Pull x86 fixes from Thomas Gleixner:
"A series of fixes for X86:
- The final fix for the end-of-stack issue in the unwinder
- Handle non PAT systems gracefully
- Prevent access to uninitiliazed memory
- Move early delay calaibration after basic init
- Fix Kconfig help text
- Fix a cross compile issue
- Unbreak older make versions"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/timers: Move simple_udelay_calibration past init_hypervisor_platform
x86/alternatives: Prevent uninitialized stack byte read in apply_alternatives()
x86/PAT: Fix Xorg regression on CPUs that don't support PAT
x86/watchdog: Fix Kconfig help text file path reference to lockup watchdog documentation
x86/build: Permit building with old make versions
x86/unwind: Add end-of-stack check for ftrace handlers
Revert "x86/entry: Fix the end of the stack for newly forked tasks"
x86/boot: Use CROSS_COMPILE prefix for readelf
Pull RAS fixes from Thomas Gleixner:
"Two fixlets for RAS:
- Export memory_error() so the NFIT module can utilize it
- Handle memory errors in NFIT correctly"
* 'ras-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
acpi, nfit: Fix the memory error check in nfit_handle_mce()
x86/MCE: Export memory_error()
ftrace use module_alloc() to allocate trampoline pages. The mapping of
module_alloc() is RWX, which makes sense as the memory is written to right
after allocation. But nothing makes these pages RO after writing to them.
Add proper set_memory_rw/ro() calls to protect the trampolines after
modification.
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1705251056410.1862@nanos
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
With function tracing starting in early bootup and having its trampoline
pages being read only, a bug triggered with the following:
kernel BUG at arch/x86/mm/pageattr.c:189!
invalid opcode: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 4.12.0-rc2-test+ #3
Hardware name: MSI MS-7823/CSM-H87M-G43 (MS-7823), BIOS V1.6 02/22/2014
task: ffffffffb4222500 task.stack: ffffffffb4200000
RIP: 0010:change_page_attr_set_clr+0x269/0x302
RSP: 0000:ffffffffb4203c88 EFLAGS: 00010046
RAX: 0000000000000046 RBX: 0000000000000000 RCX: 00000001b6000000
RDX: ffffffffb4203d40 RSI: 0000000000000000 RDI: ffffffffb4240d60
RBP: ffffffffb4203d18 R08: 00000001b6000000 R09: 0000000000000001
R10: ffffffffb4203aa8 R11: 0000000000000003 R12: ffffffffc029b000
R13: ffffffffb4203d40 R14: 0000000000000001 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff9a639ea00000(0000) knlGS:0000000000000000
CR2: ffff9a636b384000 CR3: 00000001ea21d000 CR4: 00000000000406b0
Call Trace:
change_page_attr_clear+0x1f/0x21
set_memory_ro+0x1e/0x20
arch_ftrace_update_trampoline+0x207/0x21c
? ftrace_caller+0x64/0x64
? 0xffffffffc029b000
ftrace_startup+0xf4/0x198
register_ftrace_function+0x26/0x3c
function_trace_init+0x5e/0x73
tracer_init+0x1e/0x23
tracing_set_tracer+0x127/0x15a
register_tracer+0x19b/0x1bc
init_function_trace+0x90/0x92
early_trace_init+0x236/0x2b3
start_kernel+0x200/0x3f5
x86_64_start_reservations+0x29/0x2b
x86_64_start_kernel+0x17c/0x18f
secondary_startup_64+0x9f/0x9f
? secondary_startup_64+0x9f/0x9f
Interrupts should not be enabled at this early in the boot process. It is
also fine to leave interrupts enabled during this time as there's only one
CPU running, and on_each_cpu() means to only run on the current CPU.
If early_boot_irqs_disabled is set, it is safe to run cpu_flush_range() with
interrupts disabled. Don't trigger a BUG_ON() in that case.
Link: http://lkml.kernel.org/r/20170526093717.0be3b849@gandalf.local.home
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Fix kprobes to set(recover) RWX bits correctly on trampoline
buffer before releasing it. Releasing readonly page to
module_memfree() crash the kernel.
Without this fix, if kprobes user register a bunch of kprobes
in function body (since kprobes on function entry usually
use ftrace) and unregister it, kernel hits a BUG and crash.
Link: http://lkml.kernel.org/r/149570868652.3518.14120169373590420503.stgit@devbox
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Fixes: d0381c81c2f7 ("kprobes/x86: Set kprobes pages read-only")
This ensures that adjustments to x86_platform done by the hypervisor
setup is already respected by this simple calibration.
The current user of this, introduced by 1b5aeebf3a92 ("x86/earlyprintk:
Add support for earlyprintk via USB3 debug port"), comes much later
into play.
Fixes: dd759d93f4dd ("x86/timers: Add simple udelay calibration")
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Acked-by: Lu Baolu <baolu.lu@linux.intel.com>
Link: http://lkml.kernel.org/r/5e89fe60-aab3-2c1c-aba8-32f8ad376189@siemens.com
In the current form of the code, if a->replacementlen is 0, the reference
to *insnbuf for comparison touches potentially garbage memory. While it
doesn't affect the execution flow due to the subsequent a->replacementlen
comparison, it is (rightly) detected as use of uninitialized memory by a
runtime instrumentation currently under my development, and could be
detected as such by other tools in the future, too (e.g. KMSAN).
Fix the "false-positive" by reordering the conditions to first check the
replacement instruction length before referencing specific opcode bytes.
Signed-off-by: Mateusz Jurczyk <mjurczyk@google.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/20170524135500.27223-1-mjurczyk@google.com
In the file arch/x86/mm/pat.c, there's a '__pat_enabled' variable. The
variable is set to 1 by default and the function pat_init() sets
__pat_enabled to 0 if the CPU doesn't support PAT.
However, on AMD K6-3 CPUs, the processor initialization code never calls
pat_init() and so __pat_enabled stays 1 and the function pat_enabled()
returns true, even though the K6-3 CPU doesn't support PAT.
The result of this bug is that a kernel warning is produced when attempting to
start the Xserver and the Xserver doesn't start (fork() returns ENOMEM).
Another symptom of this bug is that the framebuffer driver doesn't set the
K6-3 MTRR registers:
x86/PAT: Xorg:3891 map pfn expected mapping type uncached-minus for [mem 0xe4000000-0xe5ffffff], got write-combining
WARNING: CPU: 0 PID: 3891 at arch/x86/mm/pat.c:1020 untrack_pfn+0x5c/0x9f
To fix the bug change pat_enabled() so that it returns true only if PAT
initialization was actually done.
Also, I changed boot_cpu_has(X86_FEATURE_PAT) to
this_cpu_has(X86_FEATURE_PAT) in pat_ap_init(), so that we check the PAT
feature on the processor that is being initialized.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: stable@vger.kernel.org # v4.2+
Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1704181501450.26399@file01.intranet.prod.int.rdu2.redhat.com
documentation
Signed-off-by: Benjamin Peterson <bp@benjamin.pe>
Fixes: 9919cba7ff71147803c988521cc1ceb80e7f0f6d ("watchdog: Update documentation")
Link: http://lkml.kernel.org/r/20170521002016.13258-1-bp@benjamin.pe
At least Make 3.82 dislikes the tab in front of the $(warning) function:
arch/x86/Makefile:162: *** recipe commences before first target. Stop.
Let's be gentle.
Link: http://lkml.kernel.org/r/1944fcd8-e3df-d1f7-c0e4-60aeb1917a24@siemens.com
Dave Jones and Steven Rostedt reported unwinder warnings like the
following:
WARNING: kernel stack frame pointer at ffff8800bda0ff30 in sshd:1090 has bad value 000055b32abf1fa8
In both cases, the unwinder was attempting to unwind from an ftrace
handler into entry code. The callchain was something like:
syscall entry code
C function
ftrace handler
save_stack_trace()
The problem is that the unwinder's end-of-stack logic gets confused by
the way ftrace lays out the stack frame (with fentry enabled).
I was able to recreate this warning with:
echo call_usermodehelper_exec_async:stacktrace > /sys/kernel/debug/tracing/set_ftrace_filter
(exit login session)
I considered fixing this by changing the ftrace code to rewrite the
stack to make the unwinder happy. But that seemed too intrusive after I
implemented it. Instead, just add another check to the unwinder's
end-of-stack logic to detect this special case.
Side note: We could probably get rid of these end-of-stack checks by
encoding the frame pointer for syscall entry just like we do for
interrupt entry. That would be simpler, but it would also be a lot more
intrusive since it would slightly affect the performance of every
syscall.
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: live-patching@vger.kernel.org
Fixes: c32c47c68a0a ("x86/unwind: Warn on bad frame pointer")
Link: http://lkml.kernel.org/r/671ba22fbc0156b8f7e0cfa5ab2a795e08bc37e1.1495553739.git.jpoimboe@redhat.com
Petr Mladek reported the following warning when loading the livepatch
sample module:
WARNING: CPU: 1 PID: 3699 at arch/x86/kernel/stacktrace.c:132 save_stack_trace_tsk_reliable+0x133/0x1a0
Call Trace:
__schedule+0x273/0x820
schedule+0x36/0x80
kthreadd+0x305/0x310
? kthread_create_on_cpu+0x80/0x80
? icmp_echo.part.32+0x50/0x50
ret_from_fork+0x2c/0x40
That warning means the end of the stack is no longer recognized as such
for newly forked tasks. The problem was introduced with the following
commit:
ff3f7e2475bb ("x86/entry: Fix the end of the stack for newly forked tasks")
... which was completely misguided. It only partially fixed the
reported issue, and it introduced another bug in the process. None of
the other entry code saves the frame pointer before calling into C code,
so it doesn't make sense for ret_from_fork to do so either.
Contrary to what I originally thought, the original issue wasn't related
to newly forked tasks. It was actually related to ftrace. When entry
code calls into a function which then calls into an ftrace handler, the
stack frame looks different than normal.
The original issue will be fixed in the unwinder, in a subsequent patch.
Reported-by: Petr Mladek <pmladek@suse.com>
Cc: Dave Jones <davej@codemonkey.org.uk>
Fixes: ff3f7e2475bb ("x86/entry: Fix the end of the stack for newly forked tasks")
Link: http://lkml.kernel.org/r/f350760f7e82f0750c8d1dd093456eb212751caa.1495553739.git.jpoimboe@redhat.com
The code to fetch a 64-bit value from user space was entirely buggered,
and has been since the code was merged in early 2016 in commit
b2f680380ddf ("x86/mm/32: Add support for 64-bit __get_user() on 32-bit
kernels").
Happily the buggered routine is almost certainly entirely unused, since
the normal way to access user space memory is just with the non-inlined
"get_user()", and the inlined version didn't even historically exist.
The normal "get_user()" case is handled by external hand-written asm in
arch/x86/lib/getuser.S that doesn't have either of these issues.
There were two independent bugs in __get_user_asm_u64():
- it still did the STAC/CLAC user space access marking, even though
that is now done by the wrapper macros, see commit 11f1a4b9755f
("x86: reorganize SMAP handling in user space accesses").
This didn't result in a semantic error, it just means that the
inlined optimized version was hugely less efficient than the
allegedly slower standard version, since the CLAC/STAC overhead is
quite high on modern Intel CPU's.
- the double register %eax/%edx was marked as an output, but the %eax
part of it was touched early in the asm, and could thus clobber other
inputs to the asm that gcc didn't expect it to touch.
In particular, that meant that the generated code could look like
this:
mov (%eax),%eax
mov 0x4(%eax),%edx
where the load of %edx obviously was _supposed_ to be from the 32-bit
word that followed the source of %eax, but because %eax was
overwritten by the first instruction, the source of %edx was
basically random garbage.
The fixes are trivial: remove the extraneous STAC/CLAC entries, and mark
the 64-bit output as early-clobber to let gcc know that no inputs should
alias with the output register.
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: stable@kernel.org # v4.8+
Al noticed that unsafe_put_user() had type problems, and fixed them in
commit a7cc722fff0b ("fix unsafe_put_user()"), which made me look more
at those functions.
It turns out that unsafe_get_user() had a type issue too: it limited the
largest size of the type it could handle to "unsigned long". Which is
fine with the current users, but doesn't match our existing normal
get_user() semantics, which can also handle "u64" even when that does
not fit in a long.
While at it, also clean up the type cast in unsafe_put_user(). We
actually want to just make it an assignment to the expected type of the
pointer, because we actually do want warnings from types that don't
convert silently. And it makes the code more readable by not having
that one very long and complex line.
[ This patch might become stable material if we ever end up back-porting
any new users of the unsafe uaccess code, but as things stand now this
doesn't matter for any current existing uses. ]
Export the function which checks whether an MCE is a memory error to
other users so that we can reuse the logic. Drop the boot_cpu_data use,
while at it, as mce.cpuvendor already has the CPU vendor in there.
Integrate a piece from a patch from Vishal Verma
<vishal.l.verma@intel.com> to export it for modules (nfit).
The main reason we're exporting it is that the nfit handler
nfit_handle_mce() needs to detect a memory error properly before doing
its recovery actions.
Cc: Vishal Verma <vishal.l.verma@intel.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20170519093915.15413-2-bp@alien8.de
Pull misc uaccess fixes from Al Viro:
"Fix for unsafe_put_user() (no callers currently in mainline, but
anyone starting to use it will step into that) + alpha osf_wait4()
infoleak fix"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
osf_wait4(): fix infoleak
__put_user_size() relies upon its first argument having the same type as what
the second one points to; the only other user makes sure of that and
unsafe_put_user() should do the same.
The boot code Makefile contains a straight 'readelf' invocation. This
causes build warnings in cross compile environments, when there is no
unprefixed readelf accessible via $PATH.
Add the missing $(CROSS_COMPILE) prefix.
[ tglx: Rewrote changelog ]
Fixes: 98f78525371b ("x86/boot: Refuse to build with data relocations")
Signed-off-by: Rob Landley <rob@landley.net>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: "H.J. Lu" <hjl.tools@gmail.com>
Link: http://lkml.kernel.org/r/ced18878-693a-9576-a024-113ef39a22c0@landley.net
Pull KVM fixes from Radim Krčmář:
"ARM:
- a fix for a build failure introduced in -rc1 when tracepoints are
enabled on 32-bit ARM.
- disable use of stack pointer protection in the hyp code which can
cause panics.
- a handful of VGIC fixes.
- a fix to the init of the redistributors on GICv3 systems that
prevented boot with kvmtool on GICv3 systems introduced in -rc1.
- a number of race conditions fixed in our MMU handling code.
- a fix for the guest being able to program the debug extensions for
the host on the 32-bit side.
PPC:
- fixes for build failures with PR KVM configurations.
- a fix for a host crash that can occur on POWER9 with radix guests.
x86:
- fixes for nested PML and nested EPT.
- a fix for crashes caused by reserved bits in SSE MXCSR that could
have been set by userspace.
- an optimization of halt polling that fixes high CPU overhead.
- fixes for four reports from Dan Carpenter's static checker.
- a protection around code that shouldn't have been preemptible.
- a fix for port IO emulation"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (27 commits)
KVM: x86: prevent uninitialized variable warning in check_svme()
KVM: x86/vPMU: fix undefined shift in intel_pmu_refresh()
KVM: x86: zero base3 of unusable segments
KVM: X86: Fix read out-of-bounds vulnerability in kvm pio emulation
KVM: x86: Fix potential preemption when get the current kvmclock timestamp
KVM: Silence underflow warning in avic_get_physical_id_entry()
KVM: arm/arm64: Hold slots_lock when unregistering kvm io bus devices
KVM: arm/arm64: Fix bug when registering redist iodevs
KVM: x86: lower default for halt_poll_ns
kvm: arm/arm64: Fix use after free of stage2 page table
kvm: arm/arm64: Force reading uncached stage2 PGD
KVM: nVMX: fix EPT permissions as reported in exit qualification
KVM: VMX: Don't enable EPT A/D feature if EPT feature is disabled
KVM: x86: Fix load damaged SSEx MXCSR register
kvm: nVMX: off by one in vmx_write_pml_buffer()
KVM: arm: rename pm_fake handler to trap_raz_wi
KVM: arm: plug potential guest hardware debug leakage
kvm: arm/arm64: Fix race in resetting stage2 PGD
KVM: arm/arm64: vgic-v3: Use PREbits to infer the number of ICH_APxRn_EL2 registers
KVM: arm/arm64: vgic-v3: Do not use Active+Pending state for a HW interrupt
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from Juergen Gross:
"Some fixes for the new Xen 9pfs frontend and some minor cleanups"
* tag 'for-linus-4.12b-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: make xen_flush_tlb_all() static
xen: cleanup pvh leftovers from pv-only sources
xen/9pfs: p9_trans_xen_init and p9_trans_xen_exit can be static
xen/9pfs: fix return value check in xen_9pfs_front_probe()
get_msr() of MSR_EFER is currently always going to succeed, but static
checker doesn't see that far.
Don't complicate stuff and just use 0 for the fallback -- it means that
the feature is not present.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Static analysis noticed that pmu->nr_arch_gp_counters can be 32
(INTEL_PMC_MAX_GENERIC) and therefore cannot be used to shift 'int'.
I didn't add BUILD_BUG_ON for it as we have a better checker.
Fixes: 25462f7f5295 ("KVM: x86/vPMU: Define kvm_pmu_ops to support vPMU function dispatch")
Static checker noticed that base3 could be used uninitialized if the
segment was not present (useable). Random stack values probably would
not pass VMCS entry checks.
Fixes: 1aa366163b8b ("KVM: x86 emulator: consolidate segment accessors")
Huawei folks reported a read out-of-bounds vulnerability in kvm pio emulation.
- "inb" instruction to access PIT Mod/Command register (ioport 0x43, write only,
a read should be ignored) in guest can get a random number.
- "rep insb" instruction to access PIT register port 0x43 can control memcpy()
in emulator_pio_in_emulated() to copy max 0x400 bytes but only read 1 bytes,
which will disclose the unimportant kernel memory in host but no crash.
The similar test program below can reproduce the read out-of-bounds vulnerability:
void hexdump(void *mem, unsigned int len)
unsigned int i, j;
for(i = 0; i < len + ((len % HEXDUMP_COLS) ? (HEXDUMP_COLS - len % HEXDUMP_COLS) : 0); i++)
/* print offset */
if(i % HEXDUMP_COLS == 0)
printf("0x%06x: ", i);
/* print hex data */
if(i < len)
printf("%02x ", 0xFF & ((char*)mem)[i]);
else /* end of block, just aligning for ASCII dump */
printf(" ");
/* print ASCII dump */
if(i % HEXDUMP_COLS == (HEXDUMP_COLS - 1))
for(j = i - (HEXDUMP_COLS - 1); j <= i; j++)
if(j >= len) /* end of block, not really printing */
putchar(' ');
else if(isprint(((char*)mem)[j])) /* printable char */
putchar(0xFF & ((char*)mem)[j]);
else /* other char */
putchar('.');
putchar('\n');
int main(void)
int i;
if (iopl(3))
err(1, "set iopl unsuccessfully\n");
return -1;
static char buf[0x40];
/* test ioport 0x40,0x41,0x42,0x43,0x44,0x45 */
memset(buf, 0xab, sizeof(buf));
asm volatile("push %rdi;");
asm volatile("mov %0, %%rdi;"::"q"(buf));
asm volatile ("mov $0x40, %rdx;");
asm volatile ("in %dx,%al;");
asm volatile ("stosb;");
asm volatile ("mov $0x41, %rdx;");
asm volatile ("mov $0x42, %rdx;");
asm volatile ("mov $0x43, %rdx;");
asm volatile ("mov $0x44, %rdx;");
asm volatile ("mov $0x45, %rdx;");
asm volatile ("pop %rdi;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x40 */
asm volatile ("mov $0x20, %rcx;");
asm volatile ("rep insb;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x43 */
hexdump(buf, 0x40);
printf("\n");
return 0;
The vcpu->arch.pio_data buffer is used by both in/out instrutions emulation
w/o clear after using which results in some random datas are left over in
the buffer. Guest reads port 0x43 will be ignored since it is write only,
however, the function kernel_pio() can't distigush this ignore from successfully
reads data from device's ioport. There is no new data fill the buffer from
port 0x43, however, emulator_pio_in_emulated() will copy the stale data in
the buffer to the guest unconditionally. This patch fixes it by clearing the
buffer before in instruction emulation to avoid to grant guest the stale data
in the buffer.
In addition, string I/O is not supported for in kernel device. So there is no
iteration to read ioport %RCX times for string I/O. The function kernel_pio()
just reads one round, and then copy the io size * %RCX to the guest unconditionally,
actually it copies the one round ioport data w/ other random datas which are left
over in the vcpu->arch.pio_data buffer to the guest. This patch fixes it by
introducing the string I/O support for in kernel device in order to grant the right
ioport datas to the guest.
Before the patch:
0x000000: fe 38 93 93 ff ff ab ab .8......
0x000008: ab ab ab ab ab ab ab ab ........
0x000010: ab ab ab ab ab ab ab ab ........
0x000018: ab ab ab ab ab ab ab ab ........
0x000020: ab ab ab ab ab ab ab ab ........
0x000028: ab ab ab ab ab ab ab ab ........
0x000030: ab ab ab ab ab ab ab ab ........
0x000038: ab ab ab ab ab ab ab ab ........
0x000000: f6 00 00 00 00 00 00 00 ........
0x000008: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 4d 51 30 30 ....MQ00
0x000018: 30 30 20 33 20 20 20 20 00 3
After the patch:
0x000000: 1e 02 f8 00 ff ff ab ab ........
0x000000: d2 e2 d2 df d2 db d2 d7 ........
0x000008: d2 d3 d2 cf d2 cb d2 c7 ........
0x000010: d2 c4 d2 c0 d2 bc d2 b8 ........
0x000018: d2 b4 d2 b0 d2 ac d2 a8 ........
0x000000: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 00 00 00 00 ........
0x000018: 00 00 00 00 00 00 00 00 ........
Reported-by: Moguofang <moguofang@huawei.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Moguofang <moguofang@huawei.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
BUG: using __this_cpu_read() in preemptible [00000000] code: qemu-system-x86/2809
caller is __this_cpu_preempt_check+0x13/0x20
CPU: 2 PID: 2809 Comm: qemu-system-x86 Not tainted 4.11.0+ #13
Call Trace:
dump_stack+0x99/0xce
check_preemption_disabled+0xf5/0x100
get_kvmclock_ns+0x6f/0x110 [kvm]
get_time_ref_counter+0x5d/0x80 [kvm]
kvm_hv_process_stimers+0x2a1/0x8a0 [kvm]
? kvm_hv_process_stimers+0x2a1/0x8a0 [kvm]
? kvm_arch_vcpu_ioctl_run+0xac9/0x1ce0 [kvm]
kvm_arch_vcpu_ioctl_run+0x5bf/0x1ce0 [kvm]
kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? __fget+0xf3/0x210
do_vfs_ioctl+0xa4/0x700
? __fget+0x114/0x210
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x23/0xc2
RIP: 0033:0x7f9d164ed357
? __this_cpu_preempt_check+0x13/0x20
This can be reproduced by run kvm-unit-tests/hyperv_stimer.flat w/
CONFIG_PREEMPT and CONFIG_DEBUG_PREEMPT enabled.
Safe access to per-CPU data requires a couple of constraints, though: the
thread working with the data cannot be preempted and it cannot be migrated
while it manipulates per-CPU variables. If the thread is preempted, the
thread that replaces it could try to work with the same variables; migration
to another CPU could also cause confusion. However there is no preemption
disable when reads host per-CPU tsc rate to calculate the current kvmclock
timestamp.
This patch fixes it by utilizing get_cpu/put_cpu pair to guarantee both
__this_cpu_read() and rdtsc() are not preempted.
xen_flush_tlb_all() is used in arch/x86/xen/mmu.c only. Make it static.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
There are some leftovers testing for pvh guest mode in pv-only source
files. Remove them.
Smatch complains that we check cap the upper bound of "index" but don't
check for negatives. It's a false positive because "index" is never
negative. But it's also simple enough to make it unsigned which makes
the code easier to audit.
In some fio benchmarks, halt_poll_ns=400000 caused CPU utilization to
increase heavily even in cases where the performance improvement was
small. In particular, bandwidth divided by CPU usage was as much as
60% lower.
To some extent this is the expected effect of the patch, and the
additional CPU utilization is only visible when running the
benchmarks. However, halving the threshold also halves the extra
CPU utilization (from +30-130% to +20-70%) and has no negative
effect on performance.
This fixes the new ept_access_test_read_only and ept_access_test_read_write
testcases from vmx.flat.
The problem is that gpte_access moves bits around to switch from EPT
bit order (XWR) to ACC_*_MASK bit order (RWX). This results in an
incorrect exit qualification. To fix this, make pt_access and
pte_access operate on raw PTE values (only with NX flipped to mean
"can execute") and call gpte_access at the end of the walk. This
lets us use pte_access to compute the exit qualification with XWR
bit order.
Reviewed-by: Xiao Guangrong <xiaoguangrong@tencent.com>
We can observe eptad kvm_intel module parameter is still Y
even if ept is disabled which is weird. This patch will
not enable EPT A/D feature if EPT feature is disabled.
Reported by syzkaller:
BUG: unable to handle kernel paging request at ffffffffc07f6a2e
IP: report_bug+0x94/0x120
PGD 348e12067
P4D 348e12067
PUD 348e14067
PMD 3cbd84067
PTE 80000003f7e87161
Oops: 0003 [#1] SMP
CPU: 2 PID: 7091 Comm: kvm_load_guest_ Tainted: G OE 4.11.0+ #8
task: ffff92fdfb525400 task.stack: ffffbda6c3d04000
RIP: 0010:report_bug+0x94/0x120
RSP: 0018:ffffbda6c3d07b20 EFLAGS: 00010202
do_trap+0x156/0x170
do_error_trap+0xa3/0x170
? kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? mark_held_locks+0x79/0xa0
? retint_kernel+0x10/0x10
? trace_hardirqs_off_thunk+0x1a/0x1c
do_invalid_op+0x20/0x30
invalid_op+0x1e/0x30
RIP: 0010:kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? kvm_load_guest_fpu.part.175+0x1c/0x170 [kvm]
kvm_arch_vcpu_ioctl_run+0xed6/0x1b70 [kvm]
kvm_vcpu_ioctl+0x384/0x780 [kvm]
? kvm_vcpu_ioctl+0x384/0x780 [kvm]
? sched_clock+0x13/0x20
? __do_page_fault+0x2a0/0x550
? up_read+0x1f/0x40
SyS_ioctl+0x79/0x90
SDM mentioned that "The MXCSR has several reserved bits, and attempting to write
a 1 to any of these bits will cause a general-protection exception(#GP) to be
generated". The syzkaller forks' testcase overrides xsave area w/ random values
and steps on the reserved bits of MXCSR register. The damaged MXCSR register
values of guest will be restored to SSEx MXCSR register before vmentry. This
patch fixes it by catching userspace override MXCSR register reserved bits w/
random values and bails out immediately.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
There are PML_ENTITY_NUM elements in the pml_address[] array so the >
should be >= or we write beyond the end of the array when we do:
pml_address[vmcs12->guest_pml_index--] = gpa;
Fixes: c5f983f6e845 ("nVMX: Implement emulated Page Modification Logging")
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml
Pull UML fixes from Richard Weinberger:
"No new stuff, just fixes"
* 'for-linus-4.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml:
um: Add missing NR_CPUS include
um: Fix to call read_initrd after init_bootmem
um: Include kbuild.h instead of duplicating its macros
um: Fix PTRACE_POKEUSER on x86_64
um: Set number of CPUs
um: Fix _print_addr()
Merge misc fixes from Andrew Morton:
"15 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm, docs: update memory.stat description with workingset* entries
mm: vmscan: scan until it finds eligible pages
mm, thp: copying user pages must schedule on collapse
dax: fix PMD data corruption when fault races with write
dax: fix data corruption when fault races with write
ext4: return to starting transaction in ext4_dax_huge_fault()
mm: fix data corruption due to stale mmap reads
dax: prevent invalidation of mapped DAX entries
Tigran has moved
mm, vmalloc: fix vmalloc users tracking properly
mm/khugepaged: add missed tracepoint for collapse_huge_page_swapin
gcov: support GCC 7.1
mm, vmstat: Remove spurious WARN() during zoneinfo print
time: delete current_fs_time()
hwpoison, memcg: forcibly uncharge LRU pages
Cc: Tigran Aivazian <aivazian.tigran@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
"Incremental fixes and a small feature addition on top of the main
libnvdimm 4.12 pull request:
- Geert noticed that tinyconfig was bloated by BLOCK selecting DAX.
The size regression is fixed by moving all dax helpers into the
dax-core and only specifying "select DAX" for FS_DAX and
dax-capable drivers. He also asked for clarification of the
NR_DEV_DAX config option which, on closer look, does not need to be
a config option at all. Mike also throws in a DEV_DAX_PMEM fixup
for good measure.
- Ben's attention to detail on -stable patch submissions caught a
case where the recent fixes to arch_copy_from_iter_pmem() missed a
condition where we strand dirty data in the cache. This is tagged
for -stable and will also be included in the rework of the pmem api
to a proposed {memcpy,copy_user}_flushcache() interface for 4.13.
- Vishal adds a feature that missed the initial pull due to pending
review feedback. It allows the kernel to clear media errors when
initializing a BTT (atomic sector update driver) instance on a pmem
namespace.
- Ross noticed that the dax_device + dax_operations conversion broke
__dax_zero_page_range(). The nvdimm unit tests fail to check this
path, but xfstests immediately trips over it. No excuse for missing
this before submitting the 4.12 pull request.
These all pass the nvdimm unit tests and an xfstests spot check. The
set has received a build success notification from the kbuild robot"
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
filesystem-dax: fix broken __dax_zero_page_range() conversion
libnvdimm, btt: ensure that initializing metadata clears poison
libnvdimm: add an atomic vs process context flag to rw_bytes
x86, pmem: Fix cache flushing for iovec write < 8 bytes
device-dax: kill NR_DEV_DAX
block, dax: move "select DAX" from BLOCK to FS_DAX
device-dax: Tell kbuild DEV_DAX_PMEM depends on DEV_DAX
Pull perf updates/fixes from Ingo Molnar:
"Mostly tooling updates, but also two kernel fixes: a call chain
handling robustness fix and an x86 PMU driver event definition fix"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/callchain: Force USER_DS when invoking perf_callchain_user()
tools build: Fixup sched_getcpu feature test
perf tests kmod-path: Don't fail if compressed modules aren't supported
perf annotate: Fix AArch64 comment char
perf tools: Fix spelling mistakes
perf/x86: Fix Broadwell-EP DRAM RAPL events
perf config: Refactor a duplicated code for obtaining config file name
perf symbols: Allow user probes on versioned symbols
perf symbols: Accept symbols starting at address 0
tools lib string: Adopt prefixcmp() from perf and subcmd
perf units: Move parse_tag_value() to units.[ch]
perf ui gtk: Move gtk .so name to the only place where it is used
perf tools: Move HAS_BOOL define to where perl headers are used
perf memswap: Split the byteswap memory range wrappers from util.[ch]
perf tools: Move event prototypes from util.h to event.h
perf buildid: Move prototypes from util.h to build-id.h
Pull x86 fixes from Ingo Molnar:
"Misc fixes:
- two boot crash fixes
- unwinder fixes
- kexec related kernel direct mappings enhancements/fixes
- more Clang support quirks
- minor cleanups
- Documentation fixes"
x86/intel_rdt: Fix a typo in Documentation
x86/build: Don't add -maccumulate-outgoing-args w/o compiler support
x86/boot/32: Fix UP boot on Quark and possibly other platforms
x86/mm/32: Set the '__vmalloc_start_set' flag in initmem_init()
x86/kexec/64: Use gbpages for identity mappings if available
x86/mm: Add support for gbpages to kernel_ident_mapping_init()
x86/boot: Declare error() as noreturn
x86/mm/kaslr: Use the _ASM_MUL macro for multiplication to work around Clang incompatibility
x86/mm: Fix boot crash caused by incorrect loop count calculation in sync_global_pgds()
x86/asm: Don't use RBP as a temporary register in csum_partial_copy_generic()
x86/microcode/AMD: Remove redundant NULL check on mc
"This contains two fixes for booting under Xen introduced during this
merge window and two fixes for older problems, where one is just much
more probable due to another merge window change"
* tag 'for-linus-4.12b-rc0c-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen: adjust early dom0 p2m handling to xen hypervisor behavior
x86/amd: don't set X86_BUG_SYSRET_SS_ATTRS when running under Xen
xen/x86: Do not call xen_init_time_ops() until shared_info is initialized
x86/xen: fix xsave capability setting
When booted as pv-guest the p2m list presented by the Xen is already
mapped to virtual addresses. In dom0 case the hypervisor might make use
of 2M- or 1G-pages for this mapping. Unfortunately while being properly
aligned in virtual and machine address space, those pages might not be
aligned properly in guest physical address space.
So when trying to obtain the guest physical address of such a page
pud_pfn() and pmd_pfn() must be avoided as those will mask away guest
physical address bits not being zero in this special case.
Reviewed-by: Jan Beulich <jbeulich@suse.com>
When running as Xen pv guest X86_BUG_SYSRET_SS_ATTRS must not be set
on AMD cpus.
This bug/feature bit is kind of special as it will be used very early
when switching threads. Setting the bit and clearing it a little bit
later leaves a critical window where things can go wrong. This time
window has enlarged a little bit by using setup_clear_cpu_cap() instead
of the hypervisor's set_cpu_features callback. It seems this larger
window now makes it rather easy to hit the problem.
The proper solution is to never set the bit in case of Xen.
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild UAPI updates from Masahiro Yamada:
"Improvement of headers_install by Nicolas Dichtel.
It has been long since the introduction of uapi directories, but the
de-coupling of exported headers has not been completed. Headers listed
in header-y are exported whether they exist in uapi directories or
not. His work fixes this inconsistency.
All (and only) headers under uapi directories are now exported. The
asm-generic wrappers are still exceptions, but this is a big step
forward"
* tag 'kbuild-uapi-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
arch/include: remove empty Kbuild files
uapi: export all arch specifics directories
uapi: export all headers under uapi directories
smc_diag.h: fix include from userland
btrfs_tree.h: fix include from userland
uapi: includes linux/types.h before exporting files
Makefile.headersinst: remove destination-y option
Makefile.headersinst: cleanup input files
x86: stop exporting msr-index.h to userland
nios2: put setup.h in uapi
h8300: put bitsperlong.h in uapi
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"RTC subsystem update:
- Add OF device ID table for i2c drivers
New RTC driver:
- Motorola CPCAP PMIC RTC
RTC driver updates:
- cmos: fix IRQ selection
- ds1307: Add ST m41t0 support
- ds1374: fix watchdog configuration
- sh: Add rza series support"
* tag 'rtc-4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (33 commits)
rtc: gemini: add return value validation
rtc: snvs: fix an incorrect check of return value
rtc: ds1374: wdt: Fix stop/start ioctl always returning -EINVAL
rtc: ds1374: wdt: Fix issue with timeout scaling from secs to wdt ticks
rtc: sh: mark PM functions as unused
rtc: hid-sensor-time: remove some dead code
rtc: m41t80: Add proper compatible for rv4162
rtc: ds1307: Add m41t0 to OF device ID table
rtc: ds1307: support m41t0 variant
rtc: cpcap: fix improper use of IRQ_NONE for request_threaded_irq
rtc: cmos: Do not assume irq 8 for rtc when there are no legacy irqs
x86: i8259: export legacy_pic symbol
dt-bindings: rtc: document the rtc-sh bindings
rtc: sh: add support for rza series
rtc: cpcap: kfreeing devm allocated memory
rtc: wm8350: Remove unused to_wm8350_from_rtc_dev
rtc: cpcap: new rtc driver
dt-bindings: Add vendor prefix for Motorola
rtc: omap: mark PM methods as __maybe_unused
rtc: omap: remove incorrect __exit markups
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull hw lockdown support from David Howells:
"Annotation of module parameters that configure hardware resources
including ioports, iomem addresses, irq lines and dma channels.
This allows a future patch to prohibit the use of such module
parameters to prevent that hardware from being abused to gain access
to the running kernel image as part of locking the kernel down under
UEFI secure boot conditions.
Annotations are made by changing:
module_param(n, t, p)
module_param_named(n, v, t, p)
module_param_array(n, t, m, p)
to:
module_param_hw(n, t, hwtype, p)
module_param_hw_named(n, v, t, hwtype, p)
module_param_hw_array(n, t, hwtype, m, p)
where the module parameter refers to a hardware setting
hwtype specifies the type of the resource being configured. This can
be one of:
ioport Module parameter configures an I/O port
iomem Module parameter configures an I/O mem address
ioport_or_iomem Module parameter could be either (runtime set)
irq Module parameter configures an I/O port
dma Module parameter configures a DMA channel
dma_addr Module parameter configures a DMA buffer address
other Module parameter configures some other value
Note that the hwtype is compile checked, but not currently stored (the
lockdown code probably won't require it). It is, however, there for
future use.
A bonus is that the hwtype can also be used for grepping.
The intention is for the kernel to ignore or reject attempts to set
annotated module parameters if lockdown is enabled. This applies to
options passed on the boot command line, passed to insmod/modprobe or
direct twiddling in /sys/module/ parameter files.
The module initialisation then needs to handle the parameter not being
set, by (1) giving an error, (2) probing for a value or (3) using a
reasonable default.
What I can't do is just reject a module out of hand because it may
take a hardware setting in the module parameters. Some important
modules, some ipmi stuff for instance, both probe for hardware and
allow hardware to be manually specified; if the driver is aborts with
any error, you don't get any ipmi hardware.
Further, trying to do this entirely in the module initialisation code
doesn't protect against sysfs twiddling.
[!] Note that in and of itself, this series of patches should have no
effect on the the size of the kernel or code execution - that is
left to a patch in the next series to effect. It does mark
annotated kernel parameters with a KERNEL_PARAM_FL_HWPARAM flag in
an already existing field"
* tag 'hwparam-20170420' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs: (38 commits)
Annotate hardware config module parameters in sound/pci/
Annotate hardware config module parameters in sound/oss/
Annotate hardware config module parameters in sound/isa/
Annotate hardware config module parameters in sound/drivers/
Annotate hardware config module parameters in fs/pstore/
Annotate hardware config module parameters in drivers/watchdog/
Annotate hardware config module parameters in drivers/video/
Annotate hardware config module parameters in drivers/tty/
Annotate hardware config module parameters in drivers/staging/vme/
Annotate hardware config module parameters in drivers/staging/speakup/
Annotate hardware config module parameters in drivers/staging/media/
Annotate hardware config module parameters in drivers/scsi/
Annotate hardware config module parameters in drivers/pcmcia/
Annotate hardware config module parameters in drivers/pci/hotplug/
Annotate hardware config module parameters in drivers/parport/
Annotate hardware config module parameters in drivers/net/wireless/
Annotate hardware config module parameters in drivers/net/wan/
Annotate hardware config module parameters in drivers/net/irda/
Annotate hardware config module parameters in drivers/net/hamradio/
Annotate hardware config module parameters in drivers/net/ethernet/
Pull more KVM updates from Paolo Bonzini:
"ARM:
- bugfixes
- moved shared 32-bit/64-bit files to virt/kvm/arm
- support for saving/restoring virtual ITS state to userspace
PPC:
- XIVE (eXternal Interrupt Virtualization Engine) support
x86:
- nVMX improvements, including emulated page modification logging
(PML) which brings nice performance improvements on some workloads"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (45 commits)
KVM: arm/arm64: vgic-its: Cleanup after failed ITT restore
KVM: arm/arm64: Don't call map_resources when restoring ITS tables
KVM: arm/arm64: Register ITS iodev when setting base address
KVM: arm/arm64: Get rid of its->initialized field
KVM: arm/arm64: Register iodevs when setting redist base and creating VCPUs
KVM: arm/arm64: Slightly rework kvm_vgic_addr
KVM: arm/arm64: Make vgic_v3_check_base more broadly usable
KVM: arm/arm64: Refactor vgic_register_redist_iodevs
KVM: Add kvm_vcpu_get_idx to get vcpu index in kvm->vcpus
nVMX: Advertise PML to L1 hypervisor
kvm: x86: Add a hook for arch specific dirty logging emulation
kvm: nVMX: Validate CR3 target count on nested VM-entry
KVM: set no_llseek in stat_fops_per_vm
KVM: arm/arm64: vgic: Rename kvm_vgic_vcpu_init to kvm_vgic_vcpu_enable
KVM: arm/arm64: Clarification and relaxation to ITS save/restore ABI
KVM: arm64: vgic-v3: KVM_DEV_ARM_VGIC_SAVE_PENDING_TABLES
KVM: arm64: vgic-its: Fix pending table sync
KVM: arm64: vgic-its: ITT save and restore
KVM: arm64: vgic-its: Device table save/restore
Regularly, when a new header is created in include/uapi/, the developer
forgets to add it in the corresponding Kbuild file. This error is usually
detected after the release is out.
In fact, all headers under uapi directories should be exported, thus it's
useless to have an exhaustive list.
After this patch, the following files, which were not exported, are now
exported (with make headers_install_all):
asm-arc/kvm_para.h
asm-arc/ucontext.h
asm-blackfin/shmparam.h
asm-blackfin/ucontext.h
asm-c6x/shmparam.h
asm-c6x/ucontext.h
asm-cris/kvm_para.h
asm-h8300/shmparam.h
asm-h8300/ucontext.h
asm-hexagon/shmparam.h
asm-m32r/kvm_para.h
asm-m68k/kvm_para.h
asm-m68k/shmparam.h
asm-metag/kvm_para.h
asm-metag/shmparam.h
asm-metag/ucontext.h
asm-mips/hwcap.h
asm-mips/reg.h
asm-mips/ucontext.h
asm-nios2/kvm_para.h
asm-nios2/ucontext.h
asm-openrisc/shmparam.h
asm-parisc/kvm_para.h
asm-powerpc/perf_regs.h
asm-sh/kvm_para.h
asm-sh/ucontext.h
asm-tile/shmparam.h
asm-unicore32/shmparam.h
asm-unicore32/ucontext.h
asm-x86/hwcap2.h
asm-xtensa/kvm_para.h
drm/armada_drm.h
drm/etnaviv_drm.h
drm/vgem_drm.h
linux/aspeed-lpc-ctrl.h
linux/auto_dev-ioctl.h
linux/bcache.h
linux/btrfs_tree.h
linux/can/vxcan.h
linux/cifs/cifs_mount.h
linux/coresight-stm.h
linux/cryptouser.h
linux/fsmap.h
linux/genwqe/genwqe_card.h
linux/hash_info.h
linux/kcm.h
linux/kcov.h
linux/kfd_ioctl.h
linux/lightnvm.h
linux/module.h
linux/nbd-netlink.h
linux/nilfs2_api.h
linux/nilfs2_ondisk.h
linux/nsfs.h
linux/pr.h
linux/qrtr.h
linux/rpmsg.h
linux/sched/types.h
linux/sed-opal.h
linux/smc.h
linux/smc_diag.h
linux/stm.h
linux/switchtec_ioctl.h
linux/vfio_ccw.h
linux/wil6210_uapi.h
rdma/bnxt_re-abi.h
Note that I have removed from this list the files which are generated in every
exported directories (like .install or .install.cmd).
Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all
subdirs with a pure makefile command.
For the record, note that exported files for asm directories are a mix of
files listed by:
- include/uapi/asm-generic/Kbuild.asm;
- arch/<arch>/include/uapi/asm/Kbuild;
- arch/<arch>/include/asm/Kbuild.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Mark Salter <msalter@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Even if this file was not in an uapi directory, it was exported because
it was listed in the Kbuild file.
Fixes: b72e7464e4cf ("x86/uapi: Do not export <asm/msr-index.h> as part of the user API headers")
Suggested-by: Borislav Petkov <bp@alien8.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- code optimizations for the Intel VT-d driver
- ability to switch off a previously enabled Intel IOMMU
- support for 'struct iommu_device' for OMAP, Rockchip and Mediatek
IOMMUs
- header optimizations for IOMMU core code headers and a few fixes that
became necessary in other parts of the kernel because of that
- ACPI/IORT updates and fixes
- Exynos IOMMU optimizations
- updates for the IOMMU dma-api code to bring it closer to use per-cpu
iova caches
- new command-line option to set default domain type allocated by the
iommu core code
- another command line option to allow the Intel IOMMU switched off in
a tboot environment
- ARM/SMMU: TLB sync optimisations for SMMUv2, Support for using an
IDENTITY domain in conjunction with DMA ops, Support for SMR masking,
Support for 16-bit ASIDs (was previously broken)
- various other small fixes and improvements
* tag 'iommu-updates-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (63 commits)
soc/qbman: Move dma-mapping.h include to qman_priv.h
soc/qbman: Fix implicit header dependency now causing build fails
iommu: Remove trace-events include from iommu.h
iommu: Remove pci.h include from trace/events/iommu.h
arm: dma-mapping: Don't override dma_ops in arch_setup_dma_ops()
ACPI/IORT: Fix CONFIG_IOMMU_API dependency
iommu/vt-d: Don't print the failure message when booting non-kdump kernel
iommu: Move report_iommu_fault() to iommu.c
iommu: Include device.h in iommu.h
x86, iommu/vt-d: Add an option to disable Intel IOMMU force on
iommu/arm-smmu: Return IOVA in iova_to_phys when SMMU is bypassed
iommu/arm-smmu: Correct sid to mask
iommu/amd: Fix incorrect error handling in amd_iommu_bind_pasid()
iommu: Make iommu_bus_notifier return NOTIFY_DONE rather than error code
omap3isp: Remove iommu_group related code
iommu/omap: Add iommu-group support
iommu/omap: Make use of 'struct iommu_device'
iommu/omap: Store iommu_dev pointer in arch_data
iommu/omap: Move data structures to omap-iommu.h
iommu/omap: Drop legacy-style device support
Commit 11e63f6d920d added cache flushing for unaligned writes from an
iovec, covering the first and last cache line of a >= 8 byte write and
the first cache line of a < 8 byte write. But an unaligned write of
2-7 bytes can still cover two cache lines, so make sure we flush both
in that case.
Fixes: 11e63f6d920d ("x86, pmem: fix broken __copy_user_nocache ...")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
