KVM_CAP_MAX_VCPU_ID is currently always reporting KVM_MAX_VCPU_ID on all
architectures. However, on s390x, the amount of usable CPUs is determined
during runtime - it is depending on the features of the machine the code
is running on. Since we are using the vcpu_id as an index into the SCA
structures that are defined by the hardware (see e.g. the sca_add_vcpu()
function), it is not only the amount of CPUs that is limited by the hard-
ware, but also the range of IDs that we can use.
Thus KVM_CAP_MAX_VCPU_ID must be determined during runtime on s390x, too.
So the handling of KVM_CAP_MAX_VCPU_ID has to be moved from the common
code into the architecture specific code, and on s390x we have to return
the same value here as for KVM_CAP_MAX_VCPUS.
This problem has been discovered with the kvm_create_max_vcpus selftest.
With this change applied, the selftest now passes on s390x, too.
Reviewed-by: Andrew Jones <drjones@redhat.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Signed-off-by: Thomas Huth <thuth@redhat.com>
Message-Id: <20190523164309.13345-9-thuth@redhat.com>
Cc: stable@vger.kernel.org
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Pull KVM fixes from Paolo Bonzini:
"The usual smattering of fixes and tunings that came in too late for
the merge window, but should not wait four months before they appear
in a release.
I also travelled a bit more than usual in the first part of May, which
didn't help with picking up patches and reports promptly"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (33 commits)
KVM: x86: fix return value for reserved EFER
tools/kvm_stat: fix fields filter for child events
KVM: selftests: Wrap vcpu_nested_state_get/set functions with x86 guard
kvm: selftests: aarch64: compile with warnings on
kvm: selftests: aarch64: fix default vm mode
kvm: selftests: aarch64: dirty_log_test: fix unaligned memslot size
KVM: s390: fix memory slot handling for KVM_SET_USER_MEMORY_REGION
KVM: x86/pmu: do not mask the value that is written to fixed PMUs
KVM: x86/pmu: mask the result of rdpmc according to the width of the counters
x86/kvm/pmu: Set AMD's virt PMU version to 1
KVM: x86: do not spam dmesg with VMCS/VMCB dumps
kvm: Check irqchip mode before assign irqfd
kvm: svm/avic: fix off-by-one in checking host APIC ID
KVM: selftests: do not blindly clobber registers in guest asm
KVM: selftests: Remove duplicated TEST_ASSERT in hyperv_cpuid.c
KVM: LAPIC: Expose per-vCPU timer_advance_ns to userspace
KVM: LAPIC: Fix lapic_timer_advance_ns parameter overflow
kvm: vmx: Fix -Wmissing-prototypes warnings
KVM: nVMX: Fix using __this_cpu_read() in preemptible context
kvm: fix compilation on s390
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pule more SPDX updates from Greg KH:
"Here is another set of reviewed patches that adds SPDX tags to
different kernel files, based on a set of rules that are being used to
parse the comments to try to determine that the license of the file is
"GPL-2.0-or-later".
Only the "obvious" versions of these matches are included here, a
number of "non-obvious" variants of text have been found but those
have been postponed for later review and analysis.
These patches have been out for review on the linux-spdx@vger mailing
list, and while they were created by automatic tools, they were
hand-verified by a bunch of different people, all whom names are on
the patches are reviewers"
* tag 'spdx-5.2-rc2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (85 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 125
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 123
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 122
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 121
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 120
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 119
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 118
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 116
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 114
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 113
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 112
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 111
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 110
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 106
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 105
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 104
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 103
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 102
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 101
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 98
Commit 11988499e62b ("KVM: x86: Skip EFER vs. guest CPUID checks for
host-initiated writes", 2019-04-02) introduced a "return false" in a
function returning int, and anyway set_efer has a "nonzero on error"
conventon so it should be returning 1.
Reported-by: Pavel Machek <pavel@denx.de>
Fixes: 11988499e62b ("KVM: x86: Skip EFER vs. guest CPUID checks for host-initiated writes")
Cc: Sean Christopherson <sean.j.christopherson@intel.com>
kselftests exposed a problem in the s390 handling for memory slots.
Right now we only do proper memory slot handling for creation of new
memory slots. Neither MOVE, nor DELETION are handled properly. Let us
implement those.
According to the SDM, for MSR_IA32_PERFCTR0/1 "the lower-order 32 bits of
each MSR may be written with any value, and the high-order 8 bits are
sign-extended according to the value of bit 31", but the fixed counters
in real hardware are limited to the width of the fixed counters ("bits
beyond the width of the fixed-function counter are reserved and must be
written as zeros"). Fix KVM to do the same.
Reported-by: Nadav Amit <nadav.amit@gmail.com>
This patch will simplify the changes in the next, by enforcing the
masking of the counters to RDPMC and RDMSR.
After commit:
672ff6cff80c ("KVM: x86: Raise #GP when guest vCPU do not support PMU")
my AMD guests started #GPing like this:
general protection fault: 0000 [#1] PREEMPT SMP
CPU: 1 PID: 4355 Comm: bash Not tainted 5.1.0-rc6+ #3
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-1 04/01/2014
RIP: 0010:x86_perf_event_update+0x3b/0xa0
with Code: pointing to RDPMC. It is RDPMC because the guest has the
hardware watchdog CONFIG_HARDLOCKUP_DETECTOR_PERF enabled which uses
perf. Instrumenting kvm_pmu_rdpmc() some, showed that it fails due to:
if (!pmu->version)
return 1;
which the above commit added. Since AMD's PMU leaves the version at 0,
that causes the #GP injection into the guest.
Set pmu->version arbitrarily to 1 and move it above the non-applicable
struct kvm_pmu members.
Cc: Janakarajan Natarajan <Janakarajan.Natarajan@amd.com>
Cc: kvm@vger.kernel.org
Cc: Liran Alon <liran.alon@oracle.com>
Cc: Mihai Carabas <mihai.carabas@oracle.com>
Cc: "Radim Krčmář" <rkrcmar@redhat.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: x86@kernel.org
Fixes: 672ff6cff80c ("KVM: x86: Raise #GP when guest vCPU do not support PMU")
Userspace can easily set up invalid processor state in such a way that
dmesg will be filled with VMCS or VMCB dumps. Disable this by default
using a module parameter.
When assigning kvm irqfd we didn't check the irqchip mode but we allow
KVM_IRQFD to succeed with all the irqchip modes. However it does not
make much sense to create irqfd even without the kernel chips. Let's
provide a arch-dependent helper to check whether a specific irqfd is
allowed by the arch. At least for x86, it should make sense to check:
- when irqchip mode is NONE, all irqfds should be disallowed, and,
- when irqchip mode is SPLIT, irqfds that are with resamplefd should
be disallowed.
For either of the case, previously we'll silently ignore the irq or
the irq ack event if the irqchip mode is incorrect. However that can
cause misterious guest behaviors and it can be hard to triage. Let's
fail KVM_IRQFD even earlier to detect these incorrect configurations.
CC: Paolo Bonzini <pbonzini@redhat.com>
CC: Radim Krčmář <rkrcmar@redhat.com>
CC: Alex Williamson <alex.williamson@redhat.com>
CC: Eduardo Habkost <ehabkost@redhat.com>
Signed-off-by: Peter Xu <peterx@redhat.com>
Current logic does not allow VCPU to be loaded onto CPU with
APIC ID 255. This should be allowed since the host physical APIC ID
field in the AVIC Physical APIC table entry is an 8-bit value,
and APIC ID 255 is valid in system with x2APIC enabled.
Instead, do not allow VCPU load if the host APIC ID cannot be
represented by an 8-bit value.
Also, use the more appropriate AVIC_PHYSICAL_ID_ENTRY_HOST_PHYSICAL_ID_MASK
instead of AVIC_MAX_PHYSICAL_ID_COUNT.
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Expose per-vCPU timer_advance_ns to userspace, so it is able to
query the auto-adjusted value.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Wanpeng Li <wanpengli@tencent.com>
After commit c3941d9e0 (KVM: lapic: Allow user to disable adaptive tuning of
timer advancement), '-1' enables adaptive tuning starting from default
advancment of 1000ns. However, we should expose an int instead of an overflow
uint module parameter.
Before patch:
/sys/module/kvm/parameters/lapic_timer_advance_ns:4294967295
After patch:
/sys/module/kvm/parameters/lapic_timer_advance_ns:-1
Fixes: c3941d9e0 (KVM: lapic: Allow user to disable adaptive tuning of timer advancement)
Reviewed-by: Sean Christopherson <sean.j.christopherson@intel.com>
We get a warning when build kernel W=1:
arch/x86/kvm/vmx/vmx.c:6365:6: warning: no previous prototype for ‘vmx_update_host_rsp’ [-Wmissing-prototypes]
void vmx_update_host_rsp(struct vcpu_vmx *vmx, unsigned long host_rsp)
Add the missing declaration to fix this.
Signed-off-by: Yi Wang <wang.yi59@zte.com.cn>
BUG: using __this_cpu_read() in preemptible [00000000] code: qemu-system-x86/4590
caller is nested_vmx_enter_non_root_mode+0xebd/0x1790 [kvm_intel]
CPU: 4 PID: 4590 Comm: qemu-system-x86 Tainted: G OE 5.1.0-rc4+ #1
Call Trace:
dump_stack+0x67/0x95
__this_cpu_preempt_check+0xd2/0xe0
nested_vmx_run+0xda/0x2b0 [kvm_intel]
handle_vmlaunch+0x13/0x20 [kvm_intel]
vmx_handle_exit+0xbd/0x660 [kvm_intel]
kvm_arch_vcpu_ioctl_run+0xa2c/0x1e50 [kvm]
kvm_vcpu_ioctl+0x3ad/0x6d0 [kvm]
do_vfs_ioctl+0xa5/0x6e0
ksys_ioctl+0x6d/0x80
__x64_sys_ioctl+0x1a/0x20
do_syscall_64+0x6f/0x6c0
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Accessing per-cpu variable should disable preemption, this patch extends the
preemption disable region for __this_cpu_read().
Fixes: 52017608da33 ("KVM: nVMX: add option to perform early consistency checks via H/W")
Kvm now supports extended CPUID functions through 0x8000001f. CPUID
leaf 0x8000001e is AMD's Processor Topology Information leaf. This
contains similar information to CPUID leaf 0xb (Intel's Extended
Topology Enumeration leaf), and should be included in the output of
KVM_GET_SUPPORTED_CPUID, even though userspace is likely to override
some of this information based upon the configuration of the
particular VM.
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Borislav Petkov <bp@suse.de>
Fixes: 8765d75329a38 ("KVM: X86: Extend CPUID range to include new leaf")
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Marc Orr <marcorr@google.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Per the APM, "CPUID Fn8000_001D_E[D,C,B,A]X reports cache topology
information for the cache enumerated by the value passed to the
instruction in ECX, referred to as Cache n in the following
description. To gather information for all cache levels, software must
repeatedly execute CPUID with 8000_001Dh in EAX and ECX set to
increasing values beginning with 0 until a value of 00h is returned in
the field CacheType (EAX[4:0]) indicating no more cache descriptions
are available for this processor."
The termination condition is the same as leaf 4, so we can reuse that
code block for leaf 0x8000001d.
VMX's nested_run_pending flag is subtly consumed when stuffing state to
enter guest mode, i.e. needs to be set according before KVM knows if
setting guest state is successful. If setting guest state fails, clear
the flag as a nested run is obviously not pending.
Reported-by: Aaron Lewis <aaronlewis@google.com>
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
The offset for reading the shadow VMCS is sizeof(*kvm_state)+VMCS12_SIZE,
so the correct size must be that plus sizeof(*vmcs12). This could lead
to KVM reading garbage data from userspace and not reporting an error,
but is otherwise not sensitive.
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
KVM/arm updates for 5.2-rc2
- Correctly annotate HYP-callable code to be non-traceable
- Remove Christoffer from the MAINTAINERS file as his request
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull more arm64 fixes from Will Deacon:
- Fix incorrect LDADD instruction encoding in our disassembly macros
- Disable the broken ARM64_PSEUDO_NMI support for now
- Add workaround for Cortex-A76 CPU erratum #1463225
- Handle Cortex-A76/Neoverse-N1 erratum #1418040 w/ existing workaround
- Fix IORT build failure if IOMMU_SUPPORT=n
- Fix place-relative module relocation range checking and its
interaction with KASLR
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: insn: Add BUILD_BUG_ON() for invalid masks
arm64: insn: Fix ldadd instruction encoding
arm64: Kconfig: Make ARM64_PSEUDO_NMI depend on BROKEN for now
arm64: Handle erratum 1418040 as a superset of erratum 1188873
arm64/module: deal with ambiguity in PRELxx relocation ranges
ACPI/IORT: Fix build error when IOMMU_SUPPORT is disabled
arm64/kernel: kaslr: reduce module randomization range to 2 GB
arm64: errata: Add workaround for Cortex-A76 erratum #1463225
arm64: Remove useless message during oops
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details you
should have received a copy of the gnu general public license along
with this program if not see the file copying or write to the free
software foundation inc
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 12 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190523091651.231300438@linutronix.de
the free software foundation either version 2 or at your option any
later version this program is distributed in the hope that it will
be useful but without any warranty without even the implied warranty
of merchantability or fitness for a particular purpose see the gnu
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 44 file(s).
Link: https://lkml.kernel.org/r/20190523091651.032047323@linutronix.de
with this program
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 8 file(s).
Link: https://lkml.kernel.org/r/20190523091650.663497195@linutronix.de
later version
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 4 file(s).
Link: https://lkml.kernel.org/r/20190523091650.480557885@linutronix.de
your option any later version author [hema] [hk] [hemahk]@[ti] [com]
this program is distributed in the hope that it will be useful but
without any warranty without even the implied warranty of
general public license for more details you should have received a
copy of the gnu general public license along with this program if
not write to the free software foundation inc 675 mass ave cambridge
ma 02139 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1 file(s).
Link: https://lkml.kernel.org/r/20190523091649.791555110@linutronix.de
with this program if not write to the free software foundation inc
51 franklin st fifth floor boston ma 02110 1301 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 50 file(s).
Link: https://lkml.kernel.org/r/20190523091649.499889647@linutronix.de
your optional any later version of the license
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3 file(s).
Link: https://lkml.kernel.org/r/20190520075212.713472955@linutronix.de
this file is part of the linux kernel and is made available under
the terms of the gnu general public license version 2 or at your
option any later version incorporated herein by reference
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 18 file(s).
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Link: https://lkml.kernel.org/r/20190520075211.321157221@linutronix.de
this code is released under the gnu general public license version 2
or later
GPL-2.0-or-later
Link: https://lkml.kernel.org/r/20190520075211.232210963@linutronix.de
gdb gas and the gnu binutils are free software you can redistribute
them and or modify them under the terms of the gnu general public
license as published by the free software foundation either version
2 or at your option any later version gdb gas and the gnu binutils
are distributed in the hope that they will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this file see the file copying if not
write to the free software foundation 51 franklin street fifth floor
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 2 file(s).
Link: https://lkml.kernel.org/r/20190520075210.666183009@linutronix.de
you may copy modify and redistribute this file under the terms of
the gnu general public license version 2 or any later version at
your convenience
GPL-2.0-or-later
Link: https://lkml.kernel.org/r/20190520071859.937199252@linutronix.de
with the program if not write to the free software foundation inc
675 mass ave cambridge ma 02139 usa
GPL-2.0-or-later
Link: https://lkml.kernel.org/r/20190520071859.572421635@linutronix.de
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 441 file(s).
Reviewed-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Link: https://lkml.kernel.org/r/20190520071858.739733335@linutronix.de
the free software foundation inc 53 temple place ste 330 boston ma
02111 1307 usa either version 2 of the license or at your option any
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 13 file(s).
Link: https://lkml.kernel.org/r/20190520170858.645641371@linutronix.de
later version you should have received a copy of the gnu general
public license for example usr src linux copying if not write to the
free software foundation inc 675 mass ave cambridge ma 02139 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 20 file(s).
Link: https://lkml.kernel.org/r/20190520170858.552543146@linutronix.de
later version
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 11 file(s).
Link: https://lkml.kernel.org/r/20190520170858.370933192@linutronix.de
this is free software you can redistribute it and or modify it under
the terms of the gnu general public license as published by the free
software foundation either version 2 of the license or at your
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 14 file(s).
Link: https://lkml.kernel.org/r/20190520170857.915677517@linutronix.de
it under the terms of the gnu general public licence as published by
the free software foundation either version 2 of the licence or at
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 114 file(s).
Link: https://lkml.kernel.org/r/20190520170857.552531963@linutronix.de
59 temple place suite 330 boston ma 02111 1307 usa the full gnu
general public license is included in this distribution in the file
called copying
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 7 file(s).
Link: https://lkml.kernel.org/r/20190520170857.277062491@linutronix.de
Detect invalid instruction masks at build time. Some versions of GCC can
warn about the situation, but not all of them, it seems.
Suggested-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
GCC 8.1.0 reports that the ldadd instruction encoding, recently added to
insn.c, doesn't match the mask and couldn't possibly be identified:
linux/arch/arm64/include/asm/insn.h: In function 'aarch64_insn_is_ldadd':
linux/arch/arm64/include/asm/insn.h:280:257: warning: bitwise comparison always evaluates to false [-Wtautological-compare]
Bits [31:30] normally encode the size of the instruction (1 to 8 bytes)
and the current instruction value only encodes the 4- and 8-byte
variants. At the moment only the BPF JIT needs this instruction, and
doesn't require the 1- and 2-byte variants, but to be consistent with
our other ldr and str instruction encodings, clear the size field in the
insn value.
Fixes: 34b8ab091f9ef57a ("bpf, arm64: use more scalable stadd over ldxr / stxr loop in xadd")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Reported-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Although we merged support for pseudo-nmi using interrupt priority
masking in 5.1, we've since uncovered a number of non-trivial issues
with the implementation. Although there are patches pending to address
these problems, we're facing issues that prevent us from merging them at
this current time:
https://lkml.kernel.org/r/1556553607-46531-1-git-send-email-julien.thierry@arm.com
For now, simply mark this optional feature as BROKEN in the hope that we
can fix things properly in the near future.
Cc: <stable@vger.kernel.org> # 5.1
Cc: Julien Thierry <julien.thierry@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
KVM has helpers to handle the condition codes of trapped aarch32
instructions. These are marked __hyp_text and used from HYP, but they
aren't built by the 'hyp' Makefile, which has all the runes to avoid ASAN
and KCOV instrumentation.
Move this code to a new hyp/aarch32.c to avoid a hyp-panic when starting
an aarch32 guest on a host built with the ASAN/KCOV debug options.
Fixes: 021234ef3752f ("KVM: arm64: Make kvm_condition_valid32() accessible from EL2")
Fixes: 8cebe750c4d9a ("arm64: KVM: Make kvm_skip_instr32 available to HYP")
Signed-off-by: James Morse <james.morse@arm.com>
KVM's pmu.c contains the __hyp_text needed to switch the pmu registers
between host and guest. Because this isn't covered by the 'hyp' Makefile,
it can be built with kasan and friends when these are enabled in Kconfig.
When starting a guest, this results in:
| Kernel panic - not syncing: HYP panic:
| PS:a00003c9 PC:000083000028ada0 ESR:86000007
| FAR:000083000028ada0 HPFAR:0000000029df5300 PAR:0000000000000000
| VCPU:000000004e10b7d6
| CPU: 0 PID: 3088 Comm: qemu-system-aar Not tainted 5.2.0-rc1 #11026
| Hardware name: ARM LTD ARM Juno Development Platform/ARM Juno Development Plat
| Call trace:
| dump_backtrace+0x0/0x200
| show_stack+0x20/0x30
| dump_stack+0xec/0x158
| panic+0x1ec/0x420
| panic+0x0/0x420
| SMP: stopping secondary CPUs
| Kernel Offset: disabled
| CPU features: 0x002,25006082
| Memory Limit: none
| ---[ end Kernel panic - not syncing: HYP panic:
This is caused by functions in pmu.c calling the instrumented
code, which isn't mapped to hyp. From objdump -r:
| RELOCATION RECORDS FOR [.hyp.text]:
| OFFSET TYPE VALUE
| 0000000000000010 R_AARCH64_CALL26 __sanitizer_cov_trace_pc
| 0000000000000018 R_AARCH64_CALL26 __asan_load4_noabort
| 0000000000000024 R_AARCH64_CALL26 __asan_load4_noabort
Move the affected code to a new file under 'hyp's Makefile.
Fixes: 3d91befbb3a0 ("arm64: KVM: Enable !VHE support for :G/:H perf event modifiers")
Cc: Andrew Murray <Andrew.Murray@arm.com>
We already mitigate erratum 1188873 affecting Cortex-A76 and
Neoverse-N1 r0p0 to r2p0. It turns out that revisions r0p0 to
r3p1 of the same cores are affected by erratum 1418040, which
has the same workaround as 1188873.
Let's expand the range of affected revisions to match 1418040,
and repaint all occurences of 1188873 to 1418040. Whilst we're
there, do a bit of reformating in silicon-errata.txt and drop
a now unnecessary dependency on ARM_ARCH_TIMER_OOL_WORKAROUND.
The R_AARCH64_PREL16 and R_AARCH64_PREL32 relocations are
documented as permitting a range of [-2^15 .. 2^16), resp.
[-2^31 .. 2^32). It is also documented that this means we
cannot detect overflow in some cases, which is bad.
Since we always interpret the targets of these relocations as
signed quantities (e.g., in the ksymtab handling code), let's
tighten the overflow checks so that targets that are out of
range for our signed interpretation of the relocated quantity
get flagged.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
The following commit
7290d5809571 ("module: use relative references for __ksymtab entries")
updated the ksymtab handling of some KASLR capable architectures
so that ksymtab entries are emitted as pairs of 32-bit relative
references. This reduces the size of the entries, but more
importantly, it gets rid of statically assigned absolute
addresses, which require fixing up at boot time if the kernel
is self relocating (which takes a 24 byte RELA entry for each
member of the ksymtab struct).
Since ksymtab entries are always part of the same module as the
symbol they export, it was assumed at the time that a 32-bit
relative reference is always sufficient to capture the offset
between a ksymtab entry and its target symbol.
Unfortunately, this is not always true: in the case of per-CPU
variables, a per-CPU variable's base address (which usually differs
from the actual address of any of its per-CPU copies) is allocated
in the vicinity of the ..data.percpu section in the core kernel
(i.e., in the per-CPU reserved region which follows the section
containing the core kernel's statically allocated per-CPU variables).
Since we randomize the module space over a 4 GB window covering
the core kernel (based on the -/+ 4 GB range of an ADRP/ADD pair),
we may end up putting the core kernel out of the -/+ 2 GB range of
32-bit relative references of module ksymtab entries that refer to
per-CPU variables.
So reduce the module randomization range a bit further. We lose
1 bit of randomization this way, but this is something we can
tolerate.
Cc: <stable@vger.kernel.org> # v4.19+
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@arm.com>
Revisions of the Cortex-A76 CPU prior to r4p0 are affected by an erratum
that can prevent interrupts from being taken when single-stepping.
This patch implements a software workaround to prevent userspace from
effectively being able to disable interrupts.
Cc: Marc Zyngier <marc.zyngier@arm.com>
During an oops, we print the name of the current task and its pid twice.
We also helpfully advertise its stack limit as "0x(____ptrval____)".
Drop these useless messages.
