commit 9d2c7203ffdb846399b82b0660563c89e918c751 upstream.
In kernels compiled with CONFIG_PARAVIRT=n, the compiler re-orders the
DR7 read in exc_nmi() to happen before the call to sev_es_ist_enter().
This is problematic when running as an SEV-ES guest because in this
environment the DR7 read might cause a #VC exception, and taking #VC
exceptions is not safe in exc_nmi() before sev_es_ist_enter() has run.
The result is stack recursion if the NMI was caused on the #VC IST
stack, because a subsequent #VC exception in the NMI handler will
overwrite the stack frame of the interrupted #VC handler.
As there are no compiler barriers affecting the ordering of DR7
reads/writes, make the accesses to this register volatile, forbidding
the compiler to re-order them.
[ bp: Massage text, make them volatile too, to make sure some
aggressive compiler optimization pass doesn't discard them. ]
Fixes: 315562c9af3d ("x86/sev-es: Adjust #VC IST Stack on entering NMI handler")
Reported-by: Alexey Kardashevskiy <aik@amd.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Signed-off-by: Borislav Petkov (AMD) <bp@alien8.de>
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20230127035616.508966-1-aik@amd.com
commit 08245672cdc6505550d1a5020603b0a8d4a6dcc7 upstream.
The left shift of int 32 bit integer constant 1 is evaluated using 32 bit
arithmetic and then passed as a 64 bit function argument. In the case where
i is 32 or more this can lead to an overflow. Avoid this by shifting
using the BIT_ULL macro instead.
Fixes: 471af006a747 ("perf/x86/amd: Constrain Large Increment per Cycle events")
Signed-off-by: Colin Ian King <colin.i.king@gmail.com>
Acked-by: Ian Rogers <irogers@google.com>
Acked-by: Kim Phillips <kim.phillips@amd.com>
Link: https://lore.kernel.org/r/20221202135149.1797974-1-colin.i.king@gmail.com
commit 5fa55950729d0762a787451dc52862c3f850f859 upstream.
Baoquan reported that after triggering a crash the subsequent crash-kernel
fails to boot about half of the time. It triggers a NULL pointer
dereference in the periodic tick code.
This happens because the legacy timer interrupt (IRQ0) is resent in
software which happens in soft interrupt (tasklet) context. In this context
get_irq_regs() returns NULL which leads to the NULL pointer dereference.
The reason for the resend is a spurious APIC interrupt on the IRQ0 vector
which is captured and leads to a resend when the legacy timer interrupt is
enabled. This is wrong because the legacy PIC interrupts are level
triggered and therefore should never be resent in software, but nothing
ever sets the IRQ_LEVEL flag on those interrupts, so the core code does not
know about their trigger type.
Ensure that IRQ_LEVEL is set when the legacy PCI interrupts are set up.
Fixes: a4633adcdbc1 ("[PATCH] genirq: add genirq sw IRQ-retrigger")
Reported-by: Baoquan He <bhe@redhat.com>
Tested-by: Baoquan He <bhe@redhat.com>
Link: https://lore.kernel.org/r/87mt6rjrra.ffs@tglx
commit a44b331614e6f7e63902ed7dff7adc8c85edd8bc upstream.
When serializing and deserializing kvm_sregs, attributes of the segment
descriptors are stored by user space. For unusable segments,
vmx_segment_access_rights skips all attributes and sets them to 0.
This means we zero out the DPL (Descriptor Privilege Level) for unusable
entries.
Unusable segments are - contrary to their name - usable in 64bit mode and
are used by guests to for example create a linear map through the
NULL selector.
VMENTER checks if SS.DPL is correct depending on the CS segment type.
For types 9 (Execute Only) and 11 (Execute Read), CS.DPL must be equal to
SS.DPL [1].
We have seen real world guests setting CS to a usable segment with DPL=3
and SS to an unusable segment with DPL=3. Once we go through an sregs
get/set cycle, SS.DPL turns to 0. This causes the virtual machine to crash
reproducibly.
This commit changes the attribute logic to always preserve attributes for
unusable segments. According to [2] SS.DPL is always saved on VM exits,
regardless of the unusable bit so user space applications should have saved
the information on serialization correctly.
[3] specifies that besides SS.DPL the rest of the attributes of the
descriptors are undefined after VM entry if unusable bit is set. So, there
should be no harm in setting them all to the previous state.
[1] Intel SDM Vol 3C 26.3.1.2 Checks on Guest Segment Registers
[2] Intel SDM Vol 3C 27.3.2 Saving Segment Registers and Descriptor-Table
Registers
[3] Intel SDM Vol 3C 26.3.2.2 Loading Guest Segment Registers and
Descriptor-Table Registers
Cc: Alexander Graf <graf@amazon.de>
Signed-off-by: Hendrik Borghorst <hborghor@amazon.de>
Reviewed-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Alexander Graf <graf@amazon.com>
Message-Id: <20221114164823.69555-1-hborghor@amazon.de>
commit 0e25498f8cd43c1b5aa327f373dd094e9a006da7 upstream.
There are two big uses of do_exit. The first is it's design use to be
the guts of the exit(2) system call. The second use is to terminate
a task after something catastrophic has happened like a NULL pointer
in kernel code.
Add a function make_task_dead that is initialy exactly the same as
do_exit to cover the cases where do_exit is called to handle
catastrophic failure. In time this can probably be reduced to just a
light wrapper around do_task_dead. For now keep it exactly the same so
that there will be no behavioral differences introducing this new
concept.
Replace all of the uses of do_exit that use it for catastraphic
task cleanup with make_task_dead to make it clear what the code
is doing.
As part of this rename rewind_stack_do_exit
rewind_stack_and_make_dead.
commit a8fb40966f19ff81520d9ccf8f7e2b95201368b8 upstream.
All Zen or newer CPU which support C3 shares cache. Its not necessary to
flush the caches in software before entering C3. This will cause drop in
performance for the cores which share some caches. ARB_DIS is not used
with current AMD C state implementation. So set related flags correctly.
Signed-off-by: Deepak Sharma <deepak.sharma@amd.com>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@igalia.com>
commit 55228db2697c09abddcb9487c3d9fa5854a932cd upstream.
WG14 N2350 specifies that it is an undefined behavior to have type
definitions within offsetof", see
https://www.open-std.org/jtc1/sc22/wg14/www/docs/n2350.htm
This specification is also part of C23.
Therefore, replace the TYPE_ALIGN macro with the _Alignof builtin to
avoid undefined behavior. (_Alignof itself is C11 and the kernel is
built with -gnu11).
ISO C11 _Alignof is subtly different from the GNU C extension
__alignof__. Latter is the preferred alignment and _Alignof the
minimal alignment. For long long on x86 these are 8 and 4
respectively.
The macro TYPE_ALIGN's behavior matches _Alignof rather than
__alignof__.
[ bp: Massage commit message. ]
Signed-off-by: YingChi Long <me@inclyc.cn>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Link: https://lore.kernel.org/r/20220925153151.2467884-1-me@inclyc.cn
Signed-off-by: Nathan Chancellor <nathan@kernel.org>
[ Upstream commit 55d235361fccef573990dfa5724ab453866e7816 ]
Fix a warning: "found `movsd'; assuming `movsl' was meant"
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
[ Upstream commit fe1f0714385fbcf76b0cbceb02b7277d842014fc ]
When the user moves a running task to a new rdtgroup using the task's
file interface or by deleting its rdtgroup, the resulting change in
CLOSID/RMID must be immediately propagated to the PQR_ASSOC MSR on the
task(s) CPUs.
x86 allows reordering loads with prior stores, so if the task starts
running between a task_curr() check that the CPU hoisted before the
stores in the CLOSID/RMID update then it can start running with the old
CLOSID/RMID until it is switched again because __rdtgroup_move_task()
failed to determine that it needs to be interrupted to obtain the new
CLOSID/RMID.
Refer to the diagram below:
CPU 0 CPU 1
__rdtgroup_move_task():
curr <- t1->cpu->rq->curr
__schedule():
rq->curr <- t1
resctrl_sched_in():
t1->{closid,rmid} -> {1,1}
t1->{closid,rmid} <- {2,2}
if (curr == t1) // false
IPI(t1->cpu)
A similar race impacts rdt_move_group_tasks(), which updates tasks in a
deleted rdtgroup.
In both cases, use smp_mb() to order the task_struct::{closid,rmid}
stores before the loads in task_curr(). In particular, in the
rdt_move_group_tasks() case, simply execute an smp_mb() on every
iteration with a matching task.
It is possible to use a single smp_mb() in rdt_move_group_tasks(), but
this would require two passes and a means of remembering which
task_structs were updated in the first loop. However, benchmarking
results below showed too little performance impact in the simple
approach to justify implementing the two-pass approach.
Times below were collected using `perf stat` to measure the time to
remove a group containing a 1600-task, parallel workload.
CPU: Intel(R) Xeon(R) Platinum P-8136 CPU @ 2.00GHz (112 threads)
# mkdir /sys/fs/resctrl/test
# echo $$ > /sys/fs/resctrl/test/tasks
# perf bench sched messaging -g 40 -l 100000
task-clock time ranges collected using:
# perf stat rmdir /sys/fs/resctrl/test
Baseline: 1.54 - 1.60 ms
smp_mb() every matching task: 1.57 - 1.67 ms
Fixes: ae28d1aae48a ("x86/resctrl: Use an IPI instead of task_work_add() to update PQR_ASSOC MSR")
Fixes: 0efc89be9471 ("x86/intel_rdt: Update task closid immediately on CPU in rmdir and unmount")
Signed-off-by: Peter Newman <peternewman@google.com>
Reviewed-by: Reinette Chatre <reinette.chatre@intel.com>
Reviewed-by: Babu Moger <babu.moger@amd.com>
Cc: <stable@kernel.org>
Link: https://lore.kernel.org/r/20221220161123.432120-1-peternewman@google.com
unnecessary IPI
[ Upstream commit e0ad6dc8969f790f14bddcfd7ea284b7e5f88a16 ]
James reported in [1] that there could be two tasks running on the same CPU
with task_struct->on_cpu set. Using task_struct->on_cpu as a test if a task
is running on a CPU may thus match the old task for a CPU while the
scheduler is running and IPI it unnecessarily.
task_curr() is the correct helper to use. While doing so move the #ifdef
check of the CONFIG_SMP symbol to be a C conditional used to determine
if this helper should be used to ensure the code is always checked for
correctness by the compiler.
[1] https://lore.kernel.org/lkml/a782d2f3-d2f6-795f-f4b1-9462205fd581@arm.com
Reported-by: James Morse <james.morse@arm.com>
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
Link: https://lkml.kernel.org/r/e9e68ce1441a73401e08b641cc3b9a3cf13fe6d4.1608243147.git.reinette.chatre@intel.com
Stable-dep-of: fe1f0714385f ("x86/resctrl: Fix task CLOSID/RMID update race")
[ Upstream commit 45e966fcca03ecdcccac7cb236e16eea38cc18af ]
Passing the host topology to the guest is almost certainly wrong
and will confuse the scheduler. In addition, several fields of
these CPUID leaves vary on each processor; it is simply impossible to
return the right values from KVM_GET_SUPPORTED_CPUID in such a way that
they can be passed to KVM_SET_CPUID2.
The values that will most likely prevent confusion are all zeroes.
Userspace will have to override it anyway if it wishes to present a
specific topology to the guest.
commit 7c6dd961d0c8e7e8f9fdc65071fb09ece702e18d upstream.
With 'GNU assembler (GNU Binutils for Debian) 2.39.90.20221231' the
build now reports:
arch/x86/realmode/rm/../../boot/bioscall.S: Assembler messages:
arch/x86/realmode/rm/../../boot/bioscall.S:35: Warning: found `movsd'; assuming `movsl' was meant
arch/x86/realmode/rm/../../boot/bioscall.S:70: Warning: found `movsd'; assuming `movsl' was meant
arch/x86/boot/bioscall.S: Assembler messages:
arch/x86/boot/bioscall.S:35: Warning: found `movsd'; assuming `movsl' was meant
arch/x86/boot/bioscall.S:70: Warning: found `movsd'; assuming `movsl' was meant
Which is due to:
PR gas/29525
Note that with the dropped CMPSD and MOVSD Intel Syntax string insn
templates taking operands, mixed IsString/non-IsString template groups
(with memory operands) cannot occur anymore. With that
maybe_adjust_templates() becomes unnecessary (and is hence being
removed).
More details: https://sourceware.org/bugzilla/show_bug.cgi?id=29525
Borislav Petkov further explains:
" the particular problem here is is that the 'd' suffix is
"conflicting" in the sense that you can have SSE mnemonics like movsD %xmm...
and the same thing also for string ops (which is the case here) so apparently
the agreement in binutils land is to use the always accepted suffixes 'l' or 'q'
and phase out 'd' slowly... "
Fixes: 7a734e7dd93b ("x86, setup: "glove box" BIOS calls -- infrastructure")
Acked-by: Borislav Petkov (AMD) <bp@alien8.de>
Link: https://lore.kernel.org/r/Y71I3Ex2pvIxMpsP@hirez.programming.kicks-ass.net
commit a664ec9158eeddd75121d39c9a0758016097fa96 upstream.
We missed the window between the TIF flag update and the next reschedule.
Signed-off-by: Rodrigo Branco <bsdaemon@google.com>
Reviewed-by: Borislav Petkov (AMD) <bp@alien8.de>
Cc: <stable@vger.kernel.org>
[ Upstream commit 63dc6325ff41ee9e570bde705ac34a39c5dbeb44 ]
Since the CONFIG_RETHUNK and CONFIG_SLS will use INT3 for stopping
speculative execution after function return, kprobe jump optimization
always fails on the functions with such INT3 inside the function body.
(It already checks the INT3 padding between functions, but not inside
the function)
To avoid this issue, as same as kprobes, check whether the INT3 comes
from kgdb or not, and if so, stop decoding and make it fail. The other
INT3 will come from CONFIG_RETHUNK/CONFIG_SLS and those can be
treated as a one-byte instruction.
Fixes: e463a09af2f0 ("x86: Add straight-line-speculation mitigation")
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Masami Hiramatsu (Google) <mhiramat@kernel.org>
Link: https://lore.kernel.org/r/167146051929.1374301.7419382929328081706.stgit@devnote3
[ Upstream commit 77e768ec1391dc0d6cd89822aa60b9a1c1bd8128 ]
Simplify code, improve decoding error checking.
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Link: https://lkml.kernel.org/r/20210304174237.31945-12-bp@alien8.de
Stable-dep-of: 63dc6325ff41 ("x86/kprobes: Fix optprobe optimization check with CONFIG_RETHUNK")
[ Upstream commit bc1b705b0eee4c645ad8b3bbff3c8a66e9688362 ]
AMD's MCA Thresholding feature counts errors of all severity levels, not
just correctable errors. If a deferred error causes the threshold limit
to be reached (it was the error that caused the overflow), then both a
deferred error interrupt and a thresholding interrupt will be triggered.
The order of the interrupts is not guaranteed. If the threshold
interrupt handler is executed first, then it will clear MCA_STATUS for
the error. It will not check or clear MCA_DESTAT which also holds a copy
of the deferred error. When the deferred error interrupt handler runs it
will not find an error in MCA_STATUS, but it will find the error in
MCA_DESTAT. This will cause two errors to be logged.
Check for deferred errors when handling a threshold interrupt. If a bank
contains a deferred error, then clear the bank's MCA_DESTAT register.
Define a new helper function to do the deferred error check and clearing
of MCA_DESTAT.
[ bp: Simplify, convert comment to passive voice. ]
Fixes: 37d43acfd79f ("x86/mce/AMD: Redo error logging from APIC LVT interrupt handlers")
Signed-off-by: Yazen Ghannam <yazen.ghannam@amd.com>
Link: https://lore.kernel.org/r/20220621155943.33623-1-yazen.ghannam@amd.com
[ Upstream commit 8121b8f947be0033f567619be204639a50cad298 ]
Avoid having indirect calls and use a normal function which returns the
proper MSR address based on ->smca setting.
No functional changes.
Reviewed-by: Tony Luck <tony.luck@intel.com>
Link: https://lkml.kernel.org/r/20210922165101.18951-4-bp@alien8.de
Stable-dep-of: bc1b705b0eee ("x86/MCE/AMD: Clear DFR errors found in THR handler")
[ Upstream commit 6532783310e2b2f50dc13f46c49aa6546cb6e7a3 ]
Current clear_attr_update procedure in pmu_set_mapping() sets attr_update
field in NULL that is not correct because intel_uncore_type pmu types can
contain several groups in attr_update field. For example, SPR platform
already has uncore_alias_group to update and then UPI topology group will
be added in next patches.
Fix current behavior and clear attr_update group related to mapping only.
Fixes: bb42b3d39781 ("perf/x86/intel/uncore: Expose an Uncore unit to IIO PMON mapping")
Signed-off-by: Alexander Antonov <alexander.antonov@linux.intel.com>
Reviewed-by: Kan Liang <kan.liang@linux.intel.com>
Link: https://lore.kernel.org/r/20221117122833.3103580-4-alexander.antonov@linux.intel.com
[ Upstream commit f471fac77b41a2573c7b677ef790bf18a0e64195 ]
Currently I/O stacks to IIO PMON mapping is available on Skylake servers
only and need to make code more general to easily enable further platforms.
So, introduce get_topology() callback in struct intel_uncore_type which
allows to move common code to separate function and make mapping procedure
more general.
Link: https://lkml.kernel.org/r/20210426131614.16205-2-alexander.antonov@linux.intel.com
commit 1993bf97992df2d560287f3c4120eda57426843d upstream.
speculative execution after RET instruction, kprobes always failes to
check the probed instruction boundary by decoding the function body if
the probed address is after such sequence. (Note that some conditional
code blocks will be placed after function return, if compiler decides
it is not on the hot path.)
This is because kprobes expects kgdb puts the INT3 as a software
breakpoint and it will replace the original instruction.
But these INT3 are not such purpose, it doesn't need to recover the
To avoid this issue, kprobes checks whether the INT3 is owned by
Link: https://lore.kernel.org/r/167146051026.1374301.392728975473572291.stgit@devnote3
commit fd3dc56253acbe9c641a66d312d8393cd55eb04c upstream.
After someone reported a bug report with a failed modification due to the
expected value not matching what was found, it came to my attention that
the ftrace_expected is no longer set when that happens. This makes for
debugging the issue a bit more difficult.
Set ftrace_expected to the expected code before calling ftrace_bug, so
that it shows what was expected and why it failed.
Link: https://lore.kernel.org/all/CA+wXwBQ-VhK+hpBtYtyZP-NiX4g8fqRRWithFOHQW-0coQ3vLg@mail.gmail.com/
Link: https://lore.kernel.org/linux-trace-kernel/20221209105247.01d4e51d@gandalf.local.home
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: "x86@kernel.org" <x86@kernel.org>
Fixes: 768ae4406a5c ("x86/ftrace: Use text_poke()")
Signed-off-by: Steven Rostedt (Google) <rostedt@goodmis.org>
commit be1b670f61443aa5d0d01782e9b8ea0ee825d018 upstream.
The retries in load_ucode_intel_ap() were in place to support systems
with mixed steppings. Mixed steppings are no longer supported and there is
only one microcode image at a time. Any retries will simply reattempt to
apply the same image over and over without making progress.
[ bp: Zap the circumstantial reasoning from the commit message. ]
Fixes: 06b8534cb728 ("x86/microcode: Rework microcode loading")
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Link: https://lore.kernel.org/r/20221129210832.107850-3-ashok.raj@intel.com
commit 9cc409325ddd776f6fd6293d5ce93ce1248af6e4 upstream.
Inject #GP for if VMXON is attempting with a CR0/CR4 that fails the
generic "is CRx valid" check, but passes the CR4.VMXE check, and do the
generic checks _after_ handling the post-VMXON VM-Fail.
The CR4.VMXE check, and all other #UD cases, are special pre-conditions
that are enforced prior to pivoting on the current VMX mode, i.e. occur
before interception if VMXON is attempted in VMX non-root mode.
All other CR0/CR4 checks generate #GP and effectively have lower priority
than the post-VMXON check.
Per the SDM:
IF (register operand) or (CR0.PE = 0) or (CR4.VMXE = 0) or ...
THEN #UD;
ELSIF not in VMX operation
THEN
IF (CPL > 0) or (in A20M mode) or
(the values of CR0 and CR4 are not supported in VMX operation)
THEN #GP(0);
ELSIF in VMX non-root operation
THEN VMexit;
ELSIF CPL > 0
THEN #GP(0);
ELSE VMfail("VMXON executed in VMX root operation");
FI;
which, if re-written without ELSIF, yields:
THEN #UD
THEN VMexit;
IF CPL > 0
THEN #GP(0)
IF in VMX operation
THEN VMfail("VMXON executed in VMX root operation");
IF (in A20M mode) or
THEN #GP(0);
Note, KVM unconditionally forwards VMXON VM-Exits that occur in L2 to L1,
i.e. there is no need to check the vCPU is not in VMX non-root mode. Add
a comment to explain why unconditionally forwarding such exits is
functionally correct.
Reported-by: Eric Li <ercli@ucdavis.edu>
Fixes: c7d855c2aff2 ("KVM: nVMX: Inject #UD if VMXON is attempted with incompatible CR0/CR4")
Signed-off-by: Sean Christopherson <seanjc@google.com>
Link: https://lore.kernel.org/r/20221006001956.329314-1-seanjc@google.com
[ Upstream commit 32c97d980e2eef25465d453f2956a9ca68926a3c ]
Hyper-V cleanup code comes under panic path where preemption and irq
is already disabled. So calling of unregister_syscore_ops might schedule
out the thread even for the case where mutex lock is free.
hyperv_cleanup
mutex_lock(&syscore_ops_lock)
might_sleep
Here might_sleep might schedule out this thread, where voluntary preemption
config is on and this thread will never comes back. And also this was added
earlier to maintain the symmetry which is not required as this can comes
during crash shutdown path only.
To prevent the same, removing unregister_syscore_ops function call.
Signed-off-by: Gaurav Kohli <gauravkohli@linux.microsoft.com>
Reviewed-by: Michael Kelley <mikelley@microsoft.com>
Link: https://lore.kernel.org/r/1669443291-2575-1-git-send-email-gauravkohli@linux.microsoft.com
Signed-off-by: Wei Liu <wei.liu@kernel.org>
[ Upstream commit ca84ce153d887b1dc8b118029976cc9faf2a9b40 ]
In xen_init_lock_cpu(), the @name has allocated new string by kasprintf(),
if bind_ipi_to_irqhandler() fails, it should be freed, otherwise may lead
to a memory leak issue, fix it.
Fixes: 2d9e1e2f58b5 ("xen: implement Xen-specific spinlocks")
Signed-off-by: Xiu Jianfeng <xiujianfeng@huawei.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Link: https://lore.kernel.org/r/20221123155858.11382-3-xiujianfeng@huawei.com
Signed-off-by: Juergen Gross <jgross@suse.com>
[ Upstream commit 69143f60868b3939ddc89289b29db593b647295e ]
These local variables @{resched|pmu|callfunc...}_name saves the new
string allocated by kasprintf(), and when bind_{v}ipi_to_irqhandler()
fails, it goes to the @fail tag, and calls xen_smp_intr_free{_pv}() to
free resource, however the new string is not saved, which cause a memory
leak issue. fix it.
Fixes: 9702785a747a ("i386: move xen")
Link: https://lore.kernel.org/r/20221123155858.11382-2-xiujianfeng@huawei.com
[ Upstream commit cefa72129e45313655d53a065b8055aaeb01a0c9 ]
Intel ICC -hotpatch inserts 2-byte "0x66 0x90" NOP at the start of each
function to reserve extra space for hot-patching, and currently it is not
possible to probe these functions because branch_setup_xol_ops() wrongly
rejects NOP with REP prefix as it treats them like word-sized branch
instructions.
Fixes: 250bbd12c2fe ("uprobes/x86: Refuse to attach uprobe to "word-sized" branch insns")
Reported-by: Seiji Nishikawa <snishika@redhat.com>
Suggested-by: Denys Vlasenko <dvlasenk@redhat.com>
Acked-by: Masami Hiramatsu (Google) <mhiramat@kernel.org>
Link: https://lore.kernel.org/r/20221204173933.GA31544@redhat.com
[ Upstream commit 17b8d847b92d815d1638f0de154654081d66b281 ]
pci_get_device() will increase the reference count for the returned
pci_dev, so tgl_uncore_get_mc_dev() will return a pci_dev with its
reference count increased. We need to call pci_dev_put() to decrease the
reference count before exiting from __uncore_imc_init_box(). Add
pci_dev_put() for both normal and error path.
Fixes: fdb64822443e ("perf/x86: Add Intel Tiger Lake uncore support")
Signed-off-by: Xiongfeng Wang <wangxiongfeng2@huawei.com>
Link: https://lore.kernel.org/r/20221118063137.121512-5-wangxiongfeng2@huawei.com
[ Upstream commit 8ebd16c11c346751b3944d708e6c181ed4746c39 ]
pci_dev, so snr_uncore_get_mc_dev() will return a pci_dev with its
reference count. Let's add the missing pci_dev_put().
Fixes: ee49532b38dd ("perf/x86/intel/uncore: Add IMC uncore support for Snow Ridge")
Link: https://lore.kernel.org/r/20221118063137.121512-4-wangxiongfeng2@huawei.com
[ Upstream commit 1ff9dd6e7071a561f803135c1d684b13c7a7d01d ]
'dev'. We need to call pci_dev_put() to decrease the reference count.
Since 'dev' is only used in pci_read_config_dword(), let's add
pci_dev_put() right after it.
Fixes: 9d480158ee86 ("perf/x86/intel/uncore: Remove uncore extra PCI dev HSWEP_PCI_PCU_3")
Link: https://lore.kernel.org/r/20221118063137.121512-3-wangxiongfeng2@huawei.com
[ Upstream commit 50b7b6f29de3e18e9d6c09641256a0296361cfee ]
As io_threads are fully set up USER threads it's clearer to separate the
code path from the KTHREAD logic.
The only remaining difference to user space threads is that io_threads
never return to user space again. Instead they loop within the given
worker function.
The fact that they never return to user space means they don't have an
user space thread stack. In order to indicate that to tools like gdb we
reset the stack and instruction pointers to 0.
This allows gdb attach to user space processes using io-uring, which like
means that they have io_threads, without printing worrying message like
this:
warning: Selected architecture i386:x86-64 is not compatible with reported target architecture i386
warning: Architecture rejected target-supplied description
The output will be something like this:
(gdb) info threads
Id Target Id Frame
* 1 LWP 4863 "io_uring-cp-for" syscall () at ../sysdeps/unix/sysv/linux/x86_64/syscall.S:38
2 LWP 4864 "iou-mgr-4863" 0x0000000000000000 in ?? ()
3 LWP 4865 "iou-wrk-4863" 0x0000000000000000 in ?? ()
(gdb) thread 3
[Switching to thread 3 (LWP 4865)]
#0 0x0000000000000000 in ?? ()
(gdb) bt
Backtrace stopped: Cannot access memory at address 0x0
Fixes: 4727dc20e042 ("arch: setup PF_IO_WORKER threads like PF_KTHREAD")
Link: https://lore.kernel.org/io-uring/044d0bad-6888-a211-e1d3-159a4aeed52d@polymtl.ca/T/#m1bbf5727e3d4e839603f6ec7ed79c7eebfba6267
Signed-off-by: Stefan Metzmacher <metze@samba.org>
cc: Linus Torvalds <torvalds@linux-foundation.org>
cc: Jens Axboe <axboe@kernel.dk>
cc: Andy Lutomirski <luto@kernel.org>
cc: linux-kernel@vger.kernel.org
cc: io-uring@vger.kernel.org
cc: x86@kernel.org
Link: https://lore.kernel.org/r/20210505110310.237537-1-metze@samba.org
[ Upstream commit 4727dc20e0422211a0e0c72b1ace4ed6096df8a6 ]
PF_IO_WORKER are kernel threads too, but they aren't PF_KTHREAD in the
sense that we don't assign ->set_child_tid with our own structure. Just
ensure that every arch sets up the PF_IO_WORKER threads like kthreads
in the arch implementation of copy_thread().
[ Upstream commit c8d5ed67936fddbe2ae845fc80397718006322d7 ]
The generic entry code has support for TIF_NOTIFY_SIGNAL already. Just
provide the TIF bit.
[ tglx: Adopted to other TIF changes in x86 ]
Link: https://lore.kernel.org/r/20201026203230.386348-4-axboe@kernel.dk
[ Upstream commit 12db8b690010ccfadf9d0b49a1e1798e47dbbe1a ]
Add TIF_NOTIFY_SIGNAL handling in the generic entry code, which if set,
will return true if signal_pending() is used in a wait loop. That causes an
exit of the loop so that notify_signal tracehooks can be run. If the wait
loop is currently inside a system call, the system call is restarted once
task_work has been processed.
In preparation for only having arch_do_signal() handle syscall restarts if
_TIF_SIGPENDING isn't set, rename it to arch_do_signal_or_restart(). Pass
in a boolean that tells the architecture specific signal handler if it
should attempt to get a signal, or just process a potential syscall
restart.
For !CONFIG_GENERIC_ENTRY archs, add the TIF_NOTIFY_SIGNAL handling to
get_signal(). This is done to minimize the needed architecture changes to
support this feature.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Link: https://lore.kernel.org/r/20201026203230.386348-3-axboe@kernel.dk
commit 29368e09392123800e5e2bf0f3eda91f16972e52 upstream.
The call to rcu_cpu_starting() in mtrr_ap_init() is not early enough
in the CPU-hotplug onlining process, which results in lockdep splats
as follows:
WARNING: suspicious RCU usage
5.9.0+ #268 Not tainted
kernel/kprobes.c:300 RCU-list traversed in non-reader section!!
RCU used illegally from offline CPU!
rcu_scheduler_active = 1, debug_locks = 1
no locks held by swapper/1/0.
stack backtrace:
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.9.0+ #268
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 1.10.2-1ubuntu1 04/01/2014
Call Trace:
dump_stack+0x77/0x97
__is_insn_slot_addr+0x15d/0x170
kernel_text_address+0xba/0xe0
? get_stack_info+0x22/0xa0
__kernel_text_address+0x9/0x30
show_trace_log_lvl+0x17d/0x380
? dump_stack+0x77/0x97
__lock_acquire+0xdf7/0x1bf0
lock_acquire+0x258/0x3d0
? vprintk_emit+0x6d/0x2c0
_raw_spin_lock+0x27/0x40
printk+0x4d/0x69
start_secondary+0x1c/0x100
secondary_startup_64_no_verify+0xb8/0xbb
This is avoided by moving the call to rcu_cpu_starting up near
the beginning of the start_secondary() function. Note that the
raw_smp_processor_id() is required in order to avoid calling into lockdep
before RCU has declared the CPU to be watched for readers.
Link: https://lore.kernel.org/lkml/160223032121.7002.1269740091547117869.tip-bot2@tip-bot2/
Reported-by: Qian Cai <cai@redhat.com>
Signed-off-by: Paul E. McKenney <paulmck@kernel.org>
Cc: Joel Fernandes <joel@joelfernandes.org>
[ Upstream commit 0dd8d6cb9eddfe637bcd821bbfd40ebd5a0737b9 ]
There are 4 users of mc146818_get_time() and none of them was checking
the return value from this function. Change this.
Print the appropriate warnings in callers of mc146818_get_time() instead
of in the function mc146818_get_time() itself, in order not to add
strings to rtc-mc146818-lib.c, which is kind of a library.
The callers of alpha_rtc_read_time() and cmos_read_time() may use the
contents of (struct rtc_time *) even when the functions return a failure
code. Therefore, set the contents of (struct rtc_time *) to 0x00,
which looks more sensible then 0xff and aligns with the (possibly
stale?) comment in cmos_read_time:
* If pm_trace abused the RTC for storage, set the timespec to 0,
* which tells the caller that this RTC value is unusable.
For consistency, do this in mc146818_get_time().
Note: hpet_rtc_interrupt() may call mc146818_get_time() many times a
second. It is very unlikely, though, that the RTC suddenly stops
working and mc146818_get_time() would consistently fail.
Only compile-tested on alpha.
Signed-off-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Alexandre Belloni <alexandre.belloni@bootlin.com>
Cc: linux-alpha@vger.kernel.org
Cc: x86@kernel.org
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Link: https://lore.kernel.org/r/20211210200131.153887-4-mat.jonczyk@o2.pl
Stable-dep-of: cd17420ebea5 ("rtc: cmos: avoid UIP when writing alarm time")
commit 50bcceb7724e471d9b591803889df45dcbb584bc upstream.
pm_save_spec_msr() keeps a list of all the MSRs which _might_ need
to be saved and restored at hibernate and resume. However, it has
zero awareness of CPU support for these MSRs. It mostly works by
unconditionally attempting to manipulate these MSRs and relying on
rdmsrl_safe() being able to handle a #GP on CPUs where the support is
unavailable.
However, it's possible for reads (RDMSR) to be supported for a given MSR
while writes (WRMSR) are not. In this case, msr_build_context() sees
a successful read (RDMSR) and marks the MSR as valid. Then, later, a
write (WRMSR) fails, producing a nasty (but harmless) error message.
This causes restore_processor_state() to try and restore it, but writing
this MSR is not allowed on the Intel Atom N2600 leading to:
unchecked MSR access error: WRMSR to 0x122 (tried to write 0x0000000000000002) \
at rIP: 0xffffffff8b07a574 (native_write_msr+0x4/0x20)
Call Trace:
<TASK>
x86_acpi_suspend_lowlevel
acpi_suspend_enter
suspend_devices_and_enter
pm_suspend.cold
state_store
kernfs_fop_write_iter
vfs_write
ksys_write
do_syscall_64
? do_syscall_64
? up_read
? lock_is_held_type
? asm_exc_page_fault
? lockdep_hardirqs_on
entry_SYSCALL_64_after_hwframe
To fix this, add the corresponding X86_FEATURE bit for each MSR. Avoid
trying to manipulate the MSR when the feature bit is clear. This
required adding a X86_FEATURE bit for MSRs that do not have one already,
but it's a small price to pay.
[ bp: Move struct msr_enumeration inside the only function that uses it. ]
[Pawan: Resolve build issue in backport]
Fixes: 73924ec4d560 ("x86/pm: Save the MSR validity status at context setup")
Reported-by: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Link: https://lore.kernel.org/r/c24db75d69df6e66c0465e13676ad3f2837a2ed8.1668539735.git.pawan.kumar.gupta@linux.intel.com
commit aaa65d17eec372c6a9756833f3964ba05b05ea14 upstream.
Support for the TSX control MSR is enumerated in MSR_IA32_ARCH_CAPABILITIES.
This is different from how other CPU features are enumerated i.e. via
CPUID. Currently, a call to tsx_ctrl_is_supported() is required for
enumerating the feature. In the absence of a feature bit for TSX control,
any code that relies on checking feature bits directly will not work.
In preparation for adding a feature bit check in MSR save/restore
during suspend/resume, set a new feature bit X86_FEATURE_TSX_CTRL when
MSR_IA32_TSX_CTRL is present.
[ bp: Remove tsx_ctrl_is_supported()]
[Pawan: Resolved conflicts in backport; Removed parts of commit message
referring to removed function tsx_ctrl_is_supported()]
Suggested-by: Andrew Cooper <andrew.cooper3@citrix.com>
Link: https://lore.kernel.org/r/de619764e1d98afbb7a5fa58424f1278ede37b45.1668539735.git.pawan.kumar.gupta@linux.intel.com
commit 66065157420c5b9b3f078f43d313c153e1ff7f83 upstream.
The "force" argument to write_spec_ctrl_current() is currently ambiguous
as it does not guarantee the MSR write. This is due to the optimization
that writes to the MSR happen only when the new value differs from the
cached value.
This is fine in most cases, but breaks for S3 resume when the cached MSR
value gets out of sync with the hardware MSR value due to S3 resetting
it.
When x86_spec_ctrl_current is same as x86_spec_ctrl_base, the MSR write
is skipped. Which results in SPEC_CTRL mitigations not getting restored.
Move the MSR write from write_spec_ctrl_current() to a new function that
unconditionally writes to the MSR. Update the callers accordingly and
rename functions.
[ bp: Rework a bit. ]
Fixes: caa0ff24d5d0 ("x86/bugs: Keep a per-CPU IA32_SPEC_CTRL value")
Suggested-by: Borislav Petkov <bp@alien8.de>
Link: https://lore.kernel.org/r/806d39b0bfec2fe8f50dc5446dff20f5bb24a959.1669821572.git.pawan.kumar.gupta@linux.intel.com
commit 4dbd6a3e90e03130973688fd79e19425f720d999 upstream.
Current code re-calculates the size after aligning the starting and
ending physical addresses on a page boundary. But the re-calculation
also embeds the masking of high order bits that exceed the size of
the physical address space (via PHYSICAL_PAGE_MASK). If the masking
removes any high order bits, the size calculation results in a huge
value that is likely to immediately fail.
Fix this by re-calculating the page-aligned size first. Then mask any
high order bits using PHYSICAL_PAGE_MASK.
Fixes: ffa71f33a820 ("x86, ioremap: Fix incorrect physical address handling in PAE mode")
Signed-off-by: Michael Kelley <mikelley@microsoft.com>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Link: https://lore.kernel.org/r/1668624097-14884-2-git-send-email-mikelley@microsoft.com
commit 05311ce954aebe75935d9ae7d38ac82b5b796e33 upstream.
It is valid to receive external interrupt and have broken IDT entry,
which will lead to #GP with exit_int_into that will contain the index of
the IDT entry (e.g any value).
Other exceptions can happen as well, like #NP or #SS
(if stack switch fails).
Thus this warning can be user triggred and has very little value.
Signed-off-by: Maxim Levitsky <mlevitsk@redhat.com>
Message-Id: <20221103141351.50662-10-mlevitsk@redhat.com>
commit 917401f26a6af5756d89b550a8e1bd50cf42b07e upstream.
If the VM was terminated while nested, we free the nested state
while the vCPU still is in nested mode.
Soon a warning will be added for this condition.
Message-Id: <20221103141351.50662-2-mlevitsk@redhat.com>
commit ce0d998be9274dd3a3d971cbeaa6fe28fd2c3062 upstream.
Deal with errata TGL052, ADL037 and RPL017 "Trace May Contain Incorrect
Data When Configured With Single Range Output Larger Than 4KB" by
disabling single range output whenever larger than 4KB.
Fixes: 670638477aed ("perf/x86/intel/pt: Opportunistically use single range output mode")
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: https://lkml.kernel.org/r/20221112151508.13768-1-adrian.hunter@intel.com
commit 2632daebafd04746b4b96c2f26a6021bc38f6209 upstream.
DE_CFG contains the LFENCE serializing bit, restore it on resume too.
This is relevant to older families due to the way how they do S3.
Unify and correct naming while at it.
Fixes: e4d0e84e4907 ("x86/cpu/AMD: Make LFENCE a serializing instruction")
Reported-by: Andrew Cooper <Andrew.Cooper3@citrix.com>
Reported-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
commit ad8f9e69942c7db90758d9d774157e53bce94840 upstream.
Update the emulation mode when handling writes to CR0, because
toggling CR0.PE switches between Real and Protected Mode, and toggling
CR0.PG when EFER.LME=1 switches between Long and Protected Mode.
This is likely a benign bug because there is no writeback of state,
other than the RIP increment, and when toggling CR0.PE, the CPU has
to execute code from a very low memory address.
Message-Id: <20221025124741.228045-14-mlevitsk@redhat.com>
commit d087e0f79fa0dd336a9a6b2f79ec23120f5eff73 upstream.
Some instructions update the cpu execution mode, which needs to update the
emulation mode.
Extract this code, and make assign_eip_far use it.
assign_eip_far now reads CS, instead of getting it via a parameter,
which is ok, because callers always assign CS to the same value
before calling this function.
No functional change is intended.
Message-Id: <20221025124741.228045-12-mlevitsk@redhat.com>
commit 5015bb89b58225f97df6ac44383e7e8c8662c8c9 upstream.
SYSEXIT is one of the instructions that can change the
processor mode, thus ctxt->mode should be updated after it.
Note that this is likely a benign bug, because the only problematic
mode change is from 32 bit to 64 bit which can lead to truncation of RIP,
and it is not possible to do with sysexit,
since sysexit running in 32 bit mode will be limited to 32 bit version.
Message-Id: <20221025124741.228045-11-mlevitsk@redhat.com>
commit 0469e56a14bf8cfb80507e51b7aeec0332cdbc13 upstream.
KVM_GET_SUPPORTED_CPUID should only enumerate features that KVM
actually supports. CPUID.80000001:EBX[27:16] are reserved bits and
should be masked off.
Fixes: 0771671749b5 ("KVM: Enhance guest cpuid management")
Signed-off-by: Jim Mattson <jmattson@google.com>
commit 7030d8530e533844e2f4b0e7476498afcd324634 upstream.
actually supports. The following ranges of CPUID.80000008H are reserved
and should be masked off:
ECX[31:18]
ECX[11:8]
In addition, the PerfTscSize field at ECX[17:16] should also be zero
because KVM does not set the PERFTSC bit at CPUID.80000001H.ECX[27].
Fixes: 24c82e576b78 ("KVM: Sanitize cpuid")
Message-Id: <20220929225203.2234702-3-jmattson@google.com>
commit 079f6889818dd07903fb36c252532ab47ebb6d48 upstream.
actually supports. In the case of CPUID.8000001AH, only three bits are
currently defined. The 125 reserved bits should be masked off.
Message-Id: <20220929225203.2234702-4-jmattson@google.com>
