Signed-off-by: Cui Bixiong <bixiong@sunnorth.com.cn>
Signed-off-by: Chen Liqin <liqin.chen@sunplusct.com>
modified: arch/score/include/asm/cacheflush.h
modified: arch/score/mm/cache.c
* 'next' of git://git.secretlab.ca/git/linux-2.6: (23 commits)
powerpc: fix up for mmu_mapin_ram api change
powerpc: wii: allow ioremap within the memory hole
powerpc: allow ioremap within reserved memory regions
wii: use both mem1 and mem2 as ram
wii: bootwrapper: add fixup to calc useable mem2
powerpc: gamecube/wii: early debugging using usbgecko
powerpc: reserve fixmap entries for early debug
powerpc: wii: default config
powerpc: wii: platform support
powerpc: wii: hollywood interrupt controller support
powerpc: broadway processor support
powerpc: wii: bootwrapper bits
powerpc: wii: device tree
powerpc: gamecube: default config
powerpc: gamecube: platform support
powerpc: gamecube/wii: flipper interrupt controller support
powerpc: gamecube/wii: udbg support for usbgecko
powerpc: gamecube/wii: do not include PCI support
powerpc: gamecube/wii: declare as non-coherent platforms
powerpc: gamecube/wii: introduce GAMECUBE_COMMON
Fix up conflicts in arch/powerpc/mm/fsl_booke_mmu.c.
Hopefully even close to correctly.
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (117 commits)
ACPI processor: Fix section mismatch for processor_add()
ACPI: Add platform-wide _OSC support.
ACPI: cleanup pci_root _OSC code.
ACPI: Add a generic API for _OSC -v2
msi-wmi: depend on backlight and fix corner-cases problems
msi-wmi: switch to using input sparse keymap library
msi-wmi: replace one-condition switch-case with if statement
msi-wmi: remove unused field 'instance' in key_entry structure
msi-wmi: remove custom runtime debug implementation
msi-wmi: rework init
msi-wmi: remove useless includes
X86 drivers: Introduce msi-wmi driver
Toshiba Bluetooth Enabling driver (RFKill handler v3)
ACPI: fix for lapic_timer_propagate_broadcast()
acpi_pad: squish warning
ACPI: dock: minor whitespace and style cleanups
ACPI: dock: add struct dock_station * directly to platform device data
ACPI: dock: dock_add - hoist up platform_device_register_simple()
ACPI: dock: remove global 'dock_device_name'
ACPI: dock: combine add|alloc_dock_dependent_device (v2)
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (38 commits)
direct I/O fallback sync simplification
ocfs: stop using do_sync_mapping_range
cleanup blockdev_direct_IO locking
make generic_acl slightly more generic
sanitize xattr handler prototypes
libfs: move EXPORT_SYMBOL for d_alloc_name
vfs: force reval of target when following LAST_BIND symlinks (try #7)
ima: limit imbalance msg
Untangling ima mess, part 3: kill dead code in ima
Untangling ima mess, part 2: deal with counters
Untangling ima mess, part 1: alloc_file()
O_TRUNC open shouldn't fail after file truncation
ima: call ima_inode_free ima_inode_free
IMA: clean up the IMA counts updating code
ima: only insert at inode creation time
ima: valid return code from ima_inode_alloc
fs: move get_empty_filp() deffinition to internal.h
Sanitize exec_permission_lite()
Kill cached_lookup() and real_lookup()
Kill path_lookup_open()
Trivial conflicts in fs/direct-io.c
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix kprobes build with non-gawk awk
x86: Split swiotlb initialization into two stages
x86: Regex support and known-movable symbols for relocs, fix _end
x86, msr: Remove incorrect, duplicated code in the MSR driver
x86: Merge kernel_thread()
x86: Sync 32/64-bit kernel_thread
x86, 32-bit: Use same regs as 64-bit for kernel_thread_helper
x86, 64-bit: Use user_mode() to determine new stack pointer in copy_thread()
x86, 64-bit: Move kernel_thread to C
x86-64, paravirt: Call set_iopl_mask() on 64 bits
x86-32: Avoid pipeline serialization in PTREGSCALL1 and 2
x86: Merge sys_clone
x86, 32-bit: Convert sys_vm86 & sys_vm86old
x86: Merge sys_sigaltstack
x86: Merge sys_execve
x86: Merge sys_iopl
x86-32: Add new pt_regs stubs
cpumask: Use modern cpumask style in arch/x86/kernel/cpu/mcheck/mce-inject.c
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (88 commits)
Blackfin: Convert BUG() to use unreachable()
Blackfin: define __NR_recvmmsg
Blackfin: drop duplicate sched_clock
Blackfin: NOMPU: skip DMA ICPLB hole when it is redundant
Blackfin: MPU: add missing __init markings
Blackfin: add support for TIF_NOTIFY_RESUME
Blackfin: kgdb_test: clean up code a bit
Blackfin: convert kgdbtest to proc_fops
Blackfin: convert cyc2ns() to clocksource_cyc2ns()
Blackfin: ip0x: pull in asm/portmux.h for P_xxx defines
Blackfin: drop unused ax88180 resources
Blackfin: bf537-stamp: add ADF702x network driver resources
Blackfin: bf537-stamp: add CAN resources
Blackfin: bf537-stamp: add AD5258 i2c address
Blackfin: bf537-stamp: add adau1761 i2c address
Blackfin: bf537-stamp: add adau1371 i2c address
Blackfin: bf537-stamp: add ADP8870 resources
Blackfin: bf537-stamp: kill AD714x board-specific Kconfigs
Blackfin: bf537-stamp: update ADP5520 resources
Blackfin: bf537-stamp: add ADXL346 orientation sensing support
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus
* 'module' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
modpost: fix segfault with short symbol names
module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y
Kbuild: clear marker out of modpost
module: make MODULE_SYMBOL_PREFIX into a CONFIG option
ARM: unexport symbols used to implement floating point emulation
ARM: use unified discard definition in linker script
x86: don't export inline function
sparc64: don't export static inline pci_ functions
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] implement early_io{re,un}map for ia64
[IA64] Replace old style lock initializer
[IA64] fix SBA IOMMU to handle allocation failure properly
[IA64] Save I-resources to ia64_sal_os_state
[IA64] preallocate IA64_IRQ_MOVE_VECTOR
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits)
nfsd: remove pointless paths in file headers
nfsd: move most of nfsfh.h to fs/nfsd
nfsd: remove unused field rq_reffh
nfsd: enable V4ROOT exports
nfsd: make V4ROOT exports read-only
nfsd: restrict filehandles accepted in V4ROOT case
nfsd: allow exports of symlinks
nfsd: filter readdir results in V4ROOT case
nfsd: filter lookup results in V4ROOT case
nfsd4: don't continue "under" mounts in V4ROOT case
nfsd: introduce export flag for v4 pseudoroot
nfsd: let "insecure" flag vary by pseudoflavor
nfsd: new interface to advertise export features
nfsd: Move private headers to source directory
vfs: nfsctl.c un-used nfsd #includes
lockd: Remove un-used nfsd headers #includes
s390: remove un-used nfsd #includes
sparc: remove un-used nfsd #includes
parsic: remove un-used nfsd #includes
compat.c: Remove dependence on nfsd private headers
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (22 commits)
Input: ALPS - add interleaved protocol support (Dell E6x00 series)
Input: keyboard - don't override beep with a bell
Input: altera_ps2 - fix test of unsigned in altera_ps2_probe()
Input: add mc13783 touchscreen driver
Input: ep93xx_keypad - update driver to new core support
Input: wacom - separate pen from express keys on Graphire
Input: wacom - add defines for data packet report IDs
Input: wacom - add support for new LCD tablets
Input: wacom - add defines for packet lengths of various devices
Input: wacom - ensure the device is initialized properly upon resume
Input: at32psif - do not sleep in atomic context
Input: i8042 - add Gigabyte M1022M to the noloop list
Input: i8042 - allow installing platform filters for incoming data
Input: i8042 - fix locking in interrupt routine
Input: ALPS - do not set REL_X/REL_Y capabilities on the touchpad
Input: document use of input_event() function
Input: sa1111ps2 - annotate probe() and remove() methods
Input: ambakmi - annotate probe() and remove() methods
Input: gscps2 - fix probe() and remove() annotations
Input: altera_ps2 - add annotations to probe and remove methods
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (33 commits)
sh: Fix test of unsigned in se7722_irq_demux()
sh: mach-ecovec24: Add FSI sound support
sh: mach-ecovec24: Add mt9t112 camera support
sh: mach-ecovec24: Add tw9910 support
sh: MSIOF/mmc_spi platform data for the Ecovec24 board
sh: ms7724se: Add ak4642 support
sh: Fix up FPU build for SH5
sh: Remove old early serial console code V2
sh: sh5 scif pdata (sh5-101/sh5-103)
sh: sh4a scif pdata (sh7757/sh7763/sh7770/sh7780/sh7785/sh7786/x3)
sh: sh4a scif pdata (sh7343/sh7366/sh7722/sh7723/sh7724)
sh: sh4 scif pdata (sh7750/sh7760/sh4-202)
sh: sh3 scif pdata (sh7705/sh770x/sh7710/sh7720)
sh: sh2a scif pdata (sh7201/sh7203/sh7206/mxg)
sh: sh2 scif pdata (sh7616)
sh-sci: Extend sh-sci driver with early console V2
sh: Stub in P3 ioremap support for nommu parts.
sh: wire up vmallocinfo support in ioremap() implementations.
sh: Make the unaligned trap handler always obey notification levels.
sh: Couple kernel and user write page perm bits for CONFIG_X2TLB
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
ppc440spe-adma: adds updated ppc440spe adma driver
iop-adma.c: use resource_size()
dmaengine: clarify the meaning of the DMA_CTRL_ACK flag
sh: stylistic improvements for the DMA driver
dmaengine: fix dmatest to verify minimum transfer length and test buffer size
sh: DMA driver has to specify its alignment requirements
Add COH 901 318 DMA block driver v5
* git://git.infradead.org/mtd-2.6: (90 commits)
jffs2: Fix long-standing bug with symlink garbage collection.
mtd: OneNAND: Fix test of unsigned in onenand_otp_walk()
mtd: cfi_cmdset_0002, fix lock imbalance
Revert "mtd: move mxcnd_remove to .exit.text"
mtd: m25p80: add support for Macronix MX25L4005A
kmsg_dump: fix build for CONFIG_PRINTK=n
mtd: nandsim: add support for 4KiB pages
mtd: mtdoops: refactor as a kmsg_dumper
mtd: mtdoops: make record size configurable
mtd: mtdoops: limit the maximum mtd partition size
mtd: mtdoops: keep track of used/unused pages in an array
mtd: mtdoops: several minor cleanups
core: Add kernel message dumper to call on oopses and panics
mtd: add ARM pismo support
mtd: pxa3xx_nand: Fix PIO data transfer
mtd: nand: fix multi-chip suspend problem
mtd: add support for switching old SST chips into QRY mode
mtd: fix M29W800D dev_id and uaddr
mtd: don't use PF_MEMALLOC
mtd: Add bad block table overrides to Davinci NAND driver
Fixed up conflicts (mostly trivial) in
drivers/mtd/devices/m25p80.c
drivers/mtd/maps/pcmciamtd.c
drivers/mtd/nand/pxa3xx_nand.c
kernel/printk.c
git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6:
parisc: Fixup last users of irq_chip->typename
parisc: convert /proc/pdc/{lcd,led} to seq_file
parisc: Convert BUG() to use unreachable()
parisc: Replace old style lock init in smp.c
parisc: use sort() instead of home-made implementation (v2)
parisc: add CALLER_ADDR{0-6} macros
parisc: remove unused IRQSTAT_SIRQ_PEND and IRQSTAT_SZ defines
parisc: remove duplicated #include
* git://git.infradead.org/iommu-2.6:
Revert "Intel IOMMU: Avoid memory allocation failures in dma map api calls"
intel-iommu: ignore page table validation in pass through mode
intel-iommu: Fix oops with intel_iommu=igfx_off
intel-iommu: Check for an RMRR which ends before it starts.
intel-iommu: Apply BIOS sanity checks for interrupt remapping too.
intel-iommu: Detect DMAR in hyperspace at probe time.
dmar: Fix build failure without NUMA, warn on bogus RHSA tables and don't abort
iommu: Allocate dma-remapping structures using numa locality info
intr_remap: Allocate intr-remapping table using numa locality info
dmar: Allocate queued invalidation structure using numa locality info
dmar: support for parsing Remapping Hardware Static Affinity structure
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (116 commits)
V4L/DVB (13698): pms: replace asm/uaccess.h to linux/uaccess.h
V4L/DVB (13690): radio/si470x: #include <sched.h>
V4L/DVB (13688): au8522: modify the attributes of local filter coefficients
V4L/DVB (13687): cx231xx: use NULL when pointer is needed
V4L/DVB: Davinci VPFE Capture: remove unused #include <linux/version.h>
V4L/DVB (13685): Correct code taking the size of a pointer
V4L/DVB (13684): Fix some cut-and-paste noise in dib0090.h
V4L/DVB (13683): sanio-ms: clean up init, exit and id_table
V4L/DVB (13682): dib8000: make some constant static
V4L/DVB: lgs8gxx: Use shifts rather than multiply/divide when possible
V4L/DVB (13680b): DocBook/media: create links for included sources
V4L/DVB (13680a): DocBook/media: copy images after building HTML
V4L/DVB (13678): Add support for yet another DvbWorld, TeVii and Prof USB devices
V4L/DVB (13676): configurable IRQ mode on NetUP Dual DVB-S2 CI; IRQ from CAM processing (CI interface works faster)
V4L/DVB (13674): stv090x: Add DiSEqC envelope mode
V4L/DVB (13673): lnbp21: Implement 22 kHz tone control
V4L/DVB (13671): sh_mobile_ceu_camera: Remove frame size page alignment
V4L/DVB (13670): soc-camera: Add mt9t112 camera driver
V4L/DVB (13669): tw9910: Add sync polarity support
V4L/DVB (13668): tw9910: remove cropping
... and have the caller grab both mnt and dentry; kill
leak in infiniband, while we are at it.
* hpux_pipe() - no need to take BKL
* sys32_pipe() in arch/x86/ia32 and xtensa_pipe() in arch/xtensa -
no need at all, since both functions are open-coded sys_pipe()
Acked-by: "David S. Miller" <davem@davemloft.net>
Use bitmap library and kill some unused iommu helper functions.
1. s/iommu_area_free/bitmap_clear/
2. s/iommu_area_reserve/bitmap_set/
3. Use bitmap_find_next_zero_area instead of find_next_zero_area
This cannot be simple substitution because find_next_zero_area
doesn't check the last bit of the limit in bitmap
4. Remove iommu_area_free, iommu_area_reserve, and find_next_zero_area
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Create a function to generate the value that is written to the UV hub MMR
to cause an IPI interrupt to be sent. The function will be used in the
GRU message queue error recovery code that sends IPIs to nodes in remote
partitions.
Signed-off-by: Jack Steiner <steiner@sgi.com>
The UV BIOS has moved the location of some of their pointers to the
"partition reserved page" from memory into a uv hub MMR. The GRU does not
support bcopy operations from MMR space so we need to special case the MMR
addresses using VLOAD operations.
Additionally, the BIOS call for registering a message queue watchlist has
removed the 'blade' value and eliminated the structure that was being
passed in. This is also reflected in this patch.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
Provide a mechanism for determining if a global physical address is
pointing to a UV hub MMR.
The UV BIOS has been updated to implement some of our interface
functionality differently than originally expected. These patches update
the kernel to the bios implementation and include a few minor bug fixes
which prevent us from doing significant testing on real hardware.
This patch:
For SGI UV systems, translate from a global physical address back to a
socket physical address. This does nothing to ensure the socket physical
address is actually addressable by the kernel. That is the responsibility
of the user of the function.
dma_mask is, when interpreted as address, the last valid byte, and hence
comparison msut also be done using the last valid of the buffer in
question.
Also fix the open-coded instances in lib/swiotlb.c.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Becky Bruce <beckyb@kernel.crashing.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Currently all architectures but microblaze unconditionally define
USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so
let's kill this ifdef and make sure we are the same everywhere.
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: <linux-arch@vger.kernel.org>
Cc: Michal Simek <michal.simek@petalogix.com>
Suggested by Roland.
Unlike powepc, x86 always calls tracehook_report_syscall_exit(step) with
step = 0, and sends the trap by hand.
This results in unnecessary SIGTRAP when PTRACE_SINGLESTEP follows the
syscall-exit stop.
Change syscall_trace_leave() to pass the correct "step" argument to
tracehook and remove the send_sigtrap() logic.
Acked-by: Roland McGrath <roland@redhat.com>
Implement user_single_step_siginfo() for x86. Extract this code from
send_sigtrap().
Since x86 calls tracehook_report_syscall_exit(step => 0) the new helper is
not used yet.
Implement user_single_step_siginfo() for powerpc.
Add the platform specific callback to control LCD panel and backlight
power.
Signed-off-by: Chaithrika U S <chaithrika@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Krzysztof Helt <krzysztof.h1@poczta.fm>
Framebuffer driver for the Landscape LCD EZ-Extender (ADZS-BFLLCD-EZEXT)
http://docs.blackfin.uclinux.org/doku.php?id=hw:cards:landscape_lcd_ez-extender
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
sizes, add platform data
It has been experimentally found out, that the sensor only supports up to
512x384 video output and also has some restrictions on minimum scale. We
disable non-working size ranges until, maybe, someone finds out how to properly
set them up. Also add cropping support, an auto white balance control, platform
data to specify master clock frequency and polarity of the IOCTL pin.
create mode 100644 include/media/rj54n1cb0c.h
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Convert soc-camera core and all soc-camera drivers to the new mediabus
API. This also takes soc-camera client drivers one step closer to also be
usable with generic v4l2-subdev host drivers.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
struct soc_camera_link
After this change drivers can be further extended to not fail, if they don't
get platform data, but to use defaults.
se7722_fpga_irq[] is unsigned so the test does not work.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
The typename member of struct irq_chip was kept for migration purposes
and is obsolete since more than 2 years. Fix up the leftovers.
Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
Use the new unreachable() macro instead of for(;;);
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
SPIN_LOCK_UNLOCKED is deprecated. Init the per cpu locks at runtime
instead.
(Also kills the unused smp_lock --kyle)
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Randolph Chung <tausq@parisc-linux.org>
Remove duplicated #include('s) in
arch/parisc/kernel/signal.c
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Needed for commit 2c992208 ("intel-iommu: Detect DMAR in hyperspace at
probe time.) to build on IA64.
Signed-off-by: Tony Luck <tony.luck@intel.com>
The instruction attribute table generator fails when run by mawk
or original-awk:
$ mawk -f arch/x86/tools/gen-insn-attr-x86.awk \
arch/x86/lib/x86-opcode-map.txt > /dev/null
Semantic error at 240: Second IMM error
$ echo $?
1
Line 240 contains "c8: ENTER Iw,Ib", which indicates that this
instruction has two immediate operands, the second of which is
one byte. The script loops through the immediate operands using
a for loop.
Unfortunately, there is no guarantee in awk that a for (variable
in array) loop will return the indices in increasing order.
Internally, both original-awk and mawk iterate over a hash table
for this purpose, and both implementations happen to produce the
index 2 before 1. The supposed second immediate operand is more
than one byte wide, producing the error.
So loop over the indices in increasing order instead. As a
side-effect, with mawk this means the silly two-entry hash table
never has to be built.
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
Acked-by Masami Hiramatsu <mhiramat@redhat.com>
Cc: Jim Keniston <jkenisto@us.ibm.com>
LKML-Reference: <20091213220437.GA27718@progeny.tock>
Merge reason: Leftover mini-topic from the merge window - merge it.
Merge reason: it's stable so lets push it upstream.
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits)
clockevents: Convert to raw_spinlock
clockevents: Make tick_device_lock static
debugobjects: Convert to raw_spinlocks
perf_event: Convert to raw_spinlock
hrtimers: Convert to raw_spinlocks
genirq: Convert irq_desc.lock to raw_spinlock
smp: Convert smplocks to raw_spinlocks
rtmutes: Convert rtmutex.lock to raw_spinlock
sched: Convert pi_lock to raw_spinlock
sched: Convert cpupri lock to raw_spinlock
sched: Convert rt_runtime_lock to raw_spinlock
sched: Convert rq->lock to raw_spinlock
plist: Make plist debugging raw_spinlock aware
bkl: Fixup core_lock fallout
locking: Cleanup the name space completely
locking: Further name space cleanups
alpha: Fix fallout from locking changes
locking: Implement new raw_spinlock
locking: Convert raw_rwlock functions to arch_rwlock
locking: Convert raw_rwlock to arch_rwlock
* git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6:
avr32: update default configurations for ATNGW100, ATSTK1002 and ATSTK1006
avr32: add default configurations for ATNGW100 mkII and EVKLCD10X
avr32: add support for ATNGW100 mkII board
avr32: convert to asm-generic/hardirq.h
avr32: add two new at91 to cpu.h definition
avr32: clean up linker script using standard macros.
avr32: MRMT: correct setup of SPI slaves
avr32: function for independently setting up SPI slaves
avr32: re-instate MCI WP/CD pin assignments for ATNGW100
