path: root/arch
2008-02-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: fix deadlock, make pgd_lock irq-safe virtio: fix trivial build bug x86: fix mttr trimming x86: delay CPA self-test and repeat it x86: fix 64-bit sections generic: add __FINITDATA x86: remove suprious ifdefs from pageattr.c x86: mark the .rodata section also NX x86: fix iret exception recovery on 64-bit cpuidle: dubious one-bit signed bitfield in cpuidle.h x86: fix sparse warnings in powernow-k8.c x86: fix sparse error in traps_32.c x86: trivial sparse/checkpatch in quirks.c x86 ptrace: disallow null cs/ss MAINTAINERS: RDC R-321x SoC maintainer brk randomization: introduce CONFIG_COMPAT_BRK brk: check the lower bound properly x86: remove X2 workaround x86: make spurious fault handler aware of large mappings x86: make traps on entry code be debuggable in user space, 64-bit
2008-02-06x86: fix deadlock, make pgd_lock irq-safeIngo Molnar
lockdep just caught this one: ================================= [ INFO: inconsistent lock state ] 2.6.24 #38 --------------------------------- inconsistent {in-softirq-W} -> {softirq-on-W} usage. swapper/1 [HC0[0]:SC0[0]:HE1:SE1] takes: (pgd_lock){-+..}, at: [<ffffffff8022a9ea>] mm_init+0x1da/0x250 {in-softirq-W} state was registered at: [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 394559 hardirqs last enabled at (394559): [<ffffffff80267f0a>] get_page_from_freelist+0x30a/0x4c0 hardirqs last disabled at (394558): [<ffffffff80267d25>] get_page_from_freelist+0x125/0x4c0 softirqs last enabled at (393952): [<ffffffff80232f8e>] __do_softirq+0xce/0xe0 softirqs last disabled at (393945): [<ffffffff8020c57c>] call_softirq+0x1c/0x30 other info that might help us debug this: no locks held by swapper/1. stack backtrace: Pid: 1, comm: swapper Not tainted 2.6.24 #38 Call Trace: [<ffffffff8024e1fb>] print_usage_bug+0x18b/0x190 [<ffffffff8024f55d>] mark_lock+0x53d/0x560 [<ffffffff8024fffa>] __lock_acquire+0x3ca/0xed0 [<ffffffff80250ba8>] lock_acquire+0xa8/0xe0 [<ffffffff8022a9ea>] ? mm_init+0x1da/0x250 [<ffffffff809bcd10>] _spin_lock+0x30/0x70 [<ffffffff8022a9ea>] mm_init+0x1da/0x250 [<ffffffff8022aa99>] mm_alloc+0x39/0x50 [<ffffffff8028b95a>] bprm_mm_init+0x2a/0x1a0 [<ffffffff8028d12b>] do_execve+0x7b/0x220 [<ffffffff80209776>] sys_execve+0x46/0x70 [<ffffffff8020c214>] kernel_execve+0x64/0xd0 [<ffffffff8020901e>] ? _stext+0x1e/0x20 [<ffffffff802090ba>] init_post+0x9a/0xf0 [<ffffffff809bc5f6>] ? trace_hardirqs_on_thunk+0x35/0x3a [<ffffffff8024f75a>] ? trace_hardirqs_on+0xba/0xd0 [<ffffffff8020c1a8>] ? child_rip+0xa/0x12 [<ffffffff8020bcbc>] ? restore_args+0x0/0x44 [<ffffffff8020c19e>] ? child_rip+0x0/0x12 turns out that pgd_lock has been used on 64-bit x86 in an irq-unsafe way for almost two years, since commit 8c914cb704a11460e. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-06x86: fix mttr trimmingYinghai Lu
Pavel Emelyanov reported that his networking card did not work and bisected it down to: " The commit 093af8d7f0ba3c6be1485973508584ef081e9f93 x86_32: trim memory by updating e820 broke my e1000 card: on loading driver says that e1000: probe of 0000:04:03.0 failed with error -5 and the interface doesn't appear. " on a 32-bit kernel, base will overflow when try to do PAGE_SHIFT, and highest_addr will always less 4G. So use pfn instead of address to avoid the overflow when more than 4g RAM is installed on a 32-bit kernel. Many thanks to Pavel Emelyanov for reporting and testing it. Bisected-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Tested-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: delay CPA self-test and repeat itIngo Molnar
delay the CPA self-test so that any impact (corruption) of user-space pagetables can be triggered. Repeat the test every 30 seconds. this would have prevented the bug fixed by 8cb2a7c1e95e472b5, at its source. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: fix 64-bit sectionsSam Ravnborg
fix 64-bit section warnings. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: remove suprious ifdefs from pageattr.cArjan van de Ven
The .rodata section really should just be read only; the config option is there to make breaking up the 2Mb page an option (so people whos machines give more performance for the 2Mb case can opt to do so). But when the page gets split anyway, this is no longer an issue, so clean up the code and remove the ifdefs Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: mark the .rodata section also NXArjan van de Ven
The .rodata section shouldn't just be read-only, but also non-executable. This is free since we've broken up the 2MB page already anyway. also update test_nx to check for this. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: fix iret exception recovery on 64-bitRoland McGrath
This change broke recovery of exceptions in iret: commit 72fe4858544292ad64600765cb78bc02298c6b1c Author: Glauber de Oliveira Costa <gcosta@redhat.com> x86: replace privileged instructions with paravirt macros The ENTRY(native_iret) macro adds alignment padding before the iretq instruction, so "iret_label" no longer points exactly at the instruction. It was sloppy to leave the old "iret_label" label behind when replacing its nearby use. Removing it would have revealed the other use of the label later in the file, and upon noticing that use, anyone exercising the minimum of attention to detail expected of anyone touching this subtle code would realize it needed to change as well. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: fix sparse warnings in powernow-k8.cHarvey Harrison
arch/x86/kernel/cpu/cpufreq/powernow-k8.c:830:7: warning: symbol 'hi' shadows an earlier one arch/x86/kernel/cpu/cpufreq/powernow-k8.c:824:6: originally declared here arch/x86/kernel/cpu/cpufreq/powernow-k8.c:830:15: warning: symbol 'lo' shadows an earlier one arch/x86/kernel/cpu/cpufreq/powernow-k8.c:824:14: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: fix sparse error in traps_32.cHarvey Harrison
This was being used to ensure the proper alignment of the FXSAVE/FXRSTOR data. This would create a sparse error in the _correct_ cases, hiding further warnings. Use BUILD_BUG_ON instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: trivial sparse/checkpatch in quirks.cHarvey Harrison
arch/x86/kernel/quirks.c:384:3: warning: returning void-valued expression arch/x86/kernel/quirks.c:387:3: warning: returning void-valued expression arch/x86/kernel/quirks.c:390:3: warning: returning void-valued expression arch/x86/kernel/quirks.c:393:3: warning: returning void-valued expression Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86 ptrace: disallow null cs/ssRoland McGrath
In my revamp of the x86 ptrace code for setting register values, I accidentally omitted a check that was there in the old code. Allowing %cs to be 0 causes a bad crash in recovery from iret failure. This patch fixes that regression against 2.6.24, and adds a comment that should help prevent this subtlety from being overlooked again. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: remove X2 workaroundIngo Molnar
With the spurious handler fix, the X2 does not lock up anymore. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: make spurious fault handler aware of large mappingsThomas Gleixner
In very rare cases, on certain CPUs, we could end up in the spurious fault handler and ignore a large pud/pmd mapping. The resulting pte pointer points into the mapped physical space and dereferencing it will fault recursively. Make the code aware of large mappings and do the permission check on the pmd/pud entry, when a large pud/pmd mapping is detected. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06x86: make traps on entry code be debuggable in user space, 64-bitRoland McGrath
Unify the x86-64 behavior for 32-bit processes that set bogus %cs/%ss values (the only ones that can fault in iret) match what the native i386 behavior is. (do not kill the task via do_exit but generate a SIGSEGV signal) [ tglx@linutronix.de: build fix ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-06Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: ata_piix.c:piix_init_one() must be __devinit sata_via.c: Remove missleading comment. libata-core: unblacklist HITACHI drives sata_nv: fix ATAPI issues with memory over 4GB (v7) ata: drivers/ata/sata_mv.c needs dmapool.h libata: kill now unused n_iter and fix sata_fsl ahci: fix CAP.NP and PI handling sata_mv: Support SoC controllers Rename: linux/pata_platform.h to linux/ata_platform.h
2008-02-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Temporarily remove IOMMU merging code. [SPARC64]: Update defconfig. [SPARC]: Add new timerfd syscall entries.
2008-02-06atmel_lcdfb: backlight controlDavid Brownell
On the sam9 EK boards, the LCD backlight is hooked up to a PWM output from the LCD controller. It's controlled by "contrast" registers though. This patch lets boards declare that they have that kind of backlight control. The driver can then export this control, letting screenblank and other operations actually take effect ... reducing the typically substantial power drain from the backlight. Note that it's not fully cooked - doesn't force backlight off during system suspend - the "power" and "blank" events may not be done right This should be easily added in the future. [nicolas.ferre@atmel.com: remove unneeded inline and rename functions] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: add HPET RTC emulation to RTC_DRV_CMOSBernhard Walle
That patch adds the RTC emulation of the HPET timer to the new RTC_DRV_CMOS. The old drivers/char/rtc.ko driver had that functionality and it's important on new systems. [akpm@linux-foundation.org: unbreak alpha build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Robert Picco <Robert.Picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06idle_regs() must be __cpuinitAdrian Bunk
Fix the following section mismatch with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x399a6): Section mismatch: reference to .init.text.5:idle_regs (between 'fork_idle' and 'get_task_mm') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06calibrate_delay() must be __cpuinitAdrian Bunk
calibrate_delay() must be __cpuinit, not __{dev,}init. I've verified that this is correct for all users. While doing the latter, I also did the following cleanups: - remove pointless additional prototypes in C files - ensure all users #include <linux/delay.h> This fixes the following section mismatches with CONFIG_HOTPLUG=n, CONFIG_HOTPLUG_CPU=y: WARNING: vmlinux.o(.text+0x1128d): Section mismatch: reference to .init.text.1:calibrate_delay (between 'check_cx686_slop' and 'set_cx86_reorder') WARNING: vmlinux.o(.text+0x25102): Section mismatch: reference to .init.text.1:calibrate_delay (between 'smp_callin' and 'cpu_coregroup_map') Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christian Zankel <chris@zankel.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06get rid of NR_OPEN and introduce a sysctl_nr_openEric Dumazet
NR_OPEN (historically set to 1024*1024) actually forbids processes to open more than 1024*1024 handles. Unfortunatly some production servers hit the not so 'ridiculously high value' of 1024*1024 file descriptors per process. Changing NR_OPEN is not considered safe because of vmalloc space potential exhaust. This patch introduces a new sysctl (/proc/sys/fs/nr_open) wich defaults to 1024*1024, so that admins can decide to change this limit if their workload needs it. [akpm@linux-foundation.org: export it for sparc64] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06alpha/parisc: remove config variable DEBUG_RWLOCKJiri Olsa
Remove config variable DEBUG_RWLOCK, since it is not used. Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06read_current_timer() cleanupsAndrew Morton
- All implementations can be __devinit - The function prototypes were in asm/timex.h but they all must be the same, so create a single declaration in linux/timex.h. - uninline the sparc64 version to match the other architectures - Don't bother #defining ARCH_HAS_READ_CURRENT_TIMER to a particular value. [ezk@cs.sunysb.edu: fix build] Cc: "David S. Miller" <davem@davemloft.net> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06scheduled OSS driver removalAdrian Bunk
This patch contains the scheduled removal of OSS drivers whose config options have been removed in 2.6.23. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06proper show_interrupts() prototypeAdrian Bunk
Add a proper prototype for show_interrupts() in include/linux/interrupt.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06cleanup after APUS removalAdrian Bunk
After the APUS removal, some code can be removed. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Karsten Keil <kkeil@suse.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06remove support for un-needed _extratext sectionRobin Getz
When passing a zero address to kallsyms_lookup(), the kernel thought it was a valid kernel address, even if it is not. This is because is_ksym_addr() called is_kernel_extratext() and checked against labels that don't exist on many archs (which default as zero). Since PPC was the only kernel which defines _extra_text, (in 2005), and no longer needs it, this patch removes _extra_text support. For some history (provided by Jon): http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019734.html http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019736.html http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019751.html [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jon Loeliger <jdl@freescale.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Remove pointless casts from void pointersJeff Garzik
Mostly in and around irq handlers. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Karsten Keil <kkeil@suse.de> Acked-by: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: David Brownell <david-b@pacbell.net> Cc: "Antonino A. Daplas" <adaplas@pol.net> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Holger Schurig <hs4233@mail.mn-solutions.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Remove inclusions of <linux/autoconf.h>Ralf Baechle
Nothing should ever include this file. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: "Mike Frysinger" <vapier.adi@gmail.com> Acked-by: "Bryan Wu" <cooloney.lkml@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06taskstats scaled time cleanupMichael Neuling
This moves the ability to scale cputime into generic code. This allows us to fix the issue in kernel/timer.c (noticed by Balbir) where we could only add an unscaled value to the scaled utime/stime. This adds a cputime_to_scaled function. As before, the POWERPC version does the scaling based on the last SPURR/PURR ratio calculated. The generic and s390 (only other arch to implement asm/cputime.h) versions are both NOPs. Also moves the SPURR and PURR snapshots closer. Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06[SPARC64]: Temporarily remove IOMMU merging code.David S. Miller
Changeset fde6a3c82d67f592eb587be4d12222b0ae6d4321 ("iommu sg merging: sparc64: make iommu respect the segment size limits") broke sparc64 because whilst it added the segment limiting code to the first pass of SG mapping (in prepare_sg()) it did not add matching code to the second pass handling (in fill_sg()) As a result the two passes disagree where the segment boundaries should be, resulting in OOPSes, DMA corruption, and corrupted superblocks. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-06[SPARC64]: Update defconfig.David S. Miller
2008-02-06[SPARC]: Add new timerfd syscall entries.David S. Miller
2008-02-06Rename: linux/pata_platform.h to linux/ata_platform.hJeff Garzik
2008-02-05timerfd: fix remaining architecturesAndrew Morton
Cc: David Howells <dhowells@redhat.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Fix timerfd breakage on avr32Haavard Skinnemoen
Hmm. Someone removed the timerfd() syscall... Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05stop c_p_a corrupting the pdsHugh Dickins
When change_page_attr splits a large page on x86_32 (without PAE), it is currently corrupting every process's page directory: fix that by removing the thinko which passes down a physical instead of a virtual address. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] make pfm_get_task work with virtual pids [IA64] honor notify_die() returning NOTIFY_STOP [IA64] remove dead code: __cpu_{down,die} from !HOTPLUG_CPU [IA64] Appoint kvm/ia64 Maintainers [IA64] ia64_set_psr should use srlz.i [IA64] Export three symbols for module use [IA64] mca style cleanup [IA64] sn_hwperf semaphore to mutex [IA64] generalize attribute of fsyscall_gtod_data [IA64] efi.c Add /* never reached */ annotation [IA64] efi.c Spelling/punctuation fixes [IA64] Make efi.c mostly fit in 80 columns [IA64] aliasing-test: fix gcc warnings on non-ia64 [IA64] Slim-down __clear_bit_unlock [IA64] Fix the order of atomic operations in restore_previous_kprobes on ia64 [IA64] constify function pointer tables [IA64] fix userspace compile error in gcc_intrin.h
2008-02-05Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] dcss: Initialize workqueue before using it. [S390] Remove BUILD_BUG_ON() in vmem code. [S390] sclp_tty/sclp_vt220: Fix scheduling while atomic [S390] dasd: fix panic caused by alias device offline [S390] dasd: add ifcc handling [S390] latencytop s390 support. [S390] Implement ext2_find_next_bit. [S390] Cleanup & optimize bitops. [S390] Define GENERIC_LOCKBREAK. [S390] console: allow vt220 console to be the only console [S390] Fix couple of section mismatches. [S390] Fix smp_call_function_mask semantics. [S390] Fix linker script. [S390] DEBUG_PAGEALLOC support for s390. [S390] cio: Add shutdown callback for ccwgroup. [S390] cio: Update documentation. [S390] cio: Clean up chsc response code handling. [S390] cio: make sense id procedure work with partial hardware response
2008-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64] pci_sun4v.c: Section fixes.
2008-02-05Merge branch 'agp-patches' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6 * 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6: agp: remove flush_agp_mappings calls from new flush handling code intel-agp: introduce IS_I915 and do some cleanups.. [intel_agp] fix name for G35 chipset intel-agp: fixup resource handling in flush code. intel-agp: add new chipset ID agp: remove unnecessary pci_dev_put agp: remove uid comparison as security check fix AGP warning agp/intel: Add chipset flushing support for i8xx chipsets. intel-agp: add chipset flushing support agp: add chipset flushing support to AGP interface
2008-02-05uml: make mconsole_stack namespace-awareJeff Dike
Also fixed the include syntax while I was there. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: redo the calculation of NR_syscallsJeff Dike
Redo the calculation of NR_syscalls since that disappeared from i386 and use a similar mechanism on x86_64. We now figure out the size of the system call table in arch code and stick that in syscall_table_size. arch/um/kernel/skas/syscall.c defines NR_syscalls in terms of that since its the only thing that needs to know how many system calls there are. The old mechananism that was used on x86_64 is gone. arch/um/include/sysdep-i386/syscalls.h got some formatting since I was looking at it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: defconfig tweaksJeff Dike
Tweak the UML defconfig - we probably don't need 256 old-style ptys - this slows down udev noticably enable hostfs disable slab debugging - another noticable performance hit Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: port mutex conversionDaniel Walker
The port_sem is already used as a mutex since it's using DECLARE_MUTEX(), but the underlying construct is still a semaphore .. This patch switches it over to a struct mutex. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: mconsole mutex conversionDaniel Walker
The plug_mem_mutex is already used as a mutex since it's using DECLARE_MUTEX(), but the underlying construct is still a semaphore .. This patch switches it over to a struct mutex. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: LDT mutex conversionDaniel Walker
The ldt.semaphore conforms to the new struct mutex requirments, so I converted it to use the new API and changed the name. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: use of a public MAC is a warning, not an errorJeff Dike
Downgrade one of the MAC validity checks. If it's one that could be possibly assigned to a physical NIC, then nothing will break. So, emit a warning in this case, but keep the requested MAC. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05uml: fix infinite mconsole loopKarol Swietlicki
This patch takes care of a problem with the stopping code. The function inside the while condition returns 0 to signify a problem. A problem could be for example a bad command or a bad version of the mconsole client. A bad command would terminate the stopping loop and resume the kernel. This is a problem. A better solution is to make the loop infinite and don't leave it until we are explicitly told to. Signed-off-by: Karol Swietlicki <magotari@gmail.com> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
