Function eeh_iommu_group_to_pe() iterates each PCI device to check
the binding IOMMU group with get_iommu_table_base(), which possibly
fetches pdev->dev.archdata.dma_data.dma_offset. It's (0x1 << 59)
for "bypass" cases.
The patch fixes the issue by iterating devices hooked to the IOMMU
group and fetch IOMMU table there.
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
On PHB3, PCI devices can bypass IOMMU for DMA access. If we pass
through one PCI device, whose hose driver ever enable the bypass
mode, pdev->dev.archdata.dma_data.iommu_table_base isn't IOMMU
table. However, EEH needs access the IOMMU table when the device
is owned by guest.
The patch fixes pdev->dev.archdata.dma_data.iommu_table when
passing through the device to guest in pnv_pci_ioda2_set_bypass().
pci_get_slot() is called with hold of PCI bus semaphore and it's not
safe to be called in interrupt context. However, we possibly checks
EEH error and calls the function in interrupt context. To avoid using
pci_get_slot(), we turn into device tree for fetching location code.
Otherwise, we might run into WARN_ON() as following messages indicate:
WARNING: at drivers/pci/search.c:223
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.16.0-rc3+ #72
task: c000000001367af0 ti: c000000001444000 task.ti: c000000001444000
NIP: c000000000497b70 LR: c000000000037530 CTR: 000000003003d114
REGS: c000000001446fa0 TRAP: 0700 Not tainted (3.16.0-rc3+)
MSR: 9000000000029032 <SF,HV,EE,ME,IR,DR,RI> CR: 48002422 XER: 20000000
CFAR: c00000000003752c SOFTE: 0
NIP [c000000000497b70] .pci_get_slot+0x40/0x110
LR [c000000000037530] .eeh_pe_loc_get+0x150/0x190
Call Trace:
.of_get_property+0x30/0x60 (unreliable)
.eeh_dev_check_failure+0x1b4/0x550
.eeh_check_failure+0x90/0xf0
.lpfc_sli_check_eratt+0x504/0x7c0 [lpfc]
.lpfc_poll_eratt+0x64/0x100 [lpfc]
.call_timer_fn+0x64/0x190
.run_timer_softirq+0x2cc/0x3e0
Cc: stable@vger.kernel.org
Signed-off-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Fix wrong __IO_H definition in boot/io.h
Reported-by: Fernando Silveira <fsilveira@gmail.com>
Signed-off-by: Lucas Tanure <tanure@linux.com>
Commit bcdde7e made __sysfs_remove_dir() recursive and introduced a BUG_ON
during PHB removal while attempting to delete the power managment attribute
group of the bus. This is a result of tearing the bridge and bus devices down
out of order in remove_phb_dynamic. Since, the the bus resides below the bridge
in the sysfs device tree it should be torn down first.
This patch simply moves the device_unregister call for the PHB bridge device
after the device_unregister call for the PHB bus.
Fixes: bcdde7e221a8 ("sysfs: make __sysfs_remove_dir() recursive")
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
powerpc defines various machine-specific routines for handling
pci_set_dma_mask(). The routines for machine "PowerNV" may neglect
to set dev->dma_mask. This could confuse anyone (e.g. drivers) that
consult dev->dma_mask to find the current mask. Set the dma_mask in
the PowerNV leaf routine.
Signed-off-by: Brian W. Hart <hartb@linux.vnet.ibm.com>
CC: <stable@vger.kernel.org>
This silences a section mismatch warning. early_alloc_pgtable() is
called from map_kernel_page() which cannot be __init, but only when
slab_is_available() returns false which can only happen during early
boot.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81631
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com>
The sysfs entries are lost because of commit 2213fb1 ("powerpc/eeh:
Skip eeh sysfs when eeh is disabled"). That commit added condition
to create sysfs entries with EEH_ENABLED, which isn't populated
when trying to create sysfs entries on PowerNV platform during system
boot time. The patch fixes the issue by:
* Reoder EEH initialization functions so that they're same on
PowerNV/pSeries.
* Cache PE's primary bus by PowerNV platform instead of EEH core
to avoid kernel crash caused by the function reorder. Another
benefit with this is to avoid one eeh_probe_mode_dev() in EEH
core.
The patch exports functions to be used by new VFIO ioctl command,
which will be introduced in subsequent patch, to support EEH
functinality for VFIO PCI devices.
Acked-by: Alexander Graf <agraf@suse.de>
We must not handle EEH error on devices which are passed to somebody
else. Instead, we expect that the frozen device owner detects an EEH
error and recovers from it.
This avoids EEH error handling on passed through devices so the device
owner gets a chance to handle them.
Scott writes:
Highlights include e6500 hardware threading support, an e6500 TLB erratum
workaround, corenet error reporting, support for a new board, and some
minor fixes.
T2080PCIe-RDB is a Freescale Reference Design Board that hosts T2080 SoC.
The board feature overview:
Processor:
- T2080 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz
DDR Memory:
- Single memory controller capable of supporting DDR3 and DDR3-LP devices
- 72bit 4GB DDR3-LP SODIMM in slot
Ethernet interfaces:
- Two 1Gbps RGMII ports on-board
- Two 10Gbps SFP+ ports on-board
- Two 10Gbps Base-T ports on-board
Accelerator:
- DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC
IFC/Local Bus
- NOR: 128MB 16-bit NOR flash
- NAND: 1GB 8-bit NAND flash
- CPLD: for system controlling with programable header on-board
eSPI:
- 64MB N25Q512 SPI flash
USB:
- Two USB2.0 ports with internal PHY (both Type-A)
PCIe:
- One PCIe x4 goldfinger(support SR-IOV)
- One PCIe x4 slot
- One PCIe x2 end-point device (C293 crypto co-processor)
SATA:
- Two SATA 2.0 ports on-board
SDHC:
- support a MicroSD/TF card on-board
I2C:
- Four I2C controllers.
UART:
- Dual 4-pins UART serial ports
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
In commit ae91d60ba88ef0bdb1b5e9b2363bd52fc45d2af7, a bug was fixed that
involved converting !x & y to !(x & y). The code below shows the same
pattern, and thus should perhaps be fixed in the same way.
This is not tested and clearly changes the semantics, so it is only
something to consider.
The Coccinelle semantic patch that makes this change is as follows:
// <smpl>
@@ expression E1,E2; @@
!E1 & !E2
- !E1 & E2
+ !(E1 & E2)
// </smpl>
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
mpic_msgrs has type struct mpic_msgr **, not struct mpic_msgr *, so the
elements of the array should have pointer type, not structure type.
The advantage of kcalloc is, that will prevent integer overflows which
could result from the multiplication of number of elements and size and
it is also a bit nicer to read.
The Coccinelle semantic patch that makes the first change is as follows:
// <smpl>
@disable sizeof_type_expr@
type T;
T **x;
x =
<+...sizeof(
- T
+ *x
// </smpl>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
The CoreNet Coherency Fabric is part of the memory subsystem on
some Freescale QorIQ chips. It can report coherency violations (e.g.
due to misusing memory that is mapped noncoherent) as well as
transactions that do not hit any local access window, or which hit a
local access window with an invalid target ID.
Reviewed-by: Bharat Bhushan <bharat.bhushan@freescale.com>
Erratum A-008139 can cause duplicate TLB entries if an indirect
entry is overwritten using tlbwe while the other thread is using it to
do a lookup. Work around this by using tlbilx to invalidate prior
to overwriting.
To avoid the need to save another register to hold MAS1 during the
workaround code, TID clearing has been moved from tlb_miss_kernel_e6500
until after the SMT section.
The general idea is that each core will release all of its
threads into the secondary thread startup code, which will
eventually wait in the secondary core holding area, for the
appropriate bit in the PACA to be set. The kick_cpu function
pointer will set that bit in the PACA, and thus "release"
the core/thread to boot. We also need to do a few things that
U-Boot normally does for CPUs (like enable branch prediction).
Signed-off-by: Andy Fleming <afleming@freescale.com>
[scottwood@freescale.com: various changes, including only enabling
threads if Linux wants to kick them]
This ensures that all MSR definitions are consistently unsigned long,
and that MSR_CM does not become 0xffffffff80000000 (this is usually
harmless because MSR is 32-bit on booke and is mainly noticeable when
debugging, but still I'd rather avoid it).
Power8 has a new register (MMCR2), which contains individual freeze bits
for each counter. This is an improvement on previous chips as it means
we can have multiple events on the PMU at the same time with different
exclude_{user,kernel,hv} settings. Previously we had to ensure all
events on the PMU had the same exclude settings.
The core of the patch is fairly simple. We use the 207S feature flag to
indicate that the PMU backend supports per-event excludes, if it's set
we skip the generic logic that enforces the equality of excludes between
events. We also use that flag to skip setting the freeze bits in MMCR0,
the PMU backend is expected to have handled setting them in MMCR2.
The complication arises with EBB. The FCxP bits in MMCR2 are accessible
R/W to a task using EBB. Which means a task using EBB will be able to
see that we are using MMCR2 for freezing, whereas the old logic which
used MMCR0 is not user visible.
The task can not see or affect exclude_kernel & exclude_hv, so we only
need to consider exclude_user.
The table below summarises the behaviour both before and after this
commit is applied:
exclude_user true false
| User visible | N N
Before | Can freeze | Y Y
| Can unfreeze | N Y
| User visible | Y Y
After | Can freeze | Y Y
| Can unfreeze | Y/N Y
So firstly I assert that the simple visibility of the exclude_user
setting in MMCR2 is a non-issue. The event belongs to the task, and
was most likely created by the task. So the exclude_user setting is not
privileged information in any way.
Secondly, the behaviour in the exclude_user = false case is unchanged.
This is important as it is the case that is actually useful, ie. the
event is created with no exclude setting and the task uses MMCR2 to
implement exclusion manually.
For exclude_user = true there is no meaningful change to freezing the
event. Previously the task could use MMCR2 to freeze the event, though
it was already frozen with MMCR0. With the new code the task can use
MMCR2 to freeze the event, though it was already frozen with MMCR2.
The only real change is when exclude_user = true and the task tries to
use MMCR2 to unfreeze the event. Previously this had no effect, because
the event was already frozen in MMCR0. With the new code the task can
unfreeze the event in MMCR2, but at some indeterminate time in the
future the kernel will overwrite its setting and refreeze the event.
Therefore my final assertion is that any task using exclude_user = true
and also fiddling with MMCR2 was deeply confused before this change, and
remains so after it.
To support per-event exclude settings on Power8 we need access to the
struct perf_events in compute_mmcr().
Because we reuse cpuhw->mmcr on each call to compute_mmcr() there's a
risk that we could forget to set one of the values and use whatever
value was in there previously.
Currently all the implementations are careful to set all the values, but
it's safer to clear them all before we call compute_mmcr().
I spent ten minutes scratching my head, trying to work out where we
enabled relocation on interrupts for guest kernels. Expand the doco to
make it clear.
A lot of the code in platforms/pseries is using non-machine initcalls.
That means if a kernel built with pseries support runs on another
platform, for example powernv, the initcalls will still run.
Most of these cases are OK, though sometimes only due to luck. Some were
having more effect:
* hcall_inst_init
- Checking FW_FEATURE_LPAR which is set on ps3 & celleb.
* mobility_sysfs_init
- created sysfs files unconditionally
- but no effect due to ENOSYS from rtas_ibm_suspend_me()
* apo_pm_init
- created sysfs, allows write
- nothing checks the value written to though
* alloc_dispatch_log_kmem_cache
- creating kmem_cache on non-pseries machines
A lot of the code in platforms/powernv is using non-machine initcalls.
That means if a kernel built with powernv support runs on another
platform, for example pseries, the initcalls will still run.
That is usually OK, because the initcalls will check for something in
the device tree or elsewhere before doing anything, so on other
platforms they will usually just return.
But it's fishy for powernv code to be running on other platforms, so
switch them all to be machine initcalls. If we want any of them to run
on other platforms in future they should move to sysdev.
DISABLE_INTS has a long and storied history, but for some time now it
has not actually disabled interrupts.
For the open-coded exception handlers, just stop using it, instead call
RECONCILE_IRQ_STATE directly. This has the benefit of removing a level
of indirection, and making it clear that r10 & r11 are used at that
point.
For the addition case we still need a macro, so rename it to clarify
what it actually does.
The comment on TRACE_ENABLE_INTS is incorrect, and appears to have
always been incorrect since the code was merged. It probably came from
an original out-of-tree patch.
Replace it with something that's correct. Also propagate the message to
RECONCILE_IRQ_STATE(), because it's potentially subtle.
At the moment the allmodconfig build is failing because we run out of
space between altivec_assist() at 0x5700 and the fwnmi_data_area at
0x7000.
Fixing it permanently will take some more work, but a quick fix is to
move bad_stack() below the fwnmi_data_area. That gives us just enough
room with everything enabled.
bad_stack() is called from the common exception handlers, but it's a
non-conditional branch, so we have plenty of scope to move it further
way.
We have a strange #define in cputable.h called CLASSIC_PPC.
Although it is defined for 32 & 64bit, it's only used for 32bit and
it's basically a duplicate of CONFIG_PPC_BOOK3S_32, so let's use
the latter.
Although the name CONFIG_POWER4 suggests that it controls support for
power4 cpus, this symbol is actually misnamed.
It is a historical wart from the powermac code, which used to support
building a 32-bit kernel for power4. CONFIG_POWER4 was used in that
context to guard code that was 64-bit only.
In the powermac code we can just use CONFIG_PPC64 instead, and in other
places it is a synonym for CONFIG_PPC_BOOK3S_64.
There are still a few occurences where it remains, because it helps to
explain something that persists.
We no longer support these cpus, so we don't need oprofile support for
them either.
Now that we have dropped power3 support we can remove CONFIG_POWER3. The
usage in pgtable_32.c was already dead code as CONFIG_POWER3 was not
selectable on PPC32.
The previous patch left a bit of a wart in copy_process(). Clean it up a
bit by moving the logic out into a helper.
We now only support cpus that use an SLB, so we don't need an MMU
feature to indicate that.
Old cpus didn't have a Segment Lookaside Buffer (SLB), instead they had
a Segment Table (STAB). Now that we've dropped support for those cpus,
we can remove the STAB support entirely.
We inadvertently broke power3 support back in 3.4 with commit
f5339277eb8d "powerpc: Remove FW_FEATURE ISERIES from arch code".
No one noticed until at least 3.9.
By then we'd also broken it with the optimised memcpy, copy_to/from_user
and clear_user routines. We don't want to add any more complexity to
those just to support ancient cpus, so it seems like it's a good time to
drop support for power3 and earlier.
Currently we have sys_sigpending and sys_old_getrlimit defined to use
COMPAT_SYS() in systbl.h, but then both are #defined to sys_ni_syscall
in systbl.S.
This seems to have been done when ppc and ppc64 were merged, in commit
9994a33 "Introduce entry_{32,64}.S, misc_{32,64}.S, systbl.S".
AFAICS there's no longer (or never was) any need for this, we can just
use SYSX() for both and remove the #defines to sys_ni_syscall.
The expansion before was:
#define COMPAT_SYS(func) .llong .sys_##func,.compat_sys_##func
#define sys_old_getrlimit sys_ni_syscall
COMPAT_SYS(old_getrlimit)
.llong .sys_old_getrlimit,.compat_sys_old_getrlimit
.llong .sys_ni_syscall,.compat_sys_old_getrlimit
After is:
#define SYSX(f, f3264, f32) .llong .f,.f3264
SYSX(sys_ni_syscall, compat_sys_old_getrlimit, sys_old_getrlimit)
ie. they are equivalent.
Finally both COMPAT_SYS() and SYSX() evaluate to sys_ni_syscall in the
Cell SPU code.
Bring in some important fixes from the 3.16 branch
The function rtas_flash_firmware passes the address of a data structure,
flash_block_list, when making the update-flash-64-and-reboot rtas call.
While the endianness of the address is handled correctly, the endianness
of the data is not. This patch ensures that the data in flash_block_list
is big endian when passed to rtas on little endian hosts.
Signed-off-by: Thomas Falcon <tlfalcon@linux.vnet.ibm.com>
We can continue to read the error log (up to MAX size) even if
we get the elog size more than MAX size. Hence change BUG_ON to
WARN_ON.
Also updated error message.
Reported-by: Gopesh Kumar Chaudhary <gopchaud@in.ibm.com>
Signed-off-by: Vasant Hegde <hegdevasant@linux.vnet.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Acked-by: Stewart Smith <stewart@linux.vnet.ibm.com>
In the recent commit b50a6c584bb4 "Clear MMCR2 when enabling PMU", I
screwed up the handling of MMCR2 for tasks using EBB.
We must make sure we set MMCR2 *before* ebb_switch_in(), otherwise we
overwrite the value of MMCR2 that userspace may have written. That
potentially breaks a task that uses EBB and manually uses MMCR2 for
event freezing.
Fixes: b50a6c584bb4 ("powerpc/perf: Clear MMCR2 when enabling PMU")
memmove may be called from module code copy_pages(btrfs), and it may
call memcpy, which may call back to C code, so it needs to use
_GLOBAL_TOC to set up r2 correctly.
This fixes following error when I tried to boot an le guest:
Vector: 300 (Data Access) at [c000000073f97210]
pc: c000000000015004: enable_kernel_altivec+0x24/0x80
lr: c000000000058fbc: enter_vmx_copy+0x3c/0x60
sp: c000000073f97490
msr: 8000000002009033
dar: d000000001d50170
dsisr: 40000000
current = 0xc0000000734c0000
paca = 0xc00000000fff0000 softe: 0 irq_happened: 0x01
pid = 815, comm = mktemp
enter ? for help
[c000000073f974f0] c000000000058fbc enter_vmx_copy+0x3c/0x60
[c000000073f97510] c000000000057d34 memcpy_power7+0x274/0x840
[c000000073f97610] d000000001c3179c copy_pages+0xfc/0x110 [btrfs]
[c000000073f97660] d000000001c3c248 memcpy_extent_buffer+0xe8/0x160 [btrfs]
[c000000073f97700] d000000001be4be8 setup_items_for_insert+0x208/0x4a0 [btrfs]
[c000000073f97820] d000000001be50b4 btrfs_insert_empty_items+0xf4/0x140 [btrfs]
[c000000073f97890] d000000001bfed30 insert_with_overflow+0x70/0x180 [btrfs]
[c000000073f97900] d000000001bff174 btrfs_insert_dir_item+0x114/0x2f0 [btrfs]
[c000000073f979a0] d000000001c1f92c btrfs_add_link+0x10c/0x370 [btrfs]
[c000000073f97a40] d000000001c20e94 btrfs_create+0x204/0x270 [btrfs]
[c000000073f97b00] c00000000026d438 vfs_create+0x178/0x210
[c000000073f97b50] c000000000270a70 do_last+0x9f0/0xe90
[c000000073f97c20] c000000000271010 path_openat+0x100/0x810
[c000000073f97ce0] c000000000272ea8 do_filp_open+0x58/0xd0
[c000000073f97dc0] c00000000025ade8 do_sys_open+0x1b8/0x300
[c000000073f97e30] c00000000000a008 syscall_exit+0x0/0x7c
Commit 75b57ecf9 refactored device tree nodes to use kobjects such that they
can be exposed via /sysfs. A secondary commit 0829f6d1f furthered this rework
by moving the kobect initialization logic out of of_node_add into its own
of_node_init function. The inital commit removed the existing kref_init calls
in the pseries dlpar code with the assumption kobject initialization would
occur in of_node_add. The second commit had the side effect of triggering a
BUG_ON during DLPAR, migration and suspend/resume operations as a result of
dynamically added nodes being uninitialized.
This patch fixes this by adding of_node_init calls in place of the previously
removed kref_init calls.
Fixes: 0829f6d1f69e ("of: device_node kobject lifecycle fixes")
Acked-by: Nathan Fontenot <nfont@linux.vnet.ibm.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
We now support TASK_SIZE of 16TB, hence the array should be 8.
Fixes the below crash:
Unable to handle kernel paging request for data at address 0x000100bd
Faulting instruction address: 0xc00000000004f914
cpu 0x13: Vector: 300 (Data Access) at [c000000fea75fa90]
pc: c00000000004f914: .sys_subpage_prot+0x2d4/0x5c0
lr: c00000000004fb5c: .sys_subpage_prot+0x51c/0x5c0
sp: c000000fea75fd10
msr: 9000000000009032
dar: 100bd
dsisr: 40000000
current = 0xc000000fea6ae490
paca = 0xc00000000fb8ab00 softe: 0 irq_happened: 0x00
pid = 8237, comm = a.out
enter ? for help
[c000000fea75fe30] c00000000000a164 syscall_exit+0x0/0x98
This fixes some bugs in emulate_step(). First, the setting of the carry
bit for the arithmetic right-shift instructions was not correct on 64-bit
machines because we were masking with a mask of type int rather than
unsigned long. Secondly, the sld (shift left doubleword) instruction was
using the wrong instruction field for the register containing the shift
count.
These processors do not currently support doorbell IPIs, so remove them
from the feature list if we are at DD 1.xx for the 0x004d part.
This fixes a regression caused by d4e58e5928f8 (powerpc/powernv: Enable
POWER8 doorbell IPIs). With that patch the kernel would hang at boot
when calling smp_call_function_many, as the doorbell would not be
received by the target CPUs:
.smp_call_function_many+0x2bc/0x3c0 (unreliable)
.on_each_cpu_mask+0x30/0x100
.cpuidle_register_driver+0x158/0x1a0
.cpuidle_register+0x2c/0x110
.powernv_processor_idle_init+0x23c/0x2c0
.do_one_initcall+0xd4/0x260
.kernel_init_freeable+0x25c/0x33c
.kernel_init+0x1c/0x120
.ret_from_kernel_thread+0x58/0x7c
Fixes: d4e58e5928f8 (powerpc/powernv: Enable POWER8 doorbell IPIs)
Signed-off-by: Joel Stanley <joel@jms.id.au>
Knowing how long we spend in firmware calls is an important part of
minimising OS jitter.
This patch adds tracepoints to each OPAL call. If tracepoints are
enabled we branch out to a common routine that calls an entry and exit
tracepoint.
This allows us to write tools that monitor the frequency and duration
of OPAL calls, eg:
name count total(ms) min(ms) max(ms) avg(ms) period(ms)
OPAL_HANDLE_INTERRUPT 5 0.199 0.037 0.042 0.040 12547.545
OPAL_POLL_EVENTS 204 2.590 0.012 0.036 0.013 2264.899
OPAL_PCI_MSI_EOI 2830 3.066 0.001 0.005 0.001 81.166
We use jump labels if configured, which means we only add a single
nop instruction to every OPAL call when the tracepoints are disabled.
