path: root/arch
2008-10-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdb: call touch_softlockup_watchdog on resume kgdb, x86: Avoid invoking kgdb_nmicallback twice per NMI
2008-10-06Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: gart iommu have direct mapping when agp is present too
2008-10-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: ide: workaround for bogus gcc warning in ide_sysfs_register_port() ide-cd: Optiarc DVD RW AD-7200A does play audio IDE: Fix platform device registration in Swarm IDE driver (v2) ide-dma: fix ide_build_dmatable() for TRM290 ide-cd: temporary tray close fix
2008-10-06Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] IP27: Fix build errors if CONFIG_MAPPED_KERNEL=y [MIPS] Fix CMP Kconfig configuration and mark as broken.
2008-10-06kgdb, x86: Avoid invoking kgdb_nmicallback twice per NMIJan Kiszka
Stress-testing KVM's latest NMI support with kgdbts inside an SMP guest, I came across spurious unhandled NMIs while running the singlestep test. Looking closer at the code path each NMI takes when KGDB is enabled, I noticed that kgdb_nmicallback is called twice per event: One time via DIE_NMI_IPI notification, the second time on DIE_NMI. Removing the first invocation cures the unhandled NMIs here. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-10-06x86 ACPI: Blacklist two HP machines with buggy BIOSesRafael J. Wysocki
There is a bug in the BIOSes of some HP boxes with AMD Turions which connects IO-APIC pins with ACPI thermal trip points in such a way that if the state of the IO-APIC is not as expected by the (buggy) BIOS, the thermal trip points are set to insanely low values (usually all of them become 16 degrees Celsius). As a result, thermal throttling kicks in and knock the system down to its shoes. Unfortunately some of the recent IO-APIC changes made the bug show up. To prevent this from happening, blacklist machines that are known to be affected (nx6115 and 6715b in this particular case). This fixes http://bugzilla.kernel.org/show_bug.cgi?id=11516 listed as a regression from 2.6.26. On my box it was caused by: commit 691874fa96d6349a8b60f8ea9c2bae52ece79941 Author: Maciej W. Rozycki <macro@linux-mips.org> Date: Tue May 27 21:19:51 2008 +0100 x86: I/O APIC: timer through 8259A second-chance Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> and the whole story is described in this (huge) thread: http://marc.info/?l=linux-kernel&m=121358440508410&w=4 Matthew Garrett told us about that happening on the nx6125: http://marc.info/?l=linux-kernel&m=121396307411930&w=4 and then Maciej analysed the breakage on the basis of a DSDT from the nx6325: http://marc.info/?l=linux-kernel&m=121401068718826&w=4 As far as the Dmitry's and Jason's boxes are concerned, I recognized the symptoms and asked them to verify that the blacklisting helped. It appears that the buggy BIOS code has been copy-pasted to the entire range of machines, for no good reason. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Tested-by: Jason Vas Dias <jason.vas.dias@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-06[MIPS] IP27: Fix build errors if CONFIG_MAPPED_KERNEL=yRalf Baechle
2008-10-06[MIPS] Fix CMP Kconfig configuration and mark as broken.Ralf Baechle
Because sync-r4k.c doesn't build. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-05IDE: Fix platform device registration in Swarm IDE driver (v2)Ralf Baechle
The Swarm IDE driver uses a release method which is defined in the driver itself thus potentially oopsable. The simple fix would be to just leak the device but this patch goes the full length and moves the entire handling of the platform device in the platform code and retains only the platform driver code in drivers/ide/mips/swarm.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> [bart: remove no longer needed BLK_DEV_IDE_SWARM from ide/Kconfig] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-10-05x86: gart iommu have direct mapping when agp is present tooYinghai Lu
move init_memory_mapping() out of init_k8_gatt. for: http://bugzilla.kernel.org/show_bug.cgi?id=11676 2.6.27-rc2 to rc8, apgart fails, iommu=soft works, regression This is needed because we need to map the GART aperture even if the GATT is not initialized. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-04Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86 setup: correct segfault in generation of 32-bit reloc kernel
2008-10-03Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] SMTC: Fix SMTC dyntick support. [MIPS] SMTC: Close tiny holes in the SMTC IPI replay system. [MIPS] SMTC: Fix holes in SMTC and FPU affinity support. [MIPS] SMTC: Build fix: Fix filename in Makefile [MIPS] Build fix: Fix irq flags type
2008-10-03x86 setup: correct segfault in generation of 32-bit reloc kernelH. Peter Anvin
Impact: segfault on build of a 32-bit relocatable kernel When converting arch/x86/boot/compressed/relocs.c to support unlimited sections, the computation of sym_strtab in walk_relocs() was done incorrectly. This causes a segfault for some people when building the relocatable 32-bit kernel. Pointed out by Anonymous <pageexec@freemail.hu>. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-03[S390] nohz: Fix __udelay.Heiko Carstens
This fixes a regression that came with 934b2857cc576ae53c92a66e63fce7ddcfa74691 ("[S390] nohz/sclp: disable timer on synchronous waits."). If udelay() gets called from a disabled context it sets the clock comparator to a value where it expects the next interrupt. When the interrupt happens the clock comparator gets not reset and therefore the interrupt condition doesn't get cleared. The result is an endless timer interrupt loop. In addition this patch fixes also the following: rcutorture reveals that our __udelay implementation is still buggy, since it might schedule tasklets, but prevents their execution: NOHZ: local_softirq_pending 42 NOHZ: local_softirq_pending 02 NOHZ: local_softirq_pending 142 NOHZ: local_softirq_pending 02 To fix this we make sure that only the clock comparator interrupt is enabled when the enabled wait psw is loaded. Also no code gets called anymore which might schedule tasklets. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-10-03[MIPS] SMTC: Fix SMTC dyntick support.Kevin D. Kissell
Rework of SMTC support to make it work with the new clock event system, allowing "tickless" operation, and to make it compatible with the use of the "wait_irqoff" idle loop. The new clocking scheme means that the previously optional IPI instant replay mechanism is now required, and has been made more robust. Signed-off-by: Kevin D. Kissell <kevink@paralogos.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-03[MIPS] SMTC: Close tiny holes in the SMTC IPI replay system.Kevin D. Kissell
2008-10-03[MIPS] SMTC: Fix holes in SMTC and FPU affinity support.Kevin D. Kissell
2008-10-03[MIPS] SMTC: Build fix: Fix filename in MakefileRalf Baechle
2008-10-03[MIPS] Build fix: Fix irq flags typeRalf Baechle
Though from a hardware perspective it would be sensible to use only a 32-bit unsigned int type Linux defines interrupt flags to be stored in an unsigned long and nothing else. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-02powerpc: Fix boot hang regression on MPC8544DSKumar Gala
Commit 00c5372d37a78990c1530184a9c792ee60a30067 caused the MPC8544DS board to hang at boot. The MPC8544DS is unique in that it doesn't use the PCI slots on the ULI (unlike the MPC8572DS or MPC8610HPCD). So the dummy read at the end of the address space causes us to hang. We can detect the situation by comparing the bridge's BARs versus the root complex. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-01Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, vmi: fix broken LDT access x86: fix typo in enable_mtrr_cleanup early parameter
2008-10-01MN10300: Fix IRQ handlingDavid Howells
Fix the IRQ handling on the MN10300 arch. This patch makes a number of significant changes: (1) It separates the irq_chip definition for edge-triggered interrupts from the one for level-triggered interrupts. This is necessary because the MN10300 PIC latches the IRQ channel's interrupt request bit (GxICR_REQUEST), even after the device has ceased to assert its interrupt line and the interrupt channel has been disabled in the PIC. So for level-triggered interrupts we need to clear this bit when we re-enable - which is achieved by setting GxICR_DETECT but not GxICR_REQUEST when writing to the register. Not doing this results in spurious interrupts occurring because calling mask_ack() at the start of handle_level_irq() is insufficient - it fails to clear the REQUEST latch because the device that caused the interrupt is still asserting its interrupt line at this point. (2) IRQ disablement [irq_chip::disable_irq()] shouldn't clear the interrupt request flag for edge-triggered interrupts lest it lose an interrupt. (3) IRQ unmasking [irq_chip::unmask_irq()] also shouldn't clear the interrupt request flag for edge-triggered interrupts lest it lose an interrupt. (4) The end() operation is now left to the default (no-operation) as __do_IRQ() is compiled out. This may affect misrouted_irq(), but according to Thomas Gleixner it's the correct thing to do. (5) handle_level_irq() is used for edge-triggered interrupts rather than handle_edge_irq() as the MN10300 PIC latches interrupt events even on masked IRQ channels, thus rendering IRQ_PENDING unnecessary. It is sufficient to call mask_ack() at the start and unmask() at the end. (6) For level-triggered interrupts, ack() is now NULL as it's not used, and there is no effective ACK function on the PIC. mask_ack() is now the same as mask() as the latch continues to latch, even when the channel is masked. Further, the patch discards the disable() op implementation as its now the same as the mask() op implementation, which is used instead. It also discards the enable() op implementations as they're now the same as the unmask() op implementations, which are used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-30x86, vmi: fix broken LDT accessZachary Amsden
This one took a long time to rear up because LDT usage is not very common, but the bug is quite serious. It got introduced along with another bug, already fixed, by 75b8bb3e56ca09a467fbbe5229bc68627f7445be After investigating a JRE failure, I found this bug was introduced a long time ago, and had already managed to survive another bugfix which occurred on the same line. The result is a total failure of the JRE due to LDT selectors not working properly. Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Glauber de Oliveira Costa <gcosta@redhat.com> Cc: stable@kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-30x86: Fix broken LDT access in VMIZachary Amsden
After investigating a JRE failure, I found this bug was introduced a long time ago, and had already managed to survive another bugfix which occurred on the same line. The result is a total failure of the JRE due to LDT selectors not working properly. This one took a long time to rear up because LDT usage is not very common, but the bug is quite serious. It got introduced along with another bug, already fixed, by 75b8bb3e56ca09a467fbbe5229bc68627f7445be Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Glauber de Oliveira Costa <gcosta@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Put the space for cpu0 per-cpu area into .data section
2008-09-30Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix failure to shutdown with CPU hotplug powerpc: Fix PCI in Holly device tree
2008-09-30x86: fix typo in enable_mtrr_cleanup early parameterJ.A. Magallón
Correct typo for 'enable_mtrr_cleanup' early boot param name. Signed-off-by: J.A. Magallon <jamagallon@ono.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-30powerpc: Fix failure to shutdown with CPU hotplugJohannes Berg
I tracked down the shutdown regression to CPUs not dying when being shut down during power-off. This turns out to be due to the system_state being SYSTEM_POWER_OFF, which this code doesn't take as a valid state for shutting off CPUs in. This has never made sense to me, but when I added hotplug code to implement hibernate I only "made it work" and did not question the need to check the system_state. Thomas Gleixner helped me dig, but the only thing we found is that it was added with the original commit that added CPU hotplug support. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-09-30powerpc: Fix PCI in Holly device treeDavid Gibson
The PCI bridge on the Holly board is incorrectly represented in the device tree. The current device tree node for the PCI bridge sits under the tsi-bridge node. That's not obviously wrong, but the PCI bridge translates some PCI spaces into CPU address ranges which were not translated by the "ranges" property in tsi-bridge node. We used to get away with this problem because the PCI bridge discovery code was also buggy, assuming incorrectly that PCI host bridge nodes were always directly under the root bus and treating the translated addresses as raw CPU addresses, rather than parent bus addresses. This has since been fixed, thus breaking Holly. This could be fixed by adding extra translations to the tsi-bridge node, but this patch instead moves the Holly PCI bridge out of the tsi-bridge node to the root bus. This makes the tsi-bridge node represent only the built-in IO devices in the bridge, with a more-or-less contiguous address range. This is the same convention used on Freescale SoC chips, where the "soc" node represents only the IMMR region, and the PCI and other bus bridges are separate nodes under the root bus. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-09-29[IA64] Put the space for cpu0 per-cpu area into .data sectionTony Luck
Initial fix for making sure that we can access percpu variables in all C code (commit: 10617bbe84628eb18ab5f723d3ba35005adde143) inadvertantly allocated the memory in the "percpu" section of the vmlinux ELF executable. This confused kexec/dump. Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-09-29Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: disable apm on the olpc
2008-09-29Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [SSB] Initialise dma_mask for SSB_BUSTYPE_SSB devices [MIPS] BCM47xx: Fix build error due to missing PCI functions [MIPS] IP27: Switch to dynamic interrupt routing avoding panic on error. [MIPS] au1000: Make sure GPIO value is zero or one
2008-09-29Merge branch 'linux-m32r' of git://www.linux-m32r.org/git/takata/linux-2.6_devLinus Torvalds
* 'linux-m32r' of git://www.linux-m32r.org/git/takata/linux-2.6_dev: m32r/kernel/: cleanups m32r: export __ndelay m32r: export empty_zero_page m32r: don't offer CONFIG_ISA m32r: remove the unused NOHIGHMEM option
2008-09-29Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdboc,tty: Fix tty polling search to use name correctly kgdb, x86_64: fix PS CS SS registers in gdb serial kgdb, x86_64: gdb serial has BX and DX reversed kgdb, x86, arm, mips, powerpc: ignore user space single stepping kgdb: could not write to the last of valid memory with kgdb
2008-09-27[MIPS] BCM47xx: Fix build error due to missing PCI functionsAurelien Jarno
This patch defines pcibios_map_irq() and pcibios_plat_dev_init() for the BCM47xx platform. It fixes the regression introduced by commit aab547ce0d1493d400b6468c521a0137cd8c1edf. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-27[MIPS] IP27: Switch to dynamic interrupt routing avoding panic on error.Ralf Baechle
pcibios_map_irq is no way of returning an error but on IP27 an interrupt is possibly not routable when running out of resources. So do the interrupt routing at pcibios_enable_device time. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-27[MIPS] au1000: Make sure GPIO value is zero or oneBruno Randolf
David Brownell <david-b@pacbell.net> wrote: > The problem is that "value" is zero-or-nonzero. > This code wrongly assumes it's zero-or-one. > Possible fix: "((!!value) << gpio)". Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-27m32r/kernel/: cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global code static: - entry.S: resume_userspace - process.c: pm_idle - process.c: default_idle() - smp.c: send_IPI_allbutself() - time.c: timer_interrupt() - time.c: struct irq0 - traps.c: set_eit_vector_entries() - traps.c: kstack_depth_to_print - traps.c: show_trace() - traps.c: die_lock - remove the following unused code: - head.S: startup_32 - process.c: hlt_counter - process.c: disable_hlt() - process.c: enable_hlt() - process.c: dump_task_regs() - remove the following variables and their usages since they were always 0: - irq.c: irq_err_count - irq.c: irq_mis_count Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-27m32r: export __ndelayAdrian Bunk
ERROR: "__ndelay" [drivers/spi/spi_bitbang.ko] undefined! Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-27m32r: export empty_zero_pageAdrian Bunk
ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined! Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-27m32r: don't offer CONFIG_ISAAdrian Bunk
As far as I know no M32R hardware actually has ISA slots. And ISA drivers don't compile on M32R. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-27m32r: remove the unused NOHIGHMEM optionAdrian Bunk
Remove the unused NOHIGHMEM option. Reviewed-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
2008-09-26ARM: Delete ARM's own cnt32_to_63.hDavid Howells
Delete ARM's own cnt32_to_63.h as the copy in include/linux/ should now be used instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-26kgdb, x86_64: fix PS CS SS registers in gdb serialJason Wessel
On x86_64 the gdb serial register structure defines the PS (also known as eflags), CS and SS registers as 4 bytes entities. This patch splits the x86_64 regnames enum into a 32 and 64 version to account for the 32 bit entities in the gdb serial packets. Also the program counter is properly filled in for the sleeping threads. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-09-26kgdb, x86, arm, mips, powerpc: ignore user space single steppingJason Wessel
On the x86 arch, user space single step exceptions should be ignored if they occur in the kernel space, such as ptrace stepping through a system call. First check if it is kgdb that is executing a single step, then ensure it is not an accidental traversal into the user space, while in kgdb, any other time the TIF_SINGLESTEP is set, kgdb should ignore the exception. On x86, arm, mips and powerpc, the kgdb_contthread usage was inconsistent with the way single stepping is implemented in the kgdb core. The arch specific stub should always set the kgdb_cpu_doing_single_step correctly if it is single stepping. This allows kgdb to correctly process an instruction steps if ptrace happens to be requesting an instruction step over a system call. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-09-24Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: prevent stale state of c1e_mask across CPU offline/online, fix
2008-09-24Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Fixe the definition of PTRS_PER_PGD [MIPS] au1000: Fix gpio direction
2008-09-24MN10300: Make sched_clock() report time since bootDavid Howells
Make sched_clock() report time since boot rather than time since last timer interrupt. Make sched_clock() expand and scale the 32-bit TSC value running at IOCLK speed (~33MHz) to a 64-bit nanosecond counter, using cnt32_to_63() acquired from the ARM arch and without using slow DIVU instructions every call. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-24MN10300: Move asm-arm/cnt32_to_63.h to include/linux/David Howells
Move asm-arm/cnt32_to_63.h to include/linux/ so that MN10300 can make use of it too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-24x86: disable apm on the olpcJeremy Katz
The OLPC doesn't support APM but also doesn't have DMI, so we can't detect and disable it based on DMI data. So, just disable based on machine_is_olpc() Signed-off-by: Jeremy Katz <katzj@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
