arch/arm/mach-versatile/core.c
The ISA IRQ renumbering broke the Viper ISA code in interesting ways.
It originally assumed that ISA interrupt were numbered in the order that
is defined by the CPLD registers. Unfortunately, this is no longer the
case.
Furthermore, the viper_irq_handler() function being a chained IRQ
handler, it must ACK the interrupt by itself, or the handler will be
immediately reentered, with the expected damages.
This fix was made possible thanks to the help of David Raeman, who
provided debug information and tested each version of this patch.
Tested-by: David Raeman <david.raeman@gmail.com>
Signed-off-by: Marc Zyngier <maz@misterjones.org>
Acked-by: Eric Miao <eric.miao@marvell.com>
Fix build for CM-X2XX with CONFIG_RTC_DRV_V3020 unset:
CC arch/arm/mach-pxa/cm-x270.o
/mnt/sdb1/git/linux-2.6-arm/arch/arm/mach-pxa/cm-x270.c: In function 'cmx270_init':
/mnt/sdb1/git/linux-2.6-arm/arch/arm/mach-pxa/cm-x270.c:338: error: implicit declaration of function 'cmx270_init_rtc'
make[2]: *** [arch/arm/mach-pxa/cm-x270.o] Error 1
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
arch/arm/mach-omap2/gpmc.c
arch/arm/mach-omap2/irq.c
With the upcoming WDT patches OMAP_WDT_BASE is no longer needed
in devices.c. Revert some earlier omap3 changes to avoid merge
conflicts with the WDT patches.
Recent McBSP patches changed to allocating devices dynamically
and the check for OMAP_MAX_MCBSP_COUNT became unnecessary.
The check for OMAP_MAX_MCBSP_COUNT should have been removed with
the earlier McBSP patches in devices.c but was accidentally left
out.
Some McBSP irq defines were missing that should have been added
with the earlier McBSP patches.
Add the missing McBSP irqs, and a few other missing irqs as
defined in linux-omap tree. Also add a blank line to separate
irq defines from the irq line calculations.
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (66 commits)
ata: Add documentation for hard disk shock protection interface (v3)
ide: Implement disk shock protection support (v4)
ide-cd: fix printk format warning
piix: add Hercules EC-900 mini-notebook to ich_laptop short cable list
ide-atapi: assign taskfile flags per device type
ide-cd: move cdrom_info.dma to ide_drive_t.dma
ide: add ide_drive_t.dma flag
ide-cd: add a debug_mask module parameter
ide-cd: convert driver to new ide debugging macro (v3)
ide: move SFF DMA code to ide-dma-sff.c
ide: cleanup ide-dma.c
ide: cleanup ide_build_dmatable()
ide: remove needless includes from ide-dma.c
ide: switch to DMA-mapping API part #2
ide: make ide_dma_timeout() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n
ide: make ide_dma_lost_irq() available also for CONFIG_BLK_DEV_IDEDMA_SFF=n
ide: __ide_dma_end() -> ide_dma_end()
pmac: remove needless pmac_ide_destroy_dmatable() wrapper
pmac: remove superfluous pmif == NULL checks
ide: Two fixes regarding memory allocation
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (313 commits)
V4L/DVB (9186): Added support for Prof 7300 DVB-S/S2 cards
V4L/DVB (9185): S2API: Ensure we have a reasonable ROLLOFF default
V4L/DVB (9184): cx24116: Change the default SNR units back to percentage by default.
V4L/DVB (9183): S2API: Return error of the caller provides 0 commands.
V4L/DVB (9182): S2API: Added support for DTV_HIERARCHY
V4L/DVB (9181): S2API: Add support fot DTV_GUARD_INTERVAL and DTV_TRANSMISSION_MODE
V4L/DVB (9180): S2API: Added support for DTV_CODE_RATE_HP/LP
V4L/DVB (9179): S2API: frontend.h cleanup
V4L/DVB (9178): cx24116: Add module parameter to return SNR as ESNO.
V4L/DVB (9177): S2API: Change _8PSK / _16APSK to PSK_8 and APSK_16
V4L/DVB (9176): Add support for DvbWorld USB cards with STV0288 demodulator.
V4L/DVB (9175): Remove NULL pointer in stb6000 driver.
V4L/DVB (9174): Allow custom inittab for ST STV0288 demodulator.
V4L/DVB (9173): S2API: Remove the hardcoded command limit during validation
V4L/DVB (9172): S2API: Bugfix related to DVB-S / DVB-S2 tuning for the legacy API.
V4L/DVB (9171): S2API: Stop an OOPS if illegal commands are dumped in S2API.
V4L/DVB (9170): cx24116: Sanity checking to data input via S2API to the cx24116 demod.
V4L/DVB (9169): uvcvideo: Support two new Bison Electronics webcams.
V4L/DVB (9168): Add support for MSI TV@nywhere Plus remote
V4L/DVB: v4l2-dev: remove duplicated #include
There is now a generic solution [ide_generic_check_pci_legacy_iobases()]
so MIPS-specific ide_probe_legacy() is no longer necessary.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
I don't know why this was there, but it was dead code.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: chris@zankel.net
This is a much better version of a previous patch to make the parser
tables constant. Rather than changing the typedef, we put the "const" in
all the various places where its required, allowing the __initconst
exception for nfsroot which was the cause of the previous trouble.
This was posted for review some time ago and I believe its been in -mm
since then.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: Alexander Viro <aviro@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: (60 commits)
Blackfin arch: make sure we include the fix for SPORT hysteresis when reprogramming clocks
Blackfin arch: Fix bogus str_ident check in gpio code
Blackfin arch: AD7879 Touchscreen driver
Blackfin arch: introducing bfin_addr_dcachable
Blackfin arch: fix a typo in comments
Blackfin arch: Remove useless head file
Blackfin arch: make sure L2 start and length are always defined (fixes building on BF542)
Blackfin arch: use the Blackfin on-chip ROM to do software reset when possible
Blackfin arch: update anomaly headers to match the latest sheet
Blackfin arch: bfin_reset() is an internal reboot function ... everyone should go through machine_restart()
Blackfin arch: print out error/warning if you are running on the incorrect CPU type
Blackfin arch: remove non-bf54x ifdef logic since this file is only compiled on bf54x parts
Blackfin arch: update board defconfigs
Blackfin arch: Add optional verbose debug
Blackfin arch: emulate a TTY over the EMUDAT/JTAG interface
Blackfin arch: have is_user_addr_valid() check for overflows (like when address is -1)
Blackfin arch: ptrace - fix off-by-one check on end of memory regions
Blackfin arch: Enable framebuffer support for the BF526-EZkit TFT LCD display
Blackfin arch: flash memory map and dm9000 resources updating
Blackfin arch: early prink code still use uart core console functions to parse and set configure option string
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
chmc: Mark %ver register inline asm with __volatile__
sparc64: Add missing notify_cpu_starting() call.
sparc32: fix build errors
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc
* 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc:
proc: remove kernel.maps_protect
proc: remove now unneeded ADDBUF macro
[PATCH] proc: show personality via /proc/pid/personality
[PATCH] signal, procfs: some lock_task_sighand() users do not need rcu_read_lock()
proc: move PROC_PAGE_MONITOR to fs/proc/Kconfig
proc: make grab_header() static
proc: remove unused get_dma_list()
proc: remove dummy vmcore_open()
proc: proc_sys_root tweak
proc: fix return value of proc_reg_open() in "too late" case
Fixed up trivial conflict in removed file arch/sparc/include/asm/dma_32.h
* git://git.infradead.org/users/dwmw2/random-2.6:
Fix autoloading of MacBook Pro backlight driver.
Automatic MODULE_ALIAS() for DMI match tables.
Remove asm/a.out.h files for all architectures without a.out support.
Introduce HAVE_AOUT symbol to remove hard-coded arch list for BINFMT_AOUT
Remove redundant CONFIG_ARCH_SUPPORTS_AOUT
S390: Update comments about why we don't use <asm-generic/statfs.h>
SPARC: Use <asm-generic/statfs.h>
PowerPC: Use <asm-generic/statfs.h>
PARISC: Use <asm-generic/statfs.h>
x86_64: Use <asm-generic/statfs.h>
IA64: Use <asm-generic/statfs.h>
ARM: Use <asm-generic/statfs.h>
Make <asm-generic/statfs.h> suitable for 64-bit platforms.
Define and use PCI_DEVICE_ID_MARVELL_88ALP01_CCIC for CAFÉ camera driver
[MTD] [NAND] Define and use PCI_DEVICE_ID_MARVELL_88ALP01_NAND for CAFÉ
Use PCI_DEVICE_ID_88ALP01 for CAFÉ chip, rather than PCI_DEVICE_ID_CAFE.
EFS: Don't set f_fsid in statfs().
Merges oprofile, timers/hpet, x86/traps, x86/time, and x86/core misc items.
* 'x86-core-v4-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (132 commits)
x86: change early_ioremap to use slots instead of nesting
x86: adjust dependencies for CONFIG_X86_CMOV
dumpstack: x86: various small unification steps, fix
x86: remove additional_cpus
x86: remove additional_cpus configurability
x86: improve UP kernel when CPU-hotplug and SMP is enabled
dumpstack: i386: make kstack= an early boot-param and add oops=panic
dumpstack: x86: use log_lvl and unify trace formatting
dumptrace: x86: consistently include loglevel, print stack switch
dumpstack: x86: add "end" parameter to valid_stack_ptr and print_context_stack
dumpstack: x86: make printk_address equal
dumpstack: x86: move die_nmi to dumpstack_32.c
traps: x86: finalize unification of traps.c
traps: x86: make traps_32.c and traps_64.c equal
traps: x86: various noop-changes preparing for unification of traps_xx.c
traps: x86_64: use task_pid_nr(tsk) instead of tsk->pid in do_general_protection
traps: i386: expand clear_mem_error and remove from mach_traps.h
traps: x86_64: make io_check_error equal to the one on i386
traps: i386: use preempt_conditional_sti/cli in do_int3
Signed-off-by: Alan Cox <alan@redhat.com>
This requires three changes:
1) Remove !SPARC restriction in Kconfig.
2) Move Sparc specific serial drivers before 8250, so that serial
console devices don't change names on us, even if 8250 finds
devices.
3) Since the Sparc specific serial drivers try to use the
same major/minor device namespace as 8250, some coordination
is necessary. Use the sunserial_*() layer routines to allocate
minor number space within TTY_MAJOR when CONFIG_SPARC.
This has no effect on other platforms.
Thanks to Josip Rodin for bringing up this issue and testing
plus debugging various revisions of this patch.
interrupts in PIO mode
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
We now use the sir_dev/irtty_sir/uart/bfin_serial drivers framework
to monitor the TX status.
Signed-off-by: Graf Yang <graf.yang@analog.com>
the serial driver
move common variables out of serial headers and into the serial driver and
rename "nr_ports" to "nr_active_ports" so as to easily differentiate
between BFIN_UART_NR_PORTS (the # of available) and nr_ports (the # of enabled)
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
include/asm-x86/statfs.h
arch/x86/kernel/apic_32.c
arch/x86/oprofile/nmi_int.c
include/linux/pci_ids.h
so we could remove the requirement that one needs to call
early_iounmap() in exactly reverse order of early_ioremap().
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
After "dumpstack: x86: various small unification steps", the
assembler gives the following compile error. The error is in
dumpstack_64.c.
{standard input}: Assembler messages:
{standard input}:720: Error: Incorrect register `%rbx' used with `l' suffix
{standard input}:1340: Error: Incorrect register `%r12' used with `l' suffix
Indeed the suffix in get_bp() was wrong.
Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm>
remove remainder of additional_cpus logic. We now just listen to the
disabled_cpus value like we did for years. disabled_cpus is always >=
0 so no need for an extra check.
additional_cpus=<x> parameter is dangerous and broken: for example
if we boot additional_cpus=-2 on a stock dual-core system it will
crash the box on bootup.
So reduce the maze of code a bit by removingthe user-configurability
angle.
num_possible_cpus() can be > 1 when disabled CPUs have been accounted.
Disabled CPUs are not in the cpu_present_map, so we can use
num_present_cpus() as a safe indicator to switch to UP alternatives.
Reported-by: Chuck Ebbert <cebbert@redhat.com>
Cc: <stable@kernel.org>
- define STACKSLOTS_PER_LINE and use it
- define get_bp macro to hide the %%ebp/%%rbp difference
- i386: check task==NULL in dump_trace, like x86_64
- i386: show_trace(NULL, ...) uses current automatically
- x86_64: use [#%d] for die_counter, like i386
- whitespace and comments
- make kstack= and early_param
- add oops=panic, setting panic_on_oops
- x86: Write log_lvl strings if available
- start raw stack dumps on new line
- i386: Remove extra indentation for raw stack dumps
- i386 and x86_64: always printk the 'data' parameter
- i386: announce stack switch (irq -> normal)
- i386: check if there is a stack switch before announcing it
There is a warning that 'context' might come out corrupt in early
boot. If this is true it should be fixed, not worked around.
- Add "end" parameter to valid_stack_ptr and print_context_stack
- use sizeof(long) as the size of a word on the stack
- x86_64: use %p to print an address
- make i386-version the same as the above
The result should be the same on x86_64; on i386 the
output only changes if CONFIG_KALLSYMS is turned off,
in which case the address is printed twice.
For some reason die_nmi is still defined in traps.c for
i386, but is found in dumpstack_64.c for x86_64. Move it
to dumpstack_32.c
traps_32.c and traps_64.c are now equal. Move one to traps.c,
delete the other one and change the Makefile
Use CONFIG_X86_64/CONFIG_X86_32 to condtionally compile the
parts needed for x86_64 or i386 only.
Runs a small userspace for a number of minimal configurations
and boots the defconfigs.
- reordering include files
- whitespace changes
- comment changes
- removed unused bad_intr()
- make default_do_nmi static
Use task_pid_nr(tsk) instead of tsk->pid in do_general_protection.
This is the last user of clear_mem_error, which is defined
only on i386. Expand the inline function and remove it from
include/asm-x86/mach-default/mach_traps.h
Make io_check_error equal to the one on i386.
Use preempt_conditional_sti/cli in do_int3, like on x86_64.
- rename variable me -> tsk
- get thread and tsk like i386
- expand used_math()
- copy comment
- set_system_gate on i386 is really set_system_trap_gate
- set_system_gate on x86_64 is really set_system_intr_gate
- ist=0 means no special stack switch is done:
- introduce STACKFAULT_STACK, DOUBLEFAULT_STACK, NMI_STACK,
DEBUG_STACK and MCE_STACK as on x86_64.
- use the _ist variants with XXX_STACK set to zero
- remove set_system_gate
traps: x86: correct copy/paste bug: a trap is a GATE_TRAP
Fix copy/paste/forgot-to-edit bug in desc.h.
Make the x86_64-version and the i386-version of do_debug
more similar.
- introduce preempt_conditional_sti/cli to i386. The preempt-count
is now elevated during the trap handler, like on x86_64. It
does not run on a separate stack, however.
- replace an open-coded "send_sigtrap"
- copy some comments
Mark the exception handlers with "dotraplinkage" to hide the
calling convention differences between i386 and x86_64.
