path: root/arch/x86/um
2012-02-20x32: Add x32 system calls to syscall/syscall_64.tblH. Peter Anvin
Split the 64-bit system calls into "64" (64-bit only) and "common" (64-bit or x32) and add the x32 system call numbers. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-01-18uml: fix compile for x86-64Linus Torvalds
Randy Dunlap reports that we get arch/x86/um/shared/sysdep/ptrace.h:7:20: error: redefinition of 'regs_return_value' arch/x86/um/shared/sysdep/ptrace.h:7:20: note: previous definition of 'regs_return_value' was here when compiling UML for x86-64. Stephen Rothwell root-caused it and says: "Caused by commit d7e7528bcd45 ("Audit: push audit success and retcode into arch ptrace.h") (another patch that was never in linux-next :-(). This file now needs protection against double inclusion." so let's do as the man says. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Analyzed-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit: (29 commits) audit: no leading space in audit_log_d_path prefix audit: treat s_id as an untrusted string audit: fix signedness bug in audit_log_execve_info() audit: comparison on interprocess fields audit: implement all object interfield comparisons audit: allow interfield comparison between gid and ogid audit: complex interfield comparison helper audit: allow interfield comparison in audit rules Kernel: Audit Support For The ARM Platform audit: do not call audit_getname on error audit: only allow tasks to set their loginuid if it is -1 audit: remove task argument to audit_set_loginuid audit: allow audit matching on inode gid audit: allow matching on obj_uid audit: remove audit_finish_fork as it can't be called audit: reject entry,always rules audit: inline audit_free to simplify the look of generic code audit: drop audit_set_macxattr as it doesn't do anything audit: inline checks for not needing to collect aux records audit: drop some potentially inadvisable likely notations ... Use evil merge to fix up grammar mistakes in Kconfig file. Bad speling and horrible grammar (and copious swearing) is to be expected, but let's keep it to commit messages and comments, rather than expose it to users in config help texts or printouts.
2012-01-17Audit: push audit success and retcode into arch ptrace.hEric Paris
The audit system previously expected arches calling to audit_syscall_exit to supply as arguments if the syscall was a success and what the return code was. Audit also provides a helper AUDITSC_RESULT which was supposed to simplify things by converting from negative retcodes to an audit internal magic value stating success or failure. This helper was wrong and could indicate that a valid pointer returned to userspace was a failed syscall. The fix is to fix the layering foolishness. We now pass audit_syscall_exit a struct pt_reg and it in turns calls back into arch code to collect the return value and to determine if the syscall was a success or failure. We also define a generic is_syscall_success() macro which determines success/failure based on if the value is < -MAX_ERRNO. This works for arches like x86 which do not use a separate mechanism to indicate syscall failure. We make both the is_syscall_success() and regs_return_value() static inlines instead of macros. The reason is because the audit function must take a void* for the regs. (uml calls theirs struct uml_pt_regs instead of just struct pt_regs so audit_syscall_exit can't take a struct pt_regs). Since the audit function takes a void* we need to use static inlines to cast it back to the arch correct structure to dereference it. The other major change is that on some arches, like ia64, MIPS and ppc, we change regs_return_value() to give us the negative value on syscall failure. THE only other user of this macro, kretprobe_example.c, won't notice and it makes the value signed consistently for the audit functions across all archs. In arch/sh/kernel/ptrace_64.c I see that we were using regs[9] in the old audit code as the return value. But the ptrace_64.h code defined the macro regs_return_value() as regs[3]. I have no idea which one is correct, but this patch now uses the regs_return_value() function, so it now uses regs[3]. For powerpc we previously used regs->result but now use the regs_return_value() function which uses regs->gprs[3]. regs->gprs[3] is always positive so the regs_return_value(), much like ia64 makes it negative before calling the audit code when appropriate. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> [for x86 portion] Acked-by: Tony Luck <tony.luck@intel.com> [for ia64] Acked-by: Richard Weinberger <richard@nod.at> [for uml] Acked-by: David S. Miller <davem@davemloft.net> [for sparc] Acked-by: Ralf Baechle <ralf@linux-mips.org> [for mips] Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [for ppc]
2012-01-16Merge branch 'x86-syscall-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-syscall-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Move <asm/asm-offsets.h> from trace_syscalls.c to asm/syscall.h x86, um: Fix typo in 32-bit system call modifications um: Use $(srctree) not $(KBUILD_SRC) x86, um: Mark system call tables readonly x86, um: Use the same style generated syscall tables as native um: Generate headers before generating user-offsets.s um: Run host archheaders, allow use of host generated headers kbuild, headers.sh: Don't make archheaders explicitly x86, syscall: Allow syscall offset to be symbolic x86, syscall: Re-fix typo in comment x86: Simplify syscallhdr.sh x86: Generate system call tables and unistd_*.h from tables checksyscalls: Use arch/x86/syscalls/syscall_32.tbl as source x86: Machine-readable syscall tables and scripts to process them trace: Include <asm/asm-offsets.h> in trace_syscalls.c x86-64, ia32: Move compat_ni_syscall into C and its own file x86-64, syscall: Adjust comment spacing and remove typo kbuild: Add support for an "archheaders" target kbuild: Add support for installing generated asm headers
2012-01-12mm,x86,um: move CMPXCHG_DOUBLE config optionHeiko Carstens
Move CMPXCHG_DOUBLE and rename it to HAVE_CMPXCHG_DOUBLE so architectures can simply select the option if it is supported. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12mm,x86,um: move CMPXCHG_LOCAL config optionHeiko Carstens
Move CMPXCHG_LOCAL and rename it to HAVE_CMPXCHG_LOCAL so architectures can simply select the option if it is supported. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-09x86, um: Fix typo in 32-bit system call modificationsH. Peter Anvin
We override sys_iopl(), not stub_iopl(); the latter is a 64-bitism that doesn't apply to i386 in the first place. Reported-by: Richard Weinberger <richard@nod.at> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-12-05x86, um: Mark system call tables readonlyH. Peter Anvin
Mark the system call tables readonly, as they already are on native, and the 32-bit UM version was in the previous assembly version. The 32-bit version lost it due to copy and paste from the 64-bit version, which was missing the const. Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Link: http://lkml.kernel.org/r/tip-45db1c6176c8171d9ae6fa6d82e07d115a5950ca@git.kernel.org Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2011-12-05x86, um: Use the same style generated syscall tables as nativeH. Peter Anvin
Now when the native kernel uses a single style of generated system call table, follow suite for UML and implement the same style, all in C. This requires __NR_syscall_max and NR_syscalls to be generated; on native this is done in asm-headers.h but that file is common to all UML architectures; therefore put it in user-headers.h instead which already have accommodations for architecture-specific values. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-11-21fix braino in um patchset (mea culpa)Al Viro
wrong register returned... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-06Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scsi: drop unused Kconfig symbol pci: drop unused Kconfig symbol stmmac: drop unused Kconfig symbol x86: drop unused Kconfig symbol powerpc: drop unused Kconfig symbols powerpc: 40x: drop unused Kconfig symbol mips: drop unused Kconfig symbols openrisc: drop unused Kconfig symbols arm: at91: drop unused Kconfig symbol samples: drop unused Kconfig symbol m32r: drop unused Kconfig symbol score: drop unused Kconfig symbols sh: drop unused Kconfig symbol um: drop unused Kconfig symbol sparc: drop unused Kconfig symbol alpha: drop unused Kconfig symbol Fix up trivial conflict in drivers/net/ethernet/stmicro/stmmac/Kconfig as per Michal: the STMMAC_DUAL_MAC config variable is still unused and should be deleted.
2011-11-02um: Fix kmalloc argument order in um/vdso/vma.cDave Jones
kmalloc size is 1st arg, not second. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Richard Weinberger <richard@nod.at> Cc: <stable@kernel.org> # 3.0.x [richard@nod.at: on 3.0 the to be patched file is arch/um/sys-x86_64/vdso/vma.c]
2011-11-02um: we need sys/user.h only on i386Richard Weinberger
2011-11-02um: merge delay_{32,64}.cRichard Weinberger
2011-11-02um: kill system-um.hAl Viro
most of it belonged in irqflags.h, actually Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: segment.h is x86-only and needed only thereAl Viro
2011-11-02um: unify ptrace_user.hAl Viro
2011-11-02um: unify KSTK_...Al Viro
... and switch get_thread_register() to HOST_... for register numbers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: fix gcov build breakageAl Viro
a) exports in gmon_syms.c duplicate kernel/gcov/* ones b) excluding -pg in vdso compile is not enough - -fprofile-arcs and -ftest-coverage also needs to be excluded Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: irq_vectors.h just shadows x86 oneAl Viro
2011-11-02um: required-features.h is there only to shadow x86 one...Al Viro
2011-11-02um: asm/apic.h is there only to shadow the x86 one...Al Viro
... so take it to arch/um/x86/asm. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: take ldt.h to arch/x86/um/asm/mm_context.hAl Viro
it's x86-only and we have no business playing with it in asm/mmu.h; make the latter have struct uml_arch_mm_context arch; instead of struct uml_ldt ldt; and let arch/<subarch>/um/asm/mm_context.h decide what'll be in there. While we are at it, kill host_ldt.h - it's not needed in part of places that include it (we want asm/ldt.h in those) and it can be trivially expanded into the single remaining one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: merge signal_{32,64}.cAl Viro
2011-11-02um: no need to play with save_sp in signal frame setup anymoreAl Viro
2011-11-02um: increase stack growth cushion in pagefaultAl Viro
analog of [PATCH] i386: let usermode execute the "enter" instruction from circa 2006. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: merge HOST_... of registers common on i386 and amd64Al Viro
2011-11-02um: sanitize paths in sys_call_table* includesAl Viro
2011-11-02um: merge os-Linux/tls.c into arch/x86/um/os-Linux/tls.cAl Viro
it's i386-specific; moreover, analogs on other targets have incompatible interface - PTRACE_GET_THREAD_AREA does exist elsewhere, but struct user_desc does *not* Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: move asm/desc.h into arch/x86/um/asmAl Viro
its only purpose is to shadow the x86 asm/desc.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Richard Weinberger <richard@nod.at>
2011-11-02um: merge host_ldt_{32,64}.hAl Viro
2011-11-02um: merge tls_{32,64}.hAl Viro
2011-11-02um: kill shared/task.h and HOST_TASK_REGSAl Viro
2011-11-02um: bury unused macros around ptrace.hAl Viro
2011-11-02um: take arch/um/sys-x86 to arch/x86/umAl Viro
