alloc_pages_exact_node() was introduced in commit 6484eb3e2a81 ("page
allocator: do not check NUMA node ID when the caller knows the node is
valid") as an optimized variant of alloc_pages_node(), that doesn't
fallback to current node for nid == NUMA_NO_NODE. Unfortunately the
name of the function can easily suggest that the allocation is
restricted to the given node and fails otherwise. In truth, the node is
only preferred, unless __GFP_THISNODE is passed among the gfp flags.
The misleading name has lead to mistakes in the past, see for example
commits 5265047ac301 ("mm, thp: really limit transparent hugepage
allocation to local node") and b360edb43f8e ("mm, mempolicy:
migrate_to_node should only migrate to node").
Another issue with the name is that there's a family of
alloc_pages_exact*() functions where 'exact' means exact size (instead
of page order), which leads to more confusion.
To prevent further mistakes, this patch effectively renames
alloc_pages_exact_node() to __alloc_pages_node() to better convey that
it's an optimized variant of alloc_pages_node() not intended for general
usage. Both functions get described in comments.
It has been also considered to really provide a convenience function for
allocations restricted to a node, but the major opinion seems to be that
__GFP_THISNODE already provides that functionality and we shouldn't
duplicate the API needlessly. The number of users would be small
anyway.
Existing callers of alloc_pages_exact_node() are simply converted to
call __alloc_pages_node(), with the exception of sba_alloc_coherent()
which open-codes the check for NUMA_NO_NODE, so it is converted to use
alloc_pages_node() instead. This means it no longer performs some
VM_BUG_ON checks, and since the current check for nid in
alloc_pages_node() uses a 'nid < 0' comparison (which includes
NUMA_NO_NODE), it may hide wrong values which would be previously
exposed.
Both differences will be rectified by the next patch.
To sum up, this patch makes no functional changes, except temporarily
hiding potentially buggy callers. Restricting the checks in
alloc_pages_node() is left for the next patch which can in turn expose
more existing buggy callers.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Robin Holt <robinmholt@gmail.com>
Acked-by: Christoph Lameter <cl@linux.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Cliff Whickman <cpw@sgi.com>
The early_ioremap library now has a generic copy_from_early_mem()
function. Use the generic copy function for x86 relocate_initrd().
[akpm@linux-foundation.org: remove MAX_MAP_CHUNK define, per Yinghai Lu]
Signed-off-by: Mark Salter <msalter@redhat.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Yinghai Lu <yinghai@kernel.org>
The use of mem= could leave part or all of the initrd outside of the
kernel linear map. This will lead to an error when unpacking the initrd
and a probable failure to boot. This patch catches that situation and
relocates the initrd to be fully within the linear map.
Acked-by: Will Deacon <will.deacon@arm.com>
When parsing SRAT, all memory ranges are added into numa_meminfo. In
numa_init(), before entering numa_cleanup_meminfo(), all possible memory
ranges are in numa_meminfo. And numa_cleanup_meminfo() removes all
ranges over max_pfn or empty.
But, this only works if the nodes are continuous. Let's have a look at
the following example:
We have an SRAT like this:
SRAT: Node 0 PXM 0 [mem 0x00000000-0x5fffffff]
SRAT: Node 0 PXM 0 [mem 0x100000000-0x1ffffffffff]
SRAT: Node 1 PXM 1 [mem 0x20000000000-0x3ffffffffff]
SRAT: Node 4 PXM 2 [mem 0x40000000000-0x5ffffffffff] hotplug
SRAT: Node 5 PXM 3 [mem 0x60000000000-0x7ffffffffff] hotplug
SRAT: Node 2 PXM 4 [mem 0x80000000000-0x9ffffffffff] hotplug
SRAT: Node 3 PXM 5 [mem 0xa0000000000-0xbffffffffff] hotplug
SRAT: Node 6 PXM 6 [mem 0xc0000000000-0xdffffffffff] hotplug
SRAT: Node 7 PXM 7 [mem 0xe0000000000-0xfffffffffff] hotplug
On boot, only node 0,1,2,3 exist.
And the numa_meminfo will look like this:
numa_meminfo.nr_blks = 9
1. on node 0: [0, 60000000]
2. on node 0: [100000000, 20000000000]
3. on node 1: [20000000000, 40000000000]
4. on node 4: [40000000000, 60000000000]
5. on node 5: [60000000000, 80000000000]
6. on node 2: [80000000000, a0000000000]
7. on node 3: [a0000000000, a0800000000]
8. on node 6: [c0000000000, a0800000000]
9. on node 7: [e0000000000, a0800000000]
And numa_cleanup_meminfo() will merge 1 and 2, and remove 8,9 because the
end address is over max_pfn, which is a0800000000. But 4 and 5 are not
removed because their end addresses are less then max_pfn. But in fact,
node 4 and 5 don't exist.
In a word, numa_cleanup_meminfo() is not able to handle holes between nodes.
Since memory ranges in node 4 and 5 are in numa_meminfo, in
numa_register_memblks(), node 4 and 5 will be mistakenly set to online.
If you run lscpu, it will show:
NUMA node0 CPU(s): 0-14,128-142
NUMA node1 CPU(s): 15-29,143-157
NUMA node2 CPU(s):
NUMA node3 CPU(s):
NUMA node4 CPU(s): 62-76,190-204
NUMA node5 CPU(s): 78-92,206-220
In this patch, we use memblock_overlaps_region() to check if ranges in
numa_meminfo overlap with ranges in memory_block. Since memory_block
contains all available memory at boot time, if they overlap, it means the
ranges exist. If not, then remove them from numa_meminfo.
After this patch, lscpu will show:
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Luiz Capitulino <lcapitulino@redhat.com>
Cc: Xishi Qiu <qiuxishi@huawei.com>
Cc: Vladimir Murzin <vladimir.murzin@arm.com>
Cc: Fabian Frederick <fabf@skynet.be>
Cc: Alexander Kuleshov <kuleshovmail@gmail.com>
Cc: Baoquan He <bhe@redhat.com>
"memcg: export struct mem_cgroup" will add includes into
linux/memcontrol.h which lead to further header dependency issues as
reported by Guenter Roeck:
In file included from include/linux/highmem.h:7:0,
from include/linux/bio.h:23,
from include/linux/writeback.h:192,
from include/linux/memcontrol.h:30,
from include/linux/swap.h:8,
from ./arch/sparc/include/asm/pgtable_32.h:17,
from ./arch/sparc/include/asm/pgtable.h:6,
from arch/sparc/kernel/traps_32.c:23:
include/linux/mm.h: In function 'is_vmalloc_addr':
include/linux/mm.h:371:17: error: 'VMALLOC_START' undeclared (first use in this function)
include/linux/mm.h:371:17: note: each undeclared identifier is reported only once for each function it appears in
include/linux/mm.h:371:41: error: 'VMALLOC_END' undeclared (first use in this function)
include/linux/mm.h: In function 'maybe_mkwrite':
include/linux/mm.h:556:3: error: implicit declaration of function 'pte_mkwrite'
The issue is that pgtable_32.h depends on swap.h to get swap_entry_t but
that goes all the way down to linux/mm.h which wants to have VMALLOC_*
which is defined later in pgtable_32.h, though.
swap_entry_t is defined in include/mm_types.h so it should be sufficient
to include this header without more dependencies.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Reported-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
Pull vfs updates from Al Viro:
"In this one:
- d_move fixes (Eric Biederman)
- UFS fixes (me; locking is mostly sane now, a bunch of bugs in error
handling ought to be fixed)
- switch of sb_writers to percpu rwsem (Oleg Nesterov)
- superblock scalability (Josef Bacik and Dave Chinner)
- swapon(2) race fix (Hugh Dickins)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (65 commits)
vfs: Test for and handle paths that are unreachable from their mnt_root
dcache: Reduce the scope of i_lock in d_splice_alias
dcache: Handle escaped paths in prepend_path
mm: fix potential data race in SyS_swapon
inode: don't softlockup when evicting inodes
inode: rename i_wb_list to i_io_list
sync: serialise per-superblock sync operations
inode: convert inode_sb_list_lock to per-sb
inode: add hlist_fake to avoid the inode hash lock in evict
writeback: plug writeback at a high level
change sb_writers to use percpu_rw_semaphore
shift percpu_counter_destroy() into destroy_super_work()
percpu-rwsem: kill CONFIG_PERCPU_RWSEM
percpu-rwsem: introduce percpu_rwsem_release() and percpu_rwsem_acquire()
percpu-rwsem: introduce percpu_down_read_trylock()
document rwsem_release() in sb_wait_write()
fix the broken lockdep logic in __sb_start_write()
introduce __sb_writers_{acquired,release}() helpers
ufs_inode_get{frag,block}(): get rid of 'phys' argument
ufs_getfrag_block(): tidy up a bit
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- new DVB frontend drivers: ascot2e, cxd2841er, horus3a, lnbh25
- new HDMI capture driver: tc358743
- new driver for NetUP DVB new boards (netup_unidvb)
- IR support for DVBSky cards (smipcie-ir)
- Coda driver has gain macroblock tiling support
- Renesas R-Car gains JPEG codec driver
- new DVB platform driver for STi boards: c8sectpfe
- added documentation for the media core kABI to device-drivers DocBook
- lots of driver fixups, cleanups and improvements
* tag 'media/v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (297 commits)
[media] c8sectpfe: Remove select on undefined LIBELF_32
[media] i2c: fix platform_no_drv_owner.cocci warnings
[media] cx231xx: Use wake_up_interruptible() instead of wake_up_interruptible_nr()
[media] tc358743: only queue subdev notifications if devnode is set
[media] tc358743: add missing Kconfig dependency/select
[media] c8sectpfe: Use %pad to print 'dma_addr_t'
[media] DocBook media: Fix typo "the the" in xml files
[media] tc358743: make reset gpio optional
[media] tc358743: set direction of reset gpio using devm_gpiod_get
[media] dvbdev: document most of the functions/data structs
[media] dvb_frontend.h: document the struct dvb_frontend
[media] dvb-frontend.h: document struct dtv_frontend_properties
[media] dvb-frontend.h: document struct dvb_frontend_ops
[media] dvb: Use DVBFE_ALGO_HW where applicable
[media] dvb_frontend.h: document struct analog_demod_ops
[media] dvb_frontend.h: Document struct dvb_tuner_ops
[media] Docbook: Document struct analog_parameters
[media] dvb_frontend.h: get rid of dvbfe_modcod
[media] add documentation for struct dvb_tuner_info
[media] dvb_frontend: document dvb_frontend_tune_settings
Merge patch-bomb from Andrew Morton:
- a few misc things
- Andy's "ambient capabilities"
- fs/nofity updates
- the ocfs2 queue
- kernel/watchdog.c updates and feature work.
- some of MM. Includes Andrea's userfaultfd feature.
[ Hadn't noticed that userfaultfd was 'default y' when applying the
patches, so that got fixed in this merge instead. We do _not_ mark
new features that nobody uses yet 'default y' - Linus ]
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits)
mm/hugetlb.c: make vma_has_reserves() return bool
mm/madvise.c: make madvise_behaviour_valid() return bool
mm/memory.c: make tlb_next_batch() return bool
mm/dmapool.c: change is_page_busy() return from int to bool
mm: remove struct node_active_region
mremap: simplify the "overlap" check in mremap_to()
mremap: don't do uneccesary checks if new_len == old_len
mremap: don't do mm_populate(new_addr) on failure
mm: move ->mremap() from file_operations to vm_operations_struct
mremap: don't leak new_vma if f_op->mremap() fails
mm/hugetlb.c: make vma_shareable() return bool
mm: make GUP handle pfn mapping unless FOLL_GET is requested
mm: fix status code which move_pages() returns for zero page
mm: memcontrol: bring back the VM_BUG_ON() in mem_cgroup_swapout()
genalloc: add support of multiple gen_pools per device
genalloc: add name arg to gen_pool_get() and devm_gen_pool_create()
mm/memblock: WARN_ON when nid differs from overlap region
Documentation/features/vm: add feature description and arch support status for batched TLB flush after unmap
mm: defer flush of writable TLB entries
mm: send one IPI per CPU to TLB flush all entries after unmapping pages
This change modifies gen_pool_get() and devm_gen_pool_create() client
interfaces adding one more argument "name" of a gen_pool object.
Due to implementation gen_pool_get() is capable to retrieve only one
gen_pool associated with a device even if multiple gen_pools are created,
fortunately right at the moment it is sufficient for the clients, hence
provide NULL as a valid argument on both producer devm_gen_pool_create()
and consumer gen_pool_get() sides.
Because only one created gen_pool per device is addressable, explicitly
add a restriction to devm_gen_pool_create() to create only one gen_pool
per device, this implies two possible error codes returned by the
function, account it on client side (only misc/sram). This completes
client side changes related to genalloc updates.
[akpm@linux-foundation.org: gen_pool_get() cleanup]
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
An IPI is sent to flush remote TLBs when a page is unmapped that was
potentially accesssed by other CPUs. There are many circumstances where
this happens but the obvious one is kswapd reclaiming pages belonging to a
running process as kswapd and the task are likely running on separate
CPUs.
On small machines, this is not a significant problem but as machine gets
larger with more cores and more memory, the cost of these IPIs can be
high. This patch uses a simple structure that tracks CPUs that
potentially have TLB entries for pages being unmapped. When the unmapping
is complete, the full TLB is flushed on the assumption that a refill cost
is lower than flushing individual entries.
Architectures wishing to do this must give the following guarantee.
If a clean page is unmapped and not immediately flushed, the
architecture must guarantee that a write to that linear address
from a CPU with a cached TLB entry will trap a page fault.
This is essentially what the kernel already depends on but the window is
much larger with this patch applied and is worth highlighting. The
architecture should consider whether the cost of the full TLB flush is
higher than sending an IPI to flush each individual entry. An additional
architecture helper called flush_tlb_local is required. It's a trivial
wrapper with some accounting in the x86 case.
The impact of this patch depends on the workload as measuring any benefit
requires both mapped pages co-located on the LRU and memory pressure. The
case with the biggest impact is multiple processes reading mapped pages
taken from the vm-scalability test suite. The test case uses NR_CPU
readers of mapped files that consume 10*RAM.
Linear mapped reader on a 4-node machine with 64G RAM and 48 CPUs
4.2.0-rc1 4.2.0-rc1
vanilla flushfull-v7
Ops lru-file-mmap-read-elapsed 159.62 ( 0.00%) 120.68 ( 24.40%)
Ops lru-file-mmap-read-time_range 30.59 ( 0.00%) 2.80 ( 90.85%)
Ops lru-file-mmap-read-time_stddv 6.70 ( 0.00%) 0.64 ( 90.38%)
4.2.0-rc1 4.2.0-rc1
User 581.00 611.43
System 5804.93 4111.76
Elapsed 161.03 122.12
This is showing that the readers completed 24.40% faster with 29% less
system CPU time. From vmstats, it is known that the vanilla kernel was
interrupted roughly 900K times per second during the steady phase of the
test and the patched kernel was interrupts 180K times per second.
The impact is lower on a single socket machine.
4.2.0-rc1 4.2.0-rc1
Ops lru-file-mmap-read-elapsed 25.33 ( 0.00%) 20.38 ( 19.54%)
Ops lru-file-mmap-read-time_range 0.91 ( 0.00%) 1.44 (-58.24%)
Ops lru-file-mmap-read-time_stddv 0.28 ( 0.00%) 0.47 (-65.34%)
4.2.0-rc1 4.2.0-rc1
User 58.09 57.64
System 111.82 76.56
Elapsed 27.29 22.55
It's still a noticeable improvement with vmstat showing interrupts went
from roughly 500K per second to 45K per second.
The patch will have no impact on workloads with no memory pressure or have
relatively few mapped pages. It will have an unpredictable impact on the
workload running on the CPU being flushed as it'll depend on how many TLB
entries need to be refilled and how long that takes. Worst case, the TLB
will be completely cleared of active entries when the target PFNs were not
resident at all.
[sasha.levin@oracle.com: trace tlb flush after disabling preemption in try_to_unmap_flush]
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Michal Hocko <mhocko@suse.com>
When unmapping pages it is necessary to flush the TLB. If that page was
accessed by another CPU then an IPI is used to flush the remote CPU. That
is a lot of IPIs if kswapd is scanning and unmapping >100K pages per
second.
There already is a window between when a page is unmapped and when it is
TLB flushed. This series increases the window so multiple pages can be
flushed using a single IPI. This should be safe or the kernel is hosed
already.
Patch 1 simply made the rest of the series easier to write as ftrace
could identify all the senders of TLB flush IPIS.
Patch 2 tracks what CPUs potentially map a PFN and then sends an IPI
to flush the entire TLB.
Patch 3 tracks when there potentially are writable TLB entries that
need to be batched differently
Patch 4 increases SWAP_CLUSTER_MAX to further batch flushes
The performance impact is documented in the changelogs but in the optimistic
case on a 4-socket machine the full series reduces interrupts from 900K
interrupts/second to 60K interrupts/second.
This patch (of 4):
It is easy to trace when an IPI is received to flush a TLB but harder to
detect what event sent it. This patch makes it easy to identify the
source of IPIs being transmitted for TLB flushes on x86.
Reviewed-by: Dave Hansen <dave.hansen@intel.com>
This activates the userfaultfd syscall.
[sfr@canb.auug.org.au: activate syscall fix]
[akpm@linux-foundation.org: don't enable userfaultfd on powerpc]
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com>
Cc: zhang.zhanghailiang@huawei.com
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com>
Rename watchdog_suspend() to lockup_detector_suspend() and
watchdog_resume() to lockup_detector_resume() to avoid confusion with the
watchdog subsystem and to be consistent with the existing name
lockup_detector_init().
Also provide comment blocks to explain the watchdog_running and
watchdog_suspended variables and their relationship.
Signed-off-by: Ulrich Obergfell <uobergfe@redhat.com>
Reviewed-by: Aaron Tomlin <atomlin@redhat.com>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Remove watchdog_nmi_disable_all() and watchdog_nmi_enable_all() since
these functions are no longer needed. If a subsystem has a need to
deactivate the watchdog temporarily, it should utilize the
watchdog_suspend() and watchdog_resume() functions.
[akpm@linux-foundation.org: fix build with CONFIG_LOCKUP_DETECTOR=m]
The kernel's NMI watchdog has nothing to do with the watchdog subsystem.
Its header declarations should be in linux/nmi.h, not linux/watchdog.h.
The code provided two sets of dummy functions if HARDLOCKUP_DETECTOR is
not configured, one in the include file and one in kernel/watchdog.c.
Remove the dummy functions from kernel/watchdog.c and use those from the
include file.
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Replace ((x) >> PAGE_SHIFT) with the predefined PFN_DOWN macro.
Signed-off-by: Alexander Kuleshov <kuleshovmail@gmail.com>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Pull drm updates from Dave Airlie:
"This is the main pull request for the drm for 4.3. Nouveau is
probably the biggest amount of changes in here, since it missed 4.2.
Highlights below, along with the usual bunch of fixes.
All stuff outside drm should have applicable acks.
Highlights:
- new drivers:
freescale dcu kms driver
- core:
more atomic fixes
disable some dri1 interfaces on kms drivers
drop fb panic handling, this was just getting more broken, as more locking was required.
new core fbdev Kconfig support - instead of each driver enable/disabling it
struct_mutex cleanups
- panel:
more new panels
cleanup Kconfig
- i915:
Skylake support enabled by default
legacy modesetting using atomic infrastructure
Skylake fixes
GEN9 workarounds
- amdgpu:
Fiji support
CGS support for amdgpu
Initial GPU scheduler - off by default
Lots of bug fixes and optimisations.
- radeon:
DP fixes
misc fixes
- amdkfd:
Add Carrizo support for amdkfd using amdgpu.
- nouveau:
long pending cleanup to complete driver,
fully bisectable which makes it larger,
perfmon work
more reclocking improvements
maxwell displayport fixes
- vmwgfx:
new DX device support, supports OpenGL 3.3
screen targets support
- mgag200:
G200eW support
G200e new revision support
- msm:
dragonboard 410c support, msm8x94 support, msm8x74v1 support
yuv format support
dma plane support
mdp5 rotation
initial hdcp
- sti:
atomic support
- exynos:
lots of cleanups
atomic modesetting/pageflipping support
render node support
- tegra:
tegra210 support (dc, dsi, dp/hdmi)
dpms with atomic modesetting support
- atmel:
support for 3 more atmel SoCs
new input formats, PRIME support.
- dwhdmi:
preparing to add audio support
- rockchip:
yuv plane support"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (1369 commits)
drm/amdgpu: rename gmc_v8_0_init_compute_vmid
drm/amdgpu: fix vce3 instance handling
drm/amdgpu: remove ib test for the second VCE Ring
drm/amdgpu: properly enable VM fault interrupts
drm/amdgpu: fix warning in scheduler
drm/amdgpu: fix buffer placement under memory pressure
drm/amdgpu/cz: fix cz_dpm_update_low_memory_pstate logic
drm/amdgpu: fix typo in dce11 watermark setup
drm/amdgpu: fix typo in dce10 watermark setup
drm/amdgpu: use top down allocation for non-CPU accessible vram
drm/amdgpu: be explicit about cpu vram access for driver BOs (v2)
drm/amdgpu: set MEC doorbell range for Fiji
drm/amdgpu: implement burst NOP for SDMA
drm/amdgpu: add insert_nop ring func and default implementation
drm/amdgpu: add amdgpu_get_sdma_instance helper function
drm/amdgpu: add AMDGPU_MAX_SDMA_INSTANCES
drm/amdgpu: add burst_nop flag for sdma
drm/amdgpu: add count field for the SDMA NOP packet v2
drm/amdgpu: use PT for VM sync on unmap
drm/amdgpu: make wait_event uninterruptible in push_job
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"This is the bulk of pin control changes for the v4.3 development
cycle.
Like with GPIO it's a lot of stuff. If my subsystems are any sign of
the overall tempo of the kernel v4.3 will be a gigantic diff.
[ It looks like 4.3 is calmer than 4.2 in most other subsystems, but
we'll see - Linus ]
Core changes:
- It is possible configure groups in debugfs.
- Consolidation of chained IRQ handler install/remove replacing all
call sites where irq_set_handler_data() and
irq_set_chained_handler() were done in succession with a combined
call to irq_set_chained_handler_and_data(). This series was
created by Thomas Gleixner after the problem was observed by
Russell King.
- Tglx also made another series of patches switching
__irq_set_handler_locked() for irq_set_handler_locked() which is
way cleaner.
- Tglx also wrote a good bunch of patches to make use of
irq_desc_get_xxx() accessors and avoid looking up irq_descs from
IRQ numbers. The goal is to get rid of the irq number from the
handlers in the IRQ flow which is nice.
Driver feature enhancements:
- Power management support for the SiRF SoC Atlas 7.
- Power down support for the Qualcomm driver.
- Intel Cherryview and Baytrail: switch drivers to use raw spinlocks
in IRQ handlers to play nice with the realtime patch set.
- Rework and new modes handling for Qualcomm SPMI-MPP.
- Pinconf power source config for SH PFC.
New drivers and subdrivers:
- A new driver for Conexant Digicolor CX92755.
- A new driver for UniPhier PH1-LD4, PH1-Pro4, PH1-sLD8, PH1-Pro5,
ProXtream2 and PH1-LD6b SoC pin control support.
- Reverse-egineered the S/PDIF settings for the Allwinner sun4i
driver.
- Support for Qualcomm Technologies QDF2xxx ARM64 SoCs
- A new Freescale i.mx6ul subdriver.
Cleanup:
- Remove platform data support in a number of SH PFC subdrivers"
* tag 'pinctrl-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (95 commits)
pinctrl: at91: fix null pointer dereference
pinctrl: mediatek: Implement wake handler and suspend resume
pinctrl: mediatek: Fix multiple registration issue.
pinctrl: sh-pfc: r8a7794: add USB pin groups
pinctrl: at91: Use generic irq_{request,release}_resources()
pinctrl: cherryview: Use raw_spinlock for locking
pinctrl: baytrail: Use raw_spinlock for locking
pinctrl: imx6ul: Remove .owner field
pinctrl: zynq: Fix typos in smc0_nand_grp and smc0_nor_grp
pinctrl: sh-pfc: Implement pinconf power-source param for voltage switching
clk: rockchip: add pclk_pd_pmu to the list of rk3288 critical clocks
pinctrl: sun4i: add spdif to pin description.
pinctrl: atlas7: clear ugly branch statements for pull and drivestrength
pinctrl: baytrail: Serialize all register access
pinctrl: baytrail: Drop FSF mailing address
pinctrl: rockchip: only enable gpio clock when it setting
pinctrl/mediatek: fix spelling mistake in dev_err error message
pinctrl: cherryview: Serialize all register access
pinctrl: UniPhier: PH1-Pro5: add I2C ch6 pin-mux setting
pinctrl: nomadik: reflect current input value
Pull tile updates from Chris Metcalf:
"This includes secure computing support as well as miscellaneous minor
improvements"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
tile: correct some typos in opcode type names
tile/vdso: emit a GNU hash as well
tile: Remove finish_arch_switch
tile: enable full SECCOMP support
tile/time: Migrate to new 'set-state' interface
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
- Support for new architectural features introduced in ARMv8.1:
* Privileged Access Never (PAN) to catch user pointer dereferences in
the kernel
* Large System Extension (LSE) for building scalable atomics and locks
(depends on locking/arch-atomic from tip, which is included here)
* Hardware Dirty Bit Management (DBM) for updating clean PTEs
automatically
- Move our PSCI implementation out into drivers/firmware/, where it can
be shared with arch/arm/. RMK has also pulled this component branch
and has additional patches moving arch/arm/ over. MAINTAINERS is
updated accordingly.
- Better BUG implementation based on the BRK instruction for trapping
- Leaf TLB invalidation for unmapping user pages
- Support for PROBE_ONLY PCI configurations
- Various cleanups and non-critical fixes, including:
* Always flush FP/SIMD state over exec()
* Restrict memblock additions based on range of linear mapping
* Ensure *(LIST_POISON) generates a fatal fault
* Context-tracking syscall return no longer corrupts return value when
not forced on.
* Alternatives patching synchronisation/stability improvements
* Signed sub-word cmpxchg compare fix (tickled by HAVE_CMPXCHG_LOCAL)
* Force SMP=y
* Hide direct DCC access from userspace
* Fix EFI stub memory allocation when DRAM starts at 0x0
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (92 commits)
arm64: flush FP/SIMD state correctly after execve()
arm64: makefile: fix perf_callchain.o kconfig dependency
arm64: set MAX_MEMBLOCK_ADDR according to linear region size
of/fdt: make memblock maximum physical address arch configurable
arm64: Fix source code file path in comments
arm64: entry: always restore x0 from the stack on syscall return
arm64: mdscr_el1: avoid exposing DCC to userspace
arm64: kconfig: Move LIST_POISON to a safe value
arm64: Add __exception_irq_entry definition for function graph
arm64: mm: ensure patched kernel text is fetched from PoU
arm64: alternatives: ensure secondary CPUs execute ISB after patching
arm64: make ll/sc __cmpxchg_case_##name asm consistent
arm64: dma-mapping: Simplify pgprot handling
arm64: restore cpu suspend/resume functionality
ARM64: PCI: do not enable resources on PROBE_ONLY systems
arm64: cmpxchg: truncate sub-word signed types before comparison
arm64: alternative: put secondary CPUs into polling loop during patch
arm64/Documentation: clarify wording regarding memory below the Image
arm64: lse: fix lse cmpxchg code indentation
arm64: remove redundant object file list
Pull MIPS updates from Ralf Baechle:
"This is the main pull request for 4.3 for MIPS. Here's the summary:
Three fixes that didn't make 4.2-stable:
- a -Os build might compile the kernel using the MIPS16 instruction
set but the R2 optimized inline functions in <uapi/asm/swab.h> are
implemented using 32-bit wide instructions which is invalid.
- a build error in pgtable-bits.h for a particular kernel
configuration.
- accessing registers of the CM GCR might have been compiled to use
64 bit accesses but these registers are onl 32 bit wide.
And also a few new bits:
- move the ATH79 GPIO driver to drivers/gpio
- the definition of IRQCHIP_DECLARE has moved to linux/irqchip.h,
change ATH79 accordingly.
- fix definition of pgprot_writecombine
- add an implementation of dma_map_ops.mmap
- fix alignment of quiet build output for vmlinuz link
- BCM47xx: Use kmemdup rather than duplicating its implementation
- Netlogic: Fix 0x0x prefixes of constants.
- merge Bjorn Helgaas' series to remove most of the weak keywords
from function declarations.
- CP0 and CP1 registers are best considered treated as unsigned
values to avoid large values from becoming negative values.
- improve support for the MIPS GIC timer.
- enable common clock framework for Malta and SEAD3.
- a number of improvments and fixes to dump_tlb().
- document the MIPS TLB dump functionality in Magic SysRq.
- Cavium Octeon CN68XX improvments.
- NetLogic improvments.
- irq: Use access helper irq_data_get_affinity_mask.
- handle MSA unaligned accesses.
- a number of R6-related math-emu fixes.
- support for I6400.
- improvments to MSA support.
- add uprobes support.
- move from deprecated __initcall to arch_initcall.
- remove finish_arch_switch().
- IRQ cleanups by Thomas Gleixner.
- migrate to new 'set-state' interface.
- random small cleanups"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (148 commits)
MIPS: UAPI: Fix unrecognized opcode WSBH/DSBH/DSHD when using MIPS16.
MIPS: Fix alignment of quiet build output for vmlinuz link
MIPS: math-emu: Remove unused handle_dsemul function declaration
MIPS: math-emu: Add support for the MIPS R6 MAX{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MIN{, A} FPU instruction
MIPS: math-emu: Add support for the MIPS R6 CLASS FPU instruction
MIPS: math-emu: Add support for the MIPS R6 RINT FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MSUBF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 MADDF FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELNEZ FPU instruction
MIPS: math-emu: Add support for the MIPS R6 SELEQZ FPU instruction
MIPS: math-emu: Add support for the CMP.condn.fmt R6 instruction
MIPS: inst.h: Add new MIPS R6 FPU opcodes
MIPS: Octeon: Fix management port MII address on Kontron S1901
MIPS: BCM47xx: Use kmemdup rather than duplicating its implementation
STAGING: Octeon: Use common helpers for determining interface and port
MIPS: Octeon: Support interfaces 4 and 5
MIPS: Octeon: Set up 1:1 mapping between CN68XX PKO queues and ports
MIPS: Octeon: Initialize CN68XX PKO
STAGING: Octeon: Support CN68XX style WQE
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
- support "hybrid" iommu/direct DMA ops for coherent_mask < dma_mask
from Benjamin Herrenschmidt
- EEH fixes for SRIOV from Gavin
- introduce rtas_get_sensor_fast() for IRQ handlers from Thomas Huth
- use hardware RNG for arch_get_random_seed_* not arch_get_random_*
from Paul Mackerras
- seccomp filter support from Michael Ellerman
- opal_cec_reboot2() handling for HMIs & machine checks from Mahesh
Salgaonkar
- add powerpc timebase as a trace clock source from Naveen N. Rao
- misc cleanups in the xmon, signal & SLB code from Anshuman Khandual
- add an inline function to update POWER8 HID0 from Gautham R. Shenoy
- fix pte_pagesize_index() crash on 4K w/64K hash from Michael Ellerman
- drop support for 64K local store on 4K kernels from Michael Ellerman
- move dma_get_required_mask() from pnv_phb to pci_controller_ops from
Andrew Donnellan
- initialize distance lookup table from drconf path from Nikunj A
Dadhania
- enable RTC class support from Vaibhav Jain
- disable automatically blocked PCI config from Gavin Shan
- add LEDs driver for PowerNV platform from Vasant Hegde
- fix endianness issues in the HVSI driver from Laurent Dufour
- kexec endian fixes from Samuel Mendoza-Jonas
- fix corrupted pdn list from Gavin Shan
- fix fenced PHB caused by eeh_slot_error_detail() from Gavin Shan
- Freescale updates from Scott: Highlights include 32-bit memcpy/memset
optimizations, checksum optimizations, 85xx config fragments and
updates, device tree updates, e6500 fixes for non-SMP, and misc
cleanup and minor fixes.
- a ton of cxl updates & fixes:
- add explicit precision specifiers from Rasmus Villemoes
- use more common format specifier from Rasmus Villemoes
- destroy cxl_adapter_idr on module_exit from Johannes Thumshirn
- destroy afu->contexts_idr on release of an afu from Johannes
Thumshirn
- compile with -Werror from Daniel Axtens
- EEH support from Daniel Axtens
- plug irq_bitmap getting leaked in cxl_context from Vaibhav Jain
- add alternate MMIO error handling from Ian Munsie
- allow release of contexts which have been OPENED but not STARTED
from Andrew Donnellan
- remove use of macro DEFINE_PCI_DEVICE_TABLE from Vaishali Thakkar
- release irqs if memory allocation fails from Vaibhav Jain
- remove racy attempt to force EEH invocation in reset from Daniel
Axtens
- fix + cleanup error paths in cxl_dev_context_init from Ian Munsie
- fix force unmapping mmaps of contexts allocated through the kernel
api from Ian Munsie
- set up and enable PSL Timebase from Philippe Bergheaud
* tag 'powerpc-4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (140 commits)
cxl: Set up and enable PSL Timebase
cxl: Fix force unmapping mmaps of contexts allocated through the kernel api
cxl: Fix + cleanup error paths in cxl_dev_context_init
powerpc/eeh: Fix fenced PHB caused by eeh_slot_error_detail()
powerpc/pseries: Cleanup on pci_dn_reconfig_notifier()
powerpc/pseries: Fix corrupted pdn list
powerpc/powernv: Enable LEDS support
powerpc/iommu: Set default DMA offset in dma_dev_setup
cxl: Remove racy attempt to force EEH invocation in reset
cxl: Release irqs if memory allocation fails
cxl: Remove use of macro DEFINE_PCI_DEVICE_TABLE
powerpc/powernv: Fix mis-merge of OPAL support for LEDS driver
powerpc/powernv: Reset HILE before kexec_sequence()
powerpc/kexec: Reset secondary cpu endianness before kexec
powerpc/hvsi: Fix endianness issues in the HVSI driver
leds/powernv: Add driver for PowerNV platform
powerpc/powernv: Create LED platform device
powerpc/powernv: Add OPAL interfaces for accessing and modifying system LED states
powerpc/powernv: Fix the log message when disabling VF
cxl: Allow release of contexts which have been OPENED but not STARTED
Pull ARM development updates from Russell King:
"Included in this update:
- moving PSCI code from ARM64/ARM to drivers/
- removal of some architecture internals from global kernel view
- addition of software based "privileged no access" support using the
old domains register to turn off the ability for kernel
loads/stores to access userspace. Only the proper accessors will
be usable.
- addition of early fixup support for early console
- re-addition (and reimplementation) of OMAP special interconnect
barrier
- removal of finish_arch_switch()
- only expose cpuX/online in sysfs if hotpluggable
- a number of code cleanups"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (41 commits)
ARM: software-based priviledged-no-access support
ARM: entry: provide uaccess assembly macro hooks
ARM: entry: get rid of multiple macro definitions
ARM: 8421/1: smp: Collapse arch_cpu_idle_dead() into cpu_die()
ARM: uaccess: provide uaccess_save_and_enable() and uaccess_restore()
ARM: mm: improve do_ldrd_abort macro
ARM: entry: ensure that IRQs are enabled when calling syscall_trace_exit()
ARM: entry: efficiency cleanups
ARM: entry: get rid of asm_trace_hardirqs_on_cond
ARM: uaccess: simplify user access assembly
ARM: domains: remove DOMAIN_TABLE
ARM: domains: keep vectors in separate domain
ARM: domains: get rid of manager mode for user domain
ARM: domains: move initial domain setting value to asm/domains.h
ARM: domains: provide domain_mask()
ARM: domains: switch to keeping domain value in register
ARM: 8419/1: dma-mapping: harmonize definition of DMA_ERROR_CODE
ARM: 8417/1: refactor bitops functions with BIT_MASK() and BIT_WORD()
ARM: 8416/1: Feroceon: use of_iomap() to map register base
ARM: 8415/1: early fixmap support for earlycon
Pull locking and atomic updates from Ingo Molnar:
"Main changes in this cycle are:
- Extend atomic primitives with coherent logic op primitives
(atomic_{or,and,xor}()) and deprecate the old partial APIs
(atomic_{set,clear}_mask())
The old ops were incoherent with incompatible signatures across
architectures and with incomplete support. Now every architecture
supports the primitives consistently (by Peter Zijlstra)
- Generic support for 'relaxed atomics':
- _acquire/release/relaxed() flavours of xchg(), cmpxchg() and {add,sub}_return()
- atomic_read_acquire()
- atomic_set_release()
This came out of porting qwrlock code to arm64 (by Will Deacon)
- Clean up the fragile static_key APIs that were causing repeat bugs,
by introducing a new one:
DEFINE_STATIC_KEY_TRUE(name);
DEFINE_STATIC_KEY_FALSE(name);
which define a key of different types with an initial true/false
value.
Then allow:
static_branch_likely()
static_branch_unlikely()
to take a key of either type and emit the right instruction for the
case. To be able to know the 'type' of the static key we encode it
in the jump entry (by Peter Zijlstra)
- Static key self-tests (by Jason Baron)
- qrwlock optimizations (by Waiman Long)
- small futex enhancements (by Davidlohr Bueso)
- ... and misc other changes"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits)
jump_label/x86: Work around asm build bug on older/backported GCCs
locking, ARM, atomics: Define our SMP atomics in terms of _relaxed() operations
locking, include/llist: Use linux/atomic.h instead of asm/cmpxchg.h
locking/qrwlock: Make use of _{acquire|release|relaxed}() atomics
locking/qrwlock: Implement queue_write_unlock() using smp_store_release()
locking/lockref: Remove homebrew cmpxchg64_relaxed() macro definition
locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t'
locking, asm-generic: Rework atomic-long.h to avoid bulk code duplication
locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations
locking, compiler.h: Cast away attributes in the WRITE_ONCE() magic
locking/static_keys: Make verify_keys() static
jump label, locking/static_keys: Update docs
locking/static_keys: Provide a selftest
jump_label: Provide a self-test
s390/uaccess, locking/static_keys: employ static_branch_likely()
x86, tsc, locking/static_keys: Employ static_branch_likely()
locking/static_keys: Add selftest
locking/static_keys: Add a new static_key interface
locking/static_keys: Rework update logic
locking/static_keys: Add static_key_{en,dis}able() helpers
Pull networking updates from David Miller:
"Another merge window, another set of networking changes. I've heard
rumblings that the lightweight tunnels infrastructure has been voted
networking change of the year. But what do I know?
1) Add conntrack support to openvswitch, from Joe Stringer.
2) Initial support for VRF (Virtual Routing and Forwarding), which
allows the segmentation of routing paths without using multiple
devices. There are some semantic kinks to work out still, but
this is a reasonably strong foundation. From David Ahern.
3) Remove spinlock fro act_bpf fast path, from Alexei Starovoitov.
4) Ignore route nexthops with a link down state in ipv6, just like
ipv4. From Andy Gospodarek.
5) Remove spinlock from fast path of act_gact and act_mirred, from
Eric Dumazet.
6) Document the DSA layer, from Florian Fainelli.
7) Add netconsole support to bcmgenet, systemport, and DSA. Also
8) Add Mellanox Switch Driver and core infrastructure, from Jiri
Pirko.
9) Add support for "light weight tunnels", which allow for
encapsulation and decapsulation without bearing the overhead of a
full blown netdevice. From Thomas Graf, Jiri Benc, and a cast of
others.
10) Add Identifier Locator Addressing support for ipv6, from Tom
Herbert.
11) Support fragmented SKBs in iwlwifi, from Johannes Berg.
12) Allow perf PMUs to be accessed from eBPF programs, from Kaixu Xia.
13) Add BQL support to 3c59x driver, from Loganaden Velvindron.
14) Stop using a zero TX queue length to mean that a device shouldn't
have a qdisc attached, use an explicit flag instead. From Phil
Sutter.
15) Use generic geneve netdevice infrastructure in openvswitch, from
Pravin B Shelar.
16) Add infrastructure to avoid re-forwarding a packet in software
that was already forwarded by a hardware switch. From Scott
Feldman.
17) Allow AF_PACKET fanout function to be implemented in a bpf
program, from Willem de Bruijn"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1458 commits)
netfilter: nf_conntrack: make nf_ct_zone_dflt built-in
netfilter: nf_dup{4, 6}: fix build error when nf_conntrack disabled
net: fec: clear receive interrupts before processing a packet
ipv6: fix exthdrs offload registration in out_rt path
xen-netback: add support for multicast control
bgmac: Update fixed_phy_register()
sock, diag: fix panic in sock_diag_put_filterinfo
flow_dissector: Use 'const' where possible.
flow_dissector: Fix function argument ordering dependency
ixgbe: Resolve "initialized field overwritten" warnings
ixgbe: Remove bimodal SR-IOV disabling
ixgbe: Add support for reporting 2.5G link speed
ixgbe: fix bounds checking in ixgbe_setup_tc for 82598
ixgbe: support for ethtool set_rxfh
ixgbe: Avoid needless PHY access on copper phys
ixgbe: cleanup to use cached mask value
ixgbe: Remove second instance of lan_id variable
ixgbe: use kzalloc for allocating one thing
flow: Move __get_hash_from_flowi{4,6} into flow_dissector.c
ixgbe: Remove unused PCI bus types
drivers/perf/arm_pmu.c
for-linus
The nomips16 has to be added both as function attribute and assembler
directive.
When only function attribute is specified, the compiler will inline the
function with -Os optimization. The generated assembly code cannot be
correctly assembled because ISA mode switch has to be done through jump
instruction.
When only ".set nomips16" directive is used, the generated assembly code
will use MIPS32 code for the inline assembly template and MIPS16 for the
function return. The compiled binary is invalid:
00403100 <__arch_swab16>:
403100: 7c0410a0 wsbh v0,a0
403104: e820ea31 swc2 $0,-5583(at)
while correct code should be:
00402650 <__arch_swab16>:
402650: 7c0410a0 wsbh v0,a0
402654: 03e00008 jr ra
402658: 3042ffff andi v0,v0,0xffff
Signed-off-by: Yousong Zhou <yszhou4tech@gmail.com>
Cc: Chen Jie <chenj@lemote.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/11087/
The "LD vmlinuz" line in the quiet build output is misaligned with the
rest of the output. Fix this.
Signed-off-by: Alex Smith <alex.smith@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/11019/
handle_dsemul does not exist and it's not being used in the code at all
so remove its declaration. The deliberate DS emulation exception is
handled by the do_dsemulret C code.
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10950/
MIPS R6 introduced the following instruction:
Scalar Floating-Point Maximum and
Scalar Floating-Point argument with Maximum Absolute Value
MAX.fmt writes the maximum value of the inputs fs and ft to the
destination fd.
MAXA.fmt takes input arguments fs and ft and writes the argument with
the maximum absolute value to the destination fd.
Patchwork: https://patchwork.linux-mips.org/patch/10961/
Scalar Floating-Point Minimum and
Scalar Floating-Point argument with Minimum Absolute Value
MIN.fmt writes the minimum value of the inputs fs and ft to the
destination fd.
MINA.fmt takes input arguments fs and ft and writes the argument with
the minimum absolute value to the destination fd.
Patchwork: https://patchwork.linux-mips.org/patch/10960/
Stores in fd a bit mask reflecting the floating-point class of the
floating point scalar value fs.
CLASS.fmt: FPR[fd] = class(FPR[fs])
Patchwork: https://patchwork.linux-mips.org/patch/10959/
Floating-Point Round to Integral
Scalar floating-point round to integral floating point value.
RINT.fmt: FPR[fd] = round_int(FPR[fs])
Patchwork: https://patchwork.linux-mips.org/patch/10958/
Floating Point Fused Multiply Subtract:
MSUBF.fmt To perform a fused multiply-subtract of FP values.
MSUBF.fmt: FPR[fd] = FPR[fd] - (FPR[fs] x FPR[ft])
Patchwork: https://patchwork.linux-mips.org/patch/10957/
Floating Point Fused Multiply Add:
MADDF.fmt To perform a fused multiply-add of FP values.
MADDF.fmt: FPR[fd] = FPR[fd] + (FPR[fs] x FPR[ft])
Patchwork: https://patchwork.linux-mips.org/patch/10956/
SELNEZ.fmt: FPR[fd] FPR[ft].bit0 ? FPR[fs] : 0
Add support for emulating the single and double precision
formats of the said instruction.
Patchwork: https://patchwork.linux-mips.org/patch/10955/
SELEQZ.fmt: FPR[fd] FPR[ft].bit0 ? 0 : FPR[fs]
Add support for emulating the single and double precision formats
Patchwork: https://patchwork.linux-mips.org/patch/10954/
Add support for emulating the new CMP.condn.fmt R6 instructions and
return SIGILL for the old C.cond.fmt if R2 emulation is not enabled
since it's not supported by R6.
The functionality of the new CMP.condn.fmt is the following one:
If the comparison specified by the condn field of the instruction
is true for the operand values, the result is true; otherwise, the
result is false. If no exception is taken, the result is written into
FPR fd; true is all 1s and false is all 0s repeated the operand width
of fmt. All other bits beyond the operand width fmt are UNPREDICTABLE.
Patchwork: https://patchwork.linux-mips.org/patch/10953/
Add opcodes for the new MIPS R6 FPU instructions.
Patchwork: https://patchwork.linux-mips.org/patch/10952/
Management port MII address is incorrect on Kontron S1901 resulting
in broken networking. Fix by providing definitions for the in-tree DT
pruning code.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Acked-by: David Daney <david.daney@cavium.com>
Patchwork: https://patchwork.linux-mips.org/patch/10914/
The patch was generated using fixed coccinelle semantic patch
scripts/coccinelle/api/memdup.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2014320
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Acked-by: Hauke Mehrtens <hauke@hauke-m.de>
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Andrzej Hajda <a.hajda@samsung.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Patchwork: https://patchwork.linux-mips.org/patch/10898/
Add the support for mapping between interface/port numbers and IPD port
numbers also for the additional interfaces some Octeon II models have.
Signed-off-by: Janne Huttunen <janne.huttunen@nokia.com>
Cc: David Daney <ddaney.cavm@gmail.com>
Cc: Janne Huttunen <janne.huttunen@nokia.com>
Cc: Aaro Koskinen <aaro.koskinen@nokia.com>
Cc: devel@driverdev.osuosl.org
Patchwork: https://patchwork.linux-mips.org/patch/10967/
Use the internal port number also as the queue number on CN68XX.
Patchwork: https://patchwork.linux-mips.org/patch/10962/
CN68XX requires a different PKO configuration. This patch provides
just enough setup to get the XAUI interfaces on CN6880 working with
default parameters.
Signed-off-by: Janne Huttunen <janne.huttunen@nsn.com>
Patchwork: https://patchwork.linux-mips.org/patch/10974/
CN68XX has a bit different WQE structure. This patch provides the new
definitions and converts the code to use the proper variant based on
the actual model.
Patchwork: https://patchwork.linux-mips.org/patch/10973/
Some Octeon II models have SSO instead of POW and use a different register
for setting the interrupt thresholds. Add the necessary definitions for
configuring the interrupts also on those models.
Patchwork: https://patchwork.linux-mips.org/patch/10972/
CN68XX has common minimum packet size filters that need to be configured
for the traffic to work. Just set them to a default value.
Patchwork: https://patchwork.linux-mips.org/patch/10963/
Configure the pkinds of XAUI interfaces on Octeon models that have
them. This simple configuration uses 1:1 mapping between the PIP input
port number and the selected pkind.
Patchwork: https://patchwork.linux-mips.org/patch/10971/
