Add omap-usb2 data node in omap4 device tree file. Since omap-usb2
is connected to ocp2scp, omap-usb2 dt data is added as a child node
of ocp2scp. The information about this data node is availabe @
Documentation/devicetree/bindings/usb/usb-phy.txt
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Benoit Cousson <benoit.cousson@linaro.org>
Add omap control usb data in omap4 device tree file. This will have the
register address of registers to power on the PHY and to write to
mailbox. The information about this data node is available @
Documentation/devicetree/bindings/usb/omap-usb.txt
Currently the OMAP General-Purpose Memory Controller (GPMC) device
node maps 16 MB of address space for its hardware registers.
This is because the OMAP Technical Reference Manual says that the
GPMC module register address space size is 16 MB. But in practice
the maximum address offset used by a GPMC register is 0x02d0.
So, there is no need to map such a big address space for GPMC regs.
This change was suggested by Jon Hunter [1].
[1]: https://patchwork.kernel.org/patch/2057111/
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Acked-by: Jon Hunter <jon-hunter@ti.com>
Add device-tree support for the GPMC controller on the OMAP3.
Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch>
Add mcspi node and pinmux data for omap5 mcspi controller.
Tested on omap5430 evm with 3.8-rc6 custom kernel.
Signed-off-by: Sourav Poddar <sourav.poddar@ti.com>
Add all 4 mcspi instances to omap5.dtsi file.
Signed-off-by: Felipe Balbi <balbi@ti.com>
[benoit.cousson@linaro.org: Update the subject]
Booting 3.8-rc6 on omap4 panda results in the following error
[ 0.444427] omap_i2c 48070000.i2c: did not get pins for i2c error: -19
[ 0.445770] omap_i2c 48070000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.473937] omap_i2c 48072000.i2c: did not get pins for i2c error: -19
[ 0.474670] omap_i2c 48072000.i2c: bus 1 rev0.11 at 400 kHz
[ 0.474822] omap_i2c 48060000.i2c: did not get pins for i2c error: -19
[ 0.476379] omap_i2c 48060000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.477294] omap_i2c 48350000.i2c: did not get pins for i2c error: -19
[ 0.477996] omap_i2c 48350000.i2c: bus 3 rev0.11 at 400 kHz
[ 0.483398] Switching to clocksource 32k_counter
This happens because omap4 panda dts file is not adapted to use i2c through
pinctrl framework. Populating i2c pinctrl data to get rid of the error.
Tested on omap4460 panda with 3.8-rc6 kernel.
Reported-by: Luciano Coelho <coelho@ti.com>
Booting 3.8-rc6 on omap 5430evm results in the following error
[ 1.024261] omap_i2c 48070000.i2c: bus 0 rev0.12 at 100 kHz
[ 1.030181] omap_i2c 48072000.i2c: did not get pins for i2c error: -19
[ 1.037384] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[ 1.043762] omap_i2c 48060000.i2c: did not get pins for i2c error: -19
[ 1.050964] omap_i2c 48060000.i2c: bus 2 rev0.12 at 100 kHz
[ 1.056823] omap_i2c 4807a000.i2c: did not get pins for i2c error: -19
[ 1.064025] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
This happens because omap5 dts file is not adapted to use i2c through pinctrl
Tested on omap5430 evm with 3.8-rc6 kernel.
Add the needed sections to enable audio support on Overo.
Booting 3.8-rc6 on omap 4430sdp results in the following error
This happens because omap4 dts file is not adapted to use i2c through pinctrl
Tested on omap4430 sdp with 3.8-rc6 kernel.
Reported-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Convert the on-board LED connected to the TWL4030 (LEDB) to use
pwm-leds.
Section to describe the backlight for the LCD panels.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Sections to describe the pwm-leds in the system.
We have proper driver stack to handle the pmu_stat LED which is connected
PWMB of twl4030.
Enable support for the PWMs and LED as PWM drivers.
Enable support for the PWMs and LEDs as PWM drivers.
Add a new address space/memory resource to d_can device tree node. D_CAN
RAM initialization is achieved through RAMINIT register which is part of
AM33XX control module address space. D_CAN RAM init or de-init should be
done by writing instance corresponding value to control module register.
Till we have a separate control module driver to write to control module,
d_can driver will handle the register writes to control module by itself.
So a new address space to represent this control module register is added
to d_can driver.
Signed-off-by: AnilKumar Ch <anilkumar@ti.com>
Acked-by: Marc Kleine-Budde <mkl@pengutronix.de>
Add d_can instances to aliases node to get the D_CAN instance number
from the driver. To initialize D_CAN message RAM, corresponding instance
number is required.
To initialize instance 0 message RAM then 0x1 should be written and for
instance 1 message RAM, 0x2 should be written to control module register.
With device-tree framework ip instance number is "-1" by default for all
instances. To get device id/instance number then modules should be added
to DT "aliases" node. of_alias_get_id() gives the device id number based
on number of alias nodes present in "aliases node".
This is a follow-up to Javier Martinez effort adding initial
device tree support to IGEP technology devices [1].
It adds uart1 and uart2 bindings to the generic dtsi for the IGEP boards.
[1] http://www.spinics.net/lists/linux-omap/msg83409.html
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
ISEE IGEP COM Module is an TI OMAP3 SoC computer on module.
This patch adds an initial device tree support to boot an
IGEP COM Module from the MMC/SD.
Tested-by: Enric Balletbo i Serra <eballetbo@gmail.com>
[b-cousson@ti.com: Update the Makefile for 3.8-rc2]
ISEE IGEPv2 is an TI OMAP3 SoC based embedded board.
an IGEPv2 from the MMC/SD.
Currently is working everything that is supported by DT
on OMAP3 SoCs (MMC/SD, GPIO LEDs, EEPROM, TWL4030 audio).
[benoit.cousson@linaro.org: Update the Makefile for 3.8-rc2]
Add a generic .dtsi device tree source file for the
common characteristics across IGEP Technology devices.
Acked-by: Matthias Brugger <matthias.bgg@gmail.com>
Rename I2C and GPIO nodes according to AM33XX TRM. According to
AM33XX TRM device instances are starting from "0" like i2c0, i2c1
and i2c3.
Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
[panto@antoniou-consulting.com: initial patch by pantelis's]
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into for_3.10/dts_merged
Provide RESET and Power regulators for the USB PHY,
the USB Host port mode and the PHY device.
Also provide pin multiplexer information for USB host
pins.
CC: Benoît Cousson <b-cousson@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
Adds device nodes for HS USB Host module, TLL module,
OHCI and EHCI controllers.
Use usbhs_init_phys() to register the PHY's RESET regulator
and the NOP PHY device.
and NOP PHY device. VAUX2 supplies the PHY's VCC.
and the NOP PHY device. VAUX2 supplies the PHY's VCC.
Use usbhs_init_phys() to register the PHY's RESET regulators
and the NOP PHY devices.
Remove deprecated USBHS platform data.
Use usbhs_init_phys() to register the PHY's VCC and RESET
regulators and the NOP PHY device.
Get rid of managing the PHY clock as it will be done by the PHY driver.
For that to work we create a clock alias that links the PHY clock name
to the PHY device name.
This helper allows board support code to add the PHY's
VCC and RESET regulators which are GPIO controlled as well
as the NOP PHY device.
omap3_noncore_dpll_set_rate() attempts an enable of bypass clk as well
as ref clk for every .set_rate attempt on a noncore DPLL, regardless of
whether the .set_rate results in the DPLL being locked or put in bypass.
Early at boot, while some of these DPLLs are programmed and locked
(using .set_rate for the DPLL), this causes an ordering issue.
For instance, on OMAP5, the USB DPLL derives its bypass clk from ABE DPLL.
If a .set_rate of USB DPLL which programmes the M,N and locks it is called
before the one for ABE, the enable of USB bypass clk (derived from ABE DPLL)
then attempts to lock the ABE DPLL and fails as the M,N values for ABE
are yet to be programmed.
To get rid of this ordering needs, enable bypass clk for a DPLL as part
of its .set_rate only when its being put in bypass, and only enable the
ref clk when its locked.
Reported-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
_pwrdm_save_clkdm_state_and_activate() tried to test one of its
unsigned arguments to determine whether it was less than zero. Fix by
moving the error test to the caller.
Reported-by: Chen Gang <gang.chen@asianux.com>
_HWMOD_WAKEUP_ENABLED is currently unused across the hwmod
framework. Just get rid of it, so we have one less flag to
worry about.
Tested-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
WDT1 module can take one of the below clocks as input functional
clock -
- On-Chip 32K RC Osc [default/reset]
- 32K from PRCM
The On-Chip 32K RC Osc clock is not an accurate clock-source as per
the design/spec, so as a result, for example, timer which supposed
to get expired @60Sec, but will expire somewhere ~@40Sec, which is
not expected by any use-case.
The solution here is to switch the input clock-source to PRCM
generated 32K clock-source during boot-time itself.
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Benoit Cousson <benoit.cousson@linaro.org>
Cc: Paul Walmsley <paul@pwsan.com>
This patch adds sysc definitions to the wdt1 hwmod entry, which in-turn
makes sure that sysc idle bit-fields are configured to valid state on
enable/disable callbacks.
With the recent submitted patch from Santosh Shilimkar,
"ARM: OMAP2+: hwmod: Don't call _init_mpu_rt_base if no sysc"
(commit: 4a98c2d89), it is required to add sysconf
information to each valid hwmod entry, else device will not be
come out from idle state properly and leads to below kernel
crash -
[2.190237] Unhandled fault: external abort on non-linefetch (0x1028) at
0xf9e35034
[2.198325] Internal error: : 1028 [#1] SMP ARM
[2.203101] Modules linked in:
[2.206334] CPU: 0 Not tainted (3.9.0-rc3-00059-gd114294#1)
[2.212679] PC is at omap_wdt_disable.clone.5+0xc/0x60
[2.218090] LR is at omap_wdt_probe+0x184/0x1fc
Commit 3e7fc708eb41 ("ia64 idle: delete pm_idle") in 3.9-rc1 didn't
finish the job, leaving an un-initialized reference to (*idle)().
[ Haven't seen a crash from this - but seems like we are just being
lucky that "idle" is zero so it does get initialized before we jump to
randomland - Len ]
Reported-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
