This is the 4.4.14 stable release
The audio Codec Machine driver was missing hence the sound card
got not detected by the SAI driver.
While at it also enable L2 switch and IIO sysfs trigger.
Add support for Ethernet Switch (ESW)
commit d7de413475f443957a0c1d256e405d19b3a2cb22 upstream.
TASK_SIZE was defined as 0x7fff8000UL which for 64k pages is not a
multiple of the page size. Somewhere further down the math fails
such that executing an ELF binary fails.
Tested-by: Joshua Henderson <joshua.henderson@microchip.com>
Cc: James Hogan <james.hogan@imgtec.com>
[ Upstream commit 7cafc0b8bf130f038b0ec2dcdd6a9de6dc59b65a ]
We must handle data access exception as well as memory address unaligned
exceptions from return from trap window fill faults, not just normal
TLB misses.
Otherwise we can get an OOPS that looks like this:
ld-linux.so.2(36808): Kernel bad sw trap 5 [#1]
CPU: 1 PID: 36808 Comm: ld-linux.so.2 Not tainted 4.6.0 #34
task: fff8000303be5c60 ti: fff8000301344000 task.ti: fff8000301344000
TSTATE: 0000004410001601 TPC: 0000000000a1a784 TNPC: 0000000000a1a788 Y: 00000002 Not tainted
TPC: <do_sparc64_fault+0x5c4/0x700>
g0: fff8000024fc8248 g1: 0000000000db04dc g2: 0000000000000000 g3: 0000000000000001
g4: fff8000303be5c60 g5: fff800030e672000 g6: fff8000301344000 g7: 0000000000000001
o0: 0000000000b95ee8 o1: 000000000000012b o2: 0000000000000000 o3: 0000000200b9b358
o4: 0000000000000000 o5: fff8000301344040 sp: fff80003013475c1 ret_pc: 0000000000a1a77c
RPC: <do_sparc64_fault+0x5bc/0x700>
l0: 00000000000007ff l1: 0000000000000000 l2: 000000000000005f l3: 0000000000000000
l4: fff8000301347e98 l5: fff8000024ff3060 l6: 0000000000000000 l7: 0000000000000000
i0: fff8000301347f60 i1: 0000000000102400 i2: 0000000000000000 i3: 0000000000000000
i4: 0000000000000000 i5: 0000000000000000 i6: fff80003013476a1 i7: 0000000000404d4c
I7: <user_rtt_fill_fixup+0x6c/0x7c>
Call Trace:
[0000000000404d4c] user_rtt_fill_fixup+0x6c/0x7c
The window trap handlers are slightly clever, the trap table entries for them are
composed of two pieces of code. First comes the code that actually performs
the window fill or spill trap handling, and then there are three instructions at
the end which are for exception processing.
The userland register window fill handler is:
add %sp, STACK_BIAS + 0x00, %g1; \
ldxa [%g1 + %g0] ASI, %l0; \
mov 0x08, %g2; \
mov 0x10, %g3; \
ldxa [%g1 + %g2] ASI, %l1; \
mov 0x18, %g5; \
ldxa [%g1 + %g3] ASI, %l2; \
ldxa [%g1 + %g5] ASI, %l3; \
add %g1, 0x20, %g1; \
ldxa [%g1 + %g0] ASI, %l4; \
ldxa [%g1 + %g2] ASI, %l5; \
ldxa [%g1 + %g3] ASI, %l6; \
ldxa [%g1 + %g5] ASI, %l7; \
ldxa [%g1 + %g0] ASI, %i0; \
ldxa [%g1 + %g2] ASI, %i1; \
ldxa [%g1 + %g3] ASI, %i2; \
ldxa [%g1 + %g5] ASI, %i3; \
ldxa [%g1 + %g0] ASI, %i4; \
ldxa [%g1 + %g2] ASI, %i5; \
ldxa [%g1 + %g3] ASI, %i6; \
ldxa [%g1 + %g5] ASI, %i7; \
restored; \
retry; nop; nop; nop; nop; \
b,a,pt %xcc, fill_fixup_dax; \
b,a,pt %xcc, fill_fixup_mna; \
b,a,pt %xcc, fill_fixup;
And the way this works is that if any of those memory accesses
generate an exception, the exception handler can revector to one of
those final three branch instructions depending upon which kind of
exception the memory access took. In this way, the fault handler
doesn't have to know if it was a spill or a fill that it's handling
the fault for. It just always branches to the last instruction in
the parent trap's handler.
For example, for a regular fault, the code goes:
winfix_trampoline:
rdpr %tpc, %g3
or %g3, 0x7c, %g3
wrpr %g3, %tnpc
done
All window trap handlers are 0x80 aligned, so if we "or" 0x7c into the
trap time program counter, we'll get that final instruction in the
trap handler.
On return from trap, we have to pull the register window in but we do
this by hand instead of just executing a "restore" instruction for
several reasons. The largest being that from Niagara and onward we
simply don't have enough levels in the trap stack to fully resolve all
possible exception cases of a window fault when we are already at
trap level 1 (which we enter to get ready to return from the original
trap).
This is executed inline via the FILL_*_RTRAP handlers. rtrap_64.S's
code branches directly to these to do the window fill by hand if
necessary. Now if you look at them, we'll see at the end:
ba,a,pt %xcc, user_rtt_fill_fixup;
And oops, all three cases are handled like a fault.
This doesn't work because each of these trap types (data access
exception, memory address unaligned, and faults) store their auxiliary
info in different registers to pass on to the C handler which does the
real work.
So in the case where the stack was unaligned, the unaligned trap
handler sets up the arg registers one way, and then we branched to
the fault handler which expects them setup another way.
So the FAULT_TYPE_* value ends up basically being garbage, and
randomly would generate the backtrace seen above.
Reported-by: Nick Alcock <nix@esperi.org.uk>
[ Upstream commit d11c2a0de2824395656cf8ed15811580c9dd38aa ]
All signal frames must be at least 16-byte aligned, because that is
the alignment we explicitly create when we build signal return stack
frames.
All stack pointers must be at least 8-byte aligned.
[ Upstream commit 9ea46abe22550e3366ff7cee2f8391b35b12f730 ]
On cheetahplus chips we take the ctx_alloc_lock in order to
modify the TLB lookup parameters for the indexed TLBs, which
are stored in the context register.
This is called with interrupts disabled, however ctx_alloc_lock
is an IRQ safe lock, therefore we must take acquire/release it
properly with spin_{lock,unlock}_irq().
Reported-by: Meelis Roos <mroos@linux.ee>
Tested-by: Meelis Roos <mroos@linux.ee>
[ Upstream commit 24e49ee3d76b70853a96520e46b8837e5eae65b2 ]
During hugepage map/unmap, TSB and TLB flushes are currently
issued at every PAGE_SIZE'd boundary which is unnecessary.
We now issue the flush at REAL_HPAGE_SIZE boundaries only.
Without this patch workloads which unmap a large hugepage
backed VMA region get CPU lockups due to excessive TLB
flush calls.
Orabug: 22365539, 22643230, 22995196
Signed-off-by: Nitin Gupta <nitin.m.gupta@oracle.com>
[ Upstream commit d0c31e02005764dae0aab130a57e9794d06b824d ]
We noticed this panic while enabling SR-IOV in sparc.
mlx4_core: Mellanox ConnectX core driver v2.2-1 (Jan 1 2015)
mlx4_core: Initializing 0007:01:00.0
mlx4_core 0007:01:00.0: Enabling SR-IOV with 5 VFs
mlx4_core: Initializing 0007:01:00.1
Unable to handle kernel NULL pointer dereference
insmod(10010): Oops [#1]
CPU: 391 PID: 10010 Comm: insmod Not tainted
4.1.12-32.el6uek.kdump2.sparc64 #1
TPC: <dma_supported+0x20/0x80>
I7: <__mlx4_init_one+0x324/0x500 [mlx4_core]>
Call Trace:
[00000000104c5ea4] __mlx4_init_one+0x324/0x500 [mlx4_core]
[00000000104c613c] mlx4_init_one+0xbc/0x120 [mlx4_core]
[0000000000725f14] local_pci_probe+0x34/0xa0
[0000000000726028] pci_call_probe+0xa8/0xe0
[0000000000726310] pci_device_probe+0x50/0x80
[000000000079f700] really_probe+0x140/0x420
[000000000079fa24] driver_probe_device+0x44/0xa0
[000000000079fb5c] __device_attach+0x3c/0x60
[000000000079d85c] bus_for_each_drv+0x5c/0xa0
[000000000079f588] device_attach+0x88/0xc0
[000000000071acd0] pci_bus_add_device+0x30/0x80
[0000000000736090] virtfn_add.clone.1+0x210/0x360
[00000000007364a4] sriov_enable+0x2c4/0x520
[000000000073672c] pci_enable_sriov+0x2c/0x40
[00000000104c2d58] mlx4_enable_sriov+0xf8/0x180 [mlx4_core]
[00000000104c49ac] mlx4_load_one+0x42c/0xd40 [mlx4_core]
Disabling lock debugging due to kernel taint
Caller[00000000104c5ea4]: __mlx4_init_one+0x324/0x500 [mlx4_core]
Caller[00000000104c613c]: mlx4_init_one+0xbc/0x120 [mlx4_core]
Caller[0000000000725f14]: local_pci_probe+0x34/0xa0
Caller[0000000000726028]: pci_call_probe+0xa8/0xe0
Caller[0000000000726310]: pci_device_probe+0x50/0x80
Caller[000000000079f700]: really_probe+0x140/0x420
Caller[000000000079fa24]: driver_probe_device+0x44/0xa0
Caller[000000000079fb5c]: __device_attach+0x3c/0x60
Caller[000000000079d85c]: bus_for_each_drv+0x5c/0xa0
Caller[000000000079f588]: device_attach+0x88/0xc0
Caller[000000000071acd0]: pci_bus_add_device+0x30/0x80
Caller[0000000000736090]: virtfn_add.clone.1+0x210/0x360
Caller[00000000007364a4]: sriov_enable+0x2c4/0x520
Caller[000000000073672c]: pci_enable_sriov+0x2c/0x40
Caller[00000000104c2d58]: mlx4_enable_sriov+0xf8/0x180 [mlx4_core]
Caller[00000000104c49ac]: mlx4_load_one+0x42c/0xd40 [mlx4_core]
Caller[00000000104c5f90]: __mlx4_init_one+0x410/0x500 [mlx4_core]
Caller[000000000079fb08]: __driver_attach+0x88/0xa0
Caller[000000000079d90c]: bus_for_each_dev+0x6c/0xa0
Caller[000000000079f29c]: driver_attach+0x1c/0x40
Caller[000000000079e35c]: bus_add_driver+0x17c/0x220
Caller[00000000007a02d4]: driver_register+0x74/0x120
Caller[00000000007263fc]: __pci_register_driver+0x3c/0x60
Caller[00000000104f62bc]: mlx4_init+0x60/0xcc [mlx4_core]
Kernel panic - not syncing: Fatal exception
Press Stop-A (L1-A) to return to the boot prom
---[ end Kernel panic - not syncing: Fatal exception
Details:
Here is the call sequence
virtfn_add->__mlx4_init_one->dma_set_mask->dma_supported
The panic happened at line 760(file arch/sparc/kernel/iommu.c)
758 int dma_supported(struct device *dev, u64 device_mask)
759 {
760 struct iommu *iommu = dev->archdata.iommu;
761 u64 dma_addr_mask = iommu->dma_addr_mask;
762
763 if (device_mask >= (1UL << 32UL))
764 return 0;
765
766 if ((device_mask & dma_addr_mask) == dma_addr_mask)
767 return 1;
768
769 #ifdef CONFIG_PCI
770 if (dev_is_pci(dev))
771 return pci64_dma_supported(to_pci_dev(dev), device_mask);
772 #endif
773
774 return 0;
775 }
776 EXPORT_SYMBOL(dma_supported);
Same panic happened with Intel ixgbe driver also.
SR-IOV code looks for arch specific data while enabling
VFs. When VF device is added, driver probe function makes set
of calls to initialize the pci device. Because the VF device is
added different way than the normal PF device(which happens via
of_create_pci_dev for sparc), some of the arch specific initialization
does not happen for VF device. That causes panic when archdata is
accessed.
To fix this, I have used already defined weak function
pcibios_setup_device to copy archdata from PF to VF.
Also verified the fix.
Signed-off-by: Babu Moger <babu.moger@oracle.com>
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Reviewed-by: Ethan Zhao <ethan.zhao@oracle.com>
[ Upstream commit 397d1533b6cce0ccb5379542e2e6d079f6936c46 ]
Like a signal return, we should use synchronize_user_stack() rather
than flush_user_windows().
Reported-by: Ilya Malakhov <ilmalakhovthefirst@gmail.com>
[ Upstream commit 36beca6571c941b28b0798667608239731f9bc3a ]
Orabug: 22495713
Currently, NUMA node distance matrix is initialized only
when a machine descriptor (MD) exists. However, sun4u
machines (e.g. Sun Blade 2500) do not have an MD and thus
distance values were left uninitialized. The initialization
is now moved such that it happens on both sun4u and sun4v.
Tested-by: Mikael Pettersson <mikpelinux@gmail.com>
[ Upstream commit 49fa5230462f9f2c4e97c81356473a6bdf06c422 ]
The system call tracing bug fix mentioned in the Fixes tag
below increased the amount of assembler code in the sequence
of assembler files included by head_64.S
This caused to total set of code to exceed 0x4000 bytes in
size, which overflows the expression in head_64.S that works
to place swapper_tsb at address 0x408000.
When this is violated, the TSB is not properly aligned, and
also the trap table is not aligned properly either. All of
this together results in failed boots.
So, do two things:
1) Simplify some code by using ba,a instead of ba/nop to get
those bytes back.
2) Add a linker script assertion to make sure that if this
happens again the build will fail.
Fixes: 1a40b95374f6 ("sparc: Fix system call tracing register handling.")
Reported-by: Joerg Abraham <joerg.abraham@nokia.com>
[ Upstream commit 1a40b95374f680625318ab61d81958e949e0afe3 ]
A system call trace trigger on entry allows the tracing
process to inspect and potentially change the traced
process's registers.
Account for that by reloading the %g1 (syscall number)
and %i0-%i5 (syscall argument) values. We need to be
careful to revalidate the range of %g1, and reload the
system call table entry it corresponds to into %l7.
Reported-by: Mike Frysinger <vapier@gentoo.org>
Tested-by: Mike Frysinger <vapier@gentoo.org>
commit aaee8c3c5cce2d9107310dd9f3026b4f901d441c upstream.
Forcing in_interrupt() to return true if we're not in a bona fide
interrupt confuses the softirq code. This fixes warnings like:
NOHZ: local_softirq_pending 282
... which can happen when running things like selftests/x86.
This will change perf's static percpu buffer usage in IST context.
I think this is okay, and it's changing the behavior to match
historical (pre-4.0) behavior.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Fixes: 959274753857 ("x86, traps: Track entry into and exit from IST context")
Link: http://lkml.kernel.org/r/cdc215f94d118d691d73df35275022331156fb45.1464130360.git.luto@kernel.org
commit 8b78f260887df532da529f225c49195d18fef36b upstream.
One of the debian buildd servers had this crash in the syslog without
any other information:
Unaligned handler failed, ret = -2
clock_adjtime (pid 22578): Unaligned data reference (code 28)
CPU: 1 PID: 22578 Comm: clock_adjtime Tainted: G E 4.5.0-2-parisc64-smp #1 Debian 4.5.4-1
task: 000000007d9960f8 ti: 00000001bde7c000 task.ti: 00000001bde7c000
YZrvWESTHLNXBCVMcbcbcbcbOGFRQPDI
PSW: 00001000000001001111100000001111 Tainted: G E
r00-03 000000ff0804f80f 00000001bde7c2b0 00000000402d2be8 00000001bde7c2b0
r04-07 00000000409e1fd0 00000000fa6f7fff 00000001bde7c148 00000000fa6f7fff
r08-11 0000000000000000 00000000ffffffff 00000000fac9bb7b 000000000002b4d4
r12-15 000000000015241c 000000000015242c 000000000000002d 00000000fac9bb7b
r16-19 0000000000028800 0000000000000001 0000000000000070 00000001bde7c218
r20-23 0000000000000000 00000001bde7c210 0000000000000002 0000000000000000
r24-27 0000000000000000 0000000000000000 00000001bde7c148 00000000409e1fd0
r28-31 0000000000000001 00000001bde7c320 00000001bde7c350 00000001bde7c218
sr00-03 0000000001200000 0000000001200000 0000000000000000 0000000001200000
sr04-07 0000000000000000 0000000000000000 0000000000000000 0000000000000000
IASQ: 0000000000000000 0000000000000000 IAOQ: 00000000402d2e84 00000000402d2e88
IIR: 0ca0d089 ISR: 0000000001200000 IOR: 00000000fa6f7fff
CPU: 1 CR30: 00000001bde7c000 CR31: ffffffffffffffff
ORIG_R28: 00000002369fe628
IAOQ[0]: compat_get_timex+0x2dc/0x3c0
IAOQ[1]: compat_get_timex+0x2e0/0x3c0
RP(r2): compat_get_timex+0x40/0x3c0
Backtrace:
[<00000000402d4608>] compat_SyS_clock_adjtime+0x40/0xc0
[<0000000040205024>] syscall_exit+0x0/0x14
This means the userspace program clock_adjtime called the clock_adjtime()
syscall and then crashed inside the compat_get_timex() function.
Syscalls should never crash programs, but instead return EFAULT.
The IIR register contains the executed instruction, which disassebles
into "ldw 0(sr3,r5),r9".
This load-word instruction is part of __get_user() which tried to read the word
at %r5/IOR (0xfa6f7fff). This means the unaligned handler jumped in. The
unaligned handler is able to emulate all ldw instructions, but it fails if it
fails to read the source e.g. because of page fault.
The following program reproduces the problem:
#define _GNU_SOURCE
#include <unistd.h>
#include <sys/syscall.h>
#include <sys/mman.h>
int main(void) {
/* allocate 8k */
char *ptr = mmap(NULL, 2*4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0);
/* free second half (upper 4k) and make it invalid. */
munmap(ptr+4096, 4096);
/* syscall where first int is unaligned and clobbers into invalid memory region */
/* syscall should return EFAULT */
return syscall(__NR_clock_adjtime, 0, ptr+4095);
To fix this issue we simply need to check if the faulting instruction address
is in the exception fixup table when the unaligned handler failed. If it
is, call the fixup routine instead of crashing.
While looking at the unaligned handler I found another issue as well: The
target register should not be modified if the handler was unsuccessful.
Signed-off-by: Helge Deller <deller@gmx.de>
commit 7cc851039d643a2ee7df4d18177150f2c3a484f5 upstream.
If we do not provide the PVR for POWER8NVL, a guest on this system
currently ends up in PowerISA 2.06 compatibility mode on KVM, since QEMU
does not provide a generic PowerISA 2.07 mode yet. So some new
instructions from POWER8 (like "mtvsrd") get disabled for the guest,
resulting in crashes when using code compiled explicitly for
POWER8 (e.g. with the "-mcpu=power8" option of GCC).
Fixes: ddee09c099c3 ("powerpc: Add PVR for POWER8NVL processor")
Signed-off-by: Thomas Huth <thuth@redhat.com>
commit 8dd75ccb571f3c92c48014b3dabd3d51a115ab41 upstream.
We are already using the privileged versions of MMCR0, MMCR1
and MMCRA in the kernel, so for MMCR2, we should better use
the privileged versions, too, to be consistent.
Fixes: 240686c13687 ("powerpc: Initialise PMU related regs on Power8")
Suggested-by: Paul Mackerras <paulus@ozlabs.org>
Acked-by: Paul Mackerras <paulus@ozlabs.org>
commit d23fac2b27d94aeb7b65536a50d32bfdc21fe01e upstream.
The SIAR and SDAR registers are available twice, one time as SPRs
780 / 781 (unprivileged, but read-only), and one time as the SPRs
796 / 797 (privileged, but read and write). The Linux kernel code
currently uses the unprivileged SPRs - while this is OK for reading,
writing to that register of course does not work.
Since the KVM code tries to write to this register, too (see the mtspr
in book3s_hv_rmhandlers.S), the contents of this register sometimes get
lost for the guests, e.g. during migration of a VM.
To fix this issue, simply switch to the privileged SPR numbers instead.
commit 871e178e0f2c4fa788f694721a10b4758d494ce1 upstream.
In the "ibm,configure-pe" and "ibm,configure-bridge" RTAS calls, the
spec states that values of 9900-9905 can be returned, indicating that
software should delay for 10^x (where x is the last digit, i.e. 990x)
milliseconds and attempt the call again. Currently, the kernel doesn't
know about this, and respecting it fixes some PCI failures when the
hypervisor is busy.
The delay is capped at 0.2 seconds.
Signed-off-by: Russell Currey <ruscur@russell.cc>
Acked-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit 0106d456c4cb1770253fefc0ab23c9ca760b43f7 upstream.
Commit 66dbd6e61a52 ("arm64: Implement ptep_set_access_flags() for
hardware AF/DBM") ensured that pte flags are updated atomically in the
face of potential concurrent, hardware-assisted updates. However, Alex
reports that:
| This patch breaks swapping for me.
| In the broken case, you'll see either systemd cpu time spike (because
| it's stuck in a page fault loop) or the system hang (because the
| application owning the screen is stuck in a page fault loop).
It turns out that this is because the 'dirty' argument to
ptep_set_access_flags is always 0 for read faults, and so we can't use
it to set PTE_RDONLY. The failing sequence is:
1. We put down a PTE_WRITE | PTE_DIRTY | PTE_AF pte
2. Memory pressure -> pte_mkold(pte) -> clear PTE_AF
3. A read faults due to the missing access flag
4. ptep_set_access_flags is called with dirty = 0, due to the read fault
5. pte is then made PTE_WRITE | PTE_DIRTY | PTE_AF | PTE_RDONLY (!)
6. A write faults, but pte_write is true so we get stuck
The solution is to check the new page table entry (as would be done by
the generic, non-atomic definition of ptep_set_access_flags that just
calls set_pte_at) to establish the dirty state.
Fixes: 66dbd6e61a52 ("arm64: Implement ptep_set_access_flags() for hardware AF/DBM")
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Reported-by: Alexander Graf <agraf@suse.de>
Tested-by: Alexander Graf <agraf@suse.de>
commit e47b020a323d1b2a7b1e9aac86e99eae19463630 upstream.
This patch brings the PER_LINUX32 /proc/cpuinfo format more in line with
the 32-bit ARM one by providing an additional line:
model name : ARMv8 Processor rev X (v8l)
Acked-by: Will Deacon <will.deacon@arm.com>
commit 0fa963553a5c28d8f8aabd8878326d3f782045fc upstream.
The s390 BFP compiler currently uses relative branch instructions
that only support jumps up to 64 KB. Examples are "j", "jnz", "cgrj",
etc. Currently the maximum size of s390 BPF programs is set
to 0x7ffff. If branches over 64 KB are generated the, kernel can
crash due to incorrect code.
So fix this an reduce the maximum size to 64 KB. Programs larger than
that will be interpreted.
Fixes: ce2b6ad9c185 ("s390/bpf: increase BPF_SIZE_MAX")
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit 6edf0aa4f8bbdfbb4d6d786892fa02728d05dc36 upstream.
In case of usage of skb_vlan_push/pop, in the prologue we store
the SKB pointer on the stack and restore it after BPF_JMP_CALL
to skb_vlan_push/pop.
Unfortunately currently there are two bugs in the code:
1) The wrong stack slot (offset 170 instead of 176) is used
2) The wrong register (W1 instead of B1) is saved
So fix this and use correct stack slot and register.
Fixes: 9db7f2b81880 ("s390/bpf: recache skb->data/hlen for skb_vlan_push/pop")
commit e2dfb4b880146bfd4b6aa8e138c0205407cebbaf upstream.
PTRACE_SETVFPREGS fails to properly mark the VFP register set to be
reloaded, because it undoes one of the effects of vfp_flush_hwstate().
Specifically vfp_flush_hwstate() sets thread->vfpstate.hard.cpu to
an invalid CPU number, but vfp_set() overwrites this with the original
CPU number, thereby rendering the hardware state as apparently "valid",
even though the software state is more recent.
Fix this by reverting the previous change.
Fixes: 8130b9d7b9d8 ("ARM: 7308/1: vfp: flush thread hwstate before copying ptrace registers")
Tested-by: Simon Marchi <simon.marchi@ericsson.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit d14bdb553f9196169f003058ae1cdabe514470e6 upstream.
MOV to DR6 or DR7 causes a #GP if an attempt is made to write a 1 to
any of bits 63:32. However, this is not detected at KVM_SET_DEBUGREGS
time, and the next KVM_RUN oopses:
general protection fault: 0000 [#1] SMP
CPU: 2 PID: 14987 Comm: a.out Not tainted 4.4.9-300.fc23.x86_64 #1
Hardware name: LENOVO 2325F51/2325F51, BIOS G2ET32WW (1.12 ) 05/30/2012
Call Trace:
[<ffffffffa072c93d>] kvm_arch_vcpu_ioctl_run+0x141d/0x14e0 [kvm]
[<ffffffffa071405d>] kvm_vcpu_ioctl+0x33d/0x620 [kvm]
[<ffffffff81241648>] do_vfs_ioctl+0x298/0x480
[<ffffffff812418a9>] SyS_ioctl+0x79/0x90
[<ffffffff817a0f2e>] entry_SYSCALL_64_fastpath+0x12/0x71
Code: 55 83 ff 07 48 89 e5 77 27 89 ff ff 24 fd 90 87 80 81 0f 23 fe 5d c3 0f 23 c6 5d c3 0f 23 ce 5d c3 0f 23 d6 5d c3 0f 23 de 5d c3 <0f> 23 f6 5d c3 0f 0b 66 66 66 66 66 2e 0f 1f 84 00 00 00 00 00
RIP [<ffffffff810639eb>] native_set_debugreg+0x2b/0x40
RSP <ffff88005836bd50>
Testcase (beautified/reduced from syzkaller output):
#include <unistd.h>
#include <string.h>
#include <stdint.h>
#include <linux/kvm.h>
#include <fcntl.h>
#include <sys/ioctl.h>
long r[8];
int main()
struct kvm_debugregs dr = { 0 };
r[2] = open("/dev/kvm", O_RDONLY);
r[3] = ioctl(r[2], KVM_CREATE_VM, 0);
r[4] = ioctl(r[3], KVM_CREATE_VCPU, 7);
memcpy(&dr,
"\x5d\x6a\x6b\xe8\x57\x3b\x4b\x7e\xcf\x0d\xa1\x72"
"\xa3\x4a\x29\x0c\xfc\x6d\x44\x00\xa7\x52\xc7\xd8"
"\x00\xdb\x89\x9d\x78\xb5\x54\x6b\x6b\x13\x1c\xe9"
"\x5e\xd3\x0e\x40\x6f\xb4\x66\xf7\x5b\xe3\x36\xcb",
48);
r[7] = ioctl(r[4], KVM_SET_DEBUGREGS, &dr);
r[6] = ioctl(r[4], KVM_RUN, 0);
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit dd14be92fbf5bc1ef7343f34968440e44e21b46a upstream.
Instead of having two functions for cycling through the E820 map in
order to count to be remapped pages and remap them later, just use one
function with a caller supplied sub-function called for each region to
be processed. This eliminates the possibility of a mismatch between
both loops which showed up in certain configurations.
Suggested-by: Ed Swierk <eswierk@skyportsystems.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 5a0cdbfd17b90a89c64a71d8aec9773ecdb20d0d upstream.
The function eeh_pe_reset_and_recover() is used to recover EEH
error when the passthrou device are transferred to guest and
backwards. The content in the device's config space will be lost
on PE reset issued in the middle of the recovery. The function
saves/restores it before/after the reset. However, config access
to some adapters like Broadcom BCM5719 at this point will causes
fenced PHB. The config space is always blocked and we save 0xFF's
that are restored at late point. The memory BARs are totally
corrupted, causing another EEH error upon access to one of the
memory BARs.
This restores the config space on those adapters like BCM5719
from the content saved to the EEH device when it's populated,
to resolve above issue.
Fixes: 5cfb20b9 ("powerpc/eeh: Emulate EEH recovery for VFIO devices")
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Reviewed-by: Russell Currey <ruscur@russell.cc>
commit c2078d9ef600bdbe568c89e5ddc2c6f15b7982c8 upstream.
This reverts commit 89a51df5ab1d38b257300b8ac940bbac3bb0eb9b.
The function eeh_add_device_early() is used to perform EEH
initialization in devices added later on the system, like in
hotplug/DLPAR scenarios. Since the commit 89a51df5ab1d ("powerpc/eeh:
Fix crash in eeh_add_device_early() on Cell") a new check was introduced
in this function - Cell has no EEH capabilities which led to kernel oops
if hotplug was performed, so checking for eeh_enabled() was introduced
to avoid the issue.
However, in architectures that EEH is present like pSeries or PowerNV,
we might reach a case in which no PCI devices are present on boot time
and so EEH is not initialized. Then, if a device is added via DLPAR for
example, eeh_add_device_early() fails because eeh_enabled() is false,
and EEH end up not being enabled at all.
This reverts the aforementioned patch since a new verification was
introduced by the commit d91dafc02f42 ("powerpc/eeh: Delay probing EEH
device during hotplug") and so the original Cell issue does not happen
anymore.
Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
commit affeb0f2d3a9af419ad7ef4ac782e1540b2f7b28 upstream.
error when the passthrough device are transferred to guest and
backwards, meaning the device's driver is vfio-pci or none.
When the driver is vfio-pci that provides error_detected() error
handler only, the handler simply stops the guest and it's not
expected behaviour. On the other hand, no error handlers will
be called if we don't have a bound driver.
This ignores the error handler in eeh_pe_reset_and_recover()
that reports the error to device driver to avoid the exceptional
behaviour.
commit 8ed8ab40047a570fdd8043a40c104a57248dd3fd upstream.
Some of the interrupt vectors on 64-bit POWER server processors are only
32 bytes long (8 instructions), which is not enough for the full
first-level interrupt handler. For these we need to branch to an
out-of-line (OOL) handler. But when we are running a relocatable kernel,
interrupt vectors till __end_interrupts marker are copied down to real
address 0x100. So, branching to labels (ie. OOL handlers) outside this
section must be handled differently (see LOAD_HANDLER()), considering
relocatable kernel, which would need at least 4 instructions.
However, branching from interrupt vector means that we corrupt the
CFAR (come-from address register) on POWER7 and later processors as
mentioned in commit 1707dd16. So, EXCEPTION_PROLOG_0 (6 instructions)
that contains the part up to the point where the CFAR is saved in the
PACA should be part of the short interrupt vectors before we branch out
to OOL handlers.
But as mentioned already, there are interrupt vectors on 64-bit POWER
server processors that are only 32 bytes long (like vectors 0x4f00,
0x4f20, etc.), which cannot accomodate the above two cases at the same
time owing to space constraint. Currently, in these interrupt vectors,
we simply branch out to OOL handlers, without using LOAD_HANDLER(),
which leaves us vulnerable when running a relocatable kernel (eg. kdump
case). While this has been the case for sometime now and kdump is used
widely, we were fortunate not to see any problems so far, for three
reasons:
1. In almost all cases, production kernel (relocatable) is used for
kdump as well, which would mean that crashed kernel's OOL handler
would be at the same place where we end up branching to, from short
interrupt vector of kdump kernel.
2. Also, OOL handler was unlikely the reason for crash in almost all
the kdump scenarios, which meant we had a sane OOL handler from
crashed kernel that we branched to.
3. On most 64-bit POWER server processors, page size is large enough
that marking interrupt vector code as executable (see commit
429d2e83) leads to marking OOL handler code from crashed kernel,
that sits right below interrupt vector code from kdump kernel, as
executable as well.
Let us fix this by moving the __end_interrupts marker down past OOL
handlers to make sure that we also copy OOL handlers to real address
0x100 when running a relocatable kernel.
This fix has been tested successfully in kdump scenario, on an LPAR with
4K page size by using different default/production kernel and kdump
kernel.
Also tested by manually corrupting the OOL handlers in the first kernel
and then kdump'ing, and then causing the OOL handlers to fire - mpe.
Fixes: c1fb6816fb1b ("powerpc: Add relocation on exception vector handlers")
Signed-off-by: Hari Bathini <hbathini@linux.vnet.ibm.com>
Signed-off-by: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
commit 330d12764e15f6e3e94ff34cda29db96d2589c24 upstream.
MAX8997 PMIC requires interrupt and fails probing without it.
Fixes: d105f0b1215d ("ARM: dts: Add basic dts file for Samsung Trats board")
[k.kozlowski: Write commit message, add CC-stable]
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit b1f3a3b03eb5f61b4051e2da9aa15653e705e111 upstream.
Fix a typo on PIN_PD24 for UTXD2 and FLEXCOM4_IO3 which were
wrongly linked to PIN_PD23).
Signed-off-by: Florian Vallee <fvallee@eukrea.fr>
Fixes: 7f16cb676c00 ("ARM: at91/dt: add sama5d2 pinmux")
[nicolas.ferre@atmel.com: add commit message, changed subject]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 9800917cf92f5b5fe5cae706cb70db8d014f663c upstream.
Some of the GPIO configs were wrong in the submitted DTS files,
this patch fixes all affected boards.
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 94cc36b84acc29f543b48bc5ed786011b112a666 upstream.
Avoid an aliasing issue causing a build error in VDSO:
In file included from include/linux/srcu.h:34:0,
from include/linux/notifier.h:15,
from ./arch/mips/include/asm/uprobes.h:9,
from include/linux/uprobes.h:61,
from include/linux/mm_types.h:13,
from ./arch/mips/include/asm/vdso.h:14,
from arch/mips/vdso/vdso.h:27,
from arch/mips/vdso/gettimeofday.c:11:
include/linux/workqueue.h: In function 'work_static':
include/linux/workqueue.h:186:2: error: dereferencing type-punned pointer will break strict-aliasing rules [-Werror=strict-aliasing]
return *work_data_bits(work) & WORK_STRUCT_STATIC;
cc1: all warnings being treated as errors
make[2]: *** [arch/mips/vdso/gettimeofday.o] Error 1
with a CONFIG_DEBUG_OBJECTS_WORK configuration and GCC 5.2.0. Include
`-fno-strict-aliasing' along with compiler options used, as required for
kernel code, fixing a problem present since the introduction of VDSO
with commit ebb5e78cc634 ("MIPS: Initial implementation of a VDSO").
Thanks to Tejun for diagnosing this properly!
Signed-off-by: Maciej W. Rozycki <macro@imgtec.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Fixes: ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
Cc: Tejun Heo <tj@kernel.org>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/13357/
commit aedcfbe06558a9f53002e82d5be64c6c94687726 upstream.
On certain MIPS32 devices, the ftrace tracer "function_graph" uses
__lshrdi3() during the capturing of trace data. ftrace then attempts to
trace __lshrdi3() which leads to infinite recursion and a stack overflow.
Fix this by marking __lshrdi3() as notrace. Mark the other compiler
intrinsics as notrace in case the compiler decides to use them in the
ftrace path.
Signed-off-by: Harvey Hunt <harvey.hunt@imgtec.com>
Cc: <linux-mips@linux-mips.org>
Cc: <linux-kernel@vger.kernel.org>
Patchwork: https://patchwork.linux-mips.org/patch/13354/
commit bb93078e655be1e24d68f28f2756676e62c037ce upstream.
MicroMIPS kernels may be expected to run on microMIPS only cores which
don't support the normal MIPS instruction set, so be sure to pass the
-mmicromips flag through to the VDSO cflags.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13349/
commit 13eb192d10bcc9ac518d57356179071d603bcb4e upstream.
In microMIPS kernels, handle_signal() sets the isa16 mode bit in the
vdso address so that the sigreturn trampolines (which are offset from
the VDSO) get executed as microMIPS.
However commit ebb5e78cc634 ("MIPS: Initial implementation of a VDSO")
changed the offsets to come from the VDSO image, which already have the
isa16 mode bit set correctly since they're extracted from the VDSO
shared library symbol table.
Drop the isa16 mode bit handling from handle_signal() to fix sigreturn
for cores which support both microMIPS and normal MIPS. This doesn't fix
microMIPS only cores, since the VDSO is still built for normal MIPS, but
thats a separate problem.
Patchwork: https://patchwork.linux-mips.org/patch/13348/
commit abf378be49f38c4d3e23581d3df3fa9f1b1b11d2 upstream.
Correct the cases missed with commit 9b26616c8d9d ("MIPS: Respect the
ISA level in FCSR handling") and prevent writes to read-only FCSR bits
there.
This in particular applies to FP context initialisation where any IEEE
754-2008 bits preset by `mips_set_personality_nan' are cleared before
the relevant ptrace(2) call takes effect and the PTRACE_POKEUSR request
addressing FPC_CSR where no masking of read-only FCSR bits is done.
Remove the FCSR clearing from FP context initialisation then and unify
PTRACE_POKEUSR/FPC_CSR and PTRACE_SETFPREGS handling, by factoring out
code from `ptrace_setfpregs' and calling it from both places.
This mostly matters to soft float configurations where the emulator can
be switched this way to a mode which should not be accessible and cannot
be set with the CTC1 instruction. With hard float configurations any
effect is transient anyway as read-only bits will retain their values at
the time the FP context is restored.
Patchwork: https://patchwork.linux-mips.org/patch/13239/
commit 4249548454f7ba4581aeee26bd83f42b48a14d15 upstream.
Fix a floating-point context restoration regression introduced with
commit 9b26616c8d9d ("MIPS: Respect the ISA level in FCSR handling")
that causes a Floating Point exception and consequently a kernel oops
with hard float configurations when one or more FCSR Enable and their
corresponding Cause bits are set both at a time via a ptrace(2) call.
To do so reinstate Cause bit masking originally introduced with commit
b1442d39fac2 ("MIPS: Prevent user from setting FCSR cause bits") to
address this exact problem and then inadvertently removed from the
PTRACE_SETFPREGS request with the commit referred above.
Patchwork: https://patchwork.linux-mips.org/patch/13238/
commit bd239f1e1429e7781096bf3884bdb1b2b1bb4f28 upstream.
Whilst a PR_SET_FP_MODE prctl is performed there are decisions made
based upon whether the task is executing on the current CPU. This may
change if we're preempted, so disable preemption to avoid such changes
for the lifetime of the mode switch.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Fixes: 9791554b45a2 ("MIPS,prctl: add PR_[GS]ET_FP_MODE prctl options for MIPS")
Reviewed-by: Maciej W. Rozycki <macro@imgtec.com>
Tested-by: Aurelien Jarno <aurelien@aurel32.net>
Cc: Adam Buchbinder <adam.buchbinder@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/13144/
commit 6533af4d4831c421cd9aa4dce7cfc19a3514cc09 upstream.
If a kernel doesn't support MSA context (ie. CONFIG_CPU_HAS_MSA=n) then
it will only keep 64 bits per FP register in thread context, and the
calls to set_fpr64 in restore_msa_extcontext will overrun the end of the
FP register context into the FCSR & MSACSR values. GCC 6.x has become
smart enough to detect this & complain like so:
arch/mips/kernel/signal.c: In function 'protected_restore_fp_context':
./arch/mips/include/asm/processor.h:114:17: error: array subscript is above array bounds [-Werror=array-bounds]
fpr->val##width[FPR_IDX(width, idx)] = val; \
./arch/mips/include/asm/processor.h:118:1: note: in expansion of macro 'BUILD_FPR_ACCESS'
BUILD_FPR_ACCESS(64)
The only way to trigger this code to run would be for a program to set
up an artificial extended MSA context structure following a sigframe &
execute sigreturn. Whilst this doesn't allow a program to write to any
state that it couldn't already, it makes little sense to allow this
"restoration" of MSA context in a system that doesn't support MSA.
Fix this by killing a program with SIGSYS if it tries something as crazy
as "restoring" fake MSA context in this way, also fixing the build error
& allowing for most of restore_msa_extcontext to be optimised out of
kernels without support for MSA.
Reported-by: Michal Toman <michal.toman@imgtec.com>
Fixes: bf82cb30c7e5 ("MIPS: Save MSA extended context around signals")
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Cc: Michal Toman <michal.toman@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/13164/
commit ea1688573426adc2587ed52d086b51c7c62eaca3 upstream.
The MSA ld_*/st_* assembler macros for when the toolchain doesn't
support MSA use addu to offset the base address. However it is a virtual
memory pointer so fix it to use PTR_ADDU which expands to daddu for
64-bit kernels.
Patchwork: https://patchwork.linux-mips.org/patch/13062/
commit 8a3c8b48aca8771bff3536e40aa26ffb311699d1 upstream.
In revision 1.12 of the MSA specification, the copy_u.w instruction has
been removed for MIPS32 & the copy_u.d instruction has been removed for
MIPS64. Newer toolchains (eg. Codescape SDK essentials 2015.10) will
complain about this like so:
arch/mips/kernel/r4k_fpu.S:290: Error: opcode not supported on this
processor: mips32r2 (mips32r2) `copy_u.w $1,$w26[3]'
Since we always copy to the width of a GPR, simply use copy_s instead of
copy_u to fix this.
Patchwork: https://patchwork.linux-mips.org/patch/13061/
commit 3484de7bcbed20ecbf2b8d80671619e7059e2dd7 upstream.
Due to datasheet, reserving 0xff800000~0xffffffff (8MB below 4GB) is
not enough for RS780E integrated GPU's TOM (top of memory) registers
and MSI/MSI-x memory region, so we reserve 0xfe000000~0xffffffff (32MB
below 4GB).
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Cc: Aurelien Jarno <aurelien@aurel32.net>
Cc: Steven J . Hill <sjhill@realitydiluted.com>
Cc: Fuxin Zhang <zhangfx@lemote.com>
Cc: Zhangjin Wu <wuzhangjin@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/12889/
commit a95d069204e178f18476f5499abab0d0d9cbc32c upstream.
After commit 92923ca3aacef63c92d ("mm: meminit: only set page reserved
in the memblock region"), the MIPS hibernation is broken. Because pages
in nosave data section should be "reserved", but currently they aren't
set to "reserved" at initialization. This patch makes hibernation work
again.
Patchwork: https://patchwork.linux-mips.org/patch/12888/
commit f5b556c94c8490d42fea79d7b4ae0ecbc291e69d upstream.
This makes the ath79 bootconsole behave the same way as the generic 8250
bootconsole.
Also waiting for TEMT (transmit buffer is empty) instead of just THRE
(transmit buffer is not full) ensures that all characters have been
transmitted before the real serial driver starts reconfiguring the serial
controller (which would sometimes result in garbage being transmitted.)
This change does not cause a visible performance loss.
In addition, this seems to fix a hang observed in certain configurations on
many AR7xxx/AR9xxx SoCs during autoconfig of the real serial driver.
A more complete follow-up patch will disable 8250 autoconfig for ath79
altogether (the serial controller is detected as a 16550A, which is not
fully compatible with the ath79 serial, and the autoconfig may lead to
undefined behavior on ath79.)
Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net>
commit 37d22a0d798b5c938b277d32cfd86dc231381342 upstream.
It's possible for pages to become visible prior to update_mmu_cache
running if a thread within the same address space preempts the current
thread or runs simultaneously on another CPU. That is, the following
scenario is possible:
CPU0 CPU1
write to page
flush_dcache_page
flush_icache_page
set_pte_at
map page
update_mmu_cache
If CPU1 maps the page in between CPU0's set_pte_at, which marks it valid
& visible, and update_mmu_cache where the dcache flush occurs then CPU1s
icache will fill from stale data (unless it fills from the dcache, in
which case all is good, but most MIPS CPUs don't have this property).
Commit 4d46a67a3eb8 ("MIPS: Fix race condition in lazy cache flushing.")
attempted to fix that by performing the dcache flush in
flush_icache_page such that it occurs before the set_pte_at call makes
the page visible. However it has the problem that not all code that
writes to pages exposed to userland call flush_icache_page. There are
many callers of set_pte_at under mm/ and only 2 of them do call
flush_icache_page. Thus the race window between a page becoming visible
& being coherent between the icache & dcache remains open in some cases.
To illustrate some of the cases, a WARN was added to __update_cache with
this patch applied that triggered in cases where a page about to be
flushed from the dcache was not the last page provided to
flush_icache_page. That is, backtraces were obtained for cases in which
the race window is left open without this patch. The 2 standout examples
follow.
When forking a process:
[ 15.271842] [<80417630>] __update_cache+0xcc/0x188
[ 15.277274] [<80530394>] copy_page_range+0x56c/0x6ac
[ 15.282861] [<8042936c>] copy_process.part.54+0xd40/0x17ac
[ 15.289028] [<80429f80>] do_fork+0xe4/0x420
[ 15.293747] [<80413808>] handle_sys+0x128/0x14c
When exec'ing an ELF binary:
[ 14.445964] [<80417630>] __update_cache+0xcc/0x188
[ 14.451369] [<80538d88>] move_page_tables+0x414/0x498
[ 14.457075] [<8055d848>] setup_arg_pages+0x220/0x318
[ 14.462685] [<805b0f38>] load_elf_binary+0x530/0x12a0
[ 14.468374] [<8055ec3c>] search_binary_handler+0xbc/0x214
[ 14.474444] [<8055f6c0>] do_execveat_common+0x43c/0x67c
[ 14.480324] [<8055f938>] do_execve+0x38/0x44
[ 14.485137] [<80413808>] handle_sys+0x128/0x14c
These code paths write into a page, call flush_dcache_page then call
set_pte_at without flush_icache_page inbetween. The end result is that
the icache can become corrupted & userland processes may execute
unexpected or invalid code, typically resulting in a reserved
instruction exception, a trap or a segfault.
Fix this race condition fully by performing any cache maintenance
required to keep the icache & dcache in sync in set_pte_at, before the
page is made valid. This has the added bonus of ensuring the cache
maintenance always happens in one location, rather than being duplicated
in flush_icache_page & update_mmu_cache. It also matches the way other
architectures solve the same problem (see arm, ia64 & powerpc).
Reported-by: Ionela Voinescu <ionela.voinescu@imgtec.com>
Cc: Lars Persson <lars.persson@axis.com>
Fixes: 4d46a67a3eb8 ("MIPS: Fix race condition in lazy cache flushing.")
Cc: Steven J. Hill <sjhill@realitydiluted.com>
Cc: David Daney <david.daney@cavium.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Patchwork: https://patchwork.linux-mips.org/patch/12722/
commit f4281bba818105c7c91799abe40bc05c0dbdaa25 upstream.
The following patch will expose __update_cache to highmem pages. Handle
them by mapping them in for the duration of the cache maintenance, just
like in __flush_dcache_page. The code for that isn't shared because we
need the page address in __update_cache so sharing became messy. Given
that the entirity is an extra 5 lines, just duplicate it.
Patchwork: https://patchwork.linux-mips.org/patch/12721/
commit 234859e49a15323cf1b2331bdde7f658c4cb45fb upstream.
When flush_dcache_page is called on an executable page, that page is
about to be provided to userland & we can presume that the icache
contains no valid entries for its address range. However if the icache
does not fill from the dcache then we cannot presume that the pages
content has been written back as far as the memories that the dcache
will fill from (ie. L2 or further out).
This was being done for lowmem pages, but not for highmem which can lead
to icache corruption. Fix this by mapping highmem pages & flushing their
content from the dcache in __flush_dcache_page before providing the page
to userland, just as is done for lowmem pages.
Patchwork: https://patchwork.linux-mips.org/patch/12720/
commit a7e89326b415b5d81c4b1016fd4a40db861eb58d upstream.
Commit f51246efee2b ("MIPS: Get rid of finish_arch_switch().") moved the
__restore_watch() call from finish_arch_switch() (i.e. after resume()
returns) to before the resume() call in switch_to(). This results in
watchpoints only being restored when a task is descheduled, preventing
the watchpoints from being effective most of the time, except due to
chance before the watchpoints are lazily removed.
Fix the call sequence from switch_to() through to
mips_install_watch_registers() to pass the task_struct pointer of the
next task, instead of using current. This allows the watchpoints for the
next (non-current) task to be restored without reintroducing
Fixes: f51246efee2b ("MIPS: Get rid of finish_arch_switch().")
Patchwork: https://patchwork.linux-mips.org/patch/12726/
