path: root/arch/x86
2008-05-04x86: KVM geust: make setup_secondary_clock definition dependent on local apicGlauber Costa
Since the pv_apic_ops are only present if CONFIG_X86_LOCAL_APIC is compiled in, kvmclock failed to build without this option. This patch fixes this. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: MMU: Allow more than PAGES_PER_HPAGE write protections per large pageAvi Kivity
nonpae guests can call rmap_write_protect twice per page (for page tables) or four times per page (for page directories), triggering a bogus warning. Remove the warning. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: avoid fx_init() schedule in atomicAndrea Arcangeli
This make sure not to schedule in atomic during fx_init. I also changed the name of fpu_init to fx_finit to avoid duplicating the name with fpu_init that is already used in the kernel, this makes grep simpler if nothing else. Signed-off-by: Andrea Arcangeli <andrea@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: Avoid spurious execeptions after setting registersJan Kiszka
Clear pending exceptions when setting new register values. This avoids spurious exceptions after restoring a vcpu state or after reset-on-triple-fault. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: PIT: support mode 4Marcelo Tosatti
The in-kernel PIT emulation ignores pending timers if operating under mode 4, which for example DragonFlyBSD uses (and Plan9 too, apparently). Mode 4 seems to be similar to one-shot mode, other than the fact that it starts counting after the next CLK pulse once programmed, while mode 1 starts counting immediately, so add a FIXME to enhance precision. Fixes sourceforge bug 1952988. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: x86 emulator: disable writeback on lmswAvi Kivity
The recent changes allowing memory operands with lmsw and smsw left lmsw with writeback enabled. Since lmsw has no oridinary destination operand, the dst pointer was not initialized, resulting in an oops. Close the hole by disabling writeback for lmsw. Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: x86: task switch: fix wrong bit setting for the busy flagIzik Eidus
The busy bit is bit 1 of the type field, not bit 8. Signed-off-by: Izik Eidus <izike@qumranet.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: VMX: Enable EPT feature for KVMSheng Yang
Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: VMX: Prepare an identity page table for EPT in real modeSheng Yang
[aliguory: plug leak] Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Anthony Liguori <aliguori@us.ibm.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: MMU: Remove #ifdef CONFIG_X86_64 to support 4 level EPTSheng Yang
Currently EPT level is 4 for both pae and x86_64. The patch remove the #ifdef for alloc root_hpa and free root_hpa to support EPT. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: MMU: Add EPT supportSheng Yang
Enable kvm_set_spte() to generate EPT entries. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: Add kvm_x86_ops get_tdp_level()Sheng Yang
The function get_tdp_level() provided the number of tdp level for EPT and NPT rather than the NPT specific macro. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: MMU: Move some definitions to a header fileSheng Yang
Move some definitions to mmu.h in order to allow building common table entries between EPT and non-EPT. Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-05-04KVM: VMX: EPT Feature DetectionSheng Yang
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30x86: Mark OPTIMIZE_INLINING brokenLinus Torvalds
So Ingo finally did figure out why UML broke with this option: UML passes gcc the -fno-unit-at-a-time flag, and apparently that wreaks havoc with gcc's inlining. We could turn off -fno-unit-at-a-time for UML for gcc4+ (which is what x86 does), but there's bad blood about this whole option, and it does show that the thing is just fragile as heck. So let tempers cool, and disable the thing, and we can revisit the decision later. Cc: Adrian Bunk <bunk@kernel.org> Cc: David Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30x86: numaq fixIngo Molnar
do not override the existing pci-y rule when adding visws or numaq rules. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-30x86: 8K stacks by defaultIngo Molnar
Switch back to 8K stacks as the safer default. Out-of-memory situations are less problematic than silent and hard to debug stack corruption. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: ioremap ram check fixAndres Salomon
bdd3cee2e4b7279457139058615ced6c2b41e7de (x86: ioremap(), extend check to all RAM pages) breaks OLPC's ioremap call. The ioremap that OLPC uses is: romsig = ioremap(0xffffffc0, 16); The commit that breaks it is basically: - for (pfn = phys_addr >> PAGE_SHIFT; pfn < max_pfn_mapped && - (pfn << PAGE_SHIFT) < last_addr; pfn++) { + for (pfn = phys_addr >> PAGE_SHIFT; + (pfn << PAGE_SHIFT) < last_addr; pfn++) { + Previously, the 'pfn < max_pfn_mapped' check would've caused us to not enter the loop. Removing that check means we loop infinitely. The reason for that is because pfn is 0xfffff, and last_addr is 0xffffffcf. The remaining check that is used to exit the loop is not sufficient; when pfn<<PAGE_SHIFT is 0xfffff000, that is less than 0xffffffcf; when we increment pfn and it overflows (pfn == 0x100000), pfn<<PAGE_SHIFT ends up being 0. That, of course, is less than last_addr. In effect, pfn<<PAGE_SHIFT is never lower than last_addr. The simple fix for this is to limit the last_addr check to the PAGE_MASK; a patch is below. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: optimize inlining offIngo Molnar
default to inline optimizing off. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: CONFIG_X86_ELAN fixIngo Molnar
move the X86_CPU section out of the !X86_ELAN branch. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: Kconfig fixIngo Molnar
Andrew noticed that OPTIMIZE_INLINING appeared in the toplevel menu - fix it. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86 PAT: fix performance drop for glx, use UC minus for ioremap(), ↵Suresh Siddha
ioremap_nocache() and pci_mmap_page_range() Use UC_MINUS for ioremap(), ioremap_nocache() instead of strong UC. Once all the X drivers move to ioremap_wc(), we can go back to strong UC semantics for ioremap() and ioremap_nocache(). To avoid attribute aliasing issues, pci_mmap_page_range() will also use UC_MINUS for default non write-combining mapping request. Next steps: a) change all the video drivers using ioremap() or ioremap_nocache() and adding WC MTTR using mttr_add() to ioremap_wc() b) for strict usage, we can go back to strong uc semantics for ioremap() and ioremap_nocache() after some grace period for completing step-a. c) user level X server needs to use the appropriate method for setting up WC mapping (like using resourceX_wc sysfs file instead of adding MTRR for WC and using /dev/mem or resourceX under /sys) Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: use defconfigs from x86/configs/*Sam Ravnborg
Daniel Drake <dsd@gentoo.org> reported: In 2.6.23, if you unpacked a kernel source tarball and then ran "make menuconfig" you'd be presented with this message: # using defaults found in arch/i386/defconfig and the default options would be set. The same thing in 2.6.24 does not give you any "using defaults" message, and the default config options within menuconfig are rather blank (e.g. no PCI support). You can work around this by explicitly running "make defconfig" before menuconfig, but it would be nice to have the behaviour the way it was for 2.6.23 (and the way it still is for other archs). Fixed by adding a x86 specific defconfig list to Kconfig. Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=10470 Tested-by: dsd@gentoo.org Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30revert: "x86: ioremap(), extend check to all RAM pages"Ingo Molnar
Vegard Nossum reported a large (150 seconds) boot delay during bootup, and bisected it to "x86: ioremap(), extend check to all RAM pages" (commit bdd3cee2e4b). Revert this commit for now. Bisected-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: don't bother printing compat vdso addressJeremy Fitzhardinge
The kernel prints the compat vdso address regardless of whether compat vdso mode is enabled or not, which is confusing. Given that this isn't very interesting information anyway, just remove the printk. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Gerhard Mack <gmack@innerfire.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30fix: x86: support for new UV apicAndi Kleen
Don't warn in read_apic_id() when preemptible but only one CPU online. Signed-off-by: Andi Kleen <andi@firstfloor.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: fix early-BUG messageVegard Nossum
The .asciz directive takes any number of strings, but each one is zero- terminated, and string pasting is not done as in C. That results in only the first line being output. Replace .asciz with multiple .ascii directives and terminate with .asciz. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: iommu_sac_force can become staticDmitri Vorobiev
The iommu_sac_force variable is needlessly defined global, and this patch makes it static. Additionally, this variable needs not be explicitly initialized. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: add proper header for reboot_forceDmitri Vorobiev
This patch fixes one sparse warning by including the appropriate header for the reboot_force symbol. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86 VISWS: build fixIngo Molnar
the 'reboot_force' flag is a notion that non-PC subarchitectures do not have. also, unify the X86_BIOS_REBOOT option between 32-bit and 64-bit and get rid of a few unnecessary Kconfig and Makefile complications that way. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86, voyager: fix ioremap_nocache()Ingo Molnar
James Bottomley reported that the following commit: | commit 6371b495991debfd1417b17c2bc4f7d7bae05739 | Author: Ingo Molnar <mingo@elte.hu> | Date: Wed Jan 30 13:33:40 2008 +0100 | | x86: change ioremap() to default to uncached broke Voyager. James says: " it broke a class of voyager machines: those which rely on the quad interrupt controller (QIC). The precis of why they broke is because the QIC does IPIs (or CPIs in its terminology) via cache line interference: you interrupt a processor by moving a designated memory area to write exclusive in the cache (by simply writing to the line) and the CPU acks the interrupt by moving it back to read shared (by reading from it). That area, is, of course, mapped by ioremap, so reversing the ioremap semantics and adding the uncached bit completely breaks the QIC. " Sorry about that! Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30hpet: fixIngo Molnar
Al Viro pointed out that there's a missing readl() of timer->hpet_config, found by Sparse. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30x86: unexport kmap_atomic_to_pageAdrian Bunk
This patch removes the no longer used export of kmap_atomic_to_page. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits) ACPI: Fix acpi_processor_idle and idle= boot parameters interaction acpi: fix section mismatch warning in pnpacpi intel_menlo: fix build warning ACPI: Cleanup: Remove unneeded, multiple local dummy variables ACPI: video - fix permissions on some proc entries ACPI: video - properly handle errors when registering proc elements ACPI: video - do not store invalid entries in attached_array list ACPI: re-name acpi_pm_ops to acpi_suspend_ops ACER_WMI/ASUS_LAPTOP: fix build bug thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed ACPI: check a return value correctly in acpi_power_get_context() #if 0 acpi/bay.c:eject_removable_drive() eeepc-laptop: add hwmon fan control eeepc-laptop: add backlight eeepc-laptop: add base driver ACPI: thinkpad-acpi: bump up version to 0.20 ACPI: thinkpad-acpi: fix selects in Kconfig ACPI: thinkpad-acpi: use a private workqueue ACPI: thinkpad-acpi: fluff really minor fix ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation ... Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c manually.
2008-04-30Merge branches 'release', 'acpica', 'bugzilla-10224', 'bugzilla-9772', ↵Len Brown
'bugzilla-9916', 'ec', 'eeepc', 'idle', 'misc', 'pm-legacy', 'sysfs-links-2.6.26', 'thermal', 'thinkpad' and 'video' into release
2008-04-30signals: x86 TS_RESTORE_SIGMASKRoland McGrath
Replace TIF_RESTORE_SIGMASK with TS_RESTORE_SIGMASK and define our own set_restore_sigmask() function. This saves the costly SMP-safe set_bit operation, which we do not need for the sigmask flag since TIF_SIGPENDING always has to be set too. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29x86/pci: remove flag in pci_cfg_space_size_extYinghai Lu
so let pci_cfg_space_size call it directly without flag. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-29x86: fix section mismatch in pci_scan_busSam Ravnborg
Fix following section mismatch warning: WARNING: vmlinux.o(.text+0x275616): Section mismatch in reference from the function pci_scan_bus() to the function .devinit.text:pci_scan_bus_parented() The warning was seen with a CONFIG_DEBUG_SECTION_MISMATCH=y build. The inline function pci_scan_bus refer to functions annotated __devinit - so annotate it __devinit too. This revealed a few x86 specific functions that were only used from __init or __devinit context. So annotate these __devinit and the warning was killed. The added include in pci.h was not strictly required but added to avoid being dependent on indirect includes. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2008-04-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-fixes: x86: fix PCI MSI breaks when booting with nosmp x86: vget_cycles() __always_inline x86: add more boot protocol documentation bootprotocol: cleanup x86: fix warning in "x86: clean up vSMP detection" x86: !x & y typo in mtrr code
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86-bigbox-pci: x86: add pci=check_enable_amd_mmconf and dmi check x86: work around io allocation overlap of HT links acpi: get boot_cpu_id as early for k8_scan_nodes x86_64: don't need set default res if only have one root bus x86: double check the multi root bus with fam10h mmconf x86: multi pci root bus with different io resource range, on 64-bit x86: use bus conf in NB conf fun1 to get bus range on, on 64-bit x86: get mp_bus_to_node early x86 pci: remove checking type for mmconfig probe x86: remove unneeded check in mmconf reject driver core: try parent numa_node at first before using default x86: seperate mmconf for fam10h out from setup_64.c x86: if acpi=off, force setting the mmconf for fam10h x86_64: check MSR to get MMCONFIG for AMD Family 10h x86_64: check and enable MMCONFIG for AMD Family 10h x86_64: set cfg_size for AMD Family 10h in case MMCONFIG x86: mmconf enable mcfg early x86: clear pci_mmcfg_virt when mmcfg get rejected x86: validate against acpi motherboard resources Fixed up fairly trivial conflicts in arch/x86/pci/{init.c,pci.h} due to OLPC support manually.
2008-04-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] state info wrong after resume [CPUFREQ] allow use of the powersave governor as the default one [CPUFREQ] document the currently undocumented parts of the sysfs interface [CPUFREQ] expose cpufreq coordination requirements regardless of coordination mechanism
2008-04-29x86: use kbuild.hChristoph Lameter
Drop the macro definitions in asm-offsets_*.c and use kbuild.h Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29edd: add default mode CONFIG_EDD_OFF=n, override with edd={on,off}Tim Gardner
Add a kernel parameter option to 'edd' to enable/disable BIOS Enhanced Disk Drive Services. CONFIG_EDD_OFF disables EDD while still compiling EDD into the kernel. Default behavior can be forced using 'edd=on' or 'edd=off' as a kernel parameter. [akpm@linux-foundation.org: fix kernel-parameters.txt] Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proc: remove proc_root from driversAlexey Dobriyan
Remove proc_root export. Creation and removal works well if parent PDE is supplied as NULL -- it worked always that way. So, one useless export removed and consistency added, some drivers created PDEs with &proc_root as parent but removed them as NULL and so on. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29x86: olpc: add One Laptop Per Child architecture supportAndres Salomon
This adds support for OLPC XO hardware. Open Firmware on XOs don't contain the VSA, so it is necessary to emulate the PCI BARs in the kernel. This also adds functionality for running EC commands, and a CONFIG_OLPC. A number of OLPC drivers depend upon CONFIG_OLPC. olpc_ec_timeout is a hack to work around Embedded Controller bugs. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: geode_has_vsa build fix] [akpm@linux-foundation.org: olpc_register_battery_callback doesn't exist] Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29swiotlb: use iommu_is_span_boundary helper functionFUJITA Tomonori
iommu_is_span_boundary in lib/iommu-helper.c was exported for PARISC IOMMUs (commit 3715863aa142c4f4c5208f5f3e5e9bac06006d2f). SWIOTLB can use it instead of the homegrown function. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper extern for late_time_initAdrian Bunk
Add a proper extern for late_time_init in include/linux/init.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29proper __do_softirq() prototypeAdrian Bunk
Add a proper prototype for __do_softirq() in include/linux/interrupt.h Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
