s390: add pci_iomap_range") we use
EXPORT_SYMBOL for pci_iomap but EXPORT_SYMBOL_GPL for pci_iounmap.
Change the related functions to use EXPORT_SYMBOL like the asm-generic
variants do.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Commit 8cfc99b58366 ("s390: add pci_iomap_range") introduced counters
to keep track of the number of mappings created. This revealed that
we don't have our internal mappings in order when using hotunplug or
resume from hibernate. This patch addresses both issues.
The old implementation assumed that SP at the time of __switch_to() is
right above pt_regs which is almost certainly not the case as there will
be some stack build up between entry into kernel and leading up to
__switch_to
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
/proc/<pid>/maps currently don't annotate stack vma with "[stack]"
This is because KSTK_ESP ie expected to return usermode SP of tsk while
currently it returns the kernel mode SP of a sleeping tsk.
While the fix is trivial, we also need to adjust the ARC kernel stack
unwinder to not use KSTK_SP and friends any more.
Reported-and-suggested-by: Alexey Brodkin <abrodkin@synopsys.com>
The arc unwinder can also be used for perf callchains.
Signed-off-by: Mischa Jonker <mjonker@synopsys.com>
Patch 2f896d586610 ("arm64: use fixmap for text patching") changed
the way we patch the kernel text, using a fixmap when the kernel or
modules are flagged as read only.
Unfortunately, a flaw in the logic makes it fall over when patching
modules without CONFIG_DEBUG_SET_MODULE_RONX enabled:
[ 32.032636] Call trace:
[ 32.032716] [<fffffe00003da0dc>] __copy_to_user+0x2c/0x60
[ 32.032837] [<fffffe0000099f08>] __aarch64_insn_write+0x94/0xf8
[ 32.033027] [<fffffe000009a0a0>] aarch64_insn_patch_text_nosync+0x18/0x58
[ 32.033200] [<fffffe000009c3ec>] ftrace_modify_code+0x58/0x84
[ 32.033363] [<fffffe000009c4e4>] ftrace_make_nop+0x3c/0x58
[ 32.033532] [<fffffe0000164420>] ftrace_process_locs+0x3d0/0x5c8
[ 32.033709] [<fffffe00001661cc>] ftrace_module_init+0x28/0x34
[ 32.033882] [<fffffe0000135148>] load_module+0xbb8/0xfc4
[ 32.034044] [<fffffe0000135714>] SyS_finit_module+0x94/0xc4
This is triggered by the use of virt_to_page() on a module address,
which ends to pointing to Nowhereland if you're lucky, or corrupt
your precious data if not.
This patch fixes the logic by mimicking what is done on arm:
- If we're patching a module and CONFIG_DEBUG_SET_MODULE_RONX is set,
use vmalloc_to_page().
- If we're patching the kernel and CONFIG_DEBUG_RODATA is set,
use virt_to_page().
- Otherwise, use the provided address, as we can write to it directly.
Tested on 4.0-rc1 as a KVM guest.
Reported-by: Richard W.M. Jones <rjones@redhat.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Laura Abbott <lauraa@codeaurora.org>
Tested-by: Richard W.M. Jones <rjones@redhat.com>
This patch increases the interleave factor for parallel AES modes
to 4x. This improves performance on Cortex-A57 by ~35%. This is
due to the 3-cycle latency of AES instructions on the A57's
relatively deep pipeline (compared to Cortex-A53 where the AES
instruction latency is only 2 cycles).
At the same time, disable inline expansion of the core AES functions,
as the performance benefit of this feature is negligible.
Measured on AMD Seattle (using tcrypt.ko mode=500 sec=1):
Baseline (2x interleave, inline expansion)
testing speed of async cbc(aes) (cbc-aes-ce) decryption
test 4 (128 bit key, 8192 byte blocks): 95545 operations in 1 seconds
test 14 (256 bit key, 8192 byte blocks): 68496 operations in 1 seconds
This patch (4x interleave, no inline expansion)
test 4 (128 bit key, 8192 byte blocks): 124735 operations in 1 seconds
test 14 (256 bit key, 8192 byte blocks): 92328 operations in 1 seconds
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Caught during Trinity testing. The pte_modify does not allow
modification for PTE type bit. This cause the test to hang
the system. It is found that the PTE can't transit from an
inaccessible page (b00) to a valid page (b11) because the mask
does not allow it. This happens when a big block of mmaped
memory is set the PROT_NONE, then the a small piece is broken
off and set to PROT_WRITE | PROT_READ cause a huge page split.
Signed-off-by: Feng Kan <fkan@apm.com>
The functions __cpu_flush_user_tlb_range and __cpu_flush_kern_tlb_range
were removed in commit fa48e6f780 'arm64: mm: Optimise tlb flush logic
where we have >4K granule'. Global variable cpu_tlb was never used in
arm64.
Remove them.
Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com>
An arm64 allmodconfig fails to build with GCC 5 due to __asmeq
assertions in the PSCI firmware calling code firing due to mcount
preambles breaking our assumptions about register allocation of function
arguments:
/tmp/ccDqJsJ6.s: Assembler messages:
/tmp/ccDqJsJ6.s:60: Error: .err encountered
/tmp/ccDqJsJ6.s:61: Error: .err encountered
/tmp/ccDqJsJ6.s:62: Error: .err encountered
/tmp/ccDqJsJ6.s:99: Error: .err encountered
/tmp/ccDqJsJ6.s:100: Error: .err encountered
/tmp/ccDqJsJ6.s:101: Error: .err encountered
This patch fixes the issue by moving the PSCI calls out-of-line into
their own assembly files, which are safe from the compiler's meddling
fingers.
Reported-by: Andy Whitcroft <apw@canonical.com>
The vdso implementation of clock_getres currently returns 0 (success)
whenever a null timespec is provided by the caller, regardless of the
clock id supplied.
This behavior is incorrect. It should fall back to syscall when an
unrecognized clock id is passed, even when the timespec argument is
null. This ensures that clock_getres always returns an error for
invalid clock ids.
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
