path: root/arch
2006-03-27[PATCH] fbdev: Make BIOS EDID reading configurableAntonino A. Daplas
DDC reading via the Video BIOS may take several tens of seconds with some combination of display cards and monitors. Make this option configurable. It defaults to `y' to minimise disruption. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: SA1100/PXA2XX driverRichard Purdie
Add an RTC subsystem driver for the ARM SA1100/PXA2XX processor RTC. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: ARM Integrator cleanupRichard Purdie
Fix some namespace conflicts between the RTC subsystem and the ARM Integrator time functions. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: ARM cleanupAlessandro Zummo
This patch removes from the ARM subsytem some of the rtc-related functions that have been included in the RTC subsystem. It also fixes some naming collisions. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] mips: fixed collision of rtc function nameYoichi Yuasa
Fix the collision of rtc function name. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] Notifier chain update: API changesAlan Stern
The kernel's implementation of notifier chains is unsafe. There is no protection against entries being added to or removed from a chain while the chain is in use. The issues were discussed in this thread: http://marc.theaimsgroup.com/?l=linux-kernel&m=113018709002036&w=2 We noticed that notifier chains in the kernel fall into two basic usage classes: "Blocking" chains are always called from a process context and the callout routines are allowed to sleep; "Atomic" chains can be called from an atomic context and the callout routines are not allowed to sleep. We decided to codify this distinction and make it part of the API. Therefore this set of patches introduces three new, parallel APIs: one for blocking notifiers, one for atomic notifiers, and one for "raw" notifiers (which is really just the old API under a new name). New kinds of data structures are used for the heads of the chains, and new routines are defined for registration, unregistration, and calling a chain. The three APIs are explained in include/linux/notifier.h and their implementation is in kernel/sys.c. With atomic and blocking chains, the implementation guarantees that the chain links will not be corrupted and that chain callers will not get messed up by entries being added or removed. For raw chains the implementation provides no guarantees at all; users of this API must provide their own protections. (The idea was that situations may come up where the assumptions of the atomic and blocking APIs are not appropriate, so it should be possible for users to handle these things in their own way.) There are some limitations, which should not be too hard to live with. For atomic/blocking chains, registration and unregistration must always be done in a process context since the chain is protected by a mutex/rwsem. Also, a callout routine for a non-raw chain must not try to register or unregister entries on its own chain. (This did happen in a couple of places and the code had to be changed to avoid it.) Since atomic chains may be called from within an NMI handler, they cannot use spinlocks for synchronization. Instead we use RCU. The overhead falls almost entirely in the unregister routine, which is okay since unregistration is much less frequent that calling a chain. Here is the list of chains that we adjusted and their classifications. None of them use the raw API, so for the moment it is only a placeholder. ATOMIC CHAINS ------------- arch/i386/kernel/traps.c: i386die_chain arch/ia64/kernel/traps.c: ia64die_chain arch/powerpc/kernel/traps.c: powerpc_die_chain arch/sparc64/kernel/traps.c: sparc64die_chain arch/x86_64/kernel/traps.c: die_chain drivers/char/ipmi/ipmi_si_intf.c: xaction_notifier_list kernel/panic.c: panic_notifier_list kernel/profile.c: task_free_notifier net/bluetooth/hci_core.c: hci_notifier net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_chain net/ipv4/netfilter/ip_conntrack_core.c: ip_conntrack_expect_chain net/ipv6/addrconf.c: inet6addr_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_chain net/netfilter/nf_conntrack_core.c: nf_conntrack_expect_chain net/netlink/af_netlink.c: netlink_chain BLOCKING CHAINS --------------- arch/powerpc/platforms/pseries/reconfig.c: pSeries_reconfig_chain arch/s390/kernel/process.c: idle_chain arch/x86_64/kernel/process.c idle_notifier drivers/base/memory.c: memory_chain drivers/cpufreq/cpufreq.c cpufreq_policy_notifier_list drivers/cpufreq/cpufreq.c cpufreq_transition_notifier_list drivers/macintosh/adb.c: adb_client_list drivers/macintosh/via-pmu.c sleep_notifier_list drivers/macintosh/via-pmu68k.c sleep_notifier_list drivers/macintosh/windfarm_core.c wf_client_list drivers/usb/core/notify.c usb_notifier_list drivers/video/fbmem.c fb_notifier_list kernel/cpu.c cpu_chain kernel/module.c module_notify_list kernel/profile.c munmap_notifier kernel/profile.c task_exit_notifier kernel/sys.c reboot_notifier_list net/core/dev.c netdev_chain net/decnet/dn_dev.c: dnaddr_chain net/ipv4/devinet.c: inetaddr_chain It's possible that some of these classifications are wrong. If they are, please let us know or submit a patch to fix them. Note that any chain that gets called very frequently should be atomic, because the rwsem read-locking used for blocking chains is very likely to incur cache misses on SMP systems. (However, if the chain's callout routines may sleep then the chain cannot be atomic.) The patch set was written by Alan Stern and Chandra Seetharaman, incorporating material written by Keith Owens and suggestions from Paul McKenney and Andrew Morton. [jes@sgi.com: restructure the notifier chain initialization macros] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes: x86_64Ingo Molnar
x86_64: add the futex_atomic_cmpxchg_inuser() assembly implementation, and wire up the new syscalls. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Acked-by: Ulrich Drepper <drepper@redhat.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] lightweight robust futexes: i386Ingo Molnar
i386: add the futex_atomic_cmpxchg_inuser() assembly implementation, and wire up the new syscalls. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] unify PFN_* macrosDave Hansen
Just about every architecture defines some macros to do operations on pfns. They're all virtually identical. This patch consolidates all of them. One minor glitch is that at least i386 uses them in a very skeletal header file. To keep away from #include dependency hell, I stuck the new definitions in a new, isolated header. Of all of the implementations, sh64 is the only one that varied by a bit. It used some masks to ensure that any sign-extension got ripped away before the arithmetic is done. This has been posted to that sh64 maintainers and the development list. Compiles on x86, x86_64, ia64 and ppc64. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] for_each_online_pgdat: remove sorting pgdatKAMEZAWA Hiroyuki
Because pgdat_list was linked to pgdat_list in *reverse* order, (By default) some of arch has to sort it by themselves. for_each_pgdat has gone..for_each_online_pgdat() uses node_online_map, which doesn't need to be sorted. This patch removes codes for sorting pgdat. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] for_each_online_pgdat: renaming for_each_pgdatKAMEZAWA Hiroyuki
Replace for_each_pgdat() with for_each_online_pgdat(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] unify pfn_to_page: x86_64 pfn_to_pageKAMEZAWA Hiroyuki
x86_64 can use generic funcs. For DISCONTIGMEM, CONFIG_OUT_OF_LINE_PFN_TO_PAGE is selected. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] x86: don't use cpuid.2 to determine cache info if cpuid.4 is supportedShaohua Li
Don't use cpuid.2 to determine cache info if cpuid.4 is supported. The exception is P4 trace cache. We always use cpuid.2 to get trace cache under P4. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] sched: new sched domain for representing multi-coreSiddha, Suresh B
Add a new sched domain for representing multi-core with shared caches between cores. Consider a dual package system, each package containing two cores and with last level cache shared between cores with in a package. If there are two runnable processes, with this appended patch those two processes will be scheduled on different packages. On such systems, with this patch we have observed 8% perf improvement with specJBB(2 warehouse) benchmark and 35% improvement with CFP2000 rate(with 2 users). This new domain will come into play only on multi-core systems with shared caches. On other systems, this sched domain will be removed by domain degeneration code. This new domain can be also used for implementing power savings policy (see OLS 2005 CMP kernel scheduler paper for more details.. I will post another patch for power savings policy soon) Most of the arch/* file changes are for cpu_coregroup_map() implementation. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix thread startup raceJeff Dike
This fixes a race in the starting of write_sigio_thread. Previously, some of the data needed by the thread was initialized after the clone. If the thread ran immediately, it would see the uninitialized data, including an empty pollfds, which would cause it to hang. We move the data initialization to before the clone, and adjust the error paths and cleanup accordingly. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: prevent umid theftJeff Dike
Behavior when booting two UMLs with the same umid was broken. The second one would steal the umid. This fixes that, making the second UML take a random umid instead. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix segfault on signal deliveryJeff Dike
This fixes a process segfault where a signal was being delivered such that a new stack page needed to be allocated to hold the signal frame. This was tripping some logic in the page fault handler which wouldn't allocate the page if the faulting address was more that 32 bytes lower than the current stack pointer. Since a signal frame is greater than 32 bytes, this exercised that case. It's fixed by updating the SP in the pt_regs before starting to copy the signal frame. Since those are the registers that will be copied on to the stack, we have to be careful to put the original SP, not the new one which points to the signal frame, on the stack. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: allow ubd devices to be shared in a clusterJeff Dike
This adds a 'c' option to the ubd switch which turns off host file locking so that the device can be shared, as with a cluster. There's also some whitespace cleanup while I was in this file. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: oS header cleanupsJeff Dike
This rearranges the OS declarations by moving some declarations into os.h. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: move tty logging to os-LinuxJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from tty_log.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: more carefully test whether we are in a system callBodo Stroesser
For security reasons, UML in is_syscall() needs to have access to code in vsyscall-page. The current implementation grants this access by explicitly allowing access to vsyscall in access_ok_skas(). With this change, copy_from_user() may be used to read the code. Ptrace access to vsyscall-page for debugging already was implemented in get_user_pages() by mainline. In i386, copy_from_user can't access vsyscall-page, but returns EFAULT. To make UML behave as i386 does, I changed is_syscall to use access_process_vm(current) to read the code from vsyscall-page. This doesn't hurt security, but simplifies the code and prepares implementation of stub-vmas. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: move sigio_user.c to os-Linux/sigio.cJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves sigio_user.c to os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: move SIGIO startup code to os-Linux/start_up.cJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all startup code from sigio_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: merge irq_user.c and irq.cJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This joins irq_user.c and irq.c files. Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: move libc-dependent irq code to os-LinuxJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from irq_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix some printf formatsJeff Dike
Some printf formats are incorrect for large memory sizes. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix declaration of exit()Jeff Dike
This fixes a conflict between a header and what gcc "knows" the declaration' to be. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] PM-Timer: don't use workaround if chipset is not buggyOGAWA Hirofumi
Current timer_pm.c reads I/O port triple times, in order to avoid the bug of chipset. But I/O port is slow. 2.6.16 (pmtmr) Simple gettimeofday: 3.6532 microseconds 2.6.16+patch (pmtmr) Simple gettimeofday: 1.4582 microseconds [if chip is buggy, probably it will be 7us or more in 4.2% of probability.] This patch adds blacklist of buggy chip, and if chip is not buggy, this uses fast normal version instead of slow workaround version. If chip is buggy, warnings "pmtmr is slow". But sounds like there is gray zone. I found the PIIX4 errata, but I couldn't find the ICH4 errata. But some motherboard seems to have problem. So, if we found a ICH4, generate warnings, and use a workaround version. If user's ICH4 is good, the user can specify the "pmtmr_good" boot parameter to use fast version. Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[SPARC64]: Kill duplicate exports of string library functions.David S. Miller
Kbuild now points these out. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-26[SPARC64]: Update defconfig.David S. Miller
2006-03-26[PATCH] bitops: ia64: make partial_page.bitmap an unsigned longAkinobu Mita
The find_*_bit() routines are defined to work on a pointer to unsigned long. But partial_page.bitmap is unsigned int and it is passed to find_*_bit() in arch/ia64/ia32/sys_ia32.c. So the compiler will print warnings. This patch changes to unsigned long instead. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: xtensa: use generic bitopsAkinobu Mita
- remove {,test_and_}{set,clear,change}_bit() - remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove generic_fls64() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove generic_hweight{32,16,8}() - remove sched_find_first_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: x86_64: use generic bitopsAkinobu Mita
- remove sched_find_first_bit() - remove generic_hweight{64,32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: v850: use generic bitopsAkinobu Mita
- remove ffz() - remove find_{next,first}{,_zero}_bit() - remove generic_ffs() - remove generic_fls() - remove generic_fls64() - remove __ffs() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sparc64: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove __ffs() - remove generic_fls() - remove generic_fls64() - remove sched_find_first_bit() - remove ffs() - unless defined(ULTRA_HAS_POPULATION_COUNT) - remove generic_hweight{64,32,16,8}() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sparc: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove __ffs() - remove sched_find_first_bit() - remove ffs() - remove generic_fls() - remove generic_fls64() - remove generic_hweight{32,16,8}() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sh64: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove __ffs() - remove find_{next,first}{,_zero}_bit() - remove generic_hweight{32,16,8}() - remove sched_find_first_bit() - remove generic_ffs() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Richard Curnow <rc@rc0.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sh: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove find_{next,first}{,_zero}_bit() - remove generic_ffs() - remove generic_hweight{32,16,8}() - remove sched_find_first_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: s390: use generic bitopsAkinobu Mita
- remove generic_ffs() - remove generic_fls() - remove generic_fls64() - remove generic_hweight{64,32,16,8}() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: powerpc: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove generic_fls64() - remove generic_hweight{64,32,16,8}() - remove sched_find_first_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: parisc: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove generic_fls64() - remove generic_hweight{32,16,8}() - remove generic_hweight64() - remove sched_find_first_bit() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: mips: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - unless defined(CONFIG_CPU_MIPS32) or defined(CONFIG_CPU_MIPS64) - remove __ffs() - remove ffs() - remove ffz() - remove fls() - remove fls64() - remove find_{next,first}{,_zero}_bit() - remove sched_find_first_bit() - remove generic_hweight64() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: m68knommu: use generic bitopsAkinobu Mita
- remove ffs() - remove __ffs() - remove sched_find_first_bit() - remove ffz() - remove find_{next,first}{,_zero}_bit() - remove generic_hweight() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] ppc: fix undefined reference to hweight32Akinobu Mita
Build fix for ppc Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: m68k: use generic bitopsAkinobu Mita
- remove generic_fls64() - remove sched_find_first_bit() - remove generic_hweight() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: m32r: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove find_{next,first}{,_zero}_bit() - remove __ffs() - remove generic_fls() - remove generic_fls64() - remove sched_find_first_bit() - remove generic_ffs() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: ia64: use generic bitopsAkinobu Mita
- remove generic_fls64() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove sched_find_first_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: i386: use generic bitopsAkinobu Mita
- remove generic_fls64() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: h8300: use generic bitopsAkinobu Mita
- remove generic_ffs() - remove find_{next,first}{,_zero}_bit() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: frv: use generic bitopsAkinobu Mita
- remove ffz() - remove find_{next,first}{,_zero}_bit() - remove generic_ffs() - remove __ffs() - remove generic_fls64() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
