path: root/arch
2006-07-31[PATCH] Fix trivial unwind info bugMarkus Armbruster
CFA needs to be adjusted upwards for push, and downwards for pop. arch/i386/kernel/entry.S gets it wrong in one place. Signed-off-by: Markus Armbruster <armbru@redhat.com> Acked-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] vDSO hash-style fixRoland McGrath
The latest toolchains can produce a new ELF section in DSOs and dynamically-linked executables. The new section ".gnu.hash" replaces ".hash", and allows for more efficient runtime symbol lookups by the dynamic linker. The new ld option --hash-style={sysv|gnu|both} controls whether to produce the old ".hash", the new ".gnu.hash", or both. In some new systems such as Fedora Core 6, gcc by default passes --hash-style=gnu to the linker, so that a standard invocation of "gcc -shared" results in producing a DSO with only ".gnu.hash". The new ".gnu.hash" sections need to be dealt with the same way as ".hash" sections in all respects; only the dynamic linker cares about their contents. To work with older dynamic linkers (i.e. preexisting releases of glibc), a binary must have the old ".hash" section. The --hash-style=both option produces binaries that a new dynamic linker can use more efficiently, but an old dynamic linker can still handle. The new section runs afoul of the custom linker scripts used to build vDSO images for the kernel. On ia64, the failure mode for this is a boot-time panic because the vDSO's PT_IA_64_UNWIND segment winds up ill-formed. This patch addresses the problem in two ways. First, it mentions ".gnu.hash" in all the linker scripts alongside ".hash". This produces correct vDSO images with --hash-style=sysv (or old tools), with --hash-style=gnu, or with --hash-style=both. Second, it passes the --hash-style=sysv option when building the vDSO images, so that ".gnu.hash" is not actually produced. This is the most conservative choice for compatibility with any old userland. There is some concern that some ancient glibc builds (though not any known old production system) might choke on --hash-style=both binaries. The optimizations provided by the new style of hash section do not really matter for a DSO with a tiny number of symbols, as the vDSO has. If someone wants to use =gnu or =both for their vDSO builds and worry less about that compatibility, just change the option and the linker script changes will make any choice work fine. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Andi Kleen <ak@muc.de> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] sgiioc4: Always share IRQBrent Casavant
The SGI IOC4 IDE device always shares an interrupt with other devices which are part of IOC4. As such, IDEPCI_SHARE_IRQ should always be enabled when BLK_DEV_SGIIOC4 is enabled. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] cpu hotplug: use hotplug version of registration in late initsChandra Seetharaman
Use hotplug version of register_cpu_notifier in late init functions. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] cpu hotplug: replace __devinit* with __cpuinit* for cpu notificationsChandra Seetharaman
Few of the callback functions and notifier blocks that are associated with cpu notifications incorrectly have __devinit and __devinitdata. They should be __cpuinit and __cpuinitdata instead. It makes no functional difference but wastes text area when CONFIG_HOTPLUG is enabled and CONFIG_HOTPLUG_CPU is not. This patch fixes all those instances. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Cc: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] panic_on_oops: remove ssleep()Horms
This patch is part of an effort to unify the panic_on_oops behaviour across all architectures that implement it. It was pointed out to me by Andi Kleen that if an oops has occured in interrupt context, then calling sleep() in the oops path will only cause a panic, and that it would be really better for it not to be in the path at all. This patch removes the ssleep() call and reworks the console message accordinly. I have a slght concern that the resulting console message is too long, feedback welcome. For powerpc it also unifies the 32bit and 64bit behaviour. Fror x86_64, this patch only updates the console message, as ssleep() is already not present. Signed-off-by: Horms <horms@verge.net.au> Acked-by: Paul Mackerras <paulus@samba.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] IDE: Touch NMI watchdog during resume from STRMichal Schmidt
When resuming from suspend-to-RAM, the NMI watchdog detects a lockup in ide_wait_not_busy. Here's a screenshot of the trace taken by a digital camera: http://www.uamt.feec.vutbr.cz/rizeni/pom/DSC03510-2.JPG Let's touch the NMI watchdog in ide_wait_not_busy. The system then resumes correctly from STR. [akpm@osdl.org: modular build fix] Signed-off-by: Michal Schmidt <xschmi00@stud.feec.vutbr.cz> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] v850: call init_page_count() instead of set_page_count()Miles Bader
Signed-off-by: Miles Bader <miles@gnu.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] v850: Remove symbol exports which duplicate global onesMiles Bader
2006-07-31[PATCH] IA64: kprobe invalidate icache of jump bufferbibo, mao
Kprobe inserts breakpoint instruction in probepoint and then jumps to instruction slot when breakpoint is hit, the instruction slot icache must be consistent with dcache. Here is the patch which invalidates instruction slot icache area. Without this patch, in some machines there will be fault when executing instruction slot where icache content is inconsistent with dcache. Signed-off-by: bibo,mao <bibo.mao@intel.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Acked-by: Keshavamurthy Anil S <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] arch/alpha: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of the macro. Also remove some trailing whitespaces and needless braces. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] i386: fix CONFIG_EFI helpArthur Othieno
It is described as being experimental, but doesn't actually depend on EXPERIMENTAL. Change the text. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] kprobe-booster: disable in preemptible kernelMasami Hiramatsu
The kprobe-booster's safety check against preemption does not work well now, because the preemption count has been modified by read_rcu_lock() in atomic_notifier_call_chain() before we check it. So, I'd like to prevent boosting kprobe temporarily if the kernel is preemptable. Now we are searching for the good solution. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] machine_kexec.c: Fix the description of segment handlingEric W. Biederman
One of my original comments in machine_kexec was unclear and this should fix it. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andi Kleen <ak@muc.de> Acked-by: Horms <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] synchronize_tsc() fixesAndrew Morton
- Move the tsc synchronisation variables into a struct, mark it __initdata - local `realdelta' wants to be 64-bit - Print the skew for negative skews, as well as for positive ones - remove dead code Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] mce section fixAndrew Morton
mce_disabled cannot be __initdata - we access it during APM resume. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3734/1: Fix the unused variable warning in __iounmap() [ARM] 3737/1: Export ARM copy/clear_user_page symbols [ARM] 3736/1: xscale: don't mis-report 80219 as an iop32x [ARM] 3733/2: S3C24XX: Remove old IDE registers in Anubis [ARM] 3732/1: S3C24XX: tidy syntax in osiris and anubis machines [ARM] Fix SMP booting [ARM] 3731/1: Allow IRQ definitions of IQ80331 and IQ80332 to co-exist [ARM] 3730/1: ep93xx: enable usb ohci driver in the defconfig [ARM] Fix cats build
2006-07-29[PATCH] i386: Fix up backtrace fallback patchAndi Kleen
I didn't test all compilation combinations. Shame on me. And fix a missing option in the boot option following x86-64 (Jan Beulich) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Fix swiotlb=forceAndi Kleen
It was broken before. But having it is important as possible hardware bug workaround. And previously there was no way to force swiotlb if there is another IOMMU. Side effect is that iommu=force won't force swiotlb anymore even if there isn't another IOMMU. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Revert k8-bus.c northbridge access changeAndi Kleen
As Travis Betak points out it accesses the wrong northbridge subfunction now. Switch back to the old code. Cc: "Travis Betak" <betak@mpdtxmail.amd.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Calgary IOMMU - Multi-Node NULL pointer dereference fixJon Mason
Calgary hits a NULL pointer dereference when booting in a multi-chassis NUMA system. See Redhat bugzilla number 198498, found by Konrad Rzeszutek (konradr@redhat.com). There are many issues that had to be resolved to fix this problem. Firstly when I originally wrote the code to handle NUMA systems, I had a large misunderstanding that was not corrected until now. That was that I thought the "number of nodes online" referred to number of physical systems connected. So that if NUMA was disabled, there would only be 1 node and it would only show that node's PCI bus. In reality if NUMA is disabled, the system displays all of the connected chassis as one node but is only ignorant of the delays in accessing main memory. Therefore, references to num_online_nodes() and MAX_NUMNODES are incorrect and need to be set to the maximum number of nodes that can be accessed (which are 8). I created a variable, MAX_NUM_CHASSIS, and set it to 8 to fix this. Secondly, when walking the PCI in detect_calgary, the code only checked the first "slot" when looking to see if a device is present. This will work for most cases, but unfortunately it isn't always the case. In the NUMA MXE drawers, there are USB devices present on the 3rd slot (with slot 1 being empty). So, to work around this, all slots (up to 8) are scanned to see if there are any devices present. Lastly, the bus is being enumerated on large systems in a different way the we originally thought. This throws the ugly logic we had out the window. To more elegantly handle this, I reorganized the kva array to be sparse (which removed the need to have any bus number to kva slot logic in tce.c) and created a secondary space array to contain the bus number to phb mapping. With these changes Calgary boots on an x460 with 4 nodes with and without NUMA enabled. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Calgary IOMMU - fix off by one errorMuli Ben-Yehuda
Fixed off-by-one error in detect_calgary and calgary_init which will cause arrays to overflow. Also, removed impossible to hit BUG_ON. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: On Intel systems when CPU has C3 don't use TSCAndi Kleen
On Intel systems generally the TSC stops in C3 or deeper, so don't use it there. Follows similar logic on i386. This should fix problems on Meroms. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[PATCH] x86_64: Update defconfigAndi Kleen
Update defconfig Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-29[ARM] 3734/1: Fix the unused variable warning in __iounmap()Catalin Marinas
Patch from Catalin Marinas This patch adds #ifdef around some variables in the arch/arm/mm/ioremap.c file. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-29[ARM] 3737/1: Export ARM copy/clear_user_page symbolsGeorge G. Davis
Patch from George G. Davis As reported by various folks on the ARM Linux kernel mailing list, the video-buf.ko driver has undefined references on all ARM machines which use it as observed during `make modules`: Warning: "v4wb_clear_user_page" [drivers/media/video/video-buf.ko] undefined! Similar warnings exist for all ARM machines which use this driver. So this change adds the missing EXPORT_SYMBOLs to allow using this driver as a module. Signed-off-by: George G. Davis <gdavis@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-29[ARM] 3736/1: xscale: don't mis-report 80219 as an iop32xLennert Buytenhek
Patch from Lennert Buytenhek The IOP 80219 xscale CPU is a stripped down version of the IOP32x. But the fact that the 80219 and IOP32x are very similar doesn't mean that they need to share a cpu table entry. It's also somewhat confusing for the end user to see the 80219 reported as an IOP32x, so this patch splits the IOP32x cpu table entry to make a separate entry for the 80219. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-28[PATCH] i386: Do backtrace fallback tooAndi Kleen
Similar patch to earlier x86-64 patch. When the dwarf2 unwinder fails dump the left over stack with the old unwinder. Also some clarifications in the headers. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] x86_64: Dump leftover backtrace entries when dwarf2 unwinder got stuckAndi Kleen
The dwarf2 unwinder currently often gets stuck because a lot of assembly code doesn't have proper dwarf2 annotiation yet. This currently often happens with __down. Should fix this by adding proper dwarf2 annotation to all inline assembly. However until that's done we need a quick fix for 2.6.18 to avoid incomplete backtraces. So when this happens dump the rest of the stack with the old unwinder instead of silently not dumping it. There was already a optional "both" mode that dumped both, but that was too ugly. I also clarified the headers for the different backtraces a bit. Also add a clear error message for missing dwarf2 annotation that people can work on. And I removed a dead variable left over from Ingo's changes. Cc: mingo@elte.hu Cc: jbeulich@novell.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] x86_64: Don't clobber r8-r11 in int 0x80 handlerAndi Kleen
When int 0x80 is called from long mode r8-r11 would leak out of the kernel (or rather they would be filled with some values from the kernel stack). I don't think it's a security issue because the values come from the fixed stack frame which should be near always user registers from a previous interrupt. Still better fix it. Longer term the register save macros need to be cleaned up to avoid such mistakes in the future. Original analysis from Richard Brunner, fix by me. Cc: Richard.Brunner@amd.com Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28[PATCH] i386/x86-64: Add user_mode checks to profile_pc for oprofileAndi Kleen
Fixes a obscure user space triggerable crash during oprofiling. Oprofile calls profile_pc from NMIs even when user_mode(regs) is not true and the program counter is inside the kernel lock section. This opens a race - when a user program jumps to a kernel lock address and a NMI happens before the illegal page fault exception is raised and the program has a unmapped esp or ebp then the kernel could oops. NMIs have a higher priority than exceptions so that could happen. Add user_mode checks to i386/x86-64 profile_pc to prevent that. Cc: John Levon <levon@movementarian.org> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-28Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] update default configuration [S390] duplicate ccw devices in ccwgroup. [S390] permanent subchannel busy conditions may cause I/O stall
2006-07-28Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SUNLANCE]: fix compilation on sparc-UP [SPARC]: Defer clock_probe to fs_initcall() [SPARC64]: Fix typo in pgprot_noncached(). [SPARC64]: Fix quad-float multiply emulation.
2006-07-28[PATCH] i386: switch_to(): misplaced parenthesesChuck Ebbert
Recent changes in i386 __switch_to() have a misplaced closing parenthesis causing an unlikely() to terminate early. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-27[SPARC]: Defer clock_probe to fs_initcall()Bob Breuer
From: Bob Breuer <breuerr@mc.net> That way all the of_driver bits will be ready. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-27[S390] update default configurationMartin Schwidefsky
2006-07-26[ARM] 3733/2: S3C24XX: Remove old IDE registers in AnubisBen Dooks
Patch from Ben Dooks Remove unused IDE static mapping, now being ioremap()d by the simtec IDE driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-26[ARM] 3732/1: S3C24XX: tidy syntax in osiris and anubis machinesBen Dooks
Patch from Ben Dooks Tidy the syntax, such as missing ,'s on the end of struct entries, in the Osiris and Anubis machines. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-26[ARM] Fix SMP bootingRussell King
Processor support files now use r6 in their CPU setup code, so we can't rely on r6 being preserved. Use r7 instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-24[SPARC64]: Explicitly print return PC when the kernel fault PC is bogus.David S. Miller
That way we'll have at least some debugging info even if the stack dump explodes. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC64]: Update defconfig.David S. Miller
2006-07-21[SPARC]: Fix length parameter verification in sys_getdomainname().David S. Miller
Found by scrashme. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC]: Get sun4d SMP building again.Raymond Burns
2006-07-21[SPARC]: Do not call sun4m_irq_rotate on sun4d.Raymond Burns
2006-07-21[SPARC]: Simplify and correct __cpu_find_by()David S. Miller
By using for_each_node_by_type(). Also, correct a spurioud test in check_cpu_node() on sparc64. It is only called with nodes that have device_type "cpu". Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC]: Initialize iounit spinlock in iounit_init().Raymond Burns
2006-07-21[SPARC]: Fix initialization of sun4d SBUS interrupts.David S. Miller
1) Explicitly traverse to the root looking for the "sbi". 2) Grab the "board#" property from the sbi's parent and verify that this parent is an "io-unit" node. 3) Skip IRQ initialization when device lacks "reg" property. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC]: Fix property name acquisition in prom.cBob Breuer
On sparc32 the prom_{first,next}prop() interfaces work a little differently. The buffer argument is ignored on sparc32 and the firmware just returns a raw pointer to the property name. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC]: Kill prom_getname, unused and not implemented properly.David S. Miller
The m68k port's sun3 asm/oplib.h had a stray reference too, so I killed that off as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SPARC64]: Fix more of_device layer IRQ bugs, and correct PROMREG_MAX.David S. Miller
Sabre and Psycho PCI controllers can have partial interrupt-map properties, meaning that on-board devices don't match up to any entries. Instead, they are fully specified from the beginning and we should pass them directly to the IRQ translator as-is. Also, fill in the necessary translator slots for the "graphics" and "expansion UPA" interrupts on Sabre, Psycho, and SYSIO SBUS. Increase PROMREG_MAX to 24, as seen on SUNW,ffb devices. Finally, prevent accidentally writing past the end of the of_device struct resource[] and irqs[] arrays. Spit out a log message when we ignore some entries because there are too many of them. Signed-off-by: David S. Miller <davem@davemloft.net>
