arch/arm/mach-omap1/board-nokia770.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc64: Update defconfig.
sparc: Kill user copy check code.
sparc64: Fix perf_arch_get_caller_regs().
sparc64: Add missing ID to parport probing code.
* 'rs485fix' of git://www.jni.nu/cris:
CRIS: ioctl for getting RS485 information
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: fix build with make 3.82
Revert "Input: appletouch - fix integer overflow issue"
memblock: Fix memblock_is_region_reserved() to return a boolean
powerpc: Trim defconfigs
powerpc: fix i8042 module build error
sound/soc: mpc5200_psc_ac97: Use gpio pins for cold reset
powerpc/5200: add mpc5200_psc_ac97_gpio_reset
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: (32 commits)
Blackfin: gpio: add a debounce stub
Blackfin: update defconfigs
Blackfin: remove CONFIG_MEM_GENERIC_BOARD
Blackfin: dpmc: punt unnecessary RTC_ISTAT clearing
Blackfin: unify rotary encoder bitmasks
Blackfin: unify SDH/RSI bitmasks
Blackfin: BF54x: tweak DMAC MMR naming to match other ports
Blackfin: TWI: clean up the MMR names
Blackfin: add EVT_OVERRIDE/IPRIO core MMR helpers
Blackfin: add support for dynamic ftrace
Blackfin: add support for LZO compressed kernels
Blackfin: portmux: fix peripheral map overflow when requesting pins
Blackfin: document SPI CS limitations with CPHA=0
Blackfin: remove useless and outdated documentation
Blackfin: BF51x/BF52x: support GPIO Hysteresis/Schmitt Trigger options
Blackfin: gpio/portmux: clean up whitespace corruption
Blackfin: make sure mmiowb inserts a write barrier with SSYNC
Blackfin: fix DMA/cache bug when resuming from suspend to RAM
Blackfin: BF51x: fix handling of PH8 (the "internal" SPI0SEL4 pin)
Blackfin: add a GPIO_DEFAULT_BOOT_SPI_CS
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (30 commits)
DMAENGINE: at_hdmac: locking fixlet
DMAENGINE: pch_dma: kill another usage of __raw_{read|write}l
dma: dmatest: fix potential sign bug
ioat2: catch and recover from broken vtd configurations v6
DMAENGINE: add runtime slave control to COH 901 318 v3
DMAENGINE: add runtime slave config to DMA40 v3
DMAENGINE: generic slave channel control v3
dmaengine: Driver for Topcliff PCH DMA controller
intel_mid: Add Mrst & Mfld DMA Drivers
drivers/dma: Eliminate a NULL pointer dereference
dma/timb_dma: compile warning on 32 bit
DMAENGINE: ste_dma40: support older silicon
DMAENGINE: ste_dma40: support disabling physical channels
DMAENGINE: ste_dma40: no disabled phy channels on ux500
DMAENGINE: ste_dma40: fix suspend bug
DMAENGINE: ste_dma40: add DB8500 memcpy channels
DMAENGINE: ste_dma40: no flow control on memcpy
DMAENGINE: ste_dma40: arch updates for LCLA and LCPA
DMAENGINE: ste_dma40: allocate LCLA dynamically
DMAENGINE: ste_dma40: no premature stop
Fix up trivial conflicts in arch/arm/mach-ux500/devices-db8500.c
Workqueues are now initialized as part of the early_initcall(). So they
are available for use during cold boot process aswell.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Tejun Heo <tj@kernel.org>
Removal of these started in 2.3.43pre3, ca. 10 years ago.
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
PROC_MM doesn't exist in Kconfig. Looking around it looks like a
left-over from 2.6.0 or even 2.4 times, last mentioned in a fedora patch
for 2.6.10. I believe it's time to get rid of that last tiny parts here
that are still around.
Signed-off-by: Christoph Egger <siccegge@cs.fau.de>
Cc: Jeff Dike <jdike@addtoit.com>
When I use OpenSUSE-11.2 on UML (> 2.6.25)
I get lots of such errors:
Registering fd 1 twice
Irqs : 3, 3
Ids : 0x09cb41a0, 0x09cb4120
WARNING: at kernel/irq/manage.c:896 __free_irq+0x79/0x11a()
Trying to free already-free IRQ 3
Modules linked in:
09dadc6c: [<081b2edb>] dump_stack+0x1c/0x20
09dadc84: [<080716da>] warn_slowpath_common+0x49/0x77
09dadc9c: [<08071772>] warn_slowpath_fmt+0x26/0x2a
09dadcb4: [<08094e08>] __free_irq+0x79/0x11a
09dadce4: [<08094ed6>] free_irq+0x2d/0x49
09dadcf4: [<0805b4bc>] close_one_chan+0x70/0x9c
09dadd0c: [<0805b833>] close_chan+0x17/0x22
09dadd1c: [<0805bdda>] enable_chan+0x70/0x7c
09dadd3c: [<0805cbb7>] line_open+0x34/0x9f
09dadd54: [<0805b21e>] con_open+0x13/0x35
09dadd6c: [<0814dc89>] tty_open+0x285/0x384
09dadda0: [<080b754e>] chrdev_open+0xe0/0xf9
09daddc0: [<080b3fb2>] __dentry_open+0xf3/0x1e2
09dadde4: [<080b4142>] nameidata_to_filp+0x35/0x49
09daddfc: [<080bd270>] do_last+0x409/0x50e
09dade28: [<080bea04>] do_filp_open+0x175/0x446
09dadecc: [<080b3d89>] do_sys_open+0x4a/0x128
09dadf04: [<080b3ea2>] sys_open+0x19/0x21
09dadf28: [<0805ab5a>] handle_syscall+0x7a/0x98
09dadf78: [<08068441>] userspace+0x2c9/0x370
09dadfe0: [<08058bb3>] fork_handler+0x53/0x5b
09dadffc: [<00766564>] 0x766564
---[ end trace 9ebc1094aaf4bded ]---
This patch fixes the issue.
Signed-off-by: Richard Weinberger <richard@nod.at>
This implements hardware performance events for the EV67 and later CPUs
within the Linux performance events subsystem. Only using the performance
monitoring unit in HP/Compaq's so called "Aggregrate mode" is supported.
The code has been implemented in a manner that makes extension to other
older Alpha CPUs relatively straightforward should some mug wish to
indulge themselves.
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Jay Estabrook <jay.estabrook@hp.com>
The following patches implement hardware performance events for the Alpha
EV67 and later CPUs. I have had this running on a Compaq XP1000 (EV67,
single CPU) for a few days now. Pretty cool -- discovered that the glibc
exp2() library routine uses on average 985 cycles to execute 777 CPU
instructions whereas Compaq's CPML library version of exp2() uses on
average 32 cycles to execute 47 CPU instructions to achieve the same
thing!
This patch:
Add performance monitor interrupt counternd and export the count to user
space via /proc/interrupts.
No real bugs, just some dead code and some fixups.
As explained in commit 1c0fe6e3bd ("mm: invoke oom-killer from page
fault") , we want to call the architecture independent oom killer when
getting an unexplained OOM from handle_mm_fault, rather than simply
killing current.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: David Rientjes <rientjes@google.com>
Define stubs for the numa_*_id() generic percpu related functions for
non-NUMA configurations in <asm-generic/topology.h> where the other
non-numa stubs live.
Fixes ia64 !NUMA build breakage -- e.g., tiger_defconfig
Back out now unneeded '#ifndef CONFIG_NUMA' guards from ia64 smpboot.c
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Tested-by: Tony Luck <tony.luck@intel.com>
Acked-by: Tony Luck <tony.luck@intel.com>
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse"
list[1] ("Follow common convention and you'll get it wrong"), except in
some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3].
kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes
takes a pointer to within the page itself. This seems to once in a while
trip people up (the convention they are following is the one from
kunmap()).
Make it much harder to misuse, by moving it to level 9 on Rusty's list[4]
("The compiler/linker won't let you get it wrong"). This is done by
refusing to build if the type of its first argument is a pointer to a
struct page.
The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck()
(which is what you would call in case for some strange reason calling it
with a pointer to a struct page is not incorrect in your code).
The previous version of this patch was compile tested on x86-64.
[1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html
[2] In these cases, it is at level 5, "Do it right or it will always
break at runtime."
[3] At least mips and powerpc look very similar, and sparc also seems to
share a common ancestor with both; there seems to be quite some
degree of copy-and-paste coding here. The include/asm/highmem.h file
for these three archs mention x86 CPUs at its top.
[4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html
[5] As an aside, could someone tell me why mn10300 uses unsigned long as
the first parameter of kunmap_atomic() instead of void *?
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
Cc: Russell King <linux@arm.linux.org.uk> (arch/arm)
Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips)
Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300)
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300)
Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc)
Cc: Helge Deller <deller@gmx.de> (arch/parisc)
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc)
Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc)
Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc)
Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc)
Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86)
Cc: Ingo Molnar <mingo@redhat.com> (arch/x86)
Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86)
Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic)
Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list)
Provide an INIT_MM_CONTEXT intializer macro which can be used to
statically initialize mm_struct:mm_context of init_mm. This way we can
get rid of code which will do the initialization at run time (on s390).
In addition the current code can be found at a place where it is not
expected. So let's have a common initializer which architectures
can use if needed.
This is based on a patch from Suzuki Poulose.
Cc: Suzuki Poulose <suzuki@in.ibm.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Add ioctl to CRIS serial driver to get RS485 data from user-space.
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
To avoid more patches, I also fixed other spelling
and grammar bugs when they were in the same or
following line:
successfull -> successful
parse -> parses
controler -> controller
controlers -> controllers
Cc: Jiri Kosina <trivial@kernel.org>
Signed-off-by: Stefan Weil <weil@mail.berlios.de>
For whatever reason GCC isn't able to figure things out in
the control flow (in particular when min() and max() expressions
are involved) on sparc as well as it can on x86.
So lots of useless incorrect user copy warnings get spewed and the
full-on compile failure mode of the user copy checks were never usable
on sparc at all.
People can debug these kinds of problems on x86.
After b0f82b81fe6bbcf78d478071f33e44554726bc81 ("perf: Drop the skip
argument from perf_arch_fetch_regs_caller") the build broke on sparc64
due to the lack of a module symbol export of __perf_arch_fetch_caller_regs.
But that assembler helper can actually be complete eliminated now that
the semantics of this interface have been greatly simplified.
SunBlade-2500 has 'parallel' device node with compatible
property "pnpALI,1533,3" so add that to the ID table.
Reported-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
Thomas Backlund reported that the powerpc build broke with make 3.82.
It failed with the following message:
arch/powerpc/Makefile:183: *** mixed implicit and normal rules. Stop.
The fix is to avoid mixing non-wildcard and wildcard targets.
Reported-by: Thomas Backlund <tmb@mandriva.org>
Tested-by: Thomas Backlund <tmb@mandriva.org>
Cc: Michal Marek <mmarek@suse.cz>
Cc: stable <stable@kernel.org>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This trims all our defconfigs using make savedefconfig
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: check kmalloc() result
arch/tile: catch up on various minor cleanups.
arch/tile: avoid erroneous error return for PTRACE_POKEUSR.
tile: set ARCH_KMALLOC_MINALIGN
tile: remove homegrown L1_CACHE_ALIGN macro
arch/tile: Miscellaneous cleanup changes.
arch/tile: Split the icache flush code off to a generic <arch> header.
arch/tile: Fix bug in support for atomic64_xx() ops.
arch/tile: Shrink the tile-opcode files considerably.
arch/tile: Add driver to enable access to the user dynamic network.
arch/tile: Enable more sophisticated IRQ model for 32-bit chips.
Move list types from <linux/list.h> to <linux/types.h>.
Add wait4() back to the set of <asm-generic/unistd.h> syscalls.
Revert adding some arch-specific signal syscalls to <linux/syscalls.h>.
arch/tile: Do not use GFP_KERNEL for dma_alloc_coherent(). Feedback from fujita.tomonori@lab.ntt.co.jp.
arch/tile: core support for Tilera 32-bit chips.
Fix up the "generic" unistd.h ABI to be more useful.
* 'for-linus' of git://www.jni.nu/cris: (51 commits)
CRIS: Fix alignment problem for older ld
CRIS: Always dump registers for segfaulting process.
CRIS: Add config for pausing a seg-faulting process
CRIS: Don't take faults while in_atomic
CRIS: Fixup lookup for delay slot faults
CRIS: Discard exit.text and .data at runtime
CRIS: Add cache aligned and read mostly data sections
CRIS: Return something from profile write
CRIS: Add ARTPEC-3 and timestamps for sync-serial
CRIS: Better ARTPEC-3 support for gpio
CRIS: Add include guard
CRIS: Better handling of pinmux settings
CRIS: New DMA defines for ARTPEC-3
CRIS: __do_strncpy_from_user: Don't read the byte beyond the nil
CRIS: Pagetable for ARTPEC-3
CRIS: Machine dependent memmap.h
CRIS: Check if pointer is set before using it
CRIS: Machine dependent dma.h
CRIS: Define __read_mostly for CRISv32
CRIS: Discard .note.gnu.build-id section
* 'for-linus' of git://android.kernel.org/kernel/tegra:
[ARM] tegra: add MAINTAINERS entry
[ARM] tegra: harmony: Add harmony board file
[ARM] tegra: add pinmux support
[ARM] tegra: add GPIO support
[ARM] tegra: Add timer support
[ARM] tegra: SMP support
[ARM] tegra: Add clock support
[ARM] tegra: Add IRQ support
[ARM] tegra: initial tegra support
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: (64 commits)
OMAP: DSS2: OMAPFB: add support for FBIO_WAITFORVSYNC
OMAP: DSS2: Replace strncmp() with sysfs_streq() in overlay_manager_store()
OMAP: DSS2: Fix error path in omap_dsi_update()
OMAP: DSS2: TDO35S: fix video signaling
OMAP: DSS2: OMAPFB: Fix invalid bpp for PAL and NTSC modes
OMAP: DSS2: OMAPFB: Fix probe error path
OMAP3EVM: Replace vdvi regulator supply with vdds_dsi
OMAP: DSS2: Remove extra return statement
OMAP: DSS2: adjust YUV overlay width to be even
OMAP: DSS2: OMAPFB: Fix sysfs mirror input check
OMAP: DSS2: OMAPFB: Remove redundant color register range check
OMAP: DSS2: OMAPFB: Remove redundant rotate range check
OMAP: DSS2: OMAPFB: Check fb2display() return value
OMAP: DSS2: Taal: Optimize enable_te, rotate, mirror when value unchanged
OMAP: DSS2: DSI: detect unsupported update requests
OMAP: DSS2: DSI: increase FIFO low threshold
OMAP: DSS2: DSI: Add error IRQ mask for DSI complexIO
OMAP: DSS2: DSI: Remove BTA after set_max_rx_packet_size
OMAP: DSS2: change manual update scaling setup
OMAP: DSS2: DSI: use BTA to end the frame transfer
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (143 commits)
omap: mailbox: reorganize headers
omap: mailbox: standarize on 'omap-mailbox'
omap: mailbox: only compile for configured archs
omap: mailbox: simplify omap_mbox_register()
omap: mailbox: reorganize registering
omap: mailbox: add IRQ names
omap: mailbox: remove unecessary fields
omap: mailbox: don't export unecessary symbols
omap: mailbox: update omap1 probing
omap: mailbox: use correct config for omap1
omap: mailbox: 2420 should be detected at run-time
omap: mailbox: reorganize structures
omap: mailbox: trivial cleanups
omap mailbox: Set a device in logical mbox instance for traceability
omap: mailbox: convert block api to kfifo
omap: mailbox: remove (un)likely macros from cold paths
omap: mailbox cleanup: split MODULE_AUTHOR line
omap: mailbox: convert rwlocks to spinlock
Mailbox: disable mailbox interrupt when request queue
Mailbox: new mutext lock for h/w mailbox configuration
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci:
davinci: dm646x EVM: Specify reserved EDMA channel/slots
davinci: da8xx/omapl EVM: Specify reserved channels/slots
davinci: support for EDMA resource sharing
davinci: edma: provide ability to detect insufficient CC info data
davinci: da8xx: sparse cleanup: remove duplicate entries in irq priorities
davinci: DM365: fixed second serial port
Davinci: tnetv107x evm board initial support
Davinci: tnetv107x initial gpio support
Davinci: tnetv107x soc support
Davinci: tnetv107x decompresser uart definitions
Davinci: generalized debug macros
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits)
ALSA: hda - Add pin-fix for HP dc5750
ALSA: als4000: Fix potentially invalid DMA mode setup
ALSA: als4000: enable burst mode
ALSA: hda - Fix initial capsrc selection in patch_alc269()
ASoC: TWL4030: Capture route runtime DAPM ordering fix
ALSA: hda - Add PC-beep whitelist for an Intel board
ALSA: hda - More relax for pending period handling
ALSA: hda - Define AC_FMT_* constants
ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs
ALSA: hda - Add support for HDMI HBR passthrough
ALSA: hda - Set Stream Type in Stream Format according to AES0
ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed
ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF
ASoC: wm9081: fix resource reclaim in wm9081_register error path
ASoC: wm8978: fix a memory leak if a wm8978_register fail
ASoC: wm8974: fix a memory leak if another WM8974 is registered
ASoC: wm8961: fix resource reclaim in wm8961_register error path
ASoC: wm8955: fix resource reclaim in wm8955_register error path
ASoC: wm8940: fix a memory leak if wm8940_register return error
ASoC: wm8904: fix resource reclaim in wm8904_register error path
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits)
workqueue: mark init_workqueues() as early_initcall()
workqueue: explain for_each_*cwq_cpu() iterators
fscache: fix build on !CONFIG_SYSCTL
slow-work: kill it
gfs2: use workqueue instead of slow-work
drm: use workqueue instead of slow-work
cifs: use workqueue instead of slow-work
fscache: drop references to slow-work
fscache: convert operation to use workqueue instead of slow-work
fscache: convert object to use workqueue instead of slow-work
workqueue: fix how cpu number is stored in work->data
workqueue: fix mayday_mask handling on UP
workqueue: fix build problem on !CONFIG_SMP
workqueue: fix locking in retry path of maybe_create_worker()
async: use workqueue for worker pool
workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead
workqueue: implement unbound workqueue
workqueue: prepare for WQ_UNBOUND implementation
libata: take advantage of cmwq and remove concurrency limitations
workqueue: fix worker management invocation without pending works
Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in
include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
of_i8042_{kbd,aux}_irq needs to be exported
Work around a silicon bug in the ac97 reset functionality of the
mpc5200(b). The implementation of the ac97 "cold" reset is flawed.
If the sync and output lines are high when reset is asserted the
attached ac97 device may go into test mode. Avoid this by
reconfiguring the psc to gpio mode and generating the reset manually.
From MPC5200B User's Manual:
"Some AC97 devices goes to a test mode, if the Sync line is high
during the Res line is low (reset phase). To avoid this behavior the
Sync line must be also forced to zero during the reset phase. To do
that, the pin muxing should switch to GPIO mode and the GPIO control
register should be used to control the output lines."
Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
* 'x86-xsave-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, xsave: Make xstate_enable_boot_cpu() __init, protect on CPU 0
x86, xsave: Add __init attribute to setup_xstate_features()
x86, xsave: Make init_xstate_buf static
x86, xsave: Check cpuid level for XSTATE_CPUID (0x0d)
x86, xsave: Introduce xstate enable functions
x86, xsave: Separate fpu and xsave initialization
x86, xsave: Move boot cpu initialization to xsave_init()
x86, xsave: 32/64 bit boot cpu check unification in initialization
x86, xsave: Do not include asm/i387.h in asm/xsave.h
x86, xsave: Use xsaveopt in context-switch path when supported
x86, xsave: Sync xsave memory layout with its header for user handling
x86, xsave: Track the offset, size of state in the xsave layout
* 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mce: Use HW_ERR in MCE handler
x86, mce: Add HW_ERR printk prefix for hardware error logging
x86, mce: Fix MSR_IA32_MCI_CTL2 CMCI threshold setup
x86, mce: Rename MSR_IA32_MCx_CTL2 value
* 'x86-olpc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, olpc: Constify an olpc_ofw() arg
x86, olpc: Use pr_debug() for EC commands
x86, olpc: Add comment about implicit optimization barrier
x86, olpc: Add support for calling into OpenFirmware
* 'x86-alternatives-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, alternatives: BUG on encountering an invalid CPU feature number
x86, alternatives: Fix one more open-coded 8-bit alternative number
x86, alternatives: Use 16-bit numbers for cpufeature index
'x86-mtrr-for-linus', 'x86-apic-for-linus', 'x86-fpu-for-linus' and 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Clean up arch/x86/kernel/cpu/mtrr/cleanup.c: use ";" not "," to terminate statements
* 'x86-vmware-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, vmware: Preset lpj values when on VMware.
* 'x86-mtrr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mtrr: Use stop machine context to rendezvous all the cpu's
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86/apic/es7000_32: Remove unused variable
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Avoid unnecessary __clear_user() and xrstor in signal handling
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, vdso: Unmap vdso pages
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
xen: Do not suspend IPI IRQs.
powerpc: Use IRQF_NO_SUSPEND not IRQF_TIMER for non-timer interrupts
ixp4xx-beeper: Use IRQF_NO_SUSPEND not IRQF_TIMER for non-timer interrupt
irq: Add new IRQ flag IRQF_NO_SUSPEND
* 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Fix read_persistent_clock fallout
kgdb: Do not access xtime directly
powerpc: Clean up obsolete code relating to decrementer and timebase
powerpc: Rework VDSO gettimeofday to prevent time going backwards
clocksource: Add __clocksource_updatefreq_hz/khz methods
x86: Convert common clocksources to use clocksource_register_hz/khz
timekeeping: Make xtime and wall_to_monotonic static
hrtimer: Cleanup direct access to wall_to_monotonic
um: Convert to use read_persistent_clock
timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset
powerpc: Cleanup xtime usage
powerpc: Simplify update_vsyscall
time: Kill off CONFIG_GENERIC_TIME
time: Implement timespec_add
x86: Fix vtime/file timestamp inconsistencies
Trivial conflicts in Documentation/feature-removal-schedule.txt
Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as
per Thomas' earlier merge commit 47916be4e28c ("Merge branch
'powerpc.cherry-picks' into timers/clocksource")
KVM ended up having to put a pretty ugly wrapper around set_64bit()
in order to get the type right. Now set_64bit() takes the expected
u64 type, and this wrapper can be cleaned up.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Avi Kivity <avi@redhat.com>
LKML-Reference: <4C5C4E7A.8040603@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (30 commits)
PCI: update for owner removal from struct device_attribute
PCI: Fix warnings when CONFIG_DMI unset
PCI: Do not run NVidia quirks related to MSI with MSI disabled
x86/PCI: use for_each_pci_dev()
PCI: MSI: Restore read_msi_msg_desc(); add get_cached_msi_msg_desc()
PCI: export SMBIOS provided firmware instance and label to sysfs
PCI: Allow read/write access to sysfs I/O port resources
x86/PCI: use host bridge _CRS info on ASRock ALiveSATA2-GLAN
PCI: remove unused HAVE_ARCH_PCI_SET_DMA_MAX_SEGMENT_{SIZE|BOUNDARY}
PCI: disable mmio during bar sizing
PCI: MSI: Remove unsafe and unnecessary hardware access
PCI: Default PCIe ASPM control to on and require !EMBEDDED to disable
PCI: kernel oops on access to pci proc file while hot-removal
PCI: pci-sysfs: remove casts from void*
ACPI: Disable ASPM if the platform won't provide _OSC control for PCIe
PCI hotplug: make sure child bridges are enabled at hotplug time
PCI hotplug: shpchp: Removed check for hotplug of display devices
PCI hotplug: pciehp: Fixed return value sign for pciehp_unconfigure_device
PCI: Don't enable aspm before drivers have had a chance to veto it
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (524 commits)
Staging: wlan-ng: Update prism2_set_tx_power() to use mBm
Staging: ti-st: update TODO
Staging: wlags49_h2: use common PCI_VENDOR/DEVICE_ID name format
Staging: comedi : fix brace coding style issue in wwrap.c
Staging: quatech_usb2: remove unused qt2_box_flush function
Staging: slicoss: Remove net_device_stats from the driver's private
staging: rtl8192su: check whether requests succeeded
staging: panel: fix error path
staging: otus: check kmalloc() return value
staging: octeon: check request_irq() return value
Staging: wlan-ng: remove typedef in p80211hdr.h
Staging: wlan-ng: fix checkpatch issues in headers.
Staging: wlan-ng: remove typedef in p80211ioctl.h
Staging: wlan-ng: fix style issues in p80211conv.h
Staging: wlan-ng: fix style issues for p80211hdr.h
staging: vt6656: removed NTSTATUS definition
staging: vt6656: simplified tests involving both multi/broad-casts
Staging: vt6655: replace BOOL with in kernel bool
Staging: vt6655: replace FALSE with in kernel false
Staging: vt6655: replace TRUE with in kernel true
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (28 commits)
driver core: device_rename's new_name can be const
sysfs: Remove owner field from sysfs struct attribute
powerpc/pci: Remove owner field from attribute initialization in PCI bridge init
regulator: Remove owner field from attribute initialization in regulator core driver
leds: Remove owner field from attribute initialization in bd2802 driver
scsi: Remove owner field from attribute initialization in ARCMSR driver
scsi: Remove owner field from attribute initialization in LPFC driver
cgroupfs: create /sys/fs/cgroup to mount cgroupfs on
Driver core: Add BUS_NOTIFY_BIND_DRIVER
driver core: fix memory leak on one error path in bus_register()
debugfs: no longer needs to depend on SYSFS
sysfs: Fix one more signature discrepancy between sysfs implementation and docs.
sysfs: fix discrepancies between implementation and documentation
dcdbas: remove a redundant smi_data_buf_free in dcdbas_exit
dmi-id: fix a memory leak in dmi_id_init error path
sysfs: sysfs_chmod_file's attr can be const
firmware: Update hotplug script
Driver core: move platform device creation helpers to .init.text (if MODULE=n)
Driver core: reduce duplicated code for platform_device creation
Driver core: use kmemdup in platform_device_add_resources
* 'x86-rwsem-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, rwsem: Minor cleanups
x86, rwsem: Stay on fast path when count > 0 in __up_write()
* 'x86-gcc46-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, gcc-4.6: Fix set but not read variables
x86, gcc-4.6: Avoid unused by set variables in rdmsr
