path: root/arch
2011-06-25at91: fix at91_set_serial_console: use platform device idJean-Christophe PLAGNIOL-VILLARD
2011-06-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86/PCI/ACPI: fix type mismatch PCI: fix new kernel-doc warning PCI: Fix warning in drivers/pci/probe.c on sparc64
2011-06-21MN10300: asm/uaccess.h needs to #include linux/kernel.h for might_sleep()David Howells
MN10300's asm/uaccess.h needs to #include linux/kernel.h to get might_sleep() otherwise it fails to build on MN10300 allyesconfig. This fails in a few places with messages like the following: In file included from security/keys/trusted.c:14: include/linux/uaccess.h: In function '__copy_from_user_nocache': include/linux/uaccess.h:52: error: implicit declaration of function 'might_sleep' Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-20Merge branch 'msm-fix' of git://codeaurora.org/quic/kernel/davidb/linux-msmLinus Torvalds
* 'msm-fix' of git://codeaurora.org/quic/kernel/davidb/linux-msm: msm: timer: Fix DGT rate on 8960 and 8660 msm: timer: compensate for timer shift in msm_read_timer_count msm: timer: Fix SMP build error
2011-06-20msm: timer: Fix DGT rate on 8960 and 8660Stephen Boyd
The DGT runs at 27 MHz divided by 4 on 8660 and 8960. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2011-06-20Merge branch 'stable/bug.fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/setup: Fix for incorrect xen_extra_mem_start. xen: When calling power_off, don't call the halt function. xen: Fix compile warning when CONFIG_SMP is not defined. xen: support CONFIG_MAXSMP xen: partially revert "xen: set max_pfn_mapped to the last pfn mapped"
2011-06-20Merge branch 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: Fix register corruption in pvclock_scale_delta KVM: MMU: fix opposite condition in mapping_level_dirty_bitmap KVM: VMX: do not overwrite uptodate vcpu->arch.cr3 on KVM_SET_SREGS KVM: MMU: Fix build warnings in walk_addr_generic()
2011-06-19KVM: Fix register corruption in pvclock_scale_deltaZachary Amsden
The 128-bit multiply in pvclock.h was missing an output constraint for EDX which caused a register corruption to appear. Thanks to Ulrich for diagnosing the EDX corruption and Avi for providing this fix. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-06-19KVM: MMU: fix opposite condition in mapping_level_dirty_bitmapSteve
The condition is opposite, it always maps huge page for the dirty tracked page Reported-by: Steve <stefan.bosak@gmail.com> Signed-off-by: Steve <stefan.bosak@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-06-19KVM: VMX: do not overwrite uptodate vcpu->arch.cr3 on KVM_SET_SREGSMarcelo Tosatti
Only decache guest CR3 value if vcpu->arch.cr3 is stale. Fixes loadvm with live guest. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Tested-by: Markus Schade <markus.schade@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-06-19KVM: MMU: Fix build warnings in walk_addr_generic()Borislav Petkov
On 3.0-rc1 I get In file included from arch/x86/kvm/mmu.c:2856: arch/x86/kvm/paging_tmpl.h: In function ‘paging32_walk_addr_generic’: arch/x86/kvm/paging_tmpl.h:124: warning: ‘ptep_user’ may be used uninitialized in this function In file included from arch/x86/kvm/mmu.c:2852: arch/x86/kvm/paging_tmpl.h: In function ‘paging64_walk_addr_generic’: arch/x86/kvm/paging_tmpl.h:124: warning: ‘ptep_user’ may be used uninitialized in this function caused by 6e2ca7d1802bf8ed9908435e34daa116662e7790. According to Takuya Yoshikawa, ptep_user won't be used uninitialized so shut up gcc. Cc: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Link: http://lkml.kernel.org/r/20110530094604.GC21833@liondog.tnic Signed-off-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-06-18x86, efi: Do not reserve boot services regions within reserved areasMaarten Lankhorst
Commit 916f676f8dc started reserving boot service code since some systems require you to keep that code around until SetVirtualAddressMap is called. However, in some cases those areas will overlap with reserved regions. The proper medium-term fix is to fix the bootloader to prevent the conflicts from occurring by moving the kernel to a better position, but the kernel should check for this possibility, and only reserve regions which can be reserved. Signed-off-by: Maarten Lankhorst <m.b.lankhorst@gmail.com> Link: http://lkml.kernel.org/r/4DF7A005.1050407@gmail.com Acked-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-17msm: timer: compensate for timer shift in msm_read_timer_countJeff Ohlstein
Some msm targets have timers whose lower bits are unreliable. So, we present our timers as lower frequency than they actually are, and ignore the bottom 5 bits on such targets. This compensation was erroneously removed from the msm_read_timer_count function, so restore it. This was broken by 94790ec25 "msm: timer: SMP timer support for msm". Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org>
2011-06-17Merge branches 'gpio/merge' and 'spi/merge' of ↵Linus Torvalds
git://git.secretlab.ca/git/linux-2.6 * 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6: gpio: add GPIOF_ values regardless on kconfig settings gpio: include linux/gpio.h where needed gpio/omap4: Fix missing interrupts during device wakeup due to IOPAD. * 'spi/merge' of git://git.secretlab.ca/git/linux-2.6: spi/bfin_spi: fix handling of default bits per word setting
2011-06-17Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP1: PM: register notifiers with generic clock ops even when !PM_RUNTIME omap: pandora: fix NAND support OMAP: PM: omap_device: fix device power domain callbacks OMAP: PM debug: fix section mismatch warnings
2011-06-16xen/setup: Fix for incorrect xen_extra_mem_start.Konrad Rzeszutek Wilk
The earlier attempts (24bdb0b62cc82120924762ae6bc85afc8c3f2b26) at fixing this problem caused other problems to surface (PV guests with no PCI passthrough would have SWIOTLB turned on - which meant 64MB of precious contingous DMA32 memory being eaten up per guest). The problem was: "on xen we add an extra memory region at the end of the e820, and on this particular machine this extra memory region would start below 4g and cross over the 4g boundary: [0xfee01000-0x192655000) Unfortunately e820_end_of_low_ram_pfn does not expect an e820 layout like that so it returns 4g, therefore initial_memory_mapping will map [0 - 0x100000000), that is a memory range that includes some reserved memory regions." The memory range was the IOAPIC regions, and with the 1-1 mapping turned on, it would map them as RAM, not as MMIO regions. This caused the hypervisor to complain. Fortunately this is experienced only under the initial domain so we guard for it. Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-16Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: sh: sh7724: Add USBHS DMAEngine support sh: ecovec: Add renesas_usbhs support sh, exec: remove redundant set_fs(USER_DS) drivers: sh: resume enabled clocks fix dmaengine: shdma: SH_DMAC_MAX_CHANNELS message fix sh: Fix up xchg/cmpxchg corruption with gUSA RB. sh: Remove compressed kernel libgcc dependency. sh: fix wrong icache/dcache address-array start addr in cache-debugfs.
2011-06-16Merge branch 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x: ARM: mach-shmobile: mackerel: tidyup usbhs driver settings ARM: mach-shmobile: Correct SCIF port types for SH7367. ARM: mach-shmobile: sh73a0 gic_arch_extn.irq_set_wake() fix ARM: mach-shmobile: Mackerel USB platform data update ARM: mach-shmobile: AG5EVM SDHI1 platform data update
2011-06-16gpio: include linux/gpio.h where neededRandy Dunlap
Some files use GPIOF_ macros but don't include the header file for them. These macros are being moved to <linux/gpio.h>, so add includes for <linux/gpio.h> where needed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-16sh: sh7724: Add USBHS DMAEngine supportKuninori Morimoto
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-16sh: ecovec: Add renesas_usbhs supportKuninori Morimoto
2011-06-15Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: footbridge: fix clock event support ARM: footbridge: fix debug macros ARM: initrd: disable initrds outside of memory ARM: extend Code: line by one 16-bit quantity for Thumb instructions ARM: 6955/1: cmpxchg syscall should data abort if page not write ARM: 6954/1: zImage: fix Thumb2 breakage ARM: 6953/1: DT: don't try to access physical address zero ARM: 6949/2: mach-u300: fix compilaton warning in IO accessors Revert "ARM: 6944/1: mm: allow ASID 0 to be allocated to tasks" Revert "ARM: 6943/1: mm: use TTBR1 instead of reserved context ID" davinci: make PCM platform devices static arm: davinci: Fix fallout from generic irq chip conversion ARM: 6894/1: mmci: trigger card detect IRQs on falling and rising edges ARM: 6952/1: fix lockdep warning of "unannotated irqs-off" ARM: 6951/1: include .bss in memory layout information ARM: 6948/1: Fix .size directives for __arm{7,9}tdmi_proc_info ARM: 6947/2: mach-u300: fix compilation error in timer ARM: 6946/1: vexpress: move v2m clock init to init_early ARM: mx51/sdma: Check the chip revision in run-time arm: mxs: include asm/processor.h for cpu_relax()
2011-06-15alpha: fix several security issuesDan Rosenberg
Fix several security issues in Alpha-specific syscalls. Untested, but mostly trivial. 1. Signedness issue in osf_getdomainname allows copying out-of-bounds kernel memory to userland. 2. Signedness issue in osf_sysinfo allows copying large amounts of kernel memory to userland. 3. Typo (?) in osf_getsysinfo bounds minimum instead of maximum copy size, allowing copying large amounts of kernel memory to userland. 4. Usage of user pointer in osf_wait4 while under KERNEL_DS allows privilege escalation via writing return value of sys_wait4 to kernel memory. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Matt Turner <mattst88@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15rtc: fix build warnings in defconfigsWanlong Gao
RTC_CLASS is changed to bool, so 'm' is invalid. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-15xen: When calling power_off, don't call the halt function.Tom Goetz
.. As it won't actually power off the machine. Reported-by: Sven Köhler <sven.koehler@gmail.com> Tested-by: Sven Köhler <sven.koehler@gmail.com> Signed-off-by: Tom Goetz <tom.goetz@virtualcomputer.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-15xen: support CONFIG_MAXSMPAndrew Jones
The MAXSMP config option requires CPUMASK_OFFSTACK, which in turn requires we init the memory for the maps while we bring up the cpus. MAXSMP also increases NR_CPUS to 4096. This increase in size exposed an issue in the argument construction for multicalls from xen_flush_tlb_others. The args should only need space for the actual number of cpus. Also in 2.6.39 it exposes a bootup problem. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8157a1d3>] set_cpu_sibling_map+0x123/0x30d ... Call Trace: [<ffffffff81039a3f>] ? xen_restore_fl_direct_reloc+0x4/0x4 [<ffffffff819dc4db>] xen_smp_prepare_cpus+0x36/0x135 .. CC: stable@kernel.org Signed-off-by: Andrew Jones <drjones@redhat.com> [v2: Updated to compile on 3.0] [v3: Updated to compile when CONFIG_SMP is not defined] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-15ARM: mach-shmobile: mackerel: tidyup usbhs driver settingsKuninori Morimoto
- usb0 pipe is same as default. own pipe config is not needed - usb1 lost get_id function Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14x86 idle: APM requires pm_idle/default_idle unconditionally when a moduleAndy Whitcroft
[ Also from Ben Hutchings <ben@decadent.org.uk> and Vitaliy Ivanov <vitalivanov@gmail.com> ] Commit 06ae40ce073d ("x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it") removed the export for pm_idle/default_idle unless the apm module was modularised and CONFIG_APM_CPU_IDLE was set. But the apm module uses pm_idle/default_idle unconditionally, CONFIG_APM_CPU_IDLE only affects the bios idle threshold. Adjust the export accordingly. [ Used #ifdef instead of #if defined() as it's shorter, and what both Ben and Vitaliy used.. Andy, you're out-voted ;) - Linus ] Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Andy Whitcroft <apw@canonical.com> Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-14Merge branch 'for-linus-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68k: use kernel processor defines for conditional optimizations m68knommu: create config options for CPU classes m68knommu: fix linker script exported name sections
2011-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6: avr32, exec: remove redundant set_fs(USER_DS) avr32: make intc_resume() return void to conform to syscore_ops avr32: add some more at91 to cpu.h definition avr32: set CONFIG_CC_OPTIMIZE_FOR_SIZE=y for all defconfigs avr32/at32ap: fix mapping of platform device id for USART avr32: fix use of non-existing portnr variable in at32_map_usart()
2011-06-14Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: Compare only lower 32 bits of framebuffer map offsets drm/i915: Don't leak in i915_gem_shmem_pread_slow() drm/radeon/kms: do bounds checking for 3D_LOAD_VBPNTR and bump array limit drm/radeon/kms: fix mac g5 quirk x86/uv/x2apic: update for change in pci bridge handling. alpha, drm: Remove obsolete Alpha support in MGA DRM code alpha/drm: Cleanup Alpha support in DRM generic code savage: remove unnecessary if statement drm/radeon: fix GUI idle IH debug statements drm/radeon/kms: check modes against max pixel clock drm: fix fbs in DRM_IOCTL_MODE_GETRESOURCES ioctl
2011-06-14Merge branch 'fixes-v3.0-rc3' into devel-fixesTony Lindgren
2011-06-14OMAP1: PM: register notifiers with generic clock ops even when !PM_RUNTIMEKevin Hilman
When runtime PM is disabled, device clocks need to be enabled on device add and disabled on device remove. This currently is not happening because in the !PM_RUNTIME case, no notifiers are registered for OMAP1 devices. Fix this by ensuring notifiers are registered, even in the !PM_RUNTIME case. Reported-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-06-14avr32, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-06-14avr32: make intc_resume() return void to conform to syscore_opsHans-Christian Egtvedt
This patch removes the unneeded, and now wrong, return 0 from intc_resume() and lets the function return void instead. This matches the resume callback in struct syscore_ops. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-06-14avr32: add some more at91 to cpu.h definitionNicolas Ferre
Somme common drivers will need those at91 cpu_is_xxx() definitions. Those definitions are already in Linus' tree so if we want to use them in common drivers, we will need them in AVR32 cpu.h file. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-06-14avr32: set CONFIG_CC_OPTIMIZE_FOR_SIZE=y for all defconfigsHans-Christian Egtvedt
This patch makes sure the kconfig option CC_OPTIMIZE_FOR_SIZE is set to yes for all default configuration files. This ensures the kernel is optimized for size, and avoids potential relocation truncated to fit problems. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-06-14avr32/at32ap: fix mapping of platform device id for USARTHans-Christian Egtvedt
This patch will fix the mapping of the platform device id when mapping USART peripheral ID to UART platform device id. Not setting the platform device id will in most cases (when you map USART > 0 to UART 0) make the console not available. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-06-14avr32: fix use of non-existing portnr variable in at32_map_usart()Hans-Christian Egtvedt
This patch fixes the use of the non-existing portnr variable in at32_map_usart() to use the provided line number instead. Typo was introduced in commit 2b348e2f82f532e3aff8e0ce9293033b3294c1e0. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-06-14sh, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh-fixes-for-linus
2011-06-14ARM: mach-shmobile: Correct SCIF port types for SH7367.Paul Mundt
While SH7377 and others were updated to properly use SCIFA/B port types, SH7367 was left behind. Fix it up accordingly. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14ARM: mach-shmobile: sh73a0 gic_arch_extn.irq_set_wake() fixMagnus Damm
Initialize ->irq_set_wake() in gic_arch_extn to unbreak wake up from the KEYSC device on AG5EVM in case of Suspend-to-RAM. Without this patch "echo mem > /sys/power/state" and a key press results in the following message on resume: WARNING: at kernel/irq/manage.c:507 irq_set_irq_wake+0x7c/0xd8() Unbalanced IRQ 103 wake disable Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14ARM: mach-shmobile: Mackerel USB platform data updateMagnus Damm
This patch updates the board specific USB support code for the sh7372 Mackerel board. With this patch applied port CN22 is driven by the recently added renesas_usbhs driver using the first USB controller included in sh7372 aka USBHS0. Hotplugging of USBHS0 unfortunately has to be handled by software polling. The sh7372 SoC itself obviously supports hotplug notification by IRQ but on the Mackerel board this IRQ happens to be used for the touch screen. Also fix the pinmux configuration to avoid setting up unused pins and fix minor spelling errors. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14ARM: mach-shmobile: AG5EVM SDHI1 platform data updateMagnus Damm
Add a flag for SDHI1 to enable SDIO IRQ, and remove DMA Engine slave id:s to disable DMA as a workaround. Tested on sh73a0/AG5EVM with a BCM4318-based SDIO card. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-14m68k: use kernel processor defines for conditional optimizationsGreg Ungerer
Older m68k-linux compilers will include pre-defined symbols that confuse what processor it is being targeted for. For example gcc-4.1.2 will pre-define __mc68020__ even if you specify the target processor as -m68000 on the gcc command line. Newer versions of gcc have this corrected. In a few places the m68k code uses defined(__mc68020__) for optimizations that include instructions that are specific to the CPU 68020 and above. When compiling with older compilers this will be true even when we have selected to compile for the older 68000 processors. Switch to using the kernel processor defines, CONFIG_M68020 and friends. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14m68knommu: create config options for CPU classesGreg Ungerer
There are 3 families of CPU core types that we support in the m68knommu architecture branch. They are . traditional 68000 . CPU32 (a 68020 core derivative without MMU or bitfield instructions) . ColdFire It will be useful going forward to have a CONFIG_ option defined for each type. We already have one for ColdFire (CONFIG_COLDFIRE), so add for the other 2 families, CONFIG_M68000 and CONFIG_MCPU32. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14m68knommu: fix linker script exported name sectionsGreg Ungerer
The recent commit titled "module: Sort exported symbols" (f02e8a65) changed the exported symbol name sections. Bring the m68knommu linker script into line with those changes - including the sorting of the symbol names. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14x86/uv/x2apic: update for change in pci bridge handling.Dave Airlie
When I added 3448a19da479b6bd1e28e2a2be9fa16c6a6feb39 I forgot about the special uv handling code for this, so this patch fixes it up. Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Ingo Molnar Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-13Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ftrace: Revert 8ab2b7efd ftrace: Remove unnecessary disabling of irqs kprobes/trace: Fix kprobe selftest for gcc 4.6 ftrace: Fix possible undefined return code oprofile, dcookies: Fix possible circular locking dependency oprofile: Fix locking dependency in sync_start() oprofile: Free potentially owned tasks in case of errors oprofile, x86: Add comments to IBS LVT offset initialization
