[ Upstream commit 4a74197b65e69c46fe6e53f7df2f4d6ce9ffe012 ]
Fix build errors when CURRITUCK=y and I2C is not builtin (=m or is
not set). Fixes these build errors:
powerpc-linux-ld: arch/powerpc/platforms/44x/ppc476.o: in function `avr_halt_system':
ppc476.c:(.text+0x58): undefined reference to `i2c_smbus_write_byte_data'
powerpc-linux-ld: arch/powerpc/platforms/44x/ppc476.o: in function `ppc47x_device_probe':
ppc476.c:(.init.text+0x18): undefined reference to `i2c_register_driver'
Fixes: 2a2c74b2efcb ("IBM Akebono: Add the Akebono platform")
Reported-by: kernel test robot <lkp@intel.com>
Closes: lore.kernel.org/r/202312010820.cmdwF5X9-lkp@intel.com
Link: https://msgid.link/20231201055159.8371-1-rdunlap@infradead.org
[ Upstream commit 1b1e38002648819c04773647d5242990e2824264 ]
crtsavres.o is linked to modules. However, as explained in commit
d0e628cd817f ("kbuild: doc: clarify the difference between extra-y
and always-y"), 'make modules' does not build extra-y.
For example, the following command fails:
$ make ARCH=powerpc LLVM=1 KBUILD_MODPOST_WARN=1 mrproper ps3_defconfig modules
[snip]
LD [M] arch/powerpc/platforms/cell/spufs/spufs.ko
ld.lld: error: cannot open arch/powerpc/lib/crtsavres.o: No such file or directory
make[3]: *** [scripts/Makefile.modfinal:56: arch/powerpc/platforms/cell/spufs/spufs.ko] Error 1
make[2]: *** [Makefile:1844: modules] Error 2
make[1]: *** [/home/masahiro/workspace/linux-kbuild/Makefile:350: __build_one_by_one] Error 2
make: *** [Makefile:234: __sub-make] Error 2
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Fixes: baa25b571a16 ("powerpc/64: Do not link crtsavres.o in vmlinux")
Reviewed-by: Nicholas Piggin <npiggin@gmail.com>
Link: https://msgid.link/20231120232332.4100288-1-masahiroy@kernel.org
[ Upstream commit 54a11654de163994e32b24e3aa90ef81f4a3184d ]
Commit e4412739472b ("Documentation: raise minimum supported version of
binutils to 2.25") allows us to remove the checks for old binutils.
There is no more user for ld-ifversion. Remove it as well.
Link: https://msgid.link/20230119082250.151485-1-masahiroy@kernel.org
Stable-dep-of: 1b1e38002648 ("powerpc: add crtsavres.o to always-y instead of extra-y")
[ Upstream commit a3ad84da076009c94969fa97f604257667e2980f ]
This patch future-proofs the kernel against linker changes that might
put the toc pointer at some location other than .got+0x8000, by
replacing __toc_start+0x8000 with .TOC. throughout. If the kernel's
idea of the toc pointer doesn't agree with the linker, bad things
happen.
prom_init.c code relocating its toc is also changed so that a symbolic
__prom_init_toc_start toc-pointer relative address is calculated
rather than assuming that it is always at toc-pointer - 0x8000. The
length calculations loading values from the toc are also avoided.
It's a little incestuous to do that with unreloc_toc picking up
adjusted values (which is fine in practice, they both adjust by the
same amount if all goes well).
I've also changed the way .got is aligned in vmlinux.lds and
zImage.lds, mostly so that dumping out section info by objdump or
readelf plainly shows the alignment is 256. This linker script
feature was added 2005-09-27, available in FSF binutils releases from
2.17 onwards. Should be safe to use in the kernel, I think.
Finally, put *(.got) before the prom_init.o entry which only needs
*(.toc), so that the GOT header goes in the correct place. I don't
believe this makes any difference for the kernel as it would for
dynamic objects being loaded by ld.so. That change is just to stop
lusers who blindly copy kernel scripts being led astray. Of course,
this change needs the prom_init.c changes.
Some notes on .toc and .got.
.toc is a compiler generated section of addresses. .got is a linker
generated section of addresses, generally built when the linker sees
R_*_*GOT* relocations. In the case of powerpc64 ld.bfd, there are
multiple generated .got sections, one per input object file. So you
can somewhat reasonably write in a linker script an input section
statement like *prom_init.o(.got .toc) to mean "the .got and .toc
section for files matching *prom_init.o". On other architectures that
doesn't make sense, because the linker generally has just one .got
section. Even on powerpc64, note well that the GOT entries for
prom_init.o may be merged with GOT entries from other objects. That
means that if prom_init.o references, say, _end via some GOT
relocation, and some other object also references _end via a GOT
relocation, the GOT entry for _end may be in the range
__prom_init_toc_start to __prom_init_toc_end and if the kernel does
something special to GOT/TOC entries in that range then the value of
_end as seen by objects other than prom_init.o will be affected. On
the other hand the GOT entry for _end may not be in the range
__prom_init_toc_start to __prom_init_toc_end. Which way it turns out
is deterministic but a detail of linker operation that should not be
relied on.
A feature of ld.bfd is that input .toc (and .got) sections matching
one linker input section statement may be sorted, to put entries used
by small-model code first, near the toc base. This is why scripts for
powerpc64 normally use *(.got .toc) rather than *(.got) *(.toc), since
the first form allows more freedom to sort.
Another feature of ld.bfd is that indirect addressing sequences using
the GOT/TOC may be edited by the linker to relative addressing. In
many cases relative addressing would be emitted by gcc for
-mcmodel=medium if you appropriately decorate variable declarations
with non-default visibility.
The original patch is here:
https://lore.kernel.org/linuxppc-dev/20210310034813.GM6042@bubble.grove.modra.org/
Signed-off-by: Alan Modra <amodra@au1.ibm.com>
[aik: removed non-relocatable which is gone in 24d33ac5b8ffb]
[aik: added <=2.24 check]
[aik: because of llvm-as, kernel_toc_addr() uses "mr" instead of global register variable]
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Link: https://lore.kernel.org/r/20211221055904.555763-2-aik@ozlabs.ru
[ Upstream commit 3091f5fc5f1df7741ddf326561384e0997eca2a1 ]
.opd section contains function descriptors used to locate
functions in the kernel. If someone is able to modify a
function descriptor he will be able to run arbitrary
kernel function instead of another.
To avoid that, move .opd section inside read-only memory.
Signed-off-by: Christophe Leroy <christophe.leroy@csgroup.eu>
Link: https://lore.kernel.org/r/3cd40b682fb6f75bb40947b55ca0bac20cb3f995.1634136222.git.christophe.leroy@csgroup.eu
[ Upstream commit a24d61c609813963aacc9f6ec8343f4fcaac7243 ]
tl;dr: The num_digits() function has a theoretical overflow issue.
But it doesn't affect any actual in-tree users. Fix it by using
a larger type for one of the local variables.
Long version:
There is an overflow in variable m in function num_digits when val
is >= 1410065408 which leads to the digit calculation loop to
iterate more times than required. This results in either more
digits being counted or in some cases (for example where val is
1932683193) the value of m eventually overflows to zero and the
while loop spins forever).
Currently the function num_digits is currently only being used for
small values of val in the SMP boot stage for digit counting on the
number of cpus and NUMA nodes, so the overflow is never encountered.
However it is useful to fix the overflow issue in case the function
is used for other purposes in the future. (The issue was discovered
while investigating the digit counting performance in various
kernel helper functions rather than any real-world use-case).
The simplest fix is to make m a long long, the overhead in
multiplication speed for a long long is very minor for small values
of val less than 10000 on modern processors. The alternative
fix is to replace the multiplication with a constant division
by 10 loop (this compiles down to an multiplication and shift)
without needing to make m a long long, but this is slightly slower
than the fix in this commit when measured on a range of x86
processors).
[ dhansen: subject and changelog tweaks ]
Fixes: 646e29a1789a ("x86: Improve the printout of the SMP bootup CPU table")
Signed-off-by: Colin Ian King <colin.i.king@gmail.com>
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Link: https://lore.kernel.org/all/20231102174901.2590325-1-colin.i.king%40gmail.com
[ Upstream commit 643fe70e7bcdcc9e2d96952f7fc2bab56385cce5 ]
of_property_match_string returns an int; either an index from 0 or
greater if successful or negative on failure. Even it's very
unlikely that the DT CPU node contains multiple enable-methods
these checks should be fixed.
This patch was inspired by the work of Nick Desaulniers.
Link: https://lore.kernel.org/lkml/20230516-sunxi-v1-1-ac4b9651a8c1@google.com/T/
Cc: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Stefan Wahren <wahrenst@gmx.net>
Link: https://lore.kernel.org/r/20231228193903.9078-2-wahrenst@gmx.net
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit aca02d933f63ba8bc84258bf35f9ffaf6b664336 ]
Closes: https://lore.kernel.org/oe-kbuild-all/202312082320.VDN5A9hb-lkp@intel.com/
Signed-off-by: Vineet Gupta <vgupta@kernel.org>
[ Upstream commit 4907a3f54b12b8209864572a312cf967befcae80 ]
Device binds to proper PCI ID (LOONGSON, 0x7a03), already listed in DTS,
so checking for some other compatible does not make sense. It cannot be
bound to unsupported platform.
Drop useless, incorrect (space in between) and undocumented compatible.
Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@linaro.org>
Signed-off-by: Yanteng Si <siyanteng@loongson.cn>
Reviewed-by: Conor Dooley <conor.dooley@microchip.com>
Acked-by: Jiaxun Yang <jiaxun.yang@flygoat.com>
kprobe_emulate_call_indirect
commit f5d03da48d062966c94f0199d20be0b3a37a7982 upstream.
kprobe_emulate_call_indirect currently uses int3_emulate_call to emulate
indirect calls. However, int3_emulate_call always assumes the size of
the call to be 5 bytes when calculating the return address. This is
incorrect for register-based indirect calls in x86, which can be either
2 or 3 bytes depending on whether REX prefix is used. At kprobe runtime,
the incorrect return address causes control flow to land onto the wrong
place after return -- possibly not a valid instruction boundary. This
can lead to a panic like the following:
[ 7.308204][ C1] BUG: unable to handle page fault for address: 000000000002b4d8
[ 7.308883][ C1] #PF: supervisor read access in kernel mode
[ 7.309168][ C1] #PF: error_code(0x0000) - not-present page
[ 7.309461][ C1] PGD 0 P4D 0
[ 7.309652][ C1] Oops: 0000 [#1] SMP
[ 7.309929][ C1] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 6.7.0-rc5-trace-for-next #6
[ 7.310397][ C1] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.16.0-20220807_005459-localhost 04/01/2014
[ 7.311068][ C1] RIP: 0010:__common_interrupt+0x52/0xc0
[ 7.311349][ C1] Code: 01 00 4d 85 f6 74 39 49 81 fe 00 f0 ff ff 77 30 4c 89 f7 4d 8b 5e 68 41 ba 91 76 d8 42 45 03 53 fc 74 02 0f 0b cc ff d3 65 48 <8b> 05 30 c7 ff 7e 65 4c 89 3d 28 c7 ff 7e 5b 41 5c 41 5e 41 5f c3
[ 7.312512][ C1] RSP: 0018:ffffc900000e0fd0 EFLAGS: 00010046
[ 7.312899][ C1] RAX: 0000000000000001 RBX: 0000000000000023 RCX: 0000000000000001
[ 7.313334][ C1] RDX: 00000000000003cd RSI: 0000000000000001 RDI: ffff888100d302a4
[ 7.313702][ C1] RBP: 0000000000000001 R08: 0ef439818636191f R09: b1621ff338a3b482
[ 7.314146][ C1] R10: ffffffff81e5127b R11: ffffffff81059810 R12: 0000000000000023
[ 7.314509][ C1] R13: 0000000000000000 R14: ffff888100d30200 R15: 0000000000000000
[ 7.314951][ C1] FS: 0000000000000000(0000) GS:ffff88813bc80000(0000) knlGS:0000000000000000
[ 7.315396][ C1] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 7.315691][ C1] CR2: 000000000002b4d8 CR3: 0000000003028003 CR4: 0000000000370ef0
[ 7.316153][ C1] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 7.316508][ C1] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 7.316948][ C1] Call Trace:
[ 7.317123][ C1] <IRQ>
[ 7.317279][ C1] ? __die_body+0x64/0xb0
[ 7.317482][ C1] ? page_fault_oops+0x248/0x370
[ 7.317712][ C1] ? __wake_up+0x96/0xb0
[ 7.317964][ C1] ? exc_page_fault+0x62/0x130
[ 7.318211][ C1] ? asm_exc_page_fault+0x22/0x30
[ 7.318444][ C1] ? __cfi_native_send_call_func_single_ipi+0x10/0x10
[ 7.318860][ C1] ? default_idle+0xb/0x10
[ 7.319063][ C1] ? __common_interrupt+0x52/0xc0
[ 7.319330][ C1] common_interrupt+0x78/0x90
[ 7.319546][ C1] </IRQ>
[ 7.319679][ C1] <TASK>
[ 7.319854][ C1] asm_common_interrupt+0x22/0x40
[ 7.320082][ C1] RIP: 0010:default_idle+0xb/0x10
[ 7.320309][ C1] Code: 4c 01 c7 4c 29 c2 e9 72 ff ff ff cc cc cc cc 90 90 90 90 90 90 90 90 90 90 90 b8 0c 67 40 a5 66 90 0f 00 2d 09 b9 3b 00 fb f4 <fa> c3 0f 1f 00 90 90 90 90 90 90 90 90 90 90 90 b8 0c 67 40 a5 e9
[ 7.321449][ C1] RSP: 0018:ffffc9000009bee8 EFLAGS: 00000256
[ 7.321808][ C1] RAX: ffff88813bca8b68 RBX: 0000000000000001 RCX: 000000000001ef0c
[ 7.322227][ C1] RDX: 0000000000000000 RSI: 0000000000000001 RDI: 000000000001ef0c
[ 7.322656][ C1] RBP: ffffc9000009bef8 R08: 8000000000000000 R09: 00000000000008c2
[ 7.323083][ C1] R10: 0000000000000000 R11: ffffffff81058e70 R12: 0000000000000000
[ 7.323530][ C1] R13: ffff8881002b30c0 R14: 0000000000000000 R15: 0000000000000000
[ 7.323948][ C1] ? __cfi_lapic_next_deadline+0x10/0x10
[ 7.324239][ C1] default_idle_call+0x31/0x50
[ 7.324464][ C1] do_idle+0xd3/0x240
[ 7.324690][ C1] cpu_startup_entry+0x25/0x30
[ 7.324983][ C1] start_secondary+0xb4/0xc0
[ 7.325217][ C1] secondary_startup_64_no_verify+0x179/0x17b
[ 7.325498][ C1] </TASK>
[ 7.325641][ C1] Modules linked in:
[ 7.325906][ C1] CR2: 000000000002b4d8
[ 7.326104][ C1] ---[ end trace 0000000000000000 ]---
[ 7.326354][ C1] RIP: 0010:__common_interrupt+0x52/0xc0
[ 7.326614][ C1] Code: 01 00 4d 85 f6 74 39 49 81 fe 00 f0 ff ff 77 30 4c 89 f7 4d 8b 5e 68 41 ba 91 76 d8 42 45 03 53 fc 74 02 0f 0b cc ff d3 65 48 <8b> 05 30 c7 ff 7e 65 4c 89 3d 28 c7 ff 7e 5b 41 5c 41 5e 41 5f c3
[ 7.327570][ C1] RSP: 0018:ffffc900000e0fd0 EFLAGS: 00010046
[ 7.327910][ C1] RAX: 0000000000000001 RBX: 0000000000000023 RCX: 0000000000000001
[ 7.328273][ C1] RDX: 00000000000003cd RSI: 0000000000000001 RDI: ffff888100d302a4
[ 7.328632][ C1] RBP: 0000000000000001 R08: 0ef439818636191f R09: b1621ff338a3b482
[ 7.329223][ C1] R10: ffffffff81e5127b R11: ffffffff81059810 R12: 0000000000000023
[ 7.329780][ C1] R13: 0000000000000000 R14: ffff888100d30200 R15: 0000000000000000
[ 7.330193][ C1] FS: 0000000000000000(0000) GS:ffff88813bc80000(0000) knlGS:0000000000000000
[ 7.330632][ C1] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 7.331050][ C1] CR2: 000000000002b4d8 CR3: 0000000003028003 CR4: 0000000000370ef0
[ 7.331454][ C1] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 7.331854][ C1] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[ 7.332236][ C1] Kernel panic - not syncing: Fatal exception in interrupt
[ 7.332730][ C1] Kernel Offset: disabled
[ 7.333044][ C1] ---[ end Kernel panic - not syncing: Fatal exception in interrupt ]---
The relevant assembly code is (from objdump, faulting address
highlighted):
ffffffff8102ed9d: 41 ff d3 call *%r11
ffffffff8102eda0: 65 48 <8b> 05 30 c7 ff mov %gs:0x7effc730(%rip),%rax
The emulation incorrectly sets the return address to be ffffffff8102ed9d
+ 0x5 = ffffffff8102eda2, which is the 8b byte in the middle of the next
mov. This in turn causes incorrect subsequent instruction decoding and
eventually triggers the page fault above.
Instead of invoking int3_emulate_call, perform push and jmp emulation
directly in kprobe_emulate_call_indirect. At this point we can obtain
the instruction size from p->ainsn.size so that we can calculate the
correct return address.
Link: https://lore.kernel.org/all/20240102233345.385475-1-jinghao7@illinois.edu/
Fixes: 6256e668b7af ("x86/kprobes: Use int3 instead of debug trap for single-step")
Cc: stable@vger.kernel.org
Signed-off-by: Jinghao Jia <jinghao7@illinois.edu>
Signed-off-by: Masami Hiramatsu (Google) <mhiramat@kernel.org>
[ Upstream commit 72ad3b772b6d393701df58ba1359b0bb346a19ed ]
Running a multi-arch kernel (multi_v7_defconfig) on a Raspberry Pi 3B+
with enabled CONFIG_UBSAN triggers the following warning:
UBSAN: array-index-out-of-bounds in arch/arm/mach-sunxi/mc_smp.c:810:29
index 2 is out of range for type 'sunxi_mc_smp_data [2]'
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 6.7.0-rc6-00248-g5254c0cbc92d
Hardware name: BCM2835
unwind_backtrace from show_stack+0x10/0x14
show_stack from dump_stack_lvl+0x40/0x4c
dump_stack_lvl from ubsan_epilogue+0x8/0x34
ubsan_epilogue from __ubsan_handle_out_of_bounds+0x78/0x80
__ubsan_handle_out_of_bounds from sunxi_mc_smp_init+0xe4/0x4cc
sunxi_mc_smp_init from do_one_initcall+0xa0/0x2fc
do_one_initcall from kernel_init_freeable+0xf4/0x2f4
kernel_init_freeable from kernel_init+0x18/0x158
kernel_init from ret_from_fork+0x14/0x28
Since the enabled method couldn't match with any entry from
sunxi_mc_smp_data, the value of the index shouldn't be used right after
the loop. So move it after the check of ret in order to have a valid
index.
Fixes: 1631090e34f5 ("ARM: sun9i: smp: Add is_a83t field")
Link: https://lore.kernel.org/r/20231228193903.9078-1-wahrenst@gmx.net
commit 4b7de801606e504e69689df71475d27e35336fb3 upstream.
Lee pointed out issue found by syscaller [0] hitting BUG in prog array
map poke update in prog_array_map_poke_run function due to error value
returned from bpf_arch_text_poke function.
There's race window where bpf_arch_text_poke can fail due to missing
bpf program kallsym symbols, which is accounted for with check for
-EINVAL in that BUG_ON call.
The problem is that in such case we won't update the tail call jump
and cause imbalance for the next tail call update check which will
fail with -EBUSY in bpf_arch_text_poke.
I'm hitting following race during the program load:
CPU 0 CPU 1
bpf_prog_load
bpf_check
do_misc_fixups
prog_array_map_poke_track
map_update_elem
bpf_fd_array_map_update_elem
bpf_arch_text_poke returns -EINVAL
bpf_prog_kallsyms_add
After bpf_arch_text_poke (CPU 1) fails to update the tail call jump, the next
poke update fails on expected jump instruction check in bpf_arch_text_poke
with -EBUSY and triggers the BUG_ON in prog_array_map_poke_run.
Similar race exists on the program unload.
Fixing this by moving the update to bpf_arch_poke_desc_update function which
makes sure we call __bpf_arch_text_poke that skips the bpf address check.
Each architecture has slightly different approach wrt looking up bpf address
in bpf_arch_text_poke, so instead of splitting the function or adding new
'checkip' argument in previous version, it seems best to move the whole
map_poke_run update as arch specific code.
[0] https://syzkaller.appspot.com/bug?extid=97a4fe20470e9bc30810
Fixes: ebf7d1f508a7 ("bpf, x64: rework pro/epilogue and tailcall handling in JIT")
Reported-by: syzbot+97a4fe20470e9bc30810@syzkaller.appspotmail.com
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Yonghong Song <yonghong.song@linux.dev>
Cc: Lee Jones <lee@kernel.org>
Cc: Maciej Fijalkowski <maciej.fijalkowski@intel.com>
Link: https://lore.kernel.org/bpf/20231206083041.1306660-2-jolsa@kernel.org
[ Upstream commit 9b6a51aab5f5f9f71d2fa16e8b4d530e1643dfcb ]
With subtle timings changes, we can now sometimes get an external abort on
non-linefetch error booting am3 devices at sysc_reset(). This is because
of a missing reset delay needed for the usb target module.
Looks like we never enabled the delay earlier for am3, although a similar
issue was seen earlier with a similar usb setup for dm814x as described in
commit ebf244148092 ("ARM: OMAP2+: Use srst_udelay for USB on dm814x").
Fixes: 0782e8572ce4 ("ARM: dts: Probe am335x musb with ti-sysc")
commit 3ea1704a92967834bf0e64ca1205db4680d04048 upstream.
text_poke_early() does:
local_irq_save(flags);
memcpy(addr, opcode, len);
local_irq_restore(flags);
sync_core();
That's not really correct because the synchronization should happen before
interrupts are re-enabled to ensure that a pending interrupt observes the
complete update of the opcodes.
It's not entirely clear whether the interrupt entry provides enough
serialization already, but moving the sync_core() invocation into interrupt
disabled region does no harm and is obviously correct.
Fixes: 6fffacb30349 ("x86/alternatives, jumplabel: Use text_poke_early() before mm_init()")
Signed-off-by: Borislav Petkov (AMD) <bp@alien8.de>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: <stable@kernel.org>
Link: https://lore.kernel.org/r/ZT6narvE%2BLxX%2B7Be@windriver.com
commit 02e3858f08faabab9503ae2911cf7c7e27702257 upstream.
When failing to create a vcpu because (for example) it has a
duplicate vcpu_id, we destroy the vcpu. Amusingly, this leaves
the redistributor registered with the KVM_MMIO bus.
This is no good, and we should properly clean the mess. Force
a teardown of the vgic vcpu interface, including the RD device
before returning to the caller.
Signed-off-by: Marc Zyngier <maz@kernel.org>
Link: https://lore.kernel.org/r/20231207151201.3028710-4-maz@kernel.org
Signed-off-by: Oliver Upton <oliver.upton@linux.dev>
[ Upstream commit e6b2dab41888332bf83f592131e7ea07756770a4 ]
The KERNEL_FPR mask only contains a flag for the first eight vector
registers. However floating point registers overlay parts of the first
sixteen vector registers.
This could lead to vector register corruption if a kernel fpu context uses
any of the vector registers 8 to 15 and is interrupted or calls a
KERNEL_FPR context. If that context uses also vector registers 8 to 15,
their contents will be corrupted on return.
Luckily this is currently not a real bug, since the kernel has only one
KERNEL_FPR user with s390_adjust_jiffies() and it is only using floating
point registers 0 to 2.
Fix this by using the correct bits for KERNEL_FPR.
Fixes: 7f79695cc1b6 ("s390/fpu: improve kernel_fpu_[begin|end]")
Signed-off-by: Heiko Carstens <hca@linux.ibm.com>
Reviewed-by: Hendrik Brueckner <brueckner@linux.ibm.com>
Signed-off-by: Alexander Gordeev <agordeev@linux.ibm.com>
omap_soc_device_init
[ Upstream commit c72b9c33ef9695ad7ce7a6eb39a9df8a01b70796 ]
kasprintf() returns a pointer to dynamically allocated memory which can
be NULL upon failure. When 'soc_dev_attr->family' is NULL,it'll trigger
the null pointer dereference issue, such as in 'soc_info_show'.
And when 'soc_device_register' fails, it's necessary to release
'soc_dev_attr->family' to avoid memory leaks.
Fixes: 6770b2114325 ("ARM: OMAP2+: Export SoC information to userspace")
Signed-off-by: Kunwu Chan <chentao@kylinos.cn>
Message-ID: <20231123145237.609442-1-chentao@kylinos.cn>
[ Upstream commit 1e5caee2ba8f1426e8098afb4ca38dc40a0ca71b ]
This node can access any part of the L3 configuration registers space,
including CLK1 and CLK2 which are 0x800000 offset. Restore this area
size to include these areas.
Fixes: 7f2659ce657e ("ARM: dts: Move dra7 l3 noc to a separate node")
Signed-off-by: Andrew Davis <afd@ti.com>
Message-ID: <20231113181604.546444-1-afd@ti.com>
commit 4b3338aaa74d7d4ec5b6734dc298f0db94ec83d2 upstream.
Commit 41a506ef71eb ("powerpc/ftrace: Create a dummy stackframe to fix
stack unwind") added use of a new stack frame on ftrace entry to fix
stack unwind. However, the commit missed updating the offset used while
tearing down the ftrace stack when ftrace is disabled. Fix the same.
In addition, the commit missed saving the correct stack pointer in
pt_regs. Update the same.
Fixes: 41a506ef71eb ("powerpc/ftrace: Create a dummy stackframe to fix stack unwind")
Cc: stable@vger.kernel.org # v6.5+
Signed-off-by: Naveen N Rao <naveen@kernel.org>
Link: https://msgid.link/20231130065947.2188860-1-naveen@kernel.org
commit 41a506ef71eb38d94fe133f565c87c3e06ccc072 upstream.
With ppc64 -mprofile-kernel and ppc32 -pg, profiling instructions to
call into ftrace are emitted right at function entry. The instruction
sequence used is minimal to reduce overhead. Crucially, a stackframe is
not created for the function being traced. This breaks stack unwinding
since the function being traced does not have a stackframe for itself.
As such, it never shows up in the backtrace:
/sys/kernel/debug/tracing # echo 1 > /proc/sys/kernel/stack_tracer_enabled
/sys/kernel/debug/tracing # cat stack_trace
Depth Size Location (17 entries)
0) 4144 32 ftrace_call+0x4/0x44
1) 4112 432 get_page_from_freelist+0x26c/0x1ad0
2) 3680 496 __alloc_pages+0x290/0x1280
3) 3184 336 __folio_alloc+0x34/0x90
4) 2848 176 vma_alloc_folio+0xd8/0x540
5) 2672 272 __handle_mm_fault+0x700/0x1cc0
6) 2400 208 handle_mm_fault+0xf0/0x3f0
7) 2192 80 ___do_page_fault+0x3e4/0xbe0
8) 2112 160 do_page_fault+0x30/0xc0
9) 1952 256 data_access_common_virt+0x210/0x220
10) 1696 400 0xc00000000f16b100
11) 1296 384 load_elf_binary+0x804/0x1b80
12) 912 208 bprm_execve+0x2d8/0x7e0
13) 704 64 do_execveat_common+0x1d0/0x2f0
14) 640 160 sys_execve+0x54/0x70
15) 480 64 system_call_exception+0x138/0x350
16) 416 416 system_call_common+0x160/0x2c4
Fix this by having ftrace create a dummy stackframe for the function
being traced. With this, backtraces now capture the function being
traced:
0) 3888 32 _raw_spin_trylock+0x8/0x70
1) 3856 576 get_page_from_freelist+0x26c/0x1ad0
2) 3280 64 __alloc_pages+0x290/0x1280
3) 3216 336 __folio_alloc+0x34/0x90
4) 2880 176 vma_alloc_folio+0xd8/0x540
5) 2704 416 __handle_mm_fault+0x700/0x1cc0
6) 2288 96 handle_mm_fault+0xf0/0x3f0
7) 2192 48 ___do_page_fault+0x3e4/0xbe0
8) 2144 192 do_page_fault+0x30/0xc0
9) 1952 608 data_access_common_virt+0x210/0x220
10) 1344 16 0xc0000000334bbb50
11) 1328 416 load_elf_binary+0x804/0x1b80
12) 912 64 bprm_execve+0x2d8/0x7e0
13) 848 176 do_execveat_common+0x1d0/0x2f0
14) 672 192 sys_execve+0x54/0x70
This results in two additional stores in the ftrace entry code, but
produces reliable backtraces.
Fixes: 153086644fd1 ("powerpc/ftrace: Add support for -mprofile-kernel ftrace ABI")
Link: https://msgid.link/20230621051349.759567-1-naveen@kernel.org
commit 3c0696076aad60a2f04c019761921954579e1b0e upstream.
It is currently possible for a userspace application to enter an
infinite page fault loop when using HugeTLB pages implemented with
contiguous PTEs when HAFDBS is not available. This happens because:
1. The kernel may sometimes write PTEs that are sw-dirty but hw-clean
(PTE_DIRTY | PTE_RDONLY | PTE_WRITE).
2. If, during a write, the CPU uses a sw-dirty, hw-clean PTE in handling
the memory access on a system without HAFDBS, we will get a page
fault.
3. HugeTLB will check if it needs to update the dirty bits on the PTE.
For contiguous PTEs, it will check to see if the pgprot bits need
updating. In this case, HugeTLB wants to write a sequence of
sw-dirty, hw-dirty PTEs, but it finds that all the PTEs it is about
to overwrite are all pte_dirty() (pte_sw_dirty() => pte_dirty()),
so it thinks no update is necessary.
We can get the kernel to write a sw-dirty, hw-clean PTE with the
following steps (showing the relevant VMA flags and pgprot bits):
i. Create a valid, writable contiguous PTE.
VMA vmflags: VM_SHARED | VM_READ | VM_WRITE
VMA pgprot bits: PTE_RDONLY | PTE_WRITE
PTE pgprot bits: PTE_DIRTY | PTE_WRITE
ii. mprotect the VMA to PROT_NONE.
PTE pgprot bits: PTE_DIRTY | PTE_RDONLY
iii. mprotect the VMA back to PROT_READ | PROT_WRITE.
PTE pgprot bits: PTE_DIRTY | PTE_WRITE | PTE_RDONLY
Make it impossible to create a writeable sw-dirty, hw-clean PTE with
pte_modify(). Such a PTE should be impossible to create, and there may
be places that assume that pte_dirty() implies pte_hw_dirty().
Signed-off-by: James Houghton <jthoughton@google.com>
Fixes: 031e6e6b4e12 ("arm64: hugetlb: Avoid unnecessary clearing in huge_ptep_set_access_flags")
Cc: <stable@vger.kernel.org>
Acked-by: Will Deacon <will@kernel.org>
Reviewed-by: Ryan Roberts <ryan.roberts@arm.com>
Link: https://lore.kernel.org/r/20231204172646.2541916-3-jthoughton@google.com
[ Upstream commit c7206e7bd214ebb3ca6fa474a4423662327d9beb ]
There are many types of revsered memory passed from firmware
that should be reserved in memblock, and UMA memory passed
from firmware that should be added to system memory for system
to use.
Also for memblock there is no need to align those space into page,
which actually cause problems.
Handle them properly to prevent memory corruption on some systems.
Signed-off-by: Jiaxun Yang <jiaxun.yang@flygoat.com>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
[ Upstream commit 952eea9b01e4bbb7011329f1b7240844e61e5128 ]
We want to specify flags when hotplugging memory. Let's prepare to pass
flags to memblock_add_node() by adjusting all existing users.
Note that when hotplugging memory the system is already up and running
and we might have concurrent memblock users: for example, while we're
hotplugging memory, kexec_file code might search for suitable memory
regions to place kexec images. It's important to add the memory
directly to memblock via a single call with the right flags, instead of
adding the memory first and apply flags later: otherwise, concurrent
memblock users might temporarily stumble over memblocks with wrong
flags, which will be important in a follow-up patch that introduces a
new flag to properly handle add_memory_driver_managed().
Link: https://lkml.kernel.org/r/20211004093605.5830-4-david@redhat.com
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Heiko Carstens <hca@linux.ibm.com>
Signed-off-by: David Hildenbrand <david@redhat.com>
Acked-by: Shahab Vahedi <shahab@synopsys.com> [arch/arc]
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Cc: "Aneesh Kumar K . V" <aneesh.kumar@linux.ibm.com>
Cc: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Huacai Chen <chenhuacai@kernel.org>
Cc: Jianyong Wu <Jianyong.Wu@arm.com>
Cc: Jiaxun Yang <jiaxun.yang@flygoat.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Oscar Salvador <osalvador@suse.de>
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Vasily Gorbik <gor@linux.ibm.com>
Cc: Vineet Gupta <vgupta@kernel.org>
Stable-dep-of: c7206e7bd214 ("MIPS: Loongson64: Handle more memory types passed from firmware")
commit 5d515ee40cb57ea5331998f27df7946a69f14dc3 upstream.
The kernel warning message is triggered, when SPR MCC is used.
[ 17.945331] ------------[ cut here ]------------
[ 17.946305] WARNING: CPU: 65 PID: 1 at
arch/x86/events/intel/uncore_discovery.c:184
intel_uncore_has_discovery_tables+0x4c0/0x65c
[ 17.946305] Modules linked in:
[ 17.946305] CPU: 65 PID: 1 Comm: swapper/0 Not tainted
5.4.17-2136.313.1-X10-2c+ #4
It's caused by the broken discovery table of UPI.
The discovery tables are from hardware. Except for dropping the broken
information, there is nothing Linux can do. Using WARN_ON_ONCE() is
overkilled.
Use the pr_info() to replace WARN_ON_ONCE(), and specify what uncore unit
is dropped and the reason.
Signed-off-by: Kan Liang <kan.liang@linux.intel.com>
Tested-by: Michael Petlan <mpetlan@redhat.com>
Link: https://lore.kernel.org/r/20230112200105.733466-6-kan.liang@linux.intel.com
Cc: Mahmoud Adam <mngyadam@amazon.com>
commit edc0378eee00200a5bedf1bb9f00ad390e0d1bd4 upstream.
There are some Loongson64 systems come with broken coherent DMA
support, firmware will set a bit in boot_param and pass nocoherentio
in cmdline.
However nonconherent support was missed out when spin off Loongson-2EF
form Loongson64, and that boot_param change never made itself into
upstream.
Support DMA noncoherent properly to get those systems working.
Fixes: 71e2f4dd5a65 ("MIPS: Fork loongson2ef from loongson64")
commit 8f7aa77a463f47c9e00592d02747a9fcf2271543 upstream.
vgabios is passed from firmware to kernel on Loongson64 systems.
Sane firmware will keep this pointer in reserved memory space
passed from the firmware but insane firmware keeps it in low
memory before kernel entry that is not reserved.
Previously kernel won't try to allocate memory from low memory
before kernel entry on boot, but after converting to memblock
it will do that.
Fix by resversing those memory on early boot.
Fixes: a94e4f24ec83 ("MIPS: init: Drop boot_mem_map")
commit 4cdf351d3630a640ab6a05721ef055b9df62277f upstream.
In general, activating long mode involves setting the EFER_LME bit in
the EFER register and then enabling the X86_CR0_PG bit in the CR0
register. At this point, the EFER_LMA bit will be set automatically by
hardware.
In the case of SVM/SEV guests where writes to CR0 are intercepted, it's
necessary for the host to set EFER_LMA on behalf of the guest since
hardware does not see the actual CR0 write.
In the case of SEV-ES guests where writes to CR0 are trapped instead of
intercepted, the hardware *does* see/record the write to CR0 before
exiting and passing the value on to the host, so as part of enabling
SEV-ES support commit f1c6366e3043 ("KVM: SVM: Add required changes to
support intercepts under SEV-ES") dropped special handling of the
EFER_LMA bit with the understanding that it would be set automatically.
However, since the guest never explicitly sets the EFER_LMA bit, the
host never becomes aware that it has been set. This becomes problematic
when userspace tries to get/set the EFER values via
KVM_GET_SREGS/KVM_SET_SREGS, since the EFER contents tracked by the host
will be missing the EFER_LMA bit, and when userspace attempts to pass
the EFER value back via KVM_SET_SREGS it will fail a sanity check that
asserts that EFER_LMA should always be set when X86_CR0_PG and EFER_LME
are set.
Fix this by always inferring the value of EFER_LMA based on X86_CR0_PG
and EFER_LME, regardless of whether or not SEV-ES is enabled.
Fixes: f1c6366e3043 ("KVM: SVM: Add required changes to support intercepts under SEV-ES")
Reported-by: Peter Gonda <pgonda@google.com>
Signed-off-by: Sean Christopherson <seanjc@google.com>
Message-Id: <20210507165947.2502412-2-seanjc@google.com>
[A two year old patch that was revived after we noticed the failure in
KVM_SET_SREGS and a similar patch was posted by Michael Roth. This is
Sean's patch, but with Michael's more complete commit message. - Paolo]
commit 27072b8e18a73ffeffb1c140939023915a35134b upstream.
When the CMMA state needs to be reset, the no-dat bit also needs to be
reset. Failure to do so could cause issues in the guest, since the
guest expects the bit to be cleared after a reset.
Reviewed-by: Nico Boehr <nrb@linux.ibm.com>
Message-ID: <20231109123624.37314-1-imbrenda@linux.ibm.com>
Signed-off-by: Claudio Imbrenda <imbrenda@linux.ibm.com>
commit 9b8493dc43044376716d789d07699f17d538a7c4 upstream.
Commit in Fixes added an AMD-specific microcode callback. However, it
didn't check the CPU vendor the kernel runs on explicitly.
The only reason the Zenbleed check in it didn't run on other x86 vendors
hardware was pure coincidental luck:
if (!cpu_has_amd_erratum(c, amd_zenbleed))
return;
gives true on other vendors because they don't have those families and
models.
However, with the removal of the cpu_has_amd_erratum() in
05f5f73936fa ("x86/CPU/AMD: Drop now unused CPU erratum checking function")
that coincidental condition is gone, leading to the zenbleed check
getting executed on other vendors too.
Add the explicit vendor check for the whole callback as it should've
been done in the first place.
Fixes: 522b1d69219d ("x86/cpu/amd: Add a Zenbleed fix")
Link: https://lore.kernel.org/r/20231201184226.16749-1-bp@alien8.de
[ Upstream commit 8980c30141d3986beab815d85762b9c67196ed72 ]
Replace underscores with hyphens in pinctrl node names both for consistency
and to adhere to the bindings.
Fixes: cd894e274b74 ("arm64: dts: mt8183: Add krane-sku176 board")
Fixes: 1652dbf7363a ("arm64: dts: mt8183: add scp node")
Fixes: 27eaf34df364 ("arm64: dts: mt8183: config dsi node")
Signed-off-by: Hsin-Yi Wang <hsinyi@chromium.org>
Reviewed-by: AngeloGioacchino Del Regno <angelogioacchino.delregno@collabora.com>
Link: https://lore.kernel.org/r/20231026191343.3345279-2-hsinyi@chromium.org
Signed-off-by: AngeloGioacchino Del Regno <angelogioacchino.delregno@collabora.com>
[ Upstream commit a9c740c57f977deb41bc53c02d0dae3d0e2f191a ]
Add missing whitespace between node name/label and opening {.
Link: https://lore.kernel.org/r/20230705150006.293690-2-krzysztof.kozlowski@linaro.org
Stable-dep-of: 8980c30141d3 ("arm64: dts: mt8183: kukui: Fix underscores in node names")
[ Upstream commit 5a60d63439694590cd5ab1f998fc917ff7ba1c1d ]
The thermal zones are not a soc bus device: move it to the root
node to solve simple_bus_reg warnings.
Fixes: b325ce39785b ("arm64: dts: mt8183: add thermal zone node")
Link: https://lore.kernel.org/r/20231025093816.44327-9-angelogioacchino.delregno@collabora.com
[ Upstream commit 624f1806a7c3f8061641a1f3e7c0dfa73e82fb10 ]
Align the name of thermal zone node to dtschema to fix warnings like:
arch/arm64/boot/dts/mediatek/mt8173-elm.dt.yaml:
thermal-zones: 'cpu_thermal' does not match any of the regexes: '^[a-zA-Z][a-zA-Z0-9\\-]{1,12}-thermal$', 'pinctrl-[0-9]+'
Link: https://lore.kernel.org/r/20210820081616.83674-2-krzysztof.kozlowski@canonical.com
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
Stable-dep-of: 5a60d6343969 ("arm64: dts: mediatek: mt8183: Move thermal-zones to the root node")
commit 19cba9a6c071db57888dc6b2ec1d9bf8996ea681 upstream.
The reserved memory for scp had node name "scp_mem_region" and also
without unit-address: change the name to "memory@(address)".
This fixes a unit_address_vs_reg warning.
Link: https://lore.kernel.org/r/20231025093816.44327-6-angelogioacchino.delregno@collabora.com
commit 24165c5dad7ba7c7624d05575a5e0cc851396c71 upstream.
Fix a unit_address_vs_reg warning for the USB VBUS fixed regulators
by renaming the regulator nodes from regulator@{0,1} to regulator-usb-p0
and regulator-usb-p1.
Fixes: c0891284a74a ("arm64: dts: mediatek: add USB3 DRD driver")
Link: https://lore.kernel.org/r/20231025093816.44327-8-angelogioacchino.delregno@collabora.com
commit 74543b303a9abfe4fa253d1fa215281baa05ff3a upstream.
dtbs_check throws a warning at the dsi node:
Warning (avoid_unnecessary_addr_size): /soc/dsi@14014000: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property
Other DTS have a panel child node with a reg, so the parent dtsi
must have the address-cells and size-cells, however this specific DT
has the panel removed, but not the cells, hence the warning above.
If panel is deleted then the cells must also be deleted since they are
tied together, as the child node in this DT does not have a reg.
Fixes: cabc71b08eb5 ("arm64: dts: mt8183: Add kukui-jacuzzi-damu board")
Signed-off-by: Eugen Hristev <eugen.hristev@collabora.com>
Link: https://lore.kernel.org/r/20230814071053.5459-1-eugen.hristev@collabora.com
commit 8e6ecbfd44b5542a7598c1c5fc9c6dcb5d367f2a upstream.
dtbs_check throws a warning at the memory node:
Warning (unit_address_vs_reg): /memory: node has a reg or ranges property, but no unit name
fix by adding the address into the node name.
Fixes: 0b6286dd96c0 ("arm64: dts: mt7622: add bananapi BPI-R64 board")
Link: https://lore.kernel.org/r/20230814065042.4973-1-eugen.hristev@collabora.com
[ Upstream commit 22e0eb04837a63af111fae35a92f7577676b9bc8 ]
This is a backport of a fix that was done in OpenSBI: ec0559eb315b
("lib: sbi_misaligned_ldst: Fix handling of C.SWSP and C.SDSP").
Unlike C.LWSP/C.LDSP, these encodings can be used with the zero
register, so checking that the rs2 field is non-zero is unnecessary.
Additionally, the previous check was incorrect since it was checking
the immediate field of the instruction instead of the rs2 field.
Fixes: 956d705dd279 ("riscv: Unaligned load/store handling for M_MODE")
Signed-off-by: Clément Léger <cleger@rivosinc.com>
Link: https://lore.kernel.org/r/20231103090223.702340-1-cleger@rivosinc.com
Signed-off-by: Palmer Dabbelt <palmer@rivosinc.com>
[ Upstream commit 63ef8fc9bcee6b73ca445a19a7ac6bd544723c9f ]
Per root-node.yaml, 'model' is a required property.
Pass it to fix the following dt-schema warning:
imx28-xea.dtb: /: 'model' is a required property
from schema $id: http://devicetree.org/schemas/root-node.yaml#
Signed-off-by: Fabio Estevam <festevam@denx.de>
Fixes: 445ae16ac1c5 ("ARM: dts: imx28: Add DTS description of imx28 based XEA board")
[ Upstream commit 397caf68e2d36532054cb14ae8995537f27f8b61 ]
The timer nodes declare compatibility with "fsl,imx6sx-gpt", which
itself is compatible with "fsl,imx6dl-gpt". Switch the fallback
compatible from "fsl,imx6sx-gpt" to "fsl,imx6dl-gpt".
Fixes: 949673450291 ("ARM: dts: add imx7d soc dtsi file")
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Roland Hieber <rhi@pengutronix.de>
[ Upstream commit 1c2b1049af3f86545fcc5fae0fc725fb64b3a09e ]
devm_kasprintf() returns a pointer to dynamically allocated memory
which can be NULL upon failure. Ensure the allocation was successful
by checking the pointer validity.
Release the id allocated in 'mmdc_pmu_init' when 'devm_kasprintf'
return NULL
Suggested-by: Ahmad Fatoum <a.fatoum@pengutronix.de>
Fixes: e76bdfd7403a ("ARM: imx: Added perf functionality to mmdc driver")
[ Upstream commit d951f8f5f23a9417b7952f22b33784c73caa1ebb ]
Since commit c7e73b5051d6 ("ARM: imx: mach-imx6ul: remove 14x14 EVK
specific PHY fixup")thet Ethernet PHY is no longer configured via code
in board file.
This caused Ethernet to stop working.
Fix this problem by describing the clocks and clock-names to the
Ethernet PHY node so that the KSZ8081 chip can be clocked correctly.
Fixes: c7e73b5051d6 ("ARM: imx: mach-imx6ul: remove 14x14 EVK specific PHY fixup")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit 209043cf092d7b0d4739921b3f11d6d0b451eabf ]
The i.MX8MP and i.MX8MQ devices both use the same DWC3 controller and
are both affected by a known issue with the controller due to specific
behaviour when park mode is enabled in SuperSpeed host mode operation.
Under heavy USB traffic from multiple endpoints the controller will
sometimes incorrectly process transactions such that some transactions
are lost, or the controller may hang when processing transactions. When
the controller hangs it does not recover.
This issue is documented partially within the linux-imx vendor kernel
which references a Synopsys STAR number 9001415732 in commits [1] and
additional details in [2]. Those commits provide some additional
controller internal implementation specifics around the incorrect
behaviour of the SuperSpeed host controller operation when park mode is
enabled.
The summary of this issue is that the host controller can incorrectly
enter/exit park mode such that part of the controller is in a state
which behaves as if in park mode even though it is not. In this state
the controller incorrectly calculates the number of TRBs available which
results in incorrect access of the internal caches causing the overwrite
of pending requests in the cache which should have been processed but
are ignored. This can cause the controller to drop the requests or hang
waiting for the pending state of the dropped requests.
The workaround for this issue is to disable park mode for SuperSpeed
operation of the controller through the GUCTL1[17] bit. This is already
available as a quirk for the DWC3 controller and can be enabled via the
'snps,parkmode-disable-ss-quirk' device tree property.
It is possible to replicate this failure on an i.MX8MP EVK with a USB
Hub connecting 4 SuperSpeed USB flash drives. Performing continuous
small read operations (dd if=/dev/sd... of=/dev/null bs=16) on the block
devices will result in device errors initially and will eventually
result in the controller hanging.
[13240.896936] xhci-hcd xhci-hcd.0.auto: WARN Event TRB for slot 4 ep 2 with no TDs queued?
[13240.990708] usb 2-1.3: reset SuperSpeed USB device number 5 using xhci-hcd
[13241.015582] sd 2:0:0:0: [sdc] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x07 driverbyte=DRIVER_OK cmd_age=0s
[13241.025198] sd 2:0:0:0: [sdc] tag#0 CDB: opcode=0x28 28 00 00 00 03 e0 00 01 00 00
[13241.032949] I/O error, dev sdc, sector 992 op 0x0:(READ) flags 0x80700 phys_seg 25 prio class 2
[13272.150710] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[13272.175469] sd 1:0:0:0: [sdb] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x03 driverbyte=DRIVER_OK cmd_age=31s
[13272.185365] sd 1:0:0:0: [sdb] tag#0 CDB: opcode=0x28 28 00 00 00 03 e0 00 01 00 00
[13272.193385] I/O error, dev sdb, sector 992 op 0x0:(READ) flags 0x80700 phys_seg 18 prio class 2
[13434.846556] xhci-hcd xhci-hcd.0.auto: xHCI host not responding to stop endpoint command
[13434.854592] xhci-hcd xhci-hcd.0.auto: xHCI host controller not responding, assume dead
[13434.862553] xhci-hcd xhci-hcd.0.auto: HC died; cleaning up
[1] https://github.com/nxp-imx/linux-imx/commit/97a5349d936b08cf301730b59e4e8855283f815c
[2] https://github.com/nxp-imx/linux-imx/commit/b4b5cbc5a12d7c3b920d1d7cba0ada3379e4e42b
Fixes: fb8587a2c165 ("arm64: dtsi: imx8mp: add usb nodes")
Fixes: ad37549cb5dc ("arm64: dts: imx8mq: add USB nodes")
Signed-off-by: Nathan Rossi <nathan.rossi@digi.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
[ Upstream commit fcd3f50845be909c9e0f8ac402874a2fb4b09c6c ]
The property is NXP downstream property that there is no user
in upstream, drop it.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Link: https://lore.kernel.org/r/20230323035531.3808192-2-peng.fan@oss.nxp.com
Stable-dep-of: 209043cf092d ("arm64: dts: imx8mp: imx8mq: Add parkmode-disable-ss-quirk on DWC3")
[ Upstream commit 35938c18291b5da7422b2fac6dac0af11aa8d0d7 ]
Expand the reg size for the vdec node to include cache/performance
registers the rkvdec driver writes to. Also add missing clocks to the
related power-domain.
Fixes: cbd7214402ec ("arm64: dts: rockchip: Define the rockchip Video Decoder node on rk3399")
Signed-off-by: Alex Bee <knaerzche@gmail.com>
Signed-off-by: Jonas Karlman <jonas@kwiboo.se>
Link: https://lore.kernel.org/r/20231105233630.3927502-10-jonas@kwiboo.se
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
commit e5f3e299a2b1e9c3ece24a38adfc089aef307e8a upstream.
Those return codes are only defined for the parisc architecture and
are leftovers from when we wanted to be HP-UX compatible.
They are not returned by any Linux kernel syscall but do trigger
problems with the glibc strerrorname_np() and strerror() functions as
reported in glibc issue #31080.
There is no need to keep them, so simply remove them.
Signed-off-by: Helge Deller <deller@gmx.de>
Reported-by: Bruno Haible <bruno@clisp.org>
Closes: https://sourceware.org/bugzilla/show_bug.cgi?id=31080
commit 5e1d824f9a283cbf90f25241b66d1f69adb3835b upstream.
During floating point and vector save to thread data f0/vs0 are
clobbered by the FPSCR/VSCR store routine. This has been obvserved to
lead to userspace register corruption and application data corruption
with io-uring.
Fix it by restoring f0/vs0 after FPSCR/VSCR store has completed for
all the FP, altivec, VMX register save paths.
Tested under QEMU in kvm mode, running on a Talos II workstation with
dual POWER9 DD2.2 CPUs.
Additional detail (mpe):
Typically save_fpu() is called from __giveup_fpu() which saves the FP
regs and also *turns off FP* in the tasks MSR, meaning the kernel will
reload the FP regs from the thread struct before letting the task use FP
again. So in that case save_fpu() is free to clobber f0 because the FP
regs no longer hold live values for the task.
There is another case though, which is the path via:
sys_clone()
copy_process()
dup_task_struct()
arch_dup_task_struct()
flush_all_to_thread()
save_all()
That path saves the FP regs but leaves them live. That's meant as an
optimisation for a process that's using FP/VSX and then calls fork(),
leaving the regs live means the parent process doesn't have to take a
fault after the fork to get its FP regs back. The optimisation was added
in commit 8792468da5e1 ("powerpc: Add the ability to save FPU without
giving it up").
That path does clobber f0, but f0 is volatile across function calls,
and typically programs reach copy_process() from userspace via a syscall
wrapper function. So in normal usage f0 being clobbered across a
syscall doesn't cause visible data corruption.
But there is now a new path, because io-uring can call copy_process()
via create_io_thread() from the signal handling path. That's OK if the
signal is handled as part of syscall return, but it's not OK if the
signal is handled due to some other interrupt.
That path is:
interrupt_return_srr_user()
interrupt_exit_user_prepare()
interrupt_exit_user_prepare_main()
do_notify_resume()
get_signal()
task_work_run()
create_worker_cb()
create_io_worker()
copy_process()
dup_task_struct()
save_all()
if (tsk->thread.regs->msr & MSR_FP)
save_fpu()
# f0 is clobbered and potentially live in userspace
Note the above discussion applies equally to save_altivec().
Fixes: 8792468da5e1 ("powerpc: Add the ability to save FPU without giving it up")
Cc: stable@vger.kernel.org # v4.6+
Closes: https://lore.kernel.org/all/480932026.45576726.1699374859845.JavaMail.zimbra@raptorengineeringinc.com/
Closes: https://lore.kernel.org/linuxppc-dev/480221078.47953493.1700206777956.JavaMail.zimbra@raptorengineeringinc.com/
Tested-by: Timothy Pearson <tpearson@raptorengineering.com>
Tested-by: Jens Axboe <axboe@kernel.dk>
Signed-off-by: Timothy Pearson <tpearson@raptorengineering.com>
[mpe: Reword change log to describe exact path of corruption & other minor tweaks]
Link: https://msgid.link/1921539696.48534988.1700407082933.JavaMail.zimbra@raptorengineeringinc.com
[ Upstream commit 83767a67e7b6a0291cde5681ec7e3708f3f8f877 ]
After commit 411740f5422a ("KVM: MIPS/MMU: Implement KVM_CAP_SYNC_MMU")
old_pte is no longer used in kvm_mips_map_page(). So remove it to fix a
build warning about variable set but not used:
arch/mips/kvm/mmu.c: In function 'kvm_mips_map_page':
>> arch/mips/kvm/mmu.c:701:29: warning: variable 'old_pte' set but not used [-Wunused-but-set-variable]
701 | pte_t *ptep, entry, old_pte;
Fixes: 411740f5422a960 ("KVM: MIPS/MMU: Implement KVM_CAP_SYNC_MMU")
Closes: https://lore.kernel.org/oe-kbuild-all/202310070530.aARZCSfh-lkp@intel.com/
Signed-off-by: Huacai Chen <chenhuacai@loongson.cn>
Reviewed-by: Philippe Mathieu-Daudé <philmd@linaro.org>
[ Upstream commit 7bf9a6b46549852a37e6d07e52c601c3c706b562 ]
xen_vcpu_info is a percpu area than needs to be mapped by Xen.
Currently, it could cross a page boundary resulting in Xen being unable
to map it:
[ 0.567318] kernel BUG at arch/arm64/xen/../../arm/xen/enlighten.c:164!
[ 0.574002] Internal error: Oops - BUG: 00000000f2000800 [#1] PREEMPT SMP
Fix the issue by using __alloc_percpu and requesting alignment for the
memory allocation.
Signed-off-by: Stefano Stabellini <stefano.stabellini@amd.com>
Link: https://lore.kernel.org/r/alpine.DEB.2.22.394.2311221501340.2053963@ubuntu-linux-20-04-desktop
Fixes: 24d5373dda7c ("arm/xen: Use alloc_percpu rather than __alloc_percpu")
Reviewed-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
commit feea65a338e52297b68ceb688eaf0ffc50310a83 upstream.
As reported by Mahesh & Aneesh, opal_prd_msg_notifier() triggers a
FORTIFY_SOURCE warning:
memcpy: detected field-spanning write (size 32) of single field "&item->msg" at arch/powerpc/platforms/powernv/opal-prd.c:355 (size 4)
WARNING: CPU: 9 PID: 660 at arch/powerpc/platforms/powernv/opal-prd.c:355 opal_prd_msg_notifier+0x174/0x188 [opal_prd]
NIP opal_prd_msg_notifier+0x174/0x188 [opal_prd]
LR opal_prd_msg_notifier+0x170/0x188 [opal_prd]
Call Trace:
opal_prd_msg_notifier+0x170/0x188 [opal_prd] (unreliable)
notifier_call_chain+0xc0/0x1b0
atomic_notifier_call_chain+0x2c/0x40
opal_message_notify+0xf4/0x2c0
This happens because the copy is targeting item->msg, which is only 4
bytes in size, even though the enclosing item was allocated with extra
space following the msg.
To fix the warning define struct opal_prd_msg with a union of the header
and a flex array, and have the memcpy target the flex array.
Reported-by: "Aneesh Kumar K.V" <aneesh.kumar@linux.ibm.com>
Reported-by: Mahesh Salgaonkar <mahesh@linux.ibm.com>
Tested-by: Mahesh Salgaonkar <mahesh@linux.ibm.com>
Reviewed-by: Mahesh Salgaonkar <mahesh@linux.ibm.com>
Link: https://msgid.link/20230821142820.497107-1-mpe@ellerman.id.au
