suspend/resume
A bug was reported that on certain Broadwell platforms, after
resuming from S3, the CPU is running at an anomalously low
speed.
It turns out that the BIOS has modified the value of the
THERM_CONTROL register during S3, and changed it from 0 to 0x10,
thus enabled clock modulation(bit4), but with undefined CPU Duty
Cycle(bit1:3) - which causes the problem.
Here is a simple scenario to reproduce the issue:
1. Boot up the system
2. Get MSR 0x19a, it should be 0
3. Put the system into sleep, then wake it up
4. Get MSR 0x19a, it shows 0x10, while it should be 0
Although some BIOSen want to change the CPU Duty Cycle during
S3, in our case we don't want the BIOS to do any modification.
Fix this issue by introducing a more generic x86 framework to
save/restore specified MSR registers(THERM_CONTROL in this case)
for suspend/resume. This allows us to fix similar bugs in a much
simpler way in the future.
When the kernel wants to protect certain MSRs during suspending,
we simply add a quirk entry in msr_save_dmi_table, and customize
the MSR registers inside the quirk callback, for example:
u32 msr_id_need_to_save[] = {MSR_ID0, MSR_ID1, MSR_ID2...};
and the quirk mechanism ensures that, once resumed from suspend,
the MSRs indicated by these IDs will be restored to their
original, pre-suspend values.
Since both 64-bit and 32-bit kernels are affected, this patch
covers the common 64/32-bit suspend/resume code path. And
because the MSRs specified by the user might not be available or
readable in any situation, we use rdmsrl_safe() to safely save
these MSRs.
Reported-and-tested-by: Marcin Kaszewski <marcin.kaszewski@intel.com>
Signed-off-by: Chen Yu <yu.c.chen@intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: bp@suse.de
Cc: len.brown@intel.com
Cc: linux@horizon.com
Cc: luto@kernel.org
Cc: rjw@rjwysocki.net
Link: http://lkml.kernel.org/r/c9abdcbc173dd2f57e8990e304376f19287e92ba.1448382971.git.yu.c.chen@intel.com
[ More edits to the naming of data structures. ]
modify_ldt() has questionable locking and does not synchronize
threads. Improve it: redesign the locking and synchronize all
threads' LDTs using an IPI on all modifications.
This will dramatically slow down modify_ldt in multithreaded
programs, but there shouldn't be any multithreaded programs that
care about modify_ldt's performance in the first place.
This fixes some fallout from the CVE-2015-5157 fixes.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Andrew Cooper <andrew.cooper3@citrix.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: security@kernel.org <security@kernel.org>
Cc: <stable@vger.kernel.org>
Cc: xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/4c6978476782160600471bd865b318db34c7b628.1438291540.git.luto@kernel.org
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
The main changes in this cycle were:
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
There are a number of FPU internal function prototypes and an inline function
in fpu/api.h, mostly placed so historically as the code grew over the years.
Move them over into fpu/internal.h where they belong. (Add sched.h include
to stackprotector.h which incorrectly relied on getting it from fpu/api.h.)
fpu/api.h is now a pure file that only contains FPU APIs intended for driver
use.
Reviewed-by: Borislav Petkov <bp@alien8.de>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
The suspend code accesses FPU state internals, add a helper for
it and isolate it.
So the 'pcntxt_mask' is a misnomer, it's essentially meaningless to anyone
who doesn't know what it does exactly.
Name it more descriptively as 'xfeatures_mask'.
This unifies all the FPU related header files under a unified, hiearchical
naming scheme:
- asm/fpu/types.h: FPU related data types, needed for 'struct task_struct',
widely included in almost all kernel code, and hence kept
as small as possible.
- asm/fpu/api.h: FPU related 'public' methods exported to other subsystems.
- asm/fpu/internal.h: FPU subsystem internal methods
- asm/fpu/xsave.h: XSAVE support internal methods
(Also standardize the header guard in asm/fpu/internal.h.)
... so that they don't appear in the object file and thus in
objdump output. They're local anyway and have a meaning only
within that file.
No functionality change.
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: linux-pm@vger.kernel.org
Link: http://lkml.kernel.org/r/1428867906-12016-1-git-send-email-bp@alien8.de
It has nothing to do with init -- there's only one TSS per cpu.
Other names considered include:
- current_tss: Confusing because we never switch the tss.
- singleton_tss: Too long.
This patch was generated with 's/init_tss/cpu_tss/g'. Followup
patches will fix INIT_TSS and INIT_TSS_IST by hand.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/da29fb2a793e4f649d93ce2d1ed320ebe8516262.1425611534.git.luto@amacapital.net
Context switches and TLB flushes can change individual bits of CR4.
CR4 reads take several cycles, so store a shadow copy of CR4 in a
per-cpu variable.
To avoid wasting a cache line, I added the CR4 shadow to
cpu_tlbstate, which is already touched in switch_mm. The heaviest
users of the cr4 shadow will be switch_mm and __switch_to_xtra, and
__switch_to_xtra is called shortly after switch_mm during context
switch, so the cacheline is likely to be hot.
Cc: Vince Weaver <vince@deater.net>
Cc: "hillf.zj" <hillf.zj@alibaba-inc.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/3a54dd3353fffbf84804398e00dfdc5b7c1afd7d.1414190806.git.luto@amacapital.net
The different architectures used their own (and different) declarations:
extern __visible const void __nosave_begin, __nosave_end;
extern const void __nosave_begin, __nosave_end;
extern long __nosave_begin, __nosave_end;
Consolidate them using the first variant in <asm/sections.h>.
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
ftrace_stop() is used to stop function tracing during suspend and resume
which removes a lot of possible debugging opportunities with tracing.
The reason was that some function in the resume path was causing a triple
fault if it were to be traced. The issue I found was that doing something
as simple as calling smp_processor_id() would reboot the box!
When function tracing was first created I didn't have a good way to figure
out what function was having issues, or it looked to be multiple ones. To
fix it, we just created a big hammer approach to the problem which was to
add a flag in the mcount trampoline that could be checked and not call
the traced functions.
Lately I developed better ways to find problem functions and I can bisect
down to see what function is causing the issue. I removed the flag that
stopped tracing and proceeded to find the problem function and it ended
up being restore_processor_state(). This function makes sense as when the
CPU comes back online from a suspend it calls this function to set up
registers, amongst them the GS register, which stores things such as
what CPU the processor is (if you call smp_processor_id() without this
set up properly, it would fault).
By making restore_processor_state() notrace, the system can suspend and
resume without the need of the big hammer tracing to stop.
Link: http://lkml.kernel.org/r/3577662.BSnUZfboWb@vostro.rjw.lan
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
As requested by Linus add explicit __visible to the asmlinkage users.
This marks all functions visible to assembler.
Tree sweep for arch/x86/*
Link: http://lkml.kernel.org/r/1398984278-29319-3-git-send-email-andi@firstfloor.org
visible
Link: http://lkml.kernel.org/r/1375740170-7446-16-git-send-email-andi@firstfloor.org
The git commite7a5cd063c7b4c58417f674821d63f5eb6747e37
("x86-64, gdt: Store/load GDT for ACPI S3 or hibernate/resume path
is not needed.") assumes that for the hibernate path the booting
kernel and the resuming kernel MUST be the same. That is certainly
the case for a 32-bit kernel (see check_image_kernel and
CONFIG_ARCH_HIBERNATION_HEADER config option).
However for 64-bit kernels it is OK to have a different kernel
version (and size of the image) of the booting and resuming kernels.
Hence the above mentioned git commit introduces an regression.
This patch fixes it by introducing a 'struct desc_ptr gdt_desc'
back in the 'struct saved_context'. However instead of having in the
'save_processor_state' and 'restore_processor_state' the
store/load_gdt calls, we are only saving the GDT in the
save_processor_state.
For the restore path the lgdt operation is done in
hibernate_asm_[32|64].S in the 'restore_registers' path.
The apt reader of this description will recognize that only 64-bit
kernels need this treatment, not 32-bit. This patch adds the logic
in the 32-bit path to be more similar to 64-bit so that in the future
the unification process can take advantage of this.
[ hpa: this also reverts an inadvertent on-disk format change ]
Suggested-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1367459610-9656-2-git-send-email-konrad.wilk@oracle.com
Pull x86 paravirt update from Ingo Molnar:
"Various paravirtualization related changes - the biggest one makes
guest support optional via CONFIG_HYPERVISOR_GUEST"
* 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, wakeup, sleep: Use pvops functions for changing GDT entries
x86, xen, gdt: Remove the pvops variant of store_gdt.
x86-32, gdt: Store/load GDT for ACPI S3 or hibernation/resume path is not needed
x86-64, gdt: Store/load GDT for ACPI S3 or hibernate/resume path is not needed.
x86: Make Linux guest support optional
x86, Kconfig: Move PARAVIRT_DEBUG into the paravirt menu
We check the TSS descriptor before we try to dereference it.
Also we document what the value '9' actually means using the
AMD64 Architecture Programmer's Manual Volume 2, pg 90:
"Hex value 9: Available 64-bit TSS" and pg 91:
"The available 32-bit TSS (09h), which is redefined as the
available 64-bit TSS."
Without this, on Xen, where the GDT is available as R/O (to
protect the hypervisor from the guest modifying it), we end up
with a pagetable fault.
Link: http://lkml.kernel.org/r/1365194544-14648-5-git-send-email-konrad.wilk@oracle.com
Cc: Rafael J. Wysocki <rjw@sisk.pl>
During the ACPI S3 suspend, we store the GDT in the wakup_header (see
wakeup_asm.s) field called 'pmode_gdt'.
Which is then used during the resume path and has the same exact
value as what the store/load_gdt do with the saved_context
(which is saved/restored via save/restore_processor_state()).
The flow during resume from ACPI S3 is simpler than the 64-bit
counterpart. We only use the early bootstrap once (wakeup_gdt) and
do various checks in real mode.
After the checks are completed, we load the saved GDT ('pmode_gdt') and
continue on with the resume (by heading to startup_32 in trampoline_32.S) -
which quickly jumps to what was saved in 'pmode_entry'
aka 'wakeup_pmode_return'.
The 'wakeup_pmode_return' restores the GDT (saved_gdt) again (which was
saved in do_suspend_lowlevel initially). After that it ends up calling
the 'ret_point' which calls 'restore_processor_state()'.
We have two opportunities to remove code where we restore the same GDT
twice.
Here is the call chain:
wakeup_start
|- lgdtl wakeup_gdt [the work-around broken BIOSes]
| - lgdtl pmode_gdt [the real one]
\-- startup_32 (in trampoline_32.S)
\-- wakeup_pmode_return (in wakeup_32.S)
|- lgdtl saved_gdt [the real one]
\-- ret_point
|- call restore_processor_state
The hibernate path is much simpler. During the saving of the hibernation
image we call save_processor_state() and save the contents of that
along with the rest of the kernel in the hibernation image destination.
We save the EIP of 'restore_registers' (restore_jump_address) and
cr3 (restore_cr3).
During hibernate resume, the 'restore_registers' (via the
'restore_jump_address) in hibernate_asm_32.S is invoked which
restores the contents of most registers. Naturally the resume path benefits
from already being in 32-bit mode, so it does not have to reload the GDT.
It only reloads the cr3 (from restore_cr3) and continues on. Note
that the restoration of the restore image page-tables is done prior to
this.
After the 'restore_registers' it returns and we end up called
restore_processor_state() - where we reload the GDT. The reload of
the GDT is not needed as bootup kernel has already loaded the GDT
which is at the same physical location as the the restored kernel.
Note that the hibernation path assumes the GDT is correct during its
'restore_registers'. The assumption in the code is that the restored
image is the same as saved - meaning we are not trying to restore
an different kernel in the virtual address space of a new kernel.
Link: http://lkml.kernel.org/r/1365194544-14648-3-git-send-email-konrad.wilk@oracle.com
During the ACPI S3 resume path the trampoline code handles it already.
During the ACPI S3 suspend phase (acpi_suspend_lowlevel) we set:
early_gdt_descr.address = (..)get_cpu_gdt_table(smp_processor_id());
which is then used during the resume path and has the same exact
The flow during resume is complex and for 64-bit kernels we use three GDTs
- one early bootstrap GDT (wakeup_igdt) that we load to workaround
broken BIOSes, an early Protected Mode to Long Mode transition one
(tr_gdt), and the final one - early_gdt_descr (which points to the real GDT).
The early ('wakeup_gdt') is loaded in 'trampoline_start' for working
around broken BIOSes, and then when we end up in Protected Mode in the
startup_32 (in trampoline_64.s, not head_32.s) we use the 'tr_gdt'
(still in trampoline_64.s). This 'tr_gdt' has a a 32-bit code segment,
64-bit code segment with L=1, and a 32-bit data segment.
Once we have transitioned from Protected Mode to Long Mode we then
set the GDT to 'early_gdt_desc' and then via an iretq emerge in
wakeup_long64 (set via 'initial_code' variable in acpi_suspend_lowlevel).
In the wakeup_long64 we end up restoring the %rip (which is set to
'resume_point') and jump there.
In 'resume_point' we call 'restore_processor_state' which does
the load_gdt on the saved context. This load_gdt is redundant as the
GDT loaded via early_gdt_desc is the same.
Here is the call-chain:
wakeup_start
\-- trampoline_start (trampoline_64.S)
|- lgdtl tr_gdt
\-- startup_32 (trampoline_64.S)
\-- startup_64 (trampoline_64.S)
\-- secondary_startup_64
|- lgdtl early_gdt_desc
|- movq initial_code(%rip), %eax
|-.. lretq
\-- wakeup_64
|-- other registers are reloaded
|-- call restore_processor_state
image we call save_processor_state() and save the contents of that along
We save the EIP of 'restore_registers' (restore_jump_address) and cr3
(restore_cr3).
'restore_jump_address) in hibernate_asm_64.S is invoked which restores
the contents of most registers. Naturally the resume path benefits from
already being in 64-bit mode, so it does not have to load the GDT.
It only reloads the cr3 (from restore_cr3) and continues on. Note that
the restoration of the restore image page-tables is done prior to this.
the GDT is not needed as bootup kernel has already loaded the GDT which
Link: http://lkml.kernel.org/r/1365194544-14648-2-git-send-email-konrad.wilk@oracle.com
This patch fixes a kernel crash when using precise sampling (PEBS)
after a suspend/resume. Turns out the CPU notifier code is not invoked
on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly
by the kernel and keeps it power-on/resume value of 0 causing any PEBS
measurement to crash when running on CPU0.
The workaround is to add a hook in the actual resume code to restore
the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0,
the DS_AREA will be restored twice but this is harmless.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Stephane Eranian <eranian@google.com>
Explicitly merging these two branches due to nontrivial conflicts and
to allow further work.
Resolved Conflicts:
arch/x86/kernel/head32.c
arch/x86/kernel/head64.c
arch/x86/mm/init_64.c
arch/x86/realmode/init.c
Remove reference to removed function resume_map_numa_kva().
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20130131005616.1C79F411@kernel.stglabs.ibm.com
We should set mappings only for usable memory ranges under max_pfn
Otherwise causes same problem that is fixed by
x86, mm: Only direct map addresses that are marked as E820_RAM
Make it only map range in pfn_mapped array.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Link: http://lkml.kernel.org/r/1359058816-7615-34-git-send-email-yinghai@kernel.org
Cc: Pavel Machek <pavel@ucw.cz>
CONFIG_DEBUG_HOTPLUG_CPU0 is for debugging the CPU0 hotplug feature. The switch
offlines CPU0 as soon as possible and boots userspace up with CPU0 offlined.
User can online CPU0 back after boot time. The default value of the switch is
off.
To debug CPU0 hotplug, you need to enable CPU0 offline/online feature by either
turning on CONFIG_BOOTPARAM_HOTPLUG_CPU0 during compilation or giving
cpu0_hotplug kernel parameter at boot.
It's safe and early place to take down CPU0 after all hotplug notifiers
are installed and SMP is booted.
Please note that some applications or drivers, e.g. some versions of udevd,
during boot time may put CPU0 online again in this CPU0 hotplug debug mode.
In this debug mode, setup_local_APIC() may report a warning on max_loops<=0
when CPU0 is onlined back after boot time. This is because pending interrupt in
IRR can not move to ISR. The warning is not CPU0 specfic and it can happen on
other CPUs as well. It is harmless except the first CPU0 online takes a bit
longer time. And so this debug mode is useful to expose this issue. I'll send
a seperate patch to fix this generic warning issue.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Link: http://lkml.kernel.org/r/1352835171-3958-15-git-send-email-fenghua.yu@intel.com
Because x86 BIOS requires CPU0 to resume from sleep, suspend or hibernate can't
be executed if CPU0 is detected offline. To make suspend or hibernate and
further resume succeed, CPU0 must be online.
Link: http://lkml.kernel.org/r/1352835171-3958-6-git-send-email-fenghua.yu@intel.com
s2ram broke due to this KVM commit:
b74f05d61b73 x86: kvmclock: abstract save/restore sched_clock_state
restore_sched_clock_state() methods use percpu data, therefore
they must run after %gs is initialized, but before mtrr_bp_restore()
(due to lockstat using sched_clock).
Move it to the correct place.
Reported-and-tested-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Avi Kivity <avi@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Pull kvm updates from Avi Kivity:
"Changes include timekeeping improvements, support for assigning host
PCI devices that share interrupt lines, s390 user-controlled guests, a
large ppc update, and random fixes."
This is with the sign-off's fixed, hopefully next merge window we won't
have rebased commits.
* 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits)
KVM: Convert intx_mask_lock to spin lock
KVM: x86: fix kvm_write_tsc() TSC matching thinko
KVM: nVMX: Fix erroneous exception bitmap check
KVM: Ignore the writes to MSR_K7_HWCR(3)
KVM: MMU: make use of ->root_level in reset_rsvds_bits_mask
KVM: PMU: add proper support for fixed counter 2
KVM: PMU: Fix raw event check
KVM: PMU: warn when pin control is set in eventsel msr
KVM: VMX: Fix delayed load of shared MSRs
KVM: use correct tlbs dirty type in cmpxchg
KVM: Allow host IRQ sharing for assigned PCI 2.3 devices
KVM: Ensure all vcpus are consistent with in-kernel irqchip settings
KVM: x86 emulator: Allow PM/VM86 switch during task switch
KVM: SVM: Fix CPL updates
KVM: x86 emulator: VM86 segments must have DPL 3
KVM: x86 emulator: Fix task switch privilege checks
arch/powerpc/kvm/book3s_hv.c: included linux/sched.h twice
KVM: x86 emulator: correctly mask pmc index bits in RDPMC instruction emulation
KVM: mmu_notifier: Flush TLBs before releasing mmu_lock
Disintegrate asm/system.h for X86.
Acked-by: H. Peter Anvin <hpa@zytor.com>
cc: x86@kernel.org
Upon resume from hibernation, CPU 0's hvclock area contains the old
values for system_time and tsc_timestamp. It is necessary for the
hypervisor to update these values with uptodate ones before the CPU uses
them.
Abstract TSC's save/restore sched_clock_state functions and use
restore_state to write to KVM_SYSTEM_TIME MSR, forcing an update.
Also move restore_sched_clock_state before __restore_processor_state,
since the later calls CONFIG_LOCK_STAT's lockstat_clock (also for TSC).
Thanks to Igor Mammedov for tracking it down.
Fixes suspend-to-disk with kvmclock.
Signed-off-by: Avi Kivity <avi@redhat.com>
While various modules include <asm/i387.h> to get access to things we
actually *intend* for them to use, most of that header file was really
pretty low-level internal stuff that we really don't want to expose to
others.
So split the header file into two: the small exported interfaces remain
in <asm/i387.h>, while the internal definitions that are only used by
core architecture code are now in <asm/fpu-internal.h>.
The guiding principle for this was to expose functions that we export to
modules, and leave them in <asm/i387.h>, while stuff that is used by
task switching or was marked GPL-only is in <asm/fpu-internal.h>.
The fpu-internal.h file could be further split up too, especially since
arch/x86/kvm/ uses some of the remaining stuff for its module. But that
kvm usage should probably be abstracted out a bit, and at least now the
internal FPU accessor functions are much more contained. Even if it
isn't perhaps as contained as it _could_ be.
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1202211340330.5354@i5.linux-foundation.org
These files were implicitly getting EXPORT_SYMBOL via device.h
which was including module.h, but that will be fixed up shortly.
By fixing these now, we can avoid seeing things like:
arch/x86/kernel/rtc.c:29: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’
arch/x86/kernel/pci-dma.c:20: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’
arch/x86/kernel/e820.c:69: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL_GPL’
[ with input from Randy Dunlap <rdunlap@xenotime.net> and also
from Stephen Rothwell <sfr@canb.auug.org.au> ]
TSC's get reset after suspend/resume (even on cpu's with invariant TSC
which runs at a constant rate across ACPI P-, C- and T-states). And in
some systems BIOS seem to reinit TSC to arbitrary large value (still
sync'd across cpu's) during resume.
This leads to a scenario of scheduler rq->clock (sched_clock_cpu()) less
than rq->age_stamp (introduced in 2.6.32). This leads to a big value
returned by scale_rt_power() and the resulting big group power set by the
update_group_power() is causing improper load balancing between busy and
idle cpu's after suspend/resume.
This resulted in multi-threaded workloads (like kernel-compilation) go
slower after suspend/resume cycle on core i5 laptops.
Fix this by recomputing cyc2ns_offset's during resume, so that
sched_clock() continues from the point where it was left off during
suspend.
Reported-by: Florian Pritz <flo@xssn.at>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: <stable@kernel.org> # [v2.6.32+]
LKML-Reference: <1282262618.2675.24.camel@sbsiddha-MOBL3.sc.intel.com>
pavel@suse.cz no longer works, replace it with working address.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
Save/restore MISC_ENABLE register on suspend/resume.
This fixes OOPS (invalid opcode) on resume from STR on Asus P4P800-VM,
which wakes up with MWAIT disabled.
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=15385
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Tested-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip:
x86: Fix double enable_IR_x2apic() call on SMP kernel on !SMP boards
x86: Increase CONFIG_NODES_SHIFT max to 10
ibft, x86: Change reserve_ibft_region() to find_ibft_region()
x86, hpet: Fix bug in RTC emulation
x86, hpet: Erratum workaround for read after write of HPET comparator
bootmem, x86: Fix 32bit numa system without RAM on node 0
nobootmem, x86: Fix 32bit numa system without RAM on node 0
x86: Handle overlapping mptables
x86: Make e820_remove_range to handle all covered case
x86-32, resume: do a global tlb flush in S4 resume
Colin King reported a strange oops in S4 resume code path (see below). The test
system has i5/i7 CPU. The kernel doesn't open PAE, so 4M page table is used.
The oops always happen a virtual address 0xc03ff000, which is mapped to the
last 4k of first 4M memory. Doing a global tlb flush fixes the issue.
EIP: 0060:[<c0493a01>] EFLAGS: 00010086 CPU: 0
EIP is at copy_loop+0xe/0x15
EAX: 36aeb000 EBX: 00000000 ECX: 00000400 EDX: f55ad46c
ESI: 0f800000 EDI: c03ff000 EBP: f67fbec4 ESP: f67fbea8
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
CR2: 00000000c03ff000
Tested-by: Colin Ian King <colin.king@canonical.com>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
LKML-Reference: <20100305005932.GA22675@sli10-desk.sh.intel.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch rebase the implementation of the breakpoints API on top of
perf events instances.
Each breakpoints are now perf events that handle the
register scheduling, thread/cpu attachment, etc..
The new layering is now made as follows:
ptrace kgdb ftrace perf syscall
Core breakpoint API /
Breakpoints perf events
Breakpoints PMU ---- Debug Register constraints handling
(Part of core breakpoint API)
Hardware debug registers
Reasons of this rewrite:
- Use the centralized/optimized pmu registers scheduling,
implying an easier arch integration
- More powerful register handling: perf attributes (pinned/flexible
events, exclusive/non-exclusive, tunable period, etc...)
Impact:
- New perf ABI: the hardware breakpoints counters
- Ptrace breakpoints setting remains tricky and still needs some per
thread breakpoints references.
Todo (in the order):
- Support breakpoints perf counter events for perf tools (ie: implement
perf_bpcounter_event())
- Support from perf tools
Changes in v2:
- Follow the perf "event " rename
- The ptrace regression have been fixed (ptrace breakpoint perf events
weren't released when a task ended)
- Drop the struct hw_breakpoint and store generic fields in
perf_event_attr.
- Separate core and arch specific headers, drop
asm-generic/hw_breakpoint.h and create linux/hw_breakpoint.h
- Use new generic len/type for breakpoint
- Handle off case: when breakpoints api is not supported by an arch
Changes in v3:
- Fix broken CONFIG_KVM, we need to propagate the breakpoint api
changes to kvm when we exit the guest and restore the bp registers
to the host.
Changes in v4:
- Drop the hw_breakpoint_restore() stub as it is only used by KVM
- EXPORT_SYMBOL_GPL hw_breakpoint_restore() as KVM can be built as a
module
- Restore the breakpoints unconditionally on kvm guest exit:
TIF_DEBUG_THREAD doesn't anymore cover every cases of running
breakpoints and vcpu->arch.switch_db_regs might not always be
set when the guest used debug registers.
(Waiting for a reliable optimization)
Changes in v5:
- Split-up the asm-generic/hw-breakpoint.h moving to
linux/hw_breakpoint.h into a separate patch
- Optimize the breakpoints restoring while switching from kvm guest
to host. We only want to restore the state if we have active
breakpoints to the host, otherwise we don't care about messed-up
address registers.
- Add asm/hw_breakpoint.h to Kbuild
- Fix bad breakpoint type in trace_selftest.c
Changes in v6:
- Fix wrong header inclusion in trace.h (triggered a build
error with CONFIG_FTRACE_SELFTEST
Cc: Prasad <prasad@linux.vnet.ibm.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jan Kiszka <jan.kiszka@web.de>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
kernel/Makefile
kernel/trace/Makefile
kernel/trace/trace.h
samples/Makefile
Merge reason: We need to be uptodate with the perf events development
branch because we plan to rewrite the breakpoints API on top of
perf events.
Caught by Linus.
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
[ fixed up context conflict manually. ]
arch/Kconfig
Merge reason: resolve the conflicts, plus adopt to the new
ring-buffer APIs.
Reason: Change to is_new_memtype_allowed() in x86/urgent
Resolved semantic conflicts in:
arch/x86/mm/pat.c
arch/x86/mm/ioremap.c
SDM Vol 3a section titled "MTRR considerations in MP systems" specifies
the need for synchronizing the logical cpu's while initializing/updating
MTRR.
Currently Linux kernel does the synchronization of all cpu's only when
a single MTRR register is programmed/updated. During an AP online
(during boot/cpu-online/resume) where we initialize all the MTRR/PAT registers,
we don't follow this synchronization algorithm.
This can lead to scenarios where during a dynamic cpu online, that logical cpu
is initializing MTRR/PAT with cache disabled (cr0.cd=1) etc while other logical
HT sibling continue to run (also with cache disabled because of cr0.cd=1
on its sibling).
Starting from Westmere, VMX transitions with cr0.cd=1 don't work properly
(because of some VMX performance optimizations) and the above scenario
(with one logical cpu doing VMX activity and another logical cpu coming online)
can result in system crash.
Fix the MTRR initialization by doing rendezvous of all the cpus. During
boot and resume, we delay the MTRR/PAT init for APs till all the
logical cpu's come online and the rendezvous process at the end of AP's bringup,
will initialize the MTRR/PAT for all AP's.
For dynamic single cpu online, we synchronize all the logical cpus and
do the MTRR/PAT init on the AP that is coming online.
Patch 08687aec71bc9134fe336e561f6did877bacf74fc0a (x86: unify
power/cpu_(32|64).c) renamed cpu_32.c to cpu.c, but did not update
the special compilation flags for the file for the new name.
This patch fixes the compilation flags, and therefore fixes resume
from suspend on my Acer Aspire One.
[rjw: The regression from 2.6.30 fixed by this patch is tracked as
http://bugzilla.kernel.org/show_bug.cgi?id=13661]
Signed-off-by: Peter Chubb <peterc@nicta.com.au>
Calling mcheck_init() on resume is required only with
CONFIG_X86_OLD_MCE=y.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Acked-by: Andi Kleen <andi@firstfloor.org>
arch/x86/Kconfig
arch/x86/kernel/traps.c
arch/x86/power/cpu.c
arch/x86/power/cpu_32.c
kernel/Makefile
Semantic conflict:
arch/x86/kernel/hw_breakpoint.c
Merge reason: Resolve the conflicts, move from put_cpu_no_sched() to
put_cpu() in arch/x86/kernel/hw_breakpoint.c.
This is the last unification step. Here we do remove one of the files
and rename the left one as cpu.c, as both are now the same.
Also update power/Makefile, telling it to build cpu.o, instead of
cpu_(32|64).o
Signed-off-by: Sergio Luis <sergio@larces.uece.br>
Signed-off-by: Lauro Salmito <laurosalmito@gmail.com>
In this step, we do unify the copyright notes for both files
cpu_32.c and cpu_64.c, making such files exactly the same.
It's the last step before the actual unification, that will
rename one of them to cpu.c and remove the other one.
In this step we do unify cpu_32.c and cpu_64.c functions that
work on restoring the saved processor state. Also, we do
eliminate the forward declaration of fix_processor_context()
for X86_64, as it's not needed anymore.
