path: root/arch
2011-08-08bcm47xx: fix irq assignment for new SoCs.Hauke Mehrtens
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcm47xx: add support for bcma busHauke Mehrtens
This patch add support for the bcma bus. Broadcom uses only Mips 74K CPUs on the new SoC and on the old ons using ssb bus there are no Mips 74K CPUs. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-08bcm47xx: make it possible to build bcm47xx without ssb.Hauke Mehrtens
2011-08-08bcm47xx: prepare to support different busesHauke Mehrtens
Prepare bcm47xx to support different System buses. Before adding support for bcma it should be possible to build bcm47xx without the need of ssb. With this patch bcm47xx does not directly contain a ssb_bus, but a union contain all the supported system buses. As a SoC just uses one system bus a union is a good choice. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-07-27sparc: rename atomic_add_unlessStephen Rothwell
Should have been done in commit 1af08a1407f4 ("This is in preparation for more generic atomic"). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Arun Sharma <asharma@fb.com> Cc: David Miller <davem@davemloft.net> Cc: "Hans-Christian Egtvedt" <hans-christian.egtvedt@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-27Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'next' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Do not show error message for 32 interrupt lines Revert "microblaze: PCI fix typo fault in of_node pointer moving into pci_bus" microblaze: PCI fix typo fault in of_node pointer moving into pci_bus microblaze: Add support for early console on mdm microblaze: Simplify early console binding from DT microblaze: Get early printk console earlier microblaze: Standardise cpuinfo output for cache policy microblaze: Unprivileged stream instruction awareness microblaze: trivial: Fix typo fault microblaze: exec: Remove redundant set_fs(USER_DS) microblaze: Remove duplicated prototype of start_thread() microblaze: Fix unaligned value saving to the stack for system with MMU microblaze/irqs: Do not trace arch_local_{*,irq_*} functions
2011-07-27microblaze: Do not show error message for 32 interrupt linesMichal Simek
When interrupt controller uses 32 interrupts lines the kernel show error message about mismatch in kind-of-intr parameter because it exceeds u32. Recast fixs this issue. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-07-26Merge branch 'next/devel2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (47 commits) OMAP: Add debugfs node to show the summary of all clocks OMAP2+: hwmod: Follow the recommended PRCM module enable sequence OMAP2+: clock: allow per-SoC clock init code to prevent clockdomain calls from clock code OMAP2+: clockdomain: Add per clkdm lock to prevent concurrent state programming OMAP2+: PM: idle clkdms only if already in idle OMAP2+: clockdomain: add clkdm_in_hwsup() OMAP2+: clockdomain: Add 2 APIs to control clockdomain from hwmod framework OMAP: clockdomain: Remove redundant call to pwrdm_wait_transition() OMAP4: hwmod: Introduce the module control in hwmod control OMAP4: cm: Add two new APIs for modulemode control OMAP4: hwmod data: Add modulemode entry in omap_hwmod structure OMAP4: hwmod data: Add PRM context register offset OMAP4: prm: Remove deprecated functions OMAP4: prm: Replace warm reset API with the offset based version OMAP4: hwmod: Replace RSTCTRL absolute address with offset macros OMAP: hwmod: Wait the idle status to be disabled OMAP4: hwmod: Replace CLKCTRL absolute address with offset macros OMAP2+: hwmod: Init clkdm field at boot time OMAP4: hwmod data: Add clock domain attribute OMAP4: clock data: Add missing divider selection for auxclks ...
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-26Merge branch 'next/board' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/board' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: S3C64XX: Configure backup battery charger on Cragganmore ARM: S3C64XX: Fix WM8915 IRQ polarity on Cragganmore ARM: S3C64XX: Configure supplies for all Cragganmore regulators ARM: S3C64XX: Refresh Cragganmore support ARM: S3C64XX: Initial support for Wolfson/Simtec Cragganmore/Banff OMAP4: Keyboard: Mux changes in the board file omap: blaze: add mmc5/wl1283 device support omap: 4430SDP: Register the card detect GPIO properly arm: omap3: cm-t35: add support for cm-t3730 OMAP3: beagle: add support for beagleboard xM revision C OMAP3: rx-51: Add full regulator definitions omap: rx51: Platform support for lp5523 led chip
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-26Merge branch 'next/fixes2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/fixes2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (24 commits) ASoC: omap: McBSP: fix build breakage on OMAP1 OMAP: hwmod: fix the i2c-reset timeout during bootup I2C: OMAP2+: add correct functionality flags to all omap2plus i2c dev_attr I2C: OMAP2+: Tag all OMAP2+ hwmod defintions with I2C IP revision I2C: OMAP1/OMAP2+: create omap I2C functionality flags for each cpu_... test I2C: OMAP2+: Introduce I2C IP versioning constants I2C: OMAP2+: increase omap_i2c_dev_attr flags from u8 to u32 I2C: OMAP2+: Set hwmod flags to only allow 16-bit accesses to i2c OMAP4: hwmod data: Change DSS main_clk scheme OMAP4: powerdomain data: Remove unsupported MPU powerdomain state OMAP4: clock data: Keep GPMC clocks always enabled and hardware managed OMAP4: powerdomain data: Fix core mem states and missing cefuse flag OMAP2+: PM: Initialise sleep_switch to a non-valid value OMAP4: hwmod data: Modify DSS opt clocks OMAP4: iommu: fix clock name omap: iovmm: s/sg_dma_len(sg)/sg->length/ omap: iommu: fix pte programming arm: omap3: cm-t35: fix slow path warning arm: omap3: cm-t35: minor comments fixes omap: ZOOM: QUART: Request reset GPIO ...
2011-07-26Merge branch 'next/soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: MAINTAINERS: add maintainer of CSR SiRFprimaII machine ARM: CSR: initializing L2 cache ARM: CSR: mapping early DEBUG_LL uart ARM: CSR: Adding CSR SiRFprimaII board support OMAP4: clocks: Update the clock tree with 4460 clock nodes OMAP4: PRCM: OMAP4460 specific PRM and CM register bitshifts OMAP4: ID: add omap_has_feature for max freq supported OMAP: ID: introduce chip detection for OMAP4460 ARM: Xilinx: merge board file into main platform code ARM: Xilinx: Adding Xilinx board support Fix up conflicts in arch/arm/mach-omap2/cm-regbits-44xx.h
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26asm-generic: add another generic ext2 atomic bitopsAkinobu Mita
The majority of architectures implement ext2 atomic bitops as test_and_{set,clear}_bit() without spinlock. This adds this type of generic implementation in ext2-atomic-setbit.h and use it wherever possible. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Suggested-by: Andreas Dilger <adilger@dilger.ca> Suggested-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26h8300/m68k/xtensa: __FD_ISSET should return 0/1Andrew Morton
Harmonise these return values with other architectures. In some cases this affects all compilers and in other cases non-gcc compilers only. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Chris Zankel <chris@zankel.net> Cc: Ulrich Drepper <drepper@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26mn10300, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26frv, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Also removed the dead code in flush_thread(). Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (31 commits) MIPS: Close races in TLB modify handlers. MIPS: Add uasm UASM_i_SRL_SAFE macro. MIPS: RB532: Use hex_to_bin() MIPS: Enable cpu_has_clo_clz for MIPS Technologies' platforms MIPS: PowerTV: Provide cpu-feature-overrides.h MIPS: Remove pointless return statement from empty void functions. MIPS: Limit fixrange_init() to the FIXMAP region MIPS: Install handlers for software IRQs MIPS: Move FIXADDR_TOP into spaces.h MIPS: Add SYNC after cacheflush MIPS: pfn_valid() is broken on low memory HIGHMEM systems MIPS: HIGHMEM DMA on noncoherent MIPS32 processors MIPS: topdown mmap support MIPS: Remove redundant addr_limit assignment on exec. MIPS: AR7: Replace __attribute__((__packed__)) with __packed MIPS: AR7: Remove 'space before tabs' in platform.c MIPS: Lantiq: Add missing clk_enable and clk_disable functions. MIPS: AR7: Fix trailing semicolon bug in clock.c MAINTAINERS: Update MIPS entry. MIPS: BCM63xx: Remove duplicate PERF_IRQSTAT_REG definition ...
2011-07-26Merge branch 'x86-olpc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-olpc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, olpc-xo15-sci: Enable EC wakeup capability x86, olpc: Fix dependency on POWER_SUPPLY x86, olpc: Add XO-1.5 SCI driver x86, olpc: Add XO-1 RTC driver x86, olpc-xo1-sci: Propagate power supply/battery events x86, olpc-xo1-sci: Add lid switch functionality x86, olpc-xo1-sci: Add GPE handler and ebook switch functionality x86, olpc: EC SCI wakeup mask functionality x86, olpc: Add XO-1 SCI driver and power button control x86, olpc: Add XO-1 suspend/resume support x86, olpc: Rename olpc-xo1 to olpc-xo1-pm x86, olpc: Move CS5536-related constants to cs5535.h x86, olpc: Add missing elements to device tree
2011-07-26Revert "microblaze: PCI fix typo fault in of_node pointer moving into pci_bus"Michal Simek
This reverts commit c9d761b7c4b658a937a941aea2781f511a0ff3ec. Ben' commit "microblaze/pci: Move the remains of pci_32.c to pci-common.c" (sha1: bf13a6fa09b8db7f1fd59b5e2ed3674a89a6a25c) completely removed pci_32.c that's why my fixing commit caused the problem with merging and need to be revert. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-07-25Merge branch 'staging-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6 * 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (741 commits) staging:iio:meter:ade7753 should be 16 bit read not 8 bit for mode register. staging:iio:kfifo_buf fix double initialization of the ring device structure. staging:iio:accel:lis3l02dq: fix incorrect pointer passed to spi_set_drvdata. staging:iio:imu fix missing register table index for some channels spectra: enable device before poking it staging: rts_pstor: Fix a miswriting staging/lirc_bt829: Return -ENODEV when no hardware is found. staging/lirc_parallel: remove pointless prototypes. staging/lirc_parallel: fix panic on rmmod staging:iio:adc:ad7476: Incorrect pointer into spi_set_drvdata. Staging: zram: Fix kunmapping order Revert "gma500: Fix dependencies" gma500: Add medfield header gma500: wire up the mrst i2c bus from chip_info gma500: Fix DPU build gma500: Clean up the DPU config and make it runtime gma500: resync with Medfield progress gma500: Use the mrst helpers and power control for mode commit gma500@ Fix backlight range error gma500: More Moorestown muddle meddling means MM maybe might modeset ... Fix up fairly trivial conflicts all over, mostly due to header file cleanup conflicts, but some deleted files and some just context changes: - Documentation/feature-removal-schedule.txt - drivers/staging/bcm/headers.h - drivers/staging/brcm80211/brcmfmac/dhd_linux.c - drivers/staging/brcm80211/brcmfmac/dhd_sdio.c - drivers/staging/brcm80211/brcmfmac/wl_cfg80211.h - drivers/staging/brcm80211/brcmfmac/wl_iw.c - drivers/staging/et131x/et131x_netdev.c - drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c - drivers/staging/rtl8192e/r8192E.h - drivers/staging/usbip/userspace/src/utils.h
2011-07-25Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (115 commits) EHCI: fix direction handling for interrupt data toggles USB: serial: add IDs for WinChipHead USB->RS232 adapter USB: OHCI: fix another regression for NVIDIA controllers usb: gadget: m66592-udc: add pullup function usb: gadget: m66592-udc: add function for external controller usb: gadget: r8a66597-udc: add pullup function usb: renesas_usbhs: support multi driver usb: renesas_usbhs: inaccessible pipe is not an error usb: renesas_usbhs: care buff alignment when dma handler USB: PL2303: correctly handle baudrates above 115200 usb: r8a66597-hcd: fixup USB_PORT_STAT_C_SUSPEND shift usb: renesas_usbhs: compile/config are rescued usb: renesas_usbhs: fixup comment-out usb: update email address in ohci-sh and r8a66597-hcd usb: r8a66597-hcd: add function for external controller EHCI: only power off port if over-current is active USB: mon: Allow to use usbmon without debugfs USB: EHCI: go back to using the system clock for QH unlinks ehci: add pci quirk for Ordissimo and RM Slate 100 too ehci: refactor pci quirk to use standard dmi_check_system method ... Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68k: Revive reporting of spurious interrupts m68knommu: Move forward declaration of do_IRQ() from machdep.h to irq.h m68k: fix some atomic operation asm address modes for ColdFire m68k: use CPU_HAS_NO_BITFIELDS for signal functions m68k: merge and clean up delay.h files m68knommu: correctly use trap_init m68knommu: merge ColdFire 5206 and 5206e platform code m68k: merge mmu and non-mmu bitops.h m68k: merge MMU and non MMU versions of system.h m68k: merge MMU and non-MMU versions of asm/hardirq.h m68k: merge the non-mmu and mmu versions of module.c m68knommu: Fix printk() format in free_initrd_mem() m68knommu: Make empty_zero_page "void *", like on m68k
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-26MIPS: Close races in TLB modify handlers.David Daney
Page table entries are made invalid by writing a zero into the the PTE slot in a page table. This creates a race condition with the TLB modify handlers when they are updating the PTE. CPU0 CPU1 Test for _PAGE_PRESENT . set to not _PAGE_PRESENT (zero) Set to _PAGE_VALID So now the page not present value (zero) is suddenly valid and user space programs have access to physical page zero. We close the race by putting the test for _PAGE_PRESENT and setting of _PAGE_VALID into an atomic LL/SC section. This requires more registers than just K0 and K1 in the handlers, so we need to save some registers to a save area and then restore them when we are done. The save area is an array of cacheline aligned structures that should not suffer cache line bouncing as they are CPU private. [ralf@linux-mips.org: Fix !defined(CONFIG_MIPS_PGD_C0_CONTEXT) build error.] Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2577/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-26MIPS: Add uasm UASM_i_SRL_SAFE macro.David Daney
This can be used from either 32-bit or 64-bit code to generate logical right shifts of any constant amount. Signed-off-by: David Daney <david.daney@cavium.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2576/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25mach-ux500: add lm3530 ALS platform data for U5500Linus Walleij
From: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> platform data for simple backlight driver for LM3530 in the u5500 platform Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Lee Jones <lee.jones@linaro.org> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25notifiers: sys: move reboot notifiers into reboot.hAmerigo Wang
It is not necessary to share the same notifier.h. This patch already moves register_reboot_notifier() and unregister_reboot_notifier() from kernel/notifier.c to kernel/sys.c. [amwang@redhat.com: make allyesconfig succeed on ppc64] Signed-off-by: WANG Cong <amwang@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: remove dead codeRichard Weinberger
GCC 4.6's -Wunused-but-set-variable found some dead code. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: adjust size of pid_bufRichard Weinberger
Linux can have pids up to 4*1024*1024. To handle such huge numbers pid_buf needs to be larger. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: implement a x86_64 vDSORichard Weinberger
Until now UML had no x86_64 vDSO. So glibc always used the vsyscall page for gettimeday() and friends. Calls to gettimeday() returned falsely the host time and confused some programs. This patch adds a vDSO which turns all __vdso_* calls into a system call so that UML can trap them. As glibc still uses the vsyscall page for static binaries this patch improves the situation only for dynamic binaries. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: set __HAVE_ARCH_GATE_AREA for x86_64Richard Weinberger
Implement arch_vma_name() and make get_gate_vma(), in_gate_area() and in_gate_area_no_mm() a nop. We need arch_vma_name() to support vDSO. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: Set __HAVE_ARCH_GATE_AREA for i386Richard Weinberger
When UML is unable to reuse the host's vDSO FIXADDR_USER_START is zero. To handle this special case correclty we have to implement custom gate area helper methods. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: disable scan_elf_aux() on x86_64Richard Weinberger
Reusing the host's vDSO makes only sense on x86_32. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: free resourcesDavidlohr Bueso
When creating the temp file there's a memory and file descriptor leak upon error. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Richard Weinberger <richard@nod.at> Reviewed-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: drivers/slip_user.c memory leak fixVitaliy Ivanov
Do not free memory when you failed to allocate it. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: helper.c warning correctionsVitaliy Ivanov
Fix this warning: arch/um/os-Linux/helper.c: In function `helper_child': arch/um/os-Linux/helper.c:38:7: warning: ignoring return value of `write', declared with attribute warn_unused_result [richard@nod.at: happens only with -D_FORTIFY_SOURCE=2] Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: cow_user.c warning correctionsVitaliy Ivanov
Fix this warning: arch/um/drivers/cow_user.c: In function `absolutize': arch/um/drivers/cow_user.c:189:7: warning: ignoring return value of `chdir', declared with attribute warn_unused_result [richard@nod.at: happens only with -D_FORTIFY_SOURCE=2] Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25uml: drivers/net_user.c memory leak fixVitaliy Ivanov
Perform memory cleanup on exit. On receiving invalid 'pid' we still should clean 'output' variable. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: reinstate kernel version in generated .configGeert Uytterhoeven
Commit 0954828fcbf3 ("kconfig: replace KERNELVERSION usage by the mainmenu's prompt") made the kernel version disappear from the generated .config file when configuring for UML. As UML's Kconfig doesn't have a mainmenu, kconfig falls back to the default string "Linux Kernel Configuration". Add a suitable mainmenu to the main UML Kconfig file to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: add netpoll supportRichard Weinberger
To make netconsole usable on UML, its ethernet driver needs netpoll support. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: fix _FORTIFY_SOURCE=2 support for kernel modulesRichard Weinberger
When UML is compiled with _FORTIFY_SOURCE we have to export all _chk() functions which are used in modules. For now it's only the case for __sprintf_chk(). Tested-by: Florian Fainelli <florian@openwrt.org> Reported-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Vitaliy Ivanov <vitalivanov@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um: clean up delay functionsRichard Weinberger
Both sys-i386 and sys-x86_64 support now ndelay(). The delay functions are based on arch/x86/lib/delay.c. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25um, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so this set_fs(USER_DS) is redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
