path: root/arch
2006-07-11[ARM] 3727/1: fix ucb initialization on colliePavel Machek
Patch from Pavel Machek From: Dirk Opfer <Dirk@Opfer-Online.de> Fix ucb initialization on collie. Wrong frequency was used and that led to things not working quite correctly. (I had to actually disable checks in my tree to get it to boot). It now includes all the neccessary parts to get it to compile :-). Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-11[ARM] Allow Versatile to be built for AB and PBRussell King
If a configuration was chosen to support both the Versatile AB and PB boards, the result would write to registers not available on the PB version of the board. Resolve this by using machine_is_xxx(). Also, for the CLCD, despite how the code looks, both the AB and PB access the same location to control the clock rate - it's just called something different between the two board versions. Invent our own name for this location and use it unconditionally. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-11[ARM] 3726/1: update {ep93xx,ixp2000,ixp23xx,lpd270,onearm} defconfigs to ↵Lennert Buytenhek
2.6.18-rc1 Patch from Lennert Buytenhek Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-11[ARM] 3721/1: Small cleanup for locomo.cPavel Machek
Patch from Pavel Machek Cleanup locomo.c. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-10[PATCH] x86_64: Fix access check in ptrace compatAndi Kleen
We can't safely directly access an compat_alloc_user_space() pointer with the siginfo copy functions. Bounce it through the stack. Noticed by Al Viro using sparse [ This was only added post 2.6.17, not in any released kernel ] Cc: Al Viro <viro@ftp.linux.org.uk> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] x86_64: Allow oprofile for model P4 modelsAndi Kleen
Add it for P4 model 6 - reported to work and have a similar PMU to earlier P4s. Add an p4force=1 module override parameter for future use. We had a discussion about that earlier - it's a trade off between the PMU staying compatible or not. I think the force parameter is a reasonable compromise. Cc: oprofile-list@lists.sf.net Cc: Asit Mallick <asit.k.mallick@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] x86_64: Fix Calgary copyright statements per IBM guidelinesMuli Ben-Yehuda
Signed-off-by: Muli Ben-Yehuda <muli@il.ibm.com> Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] x86_64: Fix hotplug problem in mce amdJacob Shin
Signed-off-by: Jacob Shin <jacob.shin@amd.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] x86_64: Bring x86-64 ia32 emul in sync with i386 on ↵Markus Schoder
READ_IMPLIES_EXEC enabling Currently ia32 binaries behave differently with respect to enabling READ_IMPLIES_EXEC. On i386 a binary with the exec_stack flag set is executed with READ_IMPLIES_EXEC enabled as well. The same binary executes without READ_IMPLIES_EXEC on x86-64. This causes binaries that work on i386 to fail on x86-64 which goes somewhat against the whole 32 bit emulation idea. It has been argued that READ_IMPLIES_EXEC should not be enabled at all for binaries that have the exec_stack flag. Which is probably a valid point. However until this is clarified I think x86-64 should behave the same for ia32 binaries as i386. The following patch brings x86-64 in sync with i386 for ia32 binaries. Signed-off-by: Markus Schoder <lists@gammarayburst.de> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] x86_64: Update defconfigAndi Kleen
2006-07-10[PATCH] s390: remove BINFMT_ELF32 config optionHeiko Carstens
Remove BINFMT_ELF32 config option. Support should be always compiled in if CONFIG_COMPAT is set. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] disallow modular binfmt_elf32Christoph Hellwig
Currently most architectures either always build binfmt_elf32 in the kernel image or make it a boolean option. Only sparc64 and s390 allow to build it modularly. This patch turns the option into a boolean aswell because elf requires various symbols that shouldn't be available to modules. The most urgent one is tasklist_lock whos export this patch series kills, but there are others like force_sgi aswell. Note that sparc doesn't allow a modular 32bit a.out handler either, and that would be the more useful case as only few people want 32bit sunos compatibility and 99.9% of all sparc64 users need 32bit linux native elf support. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] make valid_mmap_phys_addr_range() take a pfnLennert Buytenhek
Newer ARMs have a 40 bit physical address space, but mapping physical memory above 4G needs a special page table format which we (currently?) do not use for userspace mappings, so what happens instead is that mapping an address >= 4G will happily discard the upper bits and wrap. There is a valid_mmap_phys_addr_range() arch hook where we could check for >= 4G addresses and deny the mapping, but this hook takes an unsigned long address: static inline int valid_mmap_phys_addr_range(unsigned long addr, size_t size); And drivers/char/mem.c:mmap_mem() calls it like this: static int mmap_mem(struct file * file, struct vm_area_struct * vma) { size_t size = vma->vm_end - vma->vm_start; if (!valid_mmap_phys_addr_range(vma->vm_pgoff << PAGE_SHIFT, size)) So that's not much help either. This patch makes the hook take a pfn instead of a phys address. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: make mconsole version requests happen in a processJeff Dike
Handling a host mconsole version request must be done in a process context rather than interrupt context now that utsname information can be process-specific rather than global. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove unused variableJeff Dike
The dedevfsification of UML left an unused variable behind. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: add some EINTR protectionJeff Dike
Add some more uses of the CATCH_EINTR wrapper. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: formatting fixesJeff Dike
Fix a bunch of formatting problems. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: move _kern.c filesJeff Dike
Move most *_kern.c files in arch/um/kernel to *.c. This makes UML somewhat more closely resemble the other arches. [akpm@osdl.org: use the new INTF_* flags] Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove syscall debuggingJeff Dike
Eliminate an unused debug option. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: make some symbols staticJeff Dike
A few sigio-related things can be made static. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: fix exitcall ordering bugJeff Dike
This fixes an exitcall ordering bug - calls to ignore_sigio_fd can come from exitcalls that come after the sigio thread has been killed. This would cause shutdown to hang or crash. Fixed by having ignore_sigio_fd check that the thread is present before trying to communicate with it. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove os_isattyJeff Dike
os_isatty can be made to disappear by moving maybe_sigio_broken from kernel to user code. This also lets write_sigio_workaround become static. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove spinlock wrapper functionsJeff Dike
The irq_spinlock is not needed from user code any more, so the irq_lock and irq_unlock wrappers can go away. This also changes the name of the lock to irq_lock. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: mark forward_interrupts as being mode-specificJeff Dike
Mark forward_interrupts as being tt-mode only. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: ifdef a mode-specific functionJeff Dike
uml_idle_timer is tt-mode only, so ifdef it as such to make it easier to spot when tt mode is killed. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: timer handler tidyingJeff Dike
Get rid of a user of timer_irq_inited (and first_tick) by observing that prev_ticks can be used to decide if this is the first call. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: signal initialization cleanupJeff Dike
It turns out that init_new_thread_signals is always called with altstack == 1, so we can eliminate the parameter. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove useless declarationJeff Dike
wall_to_monotonic isn't used in this file, so we can remove the declaration. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: fix static binary segfaultJeff Dike
When UML is built as a static binary, it segfaults when run. The reason is that a memory hole that is present in dynamic binaries isn't there in static binaries, and it contains essential stuff. This fix removes the code which maps some anonymous memory into that hole and cleans up some related code. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: remove some useless exportsJeff Dike
Spotted by Al Viro - eliminate a couple useless exports. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: timer initialization cleanupJeff Dike
This cleans up the mess that is the timer initialization. There used to be two timer handlers - one that basically ran during delay loop calibration and one that handled the timer afterwards. There were also two sets of timer initialization code - one that starts in user code and calls into the kernel side of the house, and one that starts in kernel code and calls user code. This eliminates one timer handler and consolidates the two sets of initialization code. [akpm@osdl.org: use new INTF_ flags] Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] uml: clean up address space limits codeTyler
I was looking at the code of the UML and more precisely at the functions set_task_sizes_tt and set_task_sizes_skas. I noticed that these 2 functions take a paramater (arg) which is not used : the function is always called with the value 0. I suppose that this value might change in the future (or even can be configured), so I added a constant in mem_user.h file. Also, I rounded CONFIG_HOST_TASk_SIZE to a 4M. Signed-off-by: Tyler <tyler@agat.net> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] pcf8563: remove MOD_INC_USE_COUNT, MOD_DEC_USE_COUNTIrwan Djajadi
It already has .owner. Signed-off-by: Irwan Djajadi <irwan.djajadi@iname.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] cris: switch to iminor/imajorEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] get_cmos_time() locking fix (lockdep)Andrew Morton
rtc_lock is supposed to be irq-safe. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] i386 defconfig: set CONFIG_PM_STD_PARTITION=""Adrian Bunk
Matthew Wilcox notified me that CONFIG_PM_STD_PARTITION="/dev/hda2" in the i386 defconfig wasn't a good idea (especially since it prevented booting for him due to another bug). This patch sets CONFIG_PM_STD_PARTITION="" in the i386 defconfig. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FRV: Introduce asm-offsets for FRV archDavid Howells
Introduce the use of asm-offsets into the FRV architecture. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FDPIC: Add coredump capability for the ELF-FDPIC binfmtDavid Howells
Add coredump capability for the ELF-FDPIC binfmt. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FDPIC: Move roundup() into linux/kernel.hDavid Howells
Move the roundup() macro from binfmt_elf.c into linux/kernel.h as it's generally useful. [akpm@osdl.org: nuke all the other implementations] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] FRV: Fix FRV arch compile errorsDavid Howells
Fix some FRV arch compile errors, including: (*) Marking nr_kernel_pages as __meminitdata so that references to it end up being properly calculated rather than being assumed to be in the small data section (and thus calculated wrt the GP register). Not doing this causes the linker to emit errors as the offset is too big to fit into the load instruction. (*) Move pm_power_off into an unconditionally compiled .c file as it's now unconditionally accessed. (*) Declare frv_change_cmode() in a header file rather than in a .c file, and declare it asmlinkage. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] powermac: Combined fixes for backlight codeMichael Hanselmann
This patch fixes several problems: - pmac_backlight_key() is called under interrupt context, and therefore can't use mutexes or semaphores, so defer the backlight level for later, as it's not critical (original code by Aristeu S. Rozanski F. <aris@valeta.org>). - Add exports for functions that might be called from modules - Fix Kconfig depdencies on PMAC_BACKLIGHT. - Fix locking issues on calls from inside the driver (reported by Aristeu S. Rozanski F., too) - Fix wrong calculation of backlight values in some of the drivers - Replace pmac_backlight_key_up/down by inline functions [akpm@osdl.org: fix function prototypes] Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Aristeu S. Rozanski F. <aris@valeta.org> Acked-by: Rene Nussbaumer <linux-kernel@killerfox.forkbomb.ch> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] powerpc: make OF interrupt tree parsing more strictSegher Boessenkool
This patch fixes a bit of boundchecking in the new Open Firmware interrupt tree parsing code. It's important that it fails when things aren't correct in order to trigger fallback mecanisms that are necessary to make some machines work properly. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] powerpc: fix MPIC OF tree parsing on Apple quad g5Benjamin Herrenschmidt
The quad g5 currently doesn't boot due to two problems. This patch fixes the first one: Apple new way of doing interrupt specifiers in OF for devices using the HT APIC isn't properly parsed by the new MPIC driver code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] powerpc: fix trigger handling in the new irq codeBenjamin Herrenschmidt
This patch slightly reworks the new irq code to fix a small design error. I removed the passing of the trigger to the map() calls entirely, it was not a good idea to have one call do two different things. It also fixes a couple of corner cases. Mapping a linux virtual irq to a physical irq now does only that. Setting the trigger is a different action which has a different call. The main changes are: - I no longer call host->ops->map() for an already mapped irq, I just return the virtual number that was already mapped. It was called before to give an opportunity to change the trigger, but that was causing issues as that could happen while the interrupt was in use by a device, and because of the trigger change, map would potentially muck around with things in a racy way. That was causing much burden on a given's controller implementation of map() to get it right. This is much simpler now. map() is only called on the initial mapping of an irq, meaning that you know that this irq is _not_ being used. You can initialize the hardware if you want (though you don't have to). - Controllers that can handle different type of triggers (level/edge/etc...) now implement the standard irq_chip->set_type() call as defined by the generic code. That means that you can use the standard set_irq_type() to configure an irq line manually if you wish or (though I don't like that interface), pass explicit trigger flags to request_irq() as defined by the generic kernel interfaces. Also, using those interfaces guarantees that your controller set_type callback is called with the descriptor lock held, thus providing locking against activity on the same interrupt (including mask/unmask/etc...) automatically. A result is that, for example, MPIC's own map() implementation calls irq_set_type(NONE) to configure the hardware to the default triggers. - To allow the above, the irq_map array entry for the new mapped interrupt is now set before map() callback is called for the controller. - The irq_create_of_mapping() (also used by irq_of_parse_and_map()) function for mapping interrupts from the device-tree now also call the separate set_irq_type(), and only does so if there is a change in the trigger type. - While I was at it, I changed pci_read_irq_line() (which is the helper I would expect most archs to use in their pcibios_fixup() to get the PCI interrupt routing from the device tree) to also handle a fallback when the DT mapping fails consisting of reading the PCI_INTERRUPT_PIN to know wether the device has an interrupt at all, and the the PCI_INTERRUPT_LINE to get an interrupt number from the device. That number is then mapped using the default controller, and the trigger is set to level low. That default behaviour works for several platforms that don't have a proper interrupt tree like Pegasos. If it doesn't work for your platform, then either provide a proper interrupt tree from the firmware so that fallback isn't needed, or don't call pci_read_irq_line() - Add back a bit that got dropped by my main rework patch for properly clearing pending IPIs on pSeries when using a kexec Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] put a comment at register_die_notifier that the export is usedArjan van de Ven
{un}register_die_notifier() is used by kdb... document this so that future "remove dead export" rounds can skip this export. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] lockdep: clean up completion initializer in smpboot.cIngo Molnar
Clean up lockdep on-stack-completion initializer. (This also removes the dependency on waitqueue_lock_key.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] x86_64: e820.c needs pgtable.hAndrew Morton
arch/x86_64/kernel/e820.c:42: error: 'MAXMEM' undeclared here (not in a function) Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-09[PATCH] i386: use thread_info flags for debug regs and IO bitmapsStephane Eranian
Use thread info flags to track use of debug registers and IO bitmaps. - add TIF_DEBUG to track when debug registers are active - add TIF_IO_BITMAP to track when I/O bitmap is used - modify __switch_to() to use the new TIF flags Performance tested on Pentium II, ten runs of LMbench context switch benchmark (smaller is better:) before after avg 3.65 3.39 min 3.55 3.33 Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
