asm code really wants asm/hwcap.h, so include that instead.
Use MT_DEVICE_NONSHARED instead.
As of the previous commit, MT_DEVICE_IXP2000 encodes to the same
PTE bit encoding as MT_DEVICE, so it's now redundant. Convert
MT_DEVICE_IXP2000 to use MT_DEVICE instead, and remove its aliases.
Use 'shared device' mappings for devices, and use the standard
bit combinations for Xscale3.
This member is now redundant; the memory type is encoded in the Linux
PTE bits.
Provide L_PTE_MT_xxx definitions to describe the memory types that we
use in Linux/ARM. These definitions are carefully picked such that:
1. their LSBs match what is required for pre-ARMv6 CPUs.
2. they all have a unique encoding, including after modification
by build_mem_type_table() (the result being that some have more
than one combination.)
There are actually only four separate implementations of set_pte_ext.
Use assembler macros to insert code for these into the proc-*.S files.
This patch provides an ARM implementation of ioremap_wc().
We use different page table attributes depending on which CPU we
are running on:
- Non-XScale ARMv5 and earlier systems: The ARMv5 ARM documents four
possible mapping types (CB=00/01/10/11). We can't use any of the
cached memory types (CB=10/11), since that breaks coherency with
peripheral devices. Both CB=00 and CB=01 are suitable for _wc, and
CB=01 (Uncached/Buffered) allows the hardware more freedom than
CB=00, so we'll use that.
(The ARMv5 ARM seems to suggest that CB=01 is allowed to delay stores
but isn't allowed to merge them, but there is no other mapping type
we can use that allows the hardware to delay and merge stores, so
we'll go with CB=01.)
- XScale v1/v2 (ARMv5): same as the ARMv5 case above, with the slight
difference that on these platforms, CB=01 actually _does_ allow
merging stores. (If you want noncoalescing bufferable behavior
on Xscale v1/v2, you need to use XCB=101.)
- Xscale v3 (ARMv5) and ARMv6+: on these systems, we use TEXCB=00100
mappings (Inner/Outer Uncacheable in xsc3 parlance, Uncached Normal
in ARMv6 parlance).
The ARMv6 ARM explicitly says that any accesses to Normal memory can
be merged, which makes Normal memory more suitable for _wc mappings
than Device or Strongly Ordered memory, as the latter two mapping
types are guaranteed to maintain transaction number, size and order.
We use the Uncached variety of Normal mappings for the same reason
that we can't use C=1 mappings on ARMv5.
The xsc3 Architecture Specification documents TEXCB=00100 as being
Uncacheable and allowing coalescing of writes, which is also just
what we need.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
mcbsp is confused as to what takes a physical or virtual address.
Fix the two instances where it gets it wrong.
The driver(s) below do not use LINUX_VERSION_CODE nor KERNEL_VERSION.
arch/arm/plat-mxc/clock.c
This patch removes the said #include <version.h>.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
arch/arm/plat-omap/gpio.c: In function '_omap_gpio_init':
arch/arm/plat-omap/gpio.c:1492: error: 'omap_mpuio_device' undeclared (first use in this function)
Larry Finger reported at http://lkml.org/lkml/2008/9/1/90:
An ancient laptop of mine started throwing errors from b43legacy when
I started using 2.6.27 on it. This has been bisected to commit bfc0f59
"x86: merge tsc calibration".
The unification of the TSC code adopted mostly the 64bit code, which
prefers PMTIMER/HPET over the PIT calibration.
Larrys system has an AMD K6 CPU. Such systems are known to have
PMTIMER incarnations which run at double speed. This results in a
miscalibration of the TSC by factor 0.5. So the resulting calibrated
CPU/TSC speed is half of the real CPU speed, which means that the TSC
based delay loop will run half the time it should run. That might
explain why the b43legacy driver went berserk.
On the other hand we know about systems, where the PIT based
calibration results in random crap due to heavy SMI/SMM
disturbance. On those systems the PMTIMER/HPET based calibration logic
with SMI detection shows better results.
According to Alok also virtualized systems suffer from the PIT
calibration method.
The solution is to use a more wreckage aware aproach than the current
either/or decision.
1) reimplement the retry loop which was dropped from the 32bit code
during the merge. It repeats the calibration and selects the lowest
frequency value as this is probably the closest estimate to the real
frequency
2) Monitor the delta of the TSC values in the delay loop which waits
for the PIT counter to reach zero. If the maximum value is
significantly different from the minimum, then we have a pretty safe
indicator that the loop was disturbed by an SMI.
3) keep the pmtimer/hpet reference as a backup solution for systems
where the SMI disturbance is a permanent point of failure for PIT
based calibration
4) do the loop iteration for both methods, record the lowest value and
decide after all iterations finished.
5) Set a clear preference to PIT based calibration when the result
makes sense.
The implementation does the reference calibration based on
HPET/PMTIMER around the delay, which is necessary for the PIT anyway,
but keeps separate TSC values to ensure the "independency" of the
resulting calibration values.
Tested on various 32bit/64bit machines including Geode 266Mhz, AMD K6
(affected machine with a double speed pmtimer which I grabbed out of
the dump), Pentium class machines and AMD/Intel 64 bit boxen.
Bisected-by: Larry Finger <Larry.Finger@lwfinger.net>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Fix operator precedence bug in atari_keyb_init, which caused a failure on CT60
Signed-off-by: Michael Schmitz <schmitz@debian.org>
A parisc allmodconfig build produces this:
arch/parisc/hpux/fs.c:107: error: 'buffer' undeclared (first use in this function)
Introduced by commit da574983de9f9283ba35662c8723627096e160de ("[PATCH]
fix hpux_getdents()").
Helge Dille also reported this in bugzilla 11461:
http://bugzilla.kernel.org/show_bug.cgi?id=11461
and he posted an identical patch.
Signed-off-by: Helge Deller <deller@gmx.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc64: setup_valid_addr_bitmap_from_pavail() should be __init
sparc: Fix resource flags for PCI children in OF device tree.
sparc32: Implement smp_call_function_single().
Breaking lines due to some imaginary problem with a long line length is
often stupid and wrong, but never more so when it splits a string that
is printed out into multiple lines. This really ended up making it much
harder to find where some error strings were printed out, because a
simple 'grep' didn't work.
I'm sure there is tons more of this particular idiocy hiding in other
places, but this particular case hit me once more last week. So fix it.
BAR, v3"
This reverts commit a2bd7274b47124d2fc4dfdb8c0591f545ba749dd.
It wasn't really right to begin with (there's a better fix for the
problem with e820 reservations clashing with PCI BAR's pending), but it
also actually causes more regressions, so it should be reverted even
before the better fix is finalized.
Rafael reports that this commit broke AHCI detection, and thus causes
the kernel to not boot on his quad core test box.
Reported-and-bisected-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: David Witbrodt <dawitbro@sbcglobal.net>
When a device is under an EBUS or ISA bus, the resource flags
don't get set properly.
Fix this by re-evaluating the resource flags at each level of
bus as we apply ranges on the way to the root. And let PCI
override any existing flags setting, but don't let the
default flags calculator make such overrides.
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 5226/1: remove unmatched comment end.
[ARM] Skip memory holes in FLATMEM when reading /proc/pagetypeinfo
[ARM] use bcd2bin/bin2bcd
[ARM] use the new byteorder headers
[ARM] OMAP: Fix 2430 SMC91x ethernet IRQ
[ARM] OMAP: Add and update OMAP default configuration files
[ARM] OMAP: Change mailing list for OMAP in MAINTAINERS
[ARM] S3C2443: Fix the S3C2443 clock register definitions
[ARM] JIVE: Fix the spi bus numbering
[ARM] S3C24XX: pwm.c: stop debugging output
[ARM] S3C24XX: Fix sparse warnings in pwm.c
[ARM] S3C24XX: Fix spare errors in pwm-clock driver
[ARM] S3C24XX: Fix sparse warnings in arch/arm/plat-s3c24xx/gpiolib.c
[ARM] S3C24XX: Fix nor-simtec driver sparse errors
[ARM] 5225/1: zaurus: Register I2C controller for audio codecs
[ARM] orion5x: update defconfig to v2.6.27-rc4
[ARM] Orion: register UART1 on QNAP TS-209 and TS-409
[ARM] Orion: activate lm75 driver on DNS-323
[ARM] Orion: fix MAC detection on QNAP TS-209 and TS-409
[ARM] Orion: Fix boot crash on Kurobox Pro
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6:
Blackfin arch: Fix PM building on BF52x: No ROTWE on BF52x, add USBWE
Blackfin arch: sram: use 'unsigned long' for irqflags
Blackfin arch: let PCI depend on BROKEN
Blackfin arch: move include/asm-blackfin header files to arch/blackfin
Blackfin arch: fix bug - MPU crashes under stress
Blackfin arch: Fix bug - when to rmmod the L1_module, it stucks and then reboot the board.
Blackfin arch: dont actually need to muck with EMAC_SYSTAT for BF52x for demuxing
Blackfin arch: Add MTD Partitions for MTD_DATAFLASH, increase max SPI SCLK
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: update defconfigs
x86: msr: fix bogus return values from rdmsr_safe/wrmsr_safe
x86: cpuid: correct return value on partial operations
x86: msr: correct return value on partial operations
x86: cpuid: propagate error from smp_call_function_single()
x86: msr: propagate errors from smp_call_function_single()
smp: have smp_call_function_single() detect invalid CPUs
Signed-off-by: Jean-Christophe DUBOIS <jcd@tribudubois.net>
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
Using just 'unsigned' will make flags an unsigned int. While this is
arguably not an error on blackfin where sizeof(int) == sizeof(long),
the patch is still justified on the grounds of principle.
The patch was generated using the Coccinelle semantic patch framework.
Cc: Julia Lawall <julia@diku.dk>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Reported by Stephen Rothwell.
Needed to fix the build when CONFIG_RELAY is enabled.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (55 commits)
sctp: fix random memory dereference with SCTP_HMAC_IDENT option.
sctp: correct bounds check in sctp_setsockopt_auth_key
wan: Missing capability checks in sbni_ioctl()
e100, fix iomap read
qeth: preallocated header account offset
qeth: l2 write unicast list to hardware
qeth: use -EOPNOTSUPP instead of -ENOTSUPP.
ibm_newemac: Don't call dev_mc_add() before device is registered
net: don't grab a mutex within a timer context in gianfar
forcedeth: fix checksum flag
net/usb/mcs7830: add set_mac_address
net/usb/mcs7830: new device IDs
[netdrvr] smc91x: fix resource removal (null ptr deref)
ibmveth: fix bad UDP checksums
[netdrvr] hso: dev_kfree_skb crash fix
[netdrvr] hso: icon 322 detection fix
atl1: disable TSO by default
atl1e: multistatement if missing braces
igb: remove 82576 quad adapter
drivers/net/skfp/ess.c: fix compile warnings
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
[PATCH] deal with the first call of ->show() generating no output
[PATCH] fix ->llseek() for a bunch of directories
[PATCH] fix regular readdir() and friends
[PATCH] fix hpux_getdents()
[PATCH] fix osf_getdirents()
[PATCH] ntfs: use d_add_ci
[PATCH] change d_add_ci argument ordering
[PATCH] fix efs_lookup()
[PATCH] proc: inode number fixlet
sparc: Add target for a stripped kernel
sparc64: Make NUMA depend upon SMP.
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6:
[S390] dcss: fix build bug.
[S390] Fix linker script.
Ordinarily, memory holes in flatmem still have a valid memmap and is safe
to use. However, an architecture (ARM) frees up the memmap backing memory
holes on the assumption it is never used. /proc/pagetypeinfo reads the
whole range of pages in a zone believing that the memmap is valid and that
pfn_valid will return false if it is not. On ARM, freeing the memmap breaks
the page->zone linkages even though pfn_valid() returns true and the kernel
can oops shortly afterwards due to accessing a bogus struct zone *.
This patch lets architectures say when FLATMEM can have holes in the
memmap. Rather than an expensive check for valid memory, /proc/pagetypeinfo
will confirm that the page linkages are still valid by checking page->zone
is still the expected zone. The lookup of page_zone is safe as there is a
limited range of memory that is accessed when calling page_zone. Even if
page_zone happens to return the correct zone, the impact is that the counters
in /proc/pagetypeinfo are slightly off but fragmentation monitoring is
unlikely to be relevant on an embedded system.
Reported-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
This patch changes arm to use the new bcd2bin/bin2bcd functions instead
of the obsolete BCD_TO_BIN/BIN_TO_BCD macros.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Taken from omap 97b705ad835f1481270c4b67b402d6e37fa8ad15:
ARM: OMAP: Misc compile fixes after syncing with mainline
Also fix 2430 smc91x to use IRQ_LOWLEVEL.
Update omap_h2_1610 and omap_osk_5912 default configurations.
Add ams delta, n770, omap 2430sdp, apollon_2420, generic 1510, 1610,
1710, 2420, h4 2420, innovator 1510 and 1610, perseus2 730, palte,
palmtt, palmz71 and sx1 default configurations.
Pulled out of the omap zoom tree.
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
Enable some option commonly used by testers in defconfig, including
some very common device drivers and network boot support. defconfig
is still not meant to be a kitchen-sink configuration.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
AFAIR there exists blackfin hardware with PCI support, but the support
currently in the kernel fails to build starting with:
CC drivers/pci/probe.o
probe.c: In function 'pci_scan_slot':
probe.c:1056: error: implicit declaration of function 'pcibios_scan_all_fns'
make[3]: *** [drivers/pci/probe.o] Error 1
Fix the S3C2443 clock register definitions for selecting the EPLL
reference clock described by S3C2443_CLKSRC_EPLLREF.
Signed-off-by: Wei Shuai <cpuwolf@gmail.com>
[ben-linux@fluff.org: minor description fixes]
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The first spi bus is registered with number 0, but
the board data says that the device on it is registered
on bus 1.
Move the spi bus to bus 1 to keep the compatibility with the
original board-support patches.
Move debugging output to dev_dbg() instead of dev_info().
Fix the following sparse warnings in arch/arm/plat-s3c24xx/pwm.c:
warning: symbol 's3c_device_timer' was not declared. Should it be static?
warning: symbol 'pwm_calc_tin' was not declared. Should it be static?
