commit d4a5c59a955bba96b273ec1a5885bada24c56979 upstream.
au1xmmc is split somewhat awkwardly into the main mmc subsystem driver,
and callbacks in platform_data that sit under arch/mips/ and are
always built in. The latter than call mmc_detect_change through
symbol_get. Remove the use of symbol_get by requiring the driver
to be built in. In the future the interrupt handlers for card
insert/eject detection should probably be moved into the main driver,
and which point it can be built modular again.
Acked-by: Manuel Lauss <manuel.lauss@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
[mcgrof: squashed in depends on MMC=y suggested by Arnd]
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
commit 0faa29c4207e6e29cfc81b427df60e326c37083a upstream.
The spitz board file uses the obscure symbol_get() function
to optionally call a function from sharpsl_pm.c if that is
built. However, the two files are always built together
these days, and have been for a long time, so this can
be changed to a normal function call.
Link: https://lore.kernel.org/lkml/20230731162639.GA9441@lst.de/
This reverts commit a365600bba27c35d0d93fd490b01919fbd7d4848 which is
commit 2d645604f69f3a772d58ead702f9a8e84ab2b342 upstream.
It breaks the build, so should be dropped.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Link: https://lore.kernel.org/r/5b30ff73-46cb-1d1e-3823-f175dbfbd91b@roeck-us.net
Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Cc: Sasha Levin <sashal@kernel.org>
commit a4037d1f1fc4e92b69d7196d4568c33078d465ea upstream.
core99_l2_cache/core99_l3_cache do not need to be marked as volatile,
remove it.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Link: https://lore.kernel.org/r/20200303085604.24952-1-yuehaibing@huawei.com
commit 9451c79bc39e610882bdd12370f01af5004a3c4f upstream.
When building with ppc64_defconfig, the compiler reports
that these 2 variables are not used:
warning: unused variable 'core99_l2_cache' [-Wunused-variable]
warning: unused variable 'core99_l3_cache' [-Wunused-variable]
They are only used when CONFIG_PPC64 is not defined. Move
them into a section which does the same macro check.
Reported-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Ilie Halip <ilie.halip@gmail.com>
[mpe: Move them into core99_init_caches() which is their only user]
Link: https://lore.kernel.org/r/20190920153951.25762-1-ilie.halip@gmail.com
Cc: Nathan Chancellor <nathan@kernel.org>
commit 2c66ca3949dc701da7f4c9407f2140ae425683a5 upstream.
0-Day found a 34.6% regression in stress-ng's 'af-alg' test case, and
bisected it to commit b81fac906a8f ("x86/fpu: Move FPU initialization into
arch_cpu_finalize_init()"), which optimizes the FPU init order, and moves
the CR4_OSXSAVE enabling into a later place:
identify_boot_cpu
identify_cpu
generic_identify
get_cpu_cap --> setup cpu capability
fpu__init_cpu
fpu__init_cpu_xstate
cr4_set_bits(X86_CR4_OSXSAVE);
As the FPU is not yet initialized the CPU capability setup fails to set
X86_FEATURE_OSXSAVE. Many security module like 'camellia_aesni_avx_x86_64'
depend on this feature and therefore fail to load, causing the regression.
Cure this by setting X86_FEATURE_OSXSAVE feature right after OSXSAVE
enabling.
[ tglx: Moved it into the actual BSP FPU initialization code and added a comment ]
Fixes: b81fac906a8f ("x86/fpu: Move FPU initialization into arch_cpu_finalize_init()")
Reported-by: kernel test robot <oliver.sang@intel.com>
Signed-off-by: Feng Tang <feng.tang@intel.com>
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/lkml/202307192135.203ac24e-oliver.sang@intel.com
Link: https://lore.kernel.org/lkml/20230823065747.92257-1-feng.tang@intel.com
[ Upstream commit 5487a7b60695a92cf998350e4beac17144c91fcd ]
Some CPU feature macros were using current_cpu_type to mark feature
availability.
However current_cpu_type will use smp_processor_id, which is prohibited
under preemptable context.
Since those features are all uniform on all CPUs in a SMP system, use
boot_cpu_type instead of current_cpu_type to fix preemptable kernel.
Signed-off-by: Jiaxun Yang <jiaxun.yang@flygoat.com>
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
[ Upstream commit f641519409a73403ee6612b8648b95a688ab85c2 ]
cpu_has_octeon_cache was tied to 0 for generic cpu-features,
whith this generic kernel built for octeon CPU won't boot.
Just enable this flag by cpu_type. It won't hurt orther platforms
because compiler will eliminate the code path on other processors.
Stable-dep-of: 5487a7b60695 ("MIPS: cpu-features: Use boot_cpu_type for CPU type based features")
[ Upstream commit 0a2b96e42a0284c4fc03022236f656a085ca714a ]
If the tuning step is not set, the tuning step is set to 1.
For some sd cards, the following Tuning timeout will occur.
Tuning failed, falling back to fixed sampling clock
So set the default tuning step. This refers to the NXP vendor's
commit below:
https://github.com/nxp-imx/linux-imx/blob/lf-6.1.y/
arch/arm/boot/dts/imx6sx.dtsi#L1108-L1109
Fixes: 1e336aa0c025 ("mmc: sdhci-esdhc-imx: correct the tuning start tap and step setting")
Signed-off-by: Xiaolei Wang <xiaolei.wang@windriver.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
[ Upstream commit be18293e47cbca7c6acee9231fc851601d69563a ]
mmc0: Tuning failed, falling back to fixed sampling clock
commit below:
arch/arm/boot/dts/imx7s.dtsi#L1216-L1217
[ Upstream commit e9f5cd85f1f931bb7b64031492f7051187ccaac7 ]
Currently the dtbs_check generates warnings like this:
$nodename:0: 'dma-apbh@110000' does not match '^dma-controller(@.*)?$'
So fix all affected dma-apbh node names.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
Stable-dep-of: be18293e47cb ("ARM: dts: imx: Set default tuning step for imx7d usdhc")
[ Upstream commit 9928f0a9e7c0cee3360ca1442b4001d34ad67556 ]
Drop "interrupt-names" property, since it is broken. The drivers/dma/mxs-dma.c
in Linux kernel does not use it, the property contains duplicate array entries
in existing DTs, and even malformed entries (gmpi, should have been gpmi). Get
rid of that optional property altogether.
commit 4f3175979e62de3b929bfa54a0db4b87d36257a7 upstream.
With hardened usercopy enabled (CONFIG_HARDENED_USERCOPY=y), using the
/proc/powerpc/rtas/firmware_update interface to prepare a system
firmware update yields a BUG():
kernel BUG at mm/usercopy.c:102!
Oops: Exception in kernel mode, sig: 5 [#1]
LE PAGE_SIZE=64K MMU=Hash SMP NR_CPUS=2048 NUMA pSeries
Modules linked in:
CPU: 0 PID: 2232 Comm: dd Not tainted 6.5.0-rc3+ #2
Hardware name: IBM,8408-E8E POWER8E (raw) 0x4b0201 0xf000004 of:IBM,FW860.50 (SV860_146) hv:phyp pSeries
NIP: c0000000005991d0 LR: c0000000005991cc CTR: 0000000000000000
REGS: c0000000148c76a0 TRAP: 0700 Not tainted (6.5.0-rc3+)
MSR: 8000000000029033 <SF,EE,ME,IR,DR,RI,LE> CR: 24002242 XER: 0000000c
CFAR: c0000000001fbd34 IRQMASK: 0
[ ... GPRs omitted ... ]
NIP usercopy_abort+0xa0/0xb0
LR usercopy_abort+0x9c/0xb0
Call Trace:
usercopy_abort+0x9c/0xb0 (unreliable)
__check_heap_object+0x1b4/0x1d0
__check_object_size+0x2d0/0x380
rtas_flash_write+0xe4/0x250
proc_reg_write+0xfc/0x160
vfs_write+0xfc/0x4e0
ksys_write+0x90/0x160
system_call_exception+0x178/0x320
system_call_common+0x160/0x2c4
The blocks of the firmware image are copied directly from user memory
to objects allocated from flash_block_cache, so flash_block_cache must
be created using kmem_cache_create_usercopy() to mark it safe for user
access.
Fixes: 6d07d1cd300f ("usercopy: Restrict non-usercopy caches to size 0")
Signed-off-by: Nathan Lynch <nathanl@linux.ibm.com>
[mpe: Trim and indent oops]
Link: https://msgid.link/20230810-rtas-flash-vs-hardened-usercopy-v2-1-dcf63793a938@linux.ibm.com
[ Upstream commit ccb381e1af1ace292153c88eb1fffa5683d16a20 ]
As per the generic KASAN code in mm/kasan, disable KCOV with
KCOV_INSTRUMENT := n in the makefile.
This fixes a ppc64 boot hang when KCOV and KASAN are enabled.
kasan_early_init() gets called before a PACA is initialised, but the
KCOV hook expects a valid PACA.
Suggested-by: Christophe Leroy <christophe.leroy@csgroup.eu>
Signed-off-by: Benjamin Gray <bgray@linux.ibm.com>
Link: https://msgid.link/20230710044143.146840-1-bgray@linux.ibm.com
[ Upstream commit 7b191b9b55df2a844bd32d1d380f47a7df1c2896 ]
Zero-length arrays are deprecated, and we are replacing them with flexible
array members instead. So, replace zero-length array with flexible-array
member in struct memmap.
Address the following warning found after building (with GCC-13) mips64
with decstation_64_defconfig:
In function 'rex_setup_memory_region',
inlined from 'prom_meminit' at arch/mips/dec/prom/memory.c:91:3:
arch/mips/dec/prom/memory.c:72:31: error: array subscript i is outside array bounds of 'unsigned char[0]' [-Werror=array-bounds=]
72 | if (bm->bitmap[i] == 0xff)
In file included from arch/mips/dec/prom/memory.c:16:
./arch/mips/include/asm/dec/prom.h: In function 'prom_meminit':
./arch/mips/include/asm/dec/prom.h:73:23: note: while referencing 'bitmap'
73 | unsigned char bitmap[0];
This helps with the ongoing efforts to globally enable -Warray-bounds.
This results in no differences in binary output.
Link: https://github.com/KSPP/linux/issues/79
Link: https://github.com/KSPP/linux/issues/323
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
commit 6ccbd7fd474674654019a20177c943359469103a upstream.
EXPORT_SYMBOL and __init is a bad combination because the .init.text
section is freed up after the initialization.
Commit c5a130325f13 ("ACPI/APEI: Add parameter check before error
injection") exported page_is_ram(), hence the __init annotation should
be removed.
This fixes the modpost warning in ARCH=alpha builds:
WARNING: modpost: vmlinux: page_is_ram: EXPORT_SYMBOL used for init symbol. Remove __init or EXPORT_SYMBOL.
Fixes: c5a130325f13 ("ACPI/APEI: Add parameter check before error injection")
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Reviewed-by: Randy Dunlap <rdunlap@infradead.org>
commit eb3515dc99c7c85f4170b50838136b2a193f8012 upstream.
The declaration got placed in the .c file of the caller, but that
causes a warning for the definition:
arch/x86/kernel/cpu/bugs.c:682:6: error: no previous prototype for 'gds_ucode_mitigated' [-Werror=missing-prototypes]
Move it to a header where both sides can observe it instead.
Fixes: 81ac7e5d74174 ("KVM: Add GDS_NO support to KVM")
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Tested-by: Daniel Sneddon <daniel.sneddon@linux.intel.com>
Cc: stable@kernel.org
Link: https://lore.kernel.org/all/20230809130530.1913368-2-arnd%40kernel.org
commit 1b8b1aa90c9c0e825b181b98b8d9e249dc395470 upstream.
Yingcong has noticed that on the 5-level paging machine, VDSO and VVAR
VMAs are placed above the 47-bit border:
8000001a9000-8000001ad000 r--p 00000000 00:00 0 [vvar]
8000001ad000-8000001af000 r-xp 00000000 00:00 0 [vdso]
This might confuse users who are not aware of 5-level paging and expect
all userspace addresses to be under the 47-bit border.
So far problem has only been triggered with ASLR disabled, although it
may also occur with ASLR enabled if the layout is randomized in a just
right way.
The problem happens due to custom placement for the VMAs in the VDSO
code: vdso_addr() tries to place them above the stack and checks the
result against TASK_SIZE_MAX, which is wrong. TASK_SIZE_MAX is set to
the 56-bit border on 5-level paging machines. Use DEFAULT_MAP_WINDOW
instead.
Fixes: b569bab78d8d ("x86/mm: Prepare to expose larger address space to userspace")
Reported-by: Yingcong Wu <yingcong.wu@intel.com>
Link: https://lore.kernel.org/all/20230803151609.22141-1-kirill.shutemov%40linux.intel.com
commit 6dbef74aeb090d6bee7d64ef3fa82ae6fa53f271 upstream.
Commit
522b1d69219d ("x86/cpu/amd: Add a Zenbleed fix")
provided a fix for the Zen2 VZEROUPPER data corruption bug affecting
a range of CPU models, but the AMD Custom APU 0405 found on SteamDeck
was not listed, although it is clearly affected by the vulnerability.
Add this CPU variant to the Zenbleed erratum list, in order to
unconditionally enable the fallback fix until a proper microcode update
is available.
Fixes: 522b1d69219d ("x86/cpu/amd: Add a Zenbleed fix")
Signed-off-by: Cristian Ciocaltea <cristian.ciocaltea@collabora.com>
Signed-off-by: Borislav Petkov (AMD) <bp@alien8.de>
Link: https://lore.kernel.org/r/20230811203705.1699914-1-cristian.ciocaltea@collabora.com
commit b3607269ff57fd3c9690cb25962c5e4b91a0fd3b upstream.
This cannot work and it's unclear how that ever made a difference.
init_fpstate.xsave.header.xfeatures is always 0 so get_xsave_addr() will
always return a NULL pointer, which will prevent storing the default PKRU
value in init_fpstate.
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: https://lkml.kernel.org/r/20210623121451.451391598@linutronix.de
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@canonical.com>
[ Upstream commit ee70b908f77a9d8f689dea986f09e6d7dc481934 ]
Property name "phy-3p0-supply" is used instead of "phy-reg_3p0-supply".
Fixes: 9f30b6b1a957 ("ARM: dts: imx: Add basic dtsi file for imx6sll")
cc: <stable@vger.kernel.org>
Signed-off-by: Xu Yang <xu.yang_2@nxp.com>
[ Upstream commit 1875903019ea6e32e6e544c1631b119e4fd60b20 ]
Make operating point definitions comply with binding
specifications.
Signed-off-by: Andreas Kemnade <andreas@kemnade.info>
Reviewed-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com>
Stable-dep-of: ee70b908f77a ("ARM: dts: nxp/imx6sll: fix wrong property name in usbphy node")
[ Upstream commit 5c8b3b8a182cbc1ccdfcdeea9b25dd2c12a8148f ]
Add usb alias for bootloader searching the controller in correct order.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
[ Upstream commit 69cc1502a87f5ed12e27dbe5fe2bfdd5540826c7 ]
Fix dtschema validator warnings like:
l2-cache@a02000: $nodename:0:
'l2-cache@a02000' does not match '^(cache-controller|cpu)(@[0-9a-f,]+)*$'
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 5da1b522cf7dc51f7fde2cca8d90406b0291c503 ]
In imx6sll.dtsi, the ssi node name is different with other
platforms (imx6qdl, imx6sl, imx6sx), but the
sound/soc/fsl/fsl-asoc-card.c machine driver needs to check
ssi node name for audmux configuration, then different ssi
node name causes issue on imx6sll platform.
So we change ssi node name to make all platforms have same
name.
Signed-off-by: Shengjiu Wang <shengjiu.wang@nxp.com>
[ Upstream commit db66795f61354c373ecdadbdae1ed253a96c47cb ]
The correct dts property for the SCL falling time is
"i2c-scl-falling-time-ns".
Fixes: c8da1d15b8a4 ("arm64: dts: stratix10: i2c clock running out of spec")
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
[ Upstream commit 6722b25712054c0f903b839b8f5088438dd04df3 ]
altmap->free includes the entire free space from which altmap blocks
can be allocated. So when checking whether the kernel is doing altmap
block free, compute the boundary correctly, otherwise memory hotunplug
can fail.
Fixes: 9ef34630a461 ("powerpc/mm: Fallback to RAM if the altmap is unusable")
Signed-off-by: "Aneesh Kumar K.V" <aneesh.kumar@linux.ibm.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Link: https://msgid.link/20230724181320.471386-1-aneesh.kumar@linux.ibm.com
[ Upstream commit 0c02cc576eac161601927b41634f80bfd55bfa9e ]
Commit 9fb6c9b3fea1 ("s390/sthyi: add cache to store hypervisor info")
added cache handling for store hypervisor info. This also changed the
possible return code for sthyi_fill().
Instead of only returning a condition code like the sthyi instruction would
do, it can now also return a negative error value (-ENOMEM). handle_styhi()
was not changed accordingly. In case of an error, the negative error value
would incorrectly injected into the guest PSW.
Add proper error handling to prevent this, and update the comment which
describes the possible return values of sthyi_fill().
Fixes: 9fb6c9b3fea1 ("s390/sthyi: add cache to store hypervisor info")
Reviewed-by: Christian Borntraeger <borntraeger@linux.ibm.com>
Link: https://lore.kernel.org/r/20230727182939.2050744-1-hca@linux.ibm.com
Signed-off-by: Heiko Carstens <hca@linux.ibm.com>
[ Upstream commit 79e8328e5acbe691bbde029a52c89d70dcbc22f3 ]
Compiling big-endian targets with Clang produces the diagnostic:
fs/namei.c:2173:13: warning: use of bitwise '|' with boolean operands [-Wbitwise-instead-of-logical]
} while (!(has_zero(a, &adata, &constants) | has_zero(b, &bdata, &constants)));
fs/namei.c:2173:13: note: cast one or both operands to int to silence this warning
It appears that when has_zero was introduced, two definitions were
produced with different signatures (in particular different return
types).
Looking at the usage in hash_name() in fs/namei.c, I suspect that
has_zero() is meant to be invoked twice per while loop iteration; using
logical-or would not update `bdata` when `a` did not have zeros. So I
think it's preferred to always return an unsigned long rather than a
bool than update the while loop in hash_name() to use a logical-or
rather than bitwise-or.
[ Also changed powerpc version to do the same - Linus ]
Link: https://github.com/ClangBuiltLinux/linux/issues/1832
Link: https://lore.kernel.org/lkml/20230801-bitwise-v1-1-799bec468dc4@google.com/
Fixes: 36126f8f2ed8 ("word-at-a-time: make the interfaces truly generic")
Debugged-by: Nathan Chancellor <nathan@kernel.org>
Signed-off-by: Nick Desaulniers <ndesaulniers@google.com>
Acked-by: Heiko Carstens <hca@linux.ibm.com>
commit 8ec8490a1950efeccb00967698cf7cb2fcd25ca7 upstream.
CONFIG_UBSAN_SHIFT with gcc-5 complains that the shifting of
ARM_CPU_IMP_AMPERE (0xC0) into bits [31:24] by MIDR_CPU_MODEL() is
undefined behavior. Well, sort of, it actually spells the error as:
arch/arm64/kernel/proton-pack.c: In function 'spectre_bhb_loop_affected':
arch/arm64/include/asm/cputype.h:44:2: error: initializer element is not constant
(((imp) << MIDR_IMPLEMENTOR_SHIFT) | \
This isn't an issue for other Implementor codes, as all the other codes
have zero in the top bit and so are representable as a signed int.
Cast the implementor code to unsigned in MIDR_CPU_MODEL to remove the
undefined behavior.
Fixes: 0e5d5ae837c8 ("arm64: Add AMPERE1 to the Spectre-BHB affected list")
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: D Scott Phillips <scott@os.amperecomputing.com>
Link: https://lore.kernel.org/r/20221102160106.1096948-1-scott@os.amperecomputing.com
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
commit 0e5d5ae837c8ce04d2ddb874ec5f920118bd9d31 upstream.
Per AmpereOne erratum AC03_CPU_12, "Branch history may allow control of
speculative execution across software contexts," the AMPERE1 core needs the
bhb clearing loop to mitigate Spectre-BHB, with a loop iteration count of
11.
Link: https://lore.kernel.org/r/20221011022140.432370-1-scott@os.amperecomputing.com
Reviewed-by: James Morse <james.morse@arm.com>
Stable-tree-only change.
Due to the way the GDS and SRSO patches flowed into the stable tree, it
was a 50% chance that the merge of the which value GDS and SRSO should
be. Of course, I lost that bet, and chose the opposite of what Linus
chose in commit 64094e7e3118 ("Merge tag 'gds-for-linus-2023-08-01' of
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip")
Fix this up by switching the values to match what is now in Linus's tree
as that is the correct value to mirror.
commit 8415a74852d7c24795007ee9862d25feb519007c upstream.
Add support for CPUID leaf 80000021, EAX. The majority of the features will be
used in the kernel and thus a separate leaf is appropriate.
Include KVM's reverse_cpuid entry because features are used by VM guests, too.
[ bp: Massage commit message. ]
Signed-off-by: Kim Phillips <kim.phillips@amd.com>
Acked-by: Sean Christopherson <seanjc@google.com>
Link: https://lore.kernel.org/r/20230124163319.2277355-2-kim.phillips@amd.com
[bwh: Backported to 6.1: adjust context]
Signed-off-by: Ben Hutchings <benh@debian.org>
Upstream commit: 0e52740ffd10c6c316837c6c128f460f1aaba1ea
There was never a doubt in my mind that they would not fit into a single
u32 eventually.
commit fb35d30fe5b06cc24444f0405da8fbe0be5330d1 upstream.
Collect the scattered SME/SEV related feature flags into a dedicated
word. There are now five recognized features in CPUID.0x8000001F.EAX,
with at least one more on the horizon (SEV-SNP). Using a dedicated word
allows KVM to use its automagic CPUID adjustment logic when reporting
the set of supported features to userspace.
No functional change intended.
Signed-off-by: Sean Christopherson <seanjc@google.com>
Reviewed-by: Brijesh Singh <brijesh.singh@amd.com>
Link: https://lkml.kernel.org/r/20210122204047.2860075-2-seanjc@google.com
commit 69372cf01290b9587d2cee8fbe161d75d55c3adc upstream.
On systems that do not have hardware enforced cache coherency between
encrypted and unencrypted mappings of the same physical page, the
hypervisor can use the VM page flush MSR (0xc001011e) to flush the cache
contents of an SEV guest page. When a small number of pages are being
flushed, this can be used in place of issuing a WBINVD across all CPUs.
CPUID 0x8000001f_eax[2] is used to determine if the VM page flush MSR is
available. Add a CPUID feature to indicate it is supported and define the
MSR.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Message-Id: <f1966379e31f9b208db5257509c4a089a87d33d0.1607620209.git.thomas.lendacky@amd.com>
commit 360e7c5c4ca4fd8e627781ed42f95d58bc3bb732 upstream.
Add CPU feature detection for Secure Encrypted Virtualization with
Encrypted State. This feature enhances SEV by also encrypting the
guest register state, making it in-accessible to the hypervisor.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Link: https://lkml.kernel.org/r/20200907131613.12703-6-joro@8bytes.org
commit 3f4c8211d982099be693be9aa7d6fc4607dff290 upstream.
Instead of duplicating init_mm, allocate a fresh mm. The advantage is
that mm_alloc() has much simpler dependencies. Additionally it makes
more conceptual sense, init_mm has no (and must not have) user state
to duplicate.
Link: https://lkml.kernel.org/r/20221025201057.816175235@infradead.org
commit 26ce6ec364f18d2915923bc05784084e54a5c4cc upstream.
Commit 3f4c8211d982 ("x86/mm: Use mm_alloc() in poking_init()") broke
the kernel for running as Xen PV guest.
It seems as if the new address space is never activated before being
used, resulting in Xen rejecting to accept the new CR3 value (the PGD
isn't pinned).
Fix that by adding the now missing call of paravirt_arch_dup_mmap() to
poking_init(). That call was previously done by dup_mm()->dup_mmap() and
it is a NOP for all cases but for Xen PV, where it is just doing the
pinning of the PGD.
Fixes: 3f4c8211d982 ("x86/mm: Use mm_alloc() in poking_init()")
Signed-off-by: Juergen Gross <jgross@suse.com>
Link: https://lkml.kernel.org/r/20230109150922.10578-1-jgross@suse.com
commit fe3e0a13e597c1c8617814bf9b42ab732db5c26e upstream.
Moving the call of fpu__init_cpu() from cpu_init() to start_secondary()
broke Xen PV guests, as those don't call start_secondary() for APs.
Call fpu__init_cpu() in Xen's cpu_bringup(), which is the Xen PV
replacement of start_secondary().
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: https://lore.kernel.org/r/20230703130032.22916-1-jgross@suse.com
commit 81ac7e5d741742d650b4ed6186c4826c1a0631a7 upstream
Gather Data Sampling (GDS) is a transient execution attack using
gather instructions from the AVX2 and AVX512 extensions. This attack
allows malicious code to infer data that was previously stored in
vector registers. Systems that are not vulnerable to GDS will set the
GDS_NO bit of the IA32_ARCH_CAPABILITIES MSR. This is useful for VM
guests that may think they are on vulnerable systems that are, in
fact, not affected. Guests that are running on affected hosts where
the mitigation is enabled are protected as if they were running
on an unaffected system.
On all hosts that are not affected or that are mitigated, set the
GDS_NO bit.
Signed-off-by: Daniel Sneddon <daniel.sneddon@linux.intel.com>
Acked-by: Josh Poimboeuf <jpoimboe@kernel.org>
commit 53cf5797f114ba2bd86d23a862302119848eff19 upstream
Gather Data Sampling (GDS) is mitigated in microcode. However, on
systems that haven't received the updated microcode, disabling AVX
can act as a mitigation. Add a Kconfig option that uses the microcode
mitigation if available and disables AVX otherwise. Setting this
option has no effect on systems not affected by GDS. This is the
equivalent of setting gather_data_sampling=force.
commit 553a5c03e90a6087e88f8ff878335ef0621536fb upstream
The Gather Data Sampling (GDS) vulnerability allows malicious software
to infer stale data previously stored in vector registers. This may
include sensitive data such as cryptographic keys. GDS is mitigated in
microcode, and systems with up-to-date microcode are protected by
default. However, any affected system that is running with older
microcode will still be vulnerable to GDS attacks.
Since the gather instructions used by the attacker are part of the
AVX2 and AVX512 extensions, disabling these extensions prevents gather
instructions from being executed, thereby mitigating the system from
GDS. Disabling AVX2 is sufficient, but we don't have the granularity
to do this. The XCR0[2] disables AVX, with no option to just disable
AVX2.
Add a kernel parameter gather_data_sampling=force that will enable the
microcode mitigation if available, otherwise it will disable AVX on
affected systems.
This option will be ignored if cmdline mitigations=off.
This is a *big* hammer. It is known to break buggy userspace that
uses incomplete, buggy AVX enumeration. Unfortunately, such userspace
does exist in the wild:
https://www.mail-archive.com/bug-coreutils@gnu.org/msg33046.html
[ dhansen: add some more ominous warnings about disabling AVX ]
commit 8974eb588283b7d44a7c91fa09fcbaf380339f3a upstream
Gather Data Sampling (GDS) is a hardware vulnerability which allows
unprivileged speculative access to data which was previously stored in
vector registers.
Intel processors that support AVX2 and AVX512 have gather instructions
that fetch non-contiguous data elements from memory. On vulnerable
hardware, when a gather instruction is transiently executed and
encounters a fault, stale data from architectural or internal vector
registers may get transiently stored to the destination vector
register allowing an attacker to infer the stale data using typical
side channel techniques like cache timing attacks.
This mitigation is different from many earlier ones for two reasons.
First, it is enabled by default and a bit must be set to *DISABLE* it.
This is the opposite of normal mitigation polarity. This means GDS can
be mitigated simply by updating microcode and leaving the new control
bit alone.
Second, GDS has a "lock" bit. This lock bit is there because the
mitigation affects the hardware security features KeyLocker and SGX.
It needs to be enabled and *STAY* enabled for these features to be
mitigated against GDS.
The mitigation is enabled in the microcode by default. Disable it by
setting gather_data_sampling=off or by disabling all mitigations with
mitigations=off. The mitigation status can be checked by reading:
/sys/devices/system/cpu/vulnerabilities/gather_data_sampling
commit b81fac906a8f9e682e513ddd95697ec7a20878d4 upstream
Initializing the FPU during the early boot process is a pointless
exercise. Early boot is convoluted and fragile enough.
Nothing requires that the FPU is set up early. It has to be initialized
before fork_init() because the task_struct size depends on the FPU register
buffer size.
Move the initialization to arch_cpu_finalize_init() which is the perfect
place to do so.
No functional change.
This allows to remove quite some of the custom early command line parsing,
but that's subject to the next installment.
Link: https://lore.kernel.org/r/20230613224545.902376621@linutronix.de
commit 1703db2b90c91b2eb2d699519fc505fe431dde0e upstream
No point in keeping them around.
Link: https://lore.kernel.org/r/20230613224545.841685728@linutronix.de
commit 1f34bb2a24643e0087652d81078e4f616562738d upstream
Nothing in the call chain requires it
Link: https://lore.kernel.org/r/20230613224545.783704297@linutronix.de
commit 439e17576eb47f26b78c5bbc72e344d4206d2327 upstream
Invoke the X86ism mem_encrypt_init() from X86 arch_cpu_finalize_init() and
remove the weak fallback from the core code.
Link: https://lore.kernel.org/r/20230613224545.670360645@linutronix.de
commit 61235b24b9cb37c13fcad5b9596d59a1afdcec30 upstream
Everything is converted over to arch_cpu_finalize_init(). Remove the
check_bugs() leftovers including the empty stubs in asm-generic, alpha,
parisc, powerpc and xtensa.
Reviewed-by: Richard Henderson <richard.henderson@linaro.org>
Link: https://lore.kernel.org/r/20230613224545.553215951@linutronix.de
commit 9349b5cd0908f8afe95529fc7a8cbb1417df9b0c upstream
check_bugs() is about to be phased out. Switch over to the new
arch_cpu_finalize_init() implementation.
Acked-by: Richard Weinberger <richard@nod.at>
Link: https://lore.kernel.org/r/20230613224545.493148694@linutronix.de
