Pull x86 fixes from Ingo Molnar:
"Two families of fixes:
- Fix an FPU context related boot crash on newer x86 hardware with
larger context sizes than what most people test. To fix this
without ugly kludges or extensive reverts we had to touch core task
allocator, to allow x86 to determine the task size dynamically, at
boot time.
I've tested it on a number of x86 platforms, and I cross-built it
to a handful of architectures:
(warns) (warns)
testing x86-64: -git: pass ( 0), -tip: pass ( 0)
testing x86-32: -git: pass ( 0), -tip: pass ( 0)
testing arm: -git: pass ( 1359), -tip: pass ( 1359)
testing cris: -git: pass ( 1031), -tip: pass ( 1031)
testing m32r: -git: pass ( 1135), -tip: pass ( 1135)
testing m68k: -git: pass ( 1471), -tip: pass ( 1471)
testing mips: -git: pass ( 1162), -tip: pass ( 1162)
testing mn10300: -git: pass ( 1058), -tip: pass ( 1058)
testing parisc: -git: pass ( 1846), -tip: pass ( 1846)
testing sparc: -git: pass ( 1185), -tip: pass ( 1185)
... so I hope the cross-arch impact 'none', as intended.
(by Dave Hansen)
- Fix various NMI handling related bugs unearthed by the big asm code
rewrite and generally make the NMI code more robust and more
maintainable while at it. These changes are a bit late in the
cycle, I hope they are still acceptable.
(by Andy Lutomirski)"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/fpu, sched: Introduce CONFIG_ARCH_WANTS_DYNAMIC_TASK_STRUCT and use it on x86
x86/fpu, sched: Dynamically allocate 'struct fpu'
x86/entry/64, x86/nmi/64: Add CONFIG_DEBUG_ENTRY NMI testing code
x86/nmi/64: Make the "NMI executing" variable more consistent
x86/nmi/64: Minor asm simplification
x86/nmi/64: Use DF to avoid userspace RSP confusing nested NMI detection
x86/nmi/64: Reorder nested NMI checks
x86/nmi/64: Improve nested NMI comments
x86/nmi/64: Switch stacks on userspace NMI entry
x86/nmi/64: Remove asm code that saves CR2
x86/nmi: Enable nested do_nmi() handling for 64-bit kernels
Pull perf fixes from Ingo Molnar:
"Mostly tooling fixes, plus a static key fix fixing /sys/devices/cpu/rdpmc"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf tools: Really allow to specify custom CC, AR or LD
perf auxtrace: Fix misplaced check for HAVE_SYNC_COMPARE_AND_SWAP_SUPPORT
perf hists browser: Take the --comm, --dsos, etc filters into account
perf symbols: Store if there is a filter in place
x86, perf: Fix static_key bug in load_mm_cr4()
tools: Copy lib/hweight.c from the kernel sources
perf tools: Fix the detached tarball wrt rbtree copy
perf thread_map: Fix the sizeof() calculation for map entries
tools lib: Improve clean target
perf stat: Fix shadow declaration of close
perf tools: Fix lockup using 32-bit compat vdso
Pull irq fixes from Ingo Molnar:
"Misc irq fixes:
- two driver fixes
- a Xen regression fix
- a nested irq thread crash fix"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip/gicv3-its: Fix mapping of LPIs to collections
genirq: Prevent resend to interrupts marked IRQ_NESTED_THREAD
genirq: Revert sparse irq locking around __cpu_up() and move it to x86 for now
gpio/davinci: Fix race in installing chained irq handler
on x86
Don't burden architectures without dynamic task_struct sizing
with the overhead of dynamic sizing.
Also optimize the x86 code a bit by caching task_struct_size.
Acked-and-Tested-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave@sr71.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/1437128892-9831-3-git-send-email-mingo@kernel.org
The FPU rewrite removed the dynamic allocations of 'struct fpu'.
But, this potentially wastes massive amounts of memory (2k per
task on systems that do not have AVX-512 for instance).
Instead of having a separate slab, this patch just appends the
space that we need to the 'task_struct' which we dynamically
allocate already. This saves from doing an extra slab
allocation at fork().
The only real downside here is that we have to stick everything
and the end of the task_struct. But, I think the
BUILD_BUG_ON()s I stuck in there should keep that from being too
fragile.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Link: http://lkml.kernel.org/r/1437128892-9831-2-git-send-email-mingo@kernel.org
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty
header file (mm-arch-hooks.h) for every architecture, even those which
doesn't need to define mm hooks.
As suggested by Geert Uytterhoeven, this could be cleaned through the use
of a generic header file included via each per architecture
asm/include/Kbuild file.
The PowerPC architecture is not impacted here since this architecture has
to defined the arch_remap MM hook.
Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Vineet Gupta <vgupta@synopsys.com>
It turns out to be rather tedious to test the NMI nesting code.
Make it easier: add a new CONFIG_DEBUG_ENTRY option that causes
the NMI handler to pre-emptively unmask NMIs.
With this option set, errors in the repeat_nmi logic or failures
to detect that we're in a nested NMI will result in quick panics
under perf (especially if multiple counters are running at high
frequency) instead of requiring an unusual workload that
generates page faults or breakpoints inside NMIs.
I called it CONFIG_DEBUG_ENTRY instead of CONFIG_DEBUG_NMI_ENTRY
because I want to add new non-NMI checks elsewhere in the entry
code in the future, and I'd rather not add too many new config
options or add this option and then immediately rename it.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Borislav Petkov <bp@suse.de>
Currently, "NMI executing" is one the first time an outermost
NMI hits repeat_nmi and zero thereafter. Change it to be zero
each time for consistency.
This is intended to help NMI handling fail harder if it's buggy.
Replace LEA; MOV with an equivalent SUB. This saves one
instruction.
We have a tricky bug in the nested NMI code: if we see RSP
pointing to the NMI stack on NMI entry from kernel mode, we
assume that we are executing a nested NMI.
This isn't quite true. A malicious userspace program can point
RSP at the NMI stack, issue SYSCALL, and arrange for an NMI to
happen while RSP is still pointing at the NMI stack.
Fix it with a sneaky trick. Set DF in the region of code that
the RSP check is intended to detect. IRET will clear DF
atomically.
( Note: other than paravirt, there's little need for all this
complexity. We could check RIP instead of RSP. )
Cc: stable@vger.kernel.org
Check the repeat_nmi .. end_repeat_nmi special case first. The
next patch will rework the RSP check and, as a side effect, the
RSP check will no longer detect repeat_nmi .. end_repeat_nmi, so
we'll need this ordering of the checks.
Note: this is more subtle than it appears. The check for
repeat_nmi .. end_repeat_nmi jumps straight out of the NMI code
instead of adjusting the "iret" frame to force a repeat. This
is necessary, because the code between repeat_nmi and
end_repeat_nmi sets "NMI executing" and then writes to the
"iret" frame itself. If a nested NMI comes in and modifies the
"iret" frame while repeat_nmi is also modifying it, we'll end up
with garbage. The old code got this right, as does the new
code, but the new code is a bit more explicit.
If we were to move the check right after the "NMI executing"
check, then we'd get it wrong and have random crashes.
( Because the "NMI executing" check would jump to the code that would
modify the "iret" frame without checking if the interrupted NMI was
currently modifying it. )
I found the nested NMI documentation to be difficult to follow.
Improve the comments.
Returning to userspace is tricky: IRET can fail, and ESPFIX can
rearrange the stack prior to IRET.
The NMI nesting fixup relies on a precise stack layout and
atomic IRET. Rather than trying to teach the NMI nesting fixup
to handle ESPFIX and failed IRET, punt: run NMIs that came from
user mode on the normal kernel stack.
This will make some nested NMIs visible to C code, but the C
code is okay with that.
As a side effect, this should speed up perf: it eliminates an
RDMSR when NMIs come from user mode.
Reviewed-by: Borislav Petkov <bp@suse.de>
Now that do_nmi saves CR2, we don't need to save it in asm.
Acked-by: Borislav Petkov <bp@suse.de>
32-bit kernels handle nested NMIs in C. Enable the exact same
handling on 64-bit kernels as well. This isn't currently
necessary, but it will become necessary once the asm code starts
allowing limited nesting.
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver fixes from Darren Hart:
"Fix SMBIOS call handling and hwswitch state coherency in the
dell-laptop driver. Cleanups for intel_*_ipc drivers. Details:
dell-laptop:
- Do not cache hwswitch state
- Check return value of each SMBIOS call
- Clear buffer before each SMBIOS call
intel_scu_ipc:
- Move local memory initialization out of a mutex
intel_pmc_ipc:
- Update kerneldoc formatting
- Fix compiler casting warnings"
* tag 'platform-drivers-x86-v4.2-3' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
intel_scu_ipc: move local memory initialization out of a mutex
intel_pmc_ipc: Update kerneldoc formatting
dell-laptop: Do not cache hwswitch state
dell-laptop: Check return value of each SMBIOS call
dell-laptop: Clear buffer before each SMBIOS call
intel_pmc_ipc: Fix compiler casting warnings
Pull KVM fixes from Paolo Bonzini:
- Fix FPU refactoring ("kvm: x86: fix load xsave feature warning")
- Fix eager FPU mode (Cc stable)
- AMD bits of MTRR virtualization
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: apply guest MTRR virtualization on host reserved pages
KVM: SVM: Sync g_pat with guest-written PAT value
KVM: SVM: use NPT page attributes
KVM: count number of assigned devices
KVM: VMX: fix vmwrite to invalid VMCS
KVM: x86: reintroduce kvm_is_mmio_pfn
x86: hyperv: add CPUID bit for crash handlers
Boris reported that the sparse_irq protection around __cpu_up() in the
generic code causes a regression on Xen. Xen allocates interrupts and
some more in the xen_cpu_up() function, so it deadlocks on the
sparse_irq_lock.
There is no simple fix for this and we really should have the
protection for all architectures, but for now the only solution is to
move it to x86 where actual wreckage due to the lack of protection has
been observed.
Reported-and-tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Fixes: a89941816726 'hotplug: Prevent alloc/free of irq descriptors during cpu up/down'
Cc: xiao jin <jin.xiao@intel.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Cc: xen-devel <xen-devel@lists.xenproject.org>
Pull x86 fixes from Thomas Gleixner:
- the high latency PIT detection fix, which slipped through the cracks
for rc1
- a regression fix for the early printk mechanism
- the x86 part to plug irq/vector related hotplug races
- move the allocation of the espfix pages on cpu hotplug to non atomic
context. The current code triggers a might_sleep() warning.
- a series of KASAN fixes addressing boot crashes and usability
- a trivial typo fix for Kconfig help text
x86/kconfig: Fix typo in the CONFIG_CMDLINE_BOOL help text
x86/irq: Retrieve irq data after locking irq_desc
x86/irq: Use proper locking in check_irq_vectors_for_cpu_disable()
x86/irq: Plug irq vector hotplug race
x86/earlyprintk: Allow early_printk() to use console style parameters like '115200n8'
x86/espfix: Init espfix on the boot CPU side
x86/espfix: Add 'cpu' parameter to init_espfix_ap()
x86/kasan: Move KASAN_SHADOW_OFFSET to the arch Kconfig
x86/kasan: Add message about KASAN being initialized
x86/kasan: Fix boot crash on AMD processors
x86/kasan: Flush TLBs after switching CR3
x86/kasan: Fix KASAN shadow region page tables
x86/init: Clear 'init_level4_pgt' earlier
x86/tsc: Let high latency PIT fail fast in quick_pit_calibrate()
[ 68.196974] WARNING: CPU: 1 PID: 2140 at arch/x86/kvm/x86.c:3161 kvm_arch_vcpu_ioctl+0xe88/0x1340 [kvm]()
[ 68.196975] Modules linked in: snd_hda_codec_hdmi i915 rfcomm bnep bluetooth i2c_algo_bit rfkill nfsd drm_kms_helper nfs_acl nfs drm lockd grace sunrpc fscache snd_hda_codec_realtek snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_seq_dummy snd_seq_oss x86_pkg_temp_thermal snd_seq_midi kvm_intel snd_seq_midi_event snd_rawmidi kvm snd_seq ghash_clmulni_intel fuse snd_timer aesni_intel parport_pc ablk_helper snd_seq_device cryptd ppdev snd lp parport lrw dcdbas gf128mul i2c_core glue_helper lpc_ich video shpchp mfd_core soundcore serio_raw acpi_cpufreq ext4 mbcache jbd2 sd_mod crc32c_intel ahci libahci libata e1000e ptp pps_core
[ 68.197005] CPU: 1 PID: 2140 Comm: qemu-system-x86 Not tainted 4.2.0-rc1+ #2
[ 68.197006] Hardware name: Dell Inc. OptiPlex 7020/0F5C5X, BIOS A03 01/08/2015
[ 68.197007] ffffffffa03b0657 ffff8800d984bca8 ffffffff815915a2 0000000000000000
[ 68.197009] 0000000000000000 ffff8800d984bce8 ffffffff81057c0a 00007ff6d0001000
[ 68.197010] 0000000000000002 ffff880211c1a000 0000000000000004 ffff8800ce0288c0
[ 68.197012] Call Trace:
[ 68.197017] [<ffffffff815915a2>] dump_stack+0x45/0x57
[ 68.197020] [<ffffffff81057c0a>] warn_slowpath_common+0x8a/0xc0
[ 68.197022] [<ffffffff81057cfa>] warn_slowpath_null+0x1a/0x20
[ 68.197029] [<ffffffffa037bed8>] kvm_arch_vcpu_ioctl+0xe88/0x1340 [kvm]
[ 68.197035] [<ffffffffa037aede>] ? kvm_arch_vcpu_load+0x4e/0x1c0 [kvm]
[ 68.197040] [<ffffffffa03696a6>] kvm_vcpu_ioctl+0xc6/0x5c0 [kvm]
[ 68.197043] [<ffffffff811252d2>] ? perf_pmu_enable+0x22/0x30
[ 68.197044] [<ffffffff8112663e>] ? perf_event_context_sched_in+0x7e/0xb0
[ 68.197048] [<ffffffff811a6882>] do_vfs_ioctl+0x2c2/0x4a0
[ 68.197050] [<ffffffff8107bf33>] ? finish_task_switch+0x173/0x220
[ 68.197053] [<ffffffff8123307f>] ? selinux_file_ioctl+0x4f/0xd0
[ 68.197055] [<ffffffff8122cac3>] ? security_file_ioctl+0x43/0x60
[ 68.197057] [<ffffffff811a6ad9>] SyS_ioctl+0x79/0x90
[ 68.197060] [<ffffffff81597e57>] entry_SYSCALL_64_fastpath+0x12/0x6a
[ 68.197061] ---[ end trace 558a5ebf9445fc80 ]---
After commit (0c4109bec0 'x86/fpu/xstate: Fix up bad get_xsave_addr()
assumptions'), there is no assumption an xsave bit is present in the
hardware (pcntxt_mask) that it is always present in a given xsave buffer.
An enabled state to be present on 'pcntxt_mask', but *not* in 'xstate_bv'
could happen when the last 'xsave' did not request that this feature be
saved (unlikely) or because the "init optimization" caused it to not be
saved. This patch kill the assumption.
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Currently guest MTRR is avoided if kvm_is_reserved_pfn returns true.
However, the guest could prefer a different page type than UC for
such pages. A good example is that pass-throughed VGA frame buffer is
not always UC as host expected.
This patch enables full use of virtual guest MTRRs.
Suggested-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Tested-by: Joerg Roedel <jroedel@suse.de> (on AMD)
When hardware supports the g_pat VMCB field, we can use it for emulating
the PAT configuration that the guest configures by writing to the
corresponding MSR.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Right now, NPT page attributes are not used, and the final page
attribute depends solely on gPAT (which however is not synced
correctly), the guest MTRRs and the guest page attributes.
However, we can do better by mimicking what is done for VMX.
In the absence of PCI passthrough, the guest PAT can be ignored
and the page attributes can be just WB. If passthrough is being
used, instead, keep respecting the guest PAT, and emulate the guest
MTRRs through the PAT field of the nested page tables.
The only snag is that WP memory cannot be emulated correctly,
because Linux's default PAT setting only includes the other types.
If there are no assigned devices, the guest PAT are not providing
any useful information and can be overridden to writeback; VMX
always does this because it has the "IPAT" bit in its extended
page table entries, but SVM does not have anything similar.
Hook into VFIO and legacy device assignment so that they
provide this information to KVM.
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
fpu_activate is called outside of vcpu_load(), which means it should not
touch VMCS, but fpu_activate needs to. Avoid the call by moving it to a
point where we know that the guest needs eager FPU and VMCS is loaded.
This will get rid of the following trace
vmwrite error: reg 6800 value 0 (err 1)
[<ffffffff8162035b>] dump_stack+0x19/0x1b
[<ffffffffa046c701>] vmwrite_error+0x2c/0x2e [kvm_intel]
[<ffffffffa045f26f>] vmcs_writel+0x1f/0x30 [kvm_intel]
[<ffffffffa04617e5>] vmx_fpu_activate.part.61+0x45/0xb0 [kvm_intel]
[<ffffffffa0461865>] vmx_fpu_activate+0x15/0x20 [kvm_intel]
[<ffffffffa0560b91>] kvm_arch_vcpu_create+0x51/0x70 [kvm]
[<ffffffffa0548011>] kvm_vm_ioctl+0x1c1/0x760 [kvm]
[<ffffffff8118b55a>] ? handle_mm_fault+0x49a/0xec0
[<ffffffff811e47d5>] do_vfs_ioctl+0x2e5/0x4c0
[<ffffffff8127abbe>] ? file_has_perm+0xae/0xc0
[<ffffffff811e4a51>] SyS_ioctl+0xa1/0xc0
[<ffffffff81630949>] system_call_fastpath+0x16/0x1b
(Note: we also unconditionally activate FPU in vmx_vcpu_reset(), so the
removed code added nothing.)
Fixes: c447e76b4cab ("kvm/fpu: Enable eager restore kvm FPU for MPX")
Cc: <stable@vger.kernel.org>
Reported-by: Vlastimil Holer <vlastimil.holer@gmail.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
The call to get_mt_mask was really using kvm_is_reserved_pfn to
detect an MMIO-backed page. In this case, we want "false" to be
returned for the zero page.
Reintroduce a separate kvm_is_mmio_pfn predicate for this use
only.
Mikulas reported his K6-3 not booting. This is because the
static_key API confusion struck and bit Andy, this wants to be
static_key_false().
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Tested-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Vince Weaver <vince@deater.net>
Cc: hillf.zj <hillf.zj@alibaba-inc.com>
Fixes: a66734297f78 ("perf/x86: Add /sys/devices/cpu/rdpmc=2 to allow rdpmc for all tasks")
Link: http://lkml.kernel.org/r/20150709172338.GC19282@twins.programming.kicks-ass.net
Update kerneldoc formatting per Documentation/kernel-dec-nano-HOWTO.txt.
Signed-off-by: qipeng.zha <qipeng.zha@intel.com>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Signed-off-by: Sébastien Hinderer <Sebastien.Hinderer@ens-lyon.org>
Cc: Samuel Thibault <Samuel.Thibault@ens-lyon.org>
irq_data is protected by irq_desc->lock, so retrieving the irq chip
from irq_data outside the lock is racy vs. an concurrent update. Move
it into the lock held region.
While at it add a comment why the vector walk does not require
vector_lock.
Link: http://lkml.kernel.org/r/20150705171102.331320612@linutronix.de
It's unsafe to examine fields in the irq descriptor w/o holding the
descriptor lock. Add proper locking.
While at it add a comment why the vector check can run lock less
Link: http://lkml.kernel.org/r/20150705171102.236544164@linutronix.de
Jin debugged a nasty cpu hotplug race which results in leaking a irq
vector on the newly hotplugged cpu.
cpu N cpu M
native_cpu_up device_shutdown
do_boot_cpu free_msi_irqs
start_secondary arch_teardown_msi_irqs
smp_callin default_teardown_msi_irqs
setup_vector_irq arch_teardown_msi_irq
__setup_vector_irq native_teardown_msi_irq
lock(vector_lock) destroy_irq
install vectors
unlock(vector_lock)
lock(vector_lock)
---> __clear_irq_vector
unlock(vector_lock)
lock(vector_lock)
set_cpu_online
unlock(vector_lock)
This leaves the irq vector(s) which are torn down on CPU M stale in
the vector array of CPU N, because CPU M does not see CPU N online
yet. There is a similar issue with concurrent newly setup interrupts.
The alloc/free protection of irq descriptors does not prevent the
above race, because it merily prevents interrupt descriptors from
going away or changing concurrently.
Prevent this by moving the call to setup_vector_irq() into the
vector_lock held region which protects set_cpu_online():
cpu N cpu M
lock(vector_lock) arch_teardown_msi_irq
setup_vector_irq()
install vectors destroy_irq
set_cpu_online
unlock(vector_lock)
lock(vector_lock)
__clear_irq_vector
unlock(vector_lock)
So cpu M either sees the cpu N online before clearing the vector or
cpu N installs the vectors after cpu M has cleared it.
Reported-by: xiao jin <jin.xiao@intel.com>
Link: http://lkml.kernel.org/r/20150705171102.141898931@linutronix.de
'115200n8'
When I enable early_printk on a kernel, I cut and paste the
console= input and add to earlyprintk parameter. But I notice
recently that ktest has not been detecting triple faults. The
way it detects it, is by seeing the kernel banner "Linux version
.." with a different kernel version pop up. Then I noticed that
early printk was no longer working on my console, which was why
ktest was not seeing it.
I bisected it down and it was added to 4.0 with this commit:
ea9e9d802902 ("Specify PCI based UART for earlyprintk")
because it converted the simple_strtoul() that converts the baud
number into a kstrtoul(). The problem with this is, I had as my
baud rate, 115200n8 (acceptable for console=ttyS0), but because
of the "n8", the kstrtoul() doesn't parse the baud rate and
returns an error, which sets the baud rate to the default 9600.
This explains the garbage on my screen.
Now, earlyprintk= kernel parameter does not say it accepts that
format. Thus, one answer would simply be me changing my kernel
parameters to remove the "n8" since it isn't parsed anyway. But
I wonder if other people run into this, and it seems strange
that the two consoles for serial accepts different input.
I could also extend this to have earlyprintk do something with
that "n8" or whatever it has and have it match the console
parsing (which, BTW, still uses simple_strtoul(), as I guess it
has to).
This patch just makes my old kernel parameter parsing work like
it use to.
Although, simple_strtoull() is considered obsolete, it is the
only standard string parsing function that parses a number that
is attached to text. Ironically, commit ea9e9d802902 also added
several calls to simple_strtoul()!
Cc: Alan Cox <alan@linux.intel.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: David Cohen <david.a.cohen@linux.intel.com>
Cc: Stuart R. Anderson <stuart.r.anderson@intel.com>
Link: http://lkml.kernel.org/r/20150706101434.5f6a351b@gandalf.local.home
[ Cleaned it up a bit. ]
As we alloc pages with GFP_KERNEL in init_espfix_ap() which is
called before we enable local irqs, so the lockdep sub-system
would (correctly) trigger a warning about the potentially
blocking API.
So we allocate them on the boot CPU side when the secondary CPU is
brought up by the boot CPU, and hand them over to the secondary
CPU.
And we use alloc_pages_node() with the secondary CPU's node, to
make sure the espfix stack is NUMA-local to the CPU that is
going to use it.
Signed-off-by: Zhu Guihua <zhugh.fnst@cn.fujitsu.com>
Cc: <bp@alien8.de>
Cc: <luto@amacapital.net>
Cc: <luto@kernel.org>
Link: http://lkml.kernel.org/r/c97add2670e9abebb90095369f0cfc172373ac94.1435824469.git.zhugh.fnst@cn.fujitsu.com
Add a CPU index parameter to init_espfix_ap(), so that the
parameter could be propagated to the function for espfix
page allocation.
Cc: <bp@alien8.de>
Link: http://lkml.kernel.org/r/cde3fcf1b3211f3f03feb1a995bce3fee850f0fc.1435824469.git.zhugh.fnst@cn.fujitsu.com
KASAN_SHADOW_OFFSET is purely arch specific setting,
so it should be in arch's Kconfig file.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Alexander Popov <alpopov@ptsecurity.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Link: http://lkml.kernel.org/r/1435828178-10975-7-git-send-email-a.ryabinin@samsung.com
Print informational message to tell user that kernel
runs with KASAN enabled.
Add a "kasan: " prefix to all messages in kasan_init_64.c.
Link: http://lkml.kernel.org/r/1435828178-10975-6-git-send-email-a.ryabinin@samsung.com
While populating zero shadow wrong bits in upper level page
tables used. __PAGE_KERNEL_RO that was used for pgd/pud/pmd has
_PAGE_BIT_GLOBAL set. Global bit is present only in the lowest
level of the page translation hierarchy (ptes), and it should be
zero in upper levels.
This bug seems doesn't cause any troubles on Intel cpus, while
on AMDs it cause kernel crash on boot.
Use _KERNPG_TABLE bits for pgds/puds/pmds to fix this.
Reported-by: Borislav Petkov <bp@alien8.de>
Cc: <stable@vger.kernel.org> # 4.0+
Link: http://lkml.kernel.org/r/1435828178-10975-5-git-send-email-a.ryabinin@samsung.com
load_cr3() doesn't cause tlb_flush if PGE enabled.
This may cause tons of false positive reports spamming the
kernel to death.
To fix this __flush_tlb_all() should be called explicitly
after CR3 changed.
Link: http://lkml.kernel.org/r/1435828178-10975-4-git-send-email-a.ryabinin@samsung.com
Currently KASAN shadow region page tables created without
respect of physical offset (phys_base). This causes kernel halt
when phys_base is not zero.
So let's initialize KASAN shadow region page tables in
kasan_early_init() using __pa_nodebug() which considers
phys_base.
This patch also separates x86_64_start_kernel() from KASAN low
level details by moving kasan_map_early_shadow(init_level4_pgt)
into kasan_early_init().
Remove the comment before clear_bss() which stopped bringing
much profit to the code readability. Otherwise describing all
the new order dependencies would be too verbose.
Signed-off-by: Alexander Popov <alpopov@ptsecurity.com>
Link: http://lkml.kernel.org/r/1435828178-10975-3-git-send-email-a.ryabinin@samsung.com
Currently x86_64_start_kernel() has two KASAN related
function calls. The first call maps shadow to early_level4_pgt,
the second maps shadow to init_level4_pgt.
If we move clear_page(init_level4_pgt) earlier, we could hide
KASAN low level detail from generic x86_64 initialization code.
The next patch will do it.
Link: http://lkml.kernel.org/r/1435828178-10975-2-git-send-email-a.ryabinin@samsung.com
Commit 0a196848ca36 ("perf: Fix arch_perf_out_copy_user default"),
changes copy_from_user_nmi() to return the number of
remaining bytes so that it behave like copy_from_user().
Unfortunately, when the range is outside of the process
memory, the return value is still the number of byte
copied, eg. 0, instead of the remaining bytes.
As all users of copy_from_user_nmi() were modified as
part of commit 0a196848ca36, the function should be
fixed to return the total number of bytes if range is
not correct.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Link: http://lkml.kernel.org/r/1435001923-30986-1-git-send-email-ydroneaud@opteya.com
If it takes longer than 12us to read the PIT counter lsb/msb,
then the error margin will never fall below 500ppm within 50ms,
and Fast TSC calibration will always fail.
This patch detects when that will happen and fails fast. Note
the failure message is not printed in that case because:
1. it will always happen on that class of hardware
2. the absence of the message is more informative than its
presence
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Len Brown <lenb@kernel.org>
Link: http://lkml.kernel.org/r/556EB717.9070607@intel.com
Pull late x86 platform driver updates from Darren Hart:
"The following came in a bit later and I wanted them to bake in next a
few more days before submitting, thus the second pull.
A new intel_pmc_ipc driver, a symmetrical allocation and free fix in
dell-laptop, a couple minor fixes, and some updated documentation in
the dell-laptop comments.
intel_pmc_ipc:
- Add Intel Apollo Lake PMC IPC driver
tc1100-wmi:
- Delete an unnecessary check before the function call "kfree"
dell-laptop:
- Fix allocating & freeing SMI buffer page
- Show info about WiGig and UWB in debugfs
- Update information about wireless control"
* tag 'platform-drivers-x86-v4.2-2' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
intel_pmc_ipc: Add Intel Apollo Lake PMC IPC driver
tc1100-wmi: Delete an unnecessary check before the function call "kfree"
dell-laptop: Fix allocating & freeing SMI buffer page
dell-laptop: Show info about WiGig and UWB in debugfs
dell-laptop: Update information about wireless control
Pull kvm fixes from Paolo Bonzini:
"Except for the preempt notifiers fix, these are all small bugfixes
that could have been waited for -rc2. Sending them now since I was
taking care of Peter's patch anyway"
kvm: add hyper-v crash msrs values
KVM: x86: remove data variable from kvm_get_msr_common
KVM: s390: virtio-ccw: don't overwrite config space values
KVM: x86: keep track of LVT0 changes under APICv
KVM: x86: properly restore LVT0
KVM: x86: make vapics_in_nmi_mode atomic
sched, preempt_notifier: separate notifier registration from static_key inc/dec
"Two FPU rewrite related fixes. This addresses all known x86
regressions at this stage. Also some other misc fixes"
x86/fpu: Fix boot crash in the early FPU code
x86/asm/entry/64: Update path names
x86/fpu: Fix FPU related boot regression when CPUID masking BIOS feature is enabled
x86/boot/setup: Clean up the e820_reserve_setup_data() code
x86/kaslr: Fix typo in the KASLR_FLAG documentation
Pull perf updates from Ingo Molnar:
"This tree includes an x86 PMU scheduling fix, but most changes are
late breaking tooling fixes and updates:
User visible fixes:
- Create config.detected into OUTPUT directory, fixing parallel
builds sharing the same source directory (Aaro Kiskinen)
- Allow to specify custom linker command, fixing some MIPS64 builds.
(Aaro Kiskinen)
- Fix to show proper convergence stats in 'perf bench numa' (Srikar
Dronamraju)
User visible changes:
- Validate syscall list passed via -e argument to 'perf trace'.
(Arnaldo Carvalho de Melo)
- Introduce 'perf stat --per-thread' (Jiri Olsa)
- Check access permission for --kallsyms and --vmlinux (Li Zhang)
- Move toggling event logic from 'perf top' and into hists browser,
allowing freeze/unfreeze with event lists with more than one entry
(Namhyung Kim)
- Add missing newlines when dumping PERF_RECORD_FINISHED_ROUND and
showing the Aggregated stats in 'perf report -D' (Adrian Hunter)
Infrastructure fixes:
- Add missing break for PERF_RECORD_ITRACE_START, which caused those
events samples to be parsed as well as PERF_RECORD_LOST_SAMPLES.
ITRACE_START only appears when Intel PT or BTS are present, so..
(Jiri Olsa)
- Call the perf_session destructor when bailing out in the inject,
kmem, report, kvm and mem tools (Taeung Song)
Infrastructure changes:
- Move stuff out of 'perf stat' and into the lib for further use
(Jiri Olsa)
- Reference count the cpu_map and thread_map classes (Jiri Olsa)
- Set evsel->{cpus,threads} from the evlist, if not set, allowing the
generalization of some 'perf stat' functions that previously were
accessing private static evlist variable (Jiri Olsa)
- Delete an unnecessary check before the calling free_event_desc()
(Markus Elfring)
- Allow auxtrace data alignment (Adrian Hunter)
- Allow events with dot (Andi Kleen)
- Fix failure to 'perf probe' events on arm (He Kuang)
- Add testing for Makefile.perf (Jiri Olsa)
- Add test for make install with prefix (Jiri Olsa)
- Fix single target build dependency check (Jiri Olsa)
- Access thread_map entries via accessors, prep patch to hold more
info per entry, for ongoing 'perf stat --per-thread' work (Jiri
Olsa)
- Use __weak definition from compiler.h (Sukadev Bhattiprolu)
- Split perf_pmu__new_alias() (Sukadev Bhattiprolu)"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (54 commits)
perf tools: Allow to specify custom linker command
perf tools: Create config.detected into OUTPUT directory
perf mem: Fill in the missing session freeing after an error occurs
perf kvm: Fill in the missing session freeing after an error occurs
perf report: Fill in the missing session freeing after an error occurs
perf kmem: Fill in the missing session freeing after an error occurs
perf inject: Fill in the missing session freeing after an error occurs
perf tools: Add missing break for PERF_RECORD_ITRACE_START
perf/x86: Fix 'active_events' imbalance
perf symbols: Check access permission when reading symbol files
perf stat: Introduce --per-thread option
perf stat: Introduce print_counters function
perf stat: Using init_stats instead of memset
perf stat: Rename print_interval to process_interval
perf stat: Remove perf_evsel__read_cb function
perf stat: Move perf_stat initialization counter process code
perf stat: Move zero_per_pkg into counter process code
perf stat: Separate counters reading and processing
perf stat: Introduce read_counters function
perf stat: Introduce perf_evsel__read function
Jan Kara and Thomas Gleixner reported boot crashes in the FPU
code:
general protection fault: 0000 [#1] SMP
RIP: 0010:[<ffffffff81048a6c>] [<ffffffff81048a6c>] mxcsr_feature_mask_init+0x1c/0x40
2b:* 0f ae 85 00 fe ff ff fxsave -0x200(%rbp)
and bisected it down to the following FPU commit:
91a8c2a5b43f ("x86/fpu: Clean up and fix MXCSR handling")
The reason is that the on-stack FPU registers state variable,
used by the FXSAVE instruction, did not have the required
minimum alignment of 16 bytes, causing the general protection
fault.
This is most likely a GCC bug in older GCC versions, but the
offending commit also added a bogus extra 32-byte alignment
(which GCC ignored too).
So fix this bug by making the variable static again, but also
mark it __initdata this time, because fpu__init_system_mxcsr()
is now an __init function.
Reported-and-bisected-by: Jan Kara <jack@suse.cz>
Reported-bisected-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Link: http://lkml.kernel.org/r/20150704075819.GA9201@gmail.com
Added Hyper-V crash msrs values - HV_X64_MSR_CRASH*.
Signed-off-by: Andrey Smetanin <asmetanin@virtuozzo.com>
Signed-off-by: Denis V. Lunev <den@openvz.org>
Reviewed-by: Peter Hornyack <peterhornyack@google.com>
CC: Paolo Bonzini <pbonzini@redhat.com>
CC: Gleb Natapov <gleb@kernel.org>
