path: root/arch
2008-07-15Merge branch 'timers/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: add PCI ID for 6300ESB force hpet x86: add another PCI ID for ICH6 force-hpet kernel-paramaters: document pmtmr= command line option acpi_pm clccksource: fix printk format warning nohz: don't stop idle tick if softirqs are pending. pmtmr: allow command line override of ioport nohz: reduce jiffies polling overhead hrtimer: Remove unused variables in ktime_divns() hrtimer: remove warning in hres_timers_resume posix-timers: print RT watchdog message
2008-07-15Merge branch 'genirq' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'genirq' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: remove extraneous checks in manage.c genirq: Expose default irq affinity mask (take 3)
2008-07-15Merge branch 'core/stacktrace' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/stacktrace' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: generic-ipi: powerpc/generic-ipi tree build failure stacktrace: fix build failure on sparc64 stacktrace: export save_stack_trace[_tsk] stacktrace: fix modular build, export print_stack_trace and save_stack_trace backtrace: replace timer with tasklet + completions stacktrace: add saved stack traces to backtrace self-test stacktrace: print_stack_trace() cleanup debugging: make stacktrace independent from DEBUG_KERNEL stacktrace: don't crash on invalid stack trace structs
2008-07-15x86: sanitize KconfigThomas Gleixner
Set default n for MEMTEST and MTRR_SANITIZER and fix the help texts. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-15Merge branch 'linus' into x86/urgentIngo Molnar
2008-07-14Merge branch 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6Linus Torvalds
* 'for-2.6.27' of git://git.infradead.org/users/dwmw2/firmware-2.6: (64 commits) firmware: convert sb16_csp driver to use firmware loader exclusively dsp56k: use request_firmware edgeport-ti: use request_firmware() edgeport: use request_firmware() vicam: use request_firmware() dabusb: use request_firmware() cpia2: use request_firmware() ip2: use request_firmware() firmware: convert Ambassador ATM driver to request_firmware() whiteheat: use request_firmware() ti_usb_3410_5052: use request_firmware() emi62: use request_firmware() emi26: use request_firmware() keyspan_pda: use request_firmware() keyspan: use request_firmware() ttusb-budget: use request_firmware() kaweth: use request_firmware() smctr: use request_firmware() firmware: convert ymfpci driver to use firmware loader exclusively firmware: convert maestro3 driver to use firmware loader exclusively ... Fix up trivial conflicts with BKL removal in drivers/char/dsp56k.c and drivers/char/ip2/ip2main.c manually.
2008-07-14Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (241 commits) [ARM] 5171/1: ep93xx: fix compilation of modules using clocks [ARM] 5133/2: at91sam9g20 defconfig file [ARM] 5130/4: Support for the at91sam9g20 [ARM] 5160/1: IOP3XX: gpio/gpiolib support [ARM] at91: Fix NAND FLASH timings for at91sam9x evaluation kits. [ARM] 5084/1: zylonite: Register AC97 device [ARM] 5085/2: PXA: Move AC97 over to the new central device declaration model [ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC drivers [ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin setting [ARM] 5145/1: PXA2xx: provide api to control IrDA pins state [ARM] 5144/1: pxaficp_ir: cleanup includes [ARM] pxa: remove pxa_set_cken() [ARM] pxa: allow clk aliases [ARM] Feroceon: don't disable BPU on boot [ARM] Orion: LED support for HP mv2120 [ARM] Orion: add RD88F5181L-FXO support [ARM] Orion: add RD88F5181L-GE support [ARM] Orion: add Netgear WNR854T support [ARM] s3c2410_defconfig: update for current build [ARM] Acer n30: Minor style and indentation fixes. ...
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
Conflicts: sound/pci/Kconfig
2008-07-14[ARM] Merge most of the PXA work for initial mergeRussell King
This includes PXA work up to the SPI changes for the initial merge, since e172274ccc55d20536fbdceb6131f38e288541e0 depends on the SPI tree being merged. Conflicts: arch/arm/configs/em_x270_defconfig arch/arm/configs/xm_x270_defconfig
2008-07-14Merge branch 'core/rodata' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/rodata' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: move BUG_TABLE into RODATA
2008-07-14Merge branch 'core/printk' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/printk' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, generic: mark early_printk as asmlinkage printk: export console_drivers printk: remember the message level for multi-line output printk: refactor processing of line severity tokens printk: don't prefer unsuited consoles on registration printk: clean up recursion check related static variables namespacecheck: more kernel/printk.c fixes namespacecheck: fix kernel printk.c
2008-07-14x86: MMIOTRACE should not default to onLinus Torvalds
Even the help-text makes it clear that normal people shouldn't enable it. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14Merge branch 'tracing/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (228 commits) ftrace: build fix for ftraced_suspend ftrace: separate out the function enabled variable ftrace: add ftrace_kill_atomic ftrace: use current CPU for function startup ftrace: start wakeup tracing after setting function tracer ftrace: check proper config for preempt type ftrace: trace schedule ftrace: define function trace nop ftrace: move sched_switch enable after markers ftrace: prevent ftrace modifications while being kprobe'd, v2 fix "ftrace: store mcount address in rec->ip" mmiotrace broken in linux-next (8-bit writes only) ftrace: avoid modifying kprobe'd records ftrace: freeze kprobe'd records kprobes: enable clean usage of get_kprobe ftrace: store mcount address in rec->ip ftrace: build fix with gcc 4.3 namespacecheck: fixes ftrace: fix "notrace" filtering priority ftrace: fix printout ...
2008-07-14Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: (146 commits) IB/umad: BKL is not needed for ib_umad_open() IB/uverbs: BKL is not needed for ib_uverbs_open() bf561-coreb: BKL unneeded for open() Call fasync() functions without the BKL snd/PCM: fasync BKL pushdown ipmi: fasync BKL pushdown ecryptfs: fasync BKL pushdown Bluetooth VHCI: fasync BKL pushdown tty_io: fasync BKL pushdown tun: fasync BKL pushdown i2o: fasync BKL pushdown mpt: fasync BKL pushdown Remove BKL from remote_llseek v2 Make FAT users happier by not deadlocking x86-mce: BKL pushdown vmwatchdog: BKL pushdown vmcp: BKL pushdown via-pmu: BKL pushdown uml-random: BKL pushdown uml-mmapper: BKL pushdown ...
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-14Merge branch 'x86/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (821 commits) x86: make 64bit hpet_set_mapping to use ioremap too, v2 x86: get x86_phys_bits early x86: max_low_pfn_mapped fix #4 x86: change _node_to_cpumask_ptr to return const ptr x86: I/O APIC: remove an IRQ2-mask hack x86: fix numaq_tsc_disable calling x86, e820: remove end_user_pfn x86: max_low_pfn_mapped fix, #3 x86: max_low_pfn_mapped fix, #2 x86: max_low_pfn_mapped fix, #1 x86_64: fix delayed signals x86: remove conflicting nx6325 and nx6125 quirks x86: Recover timer_ack lost in the merge of the NMI watchdog x86: I/O APIC: Never configure IRQ2 x86: L-APIC: Always fully configure IRQ0 x86: L-APIC: Set IRQ0 as edge-triggered x86: merge dwarf2 headers x86: use AS_CFI instead of UNWIND_INFO x86: use ignore macro instead of hash comment x86: use matching CFI_ENDPROC ...
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (50 commits) crypto: ixp4xx - Select CRYPTO_AUTHENC crypto: s390 - Respect STFL bit crypto: talitos - Add support for sha256 and md5 variants crypto: hash - Move ahash functions into crypto/hash.h crypto: crc32c - Add ahash implementation crypto: hash - Added scatter list walking helper crypto: prng - Deterministic CPRNG crypto: hash - Removed vestigial ahash fields crypto: hash - Fixed digest size check crypto: rmd - sparse annotations crypto: rmd128 - sparse annotations crypto: camellia - Use kernel-provided bitops, unaligned access helpers crypto: talitos - Use proper form for algorithm driver names crypto: talitos - Add support for 3des crypto: padlock - Make module loading quieter when hardware isn't available crypto: tcrpyt - Remove unnecessary kmap/kunmap calls crypto: ixp4xx - Hardware crypto support for IXP4xx CPUs crypto: talitos - Freescale integrated security engine (SEC) driver [CRYPTO] tcrypt: Add self test for des3_ebe cipher operating in cbc mode [CRYPTO] rmd: Use pointer form of endian swapping operations ...
2008-07-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hskinnemoen/avr32-2.6: (31 commits) avr32: Fix typo of IFSR in a comment in the PIO header file avr32: Power Management support ("standby" and "mem" modes) avr32: Add system device for the internal interrupt controller (intc) avr32: Add simple SRAM allocator avr32: Enable SDRAMC clock at startup rtc-at32ap700x: Enable wakeup macb: Basic suspend/resume support atmel_serial: Drain console TX shifter before suspending atmel_serial: Fix build on avr32 with CONFIG_PM enabled avr32: Use a quicklist for PTE allocation as well avr32: Use a quicklist for PGD allocation avr32: Cover the kernel page tables in the user PGDs avr32: Store virtual addresses in the PGD avr32: Remove useless zeroing of swapper_pg_dir at startup avr32: Clean up and optimize the TLB operations avr32: Rename at32ap.c -> pdc.c avr32: Move setup_platform() into chip-specific file avr32: Kill special exception handler sections avr32: Kill unneeded #include <asm/pgalloc.h> from asm/mmu_context.h avr32: Clean up time.c #includes ...
2008-07-14Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (71 commits) [S390] sclp_tty: Fix scheduling while atomic bug. [S390] sclp_tty: remove ioctl interface. [S390] Remove P390 support. [S390] Cleanup vmcp printk messages. [S390] Cleanup lcs printk messages. [S390] Cleanup kprobes printk messages. [S390] Cleanup vmwatch printk messages. [S390] Cleanup dcssblk printk messages. [S390] Cleanup zfcp dumper printk messages. [S390] Cleanup vmlogrdr printk messages. [S390] Cleanup s390 debug feature print messages. [S390] Cleanup monreader printk messages. [S390] Cleanup appldata printk messages. [S390] Cleanup smsgiucv printk messages. [S390] Cleanup cpacf printk messages. [S390] Cleanup qeth print messages. [S390] Cleanup netiucv printk messages. [S390] Cleanup iucv printk messages. [S390] Cleanup sclp printk messages. [S390] Cleanup zcrypt printk messages. ...
2008-07-14Start using the new '%pS' infrastructure to print symbolsLinus Torvalds
This simplifies the code significantly, and was the whole point of the exercise. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14x86, suspend, acpi: correct and add comments about Big Real ModeH. Peter Anvin
Explain that we set up the descriptors for Big Real Mode, and why we do so. In particular, one system that is known to fail without it is the Lenovo X61. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-07-14x86, suspend, acpi: enter Big Real ModeH. Peter Anvin
The explanation for recent video BIOS suspend quirk failures is that the VESA BIOS expects to be entered in Big Real Mode (*.limit = 0xffffffff) instead of ordinary Real Mode (*.limit = 0xffff). This patch changes the segment descriptors to Big Real Mode instead. The segment descriptor registers (what Intel calls "segment cache") is always active. The only thing that changes based on CR0.PE is how it is *loaded* and the interpretation of the CS flags. The segment descriptor registers contain of the following sub-registers: selector (the "visible" part), base, limit and flags. In protected mode or long mode, they are loaded from descriptors (or fs.base or gs.base can be manipulated directly in long mode.) In real mode, the only thing changed by a segment register load is the selector and the base, where the base <- selector << 4. In particular, *the limit and the flags are not changed*. As far as the handling of the CS flags: a code segment cannot be writable in protected mode, whereas it is "just another segment" in real mode, so there is some kind of quirk that kicks in for this when CR0.PE <- 0. I'm not sure if this is accomplished by actually changing the cs.flags register or just changing the interpretation; it might be something that is CPU-specific. In particular, the Transmeta CPUs had an explicit "CS is writable if you're in real mode" override, so even if you had loaded CS with an execute-only segment it'd be writable (but not readable!) on return to real mode. I'm not at all sure if that is how other CPUs behave. Signed-off-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14generic-ipi: powerpc/generic-ipi tree build failureStephen Rothwell
Today's linux-next build (powerpc allmodconfig) failed like this: ERROR: ".save_stack_trace" [tests/backtracetest.ko] undefined! But save_stack_trace is exported in arch/powerpc/kernel/stacktrace.c I couldn't figure it out until I noticed these earlier warnings: arch/powerpc/kernel/stacktrace.c:47: warning: data definition has no type or storage class arch/powerpc/kernel/stacktrace.c:47: warning: type defaults to 'int' in declaration of 'EXPORT_SYMBOL_GPL' arch/powerpc/kernel/stacktrace.c:47: warning: parameter names (without types) in function declaration I applied the patch below. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linuxppc-dev@ozlabs.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14x86: add PCI ID for 6300ESB force hpetJoe Buehler
00:1f.0 ISA bridge: Intel Corporation 6300ESB LPC Interface Controller (rev 02) 00:1f.0 Class 0601: 8086:25a1 (rev 02) kernel: pci 0000:00:1f.0: Force enabled HPET at 0xfed00000 kernel: hpet clockevent registered kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 kernel: hpet0: 3 64-bit timers, 14318180 Hz Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-14x86: add another PCI ID for ICH6 force-hpetKrzysztof Oledzki
Tested on Asus P5GDC-V $ lspci -n -n |grep ISA 00:1f.0 ISA bridge [0601]: Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge [8086:2640] (rev 03) Force enabled HPET at base address 0xfed00000 hpet clockevent registered hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 hpet0: 3 64-bit timers, 14318180 Hz Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-07-14Merge branch 'auto-ftrace-next' into tracing/for-linusIngo Molnar
Conflicts: arch/x86/kernel/entry_32.S arch/x86/kernel/process_32.c arch/x86/kernel/process_64.c arch/x86/lib/Makefile include/asm-x86/irqflags.h kernel/Makefile kernel/sched.c Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14[S390] Remove P390 support.Heiko Carstens
Most likely it is broken anyway because of the changes in memory detection. Since we can't test it and there are probably better ways that using a P390 card, remove support for it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] Cleanup kprobes printk messages.Martin Schwidefsky
Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] Cleanup s390 debug feature print messages.Michael Holzheu
Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] Cleanup appldata printk messages.Gerald Schaefer
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] Cleanup cpacf printk messages.Jan Glauber
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] Cleanup vtime printk messages.Martin Schwidefsky
2008-07-14[S390] Move memory detection code to own file.Heiko Carstens
Move memory detection code to own file and also simplify it. Also add an interface which can be called at any time to get the current memory layout. This interface is needed by our kernel internal system dumper. Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Cc: Michael Holzheu <holzheu@de.ibm.com> Cc: Frank Munzert <munzert@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] Add support for memory hot-add.Heiko Carstens
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] s390: use memory_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] s390: use simple_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] arch/s390: Eliminate NULL test and memset after alloc_bootmemJulia Lawall
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b, alloc_bootmem and related functions never return NULL and always return a zeroed region of memory. Thus a NULL test or memset after calls to these functions is unnecessary. arch/s390/kernel/topology.c | 2 -- 1 file changed, 2 deletions(-) This was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression E; statement S; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) ... when != E ( - BUG_ON (E == NULL); | - if (E == NULL) S ) @@ expression E,E1; @@ E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...) ... when != E - memset(E,0,E1); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] Extra Kernel Parameters via VMPARMHendrik Brueckner
Now it is possible to specify additional kernel parameters on the IPL command line using the IPL PARM option. If the Linux system is already running, the new reipl sysfs attribute 'parm' can be used to change kernel parameters for the next reboot. Examples: IPL C PARM dasd=1234 root=/dev/dasda1 IPL 1234 PARM savesys=mylnxnss echo "init=/bin/bash" > /sys/firmware/reipl/ccw/parm Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] idle: remove idle notifier chain.Heiko Carstens
The idle notifier chain consists of at most one element. So there's no point in having a notifier chain. Remove it and directly call the function. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] cio: Add chsc subchannel driver.Cornelia Huck
This patch adds a driver for subchannels of type chsc. A device /dev/chsc is created which may be used to issue ioctls to: - obtain information about the machine's I/O configuration - dynamically change the machine's I/O configuration via asynchronous chsc commands Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] stp support.Martin Schwidefsky
Add support for clock synchronization with the server time protocol. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] initrd vs bss section clearing.Heiko Carstens
In case the initrd is located within the bss section it will be overwritten when the section is cleared. To prevent this just move the initrd right behind the bss section if it starts within the section. The current code already moves the initrd if the bootmem allocator bitmap would overwrite it. With this patch we should be safe against initrd corruptions. Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] Introduce user_regset accessors for s390Martin Schwidefsky
Add the user_regset definitions for normal and compat processes, replace the dump_regs core dump cruft with the generic CORE_DUMP_USER_REGSET and replace binfmt_elf32.c with the generic compat_binfmt_elf.c implementation. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14[S390] Remove ipldelay kernel parameter.Heiko Carstens
Using the ipldelay kernel parameter leads to a crash at IPL time. Since this is broken since a long time it looks like nobody is using it anymore. So remove it instead of fixing it. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-07-14[S390] make appldata compile w/o CONFIG_SWAPGerald Schaefer
Avoid compile error by using EXPORT_SYMBOL_GPL(si_swapinfo) only if CONFIG_SWAP is set. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-07-14x86: make 64bit hpet_set_mapping to use ioremap too, v2Yinghai Lu
keep the one for VSYSCALL_HPET Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14x86: get x86_phys_bits earlyYinghai Lu
when try to make hpet_enable use io_remap instead fixmap got ioremap: invalid physical address fed00000 ------------[ cut here ]------------ WARNING: at arch/x86/mm/ioremap.c:161 __ioremap_caller+0x8c/0x2f3() Modules linked in: Pid: 0, comm: swapper Not tainted 2.6.26-rc9-tip-01873-ga9827e7-dirty #358 Call Trace: [<ffffffff8026615e>] warn_on_slowpath+0x6c/0xa7 [<ffffffff802e2313>] ? __slab_alloc+0x20a/0x3fb [<ffffffff802d85c5>] ? mpol_new+0x88/0x17d [<ffffffff8022a4f4>] ? mcount_call+0x5/0x31 [<ffffffff8022a4f4>] ? mcount_call+0x5/0x31 [<ffffffff8024b0d2>] __ioremap_caller+0x8c/0x2f3 [<ffffffff80e86dbd>] ? hpet_enable+0x39/0x241 [<ffffffff8022a4f4>] ? mcount_call+0x5/0x31 [<ffffffff8024b466>] ioremap_nocache+0x2a/0x40 [<ffffffff80e86dbd>] hpet_enable+0x39/0x241 [<ffffffff80e7a1f6>] hpet_time_init+0x21/0x4e [<ffffffff80e730e9>] start_kernel+0x302/0x395 [<ffffffff80e722aa>] x86_64_start_reservations+0xb9/0xd4 [<ffffffff80e722fe>] ? x86_64_init_pda+0x39/0x4f [<ffffffff80e72400>] x86_64_start_kernel+0xec/0x107 ---[ end trace a7919e7f17c0a725 ]--- it seems for amd system that is set later... try to move setting early in early_identify_cpu. and remove same code for intel and centaur. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-14x86: max_low_pfn_mapped fix #4Yinghai Lu
only add direct mapping for aperture Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-13x86: change _node_to_cpumask_ptr to return const ptrMike Travis
* Strengthen the return type for the _node_to_cpumask_ptr to be a const pointer. This adds compiler checking to insure that node_to_cpumask_map[] is not changed inadvertently. Signed-off-by: Mike Travis <travis@sgi.com> Cc: "akpm@linux-foundation.org" <akpm@linux-foundation.org> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Acked-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-13x86: I/O APIC: remove an IRQ2-mask hackMaciej W. Rozycki
Now that IRQ2 is never made available to the I/O APIC, there is no need to special-case it and mask as a workaround for broken systems. Actually, because of the former, mask_IO_APIC_irq(2) is a no-op already. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
