commit 1a5a9906d4e8d1976b701f889d8f35d54b928f25 upstream.
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
[akpm@linux-foundation.org: checkpatch fixes]
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: Mark Salter <msalter@redhat.com>
commit 73d63d038ee9f769f5e5b46792d227fe20e442c5 upstream.
With the recent changes to clear_IO_APIC_pin() which tries to
clear remoteIRR bit explicitly, some of the users started to see
"Unable to reset IRR for apic .." messages.
Close look shows that these are related to bogus IO-APIC entries
which return's all 1's for their io-apic registers. And the
above mentioned error messages are benign. But kernel should
have ignored such io-apic's in the first place.
Check if register 0, 1, 2 of the listed io-apic are all 1's and
ignore such io-apic.
Reported-by: Álvaro Castillo <midgoon@gmail.com>
Tested-by: Jon Dufresne <jon@jondufresne.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: yinghai@kernel.org
Cc: kernel-team@fedoraproject.org
Cc: Josh Boyer <jwboyer@redhat.com>
Link: http://lkml.kernel.org/r/1331577393.31585.94.camel@sbsiddha-desk.sc.intel.com
[ Performed minor cleanup of affected code. ]
commit 78c5c68a4cf4329d17abfa469345ddf323d4fd62 upstream.
The code for "powersurge" SMP would kick in and cause a crash
at boot due to the lack of a NULL test.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Reported-by: Adam Conrad <adconrad@ubuntu.com>
Tested-by: Adam Conrad <adconrad@ubuntu.com>
commit e0adb9902fb338a9fe634c3c2a3e474075c733ba upstream.
Newer version of binutils are more strict about specifying the
correct options to enable certain classes of instructions.
The sparc32 build is done for v7 in order to support sun4c systems
which lack hardware integer multiply and divide instructions.
So we have to pass -Av8 when building the assembler routines that
use these instructions and get patched into the kernel when we find
out that we have a v8 capable cpu.
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
commit 87e24f4b67e68d9fd8df16e0bf9c66d1ad2a2533 upstream.
Verified using the below proglet.. before:
[root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 0
remote write
Performance counter stats for './numa 0':
2,101,554 node-stores
2,096,931 node-store-misses
5.021546079 seconds time elapsed
[root@westmere ~]# perf stat -e node-stores -e node-store-misses ./numa 1
local write
Performance counter stats for './numa 1':
501,137 node-stores
199 node-store-misses
5.124451068 seconds time elapsed
After:
remote write
2,107,516 node-stores
2,097,187 node-store-misses
5.012755149 seconds time elapsed
local write
2,063,355 node-stores
165 node-store-misses
5.082091494 seconds time elapsed
#define _GNU_SOURCE
#include <sched.h>
#include <stdio.h>
#include <errno.h>
#include <sys/mman.h>
#include <sys/types.h>
#include <dirent.h>
#include <signal.h>
#include <unistd.h>
#include <numaif.h>
#include <stdlib.h>
#define SIZE (32*1024*1024)
volatile int done;
void sig_done(int sig)
done = 1;
int main(int argc, char **argv)
cpu_set_t *mask, *mask2;
size_t size;
int i, err, t;
int nrcpus = 1024;
char *mem;
unsigned long nodemask = 0x01; /* node 0 */
DIR *node;
struct dirent *de;
int read = 0;
int local = 0;
if (argc < 2) {
printf("usage: %s [0-3]\n", argv[0]);
printf(" bit0 - local/remote\n");
printf(" bit1 - read/write\n");
exit(0);
switch (atoi(argv[1])) {
case 0:
printf("remote write\n");
break;
case 1:
printf("local write\n");
local = 1;
break;
case 2:
printf("remote read\n");
read = 1;
break;
case 3:
printf("local read\n");
local = 1;
read = 1;
break;
mask = CPU_ALLOC(nrcpus);
size = CPU_ALLOC_SIZE(nrcpus);
CPU_ZERO_S(size, mask);
node = opendir("/sys/devices/system/node/node0/");
if (!node)
perror("opendir");
while ((de = readdir(node))) {
int cpu;
if (sscanf(de->d_name, "cpu%d", &cpu) == 1)
CPU_SET_S(cpu, size, mask);
closedir(node);
mask2 = CPU_ALLOC(nrcpus);
CPU_ZERO_S(size, mask2);
for (i = 0; i < size; i++)
CPU_SET_S(i, size, mask2);
CPU_XOR_S(size, mask2, mask2, mask); // invert
if (!local)
mask = mask2;
err = sched_setaffinity(0, size, mask);
if (err)
perror("sched_setaffinity");
mem = mmap(0, SIZE, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_ANONYMOUS, -1, 0);
err = mbind(mem, SIZE, MPOL_BIND, &nodemask, 8*sizeof(nodemask), MPOL_MF_MOVE);
if (err)
perror("mbind");
signal(SIGALRM, sig_done);
alarm(5);
if (!read) {
while (!done) {
for (i = 0; i < SIZE; i++)
mem[i] = 0x01;
} else {
while (!done) {
t += *(volatile char *)(mem + i);
return 0;
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-tq73sxus35xmqpojf7ootxgs@git.kernel.org
commit a7f4255f906f60f72e00aad2fb000939449ff32e upstream.
Commit f0fbf0abc093 ("x86: integrate delay functions") converted
delay_tsc() into a random delay generator for 64 bit. The reason is
that it merged the mostly identical versions of delay_32.c and
delay_64.c. Though the subtle difference of the result was:
static void delay_tsc(unsigned long loops)
- unsigned bclock, now;
+ unsigned long bclock, now;
Now the function uses rdtscl() which returns the lower 32bit of the
TSC. On 32bit that's not problematic as unsigned long is 32bit. On 64
bit this fails when the lower 32bit are close to wrap around when
bclock is read, because the following check
if ((now - bclock) >= loops)
break;
evaluated to true on 64bit for e.g. bclock = 0xffffffff and now = 0
because the unsigned long (now - bclock) of these values results in
0xffffffff00000001 which is definitely larger than the loops
value. That explains Tvortkos observation:
"Because I am seeing udelay(500) (_occasionally_) being short, and
that by delaying for some duration between 0us (yep) and 491us."
Make those variables explicitely u32 again, so this works for both 32
and 64 bit.
Reported-by: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
commit 134d12fae0bb8f3d60dc7440a9e1950bb5427167 upstream.
For some weird (freudian?) reason, commit 435792d "ARM: OMAP: make
iommu subsys_initcall to fix builtin omap3isp" unintentionally changed
the mailbox's initcall instead of the iommu's.
Fix that.
Reported-by: Fernando Guzman Lugo <fernando.lugo@ti.com>
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Joerg Roedel <Joerg.Roedel@amd.com>
Cc: Tony Lindgren <tony@atomide.com>
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
commit 3f31ae121348afd9ed39700ea2a63c17cd7eeed1 upstream.
xscale2 PMUs indicate overflow not via the PMU control register, but by
a separate overflow FLAG register instead.
This patch fixes the xscale2 PMU code to use this register to detect
to overflow and ensures that we clear any pending overflow when
disabling a counter.
commit f6f5a30c834135c9f2fa10400c59ebbdd9188567 upstream.
The PMU IRQ handlers in perf assume that if a counter has overflowed
then perf must be responsible. In the paranoid world of crazy hardware,
this could be false, so check that we do have a valid event before
attempting to dereference NULL in the interrupt path.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit 99c1745b9c76910e195889044f914b4898b7c9a5 upstream.
When disabling a counter on an ARMv7 PMU, we should also clear the
overflow flag in case an overflow occurred whilst stopping the counter.
This prevents a spurious overflow being picked up later and leading to
either false accounting or a NULL dereference.
Reported-by: Ming Lei <tom.leiming@gmail.com>
commit 5727347180ebc6b4a866fcbe00dcb39cc03acb37 upstream.
On ARM, the PMU does not stop counting after an overflow and therefore
IRQ latency affects the new counter value read by the kernel. This is
significant for non-sampling runs where it is possible for the new value
to overtake the previous one, causing the delta to be out by up to
max_period events.
Commit a737823d ("ARM: 6835/1: perf: ensure overflows aren't missed due
to IRQ latency") attempted to fix this problem by allowing interrupt
handlers to pass an overflow flag to the event update function, causing
the overflow calculation to assume that the counter passed through zero
when going from prev to new. Unfortunately, this doesn't work when
overflow occurs on the perf_task_tick path because we have the flag
cleared and end up computing a large negative delta.
This patch removes the overflow flag from armpmu_event_update and
instead limits the sample_period to half of the max_period for
non-sampling profiling runs.
Signed-off-by: Ming Lei <ming.lei@canonical.com>
commit efbc74ace95338484f8d732037b99c7c77098fce upstream.
Erratum #743622 affects all r2 variants of the Cortex-A9 processor, so
ensure that the workaround is applied regardless of the revision.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
commit c49d005b6cc8491fad5b24f82805be2d6bcbd3dd upstream.
A hardware bug in the OMAP4 HDMI PHY causes physical damage to the board
if the HDMI PHY is kept powered on when the cable is not connected.
This patch solves the problem by adding hot-plug-detection into the HDMI
IP driver. This is not a real HPD support in the sense that nobody else
than the IP driver gets to know about the HPD events, but is only meant
to fix the HW bug.
The strategy is simple: If the display device is turned off by the user,
the PHY power is set to OFF. When the display device is turned on by the
user, the PHY power is set either to LDOON or TXON, depending on whether
the HDMI cable is connected.
The reason to avoid PHY OFF when the display device is on, but the cable
is disconnected, is that when the PHY is turned OFF, the HDMI IP is not
"ticking" and thus the DISPC does not receive pixel clock from the HDMI
IP. This would, for example, prevent any VSYNCs from happening, and
would thus affect the users of omapdss. By using LDOON when the cable is
disconnected we'll avoid the HW bug, but keep the HDMI working as usual
from the user's point of view.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit aa74274b464d4aa24703963ac89a0ee942d5d267 upstream.
Both Panda and 4430SDP use GPIO 63 as HDMI hot-plug-detect. Configure
this GPIO in the board files.
commit 78a1ad8f12db70b8b0a4548b90704de08ee216ce upstream.
The HDMI GPIO pins LS_OE and CT_CP_HPD are not currently configured.
This patch configures them as output pins.
commit 7bb122d155f742fe2d79849090c825be7b4a247e upstream.
"hdmi_hpd" pin is muxed to INPUT and PULLUP, but the pin is not
currently used, and in the future when it is used, the pin is used as a
GPIO and is board specific, not an OMAP4 wide thing.
So remove the muxing for now.
commit 3932a32fcf5393f8be70ac99dc718ad7ad0a415b upstream.
The GPIO 60 on 4430sdp and Panda is not HPD GPIO, as currently marked in
the board files, but CT_CP_HPD, which is used to enable/disable HPD
functionality.
This patch renames the GPIO.
commit 575753e3bea3b67eef8e454fb87f719e3f7da599 upstream.
Instead of freeing the GPIOs individually, use gpio_free_array().
commit b06540371063f0f07aafc1d1ac5e974da85c973c upstream.
Patchset "ARM: orion: Refactor the MPP code common in the orion
platform" broke at least Orion5x based platforms. These platforms have
pins configured as GPIO when the selector is not 0x0. However the
common code assumes the selector is always 0x0 for a GPIO lines. It
then ignores the GPIO bits in the MPP definitions, resulting in that
Orion5x machines cannot correctly configure there GPIO lines.
The Fix removes the assumption that the selector is always 0x0.
In order that none GPIO configurations are correctly blocked,
Kirkwood and mv78xx0 MPP definitions are corrected to only set the
GPIO bits for GPIO configurations.
This third version, which does not contain any whitespace changes,
and is rebased on v3.3-rc2.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Acked-by: Nicolas Pitre <nico@linaro.org>
commit 72053353583230952c4b187e110e9da00dfc3afb upstream.
The patch "ARM: orion: Consolidate USB platform setup code.", commit
4fcd3f374a928081d391cd9a570afe3b2c692fdc broke USB on TS-7800 and
other orion5x boards, because the wrong type of PHY was being passed
to the EHCI driver in the platform data. Orion5x needs EHCI_PHY_ORION
and all the others want EHCI_PHY_NA.
Allow the mach- code to tell the generic plat-orion code which USB PHY
enum to place into the platform data.
Version 2: Rebase to v3.3-rc2.
Reported-by: Ambroz Bizjak <ambrop7@gmail.com>
Tested-by: Ambroz Bizjak <ambrop7@gmail.com>
commit 31e0017e6f6fb5cfdfaf932c1f98c9bef8d57688 upstream.
Enable use of the generic atomic64 implementation on AVR32 platforms.
Without this the kernel fails to build as the architecture does not
provide its version.
Signed-off-by: Fabio Baltieri <fabio.baltieri@gmail.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
commit 62aca403657fe30e5235c5331e9871e676d9ea0a upstream.
Michael Cree said:
: : I have noticed some user space problems (pulseaudio crashes in pthread
: : code, glibc/nptl test suite failures, java compiler freezes on SMP alpha
: : systems) that arise when using a 2.6.39 or later kernel on Alpha.
: : Bisecting between 2.6.38 and 2.6.39 (using glibc/nptl test suite as
: : criterion for good/bad kernel) eventually leads to:
: : 8d7718aa082aaf30a0b4989e1f04858952f941bc is the first bad commit
: : commit 8d7718aa082aaf30a0b4989e1f04858952f941bc
: : Author: Michel Lespinasse <walken@google.com>
: : Date: Thu Mar 10 18:50:58 2011 -0800
: : futex: Sanitize futex ops argument types
: : Change futex_atomic_op_inuser and futex_atomic_cmpxchg_inatomic
: : prototypes to use u32 types for the futex as this is the data type the
: : futex core code uses all over the place.
: : Looking at the commit I see there is a change of the uaddr argument in
: : the Alpha architecture specific code for futexes from int to u32, but I
: : don't see why this should cause a problem.
Richard Henderson said:
: futex_atomic_cmpxchg_inatomic(u32 *uval, u32 __user *uaddr,
: u32 oldval, u32 newval)
: : "r"(uaddr), "r"((long)oldval), "r"(newval)
: There is no 32-bit compare instruction. These are implemented by
: consistently extending the values to a 64-bit type. Since the
: load instruction sign-extends, we want to sign-extend the other
: quantity as well (despite the fact it's logically unsigned).
: So:
: - : "r"(uaddr), "r"((long)oldval), "r"(newval)
: + : "r"(uaddr), "r"((long)(int)oldval), "r"(newval)
: should do the trick.
Michael said:
: This fixes the glibc test suite failures and the pulseaudio related
: crashes, but it does not fix the java compiiler lockups that I was (and
: are still) observing. That is some other problem.
Reported-by: Michael Cree <mcree@orcon.net.nz>
Tested-by: Michael Cree <mcree@orcon.net.nz>
Acked-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Reviewed-by: Matt Turner <mattst88@gmail.com>
commit e39d40c65dfd8390b50c03482ae9e289b8a8f351 upstream.
s3c2410_dma_suspend suspends channels from 0 to dma_channels.
s3c2410_dma_resume resumes channels in reverse order. So
pointer should be decremented instead of being incremented.
Signed-off-by: Gusakov Andrey <dron0gus@gmail.com>
Reviewed-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
commit 1018faa6cf23b256bf25919ef203cd7c129f06f2 upstream.
It turned out that a performance counter on AMD does not
count at all when the GO or HO bit is set in the control
register and SVM is disabled in EFER.
This patch works around this issue by masking out the HO bit
in the performance counter control register when SVM is not
enabled.
The GO bit is not touched because it is only set when the
user wants to count in guest-mode only. So when SVM is
disabled the counter should not run at all and the
not-counting is the intended behaviour.
Cc: Avi Kivity <avi@redhat.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Robert Richter <robert.richter@amd.com>
Link: http://lkml.kernel.org/r/1330523852-19566-1-git-send-email-joerg.roedel@amd.com
commit 1d057720609ed052a6371fe1d53300e5e6328e94 upstream.
Enable the compat keyctl wrapper on s390x so that 32-bit s390 userspace can
call the keyctl() syscall.
There's an s390x assembly wrapper that truncates all the register values to
32-bits and this then calls compat_sys_keyctl() - but the latter only exists if
CONFIG_KEYS_COMPAT is enabled, and the s390 Kconfig doesn't enable it.
Without this patch, 32-bit calls to the keyctl() syscall are given an ENOSYS
error:
[root@devel4 ~]# keyctl show
Session Keyring
-3: key inaccessible (Function not implemented)
Acked-by: dan@danny.cz
Cc: Carsten Otte <cotte@de.ibm.com>
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Cc: linux-s390@vger.kernel.org
commit f6737055c1c432a9628a9a731f9881ad8e0a9eee upstream.
The GPI_28 IRQ was not registered properly. The registration of
IRQ_LPC32XX_GPI_28 was added and the (wrong) IRQ_LPC32XX_GPI_11 at
LPC32XX_SIC1_IRQ(4) was replaced by IRQ_LPC32XX_GPI_28 (see manual of
LPC32xx / interrupt controller).
Signed-off-by: Roland Stigge <stigge@antcom.de>
commit 35dd0a75d4a382e7f769dd0277732e7aa5235718 upstream.
This patch fixes the initialization of the interrupt controller of the LPC32xx
by correctly setting up SIC1 and SIC2 instead of (wrongly) using the same value
as for the Main Interrupt Controller (MIC).
commit 94ed7830cba4dce57b18a2926b5d826bfd184bd6 upstream.
This patch fixes the wakeup disable function by clearing latched events.
commit ff424aa4c89d19082e8ae5a3351006bc8a4cd91b upstream.
This patch fixes a wrong loop limit on UART init.
commit 2707208ee8a80dbbd5426f5aa1a934f766825bb5 upstream.
This patch fixes a HW bug by flushing RX FIFOs of the UARTs on init. It was
ported from NXP's git.lpclinux.com tree.
commit 048cd4e51d24ebf7f3552226d03c769d6ad91658 upstream.
The new is_compat_task() define for the !COMPAT case in
include/linux/compat.h conflicts with a similar define in
arch/s390/include/asm/compat.h.
This is the minimal patch which fixes the build issues.
Cc: Jonathan Nieder <jrnieder@gmail.com>
commit 435792d93410f008120c4dbab148019a3cc31dbc upstream.
omap3isp depends on omap's iommu and will fail to probe if
initialized before it (which always happen if they are builtin).
Make omap's iommu subsys_initcall as an interim solution until
the probe deferral mechanism is merged.
Reported-by: James <angweiyang@gmail.com>
Debugged-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Hiroshi Doyu <hdoyu@nvidia.com>
commit 32c3233885eb10ac9cb9410f2f8cd64b8df2b2a1 upstream.
For L1 instruction cache and L2 cache the shared CPU information
is wrong. On current AMD family 15h CPUs those caches are shared
between both cores of a compute unit.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=42607
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Petkov Borislav <Borislav.Petkov@amd.com>
Link: http://lkml.kernel.org/r/20120208195229.GA17523@alberich.amd.com
commit d980e0f8d858c6963d676013e976ff00ab7acb2b upstream.
When the PMIC is not found, voltdm->pmic will be NULL. vp.c's
initialization function tries to dereferences this, which causes an
oops:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = c0004000
[00000000] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT
Modules linked in:
CPU: 0 Not tainted (3.3.0-rc2+ #204)
PC is at omap_vp_init+0x5c/0x15c
LR is at omap_vp_init+0x58/0x15c
pc : [<c03db880>] lr : [<c03db87c>] psr: 60000013
sp : c181ff30 ip : c181ff68 fp : c181ff64
r10: c0407808 r9 : c040786c r8 : c0407814
r7 : c0026868 r6 : c00264fc r5 : c040ad6c r4 : 00000000
r3 : 00000040 r2 : 000032c8 r1 : 0000fa00 r0 : 000032c8
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 80004019 DAC: 00000015
Process swapper (pid: 1, stack limit = 0xc181e2e8)
Stack: (0xc181ff30 to 0xc1820000)
ff20: c0381d00 c02e9c6d c0383582 c040786c
ff40: c040ad6c c00264fc c0026868 c0407814 00000000 c03d9de4 c181ff8c c181ff68
ff60: c03db448 c03db830 c02e982c c03fdfb8 c03fe004 c0039988 00000013 00000000
ff80: c181ff9c c181ff90 c03d9df8 c03db390 c181ffdc c181ffa0 c0008798 c03d9df0
ffa0: c181ffc4 c181ffb0 c0055a44 c0187050 c0039988 c03fdfb8 c03fe004 c0039988
ffc0: 00000013 00000000 00000000 00000000 c181fff4 c181ffe0 c03d1284 c0008708
ffe0: 00000000 c03d1208 00000000 c181fff8 c0039988 c03d1214 1077ce40 01f7ee08
Backtrace:
[<c03db824>] (omap_vp_init+0x0/0x15c) from [<c03db448>] (omap_voltage_late_init+0xc4/0xfc)
[<c03db384>] (omap_voltage_late_init+0x0/0xfc) from [<c03d9df8>] (omap2_common_pm_late_init+0x14/0x54)
r8:00000000 r7:00000013 r6:c0039988 r5:c03fe004 r4:c03fdfb8
[<c03d9de4>] (omap2_common_pm_late_init+0x0/0x54) from [<c0008798>] (do_one_initcall+0x9c/0x164)
[<c00086fc>] (do_one_initcall+0x0/0x164) from [<c03d1284>] (kernel_init+0x7c/0x120)
[<c03d1208>] (kernel_init+0x0/0x120) from [<c0039988>] (do_exit+0x0/0x2cc)
r5:c03d1208 r4:00000000
Code: e5ca300b e5900034 ebf69027 e5994024 (e5941000)
---[ end trace aed617dddaf32c3d ]---
Kernel panic - not syncing: Attempted to kill init!
Cc: Igor Grinberg <grinberg@compulab.co.il>
commit 8e43a905dd574f54c5715d978318290ceafbe275 upstream.
Bootup with lockdep enabled has been broken on v7 since b46c0f74657d
("ARM: 7321/1: cache-v7: Disable preemption when reading CCSIDR").
This is because v7_setup (which is called very early during boot) calls
v7_flush_dcache_all, and the save_and_disable_irqs added by that patch
ends up attempting to call into lockdep C code (trace_hardirqs_off())
when we are in no position to execute it (no stack, MMU off).
Fix this by using a notrace variant of save_and_disable_irqs. The code
already uses the notrace variant of restore_irqs.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Rabin Vincent <rabin@rab.in>
commit b46c0f74657d1fe1c1b0c1452631cc38a9e6987f upstream.
armv7's flush_cache_all() flushes caches via set/way. To
determine the cache attributes (line size, number of sets,
etc.) the assembly first writes the CSSELR register to select a
cache level and then reads the CCSIDR register. The CSSELR register
is banked per-cpu and is used to determine which cache level CCSIDR
reads. If the task is migrated between when the CSSELR is written and
the CCSIDR is read the CCSIDR value may be for an unexpected cache
level (for example L1 instead of L2) and incorrect cache flushing
could occur.
Disable interrupts across the write and read so that the correct
cache attributes are read and used for the cache flushing
routine. We disable interrupts instead of disabling preemption
because the critical section is only 3 instructions and we want
to call v7_dcache_flush_all from __v7_setup which doesn't have a
full kernel stack with a struct thread_info.
This fixes a problem we see in scm_call() when flush_cache_all()
is called from preemptible context and sometimes the L2 cache is
not properly flushed out.
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
commit 46e33c606af8e0caeeca374103189663d877c0d6 upstream.
This fixes the thrd->req_running field being accessed before thrd
is checked for null. The error was introduced in
abb959f: ARM: 7237/1: PL330: Fix driver freeze
Reference: <1326458191-23492-1-git-send-email-mans.rullgard@linaro.org>
Signed-off-by: Mans Rullgard <mans.rullgard@linaro.org>
Acked-by: Javi Merino <javi.merino@arm.com>
commit cf1eb40f8f5ea12c9e569e7282161fc7f194fd62 upstream.
The conversion of the ktime to a value suitable for the clock comparator
does not take changes to wall_to_monotonic into account. In fact the
conversion just needs the boot clock (sched_clock_base_cc) and the
total_sleep_time.
This is applicable to 3.2+ kernels.
commit e8c9dc93e27d891636defbc269f182a83e6abba8 upstream.
Registration of at91_udc as a module will enable SoC
related code.
Fix following an idea from Karel Znamenacek.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Karel Znamenacek <karel@ryston.cz>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
events
commit 9a45a9407c69d068500923480884661e2b9cc421 upstream.
perf on POWER stopped working after commit e050e3f0a71b (perf: Fix
broken interrupt rate throttling). That patch exposed a bug in
the POWER perf_events code.
Since the PMCs count upwards and take an exception when the top bit
is set, we want to write 0x80000000 - left in power_pmu_start. We were
instead programming in left which effectively disables the counter
until we eventually hit 0x80000000. This could take seconds or longer.
With the patch applied I get the expected number of samples:
SAMPLE events: 9948
Acked-by: Paul Mackerras <paulus@samba.org>
commit 34ddc81a230b15c0e345b6b253049db731499f7e upstream.
After all the FPU state cleanups and finally finding the problem that
caused all our FPU save/restore problems, this re-introduces the
preloading of FPU state that was removed in commit b3b0870ef3ff ("i387:
do not preload FPU state at task switch time").
However, instead of simply reverting the removal, this reimplements
preloading with several fixes, most notably
- properly abstracted as a true FPU state switch, rather than as
open-coded save and restore with various hacks.
In particular, implementing it as a proper FPU state switch allows us
to optimize the CR0.TS flag accesses: there is no reason to set the
TS bit only to then almost immediately clear it again. CR0 accesses
are quite slow and expensive, don't flip the bit back and forth for
no good reason.
- Make sure that the same model works for both x86-32 and x86-64, so
that there are no gratuitous differences between the two due to the
way they save and restore segment state differently due to
architectural differences that really don't matter to the FPU state.
- Avoid exposing the "preload" state to the context switch routines,
and in particular allow the concept of lazy state restore: if nothing
else has used the FPU in the meantime, and the process is still on
the same CPU, we can avoid restoring state from memory entirely, just
re-expose the state that is still in the FPU unit.
That optimized lazy restore isn't actually implemented here, but the
infrastructure is set up for it. Of course, older CPU's that use
'fnsave' to save the state cannot take advantage of this, since the
state saving also trashes the state.
In other words, there is now an actual _design_ to the FPU state saving,
rather than just random historical baggage. Hopefully it's easier to
follow as a result.
commit f94edacf998516ac9d849f7bc6949a703977a7f3 upstream.
This moves the bit that indicates whether a thread has ownership of the
FPU from the TS_USEDFPU bit in thread_info->status to a word of its own
(called 'has_fpu') in task_struct->thread.has_fpu.
This fixes two independent bugs at the same time:
- changing 'thread_info->status' from the scheduler causes nasty
problems for the other users of that variable, since it is defined to
be thread-synchronous (that's what the "TS_" part of the naming was
supposed to indicate).
So perfectly valid code could (and did) do
ti->status |= TS_RESTORE_SIGMASK;
and the compiler was free to do that as separate load, or and store
instructions. Which can cause problems with preemption, since a task
switch could happen in between, and change the TS_USEDFPU bit. The
change to TS_USEDFPU would be overwritten by the final store.
In practice, this seldom happened, though, because the 'status' field
was seldom used more than once, so gcc would generally tend to
generate code that used a read-modify-write instruction and thus
happened to avoid this problem - RMW instructions are naturally low
fat and preemption-safe.
- On x86-32, the current_thread_info() pointer would, during interrupts
and softirqs, point to a *copy* of the real thread_info, because
x86-32 uses %esp to calculate the thread_info address, and thus the
separate irq (and softirq) stacks would cause these kinds of odd
thread_info copy aliases.
This is normally not a problem, since interrupts aren't supposed to
look at thread information anyway (what thread is running at
interrupt time really isn't very well-defined), but it confused the
heck out of irq_fpu_usable() and the code that tried to squirrel
away the FPU state.
(It also caused untold confusion for us poor kernel developers).
It also turns out that using 'task_struct' is actually much more natural
for most of the call sites that care about the FPU state, since they
tend to work with the task struct for other reasons anyway (ie
scheduling). And the FPU data that we are going to save/restore is
found there too.
Thanks to Arjan Van De Ven <arjan@linux.intel.com> for pointing us to
the %esp issue.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Reported-and-tested-by: Raphael Prevost <raphael@buro.asia>
Acked-and-tested-by: Suresh Siddha <suresh.b.siddha@intel.com>
Tested-by: Peter Anvin <hpa@zytor.com>
commit 4903062b5485f0e2c286a23b44c9b59d9b017d53 upstream.
The AMD K7/K8 CPUs don't save/restore FDP/FIP/FOP unless an exception is
pending. In order to not leak FIP state from one process to another, we
need to do a floating point load after the fxsave of the old process,
and before the fxrstor of the new FPU state. That resets the state to
the (uninteresting) kernel load, rather than some potentially sensitive
user information.
We used to do this directly after the FPU state save, but that is
actually very inconvenient, since it
(a) corrupts what is potentially perfectly good FPU state that we might
want to lazy avoid restoring later and
(b) on x86-64 it resulted in a very annoying ordering constraint, where
"__unlazy_fpu()" in the task switch needs to be delayed until after
the DS segment has been reloaded just to get the new DS value.
Coupling it to the fxrstor instead of the fxsave automatically avoids
both of these issues, and also ensures that we only do it when actually
necessary (the FP state after a save may never actually get used). It's
simply a much more natural place for the leaked state cleanup.
commit b3b0870ef3ffed72b92415423da864f440f57ad6 upstream.
Yes, taking the trap to re-load the FPU/MMX state is expensive, but so
is spending several days looking for a bug in the state save/restore
code. And the preload code has some rather subtle interactions with
both paravirtualization support and segment state restore, so it's not
nearly as simple as it should be.
Also, now that we no longer necessarily depend on a single bit (ie
TS_USEDFPU) for keeping track of the state of the FPU, we migth be able
to do better. If we are really switching between two processes that
keep touching the FP state, save/restore is inevitable, but in the case
of having one process that does most of the FPU usage, we may actually
be able to do much better than the preloading.
In particular, we may be able to keep track of which CPU the process ran
on last, and also per CPU keep track of which process' FP state that CPU
has. For modern CPU's that don't destroy the FPU contents on save time,
that would allow us to do a lazy restore by just re-enabling the
existing FPU state - with no restore cost at all!
commit 6d59d7a9f5b723a7ac1925c136e93ec83c0c3043 upstream.
This creates three helper functions that do the TS_USEDFPU accesses, and
makes everybody that used to do it by hand use those helpers instead.
In addition, there's a couple of helper functions for the "change both
CR0.TS and TS_USEDFPU at the same time" case, and the places that do
that together have been changed to use those. That means that we have
fewer random places that open-code this situation.
The intent is partly to clarify the code without actually changing any
semantics yet (since we clearly still have some hard to reproduce bug in
this area), but also to make it much easier to use another approach
entirely to caching the CR0.TS bit for software accesses.
Right now we use a bit in the thread-info 'status' variable (this patch
does not change that), but we might want to make it a full field of its
own or even make it a per-cpu variable.
commit b6c66418dcad0fcf83cd1d0a39482db37bf4fc41 upstream.
Touching TS_USEDFPU without touching CR0.TS is confusing, so don't do
it. By moving it into the callers, we always do the TS_USEDFPU next to
the CR0.TS accesses in the source code, and it's much easier to see how
the two go hand in hand.
commit 15d8791cae75dca27bfda8ecfe87dca9379d6bb0 upstream.
Commit 5b1cbac37798 ("i387: make irq_fpu_usable() tests more robust")
added a sanity check to the #NM handler to verify that we never cause
the "Device Not Available" exception in kernel mode.
However, that check actually pinpointed a (fundamental) race where we do
cause that exception as part of the signal stack FPU state save/restore
code.
Because we use the floating point instructions themselves to save and
restore state directly from user mode, we cannot do that atomically with
testing the TS_USEDFPU bit: the user mode access itself may cause a page
fault, which causes a task switch, which saves and restores the FP/MMX
state from the kernel buffers.
This kind of "recursive" FP state save is fine per se, but it means that
when the signal stack save/restore gets restarted, it will now take the
'#NM' exception we originally tried to avoid. With preemption this can
happen even without the page fault - but because of the user access, we
cannot just disable preemption around the save/restore instruction.
There are various ways to solve this, including using the
"enable/disable_page_fault()" helpers to not allow page faults at all
during the sequence, and fall back to copying things by hand without the
use of the native FP state save/restore instructions.
However, the simplest thing to do is to just allow the #NM from kernel
space, but fix the race in setting and clearing CR0.TS that this all
exposed: the TS bit changes and the TS_USEDFPU bit absolutely have to be
atomic wrt scheduling, so while the actual state save/restore can be
interrupted and restarted, the act of actually clearing/setting CR0.TS
and the TS_USEDFPU bit together must not.
Instead of just adding random "preempt_disable/enable()" calls to what
is already excessively ugly code, this introduces some helper functions
that mostly mirror the "kernel_fpu_begin/end()" functionality, just for
the user state instead.
Those helper functions should probably eventually replace the other
ad-hoc CR0.TS and TS_USEDFPU tests too, but I'll need to think about it
some more: the task switching functionality in particular needs to
expose the difference between the 'prev' and 'next' threads, while the
new helper functions intentionally were written to only work with
'current'.
commit c38e23456278e967f094b08247ffc3711b1029b2 upstream.
The check for save_init_fpu() (introduced in commit 5b1cbac37798: "i387:
make irq_fpu_usable() tests more robust") was the wrong way around, but
I hadn't noticed, because my "tests" were bogus: the FPU exceptions are
disabled by default, so even doing a divide by zero never actually
triggers this code at all unless you do extra work to enable them.
So if anybody did enable them, they'd get one spurious warning.
commit 5b1cbac37798805c1fee18c8cebe5c0a13975b17 upstream.
Some code - especially the crypto layer - wants to use the x86
FP/MMX/AVX register set in what may be interrupt (typically softirq)
context.
That *can* be ok, but the tests for when it was ok were somewhat
suspect. We cannot touch the thread-specific status bits either, so
we'd better check that we're not going to try to save FP state or
anything like that.
Now, it may be that the TS bit is always cleared *before* we set the
USEDFPU bit (and only set when we had already cleared the USEDFP
before), so the TS bit test may actually have been sufficient, but it
certainly was not obviously so.
So this explicitly verifies that we will not touch the TS_USEDFPU bit,
and adds a few related sanity-checks. Because it seems that somehow
AES-NI is corrupting user FP state. The cause is not clear, and this
patch doesn't fix it, but while debugging it I really wanted the code to
be more obviously correct and robust.
commit be98c2cdb15ba26148cd2bd58a857d4f7759ed38 upstream.
It was marked asmlinkage for some really old and stale legacy reasons.
Fix that and the equally stale comment.
Noticed when debugging the irq_fpu_usable() bugs.
