The get_dumpable() return value is not boolean. Most users of the
function actually want to be testing for non-SUID_DUMP_USER(1) rather than
SUID_DUMP_DISABLE(0). The SUID_DUMP_ROOT(2) is also considered a
protected state. Almost all places did this correctly, excepting the two
places fixed in this patch.
Wrong logic:
if (dumpable == SUID_DUMP_DISABLE) { /* be protective */ }
or
if (dumpable == 0) { /* be protective */ }
or
if (!dumpable) { /* be protective */ }
Correct logic:
if (dumpable != SUID_DUMP_USER) { /* be protective */ }
or
if (dumpable != 1) { /* be protective */ }
Without this patch, if the system had set the sysctl fs/suid_dumpable=2, a
user was able to ptrace attach to processes that had dropped privileges to
that user. (This may have been partially mitigated if Yama was enabled.)
The macros have been moved into the file that declares get/set_dumpable(),
which means things like the ia64 code can see them too.
CVE-2013-2929
Reported-by: Vasily Kulikov <segoon@openwall.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: <stable@vger.kernel.org>
Since gen_pool_dma_alloc() is introduced, we implement it to simplify code.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Only a couple of arches (sh/x86) use fpu_counter in task_struct so it can
be moved out into ARCH specific thread_struct, reducing the size of
task_struct for other arches.
Compile tested i386_defconfig + gcc 4.7.3
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Paul Mundt <paul.mundt@gmail.com>
Compile tested sh defconfig + sh4-linux-gcc (4.6.3)
glibc recently changed the error string for ESTALE to remove "NFS" -
https://sourceware.org/git/?p=glibc.git;a=commitdiff;h=96945714ec61951cc748da2b4b8a80cf02127ee9
from: [ERR_REMAP (ESTALE)] = N_("Stale NFS file handle"),
to: [ERR_REMAP (ESTALE)] = N_("Stale file handle"),
And some have expressed concern that the kernel's errno.h
comments still refer to NFS.
So make that change... note that this is a comment-only change,
and has no functional difference.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Zhi Yong Wu <wuzhy@linux.vnet.ibm.com>
The hot-Pluggable field in SRAT specifies which memory is hotpluggable.
As we mentioned before, if hotpluggable memory is used by the kernel, it
cannot be hot-removed. So memory hotplug users may want to set all
hotpluggable memory in ZONE_MOVABLE so that the kernel won't use it.
Memory hotplug users may also set a node as movable node, which has
ZONE_MOVABLE only, so that the whole node can be hot-removed.
But the kernel cannot use memory in ZONE_MOVABLE. By doing this, the
kernel cannot use memory in movable nodes. This will cause NUMA
performance down. And other users may be unhappy.
So we need a way to allow users to enable and disable this functionality.
In this patch, we introduce movable_node boot option to allow users to
choose to not to consume hotpluggable memory at early boot time and later
we can set it as ZONE_MOVABLE.
To achieve this, the movable_node boot option will control the memblock
allocation direction. That said, after memblock is ready, before SRAT is
parsed, we should allocate memory near the kernel image as we explained in
the previous patches. So if movable_node boot option is set, the kernel
does the following:
1. After memblock is ready, make memblock allocate memory bottom up.
2. After SRAT is parsed, make memblock behave as default, allocate memory
top down.
Users can specify "movable_node" in kernel commandline to enable this
functionality. For those who don't use memory hotplug or who don't want
to lose their NUMA performance, just don't specify anything. The kernel
will work as before.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Suggested-by: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Suggested-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Toshi Kani <toshi.kani@hp.com>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Jiang Liu <jiang.liu@huawei.com>
Cc: Wen Congyang <wency@cn.fujitsu.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Cc: Taku Izumi <izumi.taku@jp.fujitsu.com>
Cc: Michal Nazarewicz <mina86@mina86.com>
Cc: Minchan Kim <minchan@kernel.org>
Memory reserved for crashkernel could be large. So we should not allocate
this memory bottom up from the end of kernel image.
When SRAT is parsed, we will be able to know which memory is hotpluggable,
and we can avoid allocating this memory for the kernel. So reorder
reserve_crashkernel() after SRAT is parsed.
Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
The Linux kernel cannot migrate pages used by the kernel. As a result,
kernel pages cannot be hot-removed. So we cannot allocate hotpluggable
In a memory hotplug system, any numa node the kernel resides in should be
unhotpluggable. And for a modern server, each node could have at least
16GB memory. So memory around the kernel image is highly likely
unhotpluggable.
ACPI SRAT (System Resource Affinity Table) contains the memory hotplug
info. But before SRAT is parsed, memblock has already started to allocate
memory for the kernel. So we need to prevent memblock from doing this.
So direct memory mapping page tables setup is the case.
init_mem_mapping() is called before SRAT is parsed. To prevent page
tables being allocated within hotpluggable memory, we will use bottom-up
direction to allocate page tables from the end of kernel image to the
higher memory.
Note:
As for allocating page tables in lower memory, TJ said:
: This is an optional behavior which is triggered by a very specific kernel
: boot param, which I suspect is gonna need to stick around to support
: memory hotplug in the current setup unless we add another layer of address
: translation to support memory hotplug.
As for page tables may occupy too much lower memory if using 4K mapping
(CONFIG_DEBUG_PAGEALLOC and CONFIG_KMEMCHECK both disable using >4k
pages), TJ said:
: But as I said in the same paragraph, parsing SRAT earlier doesn't solve
: the problem in itself either. Ignoring the option if 4k mapping is
: required and memory consumption would be prohibitive should work, no?
: Something like that would be necessary if we're gonna worry about cases
: like this no matter how we implement it, but, frankly, I'm not sure this
: is something worth worrying about.
Create a new function memory_map_top_down to factor out of the top-down
direct memory mapping pagetable setup. This is also a preparation for the
following patch, which will introduce the bottom-up memory mapping. That
said, we will put the two ways of pagetable setup into separate functions,
and choose to use which way in init_mem_mapping, which makes the code more
clear.
Implement mmap base randomization for the bottom up direction, so ASLR
works for both mmap layouts on s390. See also commit df54d6fa5427 ("x86
get_unmapped_area(): use proper mmap base for bottom-up direction").
Cc: Radu Caragea <sinaelgl@gmail.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Use more appropriate NUMA_NO_NODE instead of -1 in all archs' module_alloc()
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Acked-by: David Rientjes <rientjes@google.com>
Use "pgdat_end_pfn()" instead of "pgdat->node_start_pfn +
pgdat->node_spanned_pages". Simplify the code, no functional change.
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
Cc: James Hogan <james.hogan@imgtec.com>
The callers of free_pgd_range() and hugetlb_free_pgd_range() don't hold
page table locks. The comments seems to be obsolete, so let's remove
them.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Use __free_reserved_page() to simplify the code in arch.
It used split_page() in consistent_alloc()/__dma_alloc_coherent()/dma_alloc_coherent(),
so page->_count == 1, and we can free it safely.
ClearPageReserved()
init_page_count() // it won't change the value
__free_page()
On cris arch, the functions below aren't defined:
drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_read':
drivers/media/platform/sh_veu.c:228:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
drivers/media/platform/sh_veu.c: In function 'sh_veu_reg_write':
drivers/media/platform/sh_veu.c:234:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_read':
drivers/media/platform/vsp1/vsp1.h:66:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
drivers/media/platform/vsp1/vsp1.h: In function 'vsp1_write':
drivers/media/platform/vsp1/vsp1.h:71:2: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_setup':
drivers/media/platform/soc_camera/rcar_vin.c:284:3: error: implicit declaration of function 'iowrite32' [-Werror=implicit-function-declaration]
drivers/media/platform/soc_camera/rcar_vin.c: In function 'rcar_vin_request_capture_stop':
drivers/media/platform/soc_camera/rcar_vin.c:353:2: error: implicit declaration of function 'ioread32' [-Werror=implicit-function-declaration]
Yet, they're available, as CONFIG_GENERIC_IOMAP is defined. What happens
is that asm/io.h was not including asm-generic/iomap.h.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Remove useless variable 'regs' to avoid the related warnings (warning is
treated as error).
Signed-off-by: Chen Gang <gang.chen@asianux.com>
'fn' is not defined, according to the implementation copy_thread() in
'sh32', need use 'usp' instead of.
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
"DeviceTree updates for 3.13. This is a bit larger pull request than
usual for this cycle with lots of clean-up.
- Cross arch clean-up and consolidation of early DT scanning code.
- Clean-up and removal of arch prom.h headers. Makes arch specific
prom.h optional on all but Sparc.
- Addition of interrupts-extended property for devices connected to
multiple interrupt controllers.
- Refactoring of DT interrupt parsing code in preparation for
deferred probe of interrupts.
- ARM cpu and cpu topology bindings documentation.
- Various DT vendor binding documentation updates"
* tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits)
powerpc: add missing explicit OF includes for ppc
dt/irq: add empty of_irq_count for !OF_IRQ
dt: disable self-tests for !OF_IRQ
of: irq: Fix interrupt-map entry matching
MIPS: Netlogic: replace early_init_devtree() call
of: Add Panasonic Corporation vendor prefix
of: Add Chunghwa Picture Tubes Ltd. vendor prefix
of: Add AU Optronics Corporation vendor prefix
of/irq: Fix potential buffer overflow
of/irq: Fix bug in interrupt parsing refactor.
of: set dma_mask to point to coherent_dma_mask
of: add vendor prefix for PHYTEC Messtechnik GmbH
DT: sort vendor-prefixes.txt
of: Add vendor prefix for Cadence
of: Add empty for_each_available_child_of_node() macro definition
arm/versatile: Fix versatile irq specifications.
of/irq: create interrupts-extended property
microblaze/pci: Drop PowerPC-ism from irq parsing
of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.
of/irq: Use irq_of_parse_and_map()
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds
Pull LED subsystem changes from Bryan Wu:
"LED subsystem updates for 3.13 are basically cleanup and also add a
new driver for PCA9685"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds:
leds: lp55xx: handle enable pin in driver
leds-gpio: of: led should not be created if its status is disabled
of: introduce of_get_available_child_count
leds: Added driver for the NXP PCA9685 I2C chip
leds: pwm: Remove redundant of_match_ptr
leds: Include linux/of.h header
leds: dac124s085: Remove redundant spi_set_drvdata
leds: lp55xx: enable setting default trigger
leds: blinkm: Remove redundant break
Pull clock framework changes from Mike Turquette:
"The clock changes for 3.13 are an even mix of framework improvements &
bug fixes along with updates to existing clock drivers and the
additional of new clock drivers"
* tag 'clk-for-linus-3.13' of git://git.linaro.org/people/mturquette/linux:
clk: new driver for efm32 SoC
clk: of: helper for determining number of parent clocks
clk/zynq: Fix possible memory leak
clk: keystone: Build Keystone clock drivers
clk: keystone: Add gate control clock driver
clk: keystone: add Keystone PLL clock driver
Documentation: Add documentation for APM X-Gene clock binding
clk: arm64: Add DTS clock entry for APM X-Gene Storm SoC
clk: Add APM X-Gene SoC clock driver
clk: wm831x: get rid of the implementation of remove function
clk: Correct lookup logic in clk_fetch_parent_index()
clk: Use kcalloc() to allocate arrays
clk: Add error handling to clk_fetch_parent_index()
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"Here is the bulk of GPIO changes for the v3.13 development cycle.
I've got ACKs for the things that affect other subsystems (or it's my
own subsystem, like pinctrl). Most of that pertain to an attempt from
my side to consolidate and get rid of custom GPIO implementations in
the ARM tree. I will continue doing this.
The main change this time is the new GPIO descriptor API, background
for this can be found in Corbet's summary from this january in LWN:
http://lwn.net/Articles/533632/
Summary:
- Merged the GPIO descriptor API from Alexandre Courbot. This is a
first step toward trying to get rid of the global GPIO numberspace
for the future.
- Add an API so that driver can flag that a certain GPIO line is
being used by a irqchip backend for generating IRQs, so that we can
enforce checks, like not allowing users to switch that line to an
output at runtime, since this makes no sense. Implemented
corresponding calls in a few select drivers.
- ACPI GPIO cleanups, refactorings and switch to using the
descriptor-based interface.
- Support for the TPS80036 Palmas GPIO variant.
- A new driver for the Broadcom Kona GPIO SoC IP block.
- Device tree support for the PCF857x driver.
- A set of ARM GPIO refactorings with the goal of getting rid of a
bunch of custom GPIO implementations from the arch/arm/* tree:
* Move the IOP GPIO driver to the GPIO subsystem and fix all users
to use the gpiolib API for accessing GPIOs. Delete the old
custom GPIO implementation.
* Delete the unused custom PXA GPIO implemention.
* Convert all users of the IXP4 custom GPIO implementation to use
gpiolib and delete the custom implementation.
* Delete the custom Gemini GPIO implementation, also completely
unused.
- Various cleanups and renamings"
* tag 'gpio-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits)
gpio: gpio-mxs: Remove unneeded dt checks
gpio: pl061: don't depend on CONFIG_ARM
gpio: bcm-kona: add missing .owner to struct gpio_chip
gpiolib: provide a declaration of seq_file in gpio/driver.h
gpiolib: include gpio/consumer.h in of_gpio.h for desc_to_gpio()
gpio: provide stubs for devres gpio functions
gpiolib: devres: add missing headers
gpiolib: make GPIO_DEVRES depend on GPIOLIB
gpiolib: devres: fix devm_gpiod_get_index()
gpiolib / ACPI: document the GPIO descriptor based interface
gpiolib / ACPI: allow passing GPIOF_ACTIVE_LOW for GpioInt resources
gpiolib / ACPI: add ACPI support for gpiod_get_index()
gpiolib / ACPI: convert to gpiod interfaces
gpiolib: add gpiod_get() and gpiod_put() functions
gpiolib: port of_ functions to use gpiod
gpiolib: export descriptor-based GPIO interface
Fixup "MAINTAINERS: GPIO-INTEL-MID: add maintainer"
gpio: bcm281xx: Don't print addresses of GPIO area in probe()
gpio: tegra: use new gpio_lock_as_irq() API
gpio: rcar: Include linux/of.h header
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"Main pin control pull request for the v3.13 cycle.
The changes hitting arch/blackfin are ACKed by the Blackfin
maintainer, and the device tree bindings are ACKed to the extent
possible by someone from the device tree maintainers group.
- Blackfin ADI pin control driver, we move yet another architecture
under this subsystem umbrella.
- Incremental updates to the Renesas Super-H PFC pin control driver.
New subdriver for the r8a7791 SoC.
- Non-linear GPIO ranges from the gpiolib side of things, this
enabled simplified device tree bindings by referring entire groups
of pins on some pin controller to act as back-end for a certain
GPIO-chip driver.
- Add the Abilis TB10x pin control driver used on the ARC
architecture. Also the corresponding GPIO driver is merged through
this tree, so the ARC has full support for pins and GPIOs after
this.
- Subdrivers for Freescale i.MX1, i.MX27 and i.MX50 pin controller
instances. The i.MX1 and i.MX27 is an entirely new family
(silicon) of controllers whereas i.MX50 is a variant of the
previous supported controller.
- Then the usual slew of fixes, cleanups and incremental updates"
The ARC DT changes are apparently still pending, that hopefully gets
sorted out in a timely manner.
* tag 'pinctrl-for-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (48 commits)
pinctrl: imx50: add pinctrl support code for the IMX50 SoC
pinctrl: at91: copy define to driver
pinctrl: remove minor dead code
pinctrl: imx: fix using pin->input_val wrongly
pinctrl: imx1: fix return value check in imx1_pinctrl_core_probe()
gpio: tb10x: fix return value check in tb10x_gpio_probe()
gpio: tb10x: use module_platform_driver to simplify the code
pinctrl: imx27: imx27 pincontrol driver
pinctrl: imx1 core driver
pinctrl: sh-pfc: r8a7791 PFC support
sh-pfc: r8a7778: Add CAN pin groups
gpio: add TB10x GPIO driver
pinctrl: at91: correct a few typos
pinctrl: mvebu: remove redundant of_match_ptr
pinctrl: tb10x: use module_platform_driver to simplify the code
pinctrl: tb10x: fix the error handling in tb10x_pinctrl_probe()
pinctrl: add documentation for pinctrl_get_group_pins()
pinctrl: rockchip: emulate both edge triggered interrupts
pinctrl: rockchip: add rk3188 specifics
pinctrl: rockchip: remove redundant check
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator updates from Mark Brown:
"Lots of driver updates here plus some nice new core features, the main
one being the first:
- Enable support for providing a dummy regulator when we know that
one must exist for the device to be functional. This makes it much
easier to add regulator support to drivers since we don't require
that the machine integration for all systems using the device be
updated to provide regulators.
- Substantial reduction in the amount of busy waiting done while
waiting for enables to complete.
- Allow MFDs to distribute regulator supplies to child devices so we
don't have to expose the internal structure of MFDs outside of the
driver.
- Managed registeration for regulators"
* tag 'regulator-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (113 commits)
regulator: s5m8767: Modify parsing method of the voltage table of buck2/3/4
regulator: s5m8767: Modify parse_dt function to parse data related to ramp
regulator: da9052: Revert se apply_[reg|bit] with regmap based voltage_sel operations
mfd: arizona: Specify supply mappings for Arizona CODECs
mfd: Allow mapping regulator supplies to MFD device from children
regulator: core: Add ability to create a lookup alias for supply
regulator: tps65910: Fix checkpatch issue
regulator: tps65023: Fix checkpatch issue
regulator: tps6105x: Fix checkpatch issue
regulator: mc13783: Fix checkpatch issue
regulator: max8997: Fix checkpatch issue
regulator: lp3971: Fix checkpatch issue
regulator: fixed: Fix checkpatch issue
regulator: anatop: Fix checkpatch issue
regulator: Add REGULATOR_LINEAR_RANGE macro
regulator: Remove max_uV from struct regulator_linear_range
regulator: ti-abb: Fix operator precedence typo
regulator: tps65910: get regulators node from parent node only
regulator: tps6586x: get regulators node from parent node only
regulator: tps65090: get regulators node from parent node only
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Benjamin Herrenschmidt:
"The bulk of this is LE updates. One should now be able to build an LE
kernel and even run some things in it.
I'm still sitting on a handful of patches to enable the new ABI that I
*might* still send this merge window around, but due to the
incertainty (they are pretty fresh) I want to keep them separate.
Other notable changes are some infrastructure bits to better handle
PCI pass-through under KVM, some bits and pieces added to the new
PowerNV platform support such as access to the CPU SCOM bus via sysfs,
and support for EEH error handling on PHB3 (Power8 PCIe).
We also grew arch_get_random_long() for both pseries and powernv when
running on P7+ and P8, exploiting the HW rng.
And finally various embedded updates from freescale"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (154 commits)
powerpc: Fix fatal SLB miss when restoring PPR
powerpc/powernv: Reserve the correct PE number
powerpc/powernv: Add PE to its own PELTV
powerpc/powernv: Add support for indirect XSCOM via debugfs
powerpc/scom: Improve debugfs interface
powerpc/scom: Enable 64-bit addresses
powerpc/boot: Properly handle the base "of" boot wrapper
powerpc/bpf: Support MOD operation
powerpc/bpf: Fix DIVWU instruction opcode
of: Move definition of of_find_next_cache_node into common code.
powerpc: Remove big endianness assumption in of_find_next_cache_node
powerpc/tm: Remove interrupt disable in __switch_to()
powerpc: word-at-a-time optimization for 64-bit Little Endian
powerpc/bpf: BPF JIT compiler for 64-bit Little Endian
powerpc: Only save/restore SDR1 if in hypervisor mode
powerpc/pmu: Fix ADB_PMU_LED_IDE dependencies
powerpc/nvram: Fix endian issue when using the partition length
powerpc/nvram: Fix endian issue when reading the NVRAM size
powerpc/nvram: Scan partitions only once
powerpc/mpc512x: remove unnecessary #if
Pull microblaze updates from Michal Simek:
- Get rid of NO_MMU Kconfig
- mmap2 fixups
- Some minor cleanups
* tag 'microblaze-3.13-rc1' of git://git.monstr.eu/linux-2.6-microblaze:
microblaze: Remove incorrect file path
microblaze: Fix bug with mmap2 syscall MB implementation
microblaze: Use predefined SYSCALL_DEFINE macro
microblaze: Remove deprecated IRQF_DISABLED
microblaze: Calculate kernel pad automatically
microblaze: Remove unused NO_MMU Kconfig parameter
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag
Pull metag architecture changes from James Hogan:
- A change to remove the last dependence on bootloader exception
handlers so that QEMU can more easily boot an SMP Linux/Meta kernel
image directly.
- A fix for a minor off by one error in a BUG_ON condition found by Dan
Carpenter.
* tag 'metag-for-v3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag:
metag: off by one in setup_bootmem_node()
metag: handle low level kicks directly
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull h8300 platform removal from Guenter Roeck:
"The patch series has been in -next for more than one relase cycle. I
did get a number of Acks, and no objections.
H8/300 has been dead for several years, the kernel for it has not
compiled for ages, and recent versions of gcc for it are broken.
Remove support for it"
* tag 'h8300-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
CREDITS: Add Yoshinori Sato for h8300
fs/minix: Drop dependency on H8300
Drop remaining references to H8/300 architecture
Drop MAINTAINERS entry for H8/300
watchdog: Drop references to H8300 architecture
net/ethernet: Drop H8/300 Ethernet driver
net/ethernet: smsc9194: Drop conditional code for H8/300
ide: Drop H8/300 driver
Drop support for Renesas H8/300 (h8300) architecture
Pull x86 UV debug changes from Ingo Molnar:
"Various SGI UV debuggability improvements, amongst them KDB support,
with related core KDB enabling patches changing kernel/debug/kdb/"
* 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "x86/UV: Add uvtrace support"
x86/UV: Add call to KGDB/KDB from NMI handler
kdb: Add support for external NMI handler to call KGDB/KDB
x86/UV: Check for alloc_cpumask_var() failures properly in uv_nmi_setup()
x86/UV: Add kdump to UV NMI handler
x86/UV: Add summary of cpu activity to UV NMI handler
x86/UV: Update UV support for external NMI signals
x86/UV: Move NMI support
Pull x86 uaccess changes from Ingo Molnar:
"A single change that micro-optimizes __copy_*_user_inatomic(), used by
the futex code"
* 'x86-uaccess-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Add 1/2/4/8 byte optimization to 64bit __copy_{from,to}_user_inatomic
Pull x86 reboot changes from Ingo Molnar:
"Misc changes - the only one with functional impact should be commit
16c21ae5ca63 ("reboot: Allow specifying warm/cold reset for CF9 boot
type") which extends cold/warm reboot handling to the 0xCF9 reboot
method"
* 'x86-reboot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/reboot: Correct pr_info() log message in the set_bios/pci/kbd_reboot()
x86/reboot: Sort reboot DMI quirks by vendor
x86/reboot: Remove the duplicate C6100 entry in the reboot quirks list
reboot: Allow specifying warm/cold reset for CF9 boot type
Pull x86 platform fixlet from Ingo Molnar:
"A single __initdata fix"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/geode: Fix incorrect placement of __initdata tag
Pull x86 mm fixlet from Ingo Molnar:
"One cleanup that documents a particular detail in init_mem_mapping()"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mm: Add 'step_size' comments to init_mem_mapping()
Pull x86 RAS changes from Ingo Molnar:
"The biggest change adds support for Intel 'CPER' (UEFI Common Platform
Error Record) error logging, which builds upon an enhanced error
logging mechanism available on Xeon processors.
Full description is here:
http://www.intel.com/content/www/us/en/architecture-and-technology/enhanced-mca-logging-xeon-paper.html
This change provides a module (and support code) to check for an
extended error log and prints extra details about the error on the
console"
* 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
ACPI, x86: Fix extended error log driver to depend on CONFIG_X86_LOCAL_APIC
dmi: Avoid unaligned memory access in save_mem_devices()
Move cper.c from drivers/acpi/apei to drivers/firmware/efi
EDAC, GHES: Update ghes error record info
ACPI, APEI, CPER: Cleanup CPER memory error output format
ACPI, APEI, CPER: Enhance memory reporting capability
ACPI, APEI, CPER: Add UEFI 2.4 support for memory error
DMI: Parse memory device (type 17) in SMBIOS
ACPI, x86: Extended error log driver for x86 platform
bitops: Introduce a more generic BITMASK macro
ACPI, CPER: Update cper info
ACPI, APEI, CPER: Fix status check during error printing
Pull x86 iommu changes from Ingo Molnar:
"Make it easier to turn off the old AMD GART code"
* 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/iommu: Clean up the CONFIG_GART_IOMMU config option a bit
x86/iommu: Don't make AMD_GART depend on EXPERT and default y
Pull x86/intel-mid changes from Ingo Molnar:
"Update the 'intel mid' (mobile internet device) platform code as Intel
is rolling out more SoC designs.
This gets rid of most of the 'MRST' platform code in the process,
mostly by renaming and shuffling code around into their respective
'intel-mid' platform drivers"
* 'x86-intel-mid-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, intel-mid: Do not re-introduce usage of obsolete __cpuinit
intel_mid: Move platform device setups to their own platform_<device>.* files
x86: intel-mid: Add section for sfi device table
intel-mid: sfi: Allow struct devs_id.get_platform_data to be NULL
intel_mid: Moved SFI related code to sfi.c
intel_mid: Added custom handler for ipc devices
intel_mid: Added custom device_handler support
intel_mid: Refactored sfi_parse_devs() function
intel_mid: Renamed *mrst* to *intel_mid*
pci: intel_mid: Return true/false in function returning bool
mrst: Fixed indentation issues
mrst: Fixed printk/pr_* related issues
Pull x86/hyperv changes from Ingo Molnar:
"These changes enable Linux guests to boot as 'Modern VM' guest kernels
on MS-Hyperv hosts"
* 'x86-hyperv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, hyperv: Move a variable to avoid an unused variable warning
x86, hyperv: Fix build error due to missing <asm/apic.h> include
x86, hyperv: Correctly guard the local APIC calibration code
x86, hyperv: Get the local APIC timer frequency from the hypervisor
Pull x86 EFI changes from Ingo Molnar:
"Main changes:
- Add support for earlyprintk=efi which uses the EFI framebuffer.
Very useful for debugging boot problems.
- EFI stub support for large memory maps (more than 128 entries)
- EFI ARM support - this was mostly done by generalizing x86 <-> ARM
platform differences, such as by moving x86 EFI code into
drivers/firmware/efi/ and sharing it with ARM.
- Documentation updates
- misc fixes"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits)
x86/efi: Add EFI framebuffer earlyprintk support
boot, efi: Remove redundant memset()
x86/efi: Fix config_table_type array termination
x86 efi: bugfix interrupt disabling sequence
x86: EFI stub support for large memory maps
efi: resolve warnings found on ARM compile
efi: Fix types in EFI calls to match EFI function definitions.
efi: Renames in handle_cmdline_files() to complete generalization.
efi: Generalize handle_ramdisks() and rename to handle_cmdline_files().
efi: Allow efi_free() to be called with size of 0
efi: use efi_get_memory_map() to get final map for x86
efi: generalize efi_get_memory_map()
efi: Rename __get_map() to efi_get_memory_map()
efi: Move unicode to ASCII conversion to shared function.
efi: Generalize relocate_kernel() for use by other architectures.
efi: Move relocate_kernel() to shared file.
efi: Enforce minimum alignment of 1 page on allocations.
efi: Rename memory allocation/free functions
efi: Add system table pointer argument to shared functions.
efi: Move common EFI stub code from x86 arch code to common location
Pull x86 cpu changes from Ingo Molnar:
"The biggest change that stands out is the increase of the
CONFIG_NR_CPUS range from 4096 to 8192 - as real hardware out there
already went beyond 4k CPUs ...
We only allow more than 512 CPUs if offstack cpumasks are enabled.
CONFIG_MAXSMP=y remains to be the 'you are nuts!' extreme testcase,
which now means a max of 8192 CPUs"
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/cpu: Increase max CPU count to 8192
x86/cpu: Allow higher NR_CPUS values
x86/cpu: Always print SMP information in /proc/cpuinfo
x86/cpu: Track legacy CPU model data only on 32-bit kernels
Pull x86 cleanups from Ingo Molnar:
"Two small cleanups"
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, msr: Use file_inode(), not f_mapping->host
x86: mkpiggy.c: Explicitly close the output file
Pull x86 build changes from Ingo Molnar:
"Two small changes"
* 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, defconfig: Add DEVTMPFS and DEVTMPFS_MOUNT to *86*_defconfig
x86, build: move build output statistics away from stderr
Pull x86 boot changes from Ingo Molnar:
"Two changes that prettify and compactify the SMP bootup output from:
smpboot: Booting Node 0, Processors #1 #2 #3 OK
smpboot: Booting Node 1, Processors #4 #5 #6 #7 OK
smpboot: Booting Node 2, Processors #8 #9 #10 #11 OK
smpboot: Booting Node 3, Processors #12 #13 #14 #15 OK
Brought up 16 CPUs
to something like:
x86: Booting SMP configuration:
.... node #0, CPUs: #1 #2 #3
.... node #1, CPUs: #4 #5 #6 #7
.... node #2, CPUs: #8 #9 #10 #11
.... node #3, CPUs: #12 #13 #14 #15
x86: Booted up 4 nodes, 16 CPUs"
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/boot: Further compress CPUs bootup message
x86: Improve the printout of the SMP bootup CPU table
Pull x86 user access changes from Ingo Molnar:
"This tree contains two copy_[from/to]_user() build time checking
changes/enhancements from Jan Beulich.
The desired outcome is to get better compiler warnings with
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS=y, to keep people from
introducing bugs such as overflows and information leaks"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Unify copy_to_user() and add size checking to it
x86: Unify copy_from_user() size checking
Pull x86/apic fix from Ingo Molnar:
"A single fix to the IO-APIC / local-APIC shutdown sequence"
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/apic: Disable I/O APIC before shutdown of the local APIC
Pull timer changes from Ingo Molnar:
"Main changes in this cycle were:
- Updated full dynticks support.
- Event stream support for architected (ARM) timers.
- ARM clocksource driver updates.
- Move arm64 to using the generic sched_clock framework & resulting
cleanup in the generic sched_clock code.
- Misc fixes and cleanups"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits)
x86/time: Honor ACPI FADT flag indicating absence of a CMOS RTC
clocksource: sun4i: remove IRQF_DISABLED
clocksource: sun4i: Report the minimum tick that we can program
clocksource: sun4i: Select CLKSRC_MMIO
clocksource: Provide timekeeping for efm32 SoCs
clocksource: em_sti: convert to clk_prepare/unprepare
time: Fix signedness bug in sysfs_get_uname() and its callers
timekeeping: Fix some trivial typos in comments
alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist
clocksource: arch_timer: Do not register arch_sys_counter twice
timer stats: Add a 'Collection: active/inactive' line to timer usage statistics
sched_clock: Remove sched_clock_func() hook
arch_timer: Move to generic sched_clock framework
clocksource: tcb_clksrc: Remove IRQF_DISABLED
clocksource: tcb_clksrc: Improve driver robustness
clocksource: tcb_clksrc: Replace clk_enable/disable with clk_prepare_enable/disable_unprepare
clocksource: arm_arch_timer: Use clocksource for suspend timekeeping
clocksource: dw_apb_timer_of: Mark a few more functions as __init
clocksource: Put nodes passed to CLOCKSOURCE_OF_DECLARE callbacks centrally
arm: zynq: Enable arm_global_timer
Pull scheduler changes from Ingo Molnar:
"The main changes in this cycle are:
- (much) improved CONFIG_NUMA_BALANCING support from Mel Gorman, Rik
van Riel, Peter Zijlstra et al. Yay!
- optimize preemption counter handling: merge the NEED_RESCHED flag
into the preempt_count variable, by Peter Zijlstra.
- wait.h fixes and code reorganization from Peter Zijlstra
- cfs_bandwidth fixes from Ben Segall
- SMP load-balancer cleanups from Peter Zijstra
- idle balancer improvements from Jason Low
- other fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
ftrace, sched: Add TRACE_FLAG_PREEMPT_RESCHED
stop_machine: Fix race between stop_two_cpus() and stop_cpus()
sched: Remove unnecessary iteration over sched domains to update nr_busy_cpus
sched: Fix asymmetric scheduling for POWER7
sched: Move completion code from core.c to completion.c
sched: Move wait code from core.c to wait.c
sched: Move wait.c into kernel/sched/
sched/wait: Fix __wait_event_interruptible_lock_irq_timeout()
sched: Avoid throttle_cfs_rq() racing with period_timer stopping
sched: Guarantee new group-entities always have weight
sched: Fix hrtimer_cancel()/rq->lock deadlock
sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining
sched: Fix race on toggling cfs_bandwidth_used
sched: Remove extra put_online_cpus() inside sched_setaffinity()
sched/rt: Fix task_tick_rt() comment
sched/wait: Fix build breakage
sched/wait: Introduce prepare_to_wait_event()
sched/wait: Add ___wait_cond_timeout() to wait_event*_timeout() too
sched: Remove get_online_cpus() usage
sched: Fix race in migrate_swap_stop()
Pull perf updates from Ingo Molnar:
"As a first remark I'd like to note that the way to build perf tooling
has been simplified and sped up, in the future it should be enough for
you to build perf via:
cd tools/perf/
make install
(ie without the -j option.) The build system will figure out the
number of CPUs and will do a parallel build+install.
The various build system inefficiencies and breakages Linus reported
against the v3.12 pull request should now be resolved - please
(re-)report any remaining annoyances or bugs.
Main changes on the perf kernel side:
* Performance optimizations:
. perf ring-buffer code optimizations, by Peter Zijlstra
. perf ring-buffer code optimizations, by Oleg Nesterov
. x86 NMI call-stack processing optimizations, by Peter Zijlstra
. perf context-switch optimizations, by Peter Zijlstra
. perf sampling speedups, by Peter Zijlstra
. x86 Intel PEBS processing speedups, by Peter Zijlstra
* Enhanced hardware support:
. for Intel Ivy Bridge-EP uncore PMUs, by Zheng Yan
. for Haswell transactions, by Andi Kleen, Peter Zijlstra
* Core perf events code enhancements and fixes by Oleg Nesterov:
. for uprobes, if fork() is called with pending ret-probes
. for uprobes platform support code
* New ABI details by Andi Kleen:
. Report x86 Haswell TSX transaction abort cost as weight
Main changes on the perf tooling side (some of these tooling changes
utilize the above kernel side changes):
* 'perf report/top' enhancements:
. Convert callchain children list to rbtree, greatly reducing the
time taken for callchain processing, from Namhyung Kim.
. Add new COMM infrastructure, further improving histogram
processing, from Frédéric Weisbecker, one fix from Namhyung Kim.
. Add /proc/kcore based live-annotation improvements, including
build-id cache support, multi map 'call' instruction navigation
fixes, kcore address validation, objdump workarounds. From
Adrian Hunter.
. Show progress on histogram collapsing, that can take a long
time, from Namhyung Kim.
. Add --max-stack option to limit callchain stack scan in 'top'
and 'report', improving callchain processing when reducing the
stack depth is an option, from Waiman Long.
. Add new option --ignore-vmlinux for perf top, from Willy
Tarreau.
* 'perf trace' enhancements:
. 'perf trace' now can can use a 'perf probe' dynamic tracepoints
to hook into the userspace -> kernel pathname copy so that it
can map fds to pathnames without reading /proc/pid/fd/ symlinks.
From Arnaldo Carvalho de Melo.
. Show VFS path associated with fd in live sessions, using a
'vfs_getname' 'perf probe' created dynamic tracepoint or by
looking at /proc/pid/fd, from Arnaldo Carvalho de Melo.
. Add 'trace' beautifiers for lots of syscall arguments, from
. Implement more compact 'trace' output by suppressing zeroed
args, from Arnaldo Carvalho de Melo.
. Show thread COMM by default in 'trace', from Arnaldo Carvalho de
Melo.
. Add option to show full timestamp in 'trace', from David Ahern.
. Add 'record' command in 'trace', to record raw_syscalls:*, from
David Ahern.
. Add summary option to dump syscall statistics in 'trace', from
David Ahern.
. Improve error messages in 'trace', providing hints about system
configuration steps needed for using it, from Ramkumar
Ramachandra.
. 'perf trace' now emits hints as to why tracing is not possible,
helping the user to setup the system to allow tracing in the
desired permission granularity, telling if the problem is due to
debugfs not being mounted or with not enough permission for
!root, /proc/sys/kernel/perf_event_paranoit value, etc. From
* 'perf record' enhancements:
. Check maximum frequency rate for record/top, emitting better
error messages, from Jiri Olsa.
. 'perf record' code cleanups, from David Ahern.
. Improve write_output error message in 'perf record', from Adrian
Hunter.
. Allow specifying B/K/M/G unit to the --mmap-pages arguments,
from Jiri Olsa.
. Fix command line callchain attribute tests to handle the new
-g/--call-chain semantics, from Arnaldo Carvalho de Melo.
* 'perf kvm' enhancements:
. Disable live kvm command if timerfd is not supported, from David
Ahern.
. Fix detection of non-core features, from David Ahern.
* 'perf list' enhancements:
. Add usage to 'perf list', from David Ahern.
. Show error in 'perf list' if tracepoints not available, from
Pekka Enberg.
* 'perf probe' enhancements:
. Support "$vars" meta argument syntax for local variables,
allowing asking for all possible variables at a given probe
point to be collected when it hits, from Masami Hiramatsu.
* 'perf sched' enhancements:
. Address the root cause of that 'perf sched' stack initialization
build slowdown, by programmatically setting a big array after
moving the global variable back to the stack. Fix from Adrian
Hunter.
* 'perf script' enhancements:
. Set up output options for in-stream attributes, from Adrian
Hunter.
. Print addr by default for BTS in 'perf script', from Adrian
Juntmer
* 'perf stat' enhancements:
. Improved messages when doing profiling in all or a subset of
CPUs using a workload as the session delimitator, as in:
'perf stat --cpu 0,2 sleep 10s'
. Add units to nanosec-based counters in 'perf stat', from David
Ahern.
. Remove bogus info when using 'perf stat' -e cycles/instructions,
from Ramkumar Ramachandra.
* 'perf lock' enhancements:
. 'perf lock' fixes and cleanups, from Davidlohr Bueso.
* 'perf test' enhancements:
. Fixup PERF_SAMPLE_TRANSACTION handling in sample synthesizing
and 'perf test', from Adrian Hunter.
. Clarify the "sample parsing" test entry, from Arnaldo Carvalho
de Melo.
. Consider PERF_SAMPLE_TRANSACTION in the "sample parsing" test,
. Memory leak fixes in 'perf test', from Felipe Pena.
* 'perf bench' enhancements:
. Change the procps visible command-name of invididual benchmark
tests plus cleanups, from Ingo Molnar.
* Generic perf tooling infrastructure/plumbing changes:
. Separating data file properties from session, code
reorganization from Jiri Olsa.
. Fix version when building out of tree, as when using one of
these:
$ make help | grep perf
perf-tar-src-pkg - Build perf-3.12.0.tar source tarball
perf-targz-src-pkg - Build perf-3.12.0.tar.gz source tarball
perf-tarbz2-src-pkg - Build perf-3.12.0.tar.bz2 source tarball
perf-tarxz-src-pkg - Build perf-3.12.0.tar.xz source tarball
from David Ahern.
. Enhance option parse error message, showing just the help lines
of the options affected, from Namhyung Kim.
. libtraceevent updates from upstream trace-cmd repo, from Steven
Rostedt.
. Always use perf_evsel__set_sample_bit to set sample_type, from
Adrian Hunter.
. Memory and mmap leak fixes from Chenggang Qin.
. Assorted build fixes for from David Ahern and Jiri Olsa.
. Speed up and prettify the build system, from Ingo Molnar.
. Implement addr2line directly using libbfd, from Roberto Vitillo.
. Separate the GTK support in a separate libperf-gtk.so DSO, that
is only loaded when --gtk is specified, from Namhyung Kim.
. perf bash completion fixes and improvements from Ramkumar
Ramachandra.
. Support for Openembedded/Yocto -dbg packages, from Ricardo
Ribalda Delgado.
And lots and lots of other fixes and code reorganizations that did not
make it into the list, see the shortlog, diffstat and the Git log for
details!"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (300 commits)
uprobes: Fix the memory out of bound overwrite in copy_insn()
uprobes: Fix the wrong usage of current->utask in uprobe_copy_process()
perf tools: Remove unneeded include
perf record: Remove post_processing_offset variable
perf record: Remove advance_output function
perf record: Refactor feature handling into a separate function
perf trace: Don't relookup fields by name in each sample
perf tools: Fix version when building out of tree
perf evsel: Ditch evsel->handler.data field
uprobes: Export write_opcode() as uprobe_write_opcode()
uprobes: Introduce arch_uprobe->ixol
uprobes: Kill module_init() and module_exit()
uprobes: Move function declarations out of arch
perf/x86/intel: Add Ivy Bridge-EP uncore IRP box support
perf/x86/intel/uncore: Add filter support for IvyBridge-EP QPI boxes
perf: Factor out strncpy() in perf_event_mmap_event()
tools/perf: Add required memory barriers
perf: Fix arch_perf_out_copy_user default
perf: Update a stale comment
perf: Optimize perf_output_begin() -- address calculation
Pull IRQ changes from Ingo Molnar:
"The biggest change this cycle are the softirq/hardirq stack
interaction and nesting fixes, cleanups and reorganizations from
Frederic. This is the longer followup story to the softirq nesting
fix that is already upstream (commit ded797547548: "irq: Force hardirq
exit's softirq processing on its own stack")"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip: bcm2835: Convert to use IRQCHIP_DECLARE macro
powerpc: Tell about irq stack coverage
x86: Tell about irq stack coverage
irq: Optimize softirq stack selection in irq exit
irq: Justify the various softirq stack choices
irq: Improve a bit softirq debugging
irq: Optimize call to softirq on hardirq exit
irq: Consolidate do_softirq() arch overriden implementations
x86/irq: Correct comment about i8259 initialization
This reverts commit 8eba18428ac926f436064ac281e76d36d51bd631.
uv_trace() is not used by anything, nor is uv_trace_nmi_func, nor
uv_trace_func.
That's not how we do instrumentation code in the kernel: we add
tracepoints, printk()s, etc. so that everyone not just those with
magic kernel modules can debug a system.
So remove this unused (and misguied) piece of code.
Cc: Mike Travis <travis@sgi.com>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Cc: Hedi Berriche <hedi@sgi.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Jason Wessel <jason.wessel@windriver.com>
Link: http://lkml.kernel.org/n/tip-tumfBffmr4jmnt8Gyxanoblg@git.kernel.org
Commit b5b4bb3f6a11f9 (of: only include prom.h on sparc) removed implicit
includes of of_*.h headers by powerpc's prom.h. Some components were
missed in initial clean-up patch, so add the necessary includes to fix
powerpc builds.
Cc: Tejun Heo <tj@kernel.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: linux-ide@vger.kernel.org
Cc: linux-crypto@vger.kernel.org
