This patch fixes the following DTC warnings:
"Node /memory has a reg or ranges property, but no unit name"
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
The skeleton.dtsi file was removed in ARM64 for different reasons as
explained in commit ("3ebee5a2e141 arm64: dts: kill skeleton.dtsi").
These also applies to ARM and it will also allow to get rid of the
following DTC warnings in the future:
The disassembled DTB are almost the same besides an empty chosen
node being removed and nodes reordered, so it shouldn't have
functional changes.
Since no am4372 based board had a memory node defined, a dummy node
is added so the compiled DTB memory node is the same than before.
node being removed and nodes reordered, so it should not have
functional changes.
functional changes.
functional changes.
functional changes.
functional changes.
functional changes.
functional changes.
functional changes.
But these boards don't have a memory node defined, so removing the
skeleton.dtsi inclusion from omap3.dtsi will cause a change in the
compiled DTB. Add a dummy memory node so the compiled DTB doesn't
change if the skeleton.dtsi is removed from omap3.dtsi.
Eventually the correct starting addresses and sizes should be used
but I didn't find that information.
But the sl50 board doesn't have a, so removing the skeleton.dtsi
inclusion from am33xx.dtsi will cause a change in the compiled DTB.
The board has 512 MiB of RAM and its starting address is 0x80000000,
so add a proper memory device node in the DTS.
Current clocks tree definition for CPSW/CPTS doesn't
correspond TRM for dra7/am57 SoCs.
CPTS: has to be sourced from gmac_rft_clk_mux clock
CPSW: DPLL_GMAC -> CLKOUT_M2 -> GMAC_250M_CLK -> 1/2 ->
-> GMAC_MAIN_CLK (125 MHZ)
Hence, correct clock tree for GMAC_MAIN_CLK and use proper
clock for CPTS. This also require updating of CPTS clock
multiplier.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Tero Kristo <t-kristo@ti.com>
This commit fixes the clock data inside the DRA7xx clocks device tree
structure for the gmac_gmii_ref_clk_div clock. This clock is actually
the GMAC_MAIN_CLK and has nothing to do with the register at address
0x4a0093d0. If CLKSEL_REF bit 24 inside of CM_GMAC_GMAC_CLKCTRL, is
set to 1 in order to use the GMAC_RMII_CLK instead of the
GMAC_RMII_HS_CLK, the kernel generates a clock divider warning:
WARNING: CPU: 0 PID: 0 at drivers/clk/clk-divider.c:129 clk_divider_recalc_rate+0xa8/0xe0()
gmac_gmii_ref_clk_div: Zero divisor and CLK_DIVIDER_ALLOW_ZERO not set
By properly configuring the gmac_gmii_ref_clk_div (GMAC_MAIN_CLK) to
have the parent of dpll_gmac_m2_ck always divided by 2 the warning is
resolved and the clock tree is fixed up.
Additionally, a new clock called rmii_50mhz_clk_mux is defined that
does utilize CM_GMAC_GMAC_CLKCTRL[24] CLKSEL_REF to configure the
source clock for the RMII_50MHZ_CLK.
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: J.D. Schroeder <jay.schroeder@garmin.com>
Reviewed-by: Trenton Andres <trenton.andres@garmin.com>
Since DRA7 has multiple PCIe Rootcomplex, add "linux,pci-domain"
property to assign a PCI domain number to each of the host
bridges.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
AM335x ICE board has a rotary-switch connected to PCA9536 I2C GPIO
expander. The position of the rotary-switch is reflected by status of
GPIO lines. Add gpio-decoder node to read these GPIO line status via
gpio-decoder driver and report it as an input event to the system.
Signed-off-by: Vignesh R <vigneshr@ti.com>
Silicon limitation i845 documents how to cope with false
disconnection condition on USB2 PHY. Reference: AM572x
silicon errata document SPRZ429H, revised January 2016.
Using compatible "ti,dra7x-usb2" enables the recommended
software workaround for this issue. Use it for USB1 PHY.
The workaround is already in place for USB2 PHY.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
The wega board has a TLV320AIC3007 connected via McASP0. In the default
configuration, no external crystal is mounted. We run a system clock of
25 MHz, so we use the audio codec PLL for audio clock generation.
Signed-off-by: Stefan Müller-Klieser <s.mueller-klieser@phytec.de>
Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
AM572x IDK has a Spansion s25fl256s1 QSPI flash on the EVM connected to
TI QSPI IP over CS0. Hence, add QSPI and flash slave DT nodes.
According to AM572x DM SPRS953A, QSPI maximum bus speed can be 76.8MHz.
Therefore, increase the spi-max-frequency value of QSPI node to 76.8MHz
for DRA74 and DRA72 evm. This improves flash raw read speed by ~2MB/s.
With the device tree parsing using the regulator framework
there is a no longer a need for separate compatibles for
individual regulator nodes. Hence removing them all.
Signed-off-by: Keerthy <j-keerthy@ti.com>
Without this, the memory will remain active during poweroff consuming
extra power. Please note revision 2.1 PMIC seems to fail when DCDC3
disable is attempted, so this is not done on that PMIC revision. The
PMIC revision checks in the regulator patches make sure of this.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
extra power.
during suspend
dcdc3, dcdc5, dcdc6 supply ddr and rtc respectively. These
are required to be on during suspend. Hence set the state accordingly.
This patch fixes the following DTC warnings for many boards:
"Node /leds/led@1 has a unit name, but no reg property"
"Node /gpio_keys/button0@10 has a unit name, but no reg property"
"Node /fixedregulator@0 has a unit name, but no reg property"
"Node /matrix_keypad@0 has a unit name, but no reg property"
Commit b8d368caa8dc ("ARM: dts: omap3: overo: remove unneded unit names
in display nodes") removed the unit names for all Overo display nodes
that didn't have a reg property.
But the display in arch/arm/boot/dts/omap3-overo-common-lcd35.dtsi does
have a reg property so the correct fix was to make the unit name match
the value of the reg property, instead of removing it.
This patch fixes the following DTC warning for boards using this dtsi:
"ocp/spi@48098000/display has a reg or ranges property, but no unit name"
Fixes: b8d368caa8dc ("ARM: dts: omap3: overo: remove unneded unit names in display nodes")
"Node /ocp has a reg or ranges property, but no unit name"
This fix was applied to a bunch of omap3 devices including LogicPD
Torpedo, but this got missed since it was new around the same times
the patches were applied. This makes the GPMC parameters match the
Torpedo since they have the same processor PoP memory.
This was applied to a variety of omap3 boards, so it should
probably be applied here. I did not test NAND performance, but
I tested this with UBI to confirm read/write didn't break.
