On systems containing multiple, heterogeneous clusters we need a way to
associate a PMU "device" with the CPU(s) on which it exists. For PMUs
that signal overflow with SPIs, this relationship is determined via the
"interrupt-affinity" property, which contains a list of phandles to CPU
nodes for the PMU. For PMUs using PPIs, the per-cpu nature of the
interrupt isn't enough to determine the set of CPUs which actually
contain the device.
This patch allows the interrupt-affinity property to be specified on a
PMU node irrespective of the interrupt type. For PPIs, it identifies
the set of CPUs signalling the PPI in question.
Tested-by: Stephen Boyd <sboyd@codeaurora.org> # Krait PMU
For PPI based PMUs, we bail out early in of_pmu_irq_cfg() without
setting the PMU's supported_cpus bitmap. This causes the
smp_call_function_any() in armv7_probe_num_events() to fail. Set
the bitmap to be all CPUs so that we properly probe PMUs that use
PPIs.
Fixes: cc88116da0d1 ("arm: perf: treat PMUs as CPU affine")
Cc: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
It's possible, albeit unlikely, that using the of_node here will
reference freed memory. Call of_node_put() after printing the
name to be safe.
This patch is to get correct physical address of the reset function for
PAE systems, which use aliased physical memory for booting.
See the "ARM: mm: Introduce virt_to_idmap() with an arch hook" for details.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Pull MIPS fixes from Ralf Baechle:
"A fair number of 4.2 fixes also because Markos opened the flood gates.
- Patch up the math used calculate the location for the page bitmap.
- The FDC (Not what you think, FDC stands for Fast Debug Channel) IRQ
around was causing issues on non-Malta platforms, so move the code
to a Malta specific location.
- A spelling fix replicated through several files.
- Fix to the emulation of an R2 instruction for R6 cores.
- Fix the JR emulation for R6.
- Further patching of mindless 64 bit issues.
- Ensure the kernel won't crash on CPUs with L2 caches with >= 8
ways.
- Use compat_sys_getsockopt for O32 ABI on 64 bit kernels.
- Fix cache flushing for multithreaded cores.
- A build fix"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: O32: Use compat_sys_getsockopt.
MIPS: c-r4k: Extend way_string array
MIPS: Pistachio: Support CDMM & Fast Debug Channel
MIPS: Malta: Make GIC FDC IRQ workaround Malta specific
MIPS: c-r4k: Fix cache flushing for MT cores
Revert "MIPS: Kconfig: Disable SMP/CPS for 64-bit"
MIPS: cps-vec: Use macros for various arithmetics and memory operations
MIPS: kernel: cps-vec: Replace KSEG0 with CKSEG0
MIPS: kernel: cps-vec: Use ta0-ta3 pseudo-registers for 64-bit
MIPS: kernel: cps-vec: Replace mips32r2 ISA level with mips64r2
MIPS: kernel: cps-vec: Replace 'la' macro with PTR_LA
MIPS: kernel: smp-cps: Fix 64-bit compatibility errors due to pointer casting
MIPS: Fix erroneous JR emulation for MIPS R6
MIPS: Fix branch emulation for BLTC and BGEC instructions
MIPS: kernel: traps: Fix broken indentation
MIPS: bootmem: Don't use memory holes for page bitmap
MIPS: O32: Do not handle require 32 bytes from the stack to be readable.
MIPS, CPUFREQ: Fix spelling of Institute.
MIPS: Lemote 2F: Fix build caused by recent mass rename.
Pull x86 fixes from Thomas Gleixner:
- the high latency PIT detection fix, which slipped through the cracks
for rc1
- a regression fix for the early printk mechanism
- the x86 part to plug irq/vector related hotplug races
- move the allocation of the espfix pages on cpu hotplug to non atomic
context. The current code triggers a might_sleep() warning.
- a series of KASAN fixes addressing boot crashes and usability
- a trivial typo fix for Kconfig help text
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/kconfig: Fix typo in the CONFIG_CMDLINE_BOOL help text
x86/irq: Retrieve irq data after locking irq_desc
x86/irq: Use proper locking in check_irq_vectors_for_cpu_disable()
x86/irq: Plug irq vector hotplug race
x86/earlyprintk: Allow early_printk() to use console style parameters like '115200n8'
x86/espfix: Init espfix on the boot CPU side
x86/espfix: Add 'cpu' parameter to init_espfix_ap()
x86/kasan: Move KASAN_SHADOW_OFFSET to the arch Kconfig
x86/kasan: Add message about KASAN being initialized
x86/kasan: Fix boot crash on AMD processors
x86/kasan: Flush TLBs after switching CR3
x86/kasan: Fix KASAN shadow region page tables
x86/init: Clear 'init_level4_pgt' earlier
x86/tsc: Let high latency PIT fail fast in quick_pit_calibrate()
Pull timer fixes from Thomas Gleixner:
"This update from the timer departement contains:
- A series of patches which address a shortcoming in the tick
broadcast code.
If the broadcast device is not available or an hrtimer emulated
broadcast device, some of the original assumptions lead to boot
failures. I rather plugged all of the corner cases instead of only
addressing the issue reported, so the change got a little larger.
Has been extensivly tested on x86 and arm.
- Get rid of the last holdouts using do_posix_clock_monotonic_gettime()
- A regression fix for the imx clocksource driver
- An update to the new state callbacks mechanism for clockevents.
This is required to simplify the conversion, which will take place
in 4.3"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tick/broadcast: Prevent NULL pointer dereference
time: Get rid of do_posix_clock_monotonic_gettime
cris: Replace do_posix_clock_monotonic_gettime()
tick/broadcast: Unbreak CONFIG_GENERIC_CLOCKEVENTS=n build
tick/broadcast: Handle spurious interrupts gracefully
tick/broadcast: Check for hrtimer broadcast active early
tick/broadcast: Return busy when IPI is pending
tick/broadcast: Return busy if periodic mode and hrtimer broadcast
tick/broadcast: Move the check for periodic mode inside state handling
tick/broadcast: Prevent deep idle if no broadcast device available
tick/broadcast: Make idle check independent from mode and config
tick/broadcast: Sanity check the shutdown of the local clock_event
tick/broadcast: Prevent hrtimer recursion
clockevents: Allow set-state callbacks to be optional
clocksource/imx: Define clocksource for mx27
Pull ARM SoC fixes from Kevin Hilman:
"A fairly random colletion of fixes based on -rc1 for OMAP, sunxi and
prima2 as well as a few arm64-specific DT fixes.
This series also includes a late to support a new Allwinner (sunxi)
SoC, but since it's rather simple and isolated to the
platform-specific code, it's included it for this -rc"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
arm64: dts: add device tree for ARM SMM-A53x2 on LogicTile Express 20MG
arm: dts: vexpress: add missing CCI PMU device node to TC2
arm: dts: vexpress: describe all PMUs in TC2 dts
GICv3: Add ITS entry to THUNDER dts
arm64: dts: Add poweroff button device node for APM X-Gene platform
ARM: dts: am4372.dtsi: disable rfbi
ARM: dts: am57xx-beagle-x15: Provide supply for usb2_phy2
ARM: dts: am4372: Add emif node
Revert "ARM: dts: am335x-boneblack: disable RTC-only sleep"
ARM: sunxi: Enable simplefb in the defconfig
ARM: Remove deprecated symbol from defconfig files
ARM: sunxi: Add Machine support for A33
ARM: sunxi: Introduce Allwinner H3 support
Documentation: sunxi: Update Allwinner SoC documentation
ARM: prima2: move to use REGMAP APIs for rtciobrg
ARM: dts: atlas7: add pinctrl and gpio descriptions
ARM: OMAP2+: Remove unnessary return statement from the void function, omap2_show_dma_caps
memory: omap-gpmc: Fix parsing of devices
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc fixes from Helge Deller:
"We have one important patch from Dave Anglin and myself which fixes
PTE/TLB race conditions which caused random segmentation faults on our
debian buildd servers, and one patch from Alex Ivanov which speeds up
the graphical text console on the STI framebuffer driver"
* 'parisc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Fix some PTE/TLB race conditions and optimize __flush_tlb_range based on timing results
stifb: Implement hardware accelerated copyarea
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes and clean-up from Catalin Marinas:
- ACPI fix when checking the validity of the GICC MADT subtable
- handle debug exceptions in the el*_inv exception entries
- remove pointless register assignment in two compat syscall wrappers
- unnecessary include path
- defconfig update
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: entry32: remove pointless register assignment
arm64: entry: handle debug exceptions in el*_inv
arm64: Keep the ARM64 Kconfig selects sorted
ACPI / ARM64 : use the new BAD_MADT_GICC_ENTRY macro
ACPI / ARM64: add BAD_MADT_GICC_ENTRY() macro
arm64: defconfig: Add Ceva ahci to the defconfig
arm64: remove another unnecessary libfdt include path
The increased use of pdtlb/pitlb instructions seemed to increase the
frequency of random segmentation faults building packages. Further, we
had a number of cases where TLB inserts would repeatedly fail and all
forward progress would stop. The Haskell ghc package caused a lot of
trouble in this area. The final indication of a race in pte handling was
this syslog entry on sibaris (C8000):
swap_free: Unused swap offset entry 00000004
BUG: Bad page map in process mysqld pte:00000100 pmd:019bbec5
addr:00000000ec464000 vm_flags:00100073 anon_vma:0000000221023828 mapping: (null) index:ec464
CPU: 1 PID: 9176 Comm: mysqld Not tainted 4.0.0-2-parisc64-smp #1 Debian 4.0.5-1
Backtrace:
[<0000000040173eb0>] show_stack+0x20/0x38
[<0000000040444424>] dump_stack+0x9c/0x110
[<00000000402a0d38>] print_bad_pte+0x1a8/0x278
[<00000000402a28b8>] unmap_single_vma+0x3d8/0x770
[<00000000402a4090>] zap_page_range+0xf0/0x198
[<00000000402ba2a4>] SyS_madvise+0x404/0x8c0
Note that the pte value is 0 except for the accessed bit 0x100. This bit
shouldn't be set without the present bit.
It should be noted that the madvise system call is probably a trigger for many
of the random segmentation faults.
In looking at the kernel code, I found the following problems:
1) The pte_clear define didn't take TLB lock when clearing a pte.
2) We didn't test pte present bit inside lock in exception support.
3) The pte and tlb locks needed to merged in order to ensure consistency
between page table and TLB. This also has the effect of serializing TLB
broadcasts on SMP systems.
The attached change implements the above and a few other tweaks to try
to improve performance. Based on the timing code, TLB purges are very
slow (e.g., ~ 209 cycles per page on rp3440). Thus, I think it
beneficial to test the split_tlb variable to avoid duplicate purges.
Probably, all PA 2.0 machines have combined TLBs.
I dropped using __flush_tlb_range in flush_tlb_mm as I realized all
applications and most threads have a stack size that is too large to
make this useful. I added some comments to this effect.
Since implementing 1 through 3, I haven't had any random segmentation
faults on mx3210 (rp3440) in about one week of building code and running
as a Debian buildd.
Signed-off-by: John David Anglin <dave.anglin@bell.net>
Cc: stable@vger.kernel.org # v3.18+
Signed-off-by: Helge Deller <deller@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc fixes from Michael Ellerman:
- opal-prd mmap fix from Vaidy
- set kernel taint for MCEs from Daniel
- alignment exception description from Anton
- ppc4xx_hsta_msi build fix from Daniel
- opal-elog interrupt fix from Alistair
- core_idle_state race fix from Shreyas
- hv-24x7 lockdep fix from Sukadev
- multiple cxl fixes from Daniel, Ian, Mikey & Maninder
- update MAINTAINERS to point at shared tree
* tag 'powerpc-4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux:
cxl: Check if afu is not null in cxl_slbia
powerpc: Update MAINTAINERS to point at shared tree
powerpc/perf/24x7: Fix lockdep warning
cxl: Fix off by one error allowing subsequent mmap page to be accessed
cxl: Fail mmap if requested mapping is larger than assigned problem state area
cxl: Fix refcounting in kernel API
powerpc/powernv: Fix race in updating core_idle_state
powerpc/powernv: Fix opal-elog interrupt handler
powerpc/ppc4xx_hsta_msi: Include ppc-pci.h to fix reference to hose_list
powerpc: Add plain English description for alignment exception oopses
cxl: Test the correct mmio space before unmapping
powerpc: Set the correct kernel taint on machine check errors
cxl/vphb.c: Use phb pointer after NULL check
powerpc/powernv: Fix vma page prot flags in opal-prd driver
We currently set x27 in compat_sys_sigreturn_wrapper and
compat_sys_rt_sigreturn_wrapper, similarly to what we do with r8/why on
32-bit ARM, in an attempt to prevent sigreturns from being restarted.
However, on arm64 we have always used pt_regs::syscallno for syscall
restarting (for both native and compat tasks), and x27 is never
inspected again before being overwritten in kernel_exit.
This patch removes the pointless register assignments.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
We were using the native syscall and that results in subtle breakage.
This is the same issue as fixed in 077d0e65618f27b2199d622e12ada6d8f3dbd862
(MIPS: N32: Use compat getsockopt syscall) but that commit did fix it only
for N32.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=100291
The L2 cache in the I6400 core has 16 ways, so extend the way_string
array to take such caches into account.
[ralf@linux-mips.org: Other already supported CPUs are free to support
more than 8 ways of cache as well.]
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/10640/
Implement the mips_cdmm_phys_base() platform callback to provide a
default Common Device Memory Map (CDMM) physical base address for the
Pistachio SoC. This allows the CDMM in each VPE to be configured and
probed for devices, such as the Fast Debug Channel (FDC).
The physical address chosen is just below the default CPC address, which
appears to also be unallocated.
The FDC IRQ is also usable on Pistachio, and is routed through the GIC,
so implement the get_c0_fdc_int() platform callback using
gic_get_c0_fdc_int(), so the FDC driver doesn't have to fall back to
polling.
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Andrew Bresticker <abrestic@chromium.org>
Cc: James Hartley <james.hartley@imgtec.com>
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
Patchwork: http://patchwork.linux-mips.org/patch/9749/
Wider testing reveals that the Fast Debug Channel (FDC) interrupt is
routed through the GIC just fine on Pistachio SoC, even though it
contains interAptiv cores. Clearly the FDC interrupt routing problems
previously observed on interAptiv and proAptiv cores are specific to the
Malta FPGA bitstreams.
Move the workaround for interAptiv and proAptiv out of
gic_get_c0_fdc_int() in the GIC irqchip driver into Malta's
get_c0_fdc_int() platform callback, to allow the Pistachio SoC to use
the FDC interrupt.
Cc: Jason Cooper <jason@lakedaemon.net>
Patchwork: http://patchwork.linux-mips.org/patch/9748/
MT_SMP is not the only SMP option for MT cores. The MT_SMP option
allows more than one VPE per core to appear as a secondary CPU in the
system. Because of how CM works, it propagates the address-based
cache ops to the secondary cores but not the index-based ones.
Because of that, the code does not use IPIs to flush the L1 caches on
secondary cores because the CM would have done that already. However,
the CM functionality is independent of the type of SMP kernel so even in
non-MT kernels, IPIs are not necessary. As a result of which, we change
the conditional to depend on the CM presence. Moreover, since VPEs on
the same core share the same L1 caches, there is no need to send an
IPI on all of them so we calculate a suitable cpumask with only one
VPE per core.
Cc: <stable@vger.kernel.org> # 3.15+
Patchwork: https://patchwork.linux-mips.org/patch/10654/
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Merge "omap fixes against v4.2-rc1" from Tony Lindgren:
Minor fixes for omaps against v4.2-rc1. Mostly just minor dts changes
except for a GPMC fix to not use names for probing devices. Also a
one liner clean-up to remove unecessary return from a void function.
The summary for the changes being:
- Fix probe for GPMC devices by reoving limitations based on device
name
- Remove unnecessary return from a void function
- Revert beaglebone RTC sleep fix, we now have a better fix merged
- Add am4372 EMIF node to fix a warning
- Add am57xx-beagle-x15 power supply to fix USB2 if USB1 is disabled
- Disable rfbi for am4372 as it does not have a driver
* tag 'omap-for-v4.2/fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into fixes
Merge "Allwinner late changes for 4.2" from Maxime Ripard:
A bunch of defconfig changes, and some patches to make the Allwinner H3 and
A33 boot properly.
* tag 'sunxi-late-for-4.2' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux:
This reverts commit 6ca716f2e5571d25a3899c6c5c91ff72ea6d6f5e.
SMP/CPS is now supported on 64bit cores.
Cc: <stable@vger.kernel.org> # 4.1
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10592/
Replace lw/sw and various arithmetic instructions with macros so the
code can work on 64-bit kernels as well.
Cc: <stable@vger.kernel.org> # 3.16+
Patchwork: https://patchwork.linux-mips.org/patch/10591/
In preparation for 64-bit CPS support, we replace KSEG0 with CKSEG0
so 64-bit kernels can be supported.
Patchwork: https://patchwork.linux-mips.org/patch/10590/
The cps-vec code assumes O32 ABI and uses t4-t7 in quite a few places. This
breaks the build on 64-bit. As a result of which, use the pseudo-registers
ta0-ta3 to make the code compatible with 64-bit.
Patchwork: https://patchwork.linux-mips.org/patch/10589/
mips32r2 is a subset of mips64r2, so we replace mips32r2 with mips64r2
in preparation for 64-bit CPS support.
Patchwork: https://patchwork.linux-mips.org/patch/10588/
The PTR_LA macro will pick the correct "la" or "dla" macro to
load an address to a register. This gets rids of the following
warnings (and others) when building a 64-bit CPS kernel:
arch/mips/kernel/cps-vec.S:63: Warning: la used to load 64-bit address
arch/mips/kernel/cps-vec.S:159: Warning: la used to load 64-bit address
arch/mips/kernel/cps-vec.S:220: Warning: la used to load 64-bit address
arch/mips/kernel/cps-vec.S:240: Warning: la used to load 64-bit address
Patchwork: https://patchwork.linux-mips.org/patch/10587/
Commit 1d8f1f5a780a ("MIPS: smp-cps: hotplug support") added hotplug
support in the SMP/CPS implementation but it introduced a few build problems
on 64-bit kernels due to pointer being casted to and from 'int' C types. We
fix this problem by using 'unsigned long' instead which should match the size
of the pointers in 32/64-bit kernels. Finally, we fix the comment since the
CM base address is loaded to v1($3) instead of v0.
Fixes the following build problems:
arch/mips/kernel/smp-cps.c: In function 'wait_for_sibling_halt':
arch/mips/kernel/smp-cps.c:366:17: error: cast from pointer to integer of
different size [-Werror=pointer-to-int-cast]
arch/mips/kernel/smp-cps.c: In function 'cps_cpu_die':
arch/mips/kernel/smp-cps.c:427:13: error: cast to pointer
from integer of different size [-Werror=int-to-pointer-cast]
cc1: all warnings being treated as errors
Fixes: 1d8f1f5a780a ("MIPS: smp-cps: hotplug support")
Patchwork: https://patchwork.linux-mips.org/patch/10586/
Commit 5f9f41c474befb4ebbc40b27f65bb7d649241581 ("MIPS: kernel: Prepare
the JR instruction for emulation on MIPS R6") added support for
emulating the JR instruction on MIPS R6 cores but that introduced a bug
which could be triggered when hitting a JALR opcode because the code used
the wrong field in the 'r_format' struct to determine the instruction
opcode. This lead to crashes because an emulated JALR instruction was
treated as a JR one when the R6 emulator was turned off.
Fixes: 5f9f41c474be ("MIPS: kernel: Prepare the JR instruction for emulation on MIPS R6")
Cc: <stable@vger.kernel.org> # 4.0+
Patchwork: https://patchwork.linux-mips.org/patch/10583/
Commits f1b44067c19258b7614e3cd09dfe8d8e12ff5895 ("MIPS: Emulate the
new MIPS R6 B{L,G}T{Z,}{AL,}C instructions") and commit
a8ff66f52d3f17b5ae793955270675c197f73d6c ("MIPS: Emulate the new MIPS
R6 B{L,G}E{Z,}{AL,}C instructions") added support for emulating various
branch compact instructions. However, it missed the case for those which
use the old BLEZL and BGTZL opcodes leading to random crashes when the R6
emulator is disabled. We fix this by ensuring that the 'rt' field is not
zero which is always true for these branch compact instructions.
Fixes: f1b44067c192 ("MIPS: Emulate the new MIPS R6 B{L,G}T{Z,}{AL,}C instructions")
Fixes: a8ff66f52d3f ("MIPS: Emulate the new MIPS R6 B{L,G}E{Z,}{AL,}C instructions")
Cc: Markos Chandras <markos.chandras@imgtec.com>
Patchwork: https://patchwork.linux-mips.org/patch/10582/
Fix broken indentation caused by the SMTC removal
commit b633648c5ad3cfbda0b3daea50d2135d44899259
("MIPS: MT: Remove SMTC support")
Fixes: b633648c5ad3c ("MIPS: MT: Remove SMTC support")
Patchwork: https://patchwork.linux-mips.org/patch/10581/
Commit f9a7febd leads to a fact that mapstart and therefore a page bitmap for
bootmem allocator immediately follows initrd_end. This doesn't always work
well on Octeon, where there are holes in PFN ranges (refer to 5b3b1688 and
4MB-aligned PFN allocation). Depending on the inird location it could happen,
that mapstart would be in an area not allocated by plat_mem_setup() in
arch/mips/cavium-octeon/setup.c, but in the alignment hole between initrd and
the next PFN area. Later on this memory will be unconditionally made available
to buddy allocator at the end of free_all_bootmem_core() (mm/bootmem.c).
All of this results in Linux using the memory not designated for Linux in
Octeon's plat_mem_setup(), which in turn means corruption of the memory used
by another OS/baremetal code on the same SoC.
It doesn't look to me as a problem of Octeon platform code, but rather as an
inability of f9a7febd to deal correctly with the fragmented memory-mappings.
Proposed fix moves the check for initrd address to the same calculation-loop
in bootmem_init() (arch/mips/kernel/setup.c), which also accounts for kernel
code location. This should result in mapstart located starting from the first
PFN area after kernel code AND initrd.
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Cc: David Daney <david.daney@cavium.com>
Cc: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
Cc: Huacai Chen <chenhc@lemote.com>
Cc: Andreas Herrmann <andreas.herrmann@caviumnetworks.com>
Cc: Joe Perches <joe@perches.com>
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Cc: Yusuf Khan <yusuf.khan@nokia.com>
Cc: Michael Kreuzer <michael.kreuzer@nokia.com>
Cc: Aaro Koskinen <aaro.koskinen@iki.fi>
Patchwork: https://patchwork.linux-mips.org/patch/10594/
ktime_get_ts() is the proper interface today.
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull arch/tile fix from Chris Metcalf:
"This fix eliminates a "section mismatch" warning caused by the new
__ex_table checking code in modpost"
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
modpost: work correctly with tile coldtext sections
The tilegx and tilepro compilers use .coldtext for their unlikely
executed text section name, so an __attribute__((cold)) function
will (when compiled with higher optimization levels) land in
the .coldtext section.
Modify modpost to add .coldtext to the set of OTHER_TEXT_SECTIONS
so we don't get warnings about referencing such a section in an
__ex_table block, and then also modify arch/tile/lib/memcpy_user_64.c
so that it uses plain ".coldtext" instead of ".coldtext.memcpy".
The latter naming is a relic of an earlier use of -ffunction-sections,
which we no longer use by default.
Signed-off-by: Chris Metcalf <cmetcalf@ezchip.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Add a DTS file for the MP2 Cortex-A53 Soft Macrocell Model implemented
on a LogicTile Express 20MG (V2F-1XV7) daughterboard. This is based on
the version that's currently available from the ARM DTS repository [1].
[1] git://linux-arm.org/arm-dts.git
Signed-off-by: Kristina Martsenko <kristina.martsenko@arm.com>
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
The CCI device node was added to vexpress CA15_A7(i.e. TC2) much before
the CCI PMU support and binding was added. This patch adds the missing
PMU node so that CCI PMUs can be used on TC2.
Cc: Liviu Dudau <liviu.dudau@arm.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Punit Agrawal <punit.agrawal@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
The dts for the CoreTile Express A15x2 A7x3 (TC2) only describes the
PMUs of the Cortex-A15 CPUs, and not the Cortex-A7 CPUs.
Now that we have a mechanism for describing disparate PMUs and their
interrupts in device tree, this patch makes use of these to describe the
PMUs for all CPUs in the system. For consistency, the existing A15 PMU
interrupt-affinity property is reflowed across two lines.
Acked-by: Will Deacon <will.deacon@arm.com>
The PCIe host controller uses MSIs provided by GICv3 ITS. Enable it on
Thunder SoCs by adding an entry to DT.
Signed-off-by: Tirumalesh Chalamarla <tchalamarla@cavium.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux into fixes
Merge "CSR SiRFSoC rtc iobrg move to regmap for 4.2" from Barry Song:
move CSR rtc iobrg read/write API to be regmap
this moves to general APIs, and all drivers will be changed based
on it.
* tag 'sirf-iobrg2regmap-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux:
Merge "CSR atlas7 pinctrl descriptions for 4.2" from Barry Song:
add atlas7 pinctrl dts stuff
add atlas7 pin groups and gpio/pin mapping descriptions
* tag 'atlas7-pinctrl-dts-for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/baohua/linux:
This patch adds poweroff button device node to support poweroff feature
on APM X-Gene Mustang platform.
Signed-off-by: Y Vo <yvo@apm.com>
Currently we enable debug exceptions before reading ESR_EL1 in both
el0_inv and el1_inv. If a debug exception is taken before we read
ESR_EL1, the value will have been corrupted.
As el*_inv is typically fatal, an intervening debug exception results in
misleading debug information being logged to the console, but is not
otherwise harmful.
As with the other entry paths, we can use the ESR_EL1 value stashed
earlier in the exception entry (in x25 for el0_sync{,_compat}, and x1
for el1_sync), giving us better error reporting in this case.
Signed-off-by: Sébastien Hinderer <Sebastien.Hinderer@ens-lyon.org>
Cc: Samuel Thibault <Samuel.Thibault@ens-lyon.org>
The sysfs attributes for the 24x7 counters are dynamically allocated.
Initialize the attributes using sysfs_attr_init() to fix following
warning which occurs when CONFIG_DEBUG_LOCK_VMALLOC=y.
[ 0.346249] audit: initializing netlink subsys (disabled)
[ 0.346284] audit: type=2000 audit(1436295254.340:1): initialized
[ 0.346489] BUG: key c0000000efe90198 not in .data!
[ 0.346491] DEBUG_LOCKS_WARN_ON(1)
[ 0.346502] ------------[ cut here ]------------
[ 0.346504] WARNING: at ../kernel/locking/lockdep.c:3002
[ 0.346506] Modules linked in:
Reported-by: Gustavo Luiz Duarte <gustavold@linux.vnet.ibm.com>
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Tested-by: Gustavo Luiz Duarte <gustavold@linux.vnet.ibm.com>
Commit 46e12c07b3b9603c60fc1d421ff18618241cb081 (MIPS: O32 / 32-bit:
Always copy 4 stack arguments.) change the O32 syscall handler to always
load four arguments from the userspace stack even for syscalls that
require fewer or no arguments to be copied. This removes a large table
from kernel space and need to maintain it. It appeared that it was ok
the implementation chosen requires 16 bytes of readable stack space
above the user stack pointer.
Turned out a few threading implementations munmap the user stack before
the thread exits resulting in errors due to the unreadable stack.
We now treat any failed load as a if the loaded value was zero and let
the actual syscall deal with the situation.
Pull ARM updates from Russell King:
"These are late by a week; they should have been merged during the
merge window, but unfortunately, the ARM kernel build/boot farms were
indicating random failures, and it wasn't clear whether the cause was
something in these changes or something during the merge window.
This is a set of merge window fixes with some documentation additions"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm:
ARM: avoid unwanted GCC memset()/memcpy() optimisations for IO variants
ARM: pgtable: document mapping types
ARM: io: convert ioremap*() to functions
ARM: io: fix ioremap_wt() implementation
ARM: io: document ARM specific behaviour of ioremap*() implementations
ARM: fix lockdep unannotated irqs-off warning
ARM: 8397/1: fix vdsomunge not to depend on glibc specific error.h
ARM: add helpful message when truncating physical memory
ARM: add help text for HIGHPTE configuration entry
ARM: fix DEBUG_SET_MODULE_RONX build dependencies
ARM: 8396/1: use phys_addr_t in pfn_to_kaddr()
ARM: 8394/1: update memblock limit after mapping lowmem
ARM: 8393/1: smp: Fix suspicious RCU usage with ipi tracepoints
CC arch/mips/loongson64/lemote-2f/clock.o
/home/ralf/src/linux/linux-mips/arch/mips/loongson64/lemote-2f/clock.c:18:40: fatal error: asm/mach-loongson/loongson.h: No such file or directory
#include <asm/mach-loongson/loongson.h>
compilation terminated.
Move EDAC_SUPPORT to the right place.
For those parts of the arm64 ACPI code that need to check GICC subtables
in the MADT, use the new BAD_MADT_GICC_ENTRY macro instead of the previous
BAD_MADT_ENTRY. The new macro takes into account differences in the size
of the GICC subtable that the old macro did not; this caused failures even
though the subtable entries are valid.
Fixes: aeb823bbacc2 ("ACPICA: ACPI 6.0: Add changes for FADT table.")
Signed-off-by: Al Stone <al.stone@linaro.org>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
