path: root/arch
2014-09-15ia64: Fix syscall number for memfd_createTony Luck
Cut & paste typo from the line above. Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-14Merge branch 'parisc-3.17-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc updates from Helge Deller: "The most important patch is a new Light Weigth Syscall (LWS) for 8, 16, 32 and 64 bit atomic CAS operations which is required in order to be able to implement the atomic gcc builtins on our platform. Other than that, we wire up the seccomp, getrandom and memfd_create syscalls, fixes a minor off-by-one bug and a wrong printk string" * 'parisc-3.17-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Implement new LWS CAS supporting 64 bit operations. parisc: Wire up seccomp, getrandom and memfd_create syscalls parisc: dino: fix %d confusingly prefixed with 0x in format string parisc: sys_hpux: NUL terminator is one past the end
2014-09-13parisc: Implement new LWS CAS supporting 64 bit operations.Guy Martin
The current LWS cas only works correctly for 32bit. The new LWS allows for CAS operations of variable size. Signed-off-by: Guy Martin <gmsoft@tuxicoman.be> Cc: <stable@vger.kernel.org> # 3.13+ Signed-off-by: Helge Deller <deller@gmx.de>
2014-09-13Make ARCH_HAS_FAST_MULTIPLIER a real config variableLinus Torvalds
It used to be an ad-hoc hack defined by the x86 version of <asm/bitops.h> that enabled a couple of library routines to know whether an integer multiply is faster than repeated shifts and additions. This just makes it use the real Kconfig system instead, and makes x86 (which was the only architecture that did this) select the option. NOTE! Even for x86, this really is kind of wrong. If we cared, we would probably not enable this for builds optimized for netburst (P4), where shifts-and-adds are generally faster than multiplies. This patch does *not* change that kind of logic, though, it is purely a syntactic change with no code changes. This was triggered by the fact that we have other places that really want to know "do I want to expand multiples by constants by hand or not", particularly the hash generation code. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-12Merge tag 'stable/for-linus-3.17-b-rc4-arm-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen ARM bugfix from Stefano Stabellini: "The patches fix the "xen_add_mach_to_phys_entry: cannot add" bug that has been affecting xen on arm and arm64 guests since 3.16. They require a few hypervisor side changes that just went in xen-unstable. A couple of days ago David sent out a pull request with a few other Xen fixes (it is already in master). Sorry we didn't synchronized better among us" * tag 'stable/for-linus-3.17-b-rc4-arm-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/arm: remove mach_to_phys rbtree xen/arm: reimplement xen_dma_unmap_page & friends xen/arm: introduce XENFEAT_grant_map_identity
2014-09-12Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Will Deacon: "Just a couple of stragglers here: - fix an issue migrating interrupts on CPU hotplug - fix a potential information leak of TLS registers across an exec (Nathan has sent a corresponding patch for arch/arm/ to rmk)" * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: flush TLS registers during exec arm64: use irq_set_affinity with force=false when migrating irqs
2014-09-12Merge tag 'fbdev-fixes-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev fixes from Tomi Valkeinen: "Minor fixes for amba-clcd and video DT bindings" * tag 'fbdev-fixes-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: video: ARM CLCD: Fix color model capabilities for DT platforms video: fix composite video connector compatible string
2014-09-11Merge tag 'stable/for-linus-3.17-b-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bug fixes from David Vrabel: - fix for PVHVM suspend/resume and migration - don't pointlessly retry certain ballooning ops - fix gntalloc when grefs have run out. - fix PV boot if KSALR is enable or very large modules are used. * tag 'stable/for-linus-3.17-b-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: x86/xen: don't copy bogus duplicate entries into kernel page tables xen/gntalloc: safely delete grefs in add_grefs() undo path xen/gntalloc: fix oops after runnning out of grant refs xen/balloon: cancel ballooning if adding new memory failed xen/manage: Always freeze/thaw processes when suspend/resuming
2014-09-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc fixes from Michael Ellerman: "Ben's travelling so this is my first attempt at a pull request. There's nothing too exciting. The CONFIG_FHANDLE one is annoying, I know you love defconfig changes. But we've had a couple of developers waste time debugging boxes that wouldn't boot, only to realise it's just that systemd needs CONFIG_FHANDLE and our defconfigs don't have it. The new syscalls seem to be working, I've run the selftests that exist, and also let trinity bash on them for a while" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: powerpc: Wire up sys_seccomp(), sys_getrandom() and sys_memfd_create() powerpc: Make CONFIG_FHANDLE=y for all 64 bit powerpc defconfigs powerpc: use machine_subsys_initcall() for opal_hmi_handler_init() powerpc/perf: Fix ABIv2 kernel backtraces powerpc/pseries: Fix endian issues in memory hotplug
2014-09-11xen/arm: remove mach_to_phys rbtreeStefano Stabellini
Remove the rbtree used to keep track of machine to physical mappings: the frontend can grant the same page multiple times, leading to errors inserting or removing entries from the mach_to_phys tree. Linux only needed to know the physical address corresponding to a given machine address in swiotlb-xen. Now that swiotlb-xen can call the xen_dma_* functions passing the machine address directly, we can remove it. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Tested-by: Denis Schneider <v1ne2go@gmail.com>
2014-09-11xen/arm: reimplement xen_dma_unmap_page & friendsStefano Stabellini
xen_dma_unmap_page, xen_dma_sync_single_for_cpu and xen_dma_sync_single_for_device are currently implemented by calling into the corresponding generic ARM implementation of these functions. In order to do this, firstly the dma_addr_t handle, that on Xen is a machine address, needs to be translated into a physical address. The operation is expensive and inaccurate, given that a single machine address can correspond to multiple physical addresses in one domain, because the same page can be granted multiple times by the frontend. To avoid this problem, we introduce a Xen specific implementation of xen_dma_unmap_page, xen_dma_sync_single_for_cpu and xen_dma_sync_single_for_device, that can operate on machine addresses directly. The new implementation relies on the fact that the hypervisor creates a second p2m mapping of any grant pages at physical address == machine address of the page for dom0. Therefore we can access memory at physical address == dma_addr_r handle and perform the cache flushing there. Some cache maintenance operations require a virtual address. Instead of using ioremap_cache, that is not safe in interrupt context, we allocate a per-cpu PAGE_KERNEL scratch page and we manually update the pte for it. arm64 doesn't need cache maintenance operations on unmap for now. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Tested-by: Denis Schneider <v1ne2go@gmail.com>
2014-09-11xen/arm: introduce XENFEAT_grant_map_identityStefano Stabellini
The flag tells us that the hypervisor maps a grant page to guest physical address == machine address of the page in addition to the normal grant mapping address. It is needed to properly issue cache maintenance operation at the completion of a DMA operation involving a foreign grant. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Tested-by: Denis Schneider <v1ne2go@gmail.com>
2014-09-11arm64: flush TLS registers during execWill Deacon
Nathan reports that we leak TLS information from the parent context during an exec, as we don't clear the TLS registers when flushing the thread state. This patch updates the flushing code so that we: (1) Unconditionally zero the tpidr_el0 register (since this is fully context switched for native tasks and zeroed for compat tasks) (2) Zero the tp_value state in thread_info before clearing the tpidrr0_el0 register for compat tasks (since this is only writable by the set_tls compat syscall and therefore not fully switched). A missing compiler barrier is also added to the compat set_tls syscall. Cc: <stable@vger.kernel.org> Acked-by: Nathan Lynch <Nathan_Lynch@mentor.com> Reported-by: Nathan Lynch <Nathan_Lynch@mentor.com> Signed-off-by: Will Deacon <will.deacon@arm.com>
2014-09-10sh: get_user_pages_fast() must flush cacheStas Sergeev
This patch avoids fuse hangs on sh4 by flushing the cache on get_user_pages_fast(). This is not necessary a good thing to do, but get_user_pages() does this, so get_user_pages_fast() should too. Please note the patch for mips arch that addresses the similar problem: https://kernel.googlesource.com/pub/scm/linux/kernel/git/ralf/linux/+/linux-3.4.50%5E!/#F0 They basically simply disable get_user_pages_fast() at all, using a fall-back to get_user_pages(). But my fix is different, it adds an explicit cache flushes. Signed-off-by: Stas Sergeev <stsp@users.sourceforge.net> Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Kamal Dasu <kdasu.kdev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-09-10x86/xen: don't copy bogus duplicate entries into kernel page tablesStefan Bader
When RANDOMIZE_BASE (KASLR) is enabled; or the sum of all loaded modules exceeds 512 MiB, then loading modules fails with a warning (and hence a vmalloc allocation failure) because the PTEs for the newly-allocated vmalloc address space are not zero. WARNING: CPU: 0 PID: 494 at linux/mm/vmalloc.c:128 vmap_page_range_noflush+0x2a1/0x360() This is caused by xen_setup_kernel_pagetables() copying level2_kernel_pgt into level2_fixmap_pgt, overwriting many non-present entries. Without KASLR, the normal kernel image size only covers the first half of level2_kernel_pgt and module space starts after that. L4[511]->level3_kernel_pgt[510]->level2_kernel_pgt[ 0..255]->kernel [256..511]->module [511]->level2_fixmap_pgt[ 0..505]->module This allows 512 MiB of of module vmalloc space to be used before having to use the corrupted level2_fixmap_pgt entries. With KASLR enabled, the kernel image uses the full PUD range of 1G and module space starts in the level2_fixmap_pgt. So basically: L4[511]->level3_kernel_pgt[510]->level2_kernel_pgt[0..511]->kernel [511]->level2_fixmap_pgt[0..505]->module And now no module vmalloc space can be used without using the corrupt level2_fixmap_pgt entries. Fix this by properly converting the level2_fixmap_pgt entries to MFNs, and setting level1_fixmap_pgt as read-only. A number of comments were also using the the wrong L3 offset for level2_kernel_pgt. These have been corrected. Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: stable@vger.kernel.org
2014-09-09Merge tag 'microblaze-3.17-rc5' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
Pull arch/microblaze fixes from Michal Simek: - Kconfig menu structure fix - fix number of syscalls - fix compilation warnings from allmodconfig * tag 'microblaze-3.17-rc5' of git://git.monstr.eu/linux-2.6-microblaze: microblaze: Fix number of syscalls microblaze: Rename Advance setup to Kernel features microblaze: Add mm/Kconfig to advance menu arch/microblaze/include/asm/uaccess.h: Use pr_devel() instead of pr_debug() arch/microblaze/include/asm/entry.h: Include "linux/linkage.h" to avoid compiling issue
2014-09-09microblaze: Fix number of syscallsMichal Simek
Number of syscalls have to be updated too. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-09-09microblaze: Rename Advance setup to Kernel featuresMichal Simek
"Advance setup: menu is misleading that's why rename it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-09-09microblaze: Add mm/Kconfig to advance menuMichal Simek
mm/Kconfig is getting too big to be in root menu. Move it to submenu. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-09-09arch/microblaze/include/asm/uaccess.h: Use pr_devel() instead of pr_debug()Chen Gang
When DYNAMIC_DEBUG enabled, pr_debug() depends on KBUILD_MODNAME which also depends on the modules number in Makefile. The related information in "scripts/Makefile.lib" line 94: # $(modname_flags) #defines KBUILD_MODNAME as the name of the module it will # end up in (or would, if it gets compiled in) # Note: Files that end up in two or more modules are compiled without the # KBUILD_MODNAME definition. The reason is that any made-up name would # differ in different configs. For this case, 'radio-si470x-i2c.o' and 'radio-si470x-common.o' are in one line, so cause compiling issue. And 'uaccess.h' is a common shared header (not specially for drivers), so use pr_devel() instead of is OK. The related error with allmodconfig: CC [M] drivers/media/radio/si470x/radio-si470x-i2c.o CC [M] drivers/media/radio/si470x/radio-si470x-common.o In file included from include/linux/printk.h:257:0, from include/linux/kernel.h:13, from drivers/media/radio/si470x/radio-si470x.h:29, from drivers/media/radio/si470x/radio-si470x-common.c:115: ./arch/microblaze/include/asm/uaccess.h: In function 'access_ok': include/linux/dynamic_debug.h:66:14: error: 'KBUILD_MODNAME' undeclared (first use in this function) .modname = KBUILD_MODNAME, \ ^ include/linux/dynamic_debug.h:76:2: note: in expansion of macro 'DEFINE_DYNAMIC_DEBUG_METADATA' DEFINE_DYNAMIC_DEBUG_METADATA(descriptor, fmt); \ ^ include/linux/printk.h:263:2: note: in expansion of macro 'dynamic_pr_debug' dynamic_pr_debug(fmt, ##__VA_ARGS__) ^ ./arch/microblaze/include/asm/uaccess.h:101:3: note: in expansion of macro 'pr_debug' pr_debug("ACCESS fail: %s at 0x%08x (size 0x%x), seg 0x%08x\n", ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-09-09arch/microblaze/include/asm/entry.h: Include "linux/linkage.h" to avoid ↵Chen Gang
compiling issue "entry.h" needs 'asmlinkage', and "asm/linkage.h" does not provide it. So need include "linux/linkage.h" to use generic one instead of. The related error (with allmodconfig under microblaze): CC [M] drivers/net/ethernet/emulex/benet/be_main.o In file included from ./arch/microblaze/include/asm/processor.h:17:0, from include/linux/prefetch.h:14, from drivers/net/ethernet/emulex/benet/be_main.c:18: ./arch/microblaze/include/asm/entry.h:33:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'void' extern asmlinkage void do_notify_resume(struct pt_regs *regs, int in_syscall); ^ Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-09-09powerpc: Wire up sys_seccomp(), sys_getrandom() and sys_memfd_create()Pranith Kumar
This patch wires up three new syscalls for powerpc. The three new syscalls are seccomp, getrandom and memfd_create. Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
2014-09-09powerpc: Make CONFIG_FHANDLE=y for all 64 bit powerpc defconfigsCyril Bur
CONFIG_FHANDLE is a requirement for systemd and with the increasing uptake of systemd within distros it makes sense for 64 bit defconfigs to include it. Signed-off-by: Cyril Bur <cyril.bur@au1.ibm.com>
2014-09-09powerpc: use machine_subsys_initcall() for opal_hmi_handler_init()Li Zhong
As opal_message_init() uses machine_early_initcall(powernv, ), and opal_hmi_handler_init() depends on that early initcall, so it also needs use machine_* to check the machine_id. Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
2014-09-09powerpc/perf: Fix ABIv2 kernel backtracesAnton Blanchard
ABIv2 kernels are failing to backtrace through the kernel. An example: 39.30% readseek2_proce [kernel.kallsyms] [k] find_get_entry | --- find_get_entry __GI___libc_read The problem is in valid_next_sp() where we check that the new stack pointer is at least STACK_FRAME_OVERHEAD below the previous one. ABIv1 has a minimum stack frame size of 112 bytes consisting of 48 bytes and 64 bytes of parameter save area. ABIv2 changes that to 32 bytes with no paramter save area. STACK_FRAME_OVERHEAD is in theory the minimum stack frame size, but we over 240 uses of it, some of which assume that it includes space for the parameter area. We need to work through all our stack defines and rationalise them but let's fix perf now by creating STACK_FRAME_MIN_SIZE and using in valid_next_sp(). This fixes the issue: 30.64% readseek2_proce [kernel.kallsyms] [k] find_get_entry | --- find_get_entry pagecache_get_page generic_file_read_iter new_sync_read vfs_read sys_read syscall_exit __GI___libc_read Cc: stable@vger.kernel.org # 3.16+ Reported-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org>
2014-09-09powerpc/pseries: Fix endian issues in memory hotplugThomas Falcon
Values acquired from Open Firmware are in 32-bit big endian format and need to be handled on little endian architectures. This patch ensures values are in cpu endian when hotplugging memory. Signed-off-by: Thomas Falcon <tlfalcon@linux.vnet.ibm.com>
2014-09-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "A bug fix for the vdso code, the loadparm for booting from SCSI is added and the access permissions for the dasd module parameters are corrected" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/vdso: remove NULL pointer check from clock_gettime s390/ipl: Add missing SCSI loadparm attributes to /sys/firmware s390/dasd: Make module parameter visible in sysfs
2014-09-06Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "A smattering of bug fixes across most architectures" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: powerpc/kvm/cma: Fix panic introduces by signed shift operation KVM: s390/mm: Fix guest storage key corruption in ptep_set_access_flags KVM: s390/mm: Fix storage key corruption during swapping arm/arm64: KVM: Complete WFI/WFE instructions ARM/ARM64: KVM: Nuke Hyp-mode tlbs before enabling MMU KVM: s390/mm: try a cow on read only pages for key ops KVM: s390: Fix user triggerable bug in dead code
2014-09-06Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Kevin Hilman: "Another round of fixes from arm-soc land, which are mostly DT fixes for: - OMAP: handful of DT fixes devices on newly supported hardware - davinci: fix 2nd EDMA channel - ux500: extend previous pinctrl fix to another board - at91: clock registration fixes, compatibility string precision And one more fix for event cleanup in drivers/bus/arm-ccn" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: bus: arm-ccn: Move event cleanup routine ARM: at91/dt: rm9200: fix usb clock definition ARM: at91: rm9200: fix clock registration ARM: at91/dt: sam9g20: set at91sam9g20 pllb driver ARM: dts: dra7-evm: Add vtt regulator support ARM: dts: dra7-evm: Fix spi1 mux documentation ARM: dts: am43x-epos-evm: Disable QSPI to prevent conflict with GPMC-NAND ARM: OMAP2+: gpmc: Don't complain if wait pin is used without r/w monitoring ARM: dts: am43xx-epos-evm: Don't use read/write wait monitoring ARM: dts: am437x-gp-evm: Don't use read/write wait monitoring ARM: dts: am437x-gp-evm: Use BCH16 ECC scheme instead of BCH8 ARM: dts: am43x-epos-evm: Use BCH16 ECC scheme instead of BCH8 ARM: dts: am4372: fix USB regs size ARM: dts: am437x-gp: switch i2c0 to 100KHz ARM: dts: dra7-evm: Fix 8th NAND partition's name ARM: dts: dra7-evm: Fix i2c3 pinmux and frequency ARM: ux500: disable msp2 node on Snowball ARM: edma: Fix configuration parsing for SoCs with multiple eDMA3 CC ARM: dts: set 'ti,set-rate-parent' for dpll4_m5x2 clock
2014-09-05Merge tag 'at91-fixes' of git://github.com/at91linux/linux-at91 into fixesKevin Hilman
Merge "at91: fixes for 3.17 #1" from Nicols Ferre: First AT91 fixes batch for 3.17: - compatibility string precision - clock registration and USB DT fix for at91rm9200 * tag 'at91-fixes' of git://github.com/at91linux/linux-at91: ARM: at91/dt: rm9200: fix usb clock definition ARM: at91: rm9200: fix clock registration ARM: at91/dt: sam9g20: set at91sam9g20 pllb driver Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-09-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: "Wire up new syscalls getrandom and memfd_create" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k: Wire up memfd_create m68k: Wire up getrandom
2014-09-05ARM: at91/dt: rm9200: fix usb clock definitionAlexandre Belloni
The atmel,clk-divisors property is taking 4 divisors, if less are provided, the clock registration will fail. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-05ARM: at91: rm9200: fix clock registrationAlexandre Belloni
Actually register clocks from device tree when using the common clock framework. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> [nicolas.ferre@atmel.com: add at91 to function name] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-05ARM: at91/dt: sam9g20: set at91sam9g20 pllb driverGaël PORTAY
The at91sam9g20 SOC uses its own pllb implementation which is different from the one inherited from at91sam9260 SOC. Signed-off-by: Gaël PORTAY <gael.portay@gmail.com> Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2014-09-05Merge tag 'omap-fixes-against-v3.17-rc3' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Merge "omap fixes against v3.17-rc3" from Tony Lindgren: Few fixes for omaps mostly for various devices to get them working properly on the new am437x and dra7 hardware for several devices such as I2C, NAND, DDR3 and USB. There's also a clock fix for omap3. And also included are two minor cosmetic fixes that are not stictly fixes for the new hardware support added recently to downgrade a GPMC warning into a debug statement, and fix the confusing comments for dra7-evm spi1 mux. Note that these are all .dts changes except for a GPMC change. * tag 'omap-fixes-against-v3.17-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (255 commits) ARM: dts: dra7-evm: Add vtt regulator support ARM: dts: dra7-evm: Fix spi1 mux documentation ARM: dts: am43x-epos-evm: Disable QSPI to prevent conflict with GPMC-NAND ARM: OMAP2+: gpmc: Don't complain if wait pin is used without r/w monitoring ARM: dts: am43xx-epos-evm: Don't use read/write wait monitoring ARM: dts: am437x-gp-evm: Don't use read/write wait monitoring ARM: dts: am437x-gp-evm: Use BCH16 ECC scheme instead of BCH8 ARM: dts: am43x-epos-evm: Use BCH16 ECC scheme instead of BCH8 ARM: dts: am4372: fix USB regs size ARM: dts: am437x-gp: switch i2c0 to 100KHz ARM: dts: dra7-evm: Fix 8th NAND partition's name ARM: dts: dra7-evm: Fix i2c3 pinmux and frequency Linux 3.17-rc3 ... Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-09-04Merge tag 'davinci-fixes-for-v3.17-rc4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into fixes This patch fixes setup of second EDMA channel controller on DA850. * tag 'davinci-fixes-for-v3.17-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci: ARM: edma: Fix configuration parsing for SoCs with multiple eDMA3 CC
2014-09-04ARM: dts: dra7-evm: Add vtt regulator supportLokesh Vutla
DRA7 evm REV G and later boards uses a vtt regulator for DDR3 termination and this is controlled by gpio7_11. This gpio is configured in boot loader. gpio7_11, which is only available only on Pad A22, in previous boards, is connected only to an unused pad on expansion connector EXP_P3 and is safe to be muxed as GPIO on all DRA7-evm versions (without a need to spin off another dts file). Since gpio7_11 is used to control VTT and should not be reset or kept in idle state during boot up else VTT will be disconnected and DDR gets corrupted. So, as part of this change, mark gpio7 as no-reset and no-idle on init. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: dra7-evm: Fix spi1 mux documentationNishanth Menon
While auditing the various pin ctrl configurations using the following command: grep PIN_ arch/arm/boot/dts/dra7-evm.dts|(while read line; do v=`echo "$line" | sed -e "s/\s\s*/|/g" | cut -d '|' -f1 | cut -d 'x' -f2|tr [a-z] [A-Z]`; HEX=`echo "obase=16;ibase=16;4A003400+$v"| bc`; echo "$HEX ===> $line"; done) against DRA75x/74x NDA TRM revision S(SPRUHI2S August 2014), documentation errors were found for spi1 pinctrl. Fix the same. Fixes: 6e58b8f1daaf1af ("ARM: dts: DRA7: Add the dts files for dra7 SoC and dra7-evm board") Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: am43x-epos-evm: Disable QSPI to prevent conflict with GPMC-NANDRoger Quadros
Both QSPI and GPMC-NAND share the same Pin (A8) from the SoC for Chip Select functionality. So both can't be enabled simultaneously. Disable QSPI node to prevent the pin conflict as well as be similar to 3.12 release. CC: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: OMAP2+: gpmc: Don't complain if wait pin is used without r/w monitoringRoger Quadros
For NAND read & write wait pin monitoring must be kept disabled as the wait pin is only used to indicate NAND device ready status and not to extend each read/write cycle. So don't print a warning if wait pin is specified while read/write monitoring is not in the device tree. Sanity check wait pin number irrespective if read/write monitoring is set or not. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: am43xx-epos-evm: Don't use read/write wait monitoringRoger Quadros
NAND uses wait pin only to indicate device readiness after a block/page operation. It is not use to extend individual read/write cycle and so read/write wait pin monitoring must be disabled for NAND. Add gpmc wait pin information as the NAND uses wait pin 0 for device ready indication. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: am437x-gp-evm: Don't use read/write wait monitoringRoger Quadros
NAND uses wait pin only to indicate device readiness after a block/page operation. It is not use to extend individual read/write cycle and so read/write wait pin monitoring must be disabled for NAND. This patch also gets rid of the below warning when NAND is accessed for the first time. omap_l3_noc 44000000.ocp: L3 application error: target 13 mod:1 (unclearable) Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: am437x-gp-evm: Use BCH16 ECC scheme instead of BCH8Roger Quadros
am437x-gp-evm uses a NAND chip with page size 4096 bytes and spare area of 225 bytes per page. For such a setup it is preferrable to use BCH16 ECC scheme over BCH8. This also makes it compatible with ROM code ECC scheme so we can boot with NAND after flashing from kernel. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-04ARM: dts: am43x-epos-evm: Use BCH16 ECC scheme instead of BCH8Roger Quadros
am43x-epos-evm uses a NAND chip with page size 4096 bytes and spare area of 225 bytes per page. For such a setup it is preferrable to use BCH16 ECC scheme over BCH8. This also makes it compatible with ROM code ECC scheme so we can boot with NAND after flashing from kernel. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-03ARM: dts: am4372: fix USB regs sizeFelipe Balbi
Size should be 64KiB instead of 92KiB. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-03ARM: dts: am437x-gp: switch i2c0 to 100KHzNishanth Menon
On the GP EVM, the ambient light sensor is limited to 100KHz on the I2C bus. So use 100kHz for I2C on the GP EVM due to this limitation on the ambient light sensor. Reported-by: Aparna Balasubramanian <aparnab@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-03Merge branch 'for-v3.17-rc/ti-clk-dt' of github.com:t-kristo/linux-pm into ↵Tony Lindgren
fixes-rc3
2014-09-03ARM: dts: dra7-evm: Fix 8th NAND partition's nameRoger Quadros
The 8th NAND partition should be named "NAND.u-boot-env.backup1" instead of "NAND.u-boot-env". This is to be consistent with other TI boards as well as u-boot. CC: Pekon Gupta <pekon@pek-sem.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-03ARM: dts: dra7-evm: Fix i2c3 pinmux and frequencyRoger Quadros
The I2C3 pins are taken from pads E21 (GPIO6_14) and F20 (GPIO6_15). Use the right pinmux register and mode. Also set the I2C3 bus frequency to a safer 400KHz than 3.4Mhz. CC: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-09-03arm64: use irq_set_affinity with force=false when migrating irqsSudeep Holla
The arm64 interrupt migration code on cpu offline calls irqchip.irq_set_affinity() with the argument force=true. Originally this argument had no effect because it was not used by any interrupt chip driver and there was no semantics defined. This changed with commit 01f8fa4f01d8 ("genirq: Allow forcing cpu affinity of interrupts") which made the force argument useful to route interrupts to not yet online cpus without checking the target cpu against the cpu online mask. The following commit ffde1de64012 ("irqchip: gic: Support forced affinity setting") implemented this for the GIC interrupt controller. As a consequence the cpu offline irq migration fails if CPU0 is offlined, because CPU0 is still set in the affinity mask and the validation against cpu online mask is skipped to the force argument being true. The following first_cpu(mask) selection always selects CPU0 as the target. Commit 601c942176d8("arm64: use cpu_online_mask when using forced irq_set_affinity") intended to fix the above mentioned issue but introduced another issue where affinity can be migrated to a wrong CPU due to unconditional copy of cpu_online_mask. As with for arm, solve the issue by calling irq_set_affinity() with force=false from the CPU offline irq migration code so the GIC driver validates the affinity mask against CPU online mask and therefore removes CPU0 from the possible target candidates. Also revert the changes done in the commit 601c942176d8 as it's no longer needed. Tested on Juno platform. Fixes: 601c942176d8("arm64: use cpu_online_mask when using forced irq_set_affinity") Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: <stable@vger.kernel.org> # 3.10.x Signed-off-by: Will Deacon <will.deacon@arm.com>
