commit aab0a4c83ceb344d2327194bf354820e50607af6 upstream.
The memory range assigned to the PMC (Power Management Controller) was
not including the PMC_PCR register which are used to control peripheral
clocks.
This was working fine thanks to the page granularity of ioremap(), but
started to fail when we switched to syscon/regmap, because regmap is
making sure that all accesses are falling into the reserved range.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reported-by: Richard Genoud <richard.genoud@gmail.com>
Tested-by: Richard Genoud <richard.genoud@gmail.com>
Fixes: 863a81c3be1d ("clk: at91: make use of syscon to share PMC registers in several drivers")
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 723cacbd9dc79582e562c123a0bacf8bfc69e72a upstream.
There is a race with multi-threaded applications between context switch and
pagetable upgrade. In switch_mm() a new user_asce is built from mm->pgd and
mm->context.asce_bits, w/o holding any locks. A concurrent mmap with a
pagetable upgrade on another thread in crst_table_upgrade() could already
have set new asce_bits, but not yet the new mm->pgd. This would result in a
corrupt user_asce in switch_mm(), and eventually in a kernel panic from a
translation exception.
Fix this by storing the complete asce instead of just the asce_bits, which
can then be read atomically from switch_mm(), so that it either sees the
old value or the new value, but no mixture. Both cases are OK. Having the
old value would result in a page fault on access to the higher level memory,
but the fault handler would see the new mm->pgd, if it was a valid access
after the mmap on the other thread has completed. So as worst-case scenario
we would have a page fault loop for the racing thread until the next time
slice.
Also remove dead code and simplify the upgrade/downgrade path, there are no
upgrades from 2 levels, and only downgrades from 3 levels for compat tasks.
There are also no concurrent upgrades, because the mmap_sem is held with
down_write() in do_mmap, so the flush and table checks during upgrade can
be removed.
Reported-by: Michael Munday <munday@ca.ibm.com>
Reviewed-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit a21211672c9a1d730a39aa65d4a5b3414700adfb upstream.
There are several reports of freeze on enabling HWP (Hardware PStates)
feature on Skylake-based systems by the Intel P-states driver. The root
cause is identified as the HWP interrupts causing BIOS code to freeze.
HWP interrupts use the thermal LVT which can be handled by Linux
natively, but on the affected Skylake-based systems SMM will respond
to it by default. This is a problem for several reasons:
- On the affected systems the SMM thermal LVT handler is broken (it
will crash when invoked) and a BIOS update is necessary to fix it.
- With thermal interrupt handled in SMM we lose all of the reporting
features of the arch/x86/kernel/cpu/mcheck/therm_throt driver.
- Some thermal drivers like x86-package-temp depend on the thermal
threshold interrupts signaled via the thermal LVT.
- The HWP interrupts are useful for debugging and tuning
performance (if the kernel can handle them).
The native handling of thermal interrupts needs to be enabled
because of that.
This requires some way to tell SMM that the OS can handle thermal
interrupts. That can be done by using _OSC/_PDC in processor
scope very early during ACPI initialization.
The meaning of _OSC/_PDC bit 12 in processor scope is whether or
not the OS supports native handling of interrupts for Collaborative
Processor Performance Control (CPPC) notifications. Since on
HWP-capable systems CPPC is a firmware interface to HWP, setting
this bit effectively tells the firmware that the OS will handle
thermal interrupts natively going forward.
For details on _OSC/_PDC refer to:
http://www.intel.com/content/www/us/en/standards/processor-vendor-specific-acpi-specification.html
To implement the _OSC/_PDC handshake as described, introduce a new
function, acpi_early_processor_osc(), that walks the ACPI
namespace looking for ACPI processor objects and invokes _OSC for
them with bit 12 in the capabilities buffer set and terminates the
namespace walk on the first success.
Also modify intel_thermal_interrupt() to clear HWP status bits in
the HWP_STATUS MSR to acknowledge HWP interrupts (which prevents
them from firing continuously).
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
[ rjw: Subject & changelog, function rename ]
commit b4c112114aab9aff5ed4568ca5e662bb02cdfe74 upstream.
In create_zero_mask() we have:
addi %1,%2,-1
andc %1,%1,%2
popcntd %0,%1
using the "r" constraint for %2. r0 is a valid register in the "r" set,
but addi X,r0,X turns it into an li:
li r7,-1
andc r7,r7,r0
popcntd r4,r7
Fix this by using the "b" constraint, for which r0 is not a valid
register.
This was found with a kernel build using gcc trunk, narrowed down to
when -frename-registers was enabled at -O2. It is just luck however
that we aren't seeing this on older toolchains.
Thanks to Segher for working with me to find this issue.
Fixes: d0cebfa650a0 ("powerpc: word-at-a-time optimization for 64-bit Little Endian")
commit c10fcb14c7afd6688c7b197a814358fecf244222 upstream.
The code for checking whether a BAR address range is valid will break
out of the loop when a start address of 0x0 is encountered.
This behaviour is wrong since by breaking out of the loop we may miss
the BAR that describes the EFI frame buffer in a later iteration.
Because of this bug I can't use video=efifb: boot parameter to get
efifb on my new ThinkPad E550 for my old linux system hard disk with
3.10 kernel. In 3.10, efifb is the only choice due to DRM/I915 not
supporting the GPU.
This patch also add a trivial optimization to break out after we find
the frame buffer address range without testing later BARs.
Signed-off-by: Wang YanQing <udknight@gmail.com>
[ Rewrote changelog. ]
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
Reviewed-by: Peter Jones <pjones@redhat.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: David Herrmann <dh.herrmann@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: linux-efi@vger.kernel.org
Link: http://lkml.kernel.org/r/1462454061-21561-2-git-send-email-matt@codeblueprint.co.uk
commit e5bc0478ab6cf565619224536d75ecb2aedca43b upstream.
While reviewing a different change to asm-generic/io.h Arnd spotted that
ARC ioread32 and ioread32be both of which come from asm-generic versions
are not symmetrical in terms of calling the io barriers.
generic ioread32 -> ARC readl() [ has barriers]
generic ioread32be -> __be32_to_cpu(__raw_readl()) [ lacks barriers]
While generic ioread32be is being remediated to call readl(), that involves
a swab32(), causing double swaps on ioread32be() on Big Endian systems.
So provide our versions of big endian IO accessors to ensure io barrier
calls while also keeping them optimal
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
commit 886123fb3a8656699dff40afa0573df359abeb18 upstream.
Currently we read the tsc radio: ratio = (MSR_PLATFORM_INFO >> 8) & 0x1f;
Thus we get bit 8-12 of MSR_PLATFORM_INFO, however according to the SDM
(35.5), the ratio bits are bit 8-15.
Ignoring the upper bits can result in an incorrect tsc ratio, which causes the
TSC calibration and the Local APIC timer frequency to be incorrect.
Fix this problem by masking 0xff instead.
[ tglx: Massaged changelog ]
Fixes: 7da7c1561366 "x86, tsc: Add static (MSR) TSC calibration on Intel Atom SoCs"
Signed-off-by: Chen Yu <yu.c.chen@intel.com>
Cc: "Rafael J. Wysocki" <rafael@kernel.org>
Cc: Bin Gao <bin.gao@intel.com>
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/1462505619-5516-1-git-send-email-yu.c.chen@intel.com
commit 5616f36713ea77f57ae908bf2fef641364403c9f upstream.
The secondary CPU starts up in ARM mode. When the kernel is compiled in
thumb2 mode we have to explicitly compile the secondary startup
trampoline in ARM mode, otherwise the CPU will go to Nirvana.
Reported-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Suggested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
commit a0a966b83873f33778710a4fc59240244b0734a5 upstream.
We want to skip reparenting a clock on turning on power domain, if we
do not have the parent yet. The parent is obtained when turning the
domain off. However due to a typo, the loop is continued on IS_ERR() of
clock being reparented, not on the IS_ERR() of the parent.
Theoretically this could lead to OOPS on first turn on of a power
domain, if there was no turn off before. Practically that should never
happen because all power domains are turned on by default (reset value,
bootloader does not turn off them usually) so the first action will be
always turn off.
Fixes: 29e5eea06bc1 ("ARM: EXYNOS: Get current parent clock for power domain on/off")
Reported-by: Vladimir Zapolskiy <vz@mleia.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit 88e9da9a2a70b6f1a171fbf30a681d6bc4031c4d upstream.
The "where" offset was added twice, fix it.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
Fixes: 498a92d42596 ("ARM: cns3xxx: pci: avoid potential stack overflow")
This reverts commit e924c60db1b4891e45d15a33474ac5fab62cf029 which was
commit 7f821fc9c77a9b01fe7b1d6e72717b33d8d64142 upstream.
It shouldn't have been applied as the original was already in 4.4.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Cc: Michael Neuling <mikey@neuling.org>
Cc: Michael Ellerman <mpe@ellerman.id.au>
commit 07c6b2d01d351f0512ed7145625265e435ab3240 upstream.
Since the switch from mmp_pdma to pxa_dma driver for pxa architectures,
the pxa_dma requires 2 arguments, namely the requestor line and the
requested priority.
Fix the only left device node which was still passing only one argument,
making the pxa3xx-nand driver misbehave in a device-tree configuration,
ie. failing all data transfers.
Fixes: c943646d1f49 ("ARM: dts: pxa: add dma engine node to pxa3xx-nand")
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
commit b3a7f31eb7375633cd6a742f19488fc5a4208b36 upstream.
The Armada 375 has the same SATA IP as Armada 370 and Armada XP, which
requires the PHY speed to be set in the LP_PHY_CTL register for SATA
hotplug to work.
Therefore, this commit updates the compatible string used to describe
the SATA IP in Armada 375 from marvell,orion-sata to
marvell,armada-370-sata.
Fixes: 4de59085091f753d08c8429d756b46756ab94665 ("ARM: mvebu: add Device Tree description of the Armada 375 SoC")
Signed-off-by: Lior Amsalem <alior@marvell.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit dc7eb9d589e595954792cc192bcbb92932e5c2ff upstream.
We cannot select a symbol that has disabled dependencies, so
we get a warning if we ever enable EXYNOS_THERMAL without
also turning on THERMAL_OF:
warning: (ARCH_EXYNOS) selects EXYNOS_THERMAL which has unmet direct dependencies (THERMAL && (ARCH_EXYNOS || COMPILE_TEST) && THERMAL_OF)
This adds another 'select' in the platform code to avoid that
case. Alternatively, we could decide to not select EXYNOS_THERMAL
here and instead make it a user option.
Fixes: f87e6bd3f740 ("thermal: exynos: Add the dependency of CONFIG_THERMAL_OF instead of CONFIG_OF")
commit ef2b1d777d643af227a22309d8b79898b90b123c upstream.
The atlas7 clock controller driver registers a reset controller
for itself, which causes a link error when the subsystem is
disabled:
drivers/built-in.o: In function `atlas7_clk_init':
drivers/clk/sirf/clk-atlas7.c:1681: undefined reference to `reset_controller_register'
As the clk driver does not have a Kconfig symbol for itself
but it always built-in when the platform is enabled, we have
to ensure that the reset controller subsystem is also built-in
in this case.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Fixes: 301c5d29402e ("clk: sirf: add CSR atlas7 clk and reset support")
commit 98f42221501353067251fbf11e732707dbb68ce3 upstream.
Based on CPU type choose generic omap3 or omap3430 specific cpuidle
parameters. Parameters for omap3430 were measured on Nokia N900 device and
added by commit 5a1b1d3a9efa ("OMAP3: RX-51: Pass cpu idle parameters")
which were later removed by commit 231900afba52 ("ARM: OMAP3: cpuidle -
remove rx51 cpuidle parameters table") due to huge code complexity.
This patch brings cpuidle parameters for omap3430 devices again, but uses
simple condition based on CPU type.
Fixes: 231900afba52 ("ARM: OMAP3: cpuidle - remove rx51 cpuidle
parameters table")
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit cfa52c0cfa4d727aa3e457bf29aeff296c528a08 upstream.
Because Linux might use bigger pages than the 4K pages to handle those mmio
ioremaps, the kmmio code shouldn't rely on the pade id as it currently does.
Using the memory address instead of the page id lets us look up how big the
page is and what its base address is, so that we won't get a page fault
within the same page twice anymore.
Tested-by: Pierre Moreau <pierre.morrow@free.fr>
Signed-off-by: Karol Herbst <nouveau@karolherbst.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: linux-mm@kvack.org
Cc: linux-x86_64@vger.kernel.org
Cc: nouveau@lists.freedesktop.org
Cc: pq@iki.fi
Cc: rostedt@goodmis.org
Link: http://lkml.kernel.org/r/1456966991-6861-1-git-send-email-nouveau@karolherbst.de
commit 1bdb8970392a68489b469c3a330a1adb5ef61beb upstream.
If x86_vector_alloc_irq() fails x86_vector_free_irqs() is invoked to cleanup
the already allocated vectors. This subsequently calls clear_vector_irq().
The failed irq has no vector assigned, which triggers the BUG_ON(!vector) in
clear_vector_irq().
We cannot suppress the call to x86_vector_free_irqs() for the failed
interrupt, because the other data related to this irq must be cleaned up as
well. So calling clear_vector_irq() with vector == 0 is legitimate.
Remove the BUG_ON and return if vector is zero,
Fixes: b5dc8e6c21e7 "x86/irq: Use hierarchical irqdomain to manage CPU interrupt vectors"
Signed-off-by: Keith Busch <keith.busch@intel.com>
commit 4705e02498d6d5a7ab98dfee9595cd5e91db2017 upstream.
We need to update the user TM feature bits (PPC_FEATURE2_HTM and
PPC_FEATURE2_HTM) to mirror what we do with the kernel TM feature
bit.
At the moment, if firmware reports TM is not available we turn off
the kernel TM feature bit but leave the userspace ones on. Userspace
thinks it can execute TM instructions and it dies trying.
This (together with a QEMU patch) fixes PR KVM, which doesn't currently
support TM.
commit beff82374b259d726e2625ec6c518a5f2613f0ae upstream.
scan_features() updates cpu_user_features but not cpu_user_features2.
Amongst other things, cpu_user_features2 contains the user TM feature
bits which we must keep in sync with the kernel TM feature bit.
commit 6997e57d693b07289694239e52a10d2f02c3a46f upstream.
The REAL_LE feature entry in the ibm_pa_feature struct is missing an MMU
feature value, meaning all the remaining elements initialise the wrong
values.
This means instead of checking for byte 5, bit 0, we check for byte 0,
bit 0, and then we incorrectly set the CPU feature bit as well as MMU
feature bit 1 and CPU user feature bits 0 and 2 (5).
Checking byte 0 bit 0 (IBM numbering), means we're looking at the
"Memory Management Unit (MMU)" feature - ie. does the CPU have an MMU.
In practice that bit is set on all platforms which have the property.
This means we set CPU_FTR_REAL_LE always. In practice that seems not to
matter because all the modern cpus which have this property also
implement REAL_LE, and we've never needed to disable it.
We're also incorrectly setting MMU feature bit 1, which is:
#define MMU_FTR_TYPE_8xx 0x00000002
Luckily the only place that looks for MMU_FTR_TYPE_8xx is in Book3E
code, which can't run on the same cpus as scan_features(). So this also
doesn't matter in practice.
Finally in the CPU user feature mask, we're setting bits 0 and 2. Bit 2
is not currently used, and bit 0 is:
#define PPC_FEATURE_PPC_LE 0x00000001
Which says the CPU supports the old style "PPC Little Endian" mode.
Again this should be harmless in practice as no 64-bit CPUs implement
that mode.
Fix the code by adding the missing initialisation of the MMU feature.
Also add a comment marking CPU user feature bit 2 (0x4) as reserved. It
would be unsafe to start using it as old kernels incorrectly set it.
Fixes: 44ae3ab3358e ("powerpc: Free up some CPU feature bits by moving out MMU-related features")
[mpe: Flesh out changelog, add comment reserving 0x4]
commit 0851561d9c965df086ef8a53f981f5f95a57c2c8 upstream.
In sha_complete_job, incorrect mcryptd_hash_request_ctx pointer is used
when check and complete other jobs. If the memory of first completed req
is freed, while still completing other jobs in the func, kernel will
crash since NULL pointer is assigned to RIP.
Signed-off-by: Xiaodong Liu <xiaodong.liu@intel.com>
Acked-by: Tim Chen <tim.c.chen@linux.intel.com>
commit 9d89d9e61d361f3adb75e1aebe4bb367faf16cfa upstream.
Newer machines might use a different (larger) format for function
measurement blocks. To ensure that we comply with the alignment
requirement on these machines and prevent memory corruption (when
firmware writes more data than we expect) add 16 padding bytes
at the end of the fmb.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
commit 103f6112f253017d7062cd74d17f4a514ed4485c upstream.
Huge pages are not normally available to PV guests. Not suppressing
hugetlbfs use results in an endless loop of page faults when user mode
code tries to access a hugetlbfs mapped area (since the hypervisor
denies such PTEs to be created, but error indications can't be
propagated out of xen_set_pte_at(), just like for various of its
siblings), and - once killed in an oops like this:
kernel BUG at .../fs/hugetlbfs/inode.c:428!
invalid opcode: 0000 [#1] SMP
RIP: e030:[<ffffffff811c333b>] [<ffffffff811c333b>] remove_inode_hugepages+0x25b/0x320
Call Trace:
[<ffffffff811c3415>] hugetlbfs_evict_inode+0x15/0x40
[<ffffffff81167b3d>] evict+0xbd/0x1b0
[<ffffffff8116514a>] __dentry_kill+0x19a/0x1f0
[<ffffffff81165b0e>] dput+0x1fe/0x220
[<ffffffff81150535>] __fput+0x155/0x200
[<ffffffff81079fc0>] task_work_run+0x60/0xa0
[<ffffffff81063510>] do_exit+0x160/0x400
[<ffffffff810637eb>] do_group_exit+0x3b/0xa0
[<ffffffff8106e8bd>] get_signal+0x1ed/0x470
[<ffffffff8100f854>] do_signal+0x14/0x110
[<ffffffff810030e9>] prepare_exit_to_usermode+0xe9/0xf0
[<ffffffff814178a5>] retint_user+0x8/0x13
This is CVE-2016-3961 / XSA-174.
Reported-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <JGross@suse.com>
Cc: xen-devel <xen-devel@lists.xenproject.org>
Link: http://lkml.kernel.org/r/57188ED802000078000E431C@prv-mh.provo.novell.com
commit fdc69e7df3cb24f18a93192641786e5b7ecd1dfe upstream.
The set_pte_at() function must update the hardware PTE_RDONLY bit
depending on the state of the PTE_WRITE and PTE_DIRTY bits of the given
entry value. However, it currently only performs this for pte_valid()
entries, ignoring PTE_PROT_NONE. The side-effect is that PROT_NONE
mappings would not have the PTE_RDONLY bit set. Without
CONFIG_ARM64_HW_AFDBM, this is not an issue since such PROT_NONE pages
are not accessible anyway.
With commit 2f4b829c625e ("arm64: Add support for hardware updates of
the access and dirty pte bits"), the ptep_set_wrprotect() function was
re-written to cope with automatic hardware updates of the dirty state.
As an optimisation, only PTE_RDONLY is checked to assess the "dirty"
status. Since set_pte_at() does not set this bit for PROT_NONE mappings,
such pages may be considered "dirty" as a result of
ptep_set_wrprotect().
This patch updates the pte_valid() check to pte_present() in
set_pte_at(). It also adds PTE_PROT_NONE to the swap entry bits comment.
Fixes: 2f4b829c625e ("arm64: Add support for hardware updates of the access and dirty pte bits")
Reported-by: Ganapatrao Kulkarni <gkulkarni@caviumnetworks.com>
Tested-by: Ganapatrao Kulkarni <gkulkarni@cavium.com>
commit ac15bd63bbb24238f763ec5b24ee175ec301e8cd upstream.
Currently, set_pte_at() only checks the software PTE_WRITE bit for user
mappings when it sets or clears the hardware PTE_RDONLY accordingly. The
kernel ptes are written directly without any modification, relying
solely on the protection bits in macros like PAGE_KERNEL. However,
modifying kernel pte attributes via pte_wrprotect() would be ignored by
set_pte_at(). Since pte_wrprotect() does not set PTE_RDONLY (it only
clears PTE_WRITE), the new permission is not taken into account.
This patch changes set_pte_at() to adjust the read-only permission for
kernel ptes as well. As a side effect, existing PROT_* definitions used
for kernel ioremap*() need to include PTE_DIRTY | PTE_WRITE.
(additionally, white space fix for PTE_KERNEL_ROX)
Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit 3ca4a238106dedc285193ee47f494a6584b6fd2f upstream.
Commit 127500ccb766f ("ARM: OMAP2+: Only write the sysconfig on idle
when necessary") talks about verification of sysconfig cache value before
updating it, only during idle path. But the patch is adding the
verification in the enable path. So, adding the check in a proper place
as per the commit description.
Not keeping this check during enable path as there is a chance of losing
context and it is safe to do on idle as the context of the register will
never be lost while the device is active.
Acked-by: Tero Kristo <t-kristo@ti.com>
Cc: Jon Hunter <jonathanh@nvidia.com>
Fixes: commit 127500ccb766 "ARM: OMAP2+: Only write the sysconfig on idle when necessary"
[paul@pwsan.com: appears to have been caused by my own mismerge of the
originally posted patch]
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit 456e8d53482537616899a146b706eccd095404e6 upstream.
The following commits:
commit 3fa609755c11 ("ARM: omap2: restore OMAP4 barrier behaviour")
commit f746929ffdc8 ("Revert "ARM: OMAP4: remove dead kconfig option OMAP4_ERRATA_I688"")
and
commit ea827ad5ffbb ("ARM: DRA7: Provide proper IO map table")
came in around the same time, unfortunately this seem to have missed
initializing the barrier for DRA7 platforms - omap5_map_io was reused
for dra7 till it was split out by the last patch. barrier_init
needs to be hence carried forward as it is valid for DRA7 family of
processors as they are for OMAP5.
Fixes: ea827ad5ffbb7 ("ARM: DRA7: Provide proper IO map table")
Reported-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Reported-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Nishanth Menon <nm@ti.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 199831c77c50e6913e893b6bc268ba9f4a9a2bf8 upstream.
The USB2 port for Armada 38x is defined to be at 58000, not at
50000.
Fixes: 2d0a7addbd10 ("ARM: Kirkwood: Add support for many Synology NAS devices")
Signed-off-by: Patrick Uiterwijk <patrick@puiterwijk.org>
Acked-by: Imre Kaloz <kaloz@openwrt.org>
commit cfe1580a6415bc37fd62d79eb8102a618f7650b2 upstream.
commit 55ee7017ee31 ("arm: omap2: board-generic: use omap4_local_timer_init
for AM437x") makes synctimer32k as the clocksource on AM43xx. By default
the synctimer32k is clocked by 32K RTC OSC on AM43xx. But this 32K RTC OSC
is not available on epos boards which makes it fail to boot.
Synctimer32k can also be clocked by a peripheral PLL, so making this as
clock parent for synctimer3k on epos boards.
Fixes: 55ee7017ee31 ("arm: omap2: board-generic: use omap4_local_timer_init for AM437x")
Reported-by: Nishanth Menon <nm@ti.com>
commit fc5b7f3bf1e1414bd4e91db6918c85ace0c873a5 upstream.
An interrupt handler that uses the fpu can kill a KVM VM, if it runs
under the following conditions:
- the guest's xcr0 register is loaded on the cpu
- the guest's fpu context is not loaded
- the host is using eagerfpu
Note that the guest's xcr0 register and fpu context are not loaded as
part of the atomic world switch into "guest mode". They are loaded by
KVM while the cpu is still in "host mode".
Usage of the fpu in interrupt context is gated by irq_fpu_usable(). The
interrupt handler will look something like this:
if (irq_fpu_usable()) {
kernel_fpu_begin();
[... code that uses the fpu ...]
kernel_fpu_end();
As long as the guest's fpu is not loaded and the host is using eager
fpu, irq_fpu_usable() returns true (interrupted_kernel_fpu_idle()
returns true). The interrupt handler proceeds to use the fpu with
the guest's xcr0 live.
kernel_fpu_begin() saves the current fpu context. If this uses
XSAVE[OPT], it may leave the xsave area in an undesirable state.
According to the SDM, during XSAVE bit i of XSTATE_BV is not modified
if bit i is 0 in xcr0. So it's possible that XSTATE_BV[i] == 1 and
xcr0[i] == 0 following an XSAVE.
kernel_fpu_end() restores the fpu context. Now if any bit i in
XSTATE_BV == 1 while xcr0[i] == 0, XRSTOR generates a #GP. The
fault is trapped and SIGSEGV is delivered to the current process.
Only pre-4.2 kernels appear to be vulnerable to this sequence of
events. Commit 653f52c ("kvm,x86: load guest FPU context more eagerly")
from 4.2 forces the guest's fpu to always be loaded on eagerfpu hosts.
This patch fixes the bug by keeping the host's xcr0 loaded outside
of the interrupts-disabled region where KVM switches into guest mode.
Suggested-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: David Matlack <dmatlack@google.com>
[Move load after goto cancel_injection. - Paolo]
commit a3125494cff084b098c80bb36fbe2061ffed9d52 upstream.
When we loop over all queued machine check error records to pass them
to the registered notifiers we use llist_for_each_entry(). But the loop
calls gen_pool_free() for the entry in the body of the loop - and then
the iterator looks at node->next after the free.
Use llist_for_each_entry_safe() instead.
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: Gong Chen <gong.chen@linux.intel.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/0205920@agluck-desk.sc.intel.com
Link: http://lkml.kernel.org/r/1459929916-12852-4-git-send-email-bp@alien8.de
commit 6c777e8799a93e3bdb67bec622429e1b48dc90fb upstream.
991de2e59090 ("PCI, x86: Implement pcibios_alloc_irq() and
pcibios_free_irq()") appeared in v4.3 and helps support IOAPIC hotplug.
Олег reported that the Elcus-1553 TA1-PCI driver worked in v4.2 but not
v4.3 and bisected it to 991de2e59090. Sunjin reported that the RocketRAID
272x driver worked in v4.2 but not v4.3. In both cases booting with
"pci=routirq" is a workaround.
I think the problem is that after 991de2e59090, we no longer call
pcibios_enable_irq() for upstream bridges. Prior to 991de2e59090, when a
driver called pci_enable_device(), we recursively called
pcibios_enable_irq() for upstream bridges via pci_enable_bridge().
After 991de2e59090, we call pcibios_enable_irq() from pci_device_probe()
instead of the pci_enable_device() path, which does *not* call
Revert 991de2e59090 to fix these driver regressions.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=111211
Fixes: 991de2e59090 ("PCI, x86: Implement pcibios_alloc_irq() and pcibios_free_irq()")
Reported-and-tested-by: Олег Мороз <oleg.moroz@mcc.vniiem.ru>
Reported-by: Sunjin Yang <fan4326@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Rafael J. Wysocki <rafael@kernel.org>
CC: Jiang Liu <jiang.liu@linux.intel.com>
commit 67b4eab91caf2ad574cab1b17ae09180ea2e116e upstream.
Revert 811a4e6fce09 ("PCI: Add helpers to manage pci_dev->irq and
pci_dev->irq_managed").
This is part of reverting 991de2e59090 ("PCI, x86: Implement
pcibios_alloc_irq() and pcibios_free_irq()") to fix regressions it
introduced.
commit fe25d078874f2c29c38f4160467d74f5756537c9 upstream.
Revert 8affb487d4a4 ("x86/PCI: Don't alloc pcibios-irq when MSI is
enabled").
introduced.
CC: Joerg Roedel <jroedel@suse.de>
commit cf0a25436f05753aca5151891aea4fd130556e2a upstream.
BUG: sleeping function called from invalid context at kernel/locking/rtmutex.c:917
in_atomic(): 1, irqs_disabled(): 128, pid: 383, name: sh
Preemption disabled at:[<ffff800000124c18>] kgdb_cpu_enter+0x158/0x6b8
CPU: 3 PID: 383 Comm: sh Tainted: G W 4.1.13-rt13 #2
Hardware name: Freescale Layerscape 2085a RDB Board (DT)
Call trace:
[<ffff8000000885e8>] dump_backtrace+0x0/0x128
[<ffff800000088734>] show_stack+0x24/0x30
[<ffff80000079a7c4>] dump_stack+0x80/0xa0
[<ffff8000000bd324>] ___might_sleep+0x18c/0x1a0
[<ffff8000007a20ac>] __rt_spin_lock+0x2c/0x40
[<ffff8000007a2268>] rt_read_lock+0x40/0x58
[<ffff800000085328>] single_step_handler+0x38/0xd8
[<ffff800000082368>] do_debug_exception+0x58/0xb8
Exception stack(0xffff80834a1e7c80 to 0xffff80834a1e7da0)
7c80: ffffff9c ffffffff 92c23ba0 0000ffff 4a1e7e40 ffff8083 001bfcc4 ffff8000
7ca0: f2000400 00000000 00000000 00000000 4a1e7d80 ffff8083 0049501c ffff8000
7cc0: 00005402 00000000 00aaa210 ffff8000 4a1e7ea0 ffff8083 000833f4 ffff8000
7ce0: ffffff9c ffffffff 92c23ba0 0000ffff 4a1e7ea0 ffff8083 001bfcc0 ffff8000
7d00: 4a0fc400 ffff8083 00005402 00000000 4a1e7d40 ffff8083 00490324 ffff8000
7d20: ffffff9c 00000000 92c23ba0 0000ffff 000a0000 00000000 00000000 00000000
7d40: 00000008 00000000 00080000 00000000 92c23b8b 0000ffff 92c23b8e 0000ffff
7d60: 00000038 00000000 00001cb2 00000000 00000005 00000000 92d7b498 0000ffff
7d80: 01010101 01010101 92be9000 0000ffff 00000000 00000000 00000030 00000000
[<ffff8000000833f4>] el1_dbg+0x18/0x6c
This issue is similar with 62c6c61("arm64: replace read_lock to rcu lock in
call_break_hook"), but comes to single_step_handler.
This also solves kgdbts boot test silent hang issue on 4.4 -rt kernel.
Signed-off-by: Yang Shi <yang.shi@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
commit e34b6fcf9b09ec9d93503edd5f81489791ffd602 upstream.
remove the usage of removed irq_to_gpio() function. On pre-DB1200
boards, pass the actual carddetect GPIO number instead of the IRQ,
because we need the gpio to actually test card status (inserted or
not) and can get the irq number with gpio_to_irq() instead.
Tested on DB1300 and DB1500, this patch fixes PCMCIA on the DB1500,
which used irq_to_gpio().
Fixes: 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h")
Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com>
Cc: linux-pcmcia@lists.infradead.org
Cc: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/12747/
commit fa8ff601d72bad3078ddf5ef17a5547700d06908 upstream.
Copying the content of an MSA vector from user memory may involve TLB
faults & mapping in pages. This will fail when preemption is disabled
due to an inability to acquire mmap_sem from do_page_fault, which meant
such vector loads to unmapped pages would always fail to be emulated.
Fix this by disabling preemption later only around the updating of
vector register state.
This change does however introduce a race between performing the load
into thread context & the thread being preempted, saving its current
live context & clobbering the loaded value. This should be a rare
occureence, so optimise for the fast path by simply repeating the load if
we are preempted.
Additionally if the copy failed then the failure path was taken with
preemption left disabled, leading to the kernel typically encountering
further issues around sleeping whilst atomic. The change to where
preemption is disabled avoids this issue.
Fixes: e4aa1f153add "MIPS: MSA unaligned memory access support"
Reported-by: James Hogan <james.hogan@imgtec.com>
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Reviewed-by: James Hogan <james.hogan@imgtec.com>
Cc: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: James Cowgill <James.Cowgill@imgtec.com>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/12345/
commit 14ebda3394fd3e5388747e742e510b0802a65d24 upstream.
Windows lets applications choose the frequency of the timer tick,
and in Windows 10 the maximum rate was changed from 1024 Hz to
2048 Hz. Unfortunately, because of the way the Windows API
works, most applications who need a higher rate than the default
64 Hz will just do
timeGetDevCaps(&tc, sizeof(tc));
timeBeginPeriod(tc.wPeriodMin);
and pick the maximum rate. This causes very high CPU usage when
playing media or games on Windows 10, even if the guest does not
actually use the CPU very much, because the frequent timer tick
causes halt_poll_ns to kick in.
There is no really good solution, especially because Microsoft
could sooner or later bump the limit to 4096 Hz, but for now
the best we can do is lower a bit the upper limit for
halt_poll_ns. :-(
Reported-by: Jon Panozzo <jonp@lime-technology.com>
commit 321c5658c5e9192dea0d58ab67cf1791e45b2b26 upstream.
Non maskable interrupts (NMI) are preferred to interrupts in current
implementation. If a NMI is pending and NMI is blocked by the result
of nmi_allowed(), pending interrupt is not injected and
enable_irq_window() is not executed, even if interrupts injection is
allowed.
In old kernel (e.g. 2.6.32), schedule() is often called in NMI context.
In this case, interrupts are needed to execute iret that intends end
of NMI. The flag of blocking new NMI is not cleared until the guest
execute the iret, and interrupts are blocked by pending NMI. Due to
this, iret can't be invoked in the guest, and the guest is starved
until block is cleared by some events (e.g. canceling injection).
This patch injects pending interrupts, when it's allowed, even if NMI
is blocked. And, If an interrupts is pending after executing
inject_pending_event(), enable_irq_window() is executed regardless of
NMI pending counter.
Signed-off-by: Yuki Shibuya <shibuya.yk@ncos.nec.co.jp>
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
commit a6002ec5a8c68e69706b2efd6db6d682d0ab672c upstream.
arm and arm64 use different config options to specify big endian. This
needs taking into account when including code/headers between the two
architectures.
A case in point is PAN, which uses the __instr_arm() macro to output
instructions. The macro comes from opcodes.h, which lives under arch/arm.
On a big-endian build the mismatched config options mean the instruction
isn't byte swapped correctly, resulting in undefined instruction exceptions
during boot:
| alternatives: patching kernel code
| kdevtmpfs[87]: undefined instruction: pc=ffffffc0004505b4
| kdevtmpfs[87]: undefined instruction: pc=ffffffc00076231c
| Internal error: Oops - undefined instruction: 0 [#1] SMP
| Modules linked in:
| CPU: 0 PID: 87 Comm: kdevtmpfs Not tainted 4.1.16+ #5
| Hardware name: Hisilicon PhosphorHi1382 EVB (DT)
| task: ffffffc336591700 ti: ffffffc3365a4000 task.ti: ffffffc3365a4000
| PC is at dump_instr+0x68/0x100
| LR is at do_undefinstr+0x1d4/0x2a4
| pc : [<ffffffc00076231c>] lr : [<ffffffc0000811d4>] pstate: 604001c5
| sp : ffffffc3365a6450
Reported-by: Hanjun Guo <guohanjun@huawei.com>
Tested-by: Xuefeng Wang <wxf.wang@hisilicon.com>
Signed-off-by: James Morse <james.morse@arm.com>
commit 08a5bb2921e490939f78f38fd0d02858bb709942 upstream.
hugepd_free() used __get_cpu_var() once. Nothing ensured that the code
accessing the variable did not migrate from one CPU to another and soon
this was noticed by Tiejun Chen in 94b09d755462 ("powerpc/hugetlb:
Replace __get_cpu_var with get_cpu_var"). So we had it fixed.
Christoph Lameter was doing his __get_cpu_var() replaces and forgot
PowerPC. Then he noticed this and sent his fixed up batch again which
got applied as 69111bac42f5 ("powerpc: Replace __get_cpu_var uses").
The careful reader will noticed one little detail: get_cpu_var() got
replaced with this_cpu_ptr(). So now we have a put_cpu_var() which does
a preempt_enable() and nothing that does preempt_disable() so we
underflow the preempt counter.
Cc: Christoph Lameter <cl@linux.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
commit 2ef4dfd9d9f288943e249b78365a69e3ea3ec072 upstream.
Handling exceptions from modules never worked on parisc.
It was just masked by the fact that exceptions from modules
don't happen during normal use.
When a module triggers an exception in get_user() we need to load the
main kernel dp value before accessing the exception_data structure, and
afterwards restore the original dp value of the module on exit.
Noticed-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Helge Deller <deller@gmx.de>
commit ef72f3110d8b19f4c098a0bff7ed7d11945e70c6 upstream.
The kernel module testcase (lib/test_user_copy.c) exhibited a kernel
crash on parisc if the parameters for copy_from_user were reversed
("illegal reversed copy_to_user" testcase).
Fix this potential crash by checking the fault handler if the faulting
address is in the exception table.
commit e3893027a300927049efc1572f852201eb785142 upstream.
We want to avoid the kernel module loader to create function pointers
for the kernel fixup routines of get_user() and put_user(). Changing
the external reference from function type to int type fixes this.
This unbreaks exception handling for get_user() and put_user() when
called from a kernel module.
commit e17dc65328057c00db7e1bfea249c8771a78b30b upstream.
Jiri reported some time ago that some entries in the PEBS data source table
in perf do not agree with the SDM. We investigated and the bits
changed for Sandy Bridge, but the SDM was not updated.
perf already implements the bits correctly for Sandy Bridge
and later. This patch patches it up for Nehalem and Westmere.
Cc: jolsa@kernel.org
Link: http://lkml.kernel.org/r/1456871124-15985-1-git-send-email-andi@firstfloor.org
commit e72daf3f4d764c47fb71c9bdc7f9c54a503825b1 upstream.
Using PAGE_SIZE buffers makes the WRMSR to PERF_GLOBAL_CTRL in
intel_pmu_enable_all() mysteriously hang on Core2. As a workaround, we
don't do this.
The hard lockup is easily triggered by running 'perf test attr'
repeatedly. Most of the time it gets stuck on sample session with
small periods.
# perf test attr -vv
14: struct perf_event_attr setup :
--- start ---
'PERF_TEST_ATTR=/tmp/tmpuEKz3B /usr/bin/perf record -o /tmp/tmpuEKz3B/perf.data -c 123 kill >/dev/null 2>&1' ret 1
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Kan Liang <kan.liang@intel.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/r/20160301190352.GA8355@krava.redhat.com
commit c3d266c8a9838cc141b69548bc3b1b18808ae8c4 upstream.
This patch tries to fix a PEBS warning found in my stress test. The
following perf command can easily trigger the pebs warning or spurious
NMI error on Skylake/Broadwell/Haswell platforms:
sudo perf record -e 'cpu/umask=0x04,event=0xc4/pp,cycles,branches,ref-cycles,cache-misses,cache-references' --call-graph fp -b -c1000 -a
Also the NMI watchdog must be enabled.
For this case, the events number is larger than counter number. So
perf has to do multiplexing.
In perf_mux_hrtimer_handler, it does perf_pmu_disable(), schedule out
old events, rotate_ctx, schedule in new events and finally
perf_pmu_enable().
If the old events include precise event, the MSR_IA32_PEBS_ENABLE
should be cleared when perf_pmu_disable(). The MSR_IA32_PEBS_ENABLE
should keep 0 until the perf_pmu_enable() is called and the new event is
precise event.
However, there is a corner case which could restore PEBS_ENABLE to
stale value during the above period. In perf_pmu_disable(), GLOBAL_CTRL
will be set to 0 to stop overflow and followed PMI. But there may be
pending PMI from an earlier overflow, which cannot be stopped. So even
GLOBAL_CTRL is cleared, the kernel still be possible to get PMI. At
the end of the PMI handler, __intel_pmu_enable_all() will be called,
which will restore the stale values if old events haven't scheduled
out.
Once the stale pebs value is set, it's impossible to be corrected if
the new events are non-precise. Because the pebs_enabled will be set
to 0. x86_pmu.enable_all() will ignore the MSR_IA32_PEBS_ENABLE
setting. As a result, the following NMI with stale PEBS_ENABLE
trigger pebs warning.
The pending PMI after enabled=0 will become harmless if the NMI handler
does not change the state. This patch checks cpuc->enabled in pmi and
only restore the state when PMU is active.
Here is the dump:
Call Trace:
<NMI> [<ffffffff813c3a2e>] dump_stack+0x63/0x85
[<ffffffff810a46f2>] warn_slowpath_common+0x82/0xc0
[<ffffffff810a483a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8100fe2e>] intel_pmu_drain_pebs_nhm+0x2be/0x320
[<ffffffff8100caa9>] intel_pmu_handle_irq+0x279/0x460
[<ffffffff810639b6>] ? native_write_msr_safe+0x6/0x40
[<ffffffff811f290d>] ? vunmap_page_range+0x20d/0x330
[<ffffffff811f2f11>] ? unmap_kernel_range_noflush+0x11/0x20
[<ffffffff8148379f>] ? ghes_copy_tofrom_phys+0x10f/0x2a0
[<ffffffff814839c8>] ? ghes_read_estatus+0x98/0x170
[<ffffffff81005a7d>] perf_event_nmi_handler+0x2d/0x50
[<ffffffff810310b9>] nmi_handle+0x69/0x120
[<ffffffff810316f6>] default_do_nmi+0xe6/0x100
[<ffffffff810317f2>] do_nmi+0xe2/0x130
[<ffffffff817aea71>] end_repeat_nmi+0x1a/0x1e
<<EOE>> <IRQ> [<ffffffff81006df8>] ? x86_perf_event_set_period+0xd8/0x180
[<ffffffff81006eec>] x86_pmu_start+0x4c/0x100
[<ffffffff8100722d>] x86_pmu_enable+0x28d/0x300
[<ffffffff811994d7>] perf_pmu_enable.part.81+0x7/0x10
[<ffffffff8119cb70>] perf_mux_hrtimer_handler+0x200/0x280
[<ffffffff8119c970>] ? __perf_install_in_context+0xc0/0xc0
[<ffffffff8110f92d>] __hrtimer_run_queues+0xfd/0x280
[<ffffffff811100d8>] hrtimer_interrupt+0xa8/0x190
[<ffffffff81199080>] ? __perf_read_group_add.part.61+0x1a0/0x1a0
[<ffffffff81051bd8>] local_apic_timer_interrupt+0x38/0x60
[<ffffffff817af01d>] smp_apic_timer_interrupt+0x3d/0x50
[<ffffffff817ad15c>] apic_timer_interrupt+0x8c/0xa0
<EOI> [<ffffffff81199080>] ? __perf_read_group_add.part.61+0x1a0/0x1a0
[<ffffffff81123de5>] ? smp_call_function_single+0xd5/0x130
[<ffffffff81123ddb>] ? smp_call_function_single+0xcb/0x130
[<ffffffff8119765a>] event_function_call+0x10a/0x120
[<ffffffff8119c660>] ? ctx_resched+0x90/0x90
[<ffffffff811971e0>] ? cpu_clock_event_read+0x30/0x30
[<ffffffff811976d0>] ? _perf_event_disable+0x60/0x60
[<ffffffff8119772b>] _perf_event_enable+0x5b/0x70
[<ffffffff81197388>] perf_event_for_each_child+0x38/0xa0
[<ffffffff811a0ffd>] perf_ioctl+0x12d/0x3c0
[<ffffffff8134d855>] ? selinux_file_ioctl+0x95/0x1e0
[<ffffffff8124a3a1>] do_vfs_ioctl+0xa1/0x5a0
[<ffffffff81036d29>] ? sched_clock+0x9/0x10
[<ffffffff8124a919>] SyS_ioctl+0x79/0x90
[<ffffffff817ac4b2>] entry_SYSCALL_64_fastpath+0x1a/0xa4
---[ end trace aef202839fe9a71d ]---
Uhhuh. NMI received for unknown reason 2d on CPU 2.
Do you have a strange power saving mode enabled?
Signed-off-by: Kan Liang <kan.liang@intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/1457046448-6184-1-git-send-email-kan.liang@intel.com
[ Fixed various typos and other small details. ]
commit 8077eca079a212f26419c57226f28696b7100683 upstream.
This patch fixes an issue with the GLOBAL_OVERFLOW_STATUS bits on
Haswell, Broadwell and Skylake processors when using PEBS.
The SDM stipulates that when the PEBS iterrupt threshold is crossed,
an interrupt is posted and the kernel is interrupted. The kernel will
find GLOBAL_OVF_SATUS bit 62 set indicating there are PEBS records to
drain. But the bits corresponding to the actual counters should NOT be
set. The kernel follows the SDM and assumes that all PEBS events are
processed in the drain_pebs() callback. The kernel then checks for
remaining overflows on any other (non-PEBS) events and processes these
in the for_each_bit_set(&status) loop.
As it turns out, under certain conditions on HSW and later processors,
on PEBS buffer interrupt, bit 62 is set but the counter bits may be
set as well. In that case, the kernel drains PEBS and generates
SAMPLES with the EXACT tag, then it processes the counter bits, and
generates normal (non-EXACT) SAMPLES.
I ran into this problem by trying to understand why on HSW sampling on
a PEBS event was sometimes returning SAMPLES without the EXACT tag.
This should not happen on user level code because HSW has the
eventing_ip which always point to the instruction that caused the
event.
The workaround in this patch simply ensures that the bits for the
counters used for PEBS events are cleared after the PEBS buffer has
been drained. With this fix 100% of the PEBS samples on my user code
report the EXACT tag.
Before:
$ perf record -e cpu/event=0xd0,umask=0x81/upp ./multichase
$ perf report -D | fgrep SAMPLES
PERF_RECORD_SAMPLE(IP, 0x2): 11775/11775: 0x406de5 period: 73469 addr: 0 exact=Y
\--- EXACT tag is missing
After:
PERF_RECORD_SAMPLE(IP, 0x4002): 11775/11775: 0x406de5 period: 73469 addr: 0 exact=Y
\--- EXACT tag is set
The problem tends to appear more often when multiple PEBS events are used.
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: adrian.hunter@intel.com
Cc: kan.liang@intel.com
Cc: namhyung@kernel.org
Link: http://lkml.kernel.org/r/1457034642-21837-3-git-send-email-eranian@google.com
commit b02acd4e62602a6ab307da84388a16bf60106c48 upstream.
If enabling the hsmci regulator on card detection, the board can reboot
on sd card insertion. Keeping the regulator always enabled fixes this
issue.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Fixes: 8d545f32bd77 ("ARM: at91/dt: sama5d4 xplained: add regulators for v(q)mmc1 supplies")
