path: root/arch
2008-02-05FRV: permit the memory to be located elsewhere in NOMMU modeDavid Howells
Permit the memory to be located somewhere other than address 0xC0000000 in NOMMU mode. The configuration options are already present, it just requires wiring up in the linker script. Note that only a limited set of locations of runtime addresses are available because of the way the CPU protection registers work. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05gpiolib: avr32 at32ap platform supportDavid Brownell
Teach AVR32 to use the "GPIO Library" when exposing its GPIOs, so that signals on external chips (like GPIO expanders) can easily be used. This mostly reorganizes some existing logic, with two minor changes in behavior: - The PSR registers are used instead of the previous "gpio_mask" values, matching AT91 behavior and removing some duplication between that role and that of "pinmux_mask". - NR_IRQs grew to acommodate a bank of external GPIOs. Eventually this number should probably become a board-specific config option. There's a debugfs dump of status for the built-in GPIOs, showing which pins have deglitching, pullups, or open drain drive enabled, as well as the ID string used when requesting each IRQ. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05gpiolib support for the PXA architecturePhilipp Zabel
This adds gpiolib support for the PXA architecture: - move all GPIO API functions from generic.c into gpio.c - convert the gpio_get/set_value macros into inline functions This makes it easier to hook up GPIOs provided by external chips like ASICs and CPLDs. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Minor ARM fixup from David Brownell folded into this ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05gpiolib: add drivers/gpio directoryDavid Brownell
Add an empty drivers/gpio directory for gpiolib infrastructure and GPIO expanders. It will be populated by later patches. This won't be the only place to hold such gpio_chip code. Many external chips add a few GPIOs as secondary functionality (such as MFD drivers) and platform code frequently needs to closely integrate GPIO and IRQ support. This is placed *early* in the build/link sequence since it's common for other drivers to depend on GPIOs to do their work, so they must be initialized early in the device_initcall() sequence. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg: kill __clear_bit_string and find_next_zero_stringFUJITA Tomonori
This kills unused __clear_bit_string and find_next_zero_string (they were used by only gart and calgary IOMMUs). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Muli Ben-Yehuda <mulix@mulix.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg: x86: convert gart IOMMU to use the IOMMU helperFUJITA Tomonori
This patch converts gart IOMMU to use the IOMMU helper functions. The IOMMU doesn't allocate a memory area spanning LLD's segment boundary anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Muli Ben-Yehuda <mulix@mulix.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg: x86: convert calgary IOMMU to use the IOMMU helperFUJITA Tomonori
This patch converts calgary IOMMU to use the IOMMU helper functions. The IOMMU doesn't allocate a memory area spanning LLD's segment boundary anymore. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Muli Ben-Yehuda <mulix@mulix.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg: powerpc: remove DMA 4GB boundary protectionFUJITA Tomonori
Previously, during initialization of the IOMMU tables, the last entry at each 4GB boundary is marked as used since there are many adapters which cannot handle DMAing across any 4GB boundary. The IOMMU doesn't allocate a memory area spanning LLD's segment boundary anymore. The segment boundary of devices are set to 4GB by default. So we can remove 4GB boundary protection now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg: powerpc: convert iommu to use the IOMMU helperFUJITA Tomonori
This patch converts PPC's IOMMU to use the IOMMU helper functions. The IOMMU doesn't allocate a memory area spanning LLD's segment boundary anymore. iseries_hv_alloc and iseries_hv_map don't have proper device struct. 4GB boundary is used for them. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: sparc64: make iommu respect the segment size limitsFUJITA Tomonori
This patch makes iommu respect segment size limits when merging sg lists. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: alpha: make pci_iommu respect the segment size limitsFUJITA Tomonori
This patch makes pci_iommu respect segment size limits when merging sg lists. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: IA64: make sba_iommu respect the segment size limitsFUJITA Tomonori
This patch makes sba iommu respect segment size limits when merging sg lists. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: ppc: make iommu respect the segment size limitsFUJITA Tomonori
This patch makes iommu respect segment size limits when merging sg lists. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: x86: make pci-gart iommu respect the segment size limitsFUJITA Tomonori
This patch makes pci-gart iommu respect segment size limits when merging sg lists. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Dave Airlie <airlied@linux.ie> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05m32r: remove dead config symbols from M32R codeJiri Olsa
remove dead config symbols from M32R code Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: wire the new timerfd API to the x86 familyDavide Libenzi
Wires up the new timerfd API to the x86 family. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05timerfd: new timerfd APIDavide Libenzi
This is the new timerfd API as it is implemented by the following patch: int timerfd_create(int clockid, int flags); int timerfd_settime(int ufd, int flags, const struct itimerspec *utmr, struct itimerspec *otmr); int timerfd_gettime(int ufd, struct itimerspec *otmr); The timerfd_create() API creates an un-programmed timerfd fd. The "clockid" parameter can be either CLOCK_MONOTONIC or CLOCK_REALTIME. The timerfd_settime() API give new settings by the timerfd fd, by optionally retrieving the previous expiration time (in case the "otmr" parameter is not NULL). The time value specified in "utmr" is absolute, if the TFD_TIMER_ABSTIME bit is set in the "flags" parameter. Otherwise it's a relative time. The timerfd_gettime() API returns the next expiration time of the timer, or {0, 0} if the timerfd has not been set yet. Like the previous timerfd API implementation, read(2) and poll(2) are supported (with the same interface). Here's a simple test program I used to exercise the new timerfd APIs: http://www.xmailserver.org/timerfd-test2.c [akpm@linux-foundation.org: coding-style cleanups] [akpm@linux-foundation.org: fix ia64 build] [akpm@linux-foundation.org: fix m68k build] [akpm@linux-foundation.org: fix mips build] [akpm@linux-foundation.org: fix alpha, arm, blackfin, cris, m68k, s390, sparc and sparc64 builds] [heiko.carstens@de.ibm.com: fix s390] [akpm@linux-foundation.org: fix powerpc build] [akpm@linux-foundation.org: fix sparc64 more] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05kvm: i386 fixAndrew Morton
arch/x86/kvm/x86.c: In function 'emulator_cmpxchg_emulated': arch/x86/kvm/x86.c:1746: warning: passing argument 2 of 'vcpu->arch.mmu.gva_to_gpa' makes integer from pointer without a cast arch/x86/kvm/x86.c:1746: warning: 'addr' is used uninitialized in this function Is true. Local variable `addr' shadows incoming arg `addr'. Avi is on vacation for a while, so... Cc: Avi Kivity <avi@qumranet.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 4822/1: RealView: Change the REALVIEW_MPCORE configuration option [ARM] 4821/1: RealView: Remove the platform dependencies from localtimer.c [ARM] 4820/1: RealView: Select the timer IRQ at run-time [ARM] 4819/1: RealView: Fix entry-macro.S to work with multiple platforms [ARM] 4818/1: RealView: Add core-tile detection [ARM] 4817/1: RealView: Move the AMBA resource definitions to realview_eb.c [ARM] 4816/1: RealView: Move the platform-specific definitions into board-eb.h [ARM] 4815/1: RealView: Add clockevents suport for the local timers [ARM] 4814/1: RealView: Add broadcasting clockevents support for ARM11MPCore [ARM] 4813/1: Add SMP helper functions for clockevents support [ARM] 4812/1: RealView: clockevents support for the RealView platforms [ARM] 4811/1: RealView: clocksource support for the RealView platforms [ARM] 4736/1: Export atags to userspace and allow kexec to use customised atags [ARM] 4798/1: pcm027: fix missing header file [ARM] 4803/1: pxa: fix building issue of poodle.c caused by patch 4737/1 [ARM] 4801/1: pxa: fix building issues of missing pxa2xx-regs.h [ARM] pxa: introduce sysdev for pxa3xx static memory controller [ARM] pxa: add preliminary suspend/resume code for pxa3xx [ARM] pxa: introduce sysdev for GPIO register saving/restoring [ARM] pxa: introduce sysdev for IRQ register saving/restoring ...
2008-02-04Merge branches 'at91', 'ixp', 'master', 'misc', 'pxa' and 'realview' into develRussell King
* at91: [ARM] 4802/1: Fix typo and remove vague comment [ARM] 4660/3: at91: allow selecting UART for early kernel messages [ARM] 4739/1: at91sam9263: make gpio bank C and D irqs work * ixp: [ARM] 4809/2: ixp4xx: Merge dsmg600-power.c into dsmg600-setup.c [ARM] 4808/2: ixp4xx: Merge nas100d-power.c into nas100d-setup.c [ARM] 4807/2: ixp4xx: Merge nslu2-power.c into nslu2-setup.c [ARM] 4806/1: ixp4xx: Ethernet support for the nslu2 and nas100d boards [ARM] 4805/1: ixp4xx: Use leds-gpio driver instead of IXP4XX-GPIO-LED driver [ARM] 4715/2: Ethernet support for IXDP425 boards [ARM] 4714/2: Headers for IXP4xx built-in Ethernet and WAN drivers [ARM] 4713/3: Adds drivers for IXP4xx QMgr and NPE features [ARM] 4712/2: Adds functions to read and write IXP4xx "feature" bits [ARM] 4774/2: ixp4xx: Register dsmg600 rtc i2c_board_info [ARM] 4773/2: ixp4xx: Register nas100d rtc i2c_board_info [ARM] 4772/2: ixp4xx: Register nslu2 rtc i2c_board_info [ARM] 4769/2: ixp4xx: Button updates for the dsmg600 board [ARM] 4768/2: ixp4xx: Button and LED updates for the nas100d board [ARM] 4767/2: ixp4xx: Add bitops.h include to io.h [ARM] 4766/2: ixp4xx: Update ixp4xx_defconfig, enabling all supported boards * master: [ARM] 4810/1: - Fix 'section mismatch' building warnings [ARM] xtime_seqlock: fix more ARM machines for xtime deadlocking [ARM] 21285 serial: fix build error * misc: [ARM] 4736/1: Export atags to userspace and allow kexec to use customised atags * pxa: [ARM] 4798/1: pcm027: fix missing header file [ARM] 4803/1: pxa: fix building issue of poodle.c caused by patch 4737/1 [ARM] 4801/1: pxa: fix building issues of missing pxa2xx-regs.h [ARM] pxa: introduce sysdev for pxa3xx static memory controller [ARM] pxa: add preliminary suspend/resume code for pxa3xx [ARM] pxa: introduce sysdev for GPIO register saving/restoring [ARM] pxa: introduce sysdev for IRQ register saving/restoring [ARM] pxa: fix the warning of undeclared "struct pxaohci_platform_data" [ARM] pxa: change set_kset_name() to direct name assignment for MFP sysclass * realview: [ARM] 4822/1: RealView: Change the REALVIEW_MPCORE configuration option [ARM] 4821/1: RealView: Remove the platform dependencies from localtimer.c [ARM] 4820/1: RealView: Select the timer IRQ at run-time [ARM] 4819/1: RealView: Fix entry-macro.S to work with multiple platforms [ARM] 4818/1: RealView: Add core-tile detection [ARM] 4817/1: RealView: Move the AMBA resource definitions to realview_eb.c [ARM] 4816/1: RealView: Move the platform-specific definitions into board-eb.h [ARM] 4815/1: RealView: Add clockevents suport for the local timers [ARM] 4814/1: RealView: Add broadcasting clockevents support for ARM11MPCore [ARM] 4813/1: Add SMP helper functions for clockevents support [ARM] 4812/1: RealView: clockevents support for the RealView platforms [ARM] 4811/1: RealView: clocksource support for the RealView platforms
2008-02-04[ARM] 4822/1: RealView: Change the REALVIEW_MPCORE configuration optionCatalin Marinas
This patch changes the REALVIEW_MPCORE configuration option to REALVIEW_EB_ARM11MP since this is only specific to RealView/EB. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4821/1: RealView: Remove the platform dependencies from localtimer.cCatalin Marinas
This patch removes the TWD_BASE macro used to set up and configure the local timers on ARM11MPCore. The twd_base_addr and twd_size variables are defined in localtimer.c and set from the realview_eb_init function. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4820/1: RealView: Select the timer IRQ at run-timeCatalin Marinas
This patch sets the timer IRQ at run-time by moving the sys_timer structure and the timer_init function to the realview_eb.c file. This allows multiple RealView platforms to be compiled in the same kernel image. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4819/1: RealView: Fix entry-macro.S to work with multiple platformsCatalin Marinas
This patch modifies the get_irqnr_preamble macro to work with multiple platforms at run-time by reading the address of the GIC controller from the gic_cpu_base_addr variable. This variable is defined in core.c and intialised in realview_eb.c (gic_init_irq). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4818/1: RealView: Add core-tile detectionCatalin Marinas
This patch adds the core-tile detection and only enables devices if the corresponding tile is present. It currently detects the ARM11MPCore via the core_tile_eb11mp() macro. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4817/1: RealView: Move the AMBA resource definitions to realview_eb.cCatalin Marinas
This patch moves the IRQ and DMA definitions from core.h into realview_eb.c since they are platform-specific. It adds a realview_eb11mp_fixup function to adjust the IRQ numbers if the ARM11MPCore tile is fitted. The realview_smc91x_device is also moved from core.c into realview_eb.c. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4816/1: RealView: Move the platform-specific definitions into board-eb.hCatalin Marinas
This patch moves the platform specific definitions from platform.h into the board-eb.h file. It drops the INT_* definitions as they are no longer used in irqs.h (moved to board-eb.h). It renames REALVIEW_* macros to REALVIEW_EB_* or REALVIEW_EB11MP_* to distinguish between standard EB and EB + the ARM11MPCore tile. The platform.h file contains common definitions to the RealView platforms and it is only directly included in board-*.h files. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4815/1: RealView: Add clockevents suport for the local timersCatalin Marinas
This patch registers the local timers on ARM11MPCore as clock event devices. The clock device can be set up as periodic or oneshot. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4814/1: RealView: Add broadcasting clockevents support for ARM11MPCoreCatalin Marinas
This patch adds dummy local timers for each CPU so that the board clock device is used to broadcast events to the other CPUs. The patch also adds the declaration for the dummy_timer_setup function (the equivalent of local_timer_setup when CONFIG_LOCAL_TIMERS is not set). Due to the way clockevents work, the dummy timer on the first CPU has to be registered before the board timer. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4813/1: Add SMP helper functions for clockevents supportCatalin Marinas
This patch adds the smp_call_function_single and smp_timer_broadcast functions and modifies ipi_timer to call the platform-specific function local_timer_interrupt. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4812/1: RealView: clockevents support for the RealView platformsCatalin Marinas
The patch updates the RealView code to the clockevents infrastructure. The SMP support is implemented in subsequent patches. Based on the Versatile implementation by Kevin Hilman. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04[ARM] 4811/1: RealView: clocksource support for the RealView platformsCatalin Marinas
The patch updates the RealView platform code to use the generic clocksource infrastructure for basic time keeping. Based on the Versatile implementation by Kevin Hilman. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: (78 commits) x86: fix RTC lockdep warning: potential hardirq recursion x86: cpa, micro-optimization x86: cpa, clean up code flow x86: cpa, eliminate CPA_ enum x86: cpa, cleanups x86: implement gbpages support in change_page_attr() x86: support gbpages in pagetable dump x86: add gbpages support to lookup_address x86: add pgtable accessor functions for gbpages x86: add PUD_PAGE_SIZE x86: add feature macros for the gbpages cpuid bit x86: switch direct mapping setup over to set_pte x86: fix page-present check in cpa_flush_range x86: remove cpa warning x86: remove now unused clear_kernel_mapping x86: switch pci-gart over to using set_memory_np() instead of clear_kernel_mapping() x86: cpa selftest, skip non present entries x86: CPA fix pagetable split x86: rename LARGE_PAGE_SIZE to PMD_PAGE_SIZE x86: cpa, fix lookup_address ...
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (25 commits) virtio: balloon driver virtio: Use PCI revision field to indicate virtio PCI ABI version virtio: PCI device virtio_blk: implement naming for vda-vdz,vdaa-vdzz,vdaaa-vdzzz virtio_blk: Dont waste major numbers virtio_blk: provide getgeo virtio_net: parametrize the napi_weight for virtio receive queue. virtio: free transmit skbs when notified, not on next xmit. virtio: flush buffers on open virtnet: remove double ether_setup virtio: Allow virtio to be modular and used by modules virtio: Use the sg_phys convenience function. virtio: Put the virtio under the virtualization menu virtio: handle interrupts after callbacks turned off virtio: reset function virtio: populate network rings in the probe routine, not open virtio: Tweak virtio_net defines virtio: Net header needs hdr_len virtio: remove unused id field from struct virtio_blk_outhdr virtio: clarify NO_NOTIFY flag usage ...
2008-02-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (79 commits) Jesper Juhl is the new trivial patches maintainer Documentation: mention email-clients.txt in SubmittingPatches fs/binfmt_elf.c: spello fix do_invalidatepage() comment typo fix Documentation/filesystems/porting fixes typo fixes in net/core/net_namespace.c typo fix in net/rfkill/rfkill.c typo fixes in net/sctp/sm_statefuns.c lib/: Spelling fixes kernel/: Spelling fixes include/scsi/: Spelling fixes include/linux/: Spelling fixes include/asm-m68knommu/: Spelling fixes include/asm-frv/: Spelling fixes fs/: Spelling fixes drivers/watchdog/: Spelling fixes drivers/video/: Spelling fixes drivers/ssb/: Spelling fixes drivers/serial/: Spelling fixes drivers/scsi/: Spelling fixes ...
2008-02-04kbuild: Fix instrumentation removal breakage on avr32Haavard Skinnemoen
AVR32 still includes Kconfig.instrumentation, so it won't build after this... Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04x86: cpa, micro-optimizationThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-04x86: cpa, clean up code flowIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: cpa, eliminate CPA_ enumIngo Molnar
2008-02-04x86: cpa, cleanupsIngo Molnar
2008-02-04x86: implement gbpages support in change_page_attr()Andi Kleen
Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: support gbpages in pagetable dumpAndi Kleen
2008-02-04x86: add gbpages support to lookup_addressAndi Kleen
[ tglx@linutronix.de: fix bootup crash on sparse mappings. ] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: switch direct mapping setup over to set_pteAndi Kleen
Use set_pte() for setting up the 2MB pages in the direct mapping. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: fix page-present check in cpa_flush_rangeThomas Gleixner
pte_present() might return true for PROT_NONE mappings. Explicitely check the present bit. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-04x86: remove cpa warningIngo Molnar
this race is legit and can happen on SMP systems. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: remove now unused clear_kernel_mappingAndi Kleen
2008-02-04x86: switch pci-gart over to using set_memory_np() instead of ↵Andi Kleen
clear_kernel_mapping() pci-gart needs to unmap the IOMMU aperture to prevent cache corruptions. Switch this over to using set_memory_np() instead of clear_kernel_mapping(). Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: cpa selftest, skip non present entriesThomas Gleixner
pud and pmd entries in the RAM area might be marked as non present. Do not try to modify them in the selftest. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
