Pull microblaze fixes from Michal Simek:
- Fix two compilation issues - HZ, readq/writeq
- Fix stack protection support
* tag 'microblaze-3.14-rc3' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Fix a typo when disabling stack protection
microblaze: Define readq and writeq IO helper function
microblaze: Fix missing HZ macro
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 bugfixes from Martin Schwidefsky:
"A collection a bug fixes. Most of them are minor but two of them are
more severe. The linkage stack bug can be used by user space to force
an oops, with panic_on_oops this is a denial-of-service. And the dump
memory detection issue can cause incomplete memory dumps"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/cio: improve cio_commit_config
s390: fix kernel crash due to linkage stack instructions
s390/dump: Fix dump memory detection
s390/appldata: restore missing init_virt_timer()
s390/qdio: correct program-controlled interruption checking
s390/qdio: for_each macro correctness
Pull networking updates from David Miller:
1) Fix flexcan build on big endian, from Arnd Bergmann
2) Correctly attach cpsw to GPIO bitbang MDIO drive, from Stefan Roese
3) udp_add_offload has to use GFP_ATOMIC since it can be invoked from
non-sleepable contexts. From Or Gerlitz
4) vxlan_gro_receive() does not iterate over all possible flows
properly, fix also from Or Gerlitz
5) CAN core doesn't use a proper SKB destructor when it hooks up
sockets to SKBs. Fix from Oliver Hartkopp
6) ip_tunnel_xmit() can use an uninitialized route pointer, fix from
Eric Dumazet
7) Fix address family assignment in IPVS, from Michal Kubecek
8) Fix ath9k build on ARM, from Sujith Manoharan
9) Make sure fail_over_mac only applies for the correct bonding modes,
from Ding Tianhong
10) The udp offload code doesn't use RCU correctly, from Shlomo Pongratz
11) Handle gigabit features properly in generic PHY code, from Florian
Fainelli
12) Don't blindly invoke link operations in
rtnl_link_get_slave_info_data_size, they are optional. Fix from
Fernando Luis Vazquez Cao
13) Add USB IDs for Netgear Aircard 340U, from Bjørn Mork
14) Handle netlink packet padding properly in openvswitch, from Thomas
Graf
15) Fix oops when deleting chains in nf_tables, from Patrick McHardy
16) Fix RX stalls in xen-netback driver, from Zoltan Kiss
17) Fix deadlock in mac80211 stack, from Emmanuel Grumbach
18) inet_nlmsg_size() forgets to consider ifa_cacheinfo, fix from Geert
Uytterhoeven
19) tg3_change_mtu() can deadlock, fix from Nithin Sujir
20) Fix regression in setting SCTP local source addresses on accepted
sockets, caused by some generic ipv6 socket changes. Fix from
Matija Glavinic Pecotic
21) IPPROTO_* must be pure defines, otherwise module aliases don't get
constructed properly. Fix from Jan Moskyto
22) IPV6 netconsole setup doesn't work properly unless an explicit
source address is specified, fix from Sabrina Dubroca
23) Use __GFP_NORETRY for high order skb page allocations in
sock_alloc_send_pskb and skb_page_frag_refill. From Eric Dumazet
24) Fix a regression added in netconsole over bridging, from Cong Wang
25) TCP uses an artificial offset of 1ms for SRTT, but this doesn't jive
well with TCP pacing which needs the SRTT to be accurate. Fix from
Eric Dumazet
26) Several cases of missing header file includes from Rashika Kheria
27) Add ZTE MF667 device ID to qmi_wwan driver, from Raymond Wanyoike
28) TCP Small Queues doesn't handle nonagle properly in some corner
cases, fix from Eric Dumazet
29) Remove extraneous read_unlock in bond_enslave, whoops. From Ding
Tianhong
30) Fix 9p trans_virtio handling of vmalloc buffers, from Richard Yao
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (136 commits)
6lowpan: fix lockdep splats
alx: add missing stats_lock spinlock init
9p/trans_virtio.c: Fix broken zero-copy on vmalloc() buffers
bonding: remove unwanted bond lock for enslave processing
USB2NET : SR9800 : One chip USB2.0 USB2NET SR9800 Device Driver Support
tcp: tsq: fix nonagle handling
bridge: Prevent possible race condition in br_fdb_change_mac_address
bridge: Properly check if local fdb entry can be deleted when deleting vlan
bridge: Properly check if local fdb entry can be deleted in br_fdb_delete_by_port
bridge: Properly check if local fdb entry can be deleted in br_fdb_change_mac_address
bridge: Fix the way to check if a local fdb entry can be deleted
bridge: Change local fdb entries whenever mac address of bridge device changes
bridge: Fix the way to find old local fdb entries in br_fdb_change_mac_address
bridge: Fix the way to insert new local fdb entries in br_fdb_changeaddr
bridge: Fix the way to find old local fdb entries in br_fdb_changeaddr
tcp: correct code comment stating 3 min timeout for FIN_WAIT2, we only do 1 min
net: vxge: Remove unused device pointer
net: qmi_wwan: add ZTE MF667
3c59x: Remove unused pointer in vortex_eisa_cleanup()
net: fix 'ip rule' iif/oif device rename
Steven Noonan forwarded a users report where they had a problem starting
vsftpd on a Xen paravirtualized guest, with this in dmesg:
BUG: Bad page map in process vsftpd pte:8000000493b88165 pmd:e9cc01067
page:ffffea00124ee200 count:0 mapcount:-1 mapping: (null) index:0x0
page flags: 0x2ffc0000000014(referenced|dirty)
addr:00007f97eea74000 vm_flags:00100071 anon_vma:ffff880e98f80380 mapping: (null) index:7f97eea74
CPU: 4 PID: 587 Comm: vsftpd Not tainted 3.12.7-1-ec2 #1
Call Trace:
dump_stack+0x45/0x56
print_bad_pte+0x22e/0x250
unmap_single_vma+0x583/0x890
unmap_vmas+0x65/0x90
exit_mmap+0xc5/0x170
mmput+0x65/0x100
do_exit+0x393/0x9e0
do_group_exit+0xcc/0x140
SyS_exit_group+0x14/0x20
system_call_fastpath+0x1a/0x1f
Disabling lock debugging due to kernel taint
BUG: Bad rss-counter state mm:ffff880e9ca60580 idx:0 val:-1
BUG: Bad rss-counter state mm:ffff880e9ca60580 idx:1 val:1
The issue could not be reproduced under an HVM instance with the same
kernel, so it appears to be exclusive to paravirtual Xen guests. He
bisected the problem to commit 1667918b6483 ("mm: numa: clear numa
hinting information on mprotect") that was also included in 3.12-stable.
The problem was related to how xen translates ptes because it was not
accounting for the _PAGE_NUMA bit. This patch splits pte_present to add
a pteval_present helper for use by xen so both bare metal and xen use
the same code when checking if a PTE is present.
[mgorman@suse.de: wrote changelog, proposed minor modifications]
[akpm@linux-foundation.org: fix typo in comment]
Reported-by: Steven Noonan <steven@uplinklabs.net>
Tested-by: Steven Noonan <steven@uplinklabs.net>
Signed-off-by: Elena Ufimtseva <ufimtseva@gmail.com>
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: <stable@vger.kernel.org> [3.12+]
Correct a typo causing the stack protector to be left enabled.
0xFFFFFFF -> 0xFFFFFFFF
Signed-off-by: Edgar E. Iglesias <edgar.iglesias@xilinx.com>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Some drivers check if readq/writeq functions are defined.
If not internal driver functions are used which cause
compilation failures.
Add missing param.h header because of HZ macro.
It is causing compilation failure:
In file included from include/linux/delay.h:14:0,
from drivers/clk/qcom/reset.c:18:
drivers/clk/qcom/reset.c: In function 'qcom_reset':
arch/microblaze/include/asm/delay.h:39:35: error: 'HZ'
undeclared (first use in this function)
Pull x86 fixes from Peter Anvin:
"Quite a varied little collection of fixes. Most of them are
relatively small or isolated; the biggest one is Mel Gorman's fixes
for TLB range flushing.
A couple of AMD-related fixes (including not crashing when given an
invalid microcode image) and fix a crash when compiled with gcov"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, microcode, AMD: Unify valid container checks
x86, hweight: Fix BUG when booting with CONFIG_GCOV_PROFILE_ALL=y
x86/efi: Allow mapping BGRT on x86-32
x86: Fix the initialization of physnode_map
x86, cpu hotplug: Fix stack frame warning in check_irq_vectors_for_cpu_disable()
x86/intel/mid: Fix X86_INTEL_MID dependencies
arch/x86/mm/srat: Skip NUMA_NO_NODE while parsing SLIT
mm, x86: Revisit tlb_flushall_shift tuning for page flushes except on IvyBridge
x86: mm: change tlb_flushall_shift for IvyBridge
x86/mm: Eliminate redundant page table walk during TLB range flushing
x86/mm: Clean up inconsistencies when flushing TLB ranges
mm, x86: Account for TLB flushes only when debugging
x86/AMD/NB: Fix amd_set_subcaches() parameter type
x86/quirks: Add workaround for AMD F16h Erratum792
x86, doc, kconfig: Fix dud URL for Microcode data
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
- Relax VDSO alignment requirements so that the kernel-picked one (4K)
does not conflict with the dynamic linker's one (64K)
- VDSO gettimeofday fix
- Barrier fixes for atomic operations and cache flushing
- TLB invalidation when overriding early page mappings during boot
- Wired up new 32-bit arm (compat) syscalls
- LSM_MMAP_MIN_ADDR when COMPAT is enabled
- defconfig update
- Clean-up (comments, pgd_alloc).
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: defconfig: Expand default enabled features
arm64: asm: remove redundant "cc" clobbers
arm64: atomics: fix use of acquire + release for full barrier semantics
arm64: barriers: allow dsb macro to take option parameter
security: select correct default LSM_MMAP_MIN_ADDR on arm on arm64
arm64: compat: Wire up new AArch32 syscalls
arm64: vdso: update wtm fields for CLOCK_MONOTONIC_COARSE
arm64: vdso: fix coarse clock handling
arm64: simplify pgd_alloc
arm64: fix typo: s/SERRROR/SERROR/
arm64: Invalidate the TLB when replacing pmd entries during boot
arm64: Align CMA sizes to PAGE_SIZE
arm64: add DSB after icache flush in __flush_icache_all()
arm64: vdso: prevent ld from aligning PT_LOAD segments to 64k
Pull MIPS updates from Ralf Baechle:
"hree minor patches. All have sat in -next for a few days"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: fpu.h: Fix build when CONFIG_BUG is not set
MIPS: Wire up sched_setattr/sched_getattr syscalls
MIPS: Alchemy: Fix DB1100 GPIO registration
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit).
FPGA implementations of the Cortex-A57 and Cortex-A53 are now available
in the form of the SMM-A57 and SMM-A53 Soft Macrocell Models (SMMs) for
Versatile Express. As these attach to a Motherboard Express V2M-P1 it
would be useful to have support for some V2M-P1 peripherals enabled by
default.
Additionally a couple of of features have been introduced since the last
defconfig update (CMA, jump labels) that would be good to have enabled
by default to ensure they are build and boot tested.
This patch updates the arm64 defconfig to enable support for these
devices and features. The arm64 Kconfig is modified to select
HAVE_PATA_PLATFORM, which is required to enable support for the
CompactFlash controller on the V2M-P1.
A few options which don't need to appear in defconfig are trimmed:
* BLK_DEV - selected by default
* EXPERIMENTAL - otherwise gone from the kernel
* MII - selected by drivers which require it
* USB_SUPPORT - selected by default
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
cbnz/tbnz don't update the condition flags, so remove the "cc" clobbers
from inline asm blocks that only use these instructions to implement
conditional branches.
Linux requires a number of atomic operations to provide full barrier
semantics, that is no memory accesses after the operation can be
observed before any accesses up to and including the operation in
program order.
On arm64, these operations have been incorrectly implemented as follows:
// A, B, C are independent memory locations
<Access [A]>
// atomic_op (B)
1: ldaxr x0, [B] // Exclusive load with acquire
<op(B)>
stlxr w1, x0, [B] // Exclusive store with release
cbnz w1, 1b
<Access [C]>
The assumption here being that two half barriers are equivalent to a
full barrier, so the only permitted ordering would be A -> B -> C
(where B is the atomic operation involving both a load and a store).
Unfortunately, this is not the case by the letter of the architecture
and, in fact, the accesses to A and C are permitted to pass their
nearest half barrier resulting in orderings such as Bl -> A -> C -> Bs
or Bl -> C -> A -> Bs (where Bl is the load-acquire on B and Bs is the
store-release on B). This is a clear violation of the full barrier
requirement.
The simple way to fix this is to implement the same algorithm as ARMv7
using explicit barriers:
<Access [A]>
// atomic_op (B)
dmb ish // Full barrier
1: ldxr x0, [B] // Exclusive load
<op(B)>
stxr w1, x0, [B] // Exclusive store
cbnz w1, 1b
<Access [C]>
but this has the undesirable effect of introducing *two* full barrier
instructions. A better approach is actually the following, non-intuitive
sequence:
<Access [A]>
// atomic_op (B)
<op(B)>
cbnz w1, 1b
<Access [C]>
The simple observations here are:
- The dmb ensures that no subsequent accesses (e.g. the access to C)
can enter or pass the atomic sequence.
- The dmb also ensures that no prior accesses (e.g. the access to A)
can pass the atomic sequence.
- Therefore, no prior access can pass a subsequent access, or
vice-versa (i.e. A is strictly ordered before C).
- The stlxr ensures that no prior access can pass the store component
of the atomic operation.
The only tricky part remaining is the ordering between the ldxr and the
access to A, since the absence of the first dmb means that we're now
permitting re-ordering between the ldxr and any prior accesses.
From an (arbitrary) observer's point of view, there are two scenarios:
1. We have observed the ldxr. This means that if we perform a store to
[B], the ldxr will still return older data. If we can observe the
ldxr, then we can potentially observe the permitted re-ordering
with the access to A, which is clearly an issue when compared to
the dmb variant of the code. Thankfully, the exclusive monitor will
save us here since it will be cleared as a result of the store and
the ldxr will retry. Notice that any use of a later memory
observation to imply observation of the ldxr will also imply
observation of the access to A, since the stlxr/dmb ensure strict
ordering.
2. We have not observed the ldxr. This means we can perform a store
and influence the later ldxr. However, that doesn't actually tell
us anything about the access to [A], so we've not lost anything
here either when compared to the dmb variant.
This patch implements this solution for our barriered atomic operations,
ensuring that we satisfy the full barrier requirements where they are
needed.
Switch the device tree to the new compatibles introduced in the ethernet and
mdio drivers to have a common pattern accross all Allwinner SoCs.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
memblock.reserved.
The following path will cause array out of bound.
memblock_add_region() will always set nid in memblock.reserved to
MAX_NUMNODES. In numa_register_memblks(), after we set all nid to
correct valus in memblock.reserved, we called setup_node_data(), and
used memblock_alloc_nid() to allocate memory, with nid set to
MAX_NUMNODES.
The nodemask_t type can be seen as a bit array. And the index is 0 ~
MAX_NUMNODES-1.
After that, when we call node_set() in numa_clear_kernel_node_hotplug(),
the nodemask_t got an index of value MAX_NUMNODES, which is out of [0 ~
MAX_NUMNODES-1].
See below:
numa_init()
|---> numa_register_memblks()
| |---> memblock_set_node(memory) set correct nid in memblock.memory
| |---> memblock_set_node(reserved) set correct nid in memblock.reserved
| |---> setup_node_data()
| |---> memblock_alloc_nid() here, nid is set to MAX_NUMNODES (1024)
|---> numa_clear_kernel_node_hotplug()
|---> node_set() here, we have an index 1024, and overflowed
This patch moves nid setting to numa_clear_kernel_node_hotplug() to fix
this problem.
Reported-by: Dave Jones <davej@redhat.com>
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Tested-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Tested-by: Dave Jones <davej@redhat.com>
On-stack variable numa_kernel_nodes in numa_clear_kernel_node_hotplug()
was not initialized. So we need to initialize it.
[akpm@linux-foundation.org: use NODE_MASK_NONE, per David]
Reported-by: David Rientjes <rientjes@google.com>
For additional coverage, BorisO and friends unknowlingly did swap AMD
microcode with Intel microcode blobs in order to see what happens. What
did happen on 32-bit was
[ 5.722656] BUG: unable to handle kernel paging request at be3a6008
[ 5.722693] IP: [<c106d6b4>] load_microcode_amd+0x24/0x3f0
[ 5.722716] *pdpt = 0000000000000000 *pde = 0000000000000000
because there was a valid initrd there but without valid microcode in it
and the container check happened *after* the relocated ramdisk handling
on 32-bit, which was clearly wrong.
While at it, take care of the ramdisk relocation on both 32- and 64-bit
as it is done on both. Also, comment what we're doing because this code
is a bit tricky.
Reported-and-tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: http://lkml.kernel.org/r/1391460104-7261-1-git-send-email-bp@alien8.de
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
__enable_fpu produces a build failure when CONFIG_BUG is not set:
In file included from arch/mips/kernel/cpu-probe.c:24:0:
arch/mips/include/asm/fpu.h: In function '__enable_fpu':
arch/mips/include/asm/fpu.h:77:1: error: control reaches end of non-void function [-Werror=return-type]
This is regression introduced in 3.14-rc1. Fix that.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Paul Burton <paul.burton@imgtec.com>
Cc: John Crispin <blogic@openwrt.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/6504/
The dsb instruction takes an option specifying both the target access
types and shareability domain.
This patch allows such an option to be passed to the dsb macro,
resulting in potentially more efficient code. Currently the option is
ignored until all callers are updated (unlike ARM, the option is
mandated by the assembler).
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen fixes from Konrad Rzeszutek Wilk:
"Bug-fixes:
- Revert "xen/grant-table: Avoid m2p_override during mapping" as it
broke Xen ARM build.
- Fix CR4 not being set on AP processors in Xen PVH mode"
* tag 'stable/for-linus-3.14-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/pvh: set CR4 flags for APs
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 update from Tony Luck:
"Wire up new sched_setattr and sched_getattr syscalls"
* tag 'please-pull-ia64-syscalls' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
[IA64] Wire up new sched_setattr and sched_getattr syscalls
Pull crypto fixes from Herbert Xu:
"This fixes a number of concurrency issues on s390 where multiple users
of the same crypto transform may clobber each other's results"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: s390 - fix des and des3_ede ctr concurrency issue
crypto: s390 - fix des and des3_ede cbc concurrency issue
crypto: s390 - fix concurrency issue in aes-ctr mode
CONFIG_X86_32 doesn't map the boot services regions into the EFI memory
map (see commit 700870119f49 ("x86, efi: Don't map Boot Services on
i386")), and so efi_lookup_mapped_addr() will fail to return a valid
address. Executing the ioremap() path in efi_bgrt_init() causes the
following warning on x86-32 because we're trying to ioremap() RAM,
WARNING: CPU: 0 PID: 0 at arch/x86/mm/ioremap.c:102 __ioremap_caller+0x2ad/0x2c0()
Modules linked in:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.13.0-0.rc5.git0.1.2.fc21.i686 #1
Hardware name: DellInc. Venue 8 Pro 5830/09RP78, BIOS A02 10/17/2013
00000000 00000000 c0c0df08 c09a5196 00000000 c0c0df38 c0448c1e c0b41310
00000000 00000000 c0b37bc1 00000066 c043bbfd c043bbfd 00e7dfe0 00073eff
00073eff c0c0df48 c0448ce2 00000009 00000000 c0c0df9c c043bbfd 00078d88
Call Trace:
[<c09a5196>] dump_stack+0x41/0x52
[<c0448c1e>] warn_slowpath_common+0x7e/0xa0
[<c043bbfd>] ? __ioremap_caller+0x2ad/0x2c0
[<c0448ce2>] warn_slowpath_null+0x22/0x30
[<c043bbfd>] __ioremap_caller+0x2ad/0x2c0
[<c0718f92>] ? acpi_tb_verify_table+0x1c/0x43
[<c0719c78>] ? acpi_get_table_with_size+0x63/0xb5
[<c087cd5e>] ? efi_lookup_mapped_addr+0xe/0xf0
[<c043bc2b>] ioremap_nocache+0x1b/0x20
[<c0cb01c8>] ? efi_bgrt_init+0x83/0x10c
[<c0cb01c8>] efi_bgrt_init+0x83/0x10c
[<c0cafd82>] efi_late_init+0x8/0xa
[<c0c9bab2>] start_kernel+0x3ae/0x3c3
[<c0c9b53b>] ? repair_env_string+0x51/0x51
[<c0c9b378>] i386_start_kernel+0x12e/0x131
Switch to using early_memremap(), which won't trigger this warning, and
has the added benefit of more accurately conveying what we're trying to
do - map a chunk of memory.
This patch addresses the following bug report,
https://bugzilla.kernel.org/show_bug.cgi?id=67911
Reported-by: Adam Williamson <awilliam@redhat.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
It can take some time to validate the image, make sure
{allyes|allmod}config doesn't enable it.
I'd say randconfig will cover it often enough, and the failure is also
borderline build coverage related: you cannot really make the decoder
test fail via source level changes, only with changes in the build
environment, so I agree with Andi that we can disable this one too.
Acked-by: Paul Gortmaker paul.gortmaker@windriver.com>
Suggested-and-acked-by: Andi Kleen andi@firstfloor.org>
This changes 'do_execve()' to get the executable name as a 'struct
filename', and to free it when it is done. This is what the normal
users want, and it simplifies and streamlines their error handling.
The controlled lifetime of the executable name also fixes a
use-after-free problem with the trace_sched_process_exec tracepoint: the
lifetime of the passed-in string for kernel users was not at all
obvious, and the user-mode helper code used UMH_WAIT_EXEC to serialize
the pathname allocation lifetime with the execve() having finished,
which in turn meant that the trace point that happened after
mm_release() of the old process VM ended up using already free'd memory.
To solve the kernel string lifetime issue, this simply introduces
"getname_kernel()" that works like the normal user-space getname()
function, except with the source coming from kernel memory.
As Oleg points out, this also means that we could drop the tcomm[] array
from 'struct linux_binprm', since the pathname lifetime now covers
setup_new_exec(). That would be a separate cleanup.
Reported-by: Igor Zhbanov <i.zhbanov@samsung.com>
Tested-by: Steven Rostedt <rostedt@goodmis.org>
This patch enables sys_compat, sys_finit_module, sys_sched_setattr and
sys_sched_getattr for compat (AArch32) applications.
Update wall-to-monotonic fields in the VDSO data page
unconditionally. These are used to service CLOCK_MONOTONIC_COARSE,
which is not guarded by use_syscall.
Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com>
Acked-by: Will Deacon <will.deacon@arm.com>
When __kernel_clock_gettime is called with a CLOCK_MONOTONIC_COARSE or
CLOCK_REALTIME_COARSE clock id, it returns incorrectly to whatever the
caller has placed in x2 ("ret x2" to return from the fast path). Fix
this by saving x30/LR to x2 only in code that will call
__do_get_tspec, restoring x30 afterward, and using a plain "ret" to
return from the routine.
Also: while the resulting tv_nsec value for CLOCK_REALTIME and
CLOCK_MONOTONIC must be computed using intermediate values that are
left-shifted by cs_shift (x12, set by __do_get_tspec), the results for
coarse clocks should be calculated using unshifted values
(xtime_coarse_nsec is in units of actual nanoseconds). The current
code shifts intermediate values by x12 unconditionally, but x12 is
uninitialized when servicing a coarse clock. Fix this by setting x12
to 0 once we know we are dealing with a coarse clock id.
Currently pgd_alloc has a redundant NULL check in its return path that
can be removed with no ill effects. With that removed it's also possible
to return early and eliminate the new_pgd temporary variable.
This patch applies said modifications, making the logic of pgd_alloc
correspond 1-1 with that of pgd_free.
Somehow SERROR has acquired an additional 'R' in a couple of headers.
This patch removes them before they spread further. As neither instance
is in use yet, no other sites need to be fixed up.
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
With the 64K page size configuration, __create_page_tables in head.S
maps enough memory to get started but using 64K pages rather than 512M
sections with a single pgd/pud/pmd entry pointing to a pte table.
create_mapping() may override the pgd/pud/pmd table entry with a block
(section) one if the RAM size is more than 512MB and aligned correctly.
For the end of this block to be accessible, the old TLB entry must be
invalidated.
Reported-by: Mark Salter <msalter@redhat.com>
Tested-by: Mark Salter <msalter@redhat.com>
dma_alloc_from_contiguous takes number of pages for a size.
Align up the dma size passed in to page size to avoid truncation
and allocation failures on sizes less than PAGE_SIZE.
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Add DSB after icache flush to complete the cache maintenance operation.
The function __flush_icache_all() is used only for user space mappings
and an ISB is not required because of an exception return before executing
user instructions. An exception return would behave like an ISB.
Signed-off-by: Vinayak Kale <vkale@apm.com>
The kernel currently crashes with a low-address-protection exception
if a user space process executes an instruction that tries to use the
linkage stack. Set the base-ASTE origin and the subspace-ASTE origin
of the dispatchable-unit-control-table to point to a dummy ASTE.
Set up control register 15 to point to an empty linkage stack with no
room left.
A user space process with a linkage stack instruction will still crash
but with a different exception which is correctly translated to a
segmentation fault instead of a kernel oops.
Whilst the text segment for our VDSO is marked as PT_LOAD in the ELF
headers, it is mapped by the kernel and not actually subject to
demand-paging. ld doesn't realise this, and emits a p_align field of 64k
(the maximum supported page size), which conflicts with the load address
picked by the kernel on 4k systems, which will be 4k aligned. This
causes GDB to fail with "Failed to read a valid object file image from
memory" when attempting to load the VDSO.
This patch passes the -n option to ld, which prevents it from aligning
PT_LOAD segments to the maximum page size.
Reported-by: Kyle McMartin <kyle@redhat.com>
Acked-by: Kyle McMartin <kyle@redhat.com>
Dumps created by kdump or zfcpdump can contain invalid memory holes when
dumping z/VM systems that have memory pressure.
For example:
# zgetdump -i /proc/vmcore.
Memory map:
0000000000000000 - 0000000000bfffff (12 MB)
0000000000e00000 - 00000000014fffff (7 MB)
000000000bd00000 - 00000000f3bfffff (3711 MB)
The memory detection function find_memory_chunks() issues tprot to
find valid memory chunks. In case of CMM it can happen that pages are
marked as unstable via set_page_unstable() in arch_free_page().
If z/VM has released that pages, tprot returns -EFAULT and indicates
a memory hole.
So fix this and switch off CMM in case of kdump or zfcpdump.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Wire up for MIPS the new sched_setattr and sched_getattr system calls
added in commit d50dde5a10f3 (sched: Add new scheduler syscalls to
support an extended scheduling parameters ABI) merged in v3.14-rc1.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Reviewed-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/6502/
With CONFIG_GPIOLIB=y gpios need to be requested before they can be
modified. Request the SD carddetect pins, and drop the SPI direction
setup, as the driver does that for us anyway. This gets rid of a
lot of WARN_ON()s triggered by GPIO core, and restores functionality
of the touschreen controller.
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/6497/
During bootup in the 'probe_page_size_mask' these CR4 flags are
set in there. But for AP processors they are not set as we do not
use 'secondary_startup_64' which the baremetal kernels uses.
Instead do it in this function which we use in Xen PVH during our
startup for AP processors.
As such fix it up to make sure we have that flag set.
Signed-off-by: Mukesh Rathor <mukesh.rathor@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This reverts commit 08ece5bb2312b4510b161a6ef6682f37f4eac8a1.
As it breaks ARM builds and needs more attention
on the ARM side.
Acked-by: David Vrabel <david.vrabel@citrix.com>
Add support for the flexible mmap memory layout (as described in
http://lwn.net/Articles/91829). This is especially very interesting on
parisc since we currently only support 32bit userspace (even with a
64bit Linux kernel).
Signed-off-by: Helge Deller <deller@gmx.de>
On Linux, only parisc uses a different value for EWOULDBLOCK which
causes a lot of troubles for applications not checking for both values.
Since the hpux compat is long dead, make EWOULDBLOCK behave the same as
all other architectures.
Signed-off-by: Guy Martin <gmsoft@tuxicoman.be>
The stat.h header file is exported to userspace. Some userspace
applications failed to compile due to missing/unknown types, so we
better convert it to use native types only (like it's done on other
architectures too).
This commit:
f8dae00684d678afa13041ef170cecfd1297ed40: parisc: Ensure full cache coherency for kmap/kunmap
caused negative caching side-effects, e.g. hanging processes with expect and
too many inequivalent alias messages from flush_dcache_page() on Debian 5 systems.
This patch now partly reverts it and has been in production use on our debian buildd
makeservers since a week without any major problems.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # v3.9+
Pull ARM SoC fixes from Olof Johansson:
"Here's a set of patches for (hopefully) -rc1. Some of them are fixes,
but a good number of them also do things such as enable new drivers in
the defconfigs for platforms that have such devices, increases
coverage of the multiplatform defconfig and some DTS changes that
plumbs up some of the devices that now have bindings and driver
support.
The commit dates are recent; we've mostly collected these fixes in the
last few days but I also had to rebuild the branch yesterday to sort
out some internal conflicts which reset the timestamps. The changes
should have been tested by each platform maintainer already (and few
of them have cross-platform impact) so I'm personally not too
concerned by it at this time"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (23 commits)
ARM: multi_v7_defconfig: remove redundant entries and re-enable TI_EDMA
ARM: multi_v7_defconfig: add mvebu drivers
clocksource: kona: Add basic use of external clock
drivers: bus: fix CCI driver kcalloc call parameters swap
ARM: dts: bcm28155-ap: Fix Card Detection GPIO
ARM: multi_v7_defconfig: Select CONFIG_AT803X_PHY
ARM: keystone: config: fix build warning when CONFIG_DMADEVICES is not set
MAINTAINERS: ARM: SiRF: use regex patterns to involve all SiRF drivers
ARM: dts: zynq: Add SDHCI nodes
ARM: hisi: don't select SMP
ARM: tegra: rebuild tegra_defconfig to add DEBUG_FS
ARM: multi_v7: copy most options from tegra_defconfig
ARM: iop32x: fix power off handling for the EM7210 board
ARM: integrator: restore static map on the CP
ARM: msm_defconfig: Enable MSM clock drivers
ARM: dts: msm: Add clock controller nodes and hook into uart
ARM: OMAP4+: move errata initialization to omap4_pm_init_early
ARM: OMAP4460: cpuidle: Extend PM_OMAP4_ROM_SMP_BOOT_ERRATUM_GICD on cpuidle
ARM: mvebu: fix compilation warning on Armada 370 (i.e. non-SMP)
ARM: shmobile: r8a7790.dtsi: ficx i2c[0-3] clock reference
With DISCONTIGMEM, the mapping between a pfn and its owning node is
initialized using data provided by the BIOS. However, the initialization
may fail if the extents are not aligned to section boundary (64M).
The symptom of this bug is an early boot failure in pfn_to_page(),
as it tries to access NODE_DATA(__nid) using index from an unitialized
element of the physnode_map[] array.
While the bug is always present, it is more likely to be hit in kdump
kernels on large machines, because:
1. The memory map for a kdump kernel is specified as exactmap, and
exactmap is more likely to be unaligned.
2. Large reservations are more likely to span across a 64M boundary.
[ hpa: fixed incorrect use of "pfn" instead of "start" ]
Signed-off-by: Petr Tesarik <ptesarik@suse.cz>
Link: http://lkml.kernel.org/r/20140201133019.32e56f86@hananiah.suse.cz
Acked-by: David Rientjes <rientjes@google.com>
With commit d8d14bd09cdd ("fs/compat: fix lookup_dcookie() parameter
handling") I changed the type of the len parameter of the
lookup_dcookie() syscall.
However I missed that there was still a stale declaration in
arch/tile/.. which now causes a compile error on tile:
In file included from fs/dcookies.c:28:0:
include/linux/compat.h:425:17: error: conflicting types for 'compat_sys_lookup_dcookie'
fs/dcookies.c:207:1: error: conflicting types for 'compat_sys_lookup_dcookie'
Simply remove the declaration in the tile architecture, which is only a
leftover from before the different compat lookup_dcookie() versions have
been merged. The correct declaration is now in include/linux/compat.h
The build error was reported by Fenguang's build bot.
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
TI_EDMA fell out of automatically selected options in the multi_v7
defconfig due to a select being removed from the davinci Kconfig entry. So
we need to re-enable explicitly to not regress some platforms.
The rest is just the result of running 'make multi_v7_defconfig + make
savedefconfig' to remove entries that are no longer needed due to changed
dependencies/selects or defaults.
