path: root/arch
2012-10-09Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge patches from Andrew Morton: "A few misc things and very nearly all of the MM tree. A tremendous amount of stuff (again), including a significant rbtree library rework." * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (160 commits) sparc64: Support transparent huge pages. mm: thp: Use more portable PMD clearing sequenece in zap_huge_pmd(). mm: Add and use update_mmu_cache_pmd() in transparent huge page code. sparc64: Document PGD and PMD layout. sparc64: Eliminate PTE table memory wastage. sparc64: Halve the size of PTE tables sparc64: Only support 4MB huge pages and 8KB base pages. memory-hotplug: suppress "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning mm: memcg: clean up mm_match_cgroup() signature mm: document PageHuge somewhat mm: use %pK for /proc/vmallocinfo mm, thp: fix mlock statistics mm, thp: fix mapped pages avoiding unevictable list on mlock memory-hotplug: update memory block's state and notify userspace memory-hotplug: preparation to notify memory block's state at memory hot remove mm: avoid section mismatch warning for memblock_type_name make GFP_NOTRACK definition unconditional cma: decrease cc.nr_migratepages after reclaiming pagelist CMA: migrate mlocked pages kpageflags: fix wrong KPF_THP on non-huge compound pages ...
2012-10-09sparc64: Support transparent huge pages.David Miller
This is relatively easy since PMD's now cover exactly 4MB of memory. Our PMD entries are 32-bits each, so we use a special encoding. The lowest bit, PMD_ISHUGE, determines the interpretation. This is possible because sparc64's page tables are purely software entities so we can use whatever encoding scheme we want. We just have to make the TLB miss assembler page table walkers aware of the layout. set_pmd_at() works much like set_pte_at() but it has to operate in two page from a table of non-huge PTEs, so we have to queue up TLB flushes based upon what mappings are valid in the PTE table. In the second regime we are going from huge-page to non-huge-page, and in that case we need only queue up a single TLB flush to push out the huge page mapping. We still have 5 bits remaining in the huge PMD encoding so we can very likely support any new pieces of THP state tracking that might get added in the future. With lots of help from Johannes Weiner. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: Add and use update_mmu_cache_pmd() in transparent huge page code.David Miller
The transparent huge page code passes a PMD pointer in as the third argument of update_mmu_cache(), which expects a PTE pointer. This never got noticed because X86 implements update_mmu_cache() as a macro and thus we don't get any type checking, and X86 is the only architecture which supports transparent huge pages currently. Before other architectures can support transparent huge pages properly we need to add a new interface which will take a PMD pointer as the third argument rather than a PTE pointer. [akpm@linux-foundation.org: implement update_mm_cache_pmd() for s390] Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09sparc64: Document PGD and PMD layout.David Miller
We're going to be messing around with the PMD interpretation and layout for the sake of transparent huge pages, so we better clearly document what we're starting with. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09sparc64: Eliminate PTE table memory wastage.David Miller
We've split up the PTE tables so that they take up half a page instead of a full page. This is in order to facilitate transparent huge page support, which works much better if our PMDs cover 4MB instead of 8MB. What we do is have a one-behind cache for PTE table allocations in the mm struct. This logic triggers only on allocations. For example, we don't try to keep track of free'd up page table blocks in the style that the s390 port does. There were only two slightly annoying aspects to this change: 1) Changing pgtable_t to be a "pte_t *". There's all of this special logic in the TLB free paths that needed adjustments, as did the PMD populate interfaces. 2) init_new_context() needs to zap the pointer, since the mm struct just gets copied from the parent on fork. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09sparc64: Halve the size of PTE tablesDavid Miller
The reason we want to do this is to facilitate transparent huge page support. Right now PMD's cover 8MB of address space, and our huge page size is 4MB. The current transparent hugepage support is not able to handle HPAGE_SIZE != PMD_SIZE. So make PTE tables be sized to half of a page instead of a full page. We can still map properly the whole supported virtual address range which on sparc64 requires 44 bits. Add a compile time CPP test which ensures that this requirement is always met. There is a minor inefficiency added by this change. We only use half of the page for PTE tables. It's not trivial to use only half of the page yet still get all of the pgtable_page_{ctor,dtor}() stuff working properly. It is doable, and that will come in a subsequent change. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09sparc64: Only support 4MB huge pages and 8KB base pages.David Miller
Narrowing the scope of the page size configurations will make the transparent hugepage changes much simpler. In the end what we really want to do is have the kernel support multiple huge page sizes and use whatever is appropriate as the context dictactes. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09memory-hotplug: suppress "Trying to free nonexistent resource ↵Yasuaki Ishimatsu
<XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" warning When our x86 box calls __remove_pages(), release_mem_region() shows many warnings. And x86 box cannot unregister iomem_resource. "Trying to free nonexistent resource <XXXXXXXXXXXXXXXX-YYYYYYYYYYYYYYYY>" release_mem_region() has been changed to be called in each PAGES_PER_SECTION by commit de7f0cba9678 ("memory hotplug: release memory regions in PAGES_PER_SECTION chunks"). Because powerpc registers iomem_resource in each PAGES_PER_SECTION chunk. But when I hot add memory on x86 box, iomem_resource is register in each _CRS not PAGES_PER_SECTION chunk. So x86 box unregisters iomem_resource. The patch fixes the problem. Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Len Brown <len.brown@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Christoph Lameter <cl@linux.com> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Cc: Nathan Fontenot <nfont@austin.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: thp: fix pmd_present for split_huge_page and PROT_NONE with THPAndrea Arcangeli
In many places !pmd_present has been converted to pmd_none. For pmds that's equivalent and pmd_none is quicker so using pmd_none is better. However (unless we delete pmd_present) we should provide an accurate pmd_present too. This will avoid the risk of code thinking the pmd is non present because it's under __split_huge_page_map, see the pmd_mknotpresent there and the comment above it. If the page has been mprotected as PROT_NONE, it would also lead to a pmd_present false negative in the same way as the race with split_huge_page. Because the PSE bit stays on at all times (both during split_huge_page and when the _PAGE_PROTNONE bit get set), we could only check for the PSE bit, but checking the PROTNONE bit too is still good to remember pmd_present must always keep PROT_NONE into account. This explains a not reproducible BUG_ON that was seldom reported on the lists. The same issue is in pmd_large, it would go wrong with both PROT_NONE and if it races with split_huge_page. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: fix-up zone present pagesJianguo Wu
I think zone->present_pages indicates pages that buddy system can management, it should be: zone->present_pages = spanned pages - absent pages - bootmem pages, but is now: zone->present_pages = spanned pages - absent pages - memmap pages. spanned pages: total size, including holes. absent pages: holes. bootmem pages: pages used in system boot, managed by bootmem allocator. memmap pages: pages used by page structs. This may cause zone->present_pages less than it should be. For example, numa node 1 has ZONE_NORMAL and ZONE_MOVABLE, it's memmap and other bootmem will be allocated from ZONE_MOVABLE, so ZONE_NORMAL's present_pages should be spanned pages - absent pages, but now it also minus memmap pages(free_area_init_core), which are actually allocated from ZONE_MOVABLE. When offlining all memory of a zone, this will cause zone->present_pages less than 0, because present_pages is unsigned long type, it is actually a very large integer, it indirectly caused zone->watermark[WMARK_MIN] becomes a large integer(setup_per_zone_wmarks()), than cause totalreserve_pages become a large integer(calculate_totalreserve_pages()), and finally cause memory allocating failure when fork process(__vm_enough_memory()). [root@localhost ~]# dmesg -bash: fork: Cannot allocate memory I think the bug described in http://marc.info/?l=linux-mm&m=134502182714186&w=2 is also caused by wrong zone present pages. This patch intends to fix-up zone->present_pages when memory are freed to buddy system on x86_64 and IA64 platforms. Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Petr Tesarik <ptesarik@suse.cz> Tested-by: Petr Tesarik <ptesarik@suse.cz> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Minchan Kim <minchan.kim@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09readahead: fault retry breaks mmap file read random detectionShaohua Li
.fault now can retry. The retry can break state machine of .fault. In filemap_fault, if page is miss, ra->mmap_miss is increased. In the second try, since the page is in page cache now, ra->mmap_miss is decreased. And these are done in one fault, so we can't detect random mmap file access. Add a new flag to indicate .fault is tried once. In the second try, skip ra->mmap_miss decreasing. The filemap_fault state machine is ok with it. I only tested x86, didn't test other archs, but looks the change for other archs is obvious, but who knows :) Signed-off-by: Shaohua Li <shaohua.li@fusionio.com> Cc: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09atomic: implement generic atomic_dec_if_positive()Shaohua Li
The x86 implementation of atomic_dec_if_positive is quite generic, so make it available to all architectures. This is needed for "swap: add a simple detector for inappropriate swapin readahead". [akpm@linux-foundation.org: do the "#define foo foo" trick in the conventional manner] Signed-off-by: Shaohua Li <shli@fusionio.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09rbtree: move augmented rbtree functionality to rbtree_augmented.hMichel Lespinasse
Provide rb_insert_augmented() and rb_erase_augmented() through a new rbtree_augmented.h include file. rb_erase_augmented() is defined there as an __always_inline function, in order to allow inlining of augmented rbtree callbacks into it. Since this generates a relatively large function, each augmented rbtree user should make sure to have a single call site. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: replace vma prio_tree with an interval treeMichel Lespinasse
Implement an interval tree as a replacement for the VMA prio_tree. The algorithms are similar to lib/interval_tree.c; however that code can't be directly reused as the interval endpoints are not explicitly stored in the VMA. So instead, the common algorithm is moved into a template and the details (node type, how to get interval endpoints from the node, etc) are filled in using the C preprocessor. Once the interval tree functions are available, using them as a replacement to the VMA prio tree is a relatively simple, mechanical job. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09rbtree: add RB_DECLARE_CALLBACKS() macroMichel Lespinasse
As proposed by Peter Zijlstra, this makes it easier to define the augmented rbtree callbacks. Signed-off-by: Michel Lespinasse <walken@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09rbtree: remove prior augmented rbtree implementationMichel Lespinasse
convert arch/x86/mm/pat_rbtree.c to the proposed augmented rbtree api and remove the old augmented rbtree implementation. Signed-off-by: Michel Lespinasse <walken@google.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp, s390: architecture backend for thp on s390Gerald Schaefer
This implements the architecture backend for transparent hugepages on s390. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp, s390: disable thp for kvm host on s390Gerald Schaefer
This patch is part of the architecture backend for thp on s390. It disables thp for kvm hosts, because there is no kvm host hugepage support so far. Existing thp mappings are split by follow_page() with FOLL_SPLIT, and future thp mappings are prevented by setting VM_NOHUGEPAGE in mm->def_flags. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp, s390: thp pagetable pre-allocation for s390Gerald Schaefer
This patch is part of the architecture backend for thp on s390. It provides the pagetable pre-allocation functions pgtable_trans_huge_deposit() and pgtable_trans_huge_withdraw(). Unlike other archs, s390 has no struct page * as pgtable_t, but rather a pointer to the page table. So instead of saving the pagetable pre- allocation list info inside the struct page, it is being saved within the pagetable itself. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp, s390: thp splitting backend for s390Gerald Schaefer
This patch is part of the architecture backend for thp on s390. It provides the functions related to thp splitting, including serialization against gup. Unlike other archs, pmdp_splitting_flush() cannot use a tlb flushing operation to serialize against gup on s390, because that wouldn't be stopped by the disabled IRQs. So instead, smp_call_function() is called with an empty function, which will have the expected effect. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09thp, x86: introduce HAVE_ARCH_TRANSPARENT_HUGEPAGEGerald Schaefer
Cleanup patch in preparation for transparent hugepage support on s390. Adding new architectures to the TRANSPARENT_HUGEPAGE config option can make the "depends" line rather ugly, like "depends on (X86 || (S390 && 64BIT)) && MMU". This patch adds a HAVE_ARCH_TRANSPARENT_HUGEPAGE instead. x86 already has MMU "def_bool y", so the MMU check is superfluous there and HAVE_ARCH_TRANSPARENT_HUGEPAGE can be selected in arch/x86/Kconfig. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: hugetlb: add arch hook for clearing page flags before entering poolWill Deacon
The core page allocator ensures that page flags are zeroed when freeing pages via free_pages_check. A number of architectures (ARM, PPC, MIPS) rely on this property to treat new pages as dirty with respect to the data cache and perform the appropriate flushing before mapping the pages into userspace. This can lead to cache synchronisation problems when using hugepages, since the allocator keeps its own pool of pages above the usual page allocator and does not reset the page flags when freeing a page into the pool. This patch adds a new architecture hook, arch_clear_hugepage_flags, so that architectures which rely on the page flags being in a particular state for fresh allocations can adjust the flags accordingly when a page is freed into the pool. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Michal Hocko <mhocko@suse.cz> Reviewed-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: kill vma flag VM_RESERVED and mm->reserved_vm counterKonstantin Khlebnikov
A long time ago, in v2.4, VM_RESERVED kept swapout process off VMA, currently it lost original meaning but still has some effects: | effect | alternative flags -+------------------------+--------------------------------------------- 1| account as reserved_vm | VM_IO 2| skip in core dump | VM_IO, VM_DONTDUMP 3| do not merge or expand | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP 4| do not mlock | VM_IO, VM_DONTEXPAND, VM_HUGETLB, VM_PFNMAP This patch removes reserved_vm counter from mm_struct. Seems like nobody cares about it, it does not exported into userspace directly, it only reduces total_vm showed in proc. Thus VM_RESERVED can be replaced with VM_IO or pair VM_DONTEXPAND | VM_DONTDUMP. remap_pfn_range() and io_remap_pfn_range() set VM_IO|VM_DONTEXPAND|VM_DONTDUMP. remap_vmalloc_range() set VM_DONTEXPAND | VM_DONTDUMP. [akpm@linux-foundation.org: drivers/vfio/pci/vfio_pci.c fixup] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm: use mm->exe_file instead of first VM_EXECUTABLE vma->vm_fileKonstantin Khlebnikov
Some security modules and oprofile still uses VM_EXECUTABLE for retrieving a task's executable file. After this patch they will use mm->exe_file directly. mm->exe_file is protected with mm->mmap_sem, so locking stays the same. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [arch/tile] Acked-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> [tomoyo] Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09mm, x86, pat: rework linear pfn-mmap trackingKonstantin Khlebnikov
Replace the generic vma-flag VM_PFN_AT_MMAP with x86-only VM_PAT. We can toss mapping address from remap_pfn_range() into track_pfn_vma_new(), and collect all PAT-related logic together in arch/x86/. This patch also restores orignal frustration-free is_cow_mapping() check in remap_pfn_range(), as it was before commit v2.6.28-rc8-88-g3c8bb73 ("x86: PAT: store vm_pgoff for all linear_over_vma_region mappings - v3") is_linear_pfn_mapping() checks can be removed from mm/huge_memory.c, because it already handled by VM_PFNMAP in VM_NO_THP bit-mask. [suresh.b.siddha@intel.com: Reset the VM_PAT flag as part of untrack_pfn_vma()] Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Venkatesh Pallipadi <venki@google.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Ingo Molnar <mingo@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Venkatesh Pallipadi <venki@google.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09x86, pat: separate the pfn attribute tracking for remap_pfn_range and ↵Suresh Siddha
vm_insert_pfn With PAT enabled, vm_insert_pfn() looks up the existing pfn memory attribute and uses it. Expectation is that the driver reserves the memory attributes for the pfn before calling vm_insert_pfn(). remap_pfn_range() (when called for the whole vma) will setup a new attribute (based on the prot argument) for the specified pfn range. This addresses the legacy usage which typically calls remap_pfn_range() with a desired memory attribute. For ranges smaller than the vma size (which is typically not the case), remap_pfn_range() will use the existing memory attribute for the pfn range. Expose two different API's for these different behaviors. track_pfn_insert() for tracking the pfn attribute set by vm_insert_pfn() and track_pfn_remap() for the remap_pfn_range(). This cleanup also prepares the ground for the track/untrack pfn vma routines to take over the ownership of setting PAT specific vm_flag in the 'vma'. [khlebnikov@openvz.org: Clear checks in track_pfn_remap()] [akpm@linux-foundation.org: tweak a few comments] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Venkatesh Pallipadi <venki@google.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Ingo Molnar <mingo@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09x86, pat: remove the dependency on 'vm_pgoff' in track/untrack pfn vma routinesSuresh Siddha
'pfn' argument for track_pfn_vma_new() can be used for reserving the attribute for the pfn range. No need to depend on 'vm_pgoff' Similarly, untrack_pfn_vma() can depend on the 'pfn' argument if it is non-zero or can use follow_phys() to get the starting value of the pfn range. Also the non zero 'size' argument can be used instead of recomputing it from vma. This cleanup also prepares the ground for the track/untrack pfn vma routines to take over the ownership of setting PAT specific vm_flag in the 'vma'. [khlebnikov@openvz.org: Clear pfn to paddr conversion] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Venkatesh Pallipadi <venki@google.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Ingo Molnar <mingo@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Eric Paris <eparis@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Kentaro Takeda <takedakn@nttdata.co.jp> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the "#if defined(arch)" list for exception-trace sysctl entryCatalin Marinas
Introduce SYSCTL_EXCEPTION_TRACE config option and selec it in the architectures requiring support for the "exception-trace" debug_table entry in kernel/sysctl.c. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the DEBUG_BUGVERBOSE config optionCatalin Marinas
Introduce HAVE_DEBUG_BUGVERBOSE config option and select it in corresponding architecture Kconfig files. Architectures that already select GENERIC_BUG don't need to select HAVE_DEBUG_BUGVERBOSE. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the DEBUG_KMEMLEAK config optionCatalin Marinas
Introduce HAVE_DEBUG_KMEMLEAK config option and select it in corresponding architecture Kconfig files. DEBUG_KMEMLEAK now only depends on HAVE_DEBUG_KMEMLEAK. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Kconfig: clean up the long arch list for the UID16 config optionCatalin Marinas
Introduce HAVE_UID16 config option and select it in corresponding architecture Kconfig files. UID16 now only depends on HAVE_UID16. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09Merge tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa patchset from Chris Zankel: "The Xtensa tree has been broken for some time now, and this patchset brings it back to life. It has been part of the linux-next tree for some time. Most changes are inside the xtensa subdirectory; the other changes mostly add another rule to already existing #ifdefs to exclude Xtensa, where required. The only 'common' change is to add two more sections ('.xt.prop' and '.xt.lit') to the white list in modpost." * tag 'xtensa-next-20121008' of git://github.com/czankel/xtensa-linux: (27 commits) xtensa: Setup CROSS_COMPILE at the top xtensa: drop CONFIG_EMBEDDED_RAMDISK xtensa: fix TIOCGSERIAL and TIOCSSERIAL definitions xtensa: provide dummy gcc intrinsics xtensa: add missing symbol exports parport: disable for xtensa arch xtensa: rename MISC SR definition to avoid name clashes hisax: disable build for big-endian xtensa xtensa: fix CODA build xtensa: fix parallel make xtensa: ISS: drop unused io.c xtensa: ISS: exit simulator in case of halt or poweroff xtensa: ISS: change keyboard polling rate xtensa: ISS: add platform_pcibios_init xtensa: ISS: add dummy serial.h for ISS platform xtensa: change default platform clock frequency to 10MHz xtensa: add ARCH_WANT_OPTIONAL_GPIOLIB to xtensa config xtensa: set NO_IOPORT to 'n' by default xtensa: adopt generic io routines xtensa: fix ioremap ...
2012-10-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin Pull blackfin update from Bob Liu. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lliubbo/blackfin: Blackfin: smp: add smp_mb() to keep coherency Blackfin: drop irq enable in init_arch_irq() Blackfin: fix wrong place disabled irq Blackfin: update defconfig for bf609-ezkit Blackfin: add bf548 v0.4 revision Blackfin: bf60x: Add bf608 and bf609 specific perpheral MMRs Blackfin: cpufreq: fix dpm_state_table Blackfin: bfin_gpio: proc: fix return value Blackfin: CM-BF537E: Update SPORT support in board file. Blackfin: bf537: fix lq035 platform device name Blackfin: bf533-ezkit: enable flash drivers by default
2012-10-09Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS update from Ralf Baechle: "This is the MIPS update for 3.7. A fair chunk of them are platform updates to the Cavium Octeon SOC (which involves machine generated header files of considerable size), Atheros ATH79xx, RMI aka Netlogic aka Broadcom XLP, Broadcom BCM63xx platforms. Support for the commercial MIPS simulator MIPSsim has been removed as MIPS Technologies is shifting away from this product and Qemu is offering various more powerful platforms. The generic MIPS code can now also probe for no-execute / write-only TLB features implemented without the full SmartMIPS extension as permitted by the latest MIPS processor architecture. Lots of small changes to generic code." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (78 commits) MIPS: ath79: Fix CPU/DDR frequency calculation for SRIF PLLs MIPS: ath79: use correct fractional dividers for {CPU,DDR}_PLL on AR934x MIPS: BCM63XX: Properly handle mac address octet overflow MIPS: Kconfig: Avoid build errors by hiding USE_OF from the user. MIPS: Replace `-' in defconfig filename wth `_' for consistency. MIPS: Wire kcmp syscall. MIPS: MIPSsim: Remove the MIPSsim platform. MIPS: NOTIFY_RESUME is not needed in TIF masks MIPS: Merge the identical "return from syscall" per-ABI code MIPS: Unobfuscate _TIF..._MASK MIPS: Prevent hitting do_notify_resume() with !user_mode(regs). MIPS: Replace 'kernel_uses_smartmips_rixi' with 'cpu_has_rixi'. MIPS: Add base architecture support for RI and XI. MIPS: Optimise TLB handlers for MIPS32/64 R2 cores. MIPS: uasm: Add INS and EXT instructions. MIPS: Avoid pipeline stalls on some MIPS32R2 cores. MIPS: Make VPE count to be one-based. MIPS: Add new end of interrupt functionality for GIC. MIPS: Add EIC support for GIC. MIPS: Code clean-ups for the GIC. ...
2012-10-09Merge tag 'asm-generic' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull asm-generic updates from Arnd Bergmann: "This has three changes for asm-generic that did not really fit into any other branch as normal asm-generic changes do. One is a fix for a build warning, the other two are more interesting: * A patch from Mark Brown to allow using the common clock infrastructure on all architectures, so we can use the clock API in architecture independent device drivers. * The UAPI split patches from David Howells for the asm-generic files. There are other architecture specific series that are going through the arch maintainer tree and that depend on this one. There may be a few small merge conflicts between Mark's patch and the following arch header file split patches. In each case the solution will be to keep the new "generic-y += clkdev.h" line, even if it ends up being the only line in the Kbuild file." * tag 'asm-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: UAPI: (Scripted) Disintegrate include/asm-generic asm-generic: Add default clkdev.h asm-generic: xor: mark static functions as __maybe_unused
2012-10-09Merge tag 'sound-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This contains pretty many small commits covering fairly large range of files in sound/ directory. Partly because of additional API support and partly because of constantly developed ASoC and ARM stuff. Some highlights: - Introduced the helper function and documentation for exposing the channel map via control API, as discussed in Plumbers; most of PCI drivers are covered, will follow more drivers later - Most of drivers have been replaced with the new PM callbacks (if the bus is supported) - HD-audio controller got the support of runtime PM and the support of D3 clock-stop. Also changing the power_save option in sysfs kicks off immediately to enable / disable the power-save mode. - Another significant code change in HD-audio is the rewrite of firmware loading code. Other than that, most of changes in HD-audio are continued cleanups and standardization for the generic auto parser and bug fixes (HBR, device-specific fixups), in addition to the support of channel-map API. - Addition of ASoC bindings for the compressed API, used by the mid-x86 drivers. - Lots of cleanups and API refreshes for ASoC codec drivers and DaVinci. - Conversion of OMAP to dmaengine. - New machine driver for Wolfson Microelectronics Bells. - New CODEC driver for Wolfson Microelectronics WM0010. - Enhancements to the ux500 and wm2000 drivers - A new driver for DA9055 and the support for regulator bypass mode." Fix up various arm soc header file reorg conflicts. * tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits) ALSA: hda - Add new codec ALC283 ALC290 support ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls ALSA: hda - fix indices on boost volume on Conexant ALSA: aloop - add locking to timer access ALSA: hda - Fix hang caused by race during suspend. sound: Remove unnecessary semicolon ALSA: hda/realtek - Fix detection of ALC271X codec ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310 ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event ALSA: hda - make a generic unsol event handler ASoC: codecs: Add DA9055 codec driver ASoC: eukrea-tlv320: Convert it to platform driver ALSA: ASoC: add DT bindings for CS4271 ASoC: wm_hubs: Ensure volume updates are handled during class W startup ASoC: wm5110: Adding missing volume update bits ASoC: wm5110: Add OUT3R support ASoC: wm5110: Add AEC loopback support ASoC: wm5110: Rename EPOUT to HPOUT3 ASoC: arizona: Add more clock rates ASoC: arizona: Add more DSP options for mixer input muxes ...
2012-10-09Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 changes from Catalin Marinas: "arm64 fixes: - Use swiotlb_init() instead of swiotlb_init_with_default_size(). The latter is now a static function (commit 74838b75379a "swiotlb: add the late swiotlb initialization function with iotlb memory"). - Enable interrupts before calling do_notify_resume(). arm64 clean-up: - Use the generic implementation of compat_sys_sendfile() on arm64 as commit 8f9c0119d7ba (introducing the function) has been merged." * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: arm64: Enable interrupts before calling do_notify_resume() arm64: Use the generic compat_sys_sendfile() implementation arm64: Call swiotlb_init() instead of swiotlb_init_with_default_size()
2012-10-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc changes from David S Miller: "There is an attempt to fix a bad interaction between syscall tracing and force_successful_syscall() from Al Viro, but it needs to be redone as it introduced regressions and thus had to be reverted for now. Al is working on an updated version. But what we do have here are some significant bzero/memset improvements for Niagara-4. An 8K page can be cleared in around 600 cycles, because we essentially have a store that behaves like powerpc's dcbz that we can actually make real use of." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: Revert strace hiccups fix. sparc64: Niagara-4 bzero/memset, plus use MRU stores in page copy. sparc64: Fix strace hiccups when force_successful_syscall() triggers. sparc64: Rearrange thread info to cheaply clear syscall noerror state.
2012-10-08arm64: Enable interrupts before calling do_notify_resume()Catalin Marinas
task_work_run() implementation had the side effect of enabling interrupts. With commit ac3d0da8 (task_work: Make task_work_add() lockless), interrupts are no longer enabled revealing the bug in the arch code. This patch enables the interrupt explicitly before calling do_notify_resume(). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2012-10-08arm64: Use the generic compat_sys_sendfile() implementationCatalin Marinas
The generic implementation of compat_sys_sendfile() has been introduced by commit 8f9c0119. This patch removes the arm64 implementation in favour of the generic one. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2012-10-08arm64: Call swiotlb_init() instead of swiotlb_init_with_default_size()Catalin Marinas
Following commit 74838b7 (swiotlb: add the late swiotlb initialization function with iotlb memory) the swiotlb_init_with_default_size() is a static function. This patch changes the arm64 code to call swiotlb_init() instead and use the default size of 64MB. It is assumed that AArch64 platforms have enough RAM to afford the pre-allocated swiotlb memory. It also removes the #ifdef around this call since CONFIG_SWIOTLB is always enabled. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2012-10-08Blackfin: smp: add smp_mb() to keep coherencySteven Miao
After use generic smp helpers, smp_mb() should be added to keep coherency. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-10-08Blackfin: drop irq enable in init_arch_irq()Steven Miao
Kernel common code will enable irq, drop it in init_arch_irq(). Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-10-08Blackfin: fix wrong place disabled irqSteven Miao
Shouldn't disable irq before send ipi. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-10-08Blackfin: update defconfig for bf609-ezkitBob Liu
2012-10-08Blackfin: add bf548 v0.4 revisionSonic Zhang
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-10-08Blackfin: bf60x: Add bf608 and bf609 specific perpheral MMRsSonic Zhang
2012-10-08Blackfin: cpufreq: fix dpm_state_tableJames Cosin
This patch fixes an assumption that cclk's initial divisor will always be 1 (or 0 in the register). TSCALE is always initialized on startup with a value of 4 regardless of the inital cclk divisor; so, we can't make the assumption without making lots of other assumptions. The TPERIOD value is set with a value of the current cclk (value / (HZ * TSCALE)) - 1; so, we need to adjust based on this initial frequency and not use cclk's initial divisor for adjusting the tscale. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2012-10-08Blackfin: bfin_gpio: proc: fix return valueSteven Miao
2012-10-08Blackfin: CM-BF537E: Update SPORT support in board file.Harald Krapfenbauer
Signed-off-by: Harald Krapfenbauer <harald.krapfenbauer@bluetechnix.at> Signed-off-by: Bob Liu <lliubbo@gmail.com>
