path: root/arch
2021-01-31Merge tag 'x86_entry_for_v5.11_rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fix from Borislav Petkov: "A single fix for objtool to generate proper unwind info for newer toolchains which do not generate section symbols anymore. And a cleanup ontop. This was originally going to go during the next merge window but people can already trigger a build error with binutils-2.36 which doesn't emit section symbols - something which objtool relies on - so let's expedite it" * tag 'x86_entry_for_v5.11_rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/entry: Remove put_ret_addr_in_rdi THUNK macro argument x86/entry: Emit a symbol for register restoring thunk
2021-01-31Merge tag 'powerpc-5.11-6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fix from Michael Ellerman: "One fix for a bug in our soft interrupt masking, which could lead to interrupt replaying recursing, causing spurious interrupts. Thanks to Nicholas Piggin" * tag 'powerpc-5.11-6' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc/64s: prevent recursive replay_soft_interrupts causing superfluous interrupt
2021-01-30Merge tag 'devicetree-fixes-for-5.11-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull devicetree fixes from Rob Herring: - Cleanups on properties with standard unit suffixes - Fix overwriting dma_range_map if there's no 'dma-ranges' property - Fix a bug when creating a /chosen node from ARM ATAGs - Add missing properties for TI j721e USB binding - Several doc reference updates due to DT schema conversions * tag 'devicetree-fixes-for-5.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: dt-bindings: Cleanup standard unit properties of/device: Update dma_range_map only when dev has valid dma-ranges ARM: zImage: atags_to_fdt: Fix node names on added root nodes dt-bindings: usb: j721e: add ranges and dma-coherent props dt-bindings:iio:adc: update adc.yaml reference dt-bindings: memory: mediatek: update mediatek,smi-larb.yaml references dt-bindings: display: mediatek: update mediatek,dpi.yaml reference ASoC: audio-graph-card: update audio-graph-card.yaml reference
2021-01-30Merge tag 's390-5.11-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Vasily Gorbik: - Fix max number of VCPUs reported via ultravisor information sysfs interface. - Fix memory leaks during vfio-ap resources clean up on KVM pointer invalidation notification. - Fix potential specification exception by avoiding unnecessary interrupts disable after queue reset in vfio-ap. * tag 's390-5.11-4' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390: uv: Fix sysfs max number of VCPUs reporting s390/vfio-ap: No need to disable IRQ after queue reset s390/vfio-ap: clean up vfio_ap resources when KVM pointer invalidated
2021-01-30Merge tag 'riscv-for-linus-5.11-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux Pull RISC-V fix from Palmer Dabbelt: "A fix to avoid initializing max_mapnr to be too large, which may manifest on NUMA systems" * tag 'riscv-for-linus-5.11-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux: riscv: Fixup pfn_valid error with wrong max_mapnr
2021-01-29Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - Fix the virt_addr_valid() returning true for < PAGE_OFFSET addresses. - Do not blindly trust the DMA masks from ACPI/IORT. * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: ACPI/IORT: Do not blindly trust DMA masks from firmware arm64: Fix kernel address detection of __is_lm_address()
2021-01-28Merge tag 'for-linus-5.11-rc6-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen fixes from Juergen Gross: - A fix for a regression introduced in 5.11 resulting in Xen dom0 having problems to correctly initialize Xenstore. - A fix for avoiding WARN splats when booting as Xen dom0 with CONFIG_AMD_MEM_ENCRYPT enabled due to a missing trap handler for the #VC exception (even if the handler should never be called). - A fix for the Xen bklfront driver adapting to the correct but unexpected behavior of new qemu. * tag 'for-linus-5.11-rc6-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: x86/xen: avoid warning in Xen pv guest with CONFIG_AMD_MEM_ENCRYPT enabled xen: Fix XenStore initialisation for XS_LOCAL xen-blkfront: allow discard-* nodes to be optional
2021-01-28Merge tag 'asm-generic-fixes-v5.11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic Pull ia64 fixes from Arnd Bergmann: "asm-generic/ia64 fixes, and mark as orphaned Commit 2b49ddcef297 ("ia64: convert to legacy_timer_tick") from my timer series I merged through the asm-generic tree caused a regression on all ia64 machines, as bisected by Adrian Glaubitz. Tony Luck is no longer really working on ia64, so instead of merging the fix through his tree, we ended up deciding that I'd merge the fix myself along a patch to mark the architecture as Orphaned and a compile time warning fix I made while working on the regression" [ HPE no longer accepts orders for new Itanium hardware, and Intel stopped accepting orders a year ago. While intel is still officially shipping chips until July 29, 2021, it's unlikely that any such orders actually exist. It's dead, Jim. - Linus ] * tag 'asm-generic-fixes-v5.11' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic: ia64: Mark architecture as orphaned ia64: fix xchg() warning ia64: fix timer cleanup regression
2021-01-28Merge tag 'arm-soc-fixes-v5.11-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc Pull ARM SoC fixes from Arnd Bergmann: "These are the current arm-soc bug fixes for linux-5.11. I already merged a larger set that just came in during the past three days but has not had much exposure in linux-next, but this is the subset I merged last week. Most of these are for the NXP i.MX platform (descriptions from their pull request): - Fix pcf2127 reset for imx7d-flex-concentrator board. - Fix i.MX6 suspend with Thumb-2 kernel. - Fix ethernet-phy address issue on imx6qdl-sr-som board. - Fix GPIO3 `gpio-ranges` on i.MX8MP. - Select SOC_BUS for IMX_SCU driver to fix build issue. - Fix backlight pwm on imx6qdl-kontron-samx6i which is lost from #pwm-cells conversion. - Fix duplicated bus node name for i.MX8MN SoC. - Fix reset register offset on LS1028A SoC. - Rename MMC node aliases for imx6q-tbs2910 to keep the MMC device index consistent with previous kernel version. - Selecting ARM_GIC_V3 on non-CP15 processors to fix one build failure with i.MX8M SoC driver. - Fix typos with status property on imx6qdl-kontron-samx6i board. - Fix duplicated regulator-name on imx6qdl-gw52xx board. Aside from i.MX, the bugfixes are all over the place: - Coccinelle found a refcount imbalance on integrator - defconfig fix for TI K3 - A boot regression fix for ST ux500 - A code preemption fix for the optee driver - USB DMA regression on Broadcom Stingray - A bogus boot time warning fix for at91 code" * tag 'arm-soc-fixes-v5.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: MAINTAINERS: Include bcm2835 subsequents into search arm64: dts: broadcom: Fix USB DMA address translation for Stingray drivers: soc: atmel: add null entry at the end of at91_soc_allowed_list[] drivers: soc: atmel: Avoid calling at91_soc_init on non AT91 SoCs tee: optee: replace might_sleep with cond_resched firmware: imx: select SOC_BUS to fix firmware build arm64: dts: imx8mp: Correct the gpio ranges of gpio3 ARM: dts: imx6qdl-sr-som: fix some cubox-i platforms ARM: imx: build suspend-imx6.S with arm instruction set ARM: dts: imx7d-flex-concentrator: fix pcf2127 reset ARM: dts: ux500: Reserve memory carveouts arm64: defconfig: Drop unused K3 SoC specific options bus: arm-integrator-lm: Add of_node_put() before return statement ARM: dts: imx6qdl-gw52xx: fix duplicate regulator naming ARM: dts: imx6qdl-kontron-samx6i: fix i2c_lcd/cam default status ARM: imx: fix imx8m dependencies ARM: dts: tbs2910: rename MMC node aliases arm64: dts: ls1028a: fix the offset of the reset register arm64: dts: imx8mn: Fix duplicate node name ARM: dts: imx6qdl-kontron-samx6i: fix pwms for lcd-backlight
2021-01-27Merge branch 'parisc-5.11-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fixes from Helge Deller: "Two small fixes: - Fix linking error with 64-bit kernel when modules are disabled, reported by kernel test robot - Remove leftover reference to power_tasklet, by Davidlohr Bueso" * 'parisc-5.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Enable -mlong-calls gcc option by default when !CONFIG_MODULES parisc: Remove leftover reference to the power_tasklet
2021-01-27x86/xen: avoid warning in Xen pv guest with CONFIG_AMD_MEM_ENCRYPT enabledJuergen Gross
When booting a kernel which has been built with CONFIG_AMD_MEM_ENCRYPT enabled as a Xen pv guest a warning is issued for each processor: [ 5.964347] ------------[ cut here ]------------ [ 5.968314] WARNING: CPU: 0 PID: 1 at /home/gross/linux/head/arch/x86/xen/enlighten_pv.c:660 get_trap_addr+0x59/0x90 [ 5.972321] Modules linked in: [ 5.976313] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 5.11.0-rc5-default #75 [ 5.980313] Hardware name: Dell Inc. OptiPlex 9020/0PC5F7, BIOS A05 12/05/2013 [ 5.984313] RIP: e030:get_trap_addr+0x59/0x90 [ 5.988313] Code: 42 10 83 f0 01 85 f6 74 04 84 c0 75 1d b8 01 00 00 00 c3 48 3d 00 80 83 82 72 08 48 3d 20 81 83 82 72 0c b8 01 00 00 00 eb db <0f> 0b 31 c0 c3 48 2d 00 80 83 82 48 ba 72 1c c7 71 1c c7 71 1c 48 [ 5.992313] RSP: e02b:ffffc90040033d38 EFLAGS: 00010202 [ 5.996313] RAX: 0000000000000001 RBX: ffffffff82a141d0 RCX: ffffffff8222ec38 [ 6.000312] RDX: ffffffff8222ec38 RSI: 0000000000000005 RDI: ffffc90040033d40 [ 6.004313] RBP: ffff8881003984a0 R08: 0000000000000007 R09: ffff888100398000 [ 6.008312] R10: 0000000000000007 R11: ffffc90040246000 R12: ffff8884082182a8 [ 6.012313] R13: 0000000000000100 R14: 000000000000001d R15: ffff8881003982d0 [ 6.016316] FS: 0000000000000000(0000) GS:ffff888408200000(0000) knlGS:0000000000000000 [ 6.020313] CS: e030 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 6.024313] CR2: ffffc900020ef000 CR3: 000000000220a000 CR4: 0000000000050660 [ 6.028314] Call Trace: [ 6.032313] cvt_gate_to_trap.part.7+0x3f/0x90 [ 6.036313] ? asm_exc_double_fault+0x30/0x30 [ 6.040313] xen_convert_trap_info+0x87/0xd0 [ 6.044313] xen_pv_cpu_up+0x17a/0x450 [ 6.048313] bringup_cpu+0x2b/0xc0 [ 6.052313] ? cpus_read_trylock+0x50/0x50 [ 6.056313] cpuhp_invoke_callback+0x80/0x4c0 [ 6.060313] _cpu_up+0xa7/0x140 [ 6.064313] cpu_up+0x98/0xd0 [ 6.068313] bringup_nonboot_cpus+0x4f/0x60 [ 6.072313] smp_init+0x26/0x79 [ 6.076313] kernel_init_freeable+0x103/0x258 [ 6.080313] ? rest_init+0xd0/0xd0 [ 6.084313] kernel_init+0xa/0x110 [ 6.088313] ret_from_fork+0x1f/0x30 [ 6.092313] ---[ end trace be9ecf17dceeb4f3 ]--- Reason is that there is no Xen pv trap entry for X86_TRAP_VC. Fix that by adding a generic trap handler for unknown traps and wire all unknown bare metal handlers to this generic handler, which will just crash the system in case such a trap will ever happen. Fixes: 0786138c78e793 ("x86/sev-es: Add a Runtime #VC Exception Handler") Cc: <stable@vger.kernel.org> # v5.10 Signed-off-by: Juergen Gross <jgross@suse.com> Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Juergen Gross <jgross@suse.com>
2021-01-27s390: uv: Fix sysfs max number of VCPUs reportingJanosch Frank
The number reported by the query is N-1 and I think people reading the sysfs file would expect N instead. For users creating VMs there's no actual difference because KVM's limit is currently below the UV's limit. Signed-off-by: Janosch Frank <frankja@linux.ibm.com> Fixes: a0f60f8431999 ("s390/protvirt: Add sysfs firmware interface for Ultravisor information") Cc: stable@vger.kernel.org Reviewed-by: Claudio Imbrenda <imbrenda@linux.ibm.com> Acked-by: Cornelia Huck <cohuck@redhat.com> Signed-off-by: Vasily Gorbik <gor@linux.ibm.com>
2021-01-26ARM: zImage: atags_to_fdt: Fix node names on added root nodesRob Herring
Commit 7536c7e03e74 ("of/fdt: Remove redundant kbasename function call") exposed a bug creating DT nodes in the ATAGS to DT fixup code. Non-existent nodes would mistaken get created with a leading '/'. The problem was fdt_path_offset() takes a full path while creating a node with fdt_add_subnode() takes just the basename. Since this we only add root child nodes, we can just skip over the '/'. Fixes: 7536c7e03e74 ("of/fdt: Remove redundant kbasename function call") Reported-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Qi Zheng <arch0.zheng@gmail.com> Cc: Russell King <linux@armlinux.org.uk> Signed-off-by: Rob Herring <robh@kernel.org> Tested-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Link: https://lore.kernel.org/r/20210126023905.1631161-1-robh@kernel.org
2021-01-26parisc: Enable -mlong-calls gcc option by default when !CONFIG_MODULESHelge Deller
When building a kernel without module support, the CONFIG_MLONGCALL option needs to be enabled in order to reach symbols which are outside of a 22-bit branch. This patch changes the autodetection in the Kconfig script to always enable CONFIG_MLONGCALL when modules are disabled and uses a far call to preempt_schedule_irq() in intr_do_preempt() to reach the symbol in all cases. Signed-off-by: Helge Deller <deller@gmx.de> Reported-by: kernel test robot <lkp@intel.com> Cc: stable@vger.kernel.org # v5.6+
2021-01-26Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: - x86 bugfixes - Documentation fixes - Avoid performance regression due to SEV-ES patches - ARM: - Don't allow tagged pointers to point to memslots - Filter out ARMv8.1+ PMU events on v8.0 hardware - Hide PMU registers from userspace when no PMU is configured - More PMU cleanups - Don't try to handle broken PSCI firmware - More sys_reg() to reg_to_encoding() conversions * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: allow KVM_REQ_GET_NESTED_STATE_PAGES outside guest mode for VMX KVM: x86: Revert "KVM: x86: Mark GPRs dirty when written" KVM: SVM: Unconditionally sync GPRs to GHCB on VMRUN of SEV-ES guest KVM: nVMX: Sync unsync'd vmcs02 state to vmcs12 on migration kvm: tracing: Fix unmatched kvm_entry and kvm_exit events KVM: Documentation: Update description of KVM_{GET,CLEAR}_DIRTY_LOG KVM: x86: get smi pending status correctly KVM: x86/pmu: Fix HW_REF_CPU_CYCLES event pseudo-encoding in intel_arch_events[] KVM: x86/pmu: Fix UBSAN shift-out-of-bounds warning in intel_pmu_refresh() KVM: x86: Add more protection against undefined behavior in rsvd_bits() KVM: Documentation: Fix spec for KVM_CAP_ENABLE_CAP_VM KVM: Forbid the use of tagged userspace addresses for memslots KVM: arm64: Filter out v8.1+ events on v8.0 HW KVM: arm64: Compute TPIDR_EL2 ignoring MTE tag KVM: arm64: Use the reg_to_encoding() macro instead of sys_reg() KVM: arm64: Allow PSCI SYSTEM_OFF/RESET to return KVM: arm64: Simplify handling of absent PMU system registers KVM: arm64: Hide PMU registers from userspace when not available
2021-01-26parisc: Remove leftover reference to the power_taskletDavidlohr Bueso
This was removed long ago, back in: 6e16d9409e1 ([PARISC] Convert soft power switch driver to kthread) Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Helge Deller <deller@gmx.de>
2021-01-26arm64: Fix kernel address detection of __is_lm_address()Vincenzo Frascino
Currently, the __is_lm_address() check just masks out the top 12 bits of the address, but if they are 0, it still yields a true result. This has as a side effect that virt_addr_valid() returns true even for invalid virtual addresses (e.g. 0x0). Fix the detection checking that it's actually a kernel address starting at PAGE_OFFSET. Fixes: 68dd8ef32162 ("arm64: memory: Fix virt_addr_valid() using __is_lm_address()") Cc: <stable@vger.kernel.org> # 5.4.x Cc: Will Deacon <will@kernel.org> Suggested-by: Catalin Marinas <catalin.marinas@arm.com> Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Vincenzo Frascino <vincenzo.frascino@arm.com> Link: https://lore.kernel.org/r/20210126134056.45747-1-vincenzo.frascino@arm.com Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2021-01-25KVM: x86: allow KVM_REQ_GET_NESTED_STATE_PAGES outside guest mode for VMXPaolo Bonzini
VMX also uses KVM_REQ_GET_NESTED_STATE_PAGES for the Hyper-V eVMCS, which may need to be loaded outside guest mode. Therefore we cannot WARN in that case. However, that part of nested_get_vmcs12_pages is _not_ needed at vmentry time. Split it out of KVM_REQ_GET_NESTED_STATE_PAGES handling, so that both vmentry and migration (and in the latter case, independent of is_guest_mode) do the parts that are needed. Cc: <stable@vger.kernel.org> # 5.10.x: f2c7ef3ba: KVM: nSVM: cancel KVM_REQ_GET_NESTED_STATE_PAGES Cc: <stable@vger.kernel.org> # 5.10.x Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25KVM: x86: Revert "KVM: x86: Mark GPRs dirty when written"Sean Christopherson
Revert the dirty/available tracking of GPRs now that KVM copies the GPRs to the GHCB on any post-VMGEXIT VMRUN, even if a GPR is not dirty. Per commit de3cd117ed2f ("KVM: x86: Omit caching logic for always-available GPRs"), tracking for GPRs noticeably impacts KVM's code footprint. This reverts commit 1c04d8c986567c27c56c05205dceadc92efb14ff. Signed-off-by: Sean Christopherson <seanjc@google.com> Message-Id: <20210122235049.3107620-3-seanjc@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25KVM: SVM: Unconditionally sync GPRs to GHCB on VMRUN of SEV-ES guestSean Christopherson
Drop the per-GPR dirty checks when synchronizing GPRs to the GHCB, the GRPs' dirty bits are set from time zero and never cleared, i.e. will always be seen as dirty. The obvious alternative would be to clear the dirty bits when appropriate, but removing the dirty checks is desirable as it allows reverting GPR dirty+available tracking, which adds overhead to all flavors of x86 VMs. Note, unconditionally writing the GPRs in the GHCB is tacitly allowed by the GHCB spec, which allows the hypervisor (or guest) to provide unnecessary info; it's the guest's responsibility to consume only what it needs (the hypervisor is untrusted after all). The guest and hypervisor can supply additional state if desired but must not rely on that additional state being provided. Cc: Brijesh Singh <brijesh.singh@amd.com> Cc: Tom Lendacky <thomas.lendacky@amd.com> Fixes: 291bd20d5d88 ("KVM: SVM: Add initial support for a VMGEXIT VMEXIT") Signed-off-by: Sean Christopherson <seanjc@google.com> Message-Id: <20210122235049.3107620-2-seanjc@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25KVM: nVMX: Sync unsync'd vmcs02 state to vmcs12 on migrationMaxim Levitsky
Even when we are outside the nested guest, some vmcs02 fields may not be in sync vs vmcs12. This is intentional, even across nested VM-exit, because the sync can be delayed until the nested hypervisor performs a VMCLEAR or a VMREAD/VMWRITE that affects those rarely accessed fields. However, during KVM_GET_NESTED_STATE, the vmcs12 has to be up to date to be able to restore it. To fix that, call copy_vmcs02_to_vmcs12_rare() before the vmcs12 contents are copied to userspace. Fixes: 7952d769c29ca ("KVM: nVMX: Sync rarely accessed guest fields only when needed") Reviewed-by: Sean Christopherson <seanjc@google.com> Signed-off-by: Maxim Levitsky <mlevitsk@redhat.com> Message-Id: <20210114205449.8715-2-mlevitsk@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25kvm: tracing: Fix unmatched kvm_entry and kvm_exit eventsLorenzo Brescia
On VMX, if we exit and then re-enter immediately without leaving the vmx_vcpu_run() function, the kvm_entry event is not logged. That means we will see one (or more) kvm_exit, without its (their) corresponding kvm_entry, as shown here: CPU-1979 [002] 89.871187: kvm_entry: vcpu 1 CPU-1979 [002] 89.871218: kvm_exit: reason MSR_WRITE CPU-1979 [002] 89.871259: kvm_exit: reason MSR_WRITE It also seems possible for a kvm_entry event to be logged, but then we leave vmx_vcpu_run() right away (if vmx->emulation_required is true). In this case, we will have a spurious kvm_entry event in the trace. Fix these situations by moving trace_kvm_entry() inside vmx_vcpu_run() (where trace_kvm_exit() already is). A trace obtained with this patch applied looks like this: CPU-14295 [000] 8388.395387: kvm_entry: vcpu 0 CPU-14295 [000] 8388.395392: kvm_exit: reason MSR_WRITE CPU-14295 [000] 8388.395393: kvm_entry: vcpu 0 CPU-14295 [000] 8388.395503: kvm_exit: reason EXTERNAL_INTERRUPT Of course, not calling trace_kvm_entry() in common x86 code any longer means that we need to adjust the SVM side of things too. Signed-off-by: Lorenzo Brescia <lorenzo.brescia@edu.unito.it> Signed-off-by: Dario Faggioli <dfaggioli@suse.com> Message-Id: <160873470698.11652.13483635328769030605.stgit@Wayrath> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25KVM: x86: get smi pending status correctlyJay Zhou
The injection process of smi has two steps: Qemu KVM Step1: cpu->interrupt_request &= \ ~CPU_INTERRUPT_SMI; kvm_vcpu_ioctl(cpu, KVM_SMI) call kvm_vcpu_ioctl_smi() and kvm_make_request(KVM_REQ_SMI, vcpu); Step2: kvm_vcpu_ioctl(cpu, KVM_RUN, 0) call process_smi() if kvm_check_request(KVM_REQ_SMI, vcpu) is true, mark vcpu->arch.smi_pending = true; The vcpu->arch.smi_pending will be set true in step2, unfortunately if vcpu paused between step1 and step2, the kvm_run->immediate_exit will be set and vcpu has to exit to Qemu immediately during step2 before mark vcpu->arch.smi_pending true. During VM migration, Qemu will get the smi pending status from KVM using KVM_GET_VCPU_EVENTS ioctl at the downtime, then the smi pending status will be lost. Signed-off-by: Jay Zhou <jianjay.zhou@huawei.com> Signed-off-by: Shengen Zhuang <zhuangshengen@huawei.com> Message-Id: <20210118084720.1585-1-jianjay.zhou@huawei.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25KVM: x86/pmu: Fix HW_REF_CPU_CYCLES event pseudo-encoding in intel_arch_events[]Like Xu
The HW_REF_CPU_CYCLES event on the fixed counter 2 is pseudo-encoded as 0x0300 in the intel_perfmon_event_map[]. Correct its usage. Fixes: 62079d8a4312 ("KVM: PMU: add proper support for fixed counter 2") Signed-off-by: Like Xu <like.xu@linux.intel.com> Message-Id: <20201230081916.63417-1-like.xu@linux.intel.com> Reviewed-by: Sean Christopherson <seanjc@google.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25KVM: x86/pmu: Fix UBSAN shift-out-of-bounds warning in intel_pmu_refresh()Like Xu
Since we know vPMU will not work properly when (1) the guest bit_width(s) of the [gp|fixed] counters are greater than the host ones, or (2) guest requested architectural events exceeds the range supported by the host, so we can setup a smaller left shift value and refresh the guest cpuid entry, thus fixing the following UBSAN shift-out-of-bounds warning: shift exponent 197 is too large for 64-bit type 'long long unsigned int' Call Trace: __dump_stack lib/dump_stack.c:79 [inline] dump_stack+0x107/0x163 lib/dump_stack.c:120 ubsan_epilogue+0xb/0x5a lib/ubsan.c:148 __ubsan_handle_shift_out_of_bounds.cold+0xb1/0x181 lib/ubsan.c:395 intel_pmu_refresh.cold+0x75/0x99 arch/x86/kvm/vmx/pmu_intel.c:348 kvm_vcpu_after_set_cpuid+0x65a/0xf80 arch/x86/kvm/cpuid.c:177 kvm_vcpu_ioctl_set_cpuid2+0x160/0x440 arch/x86/kvm/cpuid.c:308 kvm_arch_vcpu_ioctl+0x11b6/0x2d70 arch/x86/kvm/x86.c:4709 kvm_vcpu_ioctl+0x7b9/0xdb0 arch/x86/kvm/../../../virt/kvm/kvm_main.c:3386 vfs_ioctl fs/ioctl.c:48 [inline] __do_sys_ioctl fs/ioctl.c:753 [inline] __se_sys_ioctl fs/ioctl.c:739 [inline] __x64_sys_ioctl+0x193/0x200 fs/ioctl.c:739 do_syscall_64+0x2d/0x70 arch/x86/entry/common.c:46 entry_SYSCALL_64_after_hwframe+0x44/0xa9 Reported-by: syzbot+ae488dc136a4cc6ba32b@syzkaller.appspotmail.com Signed-off-by: Like Xu <like.xu@linux.intel.com> Message-Id: <20210118025800.34620-1-like.xu@linux.intel.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25KVM: x86: Add more protection against undefined behavior in rsvd_bits()Sean Christopherson
Add compile-time asserts in rsvd_bits() to guard against KVM passing in garbage hardcoded values, and cap the upper bound at '63' for dynamic values to prevent generating a mask that would overflow a u64. Suggested-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sean Christopherson <seanjc@google.com> Message-Id: <20210113204515.3473079-1-seanjc@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2021-01-25Merge tag 'kvmarm-fixes-5.11-2' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD KVM/arm64 fixes for 5.11, take #2 - Don't allow tagged pointers to point to memslots - Filter out ARMv8.1+ PMU events on v8.0 hardware - Hide PMU registers from userspace when no PMU is configured - More PMU cleanups - Don't try to handle broken PSCI firmware - More sys_reg() to reg_to_encoding() conversions
2021-01-24Merge tag 'sh-for-5.11' of git://git.libc.org/linux-shLinus Torvalds
Pull arch/sh updates from Rich Felker: "Cleanup and warning fixes" * tag 'sh-for-5.11' of git://git.libc.org/linux-sh: sh/intc: Restore devm_ioremap() alignment sh: mach-sh03: remove duplicate include arch: sh: remove duplicate include sh: Drop ARCH_NR_GPIOS definition sh: Remove unused HAVE_COPY_THREAD_TLS macro sh: remove CONFIG_IDE from most defconfig sh: mm: Convert to DEFINE_SHOW_ATTRIBUTE sh: intc: Convert to DEFINE_SHOW_ATTRIBUTE arch/sh: hyphenate Non-Uniform in Kconfig prompt sh: dma: fix kconfig dependency for G2_DMA
2021-01-24Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "18 patches. Subsystems affected by this patch series: mm (pagealloc, memcg, kasan, memory-failure, and highmem), ubsan, proc, and MAINTAINERS" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: MAINTAINERS: add a couple more files to the Clang/LLVM section proc_sysctl: fix oops caused by incorrect command parameters powerpc/mm/highmem: use __set_pte_at() for kmap_local() mips/mm/highmem: use set_pte() for kmap_local() mm/highmem: prepare for overriding set_pte_at() sparc/mm/highmem: flush cache and TLB mm: fix page reference leak in soft_offline_page() ubsan: disable unsigned-overflow check for i386 kasan, mm: fix resetting page_alloc tags for HW_TAGS kasan, mm: fix conflicts with init_on_alloc/free kasan: fix HW_TAGS boot parameters kasan: fix incorrect arguments passing in kasan_add_zero_shadow kasan: fix unaligned address is unhandled in kasan_remove_zero_shadow mm: fix numa stats for thp migration mm: memcg: fix memcg file_dirty numa stat mm: memcg/slab: optimize objcg stock draining mm: fix initialization of struct page for holes in memory layout x86/setup: don't remove E820_TYPE_RAM for pfn 0
2021-01-24powerpc/mm/highmem: use __set_pte_at() for kmap_local()Thomas Gleixner
The original PowerPC highmem mapping function used __set_pte_at() to denote that the mapping is per CPU. This got lost with the conversion to the generic implementation. Override the default map function. Link: https://lkml.kernel.org/r/20210112170411.281464308@linutronix.de Fixes: 47da42b27a56 ("powerpc/mm/highmem: Switch to generic kmap atomic") Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andreas Larsson <andreas@gaisler.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Paul Cercueil <paul@crapouillou.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2021-01-24mips/mm/highmem: use set_pte() for kmap_local()Thomas Gleixner
set_pte_at() on MIPS invokes update_cache() which might recurse into kmap_local(). Use set_pte() like the original MIPS highmem implementation did. Link: https://lkml.kernel.org/r/20210112170411.187513575@linutronix.de Fixes: a4c33e83bca1 ("mips/mm/highmem: Switch to generic kmap atomic") Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reported-by: Paul Cercueil <paul@crapouillou.net> Reported-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Andreas Larsson <andreas@gaisler.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2021-01-24sparc/mm/highmem: flush cache and TLBThomas Gleixner
Patch series "mm/highmem: Fix fallout from generic kmap_local conversions". The kmap_local conversion wreckaged sparc, mips and powerpc as it missed some of the details in the original implementation. This patch (of 4): The recent conversion to the generic kmap_local infrastructure failed to assign the proper pre/post map/unmap flush operations for sparc. Sparc requires cache flush before map/unmap and tlb flush afterwards. Link: https://lkml.kernel.org/r/20210112170136.078559026@linutronix.de Link: https://lkml.kernel.org/r/20210112170410.905976187@linutronix.de Fixes: 3293efa97807 ("sparc/mm/highmem: Switch to generic kmap atomic") Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reported-by: Andreas Larsson <andreas@gaisler.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Cercueil <paul@crapouillou.net> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2021-01-24Merge tag 'sched_urgent_for_v5.11_rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Borislav Petkov: - Correct the marking of kthreads which are supposed to run on a specific, single CPU vs such which are affine to only one CPU, mark per-cpu workqueue threads as such and make sure that marking "survives" CPU hotplug. Fix CPU hotplug issues with such kthreads. - A fix to not push away tasks on CPUs coming online. - Have workqueue CPU hotplug code use cpu_possible_mask when breaking affinity on CPU offlining so that pending workers can finish on newly arrived onlined CPUs too. - Dump tasks which haven't vacated a CPU which is currently being unplugged. - Register a special scale invariance callback which gets called on resume from RAM to read out APERF/MPERF after resume and thus make the schedutil scaling governor more precise. * tag 'sched_urgent_for_v5.11_rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Relax the set_cpus_allowed_ptr() semantics sched: Fix CPU hotplug / tighten is_per_cpu_kthread() sched: Prepare to use balance_push in ttwu() workqueue: Restrict affinity change to rescuer workqueue: Tag bound workers with KTHREAD_IS_PER_CPU kthread: Extract KTHREAD_IS_PER_CPU sched: Don't run cpu-online with balance_push() enabled workqueue: Use cpu_possible_mask instead of cpu_active_mask to break affinity sched/core: Print out straggler tasks in sched_cpu_dying() x86: PM: Register syscore_ops for scale invariance
2021-01-24Merge tag 'x86_urgent_for_v5.11_rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Borislav Petkov: - Add a new Intel model number for Alder Lake - Differentiate which aspects of the FPU state get saved/restored when the FPU is used in-kernel and fix a boot crash on K7 due to early MXCSR access before CR4.OSFXSR is even set. - A couple of noinstr annotation fixes - Correct die ID setting on AMD for users of topology information which need the correct die ID - A SEV-ES fix to handle string port IO to/from kernel memory properly * tag 'x86_urgent_for_v5.11_rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/cpu: Add another Alder Lake CPU to the Intel family x86/mmx: Use KFPU_387 for MMX string operations x86/fpu: Add kernel_fpu_begin_mask() to selectively initialize state x86/topology: Make __max_die_per_package available unconditionally x86: __always_inline __{rd,wr}msr() x86/mce: Remove explicit/superfluous tracing locking/lockdep: Avoid noinstr warning for DEBUG_LOCKDEP locking/lockdep: Cure noinstr fail x86/sev: Fix nonistr violation x86/entry: Fix noinstr fail x86/cpu/amd: Set __max_die_per_package on AMD x86/sev-es: Handle string port IO to kernel memory properly
2021-01-24Merge tag 'powerpc-5.11-5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: - Fix a bad interaction between the scv handling and the fallback L1D flush, which could lead to user register corruption. Only affects people using scv (~no one) on machines with old firmware that are missing the L1D flush. - Two small selftest fixes. Thanks to Eirik Fuller, Libor Pechacek, Nicholas Piggin, Sandipan Das, and Tulio Magno Quites Machado Filho. * tag 'powerpc-5.11-5' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc/64s: fix scv entry fallback flush vs interrupt selftests/powerpc: Only test lwm/stmw on big endian selftests/powerpc: Fix exit status of pkey tests
2021-01-24x86/setup: don't remove E820_TYPE_RAM for pfn 0Mike Rapoport
Patch series "mm: fix initialization of struct page for holes in memory layout", v3. Commit 73a6e474cb37 ("mm: memmap_init: iterate over memblock regions rather that check each PFN") exposed several issues with the memory map initialization and these patches fix those issues. Initially there were crashes during compaction that Qian Cai reported back in April [1]. It seemed back then that the problem was fixed, but a few weeks ago Andrea Arcangeli hit the same bug [2] and there was an additional discussion at [3]. [1] https://lore.kernel.org/lkml/8C537EB7-85EE-4DCF-943E-3CC0ED0DF56D@lca.pw [2] https://lore.kernel.org/lkml/20201121194506.13464-1-aarcange@redhat.com [3] https://lore.kernel.org/mm-commits/20201206005401.qKuAVgOXr%akpm@linux-foundation.org This patch (of 2): The first 4Kb of memory is a BIOS owned area and to avoid its allocation for the kernel it was not listed in e820 tables as memory. As the result, pfn 0 was never recognised by the generic memory management and it is not a part of neither node 0 nor ZONE_DMA. If set_pfnblock_flags_mask() would be ever called for the pageblock corresponding to the first 2Mbytes of memory, having pfn 0 outside of ZONE_DMA would trigger VM_BUG_ON_PAGE(!zone_spans_pfn(page_zone(page), pfn), page); Along with reserving the first 4Kb in e820 tables, several first pages are reserved with memblock in several places during setup_arch(). These reservations are enough to ensure the kernel does not touch the BIOS area and it is not necessary to remove E820_TYPE_RAM for pfn 0. Remove the update of e820 table that changes the type of pfn 0 and move the comment describing why it was done to trim_low_memory_range() that reserves the beginning of the memory. Link: https://lkml.kernel.org/r/20210111194017.22696-2-rppt@kernel.org Signed-off-by: Mike Rapoport <rppt@linux.ibm.com> Cc: Baoquan He <bhe@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: David Hildenbrand <david@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Michal Hocko <mhocko@kernel.org> Cc: Qian Cai <cai@lca.pw> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2021-01-24powerpc/64s: prevent recursive replay_soft_interrupts causing superfluous ↵Nicholas Piggin
interrupt When an asynchronous interrupt calls irq_exit, it checks for softirqs that may have been created, and runs them. Running softirqs enables local irqs, which can replay pending interrupts causing recursion in replay_soft_interrupts. This abridged trace shows how this can occur: ! NIP replay_soft_interrupts LR interrupt_exit_kernel_prepare Call Trace: interrupt_exit_kernel_prepare (unreliable) interrupt_return --- interrupt: ea0 at __rb_reserve_next NIP __rb_reserve_next LR __rb_reserve_next Call Trace: ring_buffer_lock_reserve trace_function function_trace_call ftrace_call __do_softirq irq_exit timer_interrupt ! replay_soft_interrupts interrupt_exit_kernel_prepare interrupt_return --- interrupt: ea0 at arch_local_irq_restore This can not be prevented easily, because softirqs must not block hard irqs, so it has to be dealt with. The recursion is bounded by design in the softirq code because softirq replay disables softirqs and loops around again to check for new softirqs created while it ran, so that's not a problem. However it does mess up interrupt replay state, causing superfluous interrupts when the second replay_soft_interrupts clears a pending interrupt, leaving it still set in the first call in the 'happened' local variable. Fix this by not caching a copy of irqs_happened across interrupt handler calls. Fixes: 3282a3da25bd ("powerpc/64: Implement soft interrupt replay in C") Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Link: https://lore.kernel.org/r/20210123061244.2076145-1-npiggin@gmail.com
2021-01-22riscv: Fixup pfn_valid error with wrong max_mapnrGuo Ren
The max_mapnr is the number of PFNs, not absolute PFN offset. Signed-off-by: Guo Ren <guoren@linux.alibaba.com> Fixes: d0d8aae64566 ("RISC-V: Set maximum number of mapped pages correctly") Cc: stable@vger.kernel.org Signed-off-by: Palmer Dabbelt <palmerdabbelt@google.com>
2021-01-22Merge tag 'imx-fixes-5.11-2' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into arm/fixes i.MX fixes for 5.11, round 2: - Fix pcf2127 reset for imx7d-flex-concentrator board. - Fix i.MX6 suspend with Thumb-2 kernel. - Fix ethernet-phy address issue on imx6qdl-sr-som board. - Fix GPIO3 `gpio-ranges` on i.MX8MP. - Select SOC_BUS for IMX_SCU driver to fix build issue. * tag 'imx-fixes-5.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: firmware: imx: select SOC_BUS to fix firmware build arm64: dts: imx8mp: Correct the gpio ranges of gpio3 ARM: dts: imx6qdl-sr-som: fix some cubox-i platforms ARM: imx: build suspend-imx6.S with arm instruction set ARM: dts: imx7d-flex-concentrator: fix pcf2127 reset Link: https://lore.kernel.org/r/20210119091949.GD4356@dragon Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2021-01-22arm64: dts: broadcom: Fix USB DMA address translation for StingrayBharat Gooty
Add a non-empty dma-ranges so that DMA address translation happens. Fixes: 2013a4b684b6 ("arm64: dts: broadcom: clear the warnings caused by empty dma-ranges") Signed-off-by: Bharat Gooty <bharat.gooty@broadcom.com> Signed-off-by: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Ray Jui <ray.jui@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2021-01-22Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - Correctly mask out bits 63:60 in a kernel tag check fault address (specified as unknown by the architecture). Previously they were just zeroed but for kernel pointers they need to be all ones. - Fix a panic (unexpected kernel BRK exception) caused by kprobes being reentered due to an interrupt. * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: kprobes: Fix Uexpected kernel BRK exception at EL1 kasan, arm64: fix pointer tags in KASAN reports
2021-01-22arm64: kprobes: Fix Uexpected kernel BRK exception at EL1Qais Yousef
I was hitting the below panic continuously when attaching kprobes to scheduler functions [ 159.045212] Unexpected kernel BRK exception at EL1 [ 159.053753] Internal error: BRK handler: f2000006 [#1] PREEMPT SMP [ 159.059954] Modules linked in: [ 159.063025] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.11.0-rc4-00008-g1e2a199f6ccd #56 [rt-app] <notice> [1] Exiting.[ 159.071166] Hardware name: ARM Juno development board (r2) (DT) [ 159.079689] pstate: 600003c5 (nZCv DAIF -PAN -UAO -TCO BTYPE=--) [ 159.085723] pc : 0xffff80001624501c [ 159.089377] lr : attach_entity_load_avg+0x2ac/0x350 [ 159.094271] sp : ffff80001622b640 [rt-app] <notice> [0] Exiting.[ 159.097591] x29: ffff80001622b640 x28: 0000000000000001 [ 159.105515] x27: 0000000000000049 x26: ffff000800b79980 [ 159.110847] x25: ffff00097ef37840 x24: 0000000000000000 [ 159.116331] x23: 00000024eacec1ec x22: ffff00097ef12b90 [ 159.121663] x21: ffff00097ef37700 x20: ffff800010119170 [rt-app] <notice> [11] Exiting.[ 159.126995] x19: ffff00097ef37840 x18: 000000000000000e [ 159.135003] x17: 0000000000000001 x16: 0000000000000019 [ 159.140335] x15: 0000000000000000 x14: 0000000000000000 [ 159.145666] x13: 0000000000000002 x12: 0000000000000002 [ 159.150996] x11: ffff80001592f9f0 x10: 0000000000000060 [ 159.156327] x9 : ffff8000100f6f9c x8 : be618290de0999a1 [ 159.161659] x7 : ffff80096a4b1000 x6 : 0000000000000000 [ 159.166990] x5 : ffff00097ef37840 x4 : 0000000000000000 [ 159.172321] x3 : ffff000800328948 x2 : 0000000000000000 [ 159.177652] x1 : 0000002507d52fec x0 : ffff00097ef12b90 [ 159.182983] Call trace: [ 159.185433] 0xffff80001624501c [ 159.188581] update_load_avg+0x2d0/0x778 [ 159.192516] enqueue_task_fair+0x134/0xe20 [ 159.196625] enqueue_task+0x4c/0x2c8 [ 159.200211] ttwu_do_activate+0x70/0x138 [ 159.204147] sched_ttwu_pending+0xbc/0x160 [ 159.208253] flush_smp_call_function_queue+0x16c/0x320 [ 159.213408] generic_smp_call_function_single_interrupt+0x1c/0x28 [ 159.219521] ipi_handler+0x1e8/0x3c8 [ 159.223106] handle_percpu_devid_irq+0xd8/0x460 [ 159.227650] generic_handle_irq+0x38/0x50 [ 159.231672] __handle_domain_irq+0x6c/0xc8 [ 159.235781] gic_handle_irq+0xcc/0xf0 [ 159.239452] el1_irq+0xb4/0x180 [ 159.242600] rcu_is_watching+0x28/0x70 [ 159.246359] rcu_read_lock_held_common+0x44/0x88 [ 159.250991] rcu_read_lock_any_held+0x30/0xc0 [ 159.255360] kretprobe_dispatcher+0xc4/0xf0 [ 159.259555] __kretprobe_trampoline_handler+0xc0/0x150 [ 159.264710] trampoline_probe_handler+0x38/0x58 [ 159.269255] kretprobe_trampoline+0x70/0xc4 [ 159.273450] run_rebalance_domains+0x54/0x80 [ 159.277734] __do_softirq+0x164/0x684 [ 159.281406] irq_exit+0x198/0x1b8 [ 159.284731] __handle_domain_irq+0x70/0xc8 [ 159.288840] gic_handle_irq+0xb0/0xf0 [ 159.292510] el1_irq+0xb4/0x180 [ 159.295658] arch_cpu_idle+0x18/0x28 [ 159.299245] default_idle_call+0x9c/0x3e8 [ 159.303265] do_idle+0x25c/0x2a8 [ 159.306502] cpu_startup_entry+0x2c/0x78 [ 159.310436] secondary_start_kernel+0x160/0x198 [ 159.314984] Code: d42000c0 aa1e03e9 d42000c0 aa1e03e9 (d42000c0) After a bit of head scratching and debugging it turned out that it is due to kprobe handler being interrupted by a tick that causes us to go into (I think another) kprobe handler. The culprit was kprobe_breakpoint_ss_handler() returning DBG_HOOK_ERROR which leads to the Unexpected kernel BRK exception. Reverting commit ba090f9cafd5 ("arm64: kprobes: Remove redundant kprobe_step_ctx") seemed to fix the problem for me. Further analysis showed that kcb->kprobe_status is set to KPROBE_REENTER when the error occurs. By teaching kprobe_breakpoint_ss_handler() to handle this status I can no longer reproduce the problem. Fixes: ba090f9cafd5 ("arm64: kprobes: Remove redundant kprobe_step_ctx") Signed-off-by: Qais Yousef <qais.yousef@arm.com> Acked-by: Will Deacon <will@kernel.org> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Link: https://lore.kernel.org/r/20210122110909.3324607-1-qais.yousef@arm.com Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2021-01-21Merge tag 'for-linus' of git://github.com/openrisc/linuxLinus Torvalds
Pull OpenRISC fixes from Stafford Horne: - Compiler warning fixup for new Litex SoC driver - Sparse warning fixup for iounmap * tag 'for-linus' of git://github.com/openrisc/linux: openrisc: io: Add missing __iomem annotation to iounmap() soc: litex: Fix compile warning when device tree is not configured
2021-01-21x86/cpu: Add another Alder Lake CPU to the Intel familyGayatri Kammela
Add Alder Lake mobile CPU model number to Intel family. Signed-off-by: Gayatri Kammela <gayatri.kammela@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Borislav Petkov <bp@suse.de> Link: https://lkml.kernel.org/r/20210121215004.11618-1-tony.luck@intel.com
2021-01-21x86/mmx: Use KFPU_387 for MMX string operationsAndy Lutomirski
The default kernel_fpu_begin() doesn't work on systems that support XMM but haven't yet enabled CR4.OSFXSR. This causes crashes when _mmx_memcpy() is called too early because LDMXCSR generates #UD when the aforementioned bit is clear. Fix it by using kernel_fpu_begin_mask(KFPU_387) explicitly. Fixes: 7ad816762f9b ("x86/fpu: Reset MXCSR to default in kernel_fpu_begin()") Reported-by: Krzysztof Mazur <krzysiek@podlesie.net> Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Borislav Petkov <bp@suse.de> Tested-by: Krzysztof Piotr Olędzki <ole@ans.pl> Tested-by: Krzysztof Mazur <krzysiek@podlesie.net> Cc: <stable@vger.kernel.org> Link: https://lkml.kernel.org/r/e7bf21855fe99e5f3baa27446e32623358f69e8d.1611205691.git.luto@kernel.org
2021-01-21x86/fpu: Add kernel_fpu_begin_mask() to selectively initialize stateAndy Lutomirski
Currently, requesting kernel FPU access doesn't distinguish which parts of the extended ("FPU") state are needed. This is nice for simplicity, but there are a few cases in which it's suboptimal: - The vast majority of in-kernel FPU users want XMM/YMM/ZMM state but do not use legacy 387 state. These users want MXCSR initialized but don't care about the FPU control word. Skipping FNINIT would save time. (Empirically, FNINIT is several times slower than LDMXCSR.) - Code that wants MMX doesn't want or need MXCSR initialized. _mmx_memcpy(), for example, can run before CR4.OSFXSR gets set, and initializing MXCSR will fail because LDMXCSR generates an #UD when the aforementioned CR4 bit is not set. - Any future in-kernel users of XFD (eXtended Feature Disable)-capable dynamic states will need special handling. Add a more specific API that allows callers to specify exactly what they want. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Borislav Petkov <bp@suse.de> Tested-by: Krzysztof Piotr Olędzki <ole@ans.pl> Link: https://lkml.kernel.org/r/aff1cac8b8fc7ee900cf73e8f2369966621b053f.1611205691.git.luto@kernel.org
2021-01-21KVM: arm64: Filter out v8.1+ events on v8.0 HWMarc Zyngier
When running on v8.0 HW, make sure we don't try to advertise events in the 0x4000-0x403f range. Cc: stable@vger.kernel.org Fixes: 88865beca9062 ("KVM: arm64: Mask out filtered events in PCMEID{0,1}_EL1") Signed-off-by: Marc Zyngier <maz@kernel.org> Link: https://lore.kernel.org/r/20210121105636.1478491-1-maz@kernel.org
2021-01-21KVM: arm64: Compute TPIDR_EL2 ignoring MTE tagSteven Price
KASAN in HW_TAGS mode will store MTE tags in the top byte of the pointer. When computing the offset for TPIDR_EL2 we don't want anything in the top byte, so remove the tag to ensure the computation is correct no matter what the tag. Fixes: 94ab5b61ee16 ("kasan, arm64: enable CONFIG_KASAN_HW_TAGS") Signed-off-by: Steven Price <steven.price@arm.com> [maz: added comment] Signed-off-by: Marc Zyngier <maz@kernel.org> Link: https://lore.kernel.org/r/20210108161254.53674-1-steven.price@arm.com
2021-01-20Merge tag 'for-linus-5.11-rc5-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen fix from Juergen Gross: "A fix for build failure showing up in some configurations" * tag 'for-linus-5.11-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: x86/xen: fix 'nopvspin' build error
2021-01-20powerpc/64s: fix scv entry fallback flush vs interruptNicholas Piggin
The L1D flush fallback functions are not recoverable vs interrupts, yet the scv entry flush runs with MSR[EE]=1. This can result in a timer (soft-NMI) or MCE or SRESET interrupt hitting here and overwriting the EXRFI save area, which ends up corrupting userspace registers for scv return. Fix this by disabling RI and EE for the scv entry fallback flush. Fixes: f79643787e0a0 ("powerpc/64s: flush L1D on kernel entry") Cc: stable@vger.kernel.org # 5.9+ which also have flush L1D patch backport Reported-by: Tulio Magno Quites Machado Filho <tuliom@linux.ibm.com> Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Link: https://lore.kernel.org/r/20210111062408.287092-1-npiggin@gmail.com
