After removing support for ATAGS based boot on Exynos, there is not much
that can be shared between Exynos and other S5P platforms. This patch
makes Exynos a standalone Samsung platform, not using PLAT_S5P.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This patch adds new Kconfig symbols, SAMSUNG_PM_GPIO and S5P_IRQ_PM that
get enabled when GPIO_SAMSUNG, PM and S5P_PM are enabled, but only if
SAMSUNG_ATAGS is selected.
This patch adds several compatibility definitions that are not relevant
for Exynos, but are required by Samsung PM core.
This patch adds Kconfig entry that selects whether legacy Samsung GPIO
driver should be built or not. For platforms that support only DT based
boot, the new pinctrl driver is used and so the old one is not needed.
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
This patch removes static definitions of power domains and code
responsible for registering them and adding devices to them, since only
DT based boot is now supported on Exynos.
Cc: linux-pm@vger.kernel.org
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
This patch makes the firmware setup code assume presence of DT, since it
is now the only way of booting supported for Exynos.
This patch removes static mapping of chip ID block that was used when
booting with ATAGS, which is not supported on Exynos any more.
This patch removes legacy platform device initialization code that was
used to set names and other parameters of static platform devices when
This patch removes legacy timer initialization code that was used to
set up system timers when booting with ATAGS, which is not supported
on Exynos any more.
This patch removes legacy IRQ initialization code that was used to set
up interrupt handling when booting with ATAGS, which is not supported
any more.
This patch removes now unused files containing old device and GPIO setup
code that was needed for ATAGS based boot, which is not supported on
Exynos any more.
The only exception is setup-i2c0.c that will be removed later, since it
has dependencies in plat-samsung/ directory.
This patch removes legacy UART initialization code that was used to
set up UART platform devices when booting with ATAGS, which is not
This patch removes legacy EINT initialization code that was used to
handle external interrupts when booting with ATAGS, which is not
supported any more.
This patch removes legacy PMU initialization code that was used to set
up PMU when booting with ATAGS, which is not supported any more.
This patch adds a Kconfig entry that enables compilation of legacy
support code required for Samsung platforms that require ATAGS based
boot.
This allows to bypass compilation of this code when platforms without
ATAGS support are selected.
Since EXYNOS is now DT-only, it always requires USE_OF option to be
selected. This patch moves USE_OF selection from entries of DT board
files to ARCH_EXYNOS.
Since commit 383ffda ARM: EXYNOS: no more support non-DT for EXYNOS SoCs
all non-DT Exynos board files are not used anymore. This patch removes
them.
As we discussed in mailing list, non-DT for EXYNOS SoCs will not be
supported from v3.11. This patch removes regarding files for non-DT
including board files and defconfig.
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Olof Johansson <olof@lixom.net>
Pull ARM SoC fixes from Olof Johansson:
"Another week, another batch of fixes for arm-soc platforms.
Nothing controversial here, a handful of fixes for regressions and/or
serious problems across several of the platforms. Things are slowing
down nicely on fix rates for 3.10"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: exynos: add debug_ll_io_init() call in exynos_init_io()
ARM: EXYNOS: uncompress - print debug messages if DEBUG_LL is defined
ARM: shmobile: sh73a0: Update CMT clockevent rating to 80
sh-pfc: r8a7779: Don't group USB OVC and PENC pins
ARM: mxs: icoll: Fix interrupts gpio bank 0
ARM: imx: clk-imx6q: AXI clock select index is incorrect
ARM: bcm2835: override the HW UART periphid
ARM: mvebu: Fix bug in coherency fabric low level init function
ARM: Kirkwood: TS219: Fix crash by double PCIe instantiation
ARM: ux500: Provide supplies for AUX1, AUX2 and AUX3
ARM: ux500: Only configure wake-up reasons on ux500 based platforms
ARM: dts: imx: fix clocks for cspi
ARM i.MX6q: fix for ldb_di_sels
Pull MIPS fixes from Ralf Baechle:
"MIPS fixes across the field. The only area that's standing out is the
exception handling which received it's dose of breakage as part of the
microMIPS patchset"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: ralink: add missing SZ_1M multiplier
MIPS: Compat: Fix cputime_to_timeval() arguments in compat binfmt_elf.
MIPS: OCTEON: Improve _machine_halt implementation.
MIPS: rtlx: Fix implicit declaration of function set_vi_handler()
MIPS: Trap exception handling fixes
MIPS: Quit exposing Kconfig symbols in uapi headers.
MIPS: Remove duplicate definition of check_for_high_segbits.
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68knommu fix from Greg Ungerer:
"A single fix for compilation breakage to many of the ColdFire CPU
targets"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68k: only use local gpio_request_one if not using GPIOLIB
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes
From Shawn Guo, imx fixes for 3.10, take 2:
- One device tree fix for all spi node to have per clock added.
The clock is needed by spi driver to calculate bit rate divisor.
The spi node in the current device trees either does not have the
clock or is defined as dummy clock, in which case the driver probe
will fail or spi will run at a wrong bit rate.
- Two imx6q clock fixes, which correct axi_sels and ldb_di_sels.
* tag 'imx-fixes-3.10-2' of git://git.linaro.org/people/shawnguo/linux-2.6:
If the early MMU mapping of the UART happens to get booted out of the
TLB between the start of paging_init() and when we finally re-add the
UART at the very end of s3c_init_cpu(), we'll get a hang at bootup if
we've got early_printk enabled. Avoid this hang by calling
debug_ll_io_init() early.
Without this patch, you can reliably reproduce a hang when early
printk is enabled by adding flush_tlb_all() at the start of
exynos_init_io(). After this patch the hang goes away.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into fixes
From Simon Horman, Renesas ARM based SoC fixes for v3.10:
- Correction to USB OVC and PENC pin groupings on r8a7779 SoC.
This avoids conflicts when the USB_OVCn pins are used by another function.
This has been observed to be a problem in v3.10-rc1.
- Update CMT clock rating for sh73a0 SoC to resolve boot failure
on kzm9g-reference. This resolves a regression between v3.9 and v3.10-rc1.
* tag 'renesas-fixes-for-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
Printing low-level debug messages make an assumption that the specified
UART port has been preconfigured by the bootloader. Incorrectly
specified UART port results in system getting stalled while printing the
message "Uncompressing Linux... done, booting the kernel"
This UART port number is specified through S3C_LOWLEVEL_UART_PORT. Since
the UART port might different for different board, it is not possible to
specify it correctly for every board that use a common defconfig file.
Calling this print subroutine only when DEBUG_LL fixes the problem. By
disabling DEBUG_LL in default config file, we would be able to boot
multiple boards with different default UART ports.
With this current approach, we miss the print "Uncompressing Linux...
done, booting the kernel." when DEBUG_LL is not defined.
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"This fixes a crash when booting a 32-bit kernel via the EFI boot stub.
PCI ROM from EFI
x86/PCI: Map PCI setup data with ioremap() so it can be in highmem"
* tag 'pci-v3.10-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
On RT5350 the memory size is set to Bytes and not MegaBytes due to a missing
multiplier.
Signed-off-by: John Crispin <blogic@openwrt.org>
Cc: John Crispin <blogic@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/5378/
cputime_to_timeval() takes a struct timeval *as its second argument but
a struct compat_timeval * will be passed resulting in:
CC arch/mips/kernel/binfmt_elfn32.o
In file included from arch/mips/kernel/binfmt_elfn32.c:122:0:
arch/mips/kernel/../../../fs/binfmt_elf.c: In function ‘fill_prstatus’:
arch/mips/kernel/../../../fs/binfmt_elf.c:1330:3: warning: passing argument 2 of ‘cputime_to_timeval’ from incompatible pointer type [enabled by default]
In file included from include/asm-generic/cputime.h:12:0,
from /home/ralf/src/linux/linux-mips/arch/mips/include/asm/cputime.h:4,
from include/linux/sched.h:28,
from include/linux/ptrace.h:5,
from include/uapi/linux/elfcore.h:7,
from include/linux/elfcore.h:7,
from arch/mips/kernel/binfmt_elfn32.c:55:
include/asm-generic/cputime_nsecs.h:92:91: note: expected ‘struct timeval *’ but argument is of type ‘struct compat_timeval *’
arch/mips/kernel/../../../fs/binfmt_elf.c:1331:3: warning: passing argument 2 of ‘cputime_to_timeval’ from incompatible pointer type [enabled by default]
arch/mips/kernel/../../../fs/binfmt_elf.c:1336:3: warning: passing argument 2 of ‘cputime_to_timeval’ from incompatible pointer type [enabled by default]
arch/mips/kernel/../../../fs/binfmt_elf.c:1337:3: warning: passing argument 2 of ‘cputime_to_timeval’ from incompatible pointer type [enabled by default]
arch/mips/kernel/../../../fs/binfmt_elf.c:1339:2: warning: passing argument 2 of ‘cputime_to_timeval’ from incompatible pointer type [enabled by default]
arch/mips/kernel/../../../fs/binfmt_elf.c:1340:2: warning: passing argument 2 of ‘cputime_to_timeval’ from incompatible pointer type [enabled by default]
AS arch/mips/kernel/scall64-n32.o
CC arch/mips/kernel/signal_n32.o
CC arch/mips/kernel/binfmt_elfo32.o
In file included from arch/mips/kernel/binfmt_elfo32.c:165:0:
from arch/mips/kernel/binfmt_elfo32.c:78:
As noted by Wladislav Wiebe:
$ halt
Sent SIGKILL to all processes
Requesting system halt
[66.729373] System halted.
[66.733244]
[66.734761] =====================================
[66.739473] [ BUG: lock held at task exit time! ]
[66.744188] 3.8.7-0-sampleversion-fct #49 Tainted: G O
[66.750202] -------------------------------------
[66.754913] init/21479 is exiting with locks still held!
[66.760234] 1 lock held by init/21479:
[66.763990] #0: (reboot_mutex){+.+...}, at: [<ffffffff801776c8>] SyS_reboot+0xe0/0x218
[66.772165]
[66.772165] stack backtrace:
[66.776532] Call Trace:
[66.778992] [<ffffffff805780a8>] dump_stack+0x8/0x34
[66.783972] [<ffffffff801618b0>] do_exit+0x610/0xa70
[66.788948] [<ffffffff801777a8>] SyS_reboot+0x1c0/0x218
[66.794186] [<ffffffff8013d6a4>] handle_sys64+0x44/0x64
This is an alternative fix to the one sent by Wladislav. We kill the
watchdog for each CPU and then spin in WAIT with interrupts disabled.
This is the lowest power mode for the OCTEON. If we were to spin with
interrupts enabled, we would get a continual stream of warning messages
and backtraces from the lockup detector, so I chose to disable
interrupts.
Signed-off-by: David Daney <david.daney@cavium.com>
Cc: Maxim Uvarov <muvarov@gmail.com>
Cc: Wladislav Wiebe <wladislav.kw@gmail.com>
Cc: linux-mips@linux-mips.org
Cc: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/5324/
arch/mips/kernel/rtlx.c: In function 'rtlx_module_init':
arch/mips/kernel/rtlx.c:523:3: error: implicit declaration of function 'set_vi_handler' [-Werror=implicit-function-declaration]
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/5340/
Since the introduction of preemptible mmu_gather TLB fast mode has been
broken. TLB fast mode relies on there being absolutely no concurrency;
it frees pages first and invalidates TLBs later.
However now we can get concurrency and stuff goes *bang*.
This patch removes all tlb_fast_mode() code; it was found the better
option vs trying to patch the hole by entangling tlb invalidation with
the scheduler.
Reported-by: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
f9a37be0f0 ("x86: Use PCI setup data") added support for using PCI ROM
images from setup_data. This used phys_to_virt(), which is not valid for
highmem addresses, and can cause a crash when booting a 32-bit kernel via
the EFI boot stub.
pcibios_add_device() assumes that the physical addresses stored in
setup_data are accessible via the direct kernel mapping, and that calling
phys_to_virt() is valid. This isn't guaranteed to be true on x86 where the
direct mapping range is much smaller than on x86-64.
Calling phys_to_virt() on a highmem address results in the following:
BUG: unable to handle kernel paging request at 39a3c198
IP: [<c262be0f>] pcibios_add_device+0x2f/0x90
Call Trace:
[<c2370c73>] pci_device_add+0xe3/0x130
[<c274640b>] pci_scan_single_device+0x8b/0xb0
[<c2370d08>] pci_scan_slot+0x48/0x100
[<c2371904>] pci_scan_child_bus+0x24/0xc0
[<c262a7b0>] pci_acpi_scan_root+0x2c0/0x490
[<c23b7203>] acpi_pci_root_add+0x312/0x42f
The solution is to use ioremap() instead of phys_to_virt() to map the
setup data into the kernel address space.
[bhelgaas: changelog]
Tested-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Seth Forshee <seth.forshee@canonical.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: stable@vger.kernel.org # v3.8+
Pull kvm bugfixes from Gleb Natapov:
"The bulk of the fixes is in MIPS KVM kernel<->userspace ABI. MIPS KVM
is new for 3.10 and some problems were found with current ABI. It is
better to fix them now and do not have a kernel with broken one"
* 'fixes' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: Fix race in apic->pending_events processing
KVM: fix sil/dil/bpl/spl in the mod/rm fields
KVM: Emulate multibyte NOP
ARM: KVM: be more thorough when invalidating TLBs
ARM: KVM: prevent NULL pointer dereferences with KVM VCPU ioctl
mips/kvm: Use ENOIOCTLCMD to indicate unimplemented ioctls.
mips/kvm: Fix ABI by moving manipulation of CP0 registers to KVM_{G,S}ET_ONE_REG
mips/kvm: Use ARRAY_SIZE() instead of hardcoded constants in kvm_arch_vcpu_ioctl_{s,g}et_regs
mips/kvm: Fix name of gpr field in struct kvm_regs.
mips/kvm: Fix ABI for use of 64-bit registers.
mips/kvm: Fix ABI for use of FPU.
Pull microblaze fixes from Michal Simek:
"One is fixing warning reported by sparse and the second warning was
reported by Geert in his build regressions/improvements status update
for -rc4."
* 'next' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Use static inline functions in cacheflush.h
microblaze: Fix sparse warnings
Update the CMT clockevent rating from 125 to 80.
This resolves a boot-failure regression for kzm9g-reference in v3.10-rc1
introduced by f7db706b132f11c79ae1d74b2382e0926cf31644 ("ARM: 7674/1: smp:
Avoid dummy clockevent being preferred over real").
The patch noted above reduces the rating of dummy clockevent from 400 to 100.
This patch reduces the rating of CMT so that it is once again less than that
of the dummy clockevent.
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Using static inline functions ensure proper type checking
which also remove compilation warning for no MMU
Compilation warning:
arch/microblaze/include/asm/cacheflush.h: warning: 'addr'
may be used uninitialized in this function [-Wmaybe-uninitialized]
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k fix from Geert Uytterhoeven:
"A boot lock-up on Mac, also destined for stable"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k/mac: Fix unexpected interrupt with CONFIG_EARLY_PRINTK
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"Recent bug fixes, one of them touches a common code file.
It adds two #ifndef/#endif pairs to asm-generic/io.h to be able to
override xlate_dev_kmem_ptr and xlate_dev_mem_ptr."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/pgtable: Fix gmap notifier address
s390/dasd: fix handling of gone paths
s390/pgtable: Fix check for pgste/storage key handling
arch: s390: appldata: using strncpy() and strnlen() instead of sprintf()
s390/smp: lost IPIs on cpu hotplug
kernel: Fix s390 absolute memory access for /dev/mem
s390/dma: do not call debug_dma after free
arch/microblaze/include/asm/uaccess.h:101:3:
warning: cast removes address space of expression
arch/microblaze/include/asm/uaccess.h:107:2:
apic->pending_events processing has a race that may cause INIT and
SIPI
processing to be reordered:
vpu0: vcpu1:
set INIT
test_and_clear_bit(KVM_APIC_INIT)
process INIT
set INIT
set SIPI
test_and_clear_bit(KVM_APIC_SIPI)
process SIPI
At the end INIT is left pending in pending_events. The following patch
fixes this by latching pending event before processing them.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
The x86-64 extended low-byte registers were fetched correctly from reg,
but not from mod/rm.
This fixes another bug in the boot of RHEL5.9 64-bit, but it is still
not enough.
Cc: <stable@vger.kernel.org> # 3.9
This is encountered when booting RHEL5.9 64-bit. There is another bug
after this one that is not a simple emulation failure, but this one lets
the boot proceed a bit.
The KVM/ARM MMU code doesn't take care of invalidating TLBs before
freeing a {pte,pmd} table. This could cause problems if the page
is reallocated and then speculated into by another CPU.
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
Some ARM KVM VCPU ioctls require the vCPU to be properly initialized
with the KVM_ARM_VCPU_INIT ioctl before being used with further
requests. KVM_RUN checks whether this initialization has been
done, but other ioctls do not.
Namely KVM_GET_REG_LIST will dereference an array with index -1
without initialization and thus leads to a kernel oops.
Fix this by adding checks before executing the ioctl handlers.
[ Removed superflous comment from static function - Christoffer ]
Changes from v1:
* moved check into a static function with a meaningful name
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
The Linux Way is to return -ENOIOCTLCMD to the vfs when an
unimplemented ioctl is requested. Do this in kvm_mips instead of a
random mixture of -ENOTSUPP and -EINVAL.
Acked-by: Sanjay Lal <sanjayl@kymasys.com>
Because not all 256 CP0 registers are ever implemented, we need a
different method of manipulating them. Use the
KVM_SET_ONE_REG/KVM_GET_ONE_REG mechanism.
Now unused code and definitions are removed.
Also we cannot set special zero register, so force it to zero.
All registers are 64-bits wide, 32-bit guests use the least
significant portion of the register storage fields.
Define a non-empty struct kvm_fpu.
